[U-Boot] [PATCH 0/4] sunxi: A64/H3/H5 DT updates
This updates the .dts and .dtsi files used in U-Boot to what will become the new DTs in Linux 4.20 (anytime soon). Those updates are not too useful for U-Boot itself, but keep the DTs consistent and allow to directly pass U-Boot's copy to any kernel, by using $fdtcontroladdr. There is a small change in the A64 .dtsi, which breaks compatibility with older kernels (stable releases and those found on distro installer images), so the second patch fixes this by re-adding the missing compatible string to the system controller node. The updates include the H5 and also H3, as they are very close and need to be updated together.
I ran into issues with the H6, so will post an update for that later.
I see that this somewhat overlaps with Vasily's Pinebook series, I am happy to arrange something here. Originally I wanted to wait for the files to hit Linus' tree (to get stable commit IDs), but I sending this now to not block Vasily.
Cheers, Andre.
Andre Przywara (4): sunxi: A64: Update .dts/.dtsi files sunxi: A64: Re-add syscon to DT node sunxi: H3/H5: Update .dts files sunxi: A64: Add Pine64-LTS board
arch/arm/dts/sun50i-a64-amarula-relic.dts | 168 +++++++++++++- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 34 ++- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 89 +++++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 103 ++++++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 179 ++++++++++++++- arch/arm/dts/sun50i-a64-pine64-lts.dts | 13 ++ arch/arm/dts/sun50i-a64-pine64.dts | 32 ++- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 32 ++- arch/arm/dts/sun50i-a64-sopine.dtsi | 15 ++ arch/arm/dts/sun50i-a64.dtsi | 312 ++++++++++++++++++++++++-- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 12 + arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 2 - arch/arm/dts/sun8i-h3.dtsi | 31 +++ arch/arm/dts/sunxi-h3-h5.dtsi | 2 - configs/pine64-lts_defconfig | 19 ++ 15 files changed, 995 insertions(+), 48 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-pine64-lts.dts create mode 100644 configs/pine64-lts_defconfig
Update the .dts/.dtsi file from the Linux sunxi/dt64-for-4.20 tree: commit 679294497be31596e1c9c61507746d72b6b05f26 Author: Rodrigo Exterckötter Tjäder rodrigo@tjader.xyz Date: Wed Sep 26 19:48:24 2018 +0000 arm64: dts: allwinner: a64: a64-olinuxino: set the PHY TX delay
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-amarula-relic.dts | 168 +++++++++++++- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 34 ++- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 89 +++++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 103 ++++++++- arch/arm/dts/sun50i-a64-orangepi-win.dts | 179 ++++++++++++++- arch/arm/dts/sun50i-a64-pine64.dts | 32 ++- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 32 ++- arch/arm/dts/sun50i-a64-sopine.dtsi | 15 ++ arch/arm/dts/sun50i-a64.dtsi | 313 +++++++++++++++++++++++++-- 9 files changed, 920 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-amarula-relic.dts b/arch/arm/dts/sun50i-a64-amarula-relic.dts index f3b4e93ece..6cb2b7f0c8 100644 --- a/arch/arm/dts/sun50i-a64-amarula-relic.dts +++ b/arch/arm/dts/sun50i-a64-amarula-relic.dts @@ -22,11 +22,11 @@ stdout-path = "serial0:115200n8"; };
- reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* WL-PMU-EN: PL2 */ }; };
@@ -34,10 +34,34 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dcdc1>; + /* + * Schematic shows both dldo4 and eldo1 connected for vcc-io-wifi, but + * dldo4 connection shows DNP(Do Not Populate) and eldo1 connected with + * 0Ohm register to vcc-io-wifi so eldo1 is used. + */ + vqmmc-supply = <®_eldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* WL-WAKE-AP: PL3 */ + interrupt-names = "host-wake"; + }; +}; + &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; bus-width = <8>; non-removable; cap-mmc-hw-reset; @@ -48,9 +72,138 @@ status = "okay"; };
+&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + x-powers,drive-vbus-en; /* set N_VBUSEN as output pin */ + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "avdd-csi"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi-dsi-sensor"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo3 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "dovdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
@@ -61,5 +214,6 @@
&usbphy { usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts index 0716b14411..ef1c90401b 100644 --- a/arch/arm/dts/sun50i-a64-bananapi-m64.dts +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -60,6 +60,17 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + leds { compatible = "gpio-leds";
@@ -86,6 +97,10 @@ }; };
+&de { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -103,6 +118,17 @@ status = "okay"; };
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -151,7 +177,7 @@
&mmc2 { pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins>; + pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>; vmmc-supply = <®_dcdc1>; bus-width = <8>; non-removable; @@ -296,9 +322,13 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts index e2dce48fa2..31884dbc88 100644 --- a/arch/arm/dts/sun50i-a64-nanopi-a64.dts +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -51,12 +51,44 @@ compatible = "friendlyarm,nanopi-a64", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "nanopi-a64:blue:status"; + gpios = <&pio 3 24 GPIO_ACTIVE_LOW>; /* PD24 */ + }; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + }; +}; + +&de { + status = "okay"; };
&ehci0 { @@ -67,6 +99,26 @@ status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dcdc1>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + /* i2c1 connected with gpio headers like pine64, bananapi */ &i2c1 { pinctrl-names = "default"; @@ -78,6 +130,13 @@ bias-pull-up; };
+&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -88,6 +147,24 @@ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8189etv: wifi@1 { + reg = <1>; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; +}; + &ohci0 { status = "okay"; }; @@ -125,9 +202,9 @@
®_dcdc1 { regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc-3v"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; };
®_dcdc2 { @@ -195,9 +272,13 @@ regulator-name = "vcc-rtc"; };
diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts index 3b3081b10e..f7a4bccaa5 100644 --- a/arch/arm/dts/sun50i-a64-olinuxino.dts +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -51,6 +51,7 @@ compatible = "olimex,a64-olinuxino", "allwinner,sun50i-a64";
@@ -58,12 +59,74 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 6 9 GPIO_ACTIVE_HIGH>; /* PG9 */ + status = "okay"; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ }; };
+&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dcdc1>; + allwinner,tx-delay-ps = <600>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -92,6 +155,14 @@ }; };
+&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + &r_rsb { status = "okay";
@@ -100,6 +171,7 @@ reg = <0x3a3>; interrupt-parent = <&r_intc>; interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + x-powers,drive-vbus-en; /* set N_VBUSEN as output pin */ }; };
@@ -142,10 +214,14 @@
+/* + * The board uses DDR3L DRAM chips. 1.36V is the closest to the nominal + * 1.35V that the PMIC can drive. + */ ®_dcdc5 { regulator-always-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; + regulator-min-microvolt = <1360000>; + regulator-max-microvolt = <1360000>; regulator-name = "vcc-ddr3"; };
@@ -180,6 +256,11 @@ regulator-name = "vcc-wifi-io"; };
+®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + ®_eldo1 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -214,8 +295,24 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { status = "okay"; + usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_usb1_vbus>; }; diff --git a/arch/arm/dts/sun50i-a64-orangepi-win.dts b/arch/arm/dts/sun50i-a64-orangepi-win.dts index bf42690a33..b0c64f7579 100644 --- a/arch/arm/dts/sun50i-a64-orangepi-win.dts +++ b/arch/arm/dts/sun50i-a64-orangepi-win.dts @@ -1,5 +1,6 @@ /* * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * Copyright (C) 2017-2018 Samuel Holland samuel@sholland.org * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -51,23 +52,127 @@ compatible = "xunlong,orangepi-win", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; };
chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + status { + label = "orangepi:green:status"; + gpios = <&pio 7 11 GPIO_ACTIVE_HIGH>; /* PH11 */ + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 14 GPIO_ACTIVE_HIGH>; /* PD14 */ + status = "okay"; + }; + + reg_usb1_vbus: usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + enable-active-high; + gpio = <&pio 3 7 GPIO_ACTIVE_HIGH>; /* PD7 */ + status = "okay"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 8 GPIO_ACTIVE_LOW>; /* PL8 */ + }; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; };
&ehci1 { status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_gmac_3v3>; + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; vmmc-supply = <®_dcdc1>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_dldo2>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&ohci0 { status = "okay"; };
@@ -89,9 +194,8 @@ #include "axp803.dtsi"
®_aldo1 { - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; regulator-name = "afvcc-csi"; };
@@ -163,12 +267,23 @@ regulator-name = "vcc-wifi-io"; };
+®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + ®_eldo1 { regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-name = "cpvdd"; };
+®_eldo3 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1800000>; + regulator-name = "dvdd-csi"; +}; + ®_fldo1 { regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1200000>; @@ -191,13 +306,65 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + compatible = "mxicy,mx25l1606e", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <80000000>; + m25p,fast-read; + status = "okay"; + }; +}; + +/* On debug connector */ &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
-&usbphy { +/* Bluetooth */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "okay"; +}; + +/* On Pi-2 connector, RTS/CTS optional */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +/* On Pi-2 connector, RTS/CTS optional */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; +}; + +/* On Pi-2 connector (labeled for SPI1), RTS/CTS optional */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; status = "okay"; };
+&usbphy { + usb0_id_det-gpios = <&pio 7 9 GPIO_ACTIVE_HIGH>; /* PH9 */ + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_usb1_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index a75825798a..c077b6c1f4 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -62,6 +62,21 @@ chosen { stdout-path = "serial0:115200n8"; }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; +}; + +&de { + status = "okay"; };
&ehci0 { @@ -82,6 +97,17 @@
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -229,6 +255,10 @@ regulator-name = "vcc-rtc"; };
+&simplefb_hdmi { + vcc-hdmi-supply = <®_dldo1>; +}; + /* On Euler connector */ &spdif { status = "disabled"; @@ -237,7 +267,7 @@ /* On Exp and Euler connectors */ &uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts index abe179de35..53fcc9098d 100644 --- a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts +++ b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts @@ -61,6 +61,17 @@ stdout-path = "serial0:115200n8"; };
+ hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + reg_vcc1v8: vcc1v8 { compatible = "regulator-fixed"; regulator-name = "vcc1v8"; @@ -69,6 +80,10 @@ }; };
+&de { + status = "okay"; +}; + &ehci0 { status = "okay"; }; @@ -86,6 +101,17 @@ status = "okay"; };
+&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &mdio { ext_rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; @@ -134,9 +160,13 @@ regulator-name = "vcc-wifi"; };
diff --git a/arch/arm/dts/sun50i-a64-sopine.dtsi b/arch/arm/dts/sun50i-a64-sopine.dtsi index 43418bd881..6723b8695e 100644 --- a/arch/arm/dts/sun50i-a64-sopine.dtsi +++ b/arch/arm/dts/sun50i-a64-sopine.dtsi @@ -45,6 +45,8 @@
#include "sun50i-a64.dtsi"
+#include <dt-bindings/gpio/gpio.h> + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; @@ -52,6 +54,7 @@ non-removable; disable-wp; bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ status = "okay"; };
@@ -66,6 +69,18 @@ }; };
+&spi0 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <40000000>; + }; +}; + #include "axp803.dtsi"
®_aldo2 { diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 7a083637c4..f3a66f8882 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -43,9 +43,12 @@ */
#include <dt-bindings/clock/sun50i-a64-ccu.h> +#include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/sun50i-a64-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h> +#include <dt-bindings/reset/sun8i-r-ccu.h>
/ { interrupt-parent = <&gic>; @@ -57,17 +60,21 @@ #size-cells = <1>; ranges;
-/* - * The pipeline mixer0-lcd0 depends on clock CLK_MIXER0 from DE2 CCU. - * However there is no support for this clock on A64 yet, so we depend - * on the upstream clocks here to keep them (and thus CLK_MIXER0) up. - */ simplefb_lcd: framebuffer-lcd { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "mixer0-lcd0"; clocks = <&ccu CLK_TCON0>, - <&ccu CLK_DE>, <&ccu CLK_BUS_DE>; + <&display_clocks CLK_MIXER0>; + status = "disabled"; + }; + + simplefb_hdmi: framebuffer-hdmi { + compatible = "allwinner,simple-framebuffer", + "simple-framebuffer"; + allwinner,pipeline = "mixer1-lcd1-hdmi"; + clocks = <&display_clocks CLK_MIXER1>, + <&ccu CLK_TCON1>, <&ccu CLK_HDMI>; status = "disabled"; }; }; @@ -81,6 +88,7 @@ device_type = "cpu"; reg = <0>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu1: cpu@1 { @@ -88,6 +96,7 @@ device_type = "cpu"; reg = <1>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu2: cpu@2 { @@ -95,6 +104,7 @@ device_type = "cpu"; reg = <2>; enable-method = "psci"; + next-level-cache = <&L2>; };
cpu3: cpu@3 { @@ -102,7 +112,20 @@ device_type = "cpu"; reg = <3>; enable-method = "psci"; + next-level-cache = <&L2>; }; + + L2: l2-cache { + compatible = "cache"; + cache-level = <2>; + }; + }; + + de: display-engine { + compatible = "allwinner,sun50i-a64-display-engine"; + allwinner,pipelines = <&mixer0>, + <&mixer1>; + status = "disabled"; };
osc24M: osc24M_clk { @@ -168,10 +191,92 @@ #size-cells = <1>; ranges;
+ de2@1000000 { + compatible = "allwinner,sun50i-a64-de2"; + reg = <0x1000000 0x400000>; + allwinner,sram = <&de2_sram 1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000000 0x400000>; + + display_clocks: clock@0 { + compatible = "allwinner,sun50i-a64-de2-clk"; + reg = <0x0 0x100000>; + clocks = <&ccu CLK_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@100000 { + compatible = "allwinner,sun50i-a64-de2-mixer-0"; + reg = <0x100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + reg = <1>; + + mixer0_out_tcon0: endpoint { + remote-endpoint = <&tcon0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@200000 { + compatible = "allwinner,sun50i-a64-de2-mixer-1"; + reg = <0x200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + + mixer1_out_tcon1: endpoint { + remote-endpoint = <&tcon1_in_mixer1>; + }; + }; + }; + }; + }; + syscon: syscon@1c00000 { - compatible = "allwinner,sun50i-a64-system-controller", - "syscon"; + compatible = "allwinner,sun50i-a64-system-control"; reg = <0x01c00000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_c: sram@18000 { + compatible = "mmio-sram"; + reg = <0x00018000 0x28000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x00018000 0x28000>; + + de2_sram: sram-section@0 { + compatible = "allwinner,sun50i-a64-sram-c"; + reg = <0x0000 0x28000>; + }; + }; };
dma: dma-controller@1c02000 { @@ -185,6 +290,75 @@ #dma-cells = <1>; };
+ tcon0: lcd-controller@1c0c000 { + compatible = "allwinner,sun50i-a64-tcon-lcd", + "allwinner,sun8i-a83t-tcon-lcd"; + reg = <0x01c0c000 0x1000>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON0>, <&ccu CLK_TCON0>; + clock-names = "ahb", "tcon-ch0"; + clock-output-names = "tcon-pixel-clock"; + resets = <&ccu RST_BUS_TCON0>, <&ccu RST_BUS_LVDS>; + reset-names = "lcd", "lvds"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon0_in_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&mixer0_out_tcon0>; + }; + }; + + tcon0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + }; + }; + }; + + tcon1: lcd-controller@1c0d000 { + compatible = "allwinner,sun50i-a64-tcon-tv", + "allwinner,sun8i-a83t-tcon-tv"; + reg = <0x01c0d000 0x1000>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON1>, <&ccu CLK_TCON1>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON1>; + reset-names = "lcd"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon1_in: port@0 { + reg = <0>; + + tcon1_in_mixer1: endpoint { + remote-endpoint = <&mixer1_out_tcon1>; + }; + }; + + tcon1_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon1_out_hdmi: endpoint@1 { + reg = <1>; + remote-endpoint = <&hdmi_in_tcon1>; + }; + }; + }; + }; + mmc0: mmc@1c0f000 { compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c0f000 0x1000>; @@ -227,6 +401,11 @@ #size-cells = <0>; };
+ sid: eeprom@1c14000 { + compatible = "allwinner,sun50i-a64-sid"; + reg = <0x1c14000 0x400>; + }; + usb_otg: usb@1c19000 { compatible = "allwinner,sun8i-a33-musb"; reg = <0x01c19000 0x0400>; @@ -356,7 +535,7 @@ };
mmc2_pins: mmc2-pins { - pins = "PC1", "PC5", "PC6", "PC8", "PC9", + pins = "PC5", "PC6", "PC8", "PC9", "PC10","PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; function = "mmc2"; @@ -364,6 +543,18 @@ bias-pull-up; };
+ mmc2_ds_pin: mmc2-ds-pin { + pins = "PC1"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + + pwm_pin: pwm_pin { + pins = "PD22"; + function = "pwm"; + }; + rmii_pins: rmii_pins { pins = "PD10", "PD11", "PD13", "PD14", "PD17", "PD18", "PD19", "PD20", "PD22", "PD23"; @@ -394,7 +585,7 @@ function = "spi1"; };
- uart0_pins_a: uart0 { + uart0_pb_pins: uart0-pb-pins { pins = "PB8", "PB9"; function = "uart0"; }; @@ -474,15 +665,6 @@ status = "disabled"; };
- pwm: pwm@1c21400 { - compatible = "allwinner,sun50i-a64-pwm", - "allwinner,sun5i-a13-pwm"; - reg = <0x01c21400 0x8>; - clocks = <&osc24M>; - #pwm-cells = <3>; - status = "disabled"; - }; - uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; @@ -617,8 +799,6 @@ clocks = <&ccu CLK_BUS_EMAC>; clock-names = "stmmaceth"; status = "disabled"; - #address-cells = <1>; - #size-cells = <0>;
mdio: mdio { compatible = "snps,dwmac-mdio"; @@ -638,11 +818,69 @@ #interrupt-cells = <3>; };
+ pwm: pwm@1c21400 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01c21400 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + + hdmi: hdmi@1ee0000 { + compatible = "allwinner,sun50i-a64-dw-hdmi", + "allwinner,sun8i-a83t-dw-hdmi"; + reg = <0x01ee0000 0x10000>; + reg-io-width = <1>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_DDC>, + <&ccu CLK_HDMI>; + clock-names = "iahb", "isfr", "tmds"; + resets = <&ccu RST_BUS_HDMI1>; + reset-names = "ctrl"; + phys = <&hdmi_phy>; + phy-names = "hdmi-phy"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi_in: port@0 { + reg = <0>; + + hdmi_in_tcon1: endpoint { + remote-endpoint = <&tcon1_out_hdmi>; + }; + }; + + hdmi_out: port@1 { + reg = <1>; + }; + }; + }; + + hdmi_phy: hdmi-phy@1ef0000 { + compatible = "allwinner,sun50i-a64-hdmi-phy"; + reg = <0x01ef0000 0x10000>; + clocks = <&ccu CLK_BUS_HDMI>, <&ccu CLK_HDMI_DDC>, + <&ccu 7>; + clock-names = "bus", "mod", "pll-0"; + resets = <&ccu RST_BUS_HDMI0>; + reset-names = "phy"; + #phy-cells = <0>; + }; + rtc: rtc@1f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x01f00000 0x54>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "rtc-osc32k", "rtc-osc32k-out"; + clocks = <&osc32k>; + #clock-cells = <1>; };
r_intc: interrupt-controller@1f00c00 { @@ -664,6 +902,29 @@ #reset-cells = <1>; };
+ r_i2c: i2c@1f02400 { + compatible = "allwinner,sun50i-a64-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x01f02400 0x400>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_I2C>; + resets = <&r_ccu RST_APB0_I2C>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + r_pwm: pwm@1f03800 { + compatible = "allwinner,sun50i-a64-pwm", + "allwinner,sun5i-a13-pwm"; + reg = <0x01f03800 0x400>; + clocks = <&osc24M>; + pinctrl-names = "default"; + pinctrl-0 = <&r_pwm_pin>; + #pwm-cells = <3>; + status = "disabled"; + }; + r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun50i-a64-r-pinctrl"; reg = <0x01f02c00 0x400>; @@ -675,6 +936,16 @@ interrupt-controller; #interrupt-cells = <3>;
+ r_i2c_pl89_pins: r-i2c-pl89-pins { + pins = "PL8", "PL9"; + function = "s_i2c"; + }; + + r_pwm_pin: pwm { + pins = "PL10"; + function = "s_pwm"; + }; + r_rsb_pins: rsb { pins = "PL0", "PL1"; function = "s_rsb";
The sun50i-a64.dtsi changes introduced in Linux v4.19-rc1 changed the compatible name for the syscon controller, dropping the generic "syscon" fallback. Using this new DT node will make the Ethernet driver in every older kernel (or non-Linux kernels) fail to initialise the MAC device.
To allow booting distribution kernels (from installer images via UEFI, for instance), re-add the syscon compatible string as a fallback. This works with both older and newer kernels.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64.dtsi | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index f3a66f8882..ff41abc96a 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -259,7 +259,8 @@ };
syscon: syscon@1c00000 { - compatible = "allwinner,sun50i-a64-system-control"; + compatible = "allwinner,sun50i-a64-system-control", + "syscon"; reg = <0x01c00000 0x1000>; #address-cells = <1>; #size-cells = <1>;
Update the .dts/.dtsi files from the Linux sunxi/dt64-for-4.20 tree: commit 679294497be31596e1c9c61507746d72b6b05f26 Author: Rodrigo Exterckötter Tjäder rodrigo@tjader.xyz Date: Wed Sep 26 19:48:24 2018 +0000 arm64: dts: allwinner: a64: a64-olinuxino: set the PHY TX delay
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 12 +++++++++++ arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 2 -- arch/arm/dts/sun8i-h3.dtsi | 31 +++++++++++++++++++++++++++ arch/arm/dts/sunxi-h3-h5.dtsi | 2 -- 4 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts index 98862c7c72..3e0d5a9c09 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts @@ -207,6 +207,18 @@ status = "okay"; };
+&spi0 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <40000000>; + }; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts index e79cf3baf4..1238de25a9 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts @@ -105,7 +105,6 @@ }; };
-/* &spi0 { status = "okay";
@@ -117,7 +116,6 @@ spi-max-frequency = <40000000>; }; }; -*/
&ohci0 { status = "okay"; diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index 41d57c76f2..f0096074a4 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -84,21 +84,30 @@ compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <1>; + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; };
cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <2>; + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; };
cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <3>; + clocks = <&ccu CLK_CPUX>; + clock-names = "cpu"; operating-points-v2 = <&cpu0_opp_table>; + #cooling-cells = <2>; }; };
@@ -111,6 +120,28 @@ };
soc { + system-control@1c00000 { + compatible = "allwinner,sun8i-h3-system-control"; + reg = <0x01c00000 0x30>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_c: sram@1d00000 { + compatible = "mmio-sram"; + reg = <0x01d00000 0x80000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x01d00000 0x80000>; + + ve_sram: sram-section@0 { + compatible = "allwinner,sun8i-h3-sram-c1", + "allwinner,sun4i-a10-sram-c1"; + reg = <0x000000 0x80000>; + }; + }; + }; + mali: gpu@1c40000 { compatible = "allwinner,sun8i-h3-mali", "arm,mali-400"; reg = <0x01c40000 0x10000>; diff --git a/arch/arm/dts/sunxi-h3-h5.dtsi b/arch/arm/dts/sunxi-h3-h5.dtsi index c3bff1105e..fc6131315c 100644 --- a/arch/arm/dts/sunxi-h3-h5.dtsi +++ b/arch/arm/dts/sunxi-h3-h5.dtsi @@ -506,8 +506,6 @@ reset-names = "stmmaceth"; clocks = <&ccu CLK_BUS_EMAC>; clock-names = "stmmaceth"; - #address-cells = <1>; - #size-cells = <0>; status = "disabled";
mdio: mdio {
The Pine64 LTS is an updated version of the Pine64, copying the technical updates from the SoPine platform: LPDDR3 DRAM, eMMC socket and soldered SPI flash chip, even the broken SD card detect pin has been copied. Consequently this leads to the .dts (copied from the kernel) just including the SoPine baseboard .dts, and the defconfig being almost identical. Nevertheless the boards deserves a separate config.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-lts.dts | 13 +++++++++++++ configs/pine64-lts_defconfig | 19 +++++++++++++++++++ 2 files changed, 32 insertions(+) create mode 100644 arch/arm/dts/sun50i-a64-pine64-lts.dts create mode 100644 configs/pine64-lts_defconfig
diff --git a/arch/arm/dts/sun50i-a64-pine64-lts.dts b/arch/arm/dts/sun50i-a64-pine64-lts.dts new file mode 100644 index 0000000000..72d6961dc3 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-pine64-lts.dts @@ -0,0 +1,13 @@ +/* + * SPDX-License-Identifier: (GPL-2.0+ OR MIT) + * + * Copyright (c) 2018 ARM Ltd. + */ + +#include "sun50i-a64-sopine-baseboard.dts" + +/ { + model = "Pine64 LTS"; + compatible = "pine64,pine64-lts", "allwinner,sun50i-r18", + "allwinner,sun50i-a64"; +}; diff --git a/configs/pine64-lts_defconfig b/configs/pine64-lts_defconfig new file mode 100644 index 0000000000..fd3cdeec85 --- /dev/null +++ b/configs/pine64-lts_defconfig @@ -0,0 +1,19 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_SUNXI_DRAM_LPDDR3_STOCK=y +CONFIG_DRAM_CLK=552 +CONFIG_DRAM_ZQ=3881949 +CONFIG_MMC0_CD_PIN="" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_SPL_SPI_SUNXI=y +CONFIG_NR_DRAM_BANKS=1 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-lts" +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
So, does this sync is on top of pinebook dts sync patch[1]? if ie case then we can squash 1/4 with [1] so all sync changes in one commit.
Just merge Andre's patches, I'll rebase mine on top of his and resend.
Marked as "Waiting for Upstream" in patchwork, will push it MW, just send your series on top it.
I've just sent v5, see https://patchwork.ozlabs.org/project/uboot/list/?series=74203
Please note that my series depends on this series.
Cheers, Andre.
Applied to u-boot-sunxi/master
Andre Przywara
Jagan Teki
Maxime Ripard
Vasily Khoruzhick
