[U-Boot-Users] [PATCH 2/3] Initial mpc8610hpcd cpu/, README and include/ files.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: Mahesh Jade mahesh.jade@freescale.com Signed-off-by: Jason Jin Jason.jin@freescale.com Signed-off-by: Jon Loeliger jdl@freescale.com --- cpu/mpc86xx/cpu.c | 15 +- doc/README.mpc8610hpcd | 67 +++++ include/asm-ppc/processor.h | 1 + include/configs/MPC8610HPCD.h | 660 +++++++++++++++++++++++++++++++++++++++++ 4 files changed, 741 insertions(+), 2 deletions(-) create mode 100644 doc/README.mpc8610hpcd create mode 100644 include/configs/MPC8610HPCD.h
diff --git a/cpu/mpc86xx/cpu.c b/cpu/mpc86xx/cpu.c index 9456471..bbc0cd6 100644 --- a/cpu/mpc86xx/cpu.c +++ b/cpu/mpc86xx/cpu.c @@ -41,6 +41,8 @@ checkcpu(void) uint major, minor; uint lcrr; /* local bus clock ratio register */ uint clkdiv; /* clock divider portion of lcrr */ + volatile immap_t *immap = (immap_t *) CFG_IMMR; + volatile ccsr_gur_t *gur = &immap->im_gur;
puts("Freescale PowerPC\n");
@@ -54,8 +56,14 @@ checkcpu(void)
switch (ver) { case PVR_VER(PVR_86xx): - puts("E600"); - break; + { + uint msscr0 = mfspr(MSSCR0); + printf("E600 Core %d", (msscr0 & 0x20) ? 1 : 0 ); + if (gur->pordevsr & MPC86xx_PORDEVSR_CORE1TE) + puts("\n Core1Translation Enabled"); + debug(" (MSSCR0=%x, PORDEVSR=%x)", msscr0, gur->pordevsr); + } + break; default: puts("Unknown"); break; @@ -76,6 +84,9 @@ checkcpu(void) puts("8641"); } break; + case SVR_8610: + puts("8610"); + break; default: puts("Unknown"); break; diff --git a/doc/README.mpc8610hpcd b/doc/README.mpc8610hpcd new file mode 100644 index 0000000..949dcb2 --- /dev/null +++ b/doc/README.mpc8610hpcd @@ -0,0 +1,67 @@ +Freescale MPC8610HPCD board +=========================== + + +Building U-Boot +--------------- + + $ make MPC8610HPCD_config + Configuring for MPC8610HPCD board... + + $ make + + +Flashing U-Boot +--------------- +The flash is 128M starting at 0xF800_0000. + +The alternate image is at 0xFBF0_0000 +The boot image is at 0xFFF0_0000. + + +To Flash U-Boot into the booting bank: + + tftp 1000000 u-boot.bin + protect off all + erase fff00000 +$filesize + cp.b 1000000 fff00000 $filesize + + +To Flash U-boot into the alternate bank + + tftp 1000000 u-boot.bin + erase fbf00000 +$filesize + cp.b 1000000 fbf00000 $filesize + + +pixis_reset command +------------------- +A new command, "pixis_reset", is introduced to reset mpc8610hpcd board +using the FPGA sequencer. When the board restarts, it has the option +of using either the current or alternate flash bank as the boot +image, with or without the watchdog timer enabled, and finally with +or without frequency changes. + +Usage is; + + pixis_reset + pixis_reset altbank + pixis_reset altbank wd + pixis_reset altbank cf <SYSCLK freq> <COREPLL ratio> <MPXPLL ratio> + pixis_reset cf <SYSCLK freq> <COREPLL ratio> <MPXPLL ratio> + +Examples; + + /* reset to current bank, like "reset" command */ + pixis_reset + + /* reset board but use the to alternate flash bank */ + pixis_reset altbank + + /* reset board, use alternate flash bank with watchdog timer enabled*/ + pixis_reset altbank wd + + /* reset board to alternate bank with frequency changed. + * 40 is SYSCLK, 2.5 is COREPLL ratio, 10 is MPXPLL ratio + */ + pixis-reset altbank cf 40 2.5 10 diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 0a160e2..07c1de0 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -875,6 +875,7 @@ #define SVR_8544_E 0x803C #define SVR_8548 0x8031 #define SVR_8548_E 0x8039 +#define SVR_8610 0x80A0 #define SVR_8641 0x8090 #define SVR_8568_E 0x807D
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h new file mode 100644 index 0000000..be3434a --- /dev/null +++ b/include/configs/MPC8610HPCD.h @@ -0,0 +1,660 @@ +/* + * Copyright 2007 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +/* + * MPC8610HPCD board configuration file + * + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_MPC86xx 1 /* MPC86xx */ +#define CONFIG_MPC8610 1 /* MPC8610 specific */ +#define CONFIG_MPC8610HPCD 1 /* MPC8610HPCD board specific */ +#define CONFIG_NUM_CPUS 1 /* Number of CPUs in the system */ +#define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ + +#ifdef RUN_DIAG +#define CFG_DIAG_ADDR 0xff800000 +#endif + +#define CFG_RESET_ADDRESS 0xfff00100 + +#define CONFIG_PCI 1 /* Enable PCI/PCIE*/ +#define CONFIG_PCI1 1 /* PCI controler 1 */ +#define CONFIG_PCIE1 1 /* PCIe 1 connected to ULI bridge */ +#define CONFIG_PCIE2 1 /* PCIe 2 connected to slot */ +#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_SPD_EEPROM /* Use SPD for DDR */ +#undef CONFIG_DDR_DLL /* possible DLL fix needed */ +#define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ +#define CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ + +#define CONFIG_ALTIVEC 1 + +/* + * L2CR setup -- make sure this is right for your board! + */ +#define CFG_L2 +#define L2_INIT 0 +#define L2_ENABLE (L2CR_L2E) + +#ifndef CONFIG_SYS_CLK_FREQ +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) +#endif + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ + +#undef CFG_DRAM_TEST /* memory test, takes time */ +#define CFG_MEMTEST_START 0x00200000 /* memtest region */ +#define CFG_MEMTEST_END 0x00400000 +#define CFG_ALT_MEMTEST + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CFG_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#define CFG_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ +#define CFG_IMMR CFG_CCSRBAR /* PQII uses CFG_IMMR */ + +#define CFG_PCI1_ADDR (CFG_CCSRBAR+0x8000) +#define CFG_PCIE1_ADDR (CFG_CCSRBAR+0xa000) +#define CFG_PCIE2_ADDR (CFG_CCSRBAR+0x9000) + +#define CFG_DIU_ADDR (CFG_CCSRBAR+0x2c000) + +/* + * DDR Setup + */ +#define CFG_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CFG_SDRAM_BASE CFG_DDR_SDRAM_BASE +#define CONFIG_VERY_BIG_RAM + +#define MPC86xx_DDR_SDRAM_CLK_CNTL + +#if defined(CONFIG_SPD_EEPROM) +/* + * Determine DDR configuration from I2C interface. + */ +#define SPD_EEPROM_ADDRESS1 0x51 /* DDR DIMM */ +#else +/* + * Manually set up DDR1 parameters + */ + +#define CFG_SDRAM_SIZE 256 /* DDR is 256MB */ + +#if 0 /* TODO */ +#define CFG_DDR_CS0_BNDS 0x0000000F +#define CFG_DDR_CS0_CONFIG 0x80010202 /* Enable, no interleaving */ +#define CFG_DDR_EXT_REFRESH 0x00000000 +#define CFG_DDR_TIMING_0 0x00260802 +#define CFG_DDR_TIMING_1 0x3935d322 +#define CFG_DDR_TIMING_2 0x14904cc8 +#define CFG_DDR_MODE_1 0x00480432 +#define CFG_DDR_MODE_2 0x00000000 +#define CFG_DDR_INTERVAL 0x06180100 +#define CFG_DDR_DATA_INIT 0xdeadbeef +#define CFG_DDR_CLK_CTRL 0x03800000 +#define CFG_DDR_OCD_CTRL 0x00000000 +#define CFG_DDR_OCD_STATUS 0x00000000 +#define CFG_DDR_CONTROL 0xe3008000 /* Type = DDR2 */ +#define CFG_DDR_CONTROL2 0x04400010 + +#define CFG_DDR_ERR_INT_EN 0x00000000 +#define CFG_DDR_ERR_DIS 0x00000000 +#define CFG_DDR_SBE 0x000f0000 + /* Not used in fixed_sdram function */ +#define CFG_DDR_MODE 0x00000022 +#define CFG_DDR_CS1_BNDS 0x00000000 +#define CFG_DDR_CS2_BNDS 0x00000FFF /* Not done */ +#define CFG_DDR_CS3_BNDS 0x00000FFF /* Not done */ +#define CFG_DDR_CS4_BNDS 0x00000FFF /* Not done */ +#define CFG_DDR_CS5_BNDS 0x00000FFF /* Not done */ +#endif +#endif + +#define CFG_ID_EEPROM +#define ID_EEPROM_ADDR 0x57 + + +#define CFG_FLASH_BASE 0xf0000000 /* start of FLASH 128M */ +#define CFG_FLASH_BASE2 0xf8000000 + +#define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE, CFG_FLASH_BASE2} + +#define CFG_BR0_PRELIM 0xf8001001 /* port size 16bit */ +#define CFG_OR0_PRELIM 0xf8006e65 /* 128MB NOR Flash*/ + +#define CFG_BR1_PRELIM 0xf0001001 /* port size 16bit */ +#define CFG_OR1_PRELIM 0xf8006e65 /* 128MB Promjet */ +#if 0 /* TODO */ +#define CFG_BR2_PRELIM 0xf0000000 +#define CFG_OR2_PRELIM 0xf0000000 /* 256MB NAND Flash - bank 1 */ +#endif +#define CFG_BR3_PRELIM 0xe8000801 /* port size 8bit */ +#define CFG_OR3_PRELIM 0xfff06ff7 /* 1MB PIXIS area*/ + + +#define PIXIS_BASE 0xe8000000 /* PIXIS registers */ +#define PIXIS_ID 0x0 /* Board ID at offset 0 */ +#define PIXIS_VER 0x1 /* Board version at offset 1 */ +#define PIXIS_PVER 0x2 /* PIXIS FPGA version at offset 2 */ +#define PIXIS_RST 0x4 /* PIXIS Reset Control register */ +#define PIXIS_AUX 0x6 /* PIXIS Auxiliary register; Scratch */ +#define PIXIS_SPD 0x7 /* Register for SYSCLK speed */ +#define PIXIS_VCTL 0x10 /* VELA Control Register */ +#define PIXIS_VCFGEN0 0x12 /* VELA Config Enable 0 */ +#define PIXIS_VCFGEN1 0x13 /* VELA Config Enable 1 */ +#define PIXIS_VBOOT 0x16 /* VELA VBOOT Register */ +#define PIXIS_VSPEED0 0x17 /* VELA VSpeed 0 */ +#define PIXIS_VSPEED1 0x18 /* VELA VSpeed 1 */ +#define PIXIS_VCLKH 0x19 /* VELA VCLKH register */ +#define PIXIS_VCLKL 0x1A /* VELA VCLKL register */ + +#define CFG_MAX_FLASH_BANKS 2 /* number of banks */ +#define CFG_MAX_FLASH_SECT 1024 /* sectors per device */ + +#undef CFG_FLASH_CHECKSUM +#define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ +#define CFG_MONITOR_BASE TEXT_BASE /* start of monitor */ + +#define CFG_FLASH_CFI_DRIVER +#define CFG_FLASH_CFI +#define CFG_FLASH_EMPTY_INFO + +#if (CFG_MONITOR_BASE < CFG_FLASH_BASE) +#define CFG_RAMBOOT +#else +#undef CFG_RAMBOOT +#endif + +#if defined(CFG_RAMBOOT) +#undef CONFIG_SPD_EEPROM +#define CFG_SDRAM_SIZE 256 +#endif + +#undef CONFIG_CLOCKS_IN_MHZ + +#define CONFIG_L1_INIT_RAM +#define CFG_INIT_RAM_LOCK 1 +#ifndef CFG_INIT_RAM_LOCK +#define CFG_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#else +#define CFG_INIT_RAM_ADDR 0xe4000000 /* Initial RAM address */ +#endif +#define CFG_INIT_RAM_END 0x4000 /* End of used area in RAM */ + +#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +#define CFG_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ +#define CFG_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CFG_NS16550 +#define CFG_NS16550_SERIAL +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK get_bus_freq(0) + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CFG_NS16550_COM1 (CFG_CCSRBAR+0x4500) +#define CFG_NS16550_COM2 (CFG_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CFG_HUSH_PARSER +#ifdef CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#endif + +/* + * Pass open firmware flat tree to kernel + */ +#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/* maximum size of the flat tree (8K) */ +#define OF_FLAT_TREE_MAX_SIZE 8192 + +#define OF_CPU "PowerPC,8610@0" +#define OF_SOC "soc@e0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc@e0000000/serial@4500" + +#define CFG_64BIT_VSPRINTF 1 +#define CFG_64BIT_STRTOUL 1 + +/* + * I2C + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F +#define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */ +#define CFG_I2C_OFFSET 0x3000 + +/* + * General PCI + * Addresses are mapped 1-1. + */ +#define CFG_PCI1_MEM_BASE 0x80000000 +#define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE +#define CFG_PCI1_MEM_SIZE 0x10000000 /* 256M */ +#define CFG_PCI1_IO_BASE 0x00000000 +#define CFG_PCI1_IO_PHYS 0xe1000000 +#define CFG_PCI1_IO_SIZE 0x00100000 /* 1M */ + +/* PCI view of System Memory */ +#define CFG_PCI_MEMORY_BUS 0x00000000 +#define CFG_PCI_MEMORY_PHYS 0x00000000 +#define CFG_PCI_MEMORY_SIZE 0x80000000 + +/* For RTL8139 */ +#define KSEG1ADDR(x) ({u32 _x = le32_to_cpu(*(u32 *)(x)); (&_x); }) +#define _IO_BASE 0x00000000 + +/* controller 1, Base address 0xa000 */ +#define CFG_PCIE1_MEM_BASE 0xa0000000 +#define CFG_PCIE1_MEM_PHYS CFG_PCIE1_MEM_BASE +#define CFG_PCIE1_MEM_SIZE 0x10000000 /* 256M */ +#define CFG_PCIE1_IO_BASE 0x00000000 +#define CFG_PCIE1_IO_PHYS 0xe3000000 +#define CFG_PCIE1_IO_SIZE 0x00100000 /* 1M */ + +/* controller 2, Base Address 0x9000 */ +#define CFG_PCIE2_MEM_BASE 0x90000000 +#define CFG_PCIE2_MEM_PHYS CFG_PCIE2_MEM_BASE +#define CFG_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CFG_PCIE2_IO_BASE 0x00000000 /* reuse mem LAW */ +#define CFG_PCIE2_IO_PHYS 0xe2000000 +#define CFG_PCIE2_IO_SIZE 0x00100000 /* 1M */ + + +#if defined(CONFIG_PCI) + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ + +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#if 0 /* TODO */ +/* enable onboard uli network support */ +#endif + +#define CONFIG_RTL8139 +#define CONFIG_SK98 +#define CONFIG_EEPRO100 +#define CONFIG_TULIP + +#if 0 /* TODO */ +/************************************************************ + * USB support + ************************************************************/ +#define CONFIG_USB_OHCI 1 +#define CONFIG_USB_KEYBOARD 1 +#define CFG_DEVICE_DEREGISTER +#define CFG_USB_INTERRUPT_POLL 1 +#endif + +#if !defined(CONFIG_PCI_PNP) +#define PCI_ENET0_IOADDR 0xe0000000 +#define PCI_ENET0_MEMADDR 0xe0000000 +#define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ +#endif + +#define CONFIG_DOS_PARTITION +#define CONFIG_SCSI_AHCI + +#ifdef CONFIG_SCSI_AHCI +#define CONFIG_SATA_ULI5288 +#define CFG_SCSI_MAX_SCSI_ID 4 +#define CFG_SCSI_MAX_LUN 1 +#define CFG_SCSI_MAX_DEVICE (CFG_SCSI_MAX_SCSI_ID * CFG_SCSI_MAX_LUN) +#define CFG_SCSI_MAXDEVICE CFG_SCSI_MAX_DEVICE +#endif + +#endif /* CONFIG_PCI */ + +/* + * BAT0 2G Cacheable, non-guarded + * 0x0000_0000 2G DDR + */ +#define CFG_DBAT0L (BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_DBAT0U (BATU_BL_2G | BATU_VS | BATU_VP) +#define CFG_IBAT0L (BATL_PP_RW | BATL_MEMCOHERENCE ) +#define CFG_IBAT0U CFG_DBAT0U + +/* + * BAT1 1G Cache-inhibited, guarded + * 0x8000_0000 256M PCI-1 Memory + * 0xa000_0000 256M PCI-Express 1 Memory + * 0x9000_0000 256M PCI-Express 2 Memory + */ + +#define CFG_DBAT1L (CFG_PCI1_MEM_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT1U (CFG_PCI1_MEM_PHYS | BATU_BL_1G | BATU_VS | BATU_VP) +#define CFG_IBAT1L (CFG_PCI1_MEM_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT1U CFG_DBAT1U + +/* + * BAT2 32M Cache-inhibited, guarded + * 0xe100_0000 1M PCI-1 I/O + * 0xe200_0000 1M PCI-Express 2 I/O + * + */ + +#define CFG_DBAT2L (CFG_PCI1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT2U (CFG_PCI1_IO_PHYS | BATU_BL_32M | BATU_VS | BATU_VP) +#define CFG_IBAT2L (CFG_PCI1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT2U CFG_DBAT2U + +/* + * BAT3 1M Cache-inhibited, guarded + * 0xe300_0000 1M PCI-Express 1 I/O + * + */ + +#define CFG_DBAT3L (CFG_PCIE1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT3U (CFG_PCIE1_IO_PHYS | BATU_BL_1M | BATU_VS | BATU_VP) +#define CFG_IBAT3L (CFG_PCIE1_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT3U CFG_DBAT3U + +/* + * BAT4 4M Cache-inhibited, guarded + * 0xe000_0000 4M CCSR + */ +#define CFG_DBAT4L (CFG_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT4U (CFG_CCSRBAR | BATU_BL_1M | BATU_VS | BATU_VP) +#define CFG_IBAT4L (CFG_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT4U CFG_DBAT4U + +/* + * BAT5 128K Cacheable, non-guarded + * 0xe400_0000 128K Init RAM for stack in the CPU DCache (no backing memory) + */ +#define CFG_DBAT5L (CFG_INIT_RAM_ADDR | BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_DBAT5U (CFG_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CFG_IBAT5L CFG_DBAT5L +#define CFG_IBAT5U CFG_DBAT5U + +/* + * BAT6 256M Cache-inhibited, guarded + * 0xf000_0000 256M FLASH + */ +#define CFG_DBAT6L (CFG_FLASH_BASE | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT6U (CFG_FLASH_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CFG_IBAT6L (CFG_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_IBAT6U CFG_DBAT6U + +/* + * BAT7 4M Cache-inhibited, guarded + * 0xe800_0000 4M PIXIS + */ +#define CFG_DBAT7L (PIXIS_BASE | BATL_PP_RW | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CFG_DBAT7U (PIXIS_BASE | BATU_BL_1M | BATU_VS | BATU_VP) +#define CFG_IBAT7L (PIXIS_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT7U CFG_DBAT7U + + +/* + * Environment + */ +#ifndef CFG_RAMBOOT +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (CFG_MONITOR_BASE + CFG_MONITOR_LEN) +#define CFG_ENV_SECT_SIZE 0x20000 /* 126k (one sector) for env */ +#define CFG_ENV_SIZE 0x2000 +#else +#define CFG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ +#define CFG_ENV_ADDR (CFG_MONITOR_BASE - 0x1000) +#define CFG_ENV_SIZE 0x2000 +#endif + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII + +#if defined(CFG_RAMBOOT) +#undef CONFIG_CMD_ENV +#endif + +#if defined(CONFIG_PCI) +#define CONFIG_CMD_PCI +#define CONFIG_CMD_SCSI +#define CONFIG_CMD_EXT2 +#endif + + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_LOAD_ADDR 0x2000000 /* default load address */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ + +#if defined(CONFIG_CMD_KGDB) +#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ +#define CFG_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/ + +/* Cache Configuration */ +#define CFG_DCACHE_SIZE 32768 +#define CFG_CACHELINE_SIZE 32 +#if defined(CONFIG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ +#endif + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_IPADDR 192.168.1.100 + +#define CONFIG_HOSTNAME unknown +#define CONFIG_ROOTPATH /opt/nfsroot +#define CONFIG_BOOTFILE uImage +#define CONFIG_UBOOTPATH 8610hpcd/u-boot.bin + +#define CONFIG_SERVERIP 192.168.1.1 +#define CONFIG_GATEWAYIP 192.168.1.1 +#define CONFIG_NETMASK 255.255.255.0 + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +#if defined(CONFIG_PCI1) +#define PCI_ENV \ + "pcireg=md ${a}000 3; echo o;md ${a}c00 25; echo i; md ${a}da0 15;" \ + "echo e;md ${a}e00 9\0" \ + "pci1regs=setenv a e0008; run pcireg\0" \ + "pcierr=md ${a}e00 8; pci d.b $b.0 7 1; pci d.w $b.0 1e 1;" \ + "pci d.w $b.0 56 1\0" \ + "pcierrc=mw ${a}e00 ffffffff; pci w.b $b.0 7 ff; pci w.w $b.0 1e ffff;" \ + "pci w.w $b.0 56 ffff\0" \ + "pci1err=setenv a e0008; run pcierr\0" \ + "pci1errc=setenv a e0008; run pcierrc\0" +#else +#define PCI_ENV "" +#endif + +#if defined(CONFIG_PCIE1) || defined(CONFIG_PCIE2) +#define PCIE_ENV \ + "pciereg=md ${a}000 6; md ${a}020 4; md ${a}bf8 2; echo o;md ${a}c00 25;" \ + "echo i; md ${a}da0 15; echo e;md ${a}e00 e; echo d; md ${a}f00 c\0" \ + "pcie1regs=setenv a e000a; run pciereg\0" \ + "pcie2regs=setenv a e0009; run pciereg\0" \ + "pcieerr=md ${a}020 1; md ${a}e00; pci d.b $b.0 7 1; pci d.w $b.0 1e 1;"\ + "pci d.w $b.0 56 1; pci d $b.0 104 1; pci d $b.0 110 1;" \ + "pci d $b.0 130 1\0" \ + "pcieerrc=mw ${a}020 ffffffff; mw ${a}e00 ffffffff; pci w.b $b.0 7 ff;"\ + "pci w.w $b.0 1e ffff; pci w.w $b.0 56 ffff; pci w $b.0 104 ffffffff;" \ + "pci w $b.0 110 ffffffff; pci w $b.0 130 ffffffff\0" \ + "pciecfg=pci d $b.0 0 20; pci d $b.0 100 e; pci d $b.0 400 69\0" \ + "pcie1err=setenv a e000a; run pcieerr\0" \ + "pcie2err=setenv a e0009; run pcieerr\0" \ + "pcie1errc=setenv a e000a; run pcieerrc\0" \ + "pcie2errc=setenv a e0009; run pcieerrc\0" +#else +#define PCIE_ENV "" +#endif + +#define DMA_ENV \ + "dma0=mw ${d}104 ffffffff;mw ${d}110 50000;mw ${d}114 $sad0;mw ${d}118 50000;"\ + "mw ${d}120 $bc0;mw ${d}100 f03c404; mw ${d}11c $dad0; md ${d}100 9\0" \ + "dma1=mw ${d}184 ffffffff;mw ${d}190 50000;mw ${d}194 $sad1;mw ${d}198 50000;"\ + "mw ${d}1a0 $bc1;mw ${d}180 f03c404; mw ${d}19c $dad1; md ${d}180 9\0" \ + "dma2=mw ${d}204 ffffffff;mw ${d}210 50000;mw ${d}214 $sad2;mw ${d}218 50000;"\ + "mw ${d}220 $bc2;mw ${d}200 f03c404; mw ${d}21c $dad2; md ${d}200 9\0" \ + "dma3=mw ${d}284 ffffffff;mw ${d}290 50000;mw ${d}294 $sad3;mw ${d}298 50000;"\ + "mw ${d}2a0 $bc3;mw ${d}280 f03c404; mw ${d}29c $dad3; md ${d}280 9\0" + + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot; " \ + "protect off " MK_STR(TEXT_BASE) " +$filesize; " \ + "erase " MK_STR(TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(TEXT_BASE) " $filesize; " \ + "protect on " MK_STR(TEXT_BASE) " +$filesize; " \ + "cmp.b $loadaddr " MK_STR(TEXT_BASE) " $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=8610hpcd/ramdisk.uboot\0" \ + "dtbaddr=c00000\0" \ + "dtbfile=8610hpcd/mpc8610_hpcd.dtb\0" \ + "bdev=sda3\0" \ + "en-wd=mw.b f8100010 0x08; echo -expect:- 08; md.b f8100010 1\0" \ + "dis-wd=mw.b f8100010 0x00; echo -expect:- 00; md.b f8100010 1\0" \ + "maxcpus=1" \ + "eoi=mw e00400b0 0\0" \ + "iack=md e00400a0 1\0" \ + "ddrreg=md ${a}000 8; md ${a}080 8;md ${a}100 d; md ${a}140 4;" \ + "md ${a}bf0 4; md ${a}e00 3; md ${a}e20 3; md ${a}e40 7;" \ + "md ${a}f00 5\0" \ + "ddr1regs=setenv a e0002; run ddrreg\0" \ + "gureg=md ${a}000 2c; md ${a}0b0 1; md ${a}0c0 1; md ${a}800 1;" \ + "md ${a}900 6; md ${a}a00 1; md ${a}b20 3; md ${a}e00 1;" \ + "md ${a}e60 1; md ${a}ef0 1d\0" \ + "guregs=setenv a e00e0; run gureg\0" \ + "mcmreg=md ${a}000 1b; md ${a}bf8 2; md ${a}e00 5\0" \ + "mcmregs=setenv a e0001; run mcmreg\0" \ + "diuregs=md e002c000 1d\0" \ + "dium=mw e002c01c\0" \ + "diuerr=md e002c014 1\0" \ + "othbootargs=debug\0" \ + "pmregs=md e00e1000 2b\0" \ + "lawregs=md e0000c08 4b\0" \ + "lbcregs=md e0005000 36\0" \ + "dma0regs=md e0021100 12\0" \ + "dma1regs=md e0021180 12\0" \ + "dma2regs=md e0021200 12\0" \ + "dma3regs=md e0021280 12\0" \ + PCI_ENV \ + PCIE_ENV \ + DMA_ENV + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $dtbaddr $dtbfile;" \ + "bootm $loadaddr - $dtbaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $dtbaddr $dtbfile;" \ + "bootm $loadaddr $ramdiskaddr $dtbaddr" + +#define CONFIG_BOOTCOMMAND \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $dtbaddr $dtbfile;" \ + "bootm $loadaddr - $dtbaddr" + +#endif /* __CONFIG_H */
Jon Loeliger
