[PATCH] rockchip: spl: Cache boot source id for later use
Rockchip BROM write a boot source id at CFG_IRAM_BASE + 0x10, the id indicate from what storage media TPL/SPL was loaded from.
SPL use this value to determine what device "same-as-spl" represent when determining from where FIT should be loaded. This works as long as the boot_devices array contain a matching id <-> node path entry.
However, SPL typically load a small part of TF-A into SRAM and on RK3399 this overwrites the CFG_IRAM_BASE + 0x10 addr used for boot source id.
Here boot source id is 3 before FIT images is loaded, and 0 after:
U-Boot SPL 2024.04-rc4 (Mar 15 2024 - 17:26:19 +0000) board_spl_was_booted_from: brom_bootdevice_id 3 maps to '/spi@ff1d0000/flash@0' Trying to boot from SPI ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256+ OK ## Checking hash(es) for Image u-boot ... sha256+ OK ## Checking hash(es) for Image fdt-1 ... sha256+ OK ## Checking hash(es) for Image atf-2 ... sha256+ OK ## Checking hash(es) for Image atf-3 ... sha256+ OK board_spl_was_booted_from: failed to resolve brom_bootdevice_id 0 spl_decode_boot_device: could not find udevice for /mmc@fe330000 spl_decode_boot_device: could not find udevice for /mmc@fe320000 spl_perform_fixups: could not map boot_device to ofpath: -19
Use a static bootdevice_brom_id to cache the boot source id after an initial read from SRAM to fix this, this allow spl_perform_fixups() to resolve correct boot source path for "same-as-spl" after SPL have loaded TF-A related FIT images into memory.
With this the spl-boot-device prop can correctly be resolved to the SPI flash node in the control FDT:
=> fdt addr ${fdtcontroladdr} Working FDT set to f1ee6710 => fdt list /chosen chosen { u-boot,spl-boot-device = "/spi@ff1d0000/flash@0"; stdout-path = "serial2:1500000n8"; u-boot,spl-boot-order = "same-as-spl", "/mmc@fe330000", "/mmc@fe320000"; };
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/mach-rockchip/spl.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 1586a093fc37..27e996b504e7 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -32,9 +32,17 @@ __weak const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = {
const char *board_spl_was_booted_from(void) { - u32 bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + static u32 bootdevice_brom_id; const char *bootdevice_ofpath = NULL;
+ if (!bootdevice_brom_id) + bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + if (!bootdevice_brom_id) { + debug("%s: unknown brom_bootdevice_id %x\n", + __func__, bootdevice_brom_id); + return NULL; + } + if (bootdevice_brom_id < ARRAY_SIZE(boot_devices)) bootdevice_ofpath = boot_devices[bootdevice_brom_id];
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
return NULL;
Hello Jonas,
Please see a few comments below.
s/write/writes/ s/indicate/indicates/
There are also a few more similar small grammar issues in the rest of the patch descroption below.
s/use/uses/ etc.
return NULL;
Maybe it would be better to execute readl(BROM_BOOTSOURCE_ID_ADDR) only once, i.e. to have something like this instead:
+ static u32 bootdevice_brom_id = -1;
+ if (bootdevice_brom_id == -1) { + bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + if (!bootdevice_brom_id) + debug("%s: unknown brom_bootdevice_id %x\n", + __func__, bootdevice_brom_id); + } + + if (!bootdevice_brom_id) /* fail on subsequent tries */ + return NULL; +
The logic behind such an approach would be to try only once and fail on subsequent (re)tries. That way, it would also serve as some kind of a runtime canary test, because the first try should succeed, which may prove useful in the field.
Hi Dragan,
On 2024-03-19 10:44, Dragan Simic wrote:
Hello Jonas,
Thanks, will try to incorporate the grammatical fixes in a v2.
s/use/uses/ etc.
return NULL;
+ static u32 bootdevice_brom_id = -1; + if (bootdevice_brom_id == -1) { + bootdevice_brom_id = readl(BROM_BOOTSOURCE_ID_ADDR); + if (!bootdevice_brom_id) + debug("%s: unknown brom_bootdevice_id %x\n", + __func__, bootdevice_brom_id); + } + + if (!bootdevice_brom_id) /* fail on subsequent tries */ + return NULL; +
If we initialize the static variable to a value it will be stored in the .data section and takes up binary size. With a static variable like in this patch this is instead stored in .bss section and gets initialized to 0 by runtime. 0 is also not a valid boot source id value and the reset value for the reg.
I do not see any point in making the code more complex than it has to be. The reg will contain a known boot source id, 1 - 10, set by BROM or something has gone wrong and the value is not usable any way.
Regards, Jonas
return NULL;
Is it mandatory that this static variable ends up in the .bss section?
As I already described, making the code more complex would intentionally introduce a failure point, which would be triggered in case obtaining valid value from readl() fails the first time. Something like that is usually known as a canary, which I'm sure you already know about.
Hi Jonas,
I'm perplexed. We make use of this spl-boot-device DT property on Puma (RK3399) and Ringneck (PX30) and I am pretty sure I tested it does what it's supposed to do. So that is a bit surprising this seems to not work anymore. Is this related to the BSS/stack memory address location changes you made recently by any chance? Or did I manage to be very lucky for a very long time for our boards?
""" U-Boot SPL 2024.04-rc4-00026-g6ec096a7116-dirty (Mar 19 2024 - 10:50:03 +0100) board_spl_was_booted_from: brom_bootdevice_id 5 maps to '/mmc@fe320000' Trying to boot from MMC2 load_simple_fit: Skip load 'atf-5': image size is 0! NOTICE: BL31: v2.9(release):v2.9.0 NOTICE: BL31: Built : 17:47:58, Jun 21 2023
U-Boot 2024.04-rc4-00026-g6ec096a7116-dirty (Mar 19 2024 - 10:50:03 +0100) [...] => fdt addr ${fdtcontroladdr} Working FDT set to f1f13d10 => fdt list /chosen chosen { u-boot,spl-boot-device = "/mmc@fe320000"; stdout-path = "serial0:115200n8"; u-boot,spl-boot-order = "same-as-spl", "/spi@ff1d0000/flash@0", "/mmc@fe330000", "/mmc@fe320000"; }; """
for Puma when booting from SD card... I don't see board_spl_was_booted_from being called a second time after BL31 is loaded?
mmmmmmm
Very interestingly, when booting from SPI-NOR flash:
""" U-Boot SPL 2024.04-rc4-00026-g6ec096a7116-dirty (Mar 19 2024 - 10:50:03 +0100) board_spl_was_booted_from: brom_bootdevice_id 3 maps to '/spi@ff1d0000/flash@0' Trying to boot from SPI load_simple_fit: Skip load 'atf-5': image size is 0! board_spl_was_booted_from: failed to resolve brom_bootdevice_id 0 NOTICE: BL31: v2.9(release):v2.9.0 NOTICE: BL31: Built : 17:47:58, Jun 21 2023
U-Boot 2024.04-rc4-00026-g6ec096a7116-dirty (Mar 19 2024 - 10:50:03 +0100) [...] => fdt addr ${fdtcontroladdr} Working FDT set to f1f13d10 => fdt list /chosen chosen { u-boot,spl-boot-device = "/spi@ff1d0000/flash@0"; stdout-path = "serial0:115200n8"; u-boot,spl-boot-order = "same-as-spl", "/spi@ff1d0000/flash@0", "/mmc@fe330000", "/mmc@fe320000"; }; """
but the DT is properly written...
Ahah! This is because of one of my commits where I added support for SPI-NOR flashes to spl_perform_fixups. So I think this worked for me because the SPI-NOR flash is explicitly listed in spl-boot-order for Puma, so when same-as-spl fails to resolve, the device is still found in spl-boot-order DT property which means spl_perform_fixup will still be able to write that spl-boot-device DT property. So basically, the issue is related to SPI-NOR flash NOT being explicitly listed in spl-boot-order or/and that the order isn't actually respected because same-as-spl is basically skipped right now (but it works for Puma because the next medium in the list is SPI, so skipping same-as-spl for SPI, would result in checking SPI again :) ).
Can you please add:
Fixes: d57e16c7e712 ("rockchip: find U-boot proper boot device by inverting the logic that sets it")
to the commit log regardless of the implementation we'll go for?
return NULL;
I don't think we absolutely need the second if block, as this would be handled by the else part of the if block that isn't shown in this git context.
Also, I would suggest to add a new entry to the BROM_BOOTSOURCE_* enum, e.g. BROM_BOOTSOURCE_INVALID/UNKNOWN = 0 so it's a bit more explicit and we're also "ready" for the day Rockchip decides to use 0 as a valid BROM boot source so we know all the places we need to modify the logic.
Moreover, I join Dragan over the use of a "valid" value for deciding to read from the RAM... but for another reason. If it actually is 0 for some reason, we would re-read from that address in RAM until we get something different from 0... which may happen to be written with something else than 0 when loading that small part of TF-A into SRAM? So we would then have something completely unexpected as boot source now.
Cheers, Quentin
Hello Quentin,
mmmmmmm
This was a very nice read, thanks for writing it down in detail! :)
Can you please add:
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 1586a093fc37..27e996b504e7 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -32,9 +32,17 @@ __weak const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { const char *board_spl_was_booted_from(void) {
- static u32 bootdevice_brom_id; const char *bootdevice_ofpath = NULL;
- if (!bootdevice_brom_id)
- if (!bootdevice_brom_id) {
return NULL;
Having a separate if + debug() message would be fine if we opt for the "runtime canary test" approach I suggested a bit earlier. If we opt for a different approach, I agree that a separate if + debug() would be pretty much redundant.
Good point. I didn't have that in mind, but using a totally invalid value to determine uninitialized state is pretty much always a good approach that may also prevent unforeseen issues.
Hi Quentin,
Hi Jonas,
As you figured out below, this is currently only an issue with SPI flash because it was only the SPI flash code path that re-used boot source id after FIT images have been loaded into memory.
mmmmmmm
Correct, as long as the spi flash node was added to the spl-boot-order there has not been any noticeable issue.
TF-A overwriting the boot source id reg is something I have only seen on RK3399 so far. I think this is not an issue on RK3328 and RK35xx, but I could be wrong.
It was only when testing the SPI flash patches for ROCK Pi 4 and my suggestion to drop the explicit listing of the flash node that I noticed that there was something not working correctly with the same-as-spl code path.
Can you please add:
Sure, I will include a fixes tag in a v2.
return NULL;
Correct, it is technically not needed, it was mostly added there was an effort to clean up boot source related debug messages in spl-boot-order.c and this adds a different grepable debug message.
Agree, I will add a BROM_BOOTSOURCE_INVALID and change debug message to invalid instead of unknown in v2.
1 - 10 is the only expected valid boot source id, anything else would be considered invalid and is ignored.
The intent of this patch was to cache the first valid boot source id that is read back from the reg, technically it currently also cache invalid values, will fix that in a v2.
I have only seen the reg being overwritten to 0 for both open source and RK TF-A on RK3399. And with current intended use of the function the value is always read at least once before FIT images is loaded so I am not that concerned that we will end up with a wrong or bad value.
Regards, Jonas
Cheers, Quentin
Dragan Simic
Jonas Karlman
Kever Yang
Quentin Schulz
