[U-Boot] [PATCH] spieval: Remove remainders of dead board
Commit 69434e4c deleted spieval board support but it missed to clean up include/configs/spieval.h file.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- include/configs/spieval.h | 494 ---------------------------------------------- 1 file changed, 494 deletions(-) delete mode 100644 include/configs/spieval.h
diff --git a/include/configs/spieval.h b/include/configs/spieval.h deleted file mode 100644 index 07668de..0000000 --- a/include/configs/spieval.h +++ /dev/null @@ -1,494 +0,0 @@ -/* - * (C) Copyright 2003-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2004-2005 - * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ -#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ -#define CONFIG_TQM5200 1 /* ... on TQM5200 module */ -#undef CONFIG_TQM5200_REV100 /* define for revision 100 modules */ -#define CONFIG_STK52XX 1 /* ... on a STK52XX base board */ -#define CONFIG_STK52XX_REV100 1 /* define for revision 100 baseboards */ - -#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ - -/* - * Serial console configuration - */ -#define CONFIG_PSC_CONSOLE 6 /* console is on PSC6 */ -#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -#ifdef CONFIG_STK52XX -#undef CONFIG_PS2KBD /* AT-PS/2 Keyboard */ -#define CONFIG_PS2MULT /* .. on PS/2 Multiplexer */ -#define CONFIG_PS2SERIAL 6 /* .. on PSC6 */ -#define CONFIG_PS2MULT_DELAY (CONFIG_SYS_HZ/2) /* Initial delay */ -#define CONFIG_BOARD_EARLY_INIT_R -#endif /* CONFIG_STK52XX */ - -/* - * PCI Mapping: - * 0x40000000 - 0x4fffffff - PCI Memory - * 0x50000000 - 0x50ffffff - PCI IO Space - */ -#ifdef CONFIG_STK52XX -#define CONFIG_PCI 1 -#define CONFIG_PCI_PNP 1 -/* #define CONFIG_PCI_SCAN_SHOW 1 */ - -#define CONFIG_PCI_MEM_BUS 0x40000000 -#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS -#define CONFIG_PCI_MEM_SIZE 0x10000000 - -#define CONFIG_PCI_IO_BUS 0x50000000 -#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS -#define CONFIG_PCI_IO_SIZE 0x01000000 - -#define CONFIG_EEPRO100 1 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#define CONFIG_NS8382X 1 -#endif /* CONFIG_STK52XX */ - -/* - * Video console - */ -#if 1 -#define CONFIG_VIDEO -#define CONFIG_VIDEO_SM501 -#define CONFIG_VIDEO_SM501_32BPP -#define CONFIG_CFB_CONSOLE -#define CONFIG_VIDEO_LOGO -#define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_SPLASH_SCREEN -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#endif - -/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION - -/* USB */ -#ifdef CONFIG_STK52XX -#define CONFIG_USB_OHCI -#define CONFIG_USB_STORAGE -#endif - -/* POST support */ -#define CONFIG_POST (CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_I2C) - -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define MPC5XXX_SRAM_POST_SIZE MPC5XXX_SRAM_SIZE-4 -#endif - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP - -#if defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) - #define CONFIG_CMD_IDE - #define CONFIG_CMD_FAT - #define CONFIG_CMD_EXT2 -#endif - -#ifdef CONFIG_STK52XX - #define CONFIG_CMD_USB - #define CONFIG_CMD_FAT -#endif - -#ifdef CONFIG_VIDEO - #define CONFIG_CMD_BMP -#endif - -#ifdef CONFIG_PCI - #define CONFIG_CMD_PCI - #define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE 1 -#endif - -#ifdef CONFIG_POST -#define CONFIG_CMD_DIAG -#endif - - -#define CONFIG_TIMESTAMP /* display image timestamps */ - -#if (CONFIG_SYS_TEXT_BASE == 0xFC000000) /* Boot low */ -# define CONFIG_SYS_LOWBOOT 1 -#endif - -/* - * Autobooting - */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "rootpath=/opt/eldk/ppc_6xx\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "bootfile=/tftpboot/tqm5200/uImage\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "u-boot=/tftpboot/tqm5200/u-boot.bin\0" \ - "update=protect off FC000000 FC05FFFF;" \ - "erase FC000000 FC05FFFF;" \ - "cp.b 200000 FC000000 ${filesize};" \ - "protect on FC000000 FC05FFFF\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" - -/* - * IPB Bus clocking configuration. - */ -#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ - -#if defined(CONFIG_SYS_IPBCLK_EQUALS_XLBCLK) -/* - * PCI Bus clocking configuration - * - * Actually a PCI Clock of 66 MHz is only set (in cpu_init.c) if - * CONFIG_SYS_IPBCLK_EQUALS_XLBCLK is defined. This is because a PCI Clock - * of 66 MHz yet hasn't been tested with a IPB Bus Clock of 66 MHz. - */ -#define CONFIG_SYS_PCICLK_EQUALS_IPBCLK_DIV2 /* define for 66MHz speed */ -#endif - -/* - * I2C configuration - */ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ -#ifdef CONFIG_TQM5200_REV100 -#define CONFIG_SYS_I2C_MODULE 1 /* Select I2C module #1 for rev. 100 board */ -#else -#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #2 for all other revs */ -#endif - -/* - * I2C clock frequency - * - * Please notice, that the resulting clock frequency could differ from the - * configured value. This is because the I2C clock is derived from system - * clock over a frequency divider with only a few divider values. U-boot - * calculates the best approximation for CONFIG_SYS_I2C_SPEED. However the calculated - * approximation allways lies below the configured value, never above. - */ -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -/* - * EEPROM configuration for onboard EEPROM M24C32 (M24C64 should work - * also). For other EEPROMs configuration should be verified. On Mini-FAP the - * EEPROM (24C64) is on the same I2C address (but on other I2C bus), so the - * same configuration could be used. - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* 1010000x */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* =32 Bytes per write */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 - -/* - * HW-Monitor configuration on Mini-FAP - */ -#if defined (CONFIG_MINIFAP) -#define CONFIG_SYS_I2C_HWMON_ADDR 0x2C -#endif - -/* List of I2C addresses to be verified by POST */ -#if defined (CONFIG_MINIFAP) -#undef CONFIG_SYS_POST_I2C_ADDRS -#define CONFIG_SYS_POST_I2C_ADDRS {CONFIG_SYS_I2C_EEPROM_ADDR, \ - CONFIG_SYS_I2C_HWMON_ADDR, \ - CONFIG_SYS_I2C_SLAVE} -#endif - -/* - * Flash configuration - */ -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE /* 0xFC000000 */ - -/* use CFI flash driver if no module variant is spezified */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_BOOTCS_START } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MByte */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ -#undef CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* not supported yet for AMD */ - -#if !defined(CONFIG_SYS_LOWBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00760000 + 0x00800000) -#else /* CONFIG_SYS_LOWBOOT */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00060000) -#endif /* CONFIG_SYS_LOWBOOT */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks - (= chip selects) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - - -/* - * Environment settings - */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/* - * Memory map - */ -#define CONFIG_SYS_MBAR 0xF0000000 -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 - -/* Use ON-Chip SRAM until RAM will be available */ -#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE -#else -#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE -#endif - - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT 1 -#endif - -#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* Reserve 384 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * Ethernet configuration - */ -#define CONFIG_MPC5xxx_FEC 1 -/* - * Define CONFIG_FEC_10MBIT to force FEC at 10Mb - */ -/* #define CONFIG_FEC_10MBIT 1 */ -#define CONFIG_PHY_ADDR 0x00 - -/* - * GPIO configuration - * - * use pin gpio_wkup_6 as second SDRAM chip select (mem_cs1): - * Bit 0 (mask: 0x80000000): 1 - * use ALT CAN position: Bits 2-3 (mask: 0x30000000): - * 00 -> No Alternatives, CAN1/2 on PSC2 according to PSC2 setting. - * 01 -> CAN1 on I2C1, CAN2 on Tmr0/1. - * Use for REV200 STK52XX boards. Do not use with REV100 modules - * (because, there I2C1 is used as I2C bus) - * use PSC1 as UART: Bits 28-31 (mask: 0x00000007): 0100 - * use PSC2 as CAN: Bits 25:27 (mask: 0x00000030) - * 000 -> All PSC2 pins are GIOPs - * 001 -> CAN1/2 on PSC2 pins - * Use for REV100 STK52xx boards - * use PSC6: - * on STK52xx: - * use as UART. Pins PSC6_0 to PSC6_3 are used. - * Bits 9:11 (mask: 0x00700000): - * 101 -> PSC6 : Extended POST test is not available - * on MINI-FAP and TQM5200_IB: - * use PSC6_0 to PSC6_3 as GPIO: Bits 9:11 (mask: 0x00700000): - * 000 -> PSC6 could not be used as UART, CODEC or IrDA - * GPIO on PSC6_3 is used in post_hotkeys_pressed() to enable extended POST - * tests. - */ -#if defined (CONFIG_MINIFAP) -# define CONFIG_SYS_GPS_PORT_CONFIG 0x91000004 -#elif defined (CONFIG_STK52XX) -# if defined (CONFIG_STK52XX_REV100) -# define CONFIG_SYS_GPS_PORT_CONFIG 0x81500014 -# else /* STK52xx REV200 and above */ -# if defined (CONFIG_TQM5200_REV100) -# error TQM5200 REV100 not supported on STK52XX REV200 or above -# else/* TQM5200 REV200 and above */ -# define CONFIG_SYS_GPS_PORT_CONFIG 0x91500004 -# endif -# endif -#else /* TMQ5200 Inbetriebnahme-Board */ -# define CONFIG_SYS_GPS_PORT_CONFIG 0x81000004 -#endif - -/* - * RTC configuration - */ -#define CONFIG_RTC_MPC5200 1 /* use internal MPC5200 RTC */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* Enable an alternate, more extensive memory test */ -#define CONFIG_SYS_ALT_MEMTEST - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* - * Various low-level settings - */ -#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI -#define CONFIG_SYS_HID0_FINAL HID0_ICE - -#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE -#ifdef CONFIG_SYS_PCICLK_EQUALS_IPBCLK_DIV2 -#define CONFIG_SYS_BOOTCS_CFG 0x0008DF30 /* for pci_clk = 66 MHz */ -#else -#define CONFIG_SYS_BOOTCS_CFG 0x0004DF30 /* for pci_clk = 33 MHz */ -#endif -#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE - -#define CONFIG_LAST_STAGE_INIT - -/* - * SRAM - Do not map below 2 GB in address space, because this area is used - * for SDRAM autosizing. - */ -#define CONFIG_SYS_CS2_START 0xE5000000 -#define CONFIG_SYS_CS2_SIZE 0x100000 /* 1 MByte */ -#define CONFIG_SYS_CS2_CFG 0x0004D930 - -/* - * Grafic controller - Do not map below 2 GB in address space, because this - * area is used for SDRAM autosizing. - */ -#define SM501_FB_BASE 0xE0000000 -#define CONFIG_SYS_CS1_START (SM501_FB_BASE) -#define CONFIG_SYS_CS1_SIZE 0x4000000 /* 64 MByte */ -#define CONFIG_SYS_CS1_CFG 0x8F48FF70 -#define SM501_MMIO_BASE CONFIG_SYS_CS1_START + 0x03E00000 - -#define CONFIG_SYS_CS_BURST 0x00000000 -#define CONFIG_SYS_CS_DEADCYCLE 0x33333311 /* 1 dead cycle for flash and SM501 */ - -#define CONFIG_SYS_RESET_ADDRESS 0xff000000 - -/*----------------------------------------------------------------------- - * USB stuff - *----------------------------------------------------------------------- - */ -#define CONFIG_USB_CLOCK 0x0001BBBB -#define CONFIG_USB_CONFIG 0x00001000 - -/*----------------------------------------------------------------------- - * IDE/ATA stuff Supports IDE harddisk - *----------------------------------------------------------------------- - */ - -#undef CONFIG_IDE_8xx_PCCARD /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_LED /* LED for ide not supported */ - -#define CONFIG_IDE_RESET /* reset for ide supported */ -#define CONFIG_IDE_PREINIT - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 2 /* max. 2 drives per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) - -/* Interval between registers */ -#define CONFIG_SYS_ATA_STRIDE 4 - -#endif /* __CONFIG_H */
Masahiro Yamada
