[U-Boot] [RFC][PATCH 2b/3] New i386 board (includes code relocation)
Split to meet mailing list size limit
Initial addition of eNET files - builds clean but will not run until additional i386 code changes are made
Signed-off-by: Graeme Russ graeme.russ@gmail.com
-- diff --git a/board/eNET/fpga.c b/board/eNET/fpga.c new file mode 100644 index 0000000..a3e4677 --- /dev/null +++ b/board/eNET/fpga.c @@ -0,0 +1,149 @@ +/* + * (C) Copyright 2002 + * Wolfgang Grandegger, DENX Software Engineering, wg@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#include <common.h> +#include <command.h> +#include <linux/ctype.h> +#include <asm/ic/sc520.h> +#include <asm/ic/ssi.h> +#include <watchdog.h> +#include <asm/io.h> + +#include "fpga.h" + +static u8 fpga_init(void); +static u8 fpga_write(void *buf, size_t bsize); +static u8 fpga_finalise(void); +static void fpga_close(void); + + +int fpga_load(int devnum, void *buf, size_t bsize ) +{ + u8 ret = FPGA_SUCCESS; + + WATCHDOG_RESET(); + + ret = fpga_init(); + + if (ret == FPGA_SUCCESS) { + ret = fpga_write(buf, bsize); + } + + if (ret == FPGA_SUCCESS) { + ret = fpga_finalise(); + } + + fpga_close(); + + WATCHDOG_RESET(); + + return ret; +} + + +static u8 fpga_init(void) +{ + u8 ret = FPGA_FAIL_INIT; + u16 state = 0x0000; + + /* + * Drop then raise the FPGA's program bit + */ + writew(CFG_FPGA_PROGRAM_PIO_BIT, CFG_FPGA_PIO_CLR); + udelay(CFG_FPGA_PROGRAM_BIT_DROP_TIME * 1000); + writew(CFG_FPGA_PROGRAM_PIO_BIT, CFG_FPGA_PIO_SET); + + reset_timer(); + + while (get_timer(0) < CFG_FPGA_MAX_INIT_TIME) { + /* + * Check if the FPGA has raised its initialized bit + */ + state = readw(CFG_FPGA_PIO_DATA); + + if (state & CFG_FPGA_INIT_PIO_BIT) { + ret = FPGA_SUCCESS; + goto Done; + } + + udelay (10); + } + +Done: + return ret; +} + + +static u8 fpga_write(void *buf, size_t bsize) +{ + u8 *ptr = (u8 *) buf; + + /* + * Stream the buffer to the FPGA using the SSI + */ + ssi_set_interface(CFG_FPGA_SSI_DATA_RATE, 0, 0, 0); + + /* + * TODO: Can ssi_tx_byte() fail (port busy)? + */ + while (bsize--) + ssi_tx_byte (*ptr); + + return FPGA_SUCCESS; +} + + +static u8 fpga_finalise(void) +{ + u8 ret = FPGA_FAIL_FINALISE; + u16 state = 0x0000; + + reset_timer(); + + while (get_timer(0) < CFG_FPGA_MAX_FINALISE_TIME) { + state = readw(CFG_FPGA_PIO_DATA); + + if (state & CFG_FPGA_DONE_PIO_BIT) { + ret = FPGA_SUCCESS; + goto Done; + } + + udelay (10); + } + +Done: + return ret; +} + +static void fpga_close(void) +{ + u16 dirs = readw(CFG_FPGA_PIO_DIRECTION); + + /* + * Set the program pin of the FPGA to be an input (high impedance) + */ + dirs &= ~CFG_FPGA_PROGRAM_PIO_BIT; + + writew(dirs, CFG_FPGA_PIO_DIRECTION); +} diff --git a/board/eNET/fpga.h b/board/eNET/fpga.h new file mode 100644 index 0000000..a4db321 --- /dev/null +++ b/board/eNET/fpga.h @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Graeme Russ, graeme.russ@gmail.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +#ifndef _FPGA_H_ +#define _FPGA_H_ + +#define FPGA_SUCCESS 0 +#define FPGA_FAIL_INIT 1 +#define FPGA_FAIL_FINALISE 2 +#define FPGA_FAIL_START 3 + + + +int fpga_load( int devnum, void *buf, size_t bsize ); + +#endif /* _FPGA_H_ */ diff --git a/board/eNET/hardware.h b/board/eNET/hardware.h new file mode 100644 index 0000000..eab612c --- /dev/null +++ b/board/eNET/hardware.h @@ -0,0 +1,13 @@ +/* + * hardware.h + * + * Created on: 17/09/2008 + * Author: graeme + */ + +#ifndef HARDWARE_H_ +#define HARDWARE_H_ + +#include "hardware_defs.h" + +#endif /* HARDWARE_H_ */ diff --git a/board/eNET/hardware_defs.h b/board/eNET/hardware_defs.h new file mode 100644 index 0000000..2ffa008 --- /dev/null +++ b/board/eNET/hardware_defs.h @@ -0,0 +1,19 @@ +/* + * hardware.h + * + * Created on: 11/09/2008 + * Author: graeme + */ + +#ifndef HARDWARE_DEFS_H_ +#define HARDWARE_DEFS_H_ + +#define LED_LATCH_ADDRESS 0x1002 +#define LED_RUN_BITMASK 0x01 +#define LED_1_BITMASK 0x02 +#define LED_2_BITMASK 0x04 +#define LED_RX_BITMASK 0x08 +#define LED_TX_BITMASK 0x10 +#define LED_ERR_BITMASK 0x20 + +#endif /* HARDWARE_H_ */ diff --git a/board/eNET/u-boot.lds b/board/eNET/u-boot.lds new file mode 100644 index 0000000..7855c0b --- /dev/null +++ b/board/eNET/u-boot.lds @@ -0,0 +1,90 @@ +/* + * (C) Copyright 2002 + * Daniel Engstr�m, Omicron Ceti AB, daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-i386", "elf32-i386", "elf32-i386") +OUTPUT_ARCH(i386) +ENTRY(_start) + +SECTIONS +{ + . = 0x38040000; /* Where bootcode in the flash is mapped */ + .text : { *(.text); } + + . = ALIGN(4); + .rodata : { *(.rodata) *(.rodata.str1.1) *(.rodata.str1.32) } + + _i386boot_text_size = SIZEOF(.text) + SIZEOF(.rodata); + + . = 0x03FF0000; /* Ram data segment to use */ + _i386boot_romdata_dest = ABSOLUTE(.); + .data : AT ( LOADADDR(.rodata) + SIZEOF(.rodata) ) { *(.data) } + _i386boot_romdata_start = LOADADDR(.data); + + . = ALIGN(4); + .got : AT ( LOADADDR(.data) + SIZEOF(.data) ) { *(.got) } + + . = ALIGN(4); + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + _i386boot_cmd_start = LOADADDR(.u_boot_cmd); + + _i386boot_romdata_size = SIZEOF(.data) + SIZEOF(.got) + SIZEOF(.u_boot_cmd); + + . = ALIGN(4); + _i386boot_bss_start = ABSOLUTE(.); + .bss (NOLOAD) : { *(.bss) } + _i386boot_bss_size = SIZEOF(.bss); + + /* 16bit realmode trampoline code */ + .realmode 0x7c0 : AT ( LOADADDR(.got) + SIZEOF(.got) + SIZEOF(.u_boot_cmd)) { *(.realmode) } + + _i386boot_realmode = LOADADDR(.realmode); + _i386boot_realmode_size = SIZEOF(.realmode); + + /* 16bit BIOS emulation code (just enough to boot Linux) */ + .bios 0 : AT ( LOADADDR(.realmode) + SIZEOF(.realmode) ) { *(.bios) } + + _i386boot_bios = LOADADDR(.bios); + _i386boot_bios_size = SIZEOF(.bios); + + /* The load addresses below assumes that the flash + * will be mapped so that 0x387f0000 == 0xffff0000 + * at reset time + * + * The fe00 and ff00 offsets of the start32 and start16 + * segments are arbitrary, the just have to be mapped + * at reset and the code have to fit. + * The fff0 offset of reset is important, however. + */ + + . = 0xfffffe00; + .start32 : AT (0x3807fe00) { *(.start32); } + + . = 0xf800; + .start16 : AT (0x3807f800) { *(.start16); } + + . = 0xfff0; + .reset : AT (0x3807fff0) { *(.reset); } + _i386boot_end = (LOADADDR(.reset) + SIZEOF(.reset) ); +} diff --git a/cpu/i386/sc520.c b/cpu/i386/sc520.c index 640b255..a5724b6 100644 --- a/cpu/i386/sc520.c +++ b/cpu/i386/sc520.c @@ -32,7 +32,7 @@ #include <config.h> #include <pci.h> #ifdef CONFIG_SC520_SSI -#include <ssi.h> +#include <asm/ic/ssi.h> #endif #include <asm/io.h> #include <asm/pci.h> diff --git a/examples/82559_eeprom.c b/examples/82559_eeprom.c index d99af26..047d3aa 100644 --- a/examples/82559_eeprom.c +++ b/examples/82559_eeprom.c @@ -19,7 +19,7 @@ */
#define _PPC_STRING_H_ /* avoid unnecessary str/mem functions */ -#define _LINUX_STRING_H_ /* avoid unnecessary str/mem functions */ +/* #define _LINUX_STRING_H_ */ /* avoid unnecessary str/mem functions */
#include <common.h> #include <exports.h> diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 0f7e7a5..2da01ea 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -312,7 +312,10 @@ extern int sc520_pci_ints[];
void init_sc520(void); unsigned long init_sc520_dram(void); + +#ifdef CONFIG_PCI void pci_sc520_init(struct pci_controller *hose); int pci_sc520_set_irq(int pci_pin, int irq); +#endif
#endif diff --git a/include/asm-i386/ic/sc520_defs.h b/include/asm-i386/ic/sc520_defs.h new file mode 100644 index 0000000..c8f6311 --- /dev/null +++ b/include/asm-i386/ic/sc520_defs.h @@ -0,0 +1,1489 @@ +/* + * sc520_defs.h + * + * Created on: 17/09/2008 + * Author: graeme + */ + +#ifndef _ASM_IC_SC520_DEFS_H_ +#define _ASM_IC_SC520_DEFS_H_ + +/* Memory mapped configuration registers, MMCR */ +#define SC520_REVID 0x0000 /* ElanSC520 Microcontroller Revision ID Register */ +#define SC520_CPUCTL 0x0002 /* Am5x86 CPU Control Register */ +#define SC520_DRCCTL 0x0010 /* SDRAM Control Register */ +#define SC520_DRCTMCTL 0x0012 /* SDRAM Timing Control Register */ +#define SC520_DRCCFG 0x0014 /* SDRAM Bank Configuration Register*/ +#define SC520_DRCBENDADR 0x0018 /* SDRAM Bank 0-3 Ending Address Register*/ +#define SC520_ECCCTL 0x0020 /* ECC Control Register */ +#define SC520_ECCSTA 0x0021 /* ECC Status Register */ +#define SC520_ECCCKBPOS 0x0022 /* ECC Check Bit Position Register */ +#define SC520_ECCSBADD 0x0024 /* ECC Single-Bit Error Address Register */ +#define SC520_DBCTL 0x0040 /* SDRAM Buffer Control Register */ +#define SC520_BOOTCSCTL 0x0050 /* /BOOTCS Control Register */ +#define SC520_ROMCS1CTL 0x0054 /* /ROMCS1 Control Register */ +#define SC520_ROMCS2CTL 0x0056 /* /ROMCS2 Control Register */ +#define SC520_HBCTL 0x0060 /* Host Bridge Control Register */ +#define SC520_HBTGTIRQCTL 0x0062 /* Host Bridge Target Interrupt Control Register */ +#define SC520_HBTGTIRQSTA 0x0064 /* Host Bridge Target Interrupt Status Register */ +#define SC520_HBMSTIRQCTL 0x0066 /* Host Bridge Target Interrupt Control Register */ +#define SC520_HBMSTIRQSTA 0x0068 /* Host Bridge Master Interrupt Status Register */ +#define SC520_MSTINTADD 0x006c /* Host Bridge Master Interrupt Address Register */ +#define SC520_SYSARBCTL 0x0070 /* System Arbiter Control Register */ +#define SC520_PCIARBSTA 0x0071 /* PCI Bus Arbiter Status Register */ +#define SC520_SYSARBMENB 0x0072 /* System Arbiter Master Enable Register */ +#define SC520_ARBPRICTL 0x0074 /* Arbiter Priority Control Register */ +#define SC520_ADDDECCTL 0x0080 /* Address Decode Control Register */ +#define SC520_WPVSTA 0x0082 /* Write-Protect Violation Status Register */ +#define SC520_PAR0 0x0088 /* Programmable Address Region 0 Register */ +#define SC520_PAR1 0x008c /* Programmable Address Region 1 Register */ +#define SC520_PAR2 0x0090 /* Programmable Address Region 2 Register */ +#define SC520_PAR3 0x0094 /* Programmable Address Region 3 Register */ +#define SC520_PAR4 0x0098 /* Programmable Address Region 4 Register */ +#define SC520_PAR5 0x009c /* Programmable Address Region 5 Register */ +#define SC520_PAR6 0x00a0 /* Programmable Address Region 6 Register */ +#define SC520_PAR7 0x00a4 /* Programmable Address Region 7 Register */ +#define SC520_PAR8 0x00a8 /* Programmable Address Region 8 Register */ +#define SC520_PAR9 0x00ac /* Programmable Address Region 9 Register */ +#define SC520_PAR10 0x00b0 /* Programmable Address Region 10 Register */ +#define SC520_PAR11 0x00b4 /* Programmable Address Region 11 Register */ +#define SC520_PAR12 0x00b8 /* Programmable Address Region 12 Register */ +#define SC520_PAR13 0x00bc /* Programmable Address Region 13 Register */ +#define SC520_PAR14 0x00c0 /* Programmable Address Region 14 Register */ +#define SC520_PAR15 0x00c4 /* Programmable Address Region 15 Register */ +#define SC520_GPECHO 0x0c00 /* GP Echo Mode Register */ +#define SC520_GPCSDW 0x0c01 /* GP Chip Select Data Width Register */ +#define SC520_GPCSQUAL 0x0c02 /* GP Chip Select Qualification Register */ +#define SC520_GPCSRT 0x0c08 /* GP Chip Select Recovery Time Register */ +#define SC520_GPCSPW 0x0c09 /* GP Chip Select Pulse Width Register */ +#define SC520_GPCSOFF 0x0c0a /* GP Chip Select Offset Register */ +#define SC520_GPRDW 0x0c0b /* GP Read Pulse Width Register */ +#define SC520_GPRDOFF 0x0c0c /* GP Read Offset Register */ +#define SC520_GPWRW 0x0c0d /* GP Write Pulse Width Register */ +#define SC520_GPWROFF 0x0c0e /* GP Write Offset Register */ +#define SC520_GPALEW 0x0c0f /* GP ALE Pulse Width Register */ +#define SC520_GPALEOFF 0x0c10 /* GP ALE Offset Register */ +#define SC520_PIOPFS15_0 0x0c20 /* PIO15-PIO0 Pin Function Select */ +#define SC520_PIOPFS31_16 0x0c22 /* PIO31-PIO16 Pin Function Select */ +#define SC520_CSPFS 0x0c24 /* Chip Select Pin Function Select */ +#define SC520_CLKSEL 0x0c26 /* Clock Select */ +#define SC520_DSCTL 0x0c28 /* Drive Strength Control */ +#define SC520_PIODIR15_0 0x0c2a /* PIO15-PIO0 Direction */ +#define SC520_PIODIR31_16 0x0c2c /* PIO31-PIO16 Direction */ +#define SC520_PIODATA15_0 0x0c30 /* PIO15-PIO0 Data */ +#define SC520_PIODATA31_16 0x0c32 /* PIO31-PIO16 Data */ +#define SC520_PIOSET15_0 0x0c34 /* PIO15-PIO0 Set */ +#define SC520_PIOSET31_16 0x0c36 /* PIO31-PIO16 Set */ +#define SC520_PIOCLR15_0 0x0c38 /* PIO15-PIO0 Clear */ +#define SC520_PIOCLR31_16 0x0c3a /* PIO31-PIO16 Clear */ +#define SC520_SWTMRMILLI 0x0c60 /* Software Timer Millisecond Count */ +#define SC520_SWTMRMICRO 0x0c62 /* Software Timer Microsecond Count */ +#define SC520_SWTMRCFG 0x0c64 /* Software Timer Configuration */ +#define SC520_GPTMRSTA 0x0c70 /* GP Timers Status Register */ +#define SC520_GPTMR0CTL 0x0c72 /* GP Timer 0 Mode/Control Register */ +#define SC520_GPTMR0CNT 0x0c74 /* GP Timer 0 Count Register */ +#define SC520_GPTMR0MAXCMPA 0x0c76 /* GP Timer 0 Maxcount Compare A Register */ +#define SC520_GPTMR0MAXCMPB 0x0c78 /* GP Timer 0 Maxcount Compare B Register */ +#define SC520_GPTMR1CTL 0x0c7a /* GP Timer 1 Mode/Control Register */ +#define SC520_GPTMR1CNT 0x0c7c /* GP Timer 1 Count Register */ +#define SC520_GPTMR1MAXCMPA 0x0c7e /* GP Timer 1 Maxcount Compare Register A */ +#define SC520_GPTMR1MAXCMPB 0x0c80 /* GP Timer 1 Maxcount Compare B Register */ +#define SC520_GPTMR2CTL 0x0c82 /* GP Timer 2 Mode/Control Register */ +#define SC520_GPTMR2CNT 0x0c84 /* GP Timer 2 Count Register */ +#define SC520_GPTMR2MAXCMPA 0x0c8e /* GP Timer 2 Maxcount Compare A Register */ +#define SC520_WDTMRCTL 0x0cb0 /* Watchdog Timer Control Register */ +#define SC520_WDTMRCNTL 0x0cb2 /* Watchdog Timer Count Low Register */ +#define SC520_WDTMRCNTH 0x0cb4 /* Watchdog Timer Count High Register */ +#define SC520_UART1CTL 0x0cc0 /* UART 1 General Control Register */ +#define SC520_UART1STA 0x0cc1 /* UART 1 General Status Register */ +#define SC520_UART1FCRSHAD 0x0cc2 /* UART 1 FIFO Control Shadow Register */ +#define SC520_UART2CTL 0x0cc4 /* UART 2 General Control Register */ +#define SC520_UART2STA 0x0cc5 /* UART 2 General Status Register */ +#define SC520_UART2FCRSHAD 0x0cc6 /* UART 2 FIFO Control Shadow Register */ +#define SC520_SSICTL 0x0cd0 /* SSI Control */ +#define SC520_SSIXMIT 0x0cd1 /* SSI Transmit */ +#define SC520_SSICMD 0x0cd2 /* SSI Command */ +#define SC520_SSISTA 0x0cd3 /* SSI Status */ +#define SC520_SSIRCV 0x0cd4 /* SSI Receive */ +#define SC520_PICICR 0x0d00 /* Interrupt Control Register */ +#define SC520_MPICMODE 0x0d02 /* Master PIC Interrupt Mode Register */ +#define SC520_SL1PICMODE 0x0d03 /* Slave 1 PIC Interrupt Mode Register */ +#define SC520_SL2PICMODE 0x0d04 /* Slave 2 PIC Interrupt Mode Register */ +#define SC520_SWINT16_1 0x0d08 /* Software Interrupt 16-1 Control Register */ +#define SC520_SWINT22_17 0x0d0a /* Software Interrupt 22-17/NMI Control Register */ +#define SC520_INTPINPOL 0x0d10 /* Interrupt Pin Polarity Register */ +#define SC520_PCIHOSTMAP 0x0d14 /* PCI Host Bridge Interrupt Mappin Register */ +#define SC520_ECCMAP 0x0d18 /* ECC Interrupt Mapping Register */ +#define SC520_GPTMR0MAP 0x0d1a /* GP Timer 0 Interrupt Mapping Register */ +#define SC520_GPTMR1MAP 0x0d1b /* GP Timer 1 Interrupt Mapping Register */ +#define SC520_GPTMR2MAP 0x0d1c /* GP Timer 2 Interrupt Mapping Register */ +#define SC520_PIT0MAP 0x0d20 /* PIT0 Interrupt Mapping Register */ +#define SC520_PIT1MAP 0x0d21 /* PIT1 Interrupt Mapping Register */ +#define SC520_PIT2MAP 0x0d22 /* PIT2 Interrupt Mapping Register */ +#define SC520_UART1MAP 0x0d28 /* UART 1 Interrupt Mapping Register */ +#define SC520_UART2MAP 0x0d29 /* UART 2 Interrupt Mapping Register */ +#define SC520_PCIINTAMAP 0x0d30 /* PCI Interrupt A Mapping Register */ +#define SC520_PCIINTBMAP 0x0d31 /* PCI Interrupt B Mapping Register */ +#define SC520_PCIINTCMAP 0x0d32 /* PCI Interrupt C Mapping Register */ +#define SC520_PCIINTDMAP 0x0d33 /* PCI Interrupt D Mapping Register */ +#define SC520_DMABCINTMAP 0x0d40 /* DMA Buffer Chaining Interrupt Mapping Register */ +#define SC520_SSIMAP 0x0d41 /* SSI Interrupt Mapping Register */ +#define SC520_WDTMAP 0x0d42 /* Watchdog Timer Interrupt Mapping Register */ +#define SC520_RTCMAP 0x0d43 /* RTC Interrupt Mapping Register */ +#define SC520_WPVMAP 0x0d44 /* Write-Protect Interrupt Mapping Register */ +#define SC520_ICEMAP 0x0d45 /* AMDebug JTAG RX/TX Interrupt Mapping Register */ +#define SC520_FERRMAP 0x0d46 /* Floating Point Error Interrupt Mapping Register */ +#define SC520_GP0IMAP 0x0d50 /* GPIRQ0 Interrupt Mapping Register */ +#define SC520_GP1IMAP 0x0d51 /* GPIRQ1 Interrupt Mapping Register */ +#define SC520_GP2IMAP 0x0d52 /* GPIRQ2 Interrupt Mapping Register */ +#define SC520_GP3IMAP 0x0d53 /* GPIRQ3 Interrupt Mapping Register */ +#define SC520_GP4IMAP 0x0d54 /* GPIRQ4 Interrupt Mapping Register */ +#define SC520_GP5IMAP 0x0d55 /* GPIRQ5 Interrupt Mapping Register */ +#define SC520_GP6IMAP 0x0d56 /* GPIRQ6 Interrupt Mapping Register */ +#define SC520_GP7IMAP 0x0d57 /* GPIRQ7 Interrupt Mapping Register */ +#define SC520_GP8IMAP 0x0d58 /* GPIRQ8 Interrupt Mapping Register */ +#define SC520_GP9IMAP 0x0d59 /* GPIRQ9 Interrupt Mapping Register */ +#define SC520_GP10IMAP 0x0d5a /* GPIRQ10 Interrupt Mapping Register */ +#define SC520_SYSINFO 0x0d70 /* System Board Information Register */ +#define SC520_RESCFG 0x0d72 /* Reset Configuration Register */ +#define SC520_RESSTA 0x0d74 /* Reset Status Register */ +#define SC520_GPDMAMMIO 0x0d81 /* GP-DMA Memory-Mapped I/O Register */ +#define SC520_GPDMAEXTCHMAPA 0x0d82 /* GP-DMA Resource Channel Map A */ +#define SC520_GPDMAEXTCHMAPB 0x0d84 /* GP-DMA Resource Channel Map B */ +#define SC520_GPDMAEXTPG0 0x0d86 /* GP-DMA Channel 0 Extended Page */ +#define SC520_GPDMAEXTPG1 0x0d87 /* GP-DMA Channel 1 Extended Page */ +#define SC520_GPDMAEXTPG2 0x0d88 /* GP-DMA Channel 2 Extended Page */ +#define SC520_GPDMAEXTPG3 0x0d89 /* GP-DMA Channel 3 Extended Page */ +#define SC520_GPDMAEXTPG5 0x0d8a /* GP-DMA Channel 5 Extended Page */ +#define SC520_GPDMAEXTPG6 0x0d8b /* GP-DMA Channel 6 Extended Page */ +#define SC520_GPDMAEXTPG7 0x0d8c /* GP-DMA Channel 7 Extended Page */ +#define SC520_GPDMAEXTTC3 0x0d90 /* GP-DMA Channel 3 Extender Transfer count */ +#define SC520_GPDMAEXTTC5 0x0d91 /* GP-DMA Channel 5 Extender Transfer count */ +#define SC520_GPDMAEXTTC6 0x0d92 /* GP-DMA Channel 6 Extender Transfer count */ +#define SC520_GPDMAEXTTC7 0x0d93 /* GP-DMA Channel 7 Extender Transfer count */ +#define SC520_GPDMABCCTL 0x0d98 /* Buffer Chaining Control */ +#define SC520_GPDMABCSTA 0x0d99 /* Buffer Chaining Status */ +#define SC520_GPDMABSINTENB 0x0d9a /* Buffer Chaining Interrupt Enable */ +#define SC520_GPDMABCVAL 0x0d9b /* Buffer Chaining Valid */ +#define SC520_GPDMANXTADDL3 0x0da0 /* GP-DMA Channel 3 Next Address Low */ +#define SC520_GPDMANXTADDH3 0x0da2 /* GP-DMA Channel 3 Next Address High */ +#define SC520_GPDMANXTADDL5 0x0da4 /* GP-DMA Channel 5 Next Address Low */ +#define SC520_GPDMANXTADDH5 0x0da6 /* GP-DMA Channel 5 Next Address High */ +#define SC520_GPDMANXTADDL6 0x0da8 /* GP-DMA Channel 6 Next Address Low */ +#define SC520_GPDMANXTADDH6 0x0daa /* GP-DMA Channel 6 Next Address High */ +#define SC520_GPDMANXTADDL7 0x0dac /* GP-DMA Channel 7 Next Address Low */ +#define SC520_GPDMANXTADDH7 0x0dae /* GP-DMA Channel 7 Next Address High */ +#define SC520_GPDMANXTTCL3 0x0db0 /* GP-DMA Channel 3 Next Transfer Count Low */ +#define SC520_GPDMANXTTCH3 0x0db2 /* GP-DMA Channel 3 Next Transfer Count High */ +#define SC520_GPDMANXTTCL5 0x0db4 /* GP-DMA Channel 5 Next Transfer Count Low */ +#define SC520_GPDMANXTTCH5 0x0db6 /* GP-DMA Channel 5 Next Transfer Count High */ +#define SC520_GPDMANXTTCL6 0x0db8 /* GP-DMA Channel 6 Next Transfer Count Low */ +#define SC520_GPDMANXTTCH6 0x0dba /* GP-DMA Channel 6 Next Transfer Count High */ +#define SC520_GPDMANXTTCL7 0x0dbc /* GP-DMA Channel 7 Next Transfer Count Low */ +#define SC520_GPDMANXTTCH7 0x0dbe /* GP-DMA Channel 7 Next Transfer Count High */ + +/* MMCR Register bits (not all of them :) ) */ + +/* SSI Stuff */ +#define CTL_CLK_SEL_4 0x00 /* Nominal Bit Rate = 8 MHz */ +#define CTL_CLK_SEL_8 0x10 /* Nominal Bit Rate = 4 MHz */ +#define CTL_CLK_SEL_16 0x20 /* Nominal Bit Rate = 2 MHz */ +#define CTL_CLK_SEL_32 0x30 /* Nominal Bit Rate = 1 MHz */ +#define CTL_CLK_SEL_64 0x40 /* Nominal Bit Rate = 512 KHz */ +#define CTL_CLK_SEL_128 0x50 /* Nominal Bit Rate = 256 KHz */ +#define CTL_CLK_SEL_256 0x60 /* Nominal Bit Rate = 128 KHz */ +#define CTL_CLK_SEL_512 0x70 /* Nominal Bit Rate = 64 KHz */ + +#define TC_INT_ENB 0x08 /* Transaction Complete Interrupt Enable */ +#define PHS_INV_ENB 0x04 /* SSI Inverted Phase Mode Enable */ +#define CLK_INV_ENB 0x02 /* SSI Inverted Clock Mode Enable */ +#define MSBF_ENB 0x01 /* SSI Most Significant Bit First Mode Enable */ + +#define SSICMD_CMD_SEL_XMITRCV 0x03 /* Simultaneous Transmit / Receive Transaction */ +#define SSICMD_CMD_SEL_RCV 0x02 /* Receive Transaction */ +#define SSICMD_CMD_SEL_XMIT 0x01 /* Transmit Transaction */ +#define SSISTA_BSY 0x02 /* SSI Busy */ +#define SSISTA_TC_INT 0x01 /* SSI Transaction Complete Interrupt */ + + +/* BITS for SC520_ADDDECCTL: */ +#define WPV_INT_ENB 0x80 /* Write-Protect Violation Interrupt Enable */ +#define IO_HOLE_DEST_PCI 0x10 /* I/O Hole Access Destination */ +#define RTC_DIS 0x04 /* RTC Disable */ +#define UART2_DIS 0x02 /* UART2 Disable */ +#define UART1_DIS 0x01 /* UART1 Disable */ + +/* bus mapping constants (used for PCI core initialization) */ /* bus mapping constants */ +#define SC520_REG_ADDR 0x00000cf8 +#define SC520_REG_DATA 0x00000cfc + + +#define SC520_ISA_MEM_PHYS 0x00000000 +#define SC520_ISA_MEM_BUS 0x00000000 +#define SC520_ISA_MEM_SIZE 0x01000000 + +#define SC520_ISA_IO_PHYS 0x00000000 +#define SC520_ISA_IO_BUS 0x00000000 +#define SC520_ISA_IO_SIZE 0x00001000 + +/* PCI I/O space from 0x1000 to 0xdfff + * (make 0xe000-0xfdff available for stuff like PCCard boot) */ +#define SC520_PCI_IO_PHYS 0x00001000 +#define SC520_PCI_IO_BUS 0x00001000 +#define SC520_PCI_IO_SIZE 0x0000d000 + +/* system memory from 0x00000000 to 0x0fffffff */ +#define SC520_PCI_MEMORY_PHYS 0x00000000 +#define SC520_PCI_MEMORY_BUS 0x00000000 +#define SC520_PCI_MEMORY_SIZE 0x10000000 + +/* PCI bus memory from 0x10000000 to 0x26ffffff + * (make 0x27000000 - 0x27ffffff available for stuff like PCCard boot) */ +#define SC520_PCI_MEM_PHYS 0x10000000 +#define SC520_PCI_MEM_BUS 0x10000000 +#define SC520_PCI_MEM_SIZE 0x17000000 + +/* 0x28000000 - 0x3fffffff is used by the flash banks */ + +/* 0x40000000 - 0xffffffff is not adressable by the SC520 */ + +/* priority numbers used for interrupt channel mappings */ +#define SC520_IRQ_DISABLED 0 +#define SC520_IRQ0 1 +#define SC520_IRQ1 2 +#define SC520_IRQ2 4 /* same as IRQ9 */ +#define SC520_IRQ3 11 +#define SC520_IRQ4 12 +#define SC520_IRQ5 13 +#define SC520_IRQ6 21 +#define SC520_IRQ7 22 +#define SC520_IRQ8 3 +#define SC520_IRQ9 4 +#define SC520_IRQ10 5 +#define SC520_IRQ11 6 +#define SC520_IRQ12 7 +#define SC520_IRQ13 8 +#define SC520_IRQ14 9 +#define SC520_IRQ15 10 + + +/* pin number used for PCI interrupt mappings */ +#define SC520_PCI_INTA 0 +#define SC520_PCI_INTB 1 +#define SC520_PCI_INTC 2 +#define SC520_PCI_INTD 3 +#define SC520_PCI_GPIRQ0 4 +#define SC520_PCI_GPIRQ1 5 +#define SC520_PCI_GPIRQ2 6 +#define SC520_PCI_GPIRQ3 7 +#define SC520_PCI_GPIRQ4 8 +#define SC520_PCI_GPIRQ5 9 +#define SC520_PCI_GPIRQ6 10 +#define SC520_PCI_GPIRQ7 11 +#define SC520_PCI_GPIRQ8 12 +#define SC520_PCI_GPIRQ9 13 +#define SC520_PCI_GPIRQ10 14 + + + +/* PIC I/O mapped registers */ + +#define MPICIR 0x20 /* Master PIC Interrupt Request Register */ +#define MPICISR 0x20 /* Master PIC In-Service Register */ +#define MPICICW1 0x20 /* Master PIC Initialization Control Word 1 Register */ +#define MPICOCW2 0x20 /* Master PIC Operation Control Word 2 Register */ +#define MPICOCW3 0x20 /* Master PIC Operation Control Word 3 Register */ + +#define MPICICW2 0x21 /* Master PIC Initialization Control Word 2 Register */ +#define MPICICW3 0x21 /* Master PIC Initialization Control Word 3 Register */ +#define MPICICW4 0x21 /* Master PIC Initialization Control Word 4 Register */ +#define MPICINTMSK 0x21 /* Master PIC Interrupt Mask Register */ + +#define S2PICIR 0x24 /* Slave 2 PIC Interrupt Request Register */ +#define S2PICISR 0x24 /* Slave 2 PIC In-Service Register */ +#define S2PICICW1 0x24 /* Slave 2 PIC Initialization Control Word 1 Register */ +#define S2PICOCW2 0x24 /* Slave 2 PIC Operation Control Word 2 Register */ +#define S2PICOCW3 0x24 /* Slave 2 PIC Operation Control Word 3 Register */ + +#define S2PICICW2 0x25 /* Slave 2 PIC Initialization Control Word 2 Register */ +#define S2PICICW3 0x25 /* Slave 2 PIC Initialization Control Word 3 Register */ +#define S2PICICW4 0x25 /* Slave 2 PIC Initialization Control Word 4 Register */ +#define S2PICINTMSK 0x25 /* Slave 2 PIC Interrupt Mask Register */ + +#define S1PICIR 0xa0 /* Slave 1 PIC Interrupt Request Register */ +#define S1PICISR 0xa0 /* Slave 1 PIC In-Service Register */ +#define S1PICICW1 0xa0 /* Slave 1 PIC Initialization Control Word 1 Register */ +#define S1PICOCW2 0xa0 /* Slave 1 PIC Operation Control Word 2 Register */ +#define S1PICOCW3 0xa0 /* Slave 1 PIC Operation Control Word 3 Register */ + +#define S1PICICW2 0xa1 /* Slave 1 PIC Initialization Control Word 2 Register */ +#define S1PICICW3 0xa1 /* Slave 1 PIC Initialization Control Word 3 Register */ +#define S1PICICW4 0xa1 /* Slave 1 PIC Initialization Control Word 4 Register */ +#define S1PICINTMSK 0xa1 /* Slave 1 PIC Interrupt Mask Register */ + +/* +Programmable Interrupt Controller Register Bit Definitions +*/ + +/* Interrupt Control Register Bit Definitions */ + +#define NMI_DONE 0x80 /* NMI Routine Done */ +#define NMI_ENB 0x40 /* Master NMI Done */ +#define S2_GINT_MODE 0x04 /* Slave 2 PIC Global Interrupt Mode Enable */ +#define S1_GINT_MODE 0x02 /* Slave 1 PIC Global Interrupt Mode Enable */ +#define M_GINT_MODE 0x01 /* Master PIC Global Interrupt Mode Enable */ + +/* Master , SLAVEs 1&2 PIC Interrupt Mode Register Bit Definitions */ + +#define CH7_INT_MODE 0x80 /* PIC Channel 7 Interrupt Mode 0-edge 1-level */ +#define CH6_INT_MODE 0x40 /* PIC Channel 6 Interrupt Mode 0-edge 1-level */ +#define CH5_INT_MODE 0x20 /* PIC Channel 5 Interrupt Mode 0-edge 1-level */ +#define CH4_INT_MODE 0x10 /* PIC Channel 4 Interrupt Mode 0-edge 1-level */ +#define CH3_INT_MODE 0x08 /* PIC Channel 3 Interrupt Mode 0-edge 1-level */ +#define CH2_INT_MODE 0x04 /* PIC Channel 2 Interrupt Mode 0-edge 1-level */ +#define CH1_INT_MODE 0x02 /* PIC Channel 1 Interrupt Mode 0-edge 1-level */ +#define CH0_INT_MODE 0x01 /* PIC Channel 0 Interrupt Mode 0-edge 1-level */ + +/* Software Interrupt 16-1 Control Register Bit Definitions */ + +#define SW_P16_TRIG 0x8000 /* Directly Trigger Priority Level P16 0-don't assert int, 1-assert int*/ +#define SW_P15_TRIG 0x4000 /* Directly Trigger Priority Level P15 */ +#define SW_P14_TRIG 0x2000 /* Directly Trigger Priority Level P14 */ +#define SW_P13_TRIG 0x1000 /* Directly Trigger Priority Level P13 */ +#define SW_P12_TRIG 0x0800 /* Directly Trigger Priority Level P12 */ +#define SW_P11_TRIG 0x0400 /* Directly Trigger Priority Level P11 */ +#define SW_P10_TRIG 0x0200 /* Directly Trigger Priority Level P10 */ +#define SW_P9_TRIG 0x0100 /* Directly Trigger Priority Level P9 */ +#define SW_P8_TRIG 0x0080 /* Directly Trigger Priority Level P8 */ +#define SW_P7_TRIG 0x0040 /* Directly Trigger Priority Level P7 */ +#define SW_P6_TRIG 0x0020 /* Directly Trigger Priority Level P6 */ +#define SW_P5_TRIG 0x0010 /* Directly Trigger Priority Level P5 */ +#define SW_P4_TRIG 0x0008 /* Directly Trigger Priority Level P4 */ +#define SW_P3_TRIG 0x0004 /* Directly Trigger Priority Level P3 */ +#define SW_P2_TRIG 0x0002 /* Directly Trigger Priority Level P2 */ +#define SW_P1_TRIG 0x0001 /* Directly Trigger Priority Level P1 */ + +/* Software Interrupt 22-17/NMI Control Register Bit Defintions */ + +#define NMI_TRIG 0x0040 /* Software NMI Source */ +#define SW_P22_TRIG 0x0020 /* Directly Trigger Priority Level P22 */ +#define SW_P21_TRIG 0x0010 /* Directly Trigger Priority Level P21 */ +#define SW_P20_TRIG 0x0008 /* Directly Trigger Priority Level P20 */ +#define SW_P19_TRIG 0x0004 /* Directly Trigger Priority Level P19 */ +#define SW_P18_TRIG 0x0002 /* Directly Trigger Priority Level P18 */ +#define SW_P17_TRIG 0x0001 /* Directly Trigger Priority Level P17 */ + +/* Interrupt Pin Polarity Register Bit Definitions */ + +#define INTD_POL 0x8000 /* PCI Interrupt Request /INTD Polarity */ +#define INTC_POL 0x4000 /* PCI Interrupt Request /INTC Polarity */ +#define INTB_POL 0x2000 /* PCI Interrupt Request /INTB Polarity */ +#define INTA_POL 0x1000 /* PCI Interrupt Request /INTA Polarity */ + +#define GPINT10_POL 0x0400 /* General-Purpose Interrupt Request GPIRQ10 Polarity 0 - high to low, 1 low to high */ +#define GPINT9_POL 0x0200 /* General-Purpose Interrupt Request GPIRQ9 Polarity 0 - high to low, 1 low to high */ +#define GPINT8_POL 0x0100 /* General-Purpose Interrupt Request GPIRQ8 Polarity 0 - high to low, 1 low to high */ +#define GPINT7_POL 0x0080 /* General-Purpose Interrupt Request GPIRQ7 Polarity 0 - high to low, 1 low to high */ +#define GPINT6_POL 0x0040 /* General-Purpose Interrupt Request GPIRQ6 Polarity 0 - high to low, 1 low to high */ +#define GPINT5_POL 0x0020 /* General-Purpose Interrupt Request GPIRQ5 Polarity 0 - high to low, 1 low to high */ +#define GPINT4_POL 0x0010 /* General-Purpose Interrupt Request GPIRQ4 Polarity 0 - high to low, 1 low to high */ +#define GPINT3_POL 0x0008 /* General-Purpose Interrupt Request GPIRQ3 Polarity 0 - high to low, 1 low to high */ +#define GPINT2_POL 0x0004 /* General-Purpose Interrupt Request GPIRQ2 Polarity 0 - high to low, 1 low to high */ +#define GPINT1_POL 0x0002 /* General-Purpose Interrupt Request GPIRQ1 Polarity 0 - high to low, 1 low to high */ +#define GPINT0_POL 0x0001 /* General-Purpose Interrupt Request GPIRQ0 Polarity 0 - high to low, 1 low to high */ + +/* PCI Host Bridge Interrupt Mapping Register Bit Definitions */ + +#define PCI_NMI_ENB 0x0010 /* PCI Host Bridge NMI Enable */ + +#define PCI_IRQ_MAP_P0 0x0000 /* PCI Host Bridge Interrupt Mapping: Disable PCI interrupt from reaching PIC */ +#define PCI_IRQ_MAP_P1 0x0001 /* PCI Host Bridge Interrupt Mapping: Priority P1 (Master PIC IR0) (highest priority)*/ +#define PCI_IRQ_MAP_P2 0x0002 /* PCI Host Bridge Interrupt Mapping: Priority P2 (Master PIC IR1)*/ +#define PCI_IRQ_MAP_P3 0x0003 /* PCI Host Bridge Interrupt Mapping: Priority P3 (Slave PIC IR0/Master PIC IR2)*/ +#define PCI_IRQ_MAP_P4 0x0004 /* PCI Host Bridge Interrupt Mapping: Priority P4 (Slave 1 PIC IR1)*/ +#define PCI_IRQ_MAP_P5 0x0005 /* PCI Host Bridge Interrupt Mapping: Priority P5 (Slave 1 PIC IR2)*/ +#define PCI_IRQ_MAP_P6 0x0006 /* PCI Host Bridge Interrupt Mapping: Priority P6 (Slave 1 PIC IR3)*/ +#define PCI_IRQ_MAP_P7 0x0007 /* PCI Host Bridge Interrupt Mapping: Priority P7 (Slave 1 PIC IR4)*/ +#define PCI_IRQ_MAP_P8 0x0008 /* PCI Host Bridge Interrupt Mapping: Priority P8 (Slave 1 PIC IR5)*/ +#define PCI_IRQ_MAP_P9 0x0009 /* PCI Host Bridge Interrupt Mapping: Priority P9 (Slave 1 PIC IR6)*/ +#define PCI_IRQ_MAP_P10 0x000a /* PCI Host Bridge Interrupt Mapping: Priority P10 (Slave 1 PIC IR7)*/ +#define PCI_IRQ_MAP_P11 0x000b /* PCI Host Bridge Interrupt Mapping: Priority P11 (Master PIC IR3)*/ +#define PCI_IRQ_MAP_P12 0x000c /* PCI Host Bridge Interrupt Mapping: Priority P12 (Master PIC IR4)*/ +#define PCI_IRQ_MAP_P13 0x000d /* PCI Host Bridge Interrupt Mapping: Priority P13 (Slave 2 PIC IR0/Master PIC IR5)*/ +#define PCI_IRQ_MAP_P14 0x000e /* PCI Host Bridge Interrupt Mapping: Priority P14 (Slave 2 PIC IR1)*/ +#define PCI_IRQ_MAP_P15 0x000f /* PCI Host Bridge Interrupt Mapping: Priority P15 (Slave 2 PIC IR2)*/ +#define PCI_IRQ_MAP_P16 0x0010 /* PCI Host Bridge Interrupt Mapping: Priority P16 (Slave 2 PIC IR3)*/ +#define PCI_IRQ_MAP_P17 0x0011 /* PCI Host Bridge Interrupt Mapping: Priority P17 (Slave 2 PIC IR4)*/ +#define PCI_IRQ_MAP_P18 0x0012 /* PCI Host Bridge Interrupt Mapping: Priority P18 (Slave 2 PIC IR5)*/ +#define PCI_IRQ_MAP_P19 0x0013 /* PCI Host Bridge Interrupt Mapping: Priority P19 (Slave 2 PIC IR6)*/ +#define PCI_IRQ_MAP_P20 0x0014 /* PCI Host Bridge Interrupt Mapping: Priority P20 (Slave 2 PIC IR7)*/ +#define PCI_IRQ_MAP_P21 0x0015 /* PCI Host Bridge Interrupt Mapping: Priority P21 (Master PIC IR6)*/ +#define PCI_IRQ_MAP_P22 0x0016 /* PCI Host Bridge Interrupt Mapping: Priority P22 (Master PIC IR7)(lowest priority) */ +#define PCI_IRQ_MAP_DA 0x0017 /* PCI Host Bridge Interrupt Mapping: disable internal-interrupt from reaching PIC*/ +#define PCI_IRQ_MAP_NMI 0x001F /* PCI Host Bridge Interrupt Mapping: NMI Source*/ + +/* ECC Interrupt Mapping Register Bit Definitions */ + +#define ECC_NMI_ENB 0x0100 /* ECC NMI Enable */ + +#define ECC_IRQ_MAP_P0 0x0000 /* SDRAM ECC Interrupt Mapping: Disable PCI interrupt from reaching PIC */ +#define ECC_IRQ_MAP_P1 0x0001 /* SDRAM ECC Interrupt Mapping: Priority P1 (Master PIC IR0) (highest priority)*/ +#define ECC_IRQ_MAP_P2 0x0002 /* SDRAM ECC Interrupt Mapping: Priority P2 (Master PIC IR1)*/ +#define ECC_IRQ_MAP_P3 0x0003 /* SDRAM ECC Interrupt Mapping: Priority P3 (Slave PIC IR0/Master PIC IR2)*/ +#define ECC_IRQ_MAP_P4 0x0004 /* SDRAM ECC Interrupt Mapping: Priority P4 (Slave 1 PIC IR1)*/ +#define ECC_IRQ_MAP_P5 0x0005 /* SDRAM ECC Interrupt Mapping: Priority P5 (Slave 1 PIC IR2)*/ +#define ECC_IRQ_MAP_P6 0x0006 /* SDRAM ECC Interrupt Mapping: Priority P6 (Slave 1 PIC IR3)*/ +#define ECC_IRQ_MAP_P7 0x0007 /* SDRAM ECC Interrupt Mapping: Priority P7 (Slave 1 PIC IR4)*/ +#define ECC_IRQ_MAP_P8 0x0008 /* SDRAM ECC Interrupt Mapping: Priority P8 (Slave 1 PIC IR5)*/ +#define ECC_IRQ_MAP_P9 0x0009 /* SDRAM ECC Interrupt Mapping: Priority P9 (Slave 1 PIC IR6)*/ +#define ECC_IRQ_MAP_P10 0x000a /* SDRAM ECC Interrupt Mapping: Priority P10 (Slave 1 PIC IR7)*/ +#define ECC_IRQ_MAP_P11 0x000b /* SDRAM ECC Interrupt Mapping: Priority P11 (Master PIC IR3)*/ +#define ECC_IRQ_MAP_P12 0x000c /* SDRAM ECC Interrupt Mapping: Priority P12 (Master PIC IR4)*/ +#define ECC_IRQ_MAP_P13 0x000d /* SDRAM ECC Interrupt Mapping: Priority P13 (Slave 2 PIC IR0/Master PIC IR5)*/ +#define ECC_IRQ_MAP_P14 0x000e /* SDRAM ECC Interrupt Mapping: Priority P14 (Slave 2 PIC IR1)*/ +#define ECC_IRQ_MAP_P15 0x000f /* SDRAM ECC Interrupt Mapping: Priority P15 (Slave 2 PIC IR2)*/ +#define ECC_IRQ_MAP_P16 0x0010 /* SDRAM ECC Interrupt Mapping: Priority P16 (Slave 2 PIC IR3)*/ +#define ECC_IRQ_MAP_P17 0x0011 /* SDRAM ECC Interrupt Mapping: Priority P17 (Slave 2 PIC IR4)*/ +#define ECC_IRQ_MAP_P18 0x0012 /* SDRAM ECC Interrupt Mapping: Priority P18 (Slave 2 PIC IR5)*/ +#define ECC_IRQ_MAP_P19 0x0013 /* SDRAM ECC Interrupt Mapping: Priority P19 (Slave 2 PIC IR6)*/ +#define ECC_IRQ_MAP_P20 0x0014 /* SDRAM ECC Interrupt Mapping: Priority P20 (Slave 2 PIC IR7)*/ +#define ECC_IRQ_MAP_P21 0x0015 /* SDRAM ECC Interrupt Mapping: Priority P21 (Master PIC IR6)*/ +#define ECC_IRQ_MAP_P22 0x0016 /* SDRAM ECC Interrupt Mapping: Priority P22 (Master PIC IR7)(lowest priority) */ +#define ECC_IRQ_MAP_DA 0x0017 /* SDRAM ECC Interrupt Mapping: disable internal-interrupt from reaching PIC*/ + +/* Interrupt Mappings for GP TIMER 0 +GP TImer 1 +GP Timer 2 +PIT0 +PIT1 +PIT2 +UART 1 +UART 2 +PCI A +PCI B +PCI C +PCI D +DMA Buffer Chaining +SSI +WDT +RTC +Write-Protection Violation +AMDebug JTAG RX/TX +Floating Point Error +GPIRQ0 - QPIRQ10 +*/ + +#define INT_MAP_P0 0x0000 /* Interrupt Mapping: Disable PCI interrupt from reaching PIC */ +#define INT_MAP_P1 0x0001 /* Interrupt Mapping: Priority P1 (Master PIC IR0) (highest priority)*/ +#define INT_MAP_P2 0x0002 /* Interrupt Mapping: Priority P2 (Master PIC IR1)*/ +#define INT_MAP_P3 0x0003 /* Interrupt Mapping: Priority P3 (Slave PIC IR0/Master PIC IR2)*/ +#define INT_MAP_P4 0x0004 /* Interrupt Mapping: Priority P4 (Slave 1 PIC IR1)*/ +#define INT_MAP_P5 0x0005 /* Interrupt Mapping: Priority P5 (Slave 1 PIC IR2)*/ +#define INT_MAP_P6 0x0006 /* Interrupt Mapping: Priority P6 (Slave 1 PIC IR3)*/ +#define INT_MAP_P7 0x0007 /* Interrupt Mapping: Priority P7 (Slave 1 PIC IR4)*/ +#define INT_MAP_P8 0x0008 /* Interrupt Mapping: Priority P8 (Slave 1 PIC IR5)*/ +#define INT_MAP_P9 0x0009 /* Interrupt Mapping: Priority P9 (Slave 1 PIC IR6)*/ +#define INT_MAP_P10 0x000a /* Interrupt Mapping: Priority P10 (Slave 1 PIC IR7)*/ +#define INT_MAP_P11 0x000b /* Interrupt Mapping: Priority P11 (Master PIC IR3)*/ +#define INT_MAP_P12 0x000c /* Interrupt Mapping: Priority P12 (Master PIC IR4)*/ +#define INT_MAP_P13 0x000d /* Interrupt Mapping: Priority P13 (Slave 2 PIC IR0/Master PIC IR5)*/ +#define INT_MAP_P14 0x000e /* Interrupt Mapping: Priority P14 (Slave 2 PIC IR1)*/ +#define INT_MAP_P15 0x000f /* Interrupt Mapping: Priority P15 (Slave 2 PIC IR2)*/ +#define INT_MAP_P16 0x0010 /* Interrupt Mapping: Priority P16 (Slave 2 PIC IR3)*/ +#define INT_MAP_P17 0x0011 /* Interrupt Mapping: Priority P17 (Slave 2 PIC IR4)*/ +#define INT_MAP_P18 0x0012 /* Interrupt Mapping: Priority P18 (Slave 2 PIC IR5)*/ +#define INT_MAP_P19 0x0013 /* Interrupt Mapping: Priority P19 (Slave 2 PIC IR6)*/ +#define INT_MAP_P20 0x0014 /* Interrupt Mapping: Priority P20 (Slave 2 PIC IR7)*/ +#define INT_MAP_P21 0x0015 /* Interrupt Mapping: Priority P21 (Master PIC IR6)*/ +#define INT_MAP_P22 0x0016 /* Interrupt Mapping: Priority P22 (Master PIC IR7)(lowest priority) */ +#define INT_MAP_DA 0x0017 /* Interrupt Mapping: disable internal-interrupt from reaching PIC*/ +#define INT_MAP_NMI 0x001F /* Interrupt Mapping: NMI Source*/ + +/* Master, SLAVE 1,2 PIC Interrupt Request Register Bit Definitions */ + +#define IR7 0x80 /* Interrupt Request 7 */ +#define IR6 0x40 /* Interrupt Request 6 */ +#define IR5 0x20 /* Interrupt Request 5 */ +#define IR4 0x10 /* Interrupt Request 4 */ +#define IR3 0x08 /* Interrupt Request 3 */ +#define IR2 0x04 /* Interrupt Request 2 */ +#define IR1 0x02 /* Interrupt Request 1 */ +#define IR0 0x01 /* Interrupt Request 0 */ + +/* Master, SLAVE 1,2 PIC In-Service Register Bit Definitions */ + +#define IS7 0x80 /* Interrupt Request 7 In-Service */ +#define IS6 0x40 /* Interrupt Request 6 In-Service */ +#define IS5 0x20 /* Interrupt Request 5 In-Service */ +#define IS4 0x10 /* Interrupt Request 4 In-Service */ +#define IS3 0x08 /* Interrupt Request 3 In-Service */ +#define IS2 0x04 /* Interrupt Request 2 In-Service */ +#define IS1 0x02 /* Interrupt Request 1 In-Service */ +#define IS0 0x01 /* Interrupt Request 0 In-Service */ + +/* Master PIC Initilization Control Word 1 Register Bit Definitions */ + +#define SLCT_ICW1 0x10 /* Select ICW1 */ +#define LTIM 0x08 /* Level-Triggered Interrupt Mode */ +#define ADI 0x04 /* Address Interval */ +#define SNGL 0x02 /* Single PIC */ +#define IC4 0x01 /* Initilization Control Word 4 */ + +/* Master PIC Operation Control Word 2 Register Bit Definitions */ + +#define R_SL_EOI_RAEOIC 0x00 /* Interrupt Request EOI and Priority Rotation Controls: Rotate in auto EOI mode (clear)*/ +#define R_SL_EOI_NEOI 0x20 /* Interrupt Request EOI and Priority Rotation Controls: Non-specific EOI */ +#define R_SL_EOI_NOP 0x40 /* Interrupt Request EOI and Priority Rotation Controls: NOP */ +#define R_SL_EOI_SEOI 0x60 /* Interrupt Request EOI and Priority Rotation Controls: Specific EOI */ +#define R_SL_EOI_RAEOIS 0x80 /* Interrupt Request EOI and Priority Rotation Controls: Rotate in auto EOI mode (set)*/ +#define R_SL_EOI_RONEOI 0xA0 /* Interrupt Request EOI and Priority Rotation Controls: Rotate on non-specific EOI command */ +#define R_SL_EOI_SPC 0xC0 /* Interrupt Request EOI and Priority Rotation Controls: Set Priority Command */ +#define R_SL_EOI_ROEOIC 0xE0 /* Interrupt Request EOI and Priority Rotation Controls: Rotate on specific EOI command */ + +#define IS_OCW3 0x08 /* Access is OCW3 */ + +#define LS_IR0 0x00 /* Specific EOI Level Select: IR0 */ +#define LS_IR1 0x01 /* Specific EOI Level Select: IR1 */ +#define LS_IR2 0x02 /* Specific EOI Level Select: IR2 */ +#define LS_IR3 0x03 /* Specific EOI Level Select: IR3 */ +#define LS_IR4 0x04 /* Specific EOI Level Select: IR4 */ +#define LS_IR5 0x05 /* Specific EOI Level Select: IR5 */ +#define LS_IR6 0x06 /* Specific EOI Level Select: IR6 */ +#define LS_IR7 0x07 /* Specific EOI Level Select: IR7 */ + +/* Master PIC Operation Control Word 3 */ + +#define ESMMSMM_NOP 0x00 /* Special Mask Mode: NOP */ +#define ESMMSMM_RSM 0x40 /* Special Mask Mode: Reset Special mask */ +#define ESMMSMM_SSM 0x60 /* Special Mask Mode: Set Special mask */ + +#define P 0x04 /* PIC Poll Command */ + +#define RRRIS_NC 0x00 /* Status Register Select: No change from last state */ +#define RRRIS_MPICIR 0x02 /* Status Register Select: Next Port 0020h read returns MPICIR register contents */ +#define RRRIS_MPICISR 0x03 /* Status Register Select: Next Port 0020h read returns MPICISR register contents */ + +/* Master PIC Intialization Control Word 2 Register Masks */ + +#define T7_T3 0xF8 /* Bits 7-3 of Base Interrupt Vector Number for this PIC */ +#define A10_A8 0x07 /* A10-A8 of Interrupt Vector */ + +/* Master PIC Intilization Control Word 3 Register Bit Definitions */ + +#define S7 0x80 /* Channel 7 Slave Cascade Select */ +#define S6 0x40 /* Channel 6 Slave Cascade Select */ +#define S5 0x20 /* Channel 5 Slave Cascade Select */ +#define S4 0x10 /* Channel 4 Slave Cascade Select */ +#define S3 0x08 /* Channel 3 Slave Cascade Select */ +#define S2 0x04 /* Channel 2 Slave Cascade Select */ +#define S1 0x02 /* Channel 1 Slave Cascade Select */ +#define S0 0x01 /* Channel 0 Slave Cascade Select */ + +/* Master PIC Initilization Control Word 4 Register Bit Definitions */ + +#define SFNM 0x10 /* Special Fully Nested Mode Enable */ +#define BUFMS_NBM 0x00 /* Buffered Mode and Master/Slave Select: Non-buffered mode */ +#define BUFMS_BMS 0x08 /* Buffered Mode and Master/Slave Select: Buffered Mode/slave */ +#define BUFMS_BMM 0x0C /* Buffered Mode and Master/Slave Select: Buffered mode/master */ + +#define AEOI 0x02 /* Automatic EOI Mode */ +#define PM 0x01 /* Microprocessor Mode */ + +/* Master, SLAVE 1,2 PIC Interrupt Mask Register Bit Definitions */ + +#define IM7 0x80 /* IR7 Mask */ +#define IM6 0x40 /* IR6 Mask */ +#define IM5 0x20 /* IR5 Mask */ +#define IM4 0x10 /* IR4 Mask */ +#define IM3 0x08 /* IR3 Mask */ +#define IM2 0x04 /* IR2 Mask */ +#define IM1 0x02 /* IR1 Mask */ +#define IM0 0x01 /* IR0 Mask */ + +/* other SLAVE1 and SLAVE2 PIC definitions have already been previously defined + just use the name of the bit as specified in the Register set manual */ + +/* Slave 1 PIC Initilization Control Word 3 Register Masks */ + +#define ID2_ID0 0x07 /* Slave 1 PIC ID 2-0 */ + +/********************************************** +* Reset Generation Registers * +**********************************************/ + +/* MMCR Registers */ + +#define OFFS_SYSINFO 0x0D70 /* System Board Information Register */ +#define OFFS_RESCFG 0x0D72 /* Reset Configuration Register */ +#define OFFS_RESSTA 0x0D74 /* Reset Status Register */ + +#define SYSINFO (MMCR + OFFS_SYSINFO) /* System Board Information Register */ +#define RESCFG (MMCR + OFFS_RESCFG) /* Reset Configuration Register */ +#define RESSTA (MMCR + OFFS_RESSTA) /* Reset Status Register */ + +/* I/O Mapped Registers */ + +#define SCPDATA 0x60 /* SCP DATA Port */ +#define SCPCMD 0x64 /* SCP Command Port */ +#define SYSCTLA 0x92 /* System Control Port A */ +#define FPUERRCLR 0xF0 /* FPU Error Interrupt Clear */ + +/* +Reset Generation Register Bit Definitions +*/ + +/* System Board Information Register Masks */ + +#define RST_ID 0xFF /* Reset Latched Input Data */ + +/* Reset Configuration Register Bit Definitions */ + +#define ICE_ON_RST 0x08 /* Enter AMDebug Mode on Next Reset */ +#define PRG_RST_ENB 0x04 /* Programmable Reset Enable */ +#define GP_RST 0x02 /* Software GP Bus Reset */ +#define SYS_RST 0x01 /* Software System Reset */ + +/* Reset Status Register Bit Definitions */ + +#define SCP_RST_DET 0x40 /* SCP Reset Detect */ +#define ICE_HRST_DET 0x20 /* AMDebug Utiliity Hard Reset Detect */ +#define ICE_SRST_DET 0x10 /* AMDebug Utility Sytem Reset Detect */ +#define WDT_RST_DET 0x08 /* WDT Reset Detect */ +#define SD_RST_DET 0x04 /* CPU Shutdown Reset Detect */ +#define PRGRST_DET 0x02 /* PRGRESET Detect */ +#define PWRGOOD_DET 0x01 /* POWERGOOD Reset Detect */ + +/* SCP Data Port Register Masks */ + +#define SCP_DATA 0xFF /* System Control Processor Data */ + +/* SCP Data Port Register Bit Definitions */ + +#define A20_GATE 0x02 /* A20 Gate Data */ +#define CPU_RST 0x01 /* CPU Reset Control */ + +/* SCP Command Port Register Masks */ + +#define SCP_CMD 0xFF /* SCP Command */ + +/* System Control Port A Register Bit Definitions */ + +#define A20G_CTL 0x02 /* A20 Gate Control */ +/* CPU_RST - Alternate CPU Core Reset Control, already defined */ + +/* Floating Point Error Interrupt Clear Register Mask */ + +#define FPUERR_RST 0xFF /* Clear FPU Error Interrupt Request */ + +/********************************** +* GP Bus DMA Controller Registers * +**********************************/ + +/* GP-DMA MMCR Registers */ + +#define OFFS_GPDMACTL 0x0D80 /* GP-DMa Control Register */ +#define OFFS_GPDMAMMIO 0x0D81 /* GP-DMA Memory-Mapped I/O Register */ +#define OFFS_GPDMAEXTCHMAPA 0x0D82 /* GP-DMA Resource Channel Map A */ +#define OFFS_GPDMAEXTCHMAPB 0x0D84 /* GP-DMA Resource Channel Map B */ +#define OFFS_GPDMAEXTPG0 0x0D86 /* GP-DMA Channel 0 Extended Page */ +#define OFFS_GPDMAEXTPG1 0x0D87 /* GP-DMA Channel 1 Extended Page */ +#define OFFS_GPDMAEXTPG2 0x0D88 /* GP-DMA Channel 2 Extended Page */ +#define OFFS_GPDMAEXTPG3 0x0D89 /* GP-DMA Channel 3 Extended Page */ +#define OFFS_GPDMAEXTPG5 0x0D8a /* GP-DMA Channel 5 Extended Page */ +#define OFFS_GPDMAEXTPG6 0x0D8b /* GP-DMA Channel 6 Extended Page */ +#define OFFS_GPDMAEXTPG7 0x0D8c /* GP-DMA Channel 7 Extended Page */ +#define OFFS_GPDMAEXTTC3 0x0D90 /* GP-DMA Channel 3 Extender Transfer count */ +#define OFFS_GPDMAEXTTC5 0x0D91 /* GP-DMA Channel 5 Extender Transfer count */ +#define OFFS_GPDMAEXTTC6 0x0D92 /* GP-DMA Channel 6 Extender Transfer count */ +#define OFFS_GPDMAEXTTC7 0x0D93 /* GP-DMA Channel 7 Extender Transfer count */ +#define OFFS_GPDMABCCTL 0x0D98 /* Buffer Chaining Control */ +#define OFFS_GPDMABCSTA 0x0D99 /* Buffer Chaining Status */ +#define OFFS_GPDMABSINTENB 0x0D9A /* Buffer Chaining Interrupt Enable */ +#define OFFS_GPDMABCVAL 0x0D9B /* Buffer Chaining Valid */ +#define OFFS_GPDMANXTADDL3 0x0DA0 /* GP-DMA Channel 3 Next Address Low */ +#define OFFS_GPDMANXTADDH3 0x0DA2 /* GP-DMA Channel 3 Next Address High */ +#define OFFS_GPDMANXTADDL5 0x0DA4 /* GP-DMA Channel 5 Next Address Low */ +#define OFFS_GPDMANXTADDH5 0x0DA6 /* GP-DMA Channel 5 Next Address High */ +#define OFFS_GPDMANXTADDL6 0x0DA8 /* GP-DMA Channel 6 Next Address Low */ +#define OFFS_GPDMANXTADDH6 0x0DAA /* GP-DMA Channel 6 Next Address High */ +#define OFFS_GPDMANXTADDL7 0x0DAC /* GP-DMA Channel 7 Next Address Low */ +#define OFFS_GPDMANXTADDH7 0x0DAE /* GP-DMA Channel 7 Next Address High */ +#define OFFS_GPDMANXTTCL3 0x0DB0 /* GP-DMA Channel 3 Next Transfer Count Low */ +#define OFFS_GPDMANXTTCH3 0x0DB2 /* GP-DMA Channel 3 Next Transfer Count High */ +#define OFFS_GPDMANXTTCL5 0x0DB4 /* GP-DMA Channel 5 Next Transfer Count Low */ +#define OFFS_GPDMANXTTCH5 0x0DB6 /* GP-DMA Channel 5 Next Transfer Count High */ +#define OFFS_GPDMANXTTCL6 0x0DB8 /* GP-DMA Channel 6 Next Transfer Count Low */ +#define OFFS_GPDMANXTTCH6 0x0DBA /* GP-DMA Channel 6 Next Transfer Count High */ +#define OFFS_GPDMANXTTCL7 0x0DBC /* GP-DMA Channel 7 Next Transfer Count Low */ +#define OFFS_GPDMANXTTCH7 0x0DBE /* GP-DMA Channel 7 Next Transfer Count High */ + +#define GPDMACTL (MMCR + OFFS_GPDMACTL) /* GP-DMa Control Register */ +#define GPDMAMMIO (MMCR + OFFS_GPDMAMMIO) /* GP-DMA Memory-Mapped I/O Register */ +#define GPDMAEXTCHMAPA (MMCR + OFFS_GPDMAEXTCHMAPA)/* GP-DMA Resource Channel Map A */ +#define GPDMAEXTCHMAPB (MMCR + OFFS_GPDMAEXTCHMAPB)/* GP-DMA Resource Channel Map B */ +#define GPDMAEXTPG0 (MMCR + OFFS_GPDMAEXTPG0) /* GP-DMA Channel 0 Extended Page */ +#define GPDMAEXTPG1 (MMCR + OFFS_GPDMAEXTPG1) /* GP-DMA Channel 1 Extended Page */ +#define GPDMAEXTPG2 (MMCR + OFFS_GPDMAEXTPG2) /* GP-DMA Channel 2 Extended Page */ +#define GPDMAEXTPG3 (MMCR + OFFS_GPDMAEXTPG3) /* GP-DMA Channel 3 Extended Page */ +#define GPDMAEXTPG5 (MMCR + OFFS_GPDMAEXTPG5) /* GP-DMA Channel 5 Extended Page */ +#define GPDMAEXTPG6 (MMCR + OFFS_GPDMAEXTPG6) /* GP-DMA Channel 6 Extended Page */ +#define GPDMAEXTPG7 (MMCR + OFFS_GPDMAEXTPG7) /* GP-DMA Channel 7 Extended Page */ +#define GPDMAEXTTC3 (MMCR + OFFS_GPDMAEXTTC3) /* GP-DMA Channel 3 Extender Transfer count */ +#define GPDMAEXTTC5 (MMCR + OFFS_GPDMAEXTTC5) /* GP-DMA Channel 5 Extender Transfer count */ +#define GPDMAEXTTC6 (MMCR + OFFS_GPDMAEXTTC6) /* GP-DMA Channel 6 Extender Transfer count */ +#define GPDMAEXTTC7 (MMCR + OFFS_GPDMAEXTTC7) /* GP-DMA Channel 7 Extender Transfer count */ +#define GPDMABCCTL (MMCR + OFFS_GPDMABCCTL) /* Buffer Chaining Control */ +#define GPDMABCSTA (MMCR + OFFS_GPDMABCSTA) /* Buffer Chaining Status */ +#define GPDMABSINTENB (MMCR + OFFS_GPDMABSINTENB) /* Buffer Chaining Interrupt Enable */ +#define GPDMABCVAL (MMCR + OFFS_GPDMABCVAL) /* Buffer Chaining Valid */ +#define GPDMANXTADDL3 (MMCR + OFFS_GPDMANXTADDL3) /* GP-DMA Channel 3 Next Address Low */ +#define GPDMANXTADDH3 (MMCR + OFFS_GPDMANXTADDH3) /* GP-DMA Channel 3 Next Address High */ +#define GPDMANXTADDL5 (MMCR + OFFS_GPDMANXTADDL5) /* GP-DMA Channel 5 Next Address Low */ +#define GPDMANXTADDH5 (MMCR + OFFS_GPDMANXTADDH5) /* GP-DMA Channel 5 Next Address High */ +#define GPDMANXTADDL6 (MMCR + OFFS_GPDMANXTADDL6) /* GP-DMA Channel 6 Next Address Low */ +#define GPDMANXTADDH6 (MMCR + OFFS_GPDMANXTADDH6) /* GP-DMA Channel 6 Next Address High */ +#define GPDMANXTADDL7 (MMCR + OFFS_GPDMANXTADDL7) /* GP-DMA Channel 7 Next Address Low */ +#define GPDMANXTADDH7 (MMCR + OFFS_GPDMANXTADDH7) /* GP-DMA Channel 7 Next Address High */ +#define GPDMANXTTCL3 (MMCR + OFFS_GPDMANXTTCL3) /* GP-DMA Channel 3 Next Transfer Count Low */ +#define GPDMANXTTCH3 (MMCR + OFFS_GPDMANXTTCH3) /* GP-DMA Channel 3 Next Transfer Count High */ +#define GPDMANXTTCL5 (MMCR + OFFS_GPDMANXTTCL5) /* GP-DMA Channel 5 Next Transfer Count Low */ +#define GPDMANXTTCH5 (MMCR + OFFS_GPDMANXTTCH5) /* GP-DMA Channel 5 Next Transfer Count High */ +#define GPDMANXTTCL6 (MMCR + OFFS_GPDMANXTTCL6) /* GP-DMA Channel 6 Next Transfer Count Low */ +#define GPDMANXTTCH6 (MMCR + OFFS_GPDMANXTTCH6) /* GP-DMA Channel 6 Next Transfer Count High */ +#define GPDMANXTTCL7 (MMCR + OFFS_GPDMANXTTCL7) /* GP-DMA Channel 7 Next Transfer Count Low */ +#define GPDMANXTTCH7 (MMCR + OFFS_GPDMANXTTCH7) /* GP-DMA Channel 7 Next Transfer Count High */ + +/* GP-DMA Direct-Mapped Registers */ + +#define GPDMA0MAR 0x0000 /* Slave DMA Channel 0 Memory Address */ +#define GPDMA0TC 0x0001 /* Slave DMA Channel 0 Transfer Count */ +#define GPDMA1MAR 0x0002 /* Slave DMA Channel 1 Memory Address */ +#define GPDMA1TC 0x0003 /* Slave DMA Channel 1 Transfer Count */ +#define GPDMA2MAR 0x0004 /* Slave DMA Channel 2 Memory Address */ +#define GPDMA2TC 0x0005 /* Slave DMA Channel 2 Transfer Count */ +#define GPDMA3MAR 0x0006 /* Slave DMA Channel 3 Memory Address */ +#define GPDMA3TC 0x0007 /* Slave DMA Channel 3 Transfer Count */ +#define SLDMASTA 0x0008 /* Slave DMA Channel 0-3 Status */ +#define SLDMACTL 0x0008 /* Slave DMA Channel 0-3 Control */ +#define SLDMASWREQ 0x0009 /* Slave Software DRQ(n) Request */ +#define SLDMAMSK 0x000A /* Slave DMA Channel 0-3 Mask */ +#define SLDMAMODE 0x000B /* Slave DMA Channel 0-3 Mode */ +#define SLDMACBP 0x000C /* Slave DMA Clear Byte Pointer */ +#define SLDMARST 0x000D /* Slave DMA Controller Reset */ +#define SLDMATMP 0x000D /* Slave DMA Controller Temporary */ +#define SLDMAMSKRST 0x000E /* Slave DMA Mask Reset */ +#define SLDMAGENMSK 0x000F /* Slave DMA General Mask */ +#define GPDMAGR0 0x0080 /* General 0 */ +#define GPDMA2PG 0x0081 /* Slave DMA Channel 2 Page */ +#define GPDMA3PG 0x0082 /* Slave DMA Channel 3 Page */ +#define GPDMA1PG 0x0083 /* Slave DMA Channel 1 Page */ +#define GPDMAGR1 0x0084 /* General 1 */ +#define GPDMAGR2 0x0085 /* General 2 */ +#define GPDMAGR3 0x0086 /* General 3 */ +#define GPDMA0PG 0x0087 /* Slave DMA Channel 0 Page */ +#define GPDMAGR4 0x0088 /* General 4 */ +#define GPDMA6PG 0x0089 /* Master DMA Channel 6 Page */ +#define GPDMA7PG 0x008a /* Master DMA Channel 7 Page */ +#define GPDMA5PG 0x008b /* Master DMA Channel 5 Page */ +#define GPDMAGR5 0x008c /* General 5 */ +#define GPDMAGR6 0x008d /* General 6 */ +#define GPDMAGR7 0x008e /* General 7 */ +#define GPDMAGR8 0x008f /* General 8 */ +#define GPDMA4MAR 0x00c0 /* Master DMA Channel 4 Memory Address */ +#define GPDMA4TC 0x00c2 /* Master DMA Channel 4 Transfer Count */ +#define GPDMA5MAR 0x00c4 /* Master DMA Channel 5 Memory Address */ +#define GPDMA5TC 0x00c6 /* Master DMA Channel 5 Transfer Count */ +#define GPDMA6MAR 0x00c8 /* Master DMA Channel 6 Memory Address */ +#define GPDMA6TC 0x00cc /* Master DMA Channel 6 Transfer Count */ +#define GPDMA7MAR 0x00ce /* Master DMA Channel 7 Memory Address */ +#define GPDMA7TC 0x00c2 /* Master DMA Channel 7 Transfer Count */ +#define MSTDMASTA 0x00d0 /* Master DMA Channel 4-7 Status */ +#define MSTDMACTL 0x00d0 /* Master DMA Channel 4-7 Control */ +#define MSTDMASWREQ 0x00d2 /* Master Software DRQ(n) Request */ +#define MSTDMAMSK 0x00d4 /* Master DMA Channel 4-7 Mask */ +#define MSTDMAMODE 0x00d6 /* Master DMA Channel 4-7 mode */ +#define MSTDMACBP 0x00d8 /* Master DMA Clear Byte Pointer */ +#define MSTDMARST 0x00da /* Master DMA Controller Reset */ +#define MSTDMATMP 0x00da /* Master DMA Temporary */ +#define MSTDMAMSKRST 0x00dc /* Master DMA Mask Reset */ +#define MSTDMAGENMSK 0x00de /* Master DMA General Mask */ + +/* +GP Bus DMA Controller Register Bit Definitions +*/ + +/* GP-DMA Control Register Bit Definitions */ + +#define CH7_ALT_SIZE 0x80 /* Alternate Size for Channel 7 */ +#define CH6_ALT_SIZE 0x40 /* Alternate Size for Channel 6 */ +#define CH5_ALT_SIZE 0x20 /* Alternate Size for Channel 5 */ +#define CH3_ALT_SIZE 0x10 /* Alternate Size for Channel 3 */ + +#define CLK_MODE_4MHZ 0x00 /* Clock Mode: GP Bus Controller at 4Mhz */ +#define CLK_MODE_8MHZ 0x04 /* Clock Mode: GP Bus Controller at 8Mhz */ +#define CLK_MODE_16MHZ 0x08 /* Clock Mode: GP Bus Controller at 16Mhz */ + +#define ENH_MODE_ENB 0x01 /* Enhanced Mode Enable */ + +/* GP-DMA Memory-Mapped I/O Register Bit Definitions */ + +#define DMA7_MMAP 0x80 /* Memory-Mapped Device for DMA Channel 7 */ +#define DMA6_MMAP 0x40 /* Memory-Mapped Device for DMA Channel 6 */ +#define DMA5_MMAP 0x20 /* Memory-Mapped Device for DMA Channel 5 */ +#define DMA3_MMAP 0x08 /* Memory-Mapped Device for DMA Channel 3 */ +#define DMA2_MMAP 0x04 /* Memory-Mapped Device for DMA Channel 2 */ +#define DMA1_MMAP 0x02 /* Memory-Mapped Device for DMA Channel 1 */ +#define DMA0_MMAP 0x01 /* Memory-Mapped Device for DMA Channel 0 */ + +/* GP-DMA Resource Channel Map A Register Bit Definitions */ + +#define GPDRQ3_CHSEL_0 0x0000 /* GPDRQ3 Channel Mapping: Channel 0 */ +#define GPDRQ3_CHSEL_1 0x1000 /* GPDRQ3 Channel Mapping: Channel 1 */ +#define GPDRQ3_CHSEL_2 0x2000 /* GPDRQ3 Channel Mapping: Channel 2 */ +#define GPDRQ3_CHSEL_3 0x3000 /* GPDRQ3 Channel Mapping: Channel 3 */ +#define GPDRQ3_CHSEL_5 0x5000 /* GPDRQ3 Channel Mapping: Channel 5 */ +#define GPDRQ3_CHSEL_6 0x6000 /* GPDRQ3 Channel Mapping: Channel 6 */ +#define GPDRQ3_CHSEL_7 0x7000 /* GPDRQ3 Channel Mapping: Channel 7 */ + +#define GPDRQ2_CHSEL_0 0x0000 /* GPDRQ2 Channel Mapping: Channel 0 */ +#define GPDRQ2_CHSEL_1 0x0100 /* GPDRQ2 Channel Mapping: Channel 1 */ +#define GPDRQ2_CHSEL_2 0x0200 /* GPDRQ2 Channel Mapping: Channel 2 */ +#define GPDRQ2_CHSEL_3 0x0300 /* GPDRQ2 Channel Mapping: Channel 3 */ +#define GPDRQ2_CHSEL_5 0x0500 /* GPDRQ2 Channel Mapping: Channel 5 */ +#define GPDRQ2_CHSEL_6 0x0600 /* GPDRQ2 Channel Mapping: Channel 6 */ +#define GPDRQ2_CHSEL_7 0x0700 /* GPDRQ2 Channel Mapping: Channel 7 */ + +#define GPDRQ1_CHSEL_0 0x0000 /* GPDRQ1 Channel Mapping: Channel 0 */ +#define GPDRQ1_CHSEL_1 0x0010 /* GPDRQ1 Channel Mapping: Channel 1 */ +#define GPDRQ1_CHSEL_2 0x0020 /* GPDRQ1 Channel Mapping: Channel 2 */ +#define GPDRQ1_CHSEL_3 0x0030 /* GPDRQ1 Channel Mapping: Channel 3 */ +#define GPDRQ1_CHSEL_5 0x0050 /* GPDRQ1 Channel Mapping: Channel 5 */ +#define GPDRQ1_CHSEL_6 0x0060 /* GPDRQ1 Channel Mapping: Channel 6 */ +#define GPDRQ1_CHSEL_7 0x0070 /* GPDRQ1 Channel Mapping: Channel 7 */ + +#define GPDRQ0_CHSEL_0 0x0000 /* GPDRQ0 Channel Mapping: Channel 0 */ +#define GPDRQ0_CHSEL_1 0x0001 /* GPDRQ0 Channel Mapping: Channel 1 */ +#define GPDRQ0_CHSEL_2 0x0002 /* GPDRQ0 Channel Mapping: Channel 2 */ +#define GPDRQ0_CHSEL_3 0x0003 /* GPDRQ0 Channel Mapping: Channel 3 */ +#define GPDRQ0_CHSEL_5 0x0005 /* GPDRQ0 Channel Mapping: Channel 5 */ +#define GPDRQ0_CHSEL_6 0x0006 /* GPDRQ0 Channel Mapping: Channel 6 */ +#define GPDRQ0_CHSEL_7 0x0007 /* GPDRQ0 Channel Mapping: Channel 7 */ + +/* GP-DMA Resource Channel Map B Register Bit Definitions */ + +#define TXDRQ3_CHSEL_0 0x0000 /* TXDRQ3 Channel Mapping: Channel 0 */ +#define TXDRQ3_CHSEL_1 0x1000 /* TXDRQ3 Channel Mapping: Channel 1 */ +#define TXDRQ3_CHSEL_2 0x2000 /* TXDRQ3 Channel Mapping: Channel 2 */ +#define TXDRQ3_CHSEL_3 0x3000 /* TXDRQ3 Channel Mapping: Channel 3 */ + +#define TXDRQ2_CHSEL_0 0x0000 /* TXDRQ2 Channel Mapping: Channel 0 */ +#define TXDRQ2_CHSEL_1 0x0100 /* TXDRQ2 Channel Mapping: Channel 1 */ +#define TXDRQ2_CHSEL_2 0x0200 /* TXDRQ2 Channel Mapping: Channel 2 */ +#define TXDRQ2_CHSEL_3 0x0300 /* TXDRQ2 Channel Mapping: Channel 3 */ + +#define TXDRQ1_CHSEL_0 0x0000 /* TXDRQ1 Channel Mapping: Channel 0 */ +#define TXDRQ1_CHSEL_1 0x0010 /* TXDRQ1 Channel Mapping: Channel 1 */ +#define TXDRQ1_CHSEL_2 0x0020 /* TXDRQ1 Channel Mapping: Channel 2 */ +#define TXDRQ1_CHSEL_3 0x0030 /* TXDRQ1 Channel Mapping: Channel 3 */ + +#define TXDRQ0_CHSEL_0 0x0000 /* TXDRQ0 Channel Mapping: Channel 0 */ +#define TXDRQ0_CHSEL_1 0x0001 /* TXDRQ0 Channel Mapping: Channel 1 */ +#define TXDRQ0_CHSEL_2 0x0002 /* TXDRQ0 Channel Mapping: Channel 2 */ +#define TXDRQ0_CHSEL_3 0x0003 /* TXDRQ0 Channel Mapping: Channel 3 */ + +/* GP-DMA Channel 0 Extended Page Register Masks */ + +#define DMA0ADR 0x0F /* GP-DMA Channel 0 Extended Page Address */ + +/* GP-DMA Channel 1 Extended Page Register Masks */ + +#define DMA1ADR 0x0F /* GP-DMA Channel 1 Extended Page Address */ + +/* GP-DMA Channel 2 Extended Page Register Masks */ + +#define DMA2ADR 0x0F /* GP-DMA Channel 2 Extended Page Address */ + +/* GP-DMA Channel 3 Extended Page Register Masks */ + +#define DMA3ADR 0x0F /* GP-DMA Channel 3 Extended Page Address */ + +/* GP-DMA Channel 5 Extended Page Register Masks */ + +#define DMA5ADR 0x0F /* GP-DMA Channel 5 Extended Page Address */ + +/* GP-DMA Channel 6 Extended Page Register Masks */ + +#define DMA6ADR 0x0F /* GP-DMA Channel 6 Extended Page Address */ + +/* GP-DMA Channel 7 Extended Page Register Masks */ + +#define DMA7ADR 0x0F /* GP-DMA Channel 7 Extended Page Address */ + +/* GP-DMA Channel 3 Extended Transfer Count Register Masks */ + +#define DMA3TC 0xFF /* GP-DMA Channel 3 Transfer Count Extension */ + +/* GP-DMA Channel 5 Extended Transfer Count Register Masks */ + +#define DMA5TC 0xFF /* GP-DMA Channel 5 Transfer Count Extension */ + +/* GP-DMA Channel 6 Extended Transfer Count Register Masks */ + +#define DMA6TC 0xFF /* GP-DMA Channel 6 Transfer Count Extension */ + +/* GP-DMA Channel 7 Extended Transfer Count Register Masks */ + +#define DMA7TC 0xFF /* GP-DMA Channel 7 Transfer Count Extension */ + +/* Buffer Chaining Control Register Bit Definitions */ + +#define CH7_BCHN_ENB 0x08 /* Buffer Chaining Enable for Channel 7 */ +#define CH6_BCHN_ENB 0x04 /* Buffer Chaining Enable for Channel 6 */ +#define CH5_BCHN_ENB 0x02 /* Buffer Chaining Enable for Channel 5 */ +#define CH3_BCHN_ENB 0x01 /* Buffer Chaining Enable for Channel 3 */ + +/* Buffer Chaining Status Register Bit Definitions */ + +#define CH7_EOB_STA 0x08 /* End of Current Buffer in Channel 7 */ +#define CH6_EOB_STA 0x04 /* End of Current Buffer in Channel 6 */ +#define CH5_EOB_STA 0x02 /* End of Current Buffer in Channel 5 */ +#define CH3_EOB_STA 0x01 /* End of Current Buffer in Channel 3 */ + +/* Buffer Chaining Interrupt Enable Register Bit Definitions */ + +#define CH7_INT_ENB 0x08 /* Interrupt Enable for Channel 7 */ +#define CH6_INT_ENB 0x04 /* Interrupt Enable for Channel 6 */ +#define CH5_INT_ENB 0x02 /* Interrupt Enable for Channel 5 */ +#define CH3_INT_ENB 0x01 /* Interrupt Enable for Channel 3 */ + +/* Buffer Chaining Valid Register Bit Definitions */ + +#define CH7_CBUF_VAL 0x08 /* Chaining Buffer Valid for Channel 7 */ +#define CH6_CBUF_VAL 0x04 /* Chaining Buffer Valid for Channel 6 */ +#define CH5_CBUF_VAL 0x02 /* Chaining Buffer Valid for Channel 5 */ +#define CH3_CBUF_VAL 0x01 /* Chaining Buffer Valid for Channel 3 */ + +/* GP-DMA Channel 3 Next Address Low Register Masks */ + +#define DMA3_NXT_ADRL 0xFFFF /* GP-DMA Channel 3 Next Address Low*/ + +/* GP-DMA Channel 3 Next Address High Register Masks */ + +#define DMA3_NXT_ADRH 0x0FFF /* GP-DMA Channel 3 Next Address High */ + +/* GP-DMA Channel 5 Next Address Low Register Masks */ + +#define DMA5_NXT_ADRL 0xFFFF /* GP-DMA Channel 5 Next Address Low */ + +/* GP-DMA Channel 5 Next Address High Register Masks */ + +#define DMA5_NXT_ADRH 0x0FFF /* GP-DMA Channel 5 Next Address High */ + +/* GP-DMA Channel 6 Next Address Low Register Masks */ + +#define DMA6_NXT_ADRL 0xFFFF /* GP-DMA Channel 6 Next Address Low */ + +/* GP-DMA Channel 6 Next Address High Register Masks */ + +#define DMA6_NXT_ADRH 0x0FFF /* GP-DMA Channel 6 Next Address High */ + +/* GP-DMA Channel 7 Next Address Low Register Masks */ + +#define DMA7_NXT_ADRL 0xFFFF /* GP-DMA Channel 7 Next Address Low */ + +/* GP-DMA Channel 7 Next Address High Register Masks */ + +#define DMA7_NXT_ADRH 0x0FFF /* GP-DMA Channel 7 Next Address High */ + + +/* GP-DMA Channel 3 Next Transfer Count Low Register Masks */ + +#define DMA3_NXT_TCL 0xFFFF /* GP-DMA Channel 3 Next Transfer Count Low*/ + +/* GP-DMA Channel 3 Next Transfer Count High Register Masks */ + +#define DMA3_NXT_TCH 0xFF /* GP-DMA Channel 3 Next Transfer Count High*/ + +/* GP-DMA Channel 5 Next Transfer Count Low Register Masks */ + +#define DMA5_NXT_TCL 0xFFFF /* GP-DMA Channel 5 Next Transfer Count Low */ + +/* GP-DMA Channel 5 Next Transfer Count High Register Masks */ + +#define DMA5_NXT_TCH 0xFF /* GP-DMA Channel 5 Next Transfer Count High*/ + +/* GP-DMA Channel 6 Next Transfer Count Low Register Masks */ + +#define DMA6_NXT_TCL 0xFFFF /* GP-DMA Channel 6 Next Transfer Count Low */ + +/* GP-DMA Channel 6 Next Transfer Count High Register Masks */ + +#define DMA6_NXT_TCH 0xFF /* GP-DMA Channel 6 Next Transfer Count High*/ + +/* GP-DMA Channel 7 Next Transfer Count Low Register Masks */ + +#define DMA7_NXT_TCL 0xFFFF /* GP-DMA Channel 7 Next Transfer Count Low */ + +/* GP-DMA Channel 7 Next Transfer Count High Register Masks */ + +#define DMA7_NXT_TCH 0xFF /* GP-DMA Channel 7 Next Transfer Count High*/ + +/* Slave DMA Channel 0 Memory Address Register Masks */ + +#define DMA0MAR 0xFF /* Lower 16 Bits of DMA Channel 0 Memory Address */ + +/* Slave DMA Channel 0 Transfer Count Register Masks */ + +#define DMA0TC 0xFF /* DMA Channel 0 Transfer Count */ + +/* Slave DMA Channel 1 Memory Address Register Masks */ + +#define DMA1MAR 0xFF /* Lower 16 Bits of DMA Channel 1 Memory Address */ + +/* Slave DMA Channel 1 Transfer Count Register Masks */ + +#define DMA1TC 0xFF /* DMA Channel 1 Transfer Count */ + +/* Slave DMA Channel 2 Memory Address Register Masks */ + +#define DMA2MAR 0xFF /* Lower 16 Bits of DMA Channel 2 Memory Address */ + +/* Slave DMA Channel 2 Transfer Count Register Masks */ + +#define DMA2TC 0xFF /* DMA Channel 2 Transfer Count */ + +/* Slave DMA Channel 3 Memory Address Register Masks */ + +#define DMA3MAR 0xFF /* Lower 16 Bits of DMA Channel 3 Memory Address */ + +/* Slave DMA Channel 3 Transfer Count Register Masks */ + +#define DMA3TC 0xFF /* DMA Channel 3 Transfer Count */ + +/* Slave DMA Channel 0-3 Status Register Bit Definitions */ + +#define DMAR3 0x80 /* Channel 3 DMA Request */ +#define DMAR2 0x40 /* Channel 2 DMA Request */ +#define DMAR1 0x20 /* Channel 1 DMA Request */ +#define DMAR0 0x10 /* Channel 0 DMA Request */ + +#define TC3 0x08 /* Channel 3 Terminal Count */ +#define TC2 0x04 /* Channel 2 Terminal Count */ +#define TC1 0x02 /* Channel 1 Terminal Count */ +#define TC0 0x01 /* Channel 0 Terminal Count */ + +/* Slave DMA Channel 0-3 Control Register Bit Definitions */ + +#define DAKSEN 0x80 /* Internal /DACKX Sense */ +#define DRQSEN 0x40 /* Internal drqx Sense */ +#define WRTSEL 0x20 /* Write Selection Control */ +#define PRITYPE 0x10 /* Priority Type */ +#define COMPTIM 0x08 /* Compressed Timing */ +#define DMA_DIS 0x04 /* Disable DMA Controller */ + +/* Slave Software DRQ(n) Request Register Bit Definitions */ + +#define REQDMA 0x04 /* Software DMA Request */ + +#define REQSEL_CH0 0x00 /* DMA Channel Select: channel 0 */ +#define REQSEL_CH1 0x01 /* DMA Channel Select: channel 1 */ +#define REQSEL_CH2 0x02 /* DMA Channel Select: channel 2 */ +#define REQSEL_CH3 0x03 /* DMA Channel Select: channel 3 */ + +/* Slave DMA Channel 0-3 Mask Register Bit Definitions */ + +#define CHMASK 0x40 /* DMA Channel Mask */ + +#define MSKSEL_CH0 0x00 /* DMA Channel Mask Select: channel 0 */ +#define MSKSEL_CH1 0x01 /* DMA Channel Mask Select: channel 1 */ +#define MSKSEL_CH2 0x02 /* DMA Channel Mask Select: channel 2 */ +#define MSKSEL_CH3 0x03 /* DMA Channel Mask Select: channel 3 */ + +/* Slave DMA Channel 0-3 Mode Register Bit Definitions */ + +#define TRNMOD_DTM 0x00 /* Transfer Mode: Demand transfer */ +#define TRNMOD_STM 0x40 /* Transfer Mode: Single transfer */ +#define TRNMOD_BTM 0x80 /* Transfer Mode: Block transfer */ +#define TRNMOD_CM 0xC0 /* Transfer Mode: Cascade Mode */ + +#define ADDDEC 0x20 /* Address Decrement */ +#define AINIT 0x10 /* Automatic Initilization Control */ + +#define OPSEL_VM 0x00 /* Operation Select: Verify Mode */ +#define OPSEL_WT 0x40 /* Operation Select: Write Transfer Mode */ +#define OPSEL_RT 0x80 /* Operation Select: Read Transfer Mode */ + +#define MODSEL_CH0 0x00 /* DMA Channel Select:channel 0 */ +#define MODSEL_CH1 0x01 /* DMA Channel Select:channel 1 */ +#define MODSEL_CH2 0x02 /* DMA Channel Select:channel 2 */ +#define MODSEL_CH30 0x03 /* DMA Channel Select:channel 3 */ + +/* Slave DMA Clear Byte Pointer Register Masks */ + +#define SLAVE_CBP 0xFF /* Slave DMA Clear Byte Pointer */ + +/* Slave DMA Controller Reset Register Masks */ + +#define SLAVE_RST 0xFF /* Slave DMA Controller Reset */ + +/* Slave DMA Controller Temporary Register Masks */ + +#define SLAVE_TMP 0xFF /* Slave DMa Controller Temporary Register */ + +/* Slave DMA Mask Reset Register Masks */ + +#define SLAVE_MSK_RST 0xFF /* Slave DMA Reset Mask */ + +/* Slave DMA General Mask Register Bit Definitions */ + +#define CH3_DIS 0x08 /* DMA Channel 3 Mask */ +#define CH2_DIS 0x04 /* DMA Channel 2 Mask */ +#define CH1_DIS 0x02 /* DMA Channel 1 Mask */ +#define CH0_DIS 0x01 /* DMA Channel 0 Mask */ + +/* General 0 Register Masks */ + +#define PORT80 0xFF /* General Purpose R/W Register */ + +/* Slave DMA Channel 2 Page Register Masks */ + +#define DMA2MAR 0xFF /* DMA Channel 2 Memory Address Bits [23-16] */ + +/* Slave DMA Channel 3 Page Register Masks */ + +#define DMA3MAR 0xFF /* DMA Channel 3 Memory Address Bits [23-16] */ + +/* Slave DMA Channel 1 Page Register Masks */ + +#define DMA1MAR 0xFF /* DMA Channel 1 Memory Address Bits [23-16] */ + +/* General 1 Register Masks */ + +#define PORT84 0xFF /* General Purpose R/W Register */ + +/* General 2 Register Masks */ + +#define PORT85 0xFF /* General Purpose R/W Register */ + +/* General 3 Register Masks */ + +#define PORT86 0xFF /* General Purpose R/W Register */ + +/* Slave DMA Channel 0 Page Register Masks */ + +#define DMA0MAR 0xFF /* DMA Channel 0 Memory Address Bits [23-16] */ + +/* General 4 Register Masks */ + +#define PORT88 0xFF /* General Purpose R/W Register */ + + + +/* Master DMA Channel 6 Page Register Masks */ + +#define DMA6MAR_H 0xFE /* DMA Channel 6 Memory Address Bits [23-17] */ + +/* Master DMA Channel 7 Page Register Masks */ + +#define DMA7MAR_H 0xFE /* DMA Channel 7 Memory Address Bits [23-17] */ + +/* Master DMA Channel 5 Page Register Masks */ + +#define DMA5MAR_H 0xFE /* DMA Channel 5 Memory Address Bits [23-17] */ + +/* General 5 Register Masks */ + +#define PORT8C 0xFF /* General Purpose R/W Register */ + +/* General 6 Register Masks */ + +#define PORT8D 0xFF /* General Purpose R/W Register */ + +/* General 7 Register Masks */ + +#define PORT8E 0xFF /* General Purpose R/W Register */ + +/* General 8 Register Masks */ + +#define PORT8F 0xFF /* General Purpose R/W Register */ + +/* Master DMA Channel 4 Memory Address Register Masks */ + +#define DMA4MAR 0xFF /* DMA Channel 4 Memory Address */ + +/* Master DMA Channel 4 Transfer Count Register Masks */ + +#define DMA4TC 0xFF /* DMA Channel 4 Transfer Count */ + +/* Master DMA Channel 5 Memory Address Register Masks */ + +#define DMA5MAR 0xFF /* DMA Channel 5 Memory Address */ + +/* Master DMA Channel 5 Transfer Count Register Masks */ + +#define DMA5TC 0xFF /* DMA Channel 5 Transfer Count */ + +/* Master DMA Channel 6 Memory Address Register Masks */ + +#define DMA6MAR 0xFF /* DMA Channel 6 Memory Address */ + +/* Master DMA Channel 6 Transfer Count Register Masks */ + +#define DMA6TC 0xFF /* DMA Channel 6 Transfer Count */ + +/* Master DMA Channel 7 Memory Address Register Masks */ + +#define DMA7MAR 0xFF /* DMA Channel 7 Memory Address */ + +/* Master DMA Channel 7 Transfer Count Register Masks */ + +#define DMA7TC 0xFF /* DMA Channel 7 Transfer Count */ + +/* Master DMA Channel 4-7 Status Register Bit Definitions */ + +#define DMAR7 0x80 /* Channel 7 DMA Request */ +#define DMAR6 0x40 /* Channel 6 DMA Request */ +#define DMAR5 0x20 /* Channel 5 DMA Request */ +#define DMAR4 0x10 /* Channel 4 DMA Request */ + +#define TC7 0x08 /* Channel 7 Terminal Count */ +#define TC6 0x04 /* Channel 6 Terminal Count */ +#define TC5 0x02 /* Channel 5 Terminal Count */ +#define TC4 0x01 /* Channel 4 Terminal Count */ + +/* Master DMA Channel 4-7 Control Bit Definitions already defined previously */ + + /* REQDMA bit already definined */ + +#define REQSEL1_CH4 0x00 /* DMA Channel Select: Channel 4 */ +#define REQSEL1_CH5 0x01 /* DMA Channel Select: Channel 5 */ +#define REQSEL1_CH6 0x02 /* DMA Channel Select: Channel 6 */ +#define REQSEL1_CH7 0x03 /* DMA Channel Select: Channel 7 */ + +/* Master DMA Channel 4-7 Mask Register Definitions */ + + /* CHMASK bit already correctly defined previously */ + +#define MSKSEL_CH4 0x00 /* DMA Channel Mask Select: channel 4 */ +#define MSKSEL_CH5 0x01 /* DMA Channel Mask Select: channel 5 */ +#define MSKSEL_CH6 0x02 /* DMA Channel Mask Select: channel 6 */ +#define MSKSEL_CH7 0x03 /* DMA Channel Mask Select: channel 7 */ + +/* Master DMA Channel 4-7 Mode Register Bit Definitions */ + + /* TRNMOD bits already defined */ + /* ADDDEC bit already defined */ + /* AINIT bit already defined */ + /* OPSEL bits already defined */ + +#define MODSEL_CH4 0x00 /* DMA Channel Select: Channel 4 */ +#define MODSEL_CH5 0x01 /* DMA Channel Select: Channel 5 */ +#define MODSEL_CH6 0x02 /* DMA Channel Select: Channel 6 */ +#define MODSEL_CH7 0x03 /* DMA Channel Select: Channel 7 */ + +/* Master DEMA Clear Byte Pointer Register Masks */ + +#define MASTR_CBP 0xFF /* Master DMA Clear Byte Pointer */ + +/* Master DMA Controller Reset Register Masks */ + +#define MASTR_RST 0xFF /* Master DMA Controller Reset */ + +/* Master DMA Controller Temporary Register Masks */ + +#define MASTR_TMP 0xFF /* Master DMA Controller Temporary Register */ + +/* Master DMA Mask Reset Register Masks */ + +#define MASTR_MSK_RST 0xFF /* Master DMA Reset Mask */ + +/* Master DMA General Mask Register Bit Definitions */ + +#define CH7_DIS 0x08 /* DMA Channel 7 Mask */ +#define CH6_DIS 0x04 /* DMA Channel 6 Mask */ +#define CH5_DIS 0x02 /* DMA Channel 5 Mask */ +#define CH4_DIS 0x01 /* DMA Channel 4 Mask */ + +/**************************** +* Real-Time Clock Registers * +****************************/ + +/* Real-Time Clock Direct-Mapped Registers */ + +#define RTCIDX 0x0070 /* RTC/CMOS RAM Index Register */ +#define RTCDATA 0x0071 /* RTC/CMOS RAM Data Port */ + +/* Real-Time Clock Indexed Registers */ + +#define RTCCURSEC 0x00 /* RTC Current Second */ +#define RTCALMSEC 0x01 /* RTC Alarm Second */ +#define RTCCURMIN 0x02 /* RTC Current Minute */ +#define RTCALMMIN 0x03 /* RTC Alarm Minute */ +#define RTCCURHR 0x04 /* RTC Current Hour */ +#define RTCALMHR 0x05 /* RTC Alarm Hour */ +#define RTCCURDOW 0x06 /* RTC Current Day of Week */ +#define RTCCURDOM 0x07 /* RTC Current Day of Month */ +#define RTCDURMON 0x08 /* RTC Current Month */ +#define RTCCURYR 0x09 /* RTC Current Year */ +#define RTCCTLA 0x0a /* RTC Control A */ +#define RTCCTLB 0x0b /* RTC Control A */ +#define RTCCTLC 0x0c /* RTC Control A */ +#define RTCCTLD 0x0d /* RTC Control A */ + +/* +Real-Time Clock Register Bit Definitions +*/ + +/* RTC/CMOS RAM Index Register Mask */ + +#define CMOSIDX 0x7E /* RTC/CMOS RAM Index */ + +/* RTC/CMOS RAM Data Port Register Mask */ + +#define CMOSDATA 0xFF /* RTC/CMOS Data Port */ + +/* RTC Current Second Register Mask */ + +#define SECOND 0xFF /* RTC Current Second */ + +/* RTC Alarm Second Register Mask */ + +#define ALM_SECOND 0xFF /* RTC Alarm Second */ + +/* RTC Current Minute Register Mask */ + +#define MINUTE 0xFF /* RTC Current Minute */ + +/* RTC Alarm Minute Register Mask */ + +#define ALM_MINUTE 0xFF /* RTC Alarm Minute */ + +/* RTC Current Hour Register Bit Definitions */ + +#define AM_PM 0x80 /* RTC AM/PM Indicator */ + +/* RTC Current Hour Register Mask */ + +#define HOUR 0x7F /* RTC Current Hour */ + +/* RTC Alarm Hour Register Bit Definitions */ + +#define ALARM_AM_PM 0x80 /* RTC Alarm AM/PM Indicator */ + +/* RTC Alarm Hour Register Mask */ + +#define ALM_HOUR 0x7F /* RTC Alarm Hour */ + +/* RTC Current Day of the Week Register Bit Definitions */ + +#define SUNDAY 0x01 /* Sunday day of week */ +#define MONDAY 0x02 /* Monday day of week */ +#define TUESDAY 0x03 /* Tuesday day of week */ +#define WEDNESDAY 0x04 /* Wednesday day of week */ +#define THURDAY 0x05 /* Thursday day of week */ +#define FRIDAY 0x06 /* Friday!!!! day of week */ +#define SATURDAY 0x07 /* Saturday day of week */ + +/* RTC Current Day of the Week Register Mask */ + +#define DAY_OF_WEEK 0xFF /* RTC Current Day of the Week */ + +/* RTC Current Day of the Month Register Mask */ + +#define DAY_OF_MTH 0xFF /* RTC Current Day of the Month */ + +/* RTC Current Month Register Bit Definitions */ + +#define JANUARY 0x01 /* month of January */ +#define FEBRUARY 0x02 /* month of February */ +#define MARCH 0x03 /* month of March */ +#define APRIL 0x04 /* month of April */ +#define MAY 0x05 /* month of May */ +#define JUNE 0x06 /* month of June */ +#define JULY 0x07 /* month of July */ +#define AUGUST 0x08 /* month of August */ +#define SEPTEMBER 0x09 /* month of September */ +#define OCTOBER 0x0a /* month of October */ +#define NOVEMBER 0x0b /* month of November */ +#define DECEMBER 0x0c /* month of December */ + +/* RTC Current Month Register Mask */ + +#define MONTH 0xFF /* RTC Current Month */ + +/* RTC Current Year Register Mask */ + +#define YEAR 0xFF /* RTC Current Year */ + +/* RTC Control A Register Bit Definitions */ + +#define UIP 0x80 /* Update in Progress */ + +#define OSC_CTL_ENB 0x20 /* Enable RTC to be updated once per sec (normal) */ +#define OSC_CTL_HOLD 0x60 /* Hold RTC in reset state */ + +#define RATE_SEL_PID 0x00 /* Rate Selection: Periodic Interrupt Disabled */ +#define RATE_SEL_3_906m 0x01 /* Rate Selection: 3.906 milliseconds */ +#define RATE_SEL_7_812m 0x02 /* Rate Selection: 7.812 milliseconds */ +#define RATE_SEL_122_070u 0x03 /* Rate Selection: 122.070 microseconds */ +#define RATE_SEL_244_141u 0x04 /* Rate Selection: 244.141 microseconds */ +#define RATE_SEL_488_281u 0x05 /* Rate Selection: 488.281 microseconds */ +#define RATE_SEL_976_563u 0x06 /* Rate Selection: 976.563 microseconds */ + +#define RATE_SEL_1_953m 0x09 /* Rate Selection: 1.953 milliseconds */ +#define RATE_SEL_15_625m 0x0a /* Rate Selection: 15.625 milliseconds */ +#define RATE_SEL_31_250m 0x0b /* Rate Selection: 31.250 milliseconds */ +#define RATE_SEL_62_500m 0x0c /* Rate Selection: 62.500 milliseconds */ +#define RATE_SEL_125_000m 0x0d /* Rate Selection: 125.000 milliseconds */ +#define RATE_SEL_250_000m 0x0e /* Rate Selection: 250.000 milliseconds */ +#define RATE_SEL_500_000m 0x0f /* Rate Selection: 500.000 milliseconds */ + +/* RTC Control B Register Bit Definitions */ + +#define SET 0x80 /* Set Bit */ +#define PER_INT_ENB 0x40 /* Periodic Interrupt Enable */ +#define ALM_INT_ENB 0x20 /* Alarm Interrupt Enable */ +#define UPD_INT_ENB 0x10 /* Update-Ended Interrupt Enable */ +#define DATE_MODE 0x04 /* Date Mode */ +#define HOUR_MODE_SEL 0x02 /* 12/24-Hour Mode Select Bit */ +#define DS_ENB 0x01 /* Daylight Savings Enable */ + +/* RTC Status C Register Bit Definitions */ + +#define INT_FLG 0x80 /* Interrupt Request Flag */ +#define PER_INT_FLG 0x40 /* Periodic Interrupt Flag */ +#define ALM_INT_FLG 0x20 /* Alarm Interrupt Flag */ +#define UPD_INT_FLG 0x10 /* Update-Ended Interrupt Flag */ + + +/* RTC Status D Register Bit Definitions */ + +#define RTC_VRT 0x80 /* Valid Ram and Time */ + +/* General-Purpose CMOS RAM Mask */ + +#define RTC_CMOS_REG_X 0xFF /* CMOS RAM Location */ + + + + + + + + + + + + + + + + + + + + + + + +#endif /* _ASM_IC_SC520_DEFS_H_ */ diff --git a/include/configs/eNET.h b/include/configs/eNET.h new file mode 100644 index 0000000..4f206df --- /dev/null +++ b/include/configs/eNET.h @@ -0,0 +1,215 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * board/config.h - configuration options, board specific + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + * (easy to change) + */ +#define DEBUG_PARSER + +#define CONFIG_X86 1 /* This is a X86 CPU */ +#define CONFIG_SC520 1 /* Include support for AMD SC520 */ +#define CONFIG_SC520_SSI + +/* + * No video hardware on the eNET + */ +#undef CONFIG_VIDEO /* No Video Hardware */ +#undef CONFIG_CFB_CONSOLE + +#define CFG_SDRAM_DRCTMCTL 0x18 + +#undef CFG_SDRAM_PRECHARGE_DELAY /* CFG_SDRAM_DRCTMCTL Overrides */ +#undef CFG_SDRAM_REFRESH_RATE /* CFG_SDRAM_DRCTMCTL Overrides */ +#undef CFG_SDRAM_RAS_CAS_DELAY /* CFG_SDRAM_DRCTMCTL Overrides */ +#undef CFG_SDRAM_CAS_LATENCY_2T /* CFG_SDRAM_DRCTMCTL Overrides */ +#undef CFG_SDRAM_CAS_LATENCY_3T /* CFG_SDRAM_DRCTMCTL Overrides */ + +#define CFG_SC520_HIGH_SPEED 0 /* 100 or 133MHz */ +#define CFG_RESET_GENERIC /* use tripple-fault to reset cpu */ +#undef CFG_RESET_SC520 /* use SC520 MMCR's to reset cpu */ +#define CFG_TIMER_SC520 /* use SC520 swtimers */ +#undef CFG_TIMER_GENERIC /* use the i8254 PIT timers */ +#undef CFG_TIMER_TSC /* use the Pentium TSC timers */ +#define CFG_USE_SIO_UART 0 /* prefer the uarts on the SIO to those + * in the SC520 on the CDP */ + +#define CFG_STACK_SIZE 0x8000 /* Size of bootloader stack */ +#define CFG_RELOC_ADDR 0x03fd0000 /* Address of relocated code */ + +#define CONFIG_SHOW_BOOT_PROGRESS 1 +#define CONFIG_LAST_STAGE_INIT 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_MALLOC_SIZE (CFG_ENV_SIZE + 128*1024) + +#define CONFIG_BAUDRATE 9600 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + + +#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_ENV /* saveenv */ +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_IMI /* iminfo */ +#define CONFIG_CMD_IMLS /* List all found images */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MISC /* Misc functions like sleep etc*/ +#undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#undef CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */ + + + + + +#define CONFIG_BOOTDELAY 15 +#define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyS0,9600" +/* #define CONFIG_BOOTCOMMAND "bootm 38000000" */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_PROMPT "boot > " /* Monitor Command Prompt */ +#define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ + +#define CFG_MEMTEST_START 0x00100000 /* memtest works on */ +#define CFG_MEMTEST_END 0x01000000 /* 1 ... 16 MB in DRAM */ + +#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CFG_LOAD_ADDR 0x100000 /* default load address */ + +#define CFG_HZ 1024 /* incrementer freq: 1kHz */ + + /* valid baudrates */ +#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 4 /* we have 4 banks of DRAM */ + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CFG_MAX_FLASH_BANKS 3 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 64 /* max number of sectors on one chip */ + +/* timeout values are in ticks */ +#define CFG_FLASH_ERASE_TOUT (2*CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (2*CFG_HZ) /* Timeout for Flash Write */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Environment in NVRAM */ +#define CONFIG_ENV_IS_IN_NVRAM +#define CONFIG_ENV_ADDR 0x19000000 +#define CONFIG_ENV_SIZE 0x1000 +/************************************************************ + * RTC + ***********************************************************/ +#define CONFIG_RTC_MC146818 + +/* + * Enable hardware watchdog. + * + * WARNING: If CONFIG_HW_WATCHDOG is not defined, the watchdog jumper on the + * bottom (processor) board MUST be removed! + */ +#undef CONFIG_WATCHDOG +#define CONFIG_HW_WATCHDOG + +/* + * PCI stuff + */ +#undef CONFIG_PCI /* include pci support */ +#undef CONFIG_PCI_PNP /* pci plug-and-play */ +#undef CONFIG_PCI_SCAN_SHOW + +#undef CFG_FIRST_PCI_IRQ +#undef CFG_SECOND_PCI_IRQ +#undef CFG_THIRD_PCI_IRQ +#undef CFG_FORTH_PCI_IRQ +/* + * #undef CFG_FIRST_PCI_IRQ 10 + * #undef CFG_SECOND_PCI_IRQ 9 + * #undef CFG_THIRD_PCI_IRQ 11 + * #undef CFG_FORTH_PCI_IRQ 15 + */ +/* + * Hardware watchdog stuff + */ +#define CFG_WATCHDOG_PIO_BIT 0x8000 +#define CFG_WATCHDIG_PIO_DATA SC520_PIODATA15_0 +#define CFG_WATCHDIG_PIO_CLR SC520_PIOCLR15_0 +#define CFG_WATCHDIG_PIO_SET SC520_PIOSET15_0 + +/* + * FPGA stuff + */ +#define CFG_FPGA_PROGRAM_PIO_BIT 0x2000 +#define CFG_FPGA_INIT_PIO_BIT 0x4000 +#define CFG_FPGA_DONE_PIO_BIT 0x8000 +#define CFG_FPGA_PIO_DATA SC520_PIODATA31_16 +#define CFG_FPGA_PIO_DIRECTION SC520_PIODIR31_16 +#define CFG_FPGA_PIO_CLR SC520_PIOCLR31_16 +#define CFG_FPGA_PIO_SET SC520_PIOSET31_16 +#define CFG_FPGA_PROGRAM_BIT_DROP_TIME 1 /* milliseconds */ +#define CFG_FPGA_MAX_INIT_TIME 10 /* milliseconds */ +#define CFG_FPGA_MAX_FINALISE_TIME 10 /* milliseconds */ +#define CFG_FPGA_SSI_DATA_RATE 8333 /* kHz (33.3333MHz xtal) */ + +#endif /* __CONFIG_H */
Dear Graeme Russ,
Note: all comments made to part 'a' of this patch apply here, too.
In message 48E0D7CB.6040706@gmail.com you wrote:
Split to meet mailing list size limit
This should not be part of the git commit message, so please move below the '---' line.
Initial addition of eNET files - builds clean but will not run until additional i386 code changes are made
Signed-off-by: Graeme Russ graeme.russ@gmail.com
These should be 3 (three) dashes:
And any comments that are not intended for the commit message must go *below* that line..
diff --git a/board/eNET/fpga.c b/board/eNET/fpga.c new file mode 100644 index 0000000..a3e4677 --- /dev/null +++ b/board/eNET/fpga.c @@ -0,0 +1,149 @@ +/*
- (C) Copyright 2002
- Wolfgang Grandegger, DENX Software Engineering, wg@denx.de.
Is this correct and complete?
+#include "fpga.h"
+static u8 fpga_init(void); +static u8 fpga_write(void *buf, size_t bsize); +static u8 fpga_finalise(void); +static void fpga_close(void);
+int fpga_load(int devnum, void *buf, size_t bsize ) +{
- u8 ret = FPGA_SUCCESS;
Do you really have to copy that code?
diff --git a/board/eNET/hardware.h b/board/eNET/hardware.h new file mode 100644 index 0000000..eab612c --- /dev/null +++ b/board/eNET/hardware.h @@ -0,0 +1,13 @@ +/*
- hardware.h
- Created on: 17/09/2008
Author: graeme
+#ifndef HARDWARE_H_ +#define HARDWARE_H_
+#include "hardware_defs.h"
+#endif /* HARDWARE_H_ */
Um... A header file that just includes a single othe rheader file does not make sense to me here.
diff --git a/include/asm-i386/ic/sc520_defs.h b/include/asm-i386/ic/sc520_defs.h new file mode 100644 index 0000000..c8f6311 --- /dev/null +++ b/include/asm-i386/ic/sc520_defs.h @@ -0,0 +1,1489 @@ +/*
- sc520_defs.h
Author: graeme
Do we really need all these 1500 lines of definitions?
Really?
Too many empty lines - max. 2 allowed. Here, not more tna 1 should be used.
This applies to some other files as well.
Please clean up, rebase against current code, and resubmit.
Graeme Russ
