Re: [U-Boot-Users] [PATCH] Altera Stratix II support
Adds Support for Altera's Stratix II.
Within your board specific init file you will have to call
1. fpga_init (/* relocated code offset. usually => */ gd->reloc_off); 2. fpga_add (fpga_altera, (Altera_desc*)&altera_desc);
Altera_desc* contines (for example): { Altera_StratixII, /* part type */ passive_serial, /* interface type */ 1, /* bytes of data part can accept */ (void *)(&funcs), /* interface function table */ 0L, /* base interface address */ 0 /* implementation specific cookie */ }
funcs is the interface. It is of type altera_board_specific_func. It looks like this: altera_board_specific_func func = { pre_fn, config_fn, status_fn, done_fn, clk_fn, data_fn, abort_fn, post_fn, };
you will have to implement these functions, which is usually bit banging some gpio.
Signed-off-by: Eran Liberty liberty@extricom.com
--- Posted on behalf of Eran Liberty -- wd
Index: include/stratixII.h =================================================================== --- include/stratixII.h (revision 0) +++ include/stratixII.h (revision 0) @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom, eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#ifndef _STRATIXII_H_ +#define _STRATIXII_H_ + +extern int StratixII_load (Altera_desc * desc, void *image, size_t size); +extern int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize); +extern int StratixII_info (Altera_desc * desc); +extern int StratixII_reloc (Altera_desc * desc, ulong reloc_off); + +#endif /* _STRATIXII_H_ */ Index: include/altera.h =================================================================== --- include/altera.h (revision 121) +++ include/altera.h (working copy) @@ -27,22 +27,21 @@ #ifndef _ALTERA_H_ #define _ALTERA_H_
-/* - * See include/xilinx.h for another working example. - */ - /* Altera Model definitions *********************************************************************/ #define CFG_ACEX1K CFG_FPGA_DEV( 0x1 ) #define CFG_CYCLON2 CFG_FPGA_DEV( 0x2 ) +#define CFG_STRATIX_II CFG_FPGA_DEV( 0x4 )
#define CFG_ALTERA_ACEX1K (CFG_FPGA_ALTERA | CFG_ACEX1K) #define CFG_ALTERA_CYCLON2 (CFG_FPGA_ALTERA | CFG_CYCLON2) +#define CFG_ALTERA_STRATIX_II (CFG_FPGA_ALTERA | CFG_STRATIX_II) /* Add new models here */
/* Altera Interface definitions *********************************************************************/ #define CFG_ALTERA_IF_PS CFG_FPGA_IF( 0x1 ) /* passive serial */ +#define CFG_ALTERA_IF_FPP CFG_FPGA_IF( 0x2 ) /* fast passive parallel */ /* Add new interfaces here */
typedef enum { /* typedef Altera_iface */ @@ -52,6 +51,8 @@ passive_parallel_asynchronous, /* parallel data */ passive_serial_asynchronous, /* serial data w/ internal clock (not used) */ altera_jtag_mode, /* jtag/tap serial (not used ) */ + fast_passive_parallel, /* fast passive parallel (FPP) */ + fast_passive_parallel_security, /* fast passive parallel with security (FPPS) */ max_altera_iface_type /* insert all new types before this */ } Altera_iface; /* end, typedef Altera_iface */
@@ -59,6 +60,7 @@ min_altera_type, /* insert all new types after this */ Altera_ACEX1K, /* ACEX1K Family */ Altera_CYC2, /* CYCLONII Family */ + Altera_StratixII, /* StratixII Familiy */ /* Add new models here */ max_altera_type /* insert all new types before this */ } Altera_Family; /* end, typedef Altera_Family */ @@ -91,4 +93,15 @@ typedef int (*Altera_abort_fn)( int cookie ); typedef int (*Altera_post_fn)( int cookie );
+typedef struct { + Altera_pre_fn pre; + Altera_config_fn config; + Altera_status_fn status; + Altera_done_fn done; + Altera_clk_fn clk; + Altera_data_fn data; + Altera_abort_fn abort; + Altera_post_fn post; +} altera_board_specific_func; + #endif /* _ALTERA_H_ */ Index: common/fpga.c =================================================================== --- common/fpga.c (revision 121) +++ common/fpga.c (working copy) @@ -199,10 +199,6 @@ memset( desc_table, 0, sizeof(desc_table));
PRINTF( "%s: CONFIG_FPGA = 0x%x\n", __FUNCTION__, CONFIG_FPGA ); -#if 0 - PRINTF( "%s: CFG_FPGA_XILINX = 0x%x\n", __FUNCTION__, CFG_FPGA_XILINX ); - PRINTF( "%s: CFG_FPGA_ALTERA = 0x%x\n", __FUNCTION__, CFG_FPGA_ALTERA ); -#endif }
/* fpga_count Index: common/Makefile =================================================================== --- common/Makefile (revision 121) +++ common/Makefile (working copy) @@ -95,6 +95,7 @@ COBJS-y += command.o COBJS-y += console.o COBJS-y += cyclon2.o +COBJS-y += stratixII.o COBJS-y += devices.o COBJS-y += dlmalloc.o COBJS-y += docecc.o Index: common/altera.c =================================================================== --- common/altera.c (revision 121) +++ common/altera.c (working copy) @@ -30,6 +30,7 @@ */ #include <common.h> #include <ACEX1K.h> +#include <stratixII.h>
/* Define FPGA_DEBUG to get debug printf's */ /* #define FPGA_DEBUG */ @@ -43,7 +44,7 @@ #if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA)
/* Local Static Functions */ -static int altera_validate (Altera_desc * desc, char *fn); +static int altera_validate (Altera_desc * desc, const char *fn);
/* ------------------------------------------------------------------------- */ int altera_load( Altera_desc *desc, void *buf, size_t bsize ) @@ -60,7 +61,7 @@ PRINTF ("%s: Launching the ACEX1K Loader...\n", __FUNCTION__); ret_val = ACEX1K_load (desc, buf, bsize); -#elif defined CONFIG_FPGA_CYCLON2 +#elif defined(CONFIG_FPGA_CYCLON2) PRINTF ("%s: Launching the CYCLON II Loader...\n", __FUNCTION__); ret_val = CYC2_load (desc, buf, bsize); @@ -70,6 +71,13 @@ #endif break;
+#if defined(CONFIG_FPGA_STRATIX_II) + case Altera_StratixII: + PRINTF ("%s: Launching the Stratix II Loader...\n", + __FUNCTION__); + ret_val = StratixII_load (desc, buf, bsize); + break; +#endif default: printf ("%s: Unsupported family type, %d\n", __FUNCTION__, desc->family); @@ -98,6 +106,13 @@ #endif break;
+#if defined(CONFIG_FPGA_STRATIX_II) + case Altera_StratixII: + PRINTF ("%s: Launching the Stratix II Reader...\n", + __FUNCTION__); + ret_val = StratixII_dump (desc, buf, bsize); + break; +#endif default: printf ("%s: Unsupported family type, %d\n", __FUNCTION__, desc->family); @@ -117,10 +132,13 @@ case Altera_ACEX1K: printf ("ACEX1K\n"); break; - /* Add new family types here */ case Altera_CYC2: printf ("CYCLON II\n"); break; + case Altera_StratixII: + printf ("Stratix II\n"); + break; + /* Add new family types here */ default: printf ("Unknown family type, %d\n", desc->family); } @@ -142,6 +160,13 @@ case altera_jtag_mode: /* Not used */ printf ("JTAG Mode\n"); break; + case fast_passive_parallel: + printf ("Fast Passive Parallel (FPP)\n"); + break; + case fast_passive_parallel_security: + printf + ("Fast Passive Parallel with Security (FPPS) \n"); + break; /* Add new interface types here */ default: printf ("Unsupported interface type, %d\n", desc->iface); @@ -166,6 +191,11 @@ __FUNCTION__); #endif break; +#if defined(CONFIG_FPGA_STRATIX_II) + case Altera_StratixII: + StratixII_info (desc); + break; +#endif /* Add new family types here */ default: /* we don't need a message here - we give one up above */ @@ -199,6 +229,11 @@ __FUNCTION__); #endif break; +#if defined(CONFIG_FPGA_STRATIX_II) + case Altera_StratixII: + ret_val = StratixII_reloc (desc, reloc_offset); + break; +#endif case Altera_CYC2: #if defined(CONFIG_FPGA_CYCLON2) ret_val = CYC2_reloc (desc, reloc_offset); @@ -219,7 +254,7 @@
-static int altera_validate (Altera_desc * desc, char *fn) +static int altera_validate (Altera_desc * desc, const char *fn) { int ret_val = FALSE;
Index: common/stratixII.c =================================================================== --- common/stratixII.c (revision 0) +++ common/stratixII.c (revision 0) @@ -0,0 +1,235 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom , eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> /* core U-Boot definitions */ +#include <altera.h> + +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA) && defined(CONFIG_FPGA_STRATIX_II) + +int StratixII_ps_fpp_load (Altera_desc * desc, void *buf, size_t bsize, + int isSerial, int isSecure); +int StratixII_ps_fpp_dump (Altera_desc * desc, void *buf, size_t bsize); + +/****************************************************************/ +/* Stratix II Generic Implementation */ +int StratixII_load (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case passive_serial: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 1, 0); + break; + case fast_passive_parallel: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 0, 0); + break; + case fast_passive_parallel_security: + ret_val = StratixII_ps_fpp_load (desc, buf, bsize, 0, 1); + break; + + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case passive_serial: + case fast_passive_parallel: + case fast_passive_parallel_security: + ret_val = StratixII_ps_fpp_dump (desc, buf, bsize); + break; + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_info (Altera_desc * desc) +{ + return FPGA_SUCCESS; +} + +int StratixII_reloc (Altera_desc * desc, ulong reloc_offset) +{ + int i; + uint32_t dest = (uint32_t) desc & 0xff000000; + + /* we assume a relocated code and non relocated code has different upper 8 bits */ + if (dest != ((uint32_t) desc->iface_fns & 0xff000000)) { + desc->iface_fns = + (void *)((uint32_t) (desc->iface_fns) + reloc_offset); + } + for (i = 0; i < sizeof (altera_board_specific_func) / sizeof (void *); + i++) { + if (dest != + ((uint32_t) (((void **)(desc->iface_fns))[i]) & 0xff000000)) + { + ((void **)(desc->iface_fns))[i] = + (void + *)(((uint32_t) (((void **)(desc->iface_fns))[i])) + + reloc_offset); + } + } + return FPGA_SUCCESS; +} + +int StratixII_ps_fpp_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + printf ("Stratix II Fast Passive Parallel dump is not implemented\n"); + return FPGA_FAIL; +} + +int StratixII_ps_fpp_load (Altera_desc * desc, void *buf, size_t bsize, + int isSerial, int isSecure) +{ + altera_board_specific_func *fns; + int cookie; + int ret_val = FPGA_FAIL; + int bytecount; + char *buff = buf; + int i; + + if (!desc) { + printf ("%s(%d) Altera_desc missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!buff) { + printf ("%s(%d) buffer is missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!bsize) { + printf ("%s(%d) size is zero\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!desc->iface_fns) { + printf + ("%s(%d) Altera_desc function interface table is missing\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + fns = (altera_board_specific_func *) (desc->iface_fns); + cookie = desc->cookie; + + if (! + (fns->config && fns->status && fns->done && fns->data + && fns->abort)) { + printf + ("%s(%d) Missing some function in the function interface table\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + + /* 1. give board specific a chance to do anything before we start */ + if (fns->pre) { + if ((ret_val = fns->pre (cookie)) < 0) { + return ret_val; + } + } + + /* from this point on we must fail gracfully by calling lower layer abort */ + + /* 2. Strat burn cycle by deasserting config for t_CFG and waiting t_CF2CK after reaserted */ + fns->config (0, 1, cookie); + udelay (5); /* nCONFIG low pulse width 2usec */ + fns->config (1, 1, cookie); + udelay (100); /* nCONFIG high to first rising edge on DCLK */ + + /* 3. Start the Data cycle with clk deasserted */ + bytecount = 0; + fns->clk (0, 1, cookie); + + printf ("loading to fpga "); + while (bytecount < bsize) { + /* 3.1 check stratix has not signaled us an error */ + if (fns->status (cookie) != 1) { + printf + ("\n%s(%d) Stratix failed (byte transfered till failure 0x%x)\n", + __FUNCTION__, __LINE__, bytecount); + fns->abort (cookie); + return FPGA_FAIL; + } + if (isSerial) { + int i; + uint8_t data = buff[bytecount++]; + for (i = 0; i < 8; i++) { + /* 3.2(ps) put data on the bus */ + fns->data ((data >> i) & 1, 1, cookie); + + /* 3.3(ps) clock once */ + fns->clk (1, 1, cookie); + fns->clk (0, 1, cookie); + } + } else { + /* 3.2(fpp) put data on the bus */ + fns->data (buff[bytecount++], 1, cookie); + + /* 3.3(fpp) clock once */ + fns->clk (1, 1, cookie); + fns->clk (0, 1, cookie); + + /* 3.4(fpp) for secure cycle push 3 more clocks */ + for (i = 0; isSecure && i < 3; i++) { + fns->clk (1, 1, cookie); + fns->clk (0, 1, cookie); + } + } + + /* 3.5 while clk is deasserted it is safe to print some progress indication */ + if ((bytecount % (bsize / 100)) == 0) { + printf ("\b\b\b%02d%", bytecount * 100 / bsize); + } + } + + /* 4. Set one last clock and check conf done signal */ + fns->clk (1, 1, cookie); + udelay (100); + if (!fns->done (cookie)) { + printf (" error!.\n"); + fns->abort (cookie); + return FPGA_FAIL; + } else { + printf ("\b\b\b done.\n"); + } + + /* 5. call lower layer post configuration */ + if (fns->post) { + if ((ret_val = fns->post (cookie)) < 0) { + fns->abort (cookie); + return ret_val; + } + } + + return FPGA_SUCCESS; +} + +#endif /* defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA) && defined(CONFIG_FPGA_STRATIX_II) */
- fpga_init (/* relocated code offset. usually => */ gd->reloc_off);
- fpga_add (fpga_altera, (Altera_desc*)&altera_desc);
Applied, thanks.
