[U-Boot] [PATCH V2] tegra: Compulab TrimSlice board support
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Fixed unused variable warnings --- MAINTAINERS | 1 + board/compulab/dts/tegra2-trimslice.dts | 57 ++++++++++++++++++++ board/compulab/trimslice/Makefile | 49 +++++++++++++++++ board/compulab/trimslice/trimslice.c | 73 +++++++++++++++++++++++++ boards.cfg | 1 + include/configs/trimslice.h | 89 +++++++++++++++++++++++++++++++ 6 files changed, 270 insertions(+), 0 deletions(-) create mode 100644 board/compulab/dts/tegra2-trimslice.dts create mode 100644 board/compulab/trimslice/Makefile create mode 100644 board/compulab/trimslice/trimslice.c create mode 100644 include/configs/trimslice.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7c161db..9d35c0e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -912,6 +912,7 @@ Stephen Warren swarren@nvidia.com
ventana Tegra2 (ARM7 & A9 Dual Core) paz00 Tegra2 (ARM7 & A9 Dual Core) + trimslice Tegra2 (ARM7 & A9 Dual Core) whistler Tegra2 (ARM7 & A9 Dual Core)
Thomas Weber weber@corscience.de diff --git a/board/compulab/dts/tegra2-trimslice.dts b/board/compulab/dts/tegra2-trimslice.dts new file mode 100644 index 0000000..c707eb8 --- /dev/null +++ b/board/compulab/dts/tegra2-trimslice.dts @@ -0,0 +1,57 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "Compulab TrimSlice board"; + compatible = "compulab,trimslice", "nvidia,tegra20"; + + aliases { + usb0 = "/usb@c5008000"; + }; + + memory { + reg = <0x00000000 0x40000000>; + }; + + clocks { + clk_32k: clk_32k { + clock-frequency = <32000>; + }; + osc { + clock-frequency = <12000000>; + }; + }; + + clock@60006000 { + clocks = <&clk_32k &osc>; + }; + + serial@70006000 { + clock-frequency = <216000000>; + }; + + i2c@7000c000 { + status = "disabled"; + }; + + i2c@7000c400 { + status = "disabled"; + }; + + i2c@7000c500 { + status = "disabled"; + }; + + i2c@7000d000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; +}; diff --git a/board/compulab/trimslice/Makefile b/board/compulab/trimslice/Makefile new file mode 100644 index 0000000..bf624f4 --- /dev/null +++ b/board/compulab/trimslice/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../../nvidia/common) +endif + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o +COBJS += ../../nvidia/common/board.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c new file mode 100644 index 0000000..7167c91 --- /dev/null +++ b/board/compulab/trimslice/trimslice.c @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2010-2012 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/tegra2.h> +#include <asm/arch/clock.h> +#include <asm/arch/funcmux.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/mmc.h> +#include <asm/gpio.h> +#ifdef CONFIG_TEGRA2_MMC +#include <mmc.h> +#endif + +/* + * Routine: gpio_config_uart + * Description: Does nothing on TrimSlice - no UART-related GPIOs. + */ +void gpio_config_uart(void) +{ +} + +/* + * Routine: pin_mux_mmc + * Description: setup the pin muxes/tristate values for the SDMMC(s) + */ +static void pin_mux_mmc(void) +{ + funcmux_select(PERIPH_ID_SDMMC1, FUNCMUX_SDMMC1_SDIO1_4BIT); + funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); + + /* For CD GPIO PP1 */ + pinmux_tristate_disable(PINGRP_DAP3); +} + +/* this is a weak define that we are overriding */ +int board_mmc_init(bd_t *bd) +{ + debug("board_mmc_init called\n"); + + /* Enable muxes, etc. for SDMMC controllers */ + pin_mux_mmc(); + + /* init dev 0 (SDMMC4), (micro-SD slot) with 4-bit bus */ + tegra2_mmc_init(0, 4, -1, GPIO_PP1); + + /* init dev 3 (SDMMC1), (SD slot) with 4-bit bus */ + tegra2_mmc_init(3, 4, -1, -1); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index a96b7d7..e983b05 100644 --- a/boards.cfg +++ b/boards.cfg @@ -260,6 +260,7 @@ jornada arm sa1100 plutux arm armv7 plutux avionic-design tegra2 medcom arm armv7 medcom avionic-design tegra2 paz00 arm armv7 paz00 compal tegra2 +trimslice arm armv7 trimslice compulab tegra2 atngw100 avr32 at32ap - atmel at32ap700x atstk1002 avr32 at32ap atstk1000 atmel at32ap700x atstk1003 avr32 at32ap atstk1000 atmel at32ap700x diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h new file mode 100644 index 0000000..dafca5e --- /dev/null +++ b/include/configs/trimslice.h @@ -0,0 +1,89 @@ +/* + * (C) Copyright 2010-2012 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> +#include "tegra2-common.h" + +/* Enable fdt support for TrimSlice. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-trimslice +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* High-level configuration options */ +#define V_PROMPT "Tegra2 (TrimSlice) # " +#define CONFIG_TEGRA2_BOARD_STRING "NVIDIA Trimslice" + +/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA2_ENABLE_UARTA +#define CONFIG_TEGRA2_UARTA_GPU +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#define CONFIG_MACH_TYPE MACH_TYPE_TRIMSLICE +#define CONFIG_SYS_BOARD_ODMDATA 0x300c0011 /* lp?, 1GB, UARTA */ + +#define CONFIG_BOARD_EARLY_INIT_F + +/* I2C */ +#define CONFIG_TEGRA_I2C +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 4 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_CMD_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA2_MMC +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + +/* Environment not stored */ +#define CONFIG_ENV_IS_NOWHERE + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_ASIX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + +#include "tegra2-common-post.h" + +#endif /* __CONFIG_H */
Hi Stephen,
Thanks for doing this! We highly appreciate your help. We (Igor and me) have several comments below...
On 05/17/2012 07:03 PM, Stephen Warren wrote:
Signed-off-by: Stephen Warrenswarren@nvidia.com
diff --git a/MAINTAINERS b/MAINTAINERS index 7c161db..9d35c0e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -912,6 +912,7 @@ Stephen Warrenswarren@nvidia.com
ventana Tegra2 (ARM7& A9 Dual Core) paz00 Tegra2 (ARM7& A9 Dual Core)
trimslice Tegra2 (ARM7& A9 Dual Core) whistler Tegra2 (ARM7& A9 Dual Core)
Thomas Weberweber@corscience.de
- model = "Compulab TrimSlice board";
- compatible = "compulab,trimslice", "nvidia,tegra20";
- aliases {
- memory {
reg =<0x00000000 0x40000000>;
- clocks {
clk_32k: clk_32k {
clock-frequency =<32000>;
osc {
clock-frequency =<12000000>;
- clock@60006000 {
clocks =<&clk_32k&osc>;
- serial@70006000 {
clock-frequency =<216000000>;
- i2c@7000c000 {
- i2c@7000c400 {
- i2c@7000c500 {
- i2c@7000d000 {
- usb@c5004000 {
- usb@c5004000 {
This looks like a typo?
+}; diff --git a/board/compulab/trimslice/Makefile b/board/compulab/trimslice/Makefile new file mode 100644 index 0000000..bf624f4 --- /dev/null +++ b/board/compulab/trimslice/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation<www.nvidia.com> +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA
Can we, please not have the postal address here and all other files?
I feel that the common board.c file should be in the common SoC location, like arch/arm/cpu/armv7/tegra2/ ? In fact there is already a board.c file there, so how about we move the common stuff there?
- $(call cmd_link_o_target, $(OBJS))
- (C) Copyright 2010-2012
- NVIDIA Corporation<www.nvidia.com>
- project.
- MA 02111-1307 USA
+#include<common.h> +#include<i2c.h> +#include<asm/io.h> +#include<asm/arch/tegra2.h> +#include<asm/arch/clock.h> +#include<asm/arch/funcmux.h> +#include<asm/arch/pinmux.h> +#include<asm/arch/mmc.h> +#include<asm/gpio.h> +#ifdef CONFIG_TEGRA2_MMC +#include<mmc.h> +#endif
- Routine: gpio_config_uart
- Description: Does nothing on TrimSlice - no UART-related GPIOs.
- Routine: pin_mux_mmc
- Description: setup the pin muxes/tristate values for the SDMMC(s)
- funcmux_select(PERIPH_ID_SDMMC1, FUNCMUX_SDMMC1_SDIO1_4BIT);
- funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT);
- /* For CD GPIO PP1 */
- pinmux_tristate_disable(PINGRP_DAP3);
- debug("board_mmc_init called\n");
- /* Enable muxes, etc. for SDMMC controllers */
- pin_mux_mmc();
- /* init dev 0 (SDMMC4), (micro-SD slot) with 4-bit bus */
- tegra2_mmc_init(0, 4, -1, GPIO_PP1);
- /* init dev 3 (SDMMC1), (SD slot) with 4-bit bus */
- tegra2_mmc_init(3, 4, -1, -1);
- project.
- MA 02111-1307 USA
+#include<asm/sizes.h> +#include "tegra2-common.h"
Can this, please be "TrimSlice #"
Can this, please be "CompuLab TrimSlice"
In our downstream U-Boot, ODMDATA is 0x300d8011 /* lp1, 1GB, UARTA*/ Are you certain that your value is the correct one?
TrimSlice does not have any on-board Ethernet over USB devices. Do you connect them through the USB port? Or is it just a copy/paste from another board?
Best Regards,
Konstantin
On 05/30/2012 09:35 AM, Konstantin Sinyuk wrote:
Hi Stephen,
- usb@c5004000 {
- usb@c5004000 {
Yes indeed. I'll send a patch to fix that up.
Hmm. Well, all the existing code I'm basing these patches on has that license header. I don't feel strongly enough to change it now this patch is checked in. Feel free to submit a patch to clean this up, but if you do, I'd prefer if you made everything Tegra-related consistent.
Yes, the Tegra board support is evolving and may not be optimally structured right now. The logic above is what's needed given the current state. Perhaps this will move to a better location in the future. I don't plan on making that change right now though; I don't want to conflict with other changes I know people are making such as moving a bunch of code around to support a separate SPL.
That wouldn't be consistent with any of the other Tegra boards though. Is there a specific need for the prompt to be different?
Sure, that's just something I forgot to update when copying from another board's config file.
Yes, 300d8011 is wrong, and you're just getting lucky that it's working for you since nothing actually uses the ODMDATA fields that are wrong.
The "d8" in the ODMDATA means to use UART D as the debug UART. However, TrimSlice uses UART A, and hence needs "c0" here.
Without this change, the mainline kernel config option CONFIG_TEGRA_DEBUG_UART_AUTO_ODMDATA (which affects where DEBUG_LL/earlyprintk output is routed) will not work correctly.
A later change has removed the SMSC95XX support since as you say, that chip is not present on the board. However, I actively use an ASIX USB Ethernet dongle with TrimSlice, so do need that config option enabled. Perhaps it can be removed if/when Tegra PCIe support is added to mainline U-Boot, so the built-in Ethernet adapter can be used instead.
Hi Stephen,
- usb@c5004000 {
- usb@c5004000 {
Ok, I see, the reason I don't like the postal addresses was explained by Russell King some time ago (I can't find it right now) and was about the postal address is subject to change without prior notice (and it did several times before) and that will leave majority of files with the wrong address... I consider it a bad practice. But I don't really insist on this.
Now you say, that the patch has already been checked in... Tom, can we have a short notice on this, may be an email (e.g. Applied, thanks!) to the list, so we know which patches went in and which are still pending? I know we can look at your repository, but still...
Ok.
I see and probably you are right... On the second thought, it will not be consistent with other CompuLab boards (which are not Tegra based), so this whole consistency thing... I don't know... Let it be... After all, you have volunteered to maintain it :-)
Thanks
Ok, I see, thanks for sharing this information.
Fare enough. Thanks for the patches, information and the work you've done!
Igor,
-----Original Message----- From: Igor Grinberg [mailto:grinberg@compulab.co.il] Sent: Thursday, May 31, 2012 1:45 AM To: Stephen Warren Cc: Konstantin Sinyuk; Tom Warren; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V2] tegra: Compulab TrimSlice board support
Hi Stephen,
- usb@c5004000 {
- usb@c5004000 {
+# You should have received a copy of the GNU General Public +License # along with this program; if not, write to the Free +Software # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # +MA 02111-1307 USA
You'll see a pull request to Albert Aribaud when I've collected enough patches to go into u-boot-tegra/master, and if your patch (or a patch you care about) has been checked in, you'll see it there. I can't keep track of every contributor nor every Tegra board and remember to email them individually when code that affects them has been checked in. I can try to remember to add you to the CC when I send the pull request, but no guarantees. ;)
Also, if you are monitoring the mailing list, you can search for TrimSlice commits/discussions, etc. in each digest, on PatchWork, or gmane/pipermail, etc.
Tom
+ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../../nvidia/common) endif
Ok.
Thanks
wrong.
-- Regards, Igor.
Hi Tom,
On 05/31/12 19:17, Tom Warren wrote:
Igor,
Hi Stephen,
- usb@c5004000 {
- usb@c5004000 {
Yes, but it will also be useful to know when you apply the patch to your tree, but please see below...
And that is not what I was asking for... I'm not asking if you can CC everybody you think is interested in the patch... No! I'm asking if you can do a "Reply to all" to the patch (or a patch set) saying that the patch has been applied? Many other maintainers do this (not only in U-Boot) and it is really convenient to have that short email.
Thanks.
Well, monitoring mailing list will not help, if you don't "reply to all" (or at least reply to the list). I you had replied to the list, I would have no questions... ;-)
Tom
Ok.
Thanks
wrong.
-- Regards, Igor.
Igor Grinberg
Konstantin Sinyuk
Stephen Warren
Tom Warren
