[PATCH] arm: mvebu: Use 4K sector for Thecus N2350 SPI flash
Since the SPI flash chip mx25l3205d on this board has 4K-sector capability, enable it for the envs.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
configs/n2350_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/n2350_defconfig b/configs/n2350_defconfig index dcb2c96791..b85ef0dfeb 100644 --- a/configs/n2350_defconfig +++ b/configs/n2350_defconfig @@ -14,7 +14,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xff0000 CONFIG_TARGET_N2350=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x100000 -CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="armada-385-thecus-n2350" CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SYS_PROMPT="N2350 > "
Thanks, Stefan
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Stefan Roese
Tony Dinh
