[U-Boot] [PATCH] armv8/ls104xa: remove the DDR interactive debugging info from SPL
Remove the DDR interactive debugging to reduce the size of spl image.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- include/configs/ls1043aqds.h | 2 ++ include/configs/ls1043ardb.h | 2 ++ include/configs/ls1046aqds.h | 2 ++ include/configs/ls1046ardb.h | 2 ++ 4 files changed, 8 insertions(+)
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 431c8f8..33439bd 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -38,7 +38,9 @@ unsigned long get_board_ddr_clk(void); #define SPD_EEPROM_ADDRESS 0x51 #define CONFIG_SYS_SPD_BUS_NUM 0
+#ifndef CONFIG_SPL #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif
#define CONFIG_DDR_ECC #ifdef CONFIG_DDR_ECC diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 0054d16..6a904c4 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -29,7 +29,9 @@ #define CONFIG_SYS_SPD_BUS_NUM 0
#define CONFIG_FSL_DDR_BIST +#ifndef CONFIG_SPL #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif #define CONFIG_SYS_DDR_RAW_TIMING #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xdeadbeef diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 3618a06..f3877a9 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -38,7 +38,9 @@ unsigned long get_board_ddr_clk(void); #define SPD_EEPROM_ADDRESS 0x51 #define CONFIG_SYS_SPD_BUS_NUM 0
#define CONFIG_DDR_ECC #ifdef CONFIG_DDR_ECC diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 24843dc..5845ead 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -34,7 +34,9 @@ #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #define CONFIG_FSL_DDR_BIST /* enable built-in memory test */ +#ifndef CONFIG_SPL #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif
#ifdef CONFIG_RAMBOOT_PBL #define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1046ardb/ls1046ardb_pbi.cfg
Applied to u-boot-fsl-qoriq master, awaiting upstream.
York
york sun
Zhiqiang Hou
