[U-Boot] [PATCH] Kconfig: Remove trailing whitespaces in prompt
Remove additional trailing whitespaces in prompt reported by kconfiglib:
warning: DM_PMIC_SANDBOX (defined at drivers/power/pmic/Kconfig:133) has leading or trailing whitespace in its prompt warning: <choice> (defined at dts/Kconfig:204) has leading or trailing whitespace in its prompt
drivers/power/pmic/Kconfig | 2 +- dts/Kconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index d504c28b77fc..cba48e12da46 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -131,7 +131,7 @@ config PMIC_S2MPS11 Binding info: doc/device-tree-bindings/pmic/s2mps11.txt
config DM_PMIC_SANDBOX - bool "Enable Driver Model for emulated Sandbox PMIC " + bool "Enable Driver Model for emulated Sandbox PMIC" depends on DM_PMIC ---help--- Enable the driver for Sandbox PMIC emulation. The emulated PMIC device diff --git a/dts/Kconfig b/dts/Kconfig index a1a92f2bbd41..43f85c2f6f44 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -202,7 +202,7 @@ config SPL_MULTI_DTB_FIT_NO_COMPRESSION endchoice
choice - prompt "Location of uncompressed DTBs " + prompt "Location of uncompressed DTBs" depends on (SPL_MULTI_DTB_FIT_GZIP || SPL_MULTI_DTB_FIT_LZO) default SPL_MULTI_DTB_FIT_DYN_ALLOC if SYS_MALLOC_F
- bool "Enable Driver Model for emulated Sandbox PMIC" depends on DM_PMIC ---help--- Enable the driver for Sandbox PMIC emulation. The emulated PMIC device
choice
- prompt "Location of uncompressed DTBs" depends on (SPL_MULTI_DTB_FIT_GZIP || SPL_MULTI_DTB_FIT_LZO) default SPL_MULTI_DTB_FIT_DYN_ALLOC if SYS_MALLOC_F
Reviewed-by: Felix Brack fb@ltec.ch
regards, Felix
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Felix Brack fb@ltec.ch
Felix Brack
Michal Simek
