[U-Boot] [PATCH v3 0/3] Remove unused _relocate arguments
EFI image handle and system table are not used in _relocate().
v3: Rebased on u-boot/master
v2: Separated the changes in efi_main() arguments and calling convention.
Ivan Gorinov (3): x86: Remove unused _relocate arguments arm: Remove unused _relocate arguments riscv: Remove unused _relocate arguments
arch/arm/lib/crt0_aarch64_efi.S | 2 -- arch/arm/lib/crt0_arm_efi.S | 2 -- arch/arm/lib/reloc_aarch64_efi.c | 3 +-- arch/arm/lib/reloc_arm_efi.c | 3 +-- arch/riscv/lib/reloc_riscv_efi.c | 3 +-- arch/x86/lib/crt0_x86_64_efi.S | 3 --- arch/x86/lib/reloc_ia32_efi.c | 3 +-- arch/x86/lib/reloc_x86_64_efi.c | 3 +-- 8 files changed, 5 insertions(+), 17 deletions(-)
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- arch/x86/lib/crt0_x86_64_efi.S | 3 --- arch/x86/lib/reloc_ia32_efi.c | 3 +-- arch/x86/lib/reloc_x86_64_efi.c | 3 +-- 3 files changed, 2 insertions(+), 7 deletions(-)
diff --git a/arch/x86/lib/crt0_x86_64_efi.S b/arch/x86/lib/crt0_x86_64_efi.S index bb8d3cf..47ed5af 100644 --- a/arch/x86/lib/crt0_x86_64_efi.S +++ b/arch/x86/lib/crt0_x86_64_efi.S @@ -18,9 +18,6 @@ _start: pushq %rcx pushq %rdx
- mov %rcx, %r8 - mov %rdx, %r9 - lea image_base(%rip), %rcx lea _DYNAMIC(%rip), %rdx
diff --git a/arch/x86/lib/reloc_ia32_efi.c b/arch/x86/lib/reloc_ia32_efi.c index e838af3..a262533 100644 --- a/arch/x86/lib/reloc_ia32_efi.c +++ b/arch/x86/lib/reloc_ia32_efi.c @@ -12,8 +12,7 @@ #include <elf.h> #include <asm/elf.h>
-efi_status_t _relocate(long ldbase, Elf32_Dyn *dyn, efi_handle_t image, - struct efi_system_table *systab) +efi_status_t EFIAPI _relocate(long ldbase, Elf32_Dyn *dyn) { long relsz = 0, relent = 0; Elf32_Rel *rel = 0; diff --git a/arch/x86/lib/reloc_x86_64_efi.c b/arch/x86/lib/reloc_x86_64_efi.c index 34c5b2e..59d6f8d 100644 --- a/arch/x86/lib/reloc_x86_64_efi.c +++ b/arch/x86/lib/reloc_x86_64_efi.c @@ -14,8 +14,7 @@ #include <elf.h> #include <asm/elf.h>
-efi_status_t _relocate(long ldbase, Elf64_Dyn *dyn, efi_handle_t image, - struct efi_system_table *systab) +efi_status_t EFIAPI _relocate(long ldbase, Elf64_Dyn *dyn) { long relsz = 0, relent = 0; Elf64_Rel *rel = 0;
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- arch/arm/lib/crt0_aarch64_efi.S | 2 -- arch/arm/lib/crt0_arm_efi.S | 2 -- arch/arm/lib/reloc_aarch64_efi.c | 3 +-- arch/arm/lib/reloc_arm_efi.c | 3 +-- 4 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/arch/arm/lib/crt0_aarch64_efi.S b/arch/arm/lib/crt0_aarch64_efi.S index 5b6c384..0db4360 100644 --- a/arch/arm/lib/crt0_aarch64_efi.S +++ b/arch/arm/lib/crt0_aarch64_efi.S @@ -122,8 +122,6 @@ _start: mov x29, sp
stp x0, x1, [sp, #16] - mov x2, x0 - mov x3, x1 adr x0, ImageBase adrp x1, _DYNAMIC add x1, x1, #:lo12:_DYNAMIC diff --git a/arch/arm/lib/crt0_arm_efi.S b/arch/arm/lib/crt0_arm_efi.S index 0f296f3..23db49f 100644 --- a/arch/arm/lib/crt0_arm_efi.S +++ b/arch/arm/lib/crt0_arm_efi.S @@ -119,8 +119,6 @@ section_table: _start: stmfd sp!, {r0-r2, lr}
- mov r2, r0 - mov r3, r1 adr r1, .L_DYNAMIC ldr r0, [r1] add r1, r0, r1 diff --git a/arch/arm/lib/reloc_aarch64_efi.c b/arch/arm/lib/reloc_aarch64_efi.c index 38c13d3..1cf5cdc 100644 --- a/arch/arm/lib/reloc_aarch64_efi.c +++ b/arch/arm/lib/reloc_aarch64_efi.c @@ -38,8 +38,7 @@
#include <elf.h>
-efi_status_t _relocate(long ldbase, Elf64_Dyn *dyn, efi_handle_t image, - struct efi_system_table *systab) +efi_status_t _relocate(long ldbase, Elf64_Dyn *dyn) { long relsz = 0, relent = 0; Elf64_Rela *rel = 0; diff --git a/arch/arm/lib/reloc_arm_efi.c b/arch/arm/lib/reloc_arm_efi.c index 6232e3f..336a98a 100644 --- a/arch/arm/lib/reloc_arm_efi.c +++ b/arch/arm/lib/reloc_arm_efi.c @@ -14,8 +14,7 @@ #include <efi.h> #include <elf.h>
-efi_status_t _relocate(long ldbase, Elf32_Dyn *dyn, efi_handle_t image, - struct efi_system_table *systab) +efi_status_t _relocate(long ldbase, Elf32_Dyn *dyn) { long relsz = 0, relent = 0; Elf32_Rel *rel = 0;
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- arch/riscv/lib/reloc_riscv_efi.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/riscv/lib/reloc_riscv_efi.c b/arch/riscv/lib/reloc_riscv_efi.c index 8b4b2b1..2fbbfcb 100644 --- a/arch/riscv/lib/reloc_riscv_efi.c +++ b/arch/riscv/lib/reloc_riscv_efi.c @@ -50,8 +50,7 @@ #define ELF_R_TYPE ELF32_R_TYPE #endif
-efi_status_t _relocate(long ldbase, Elf_Dyn *dyn, efi_handle_t image, - struct efi_system_table *systab) +efi_status_t _relocate(long ldbase, Elf_Dyn *dyn) { long relsz = 0, relent = 0; Elf_Rela *rel = 0;
Reviewed-by: Andy Shevchenko andriy.shevchenko@linux.intel.com
Hi Ivan,
I don't understand the v3 patch now.
In previous v1/v2 patch, you did not change x86's _relocate() to declare EFIAPI, but in v3, you suddenly added EFIAPI to the x86 version but without adding EFIAPI to arm and risv, why?
Regards, Bin
On Thu, Jun 28, 2018 at 03:57:24PM +0800, Bin Meng wrote:
Hi Ivan,
Keeping default calling convention in v2 was a mistake because the x86_64 startup code passes _relocate() arguments using EFI convention.
I will submit another version that consistently uses EFIAPI in _relocate().
Regards, Bin
Andy Shevchenko
Bin Meng
Ivan Gorinov
