[U-Boot-Users] U-boot not compiling--may be bug..
HI all
I have taken u-boot code from u-boot-1.1.6 ( http://www.denx.de/wiki/UBoot )
I tried to compile for omap1510inn(which is having arm926ejs core), I want to compile it for arm926ejs. I have done,
$make omap1510inn_config $make
It is throwing me errors,
board.c: In function `start_armboot': board.c:331: error: incompatible types in assignment board.c:373: warning: passing arg 1 of `smc_set_mac_addr' from incompatible pointer type make[1]: *** [board.o] Error 1 make[1]: Leaving directory `/home/bhagwat/u-boot/u-boot-1.1.6/lib_arm'
seems some bug..
please help me; I am not able to proceed.
Regards, __Bhagwat
In message 098f01c7eeff$8a2f5f20$9c02a8c0@socpassion you wrote:
I have taken u-boot code from u-boot-1.1.6 ( = http://www.denx.de/wiki/UBoot )
Why are you using such old code for any recent work?
Why don't you follow the recommendation to use current code, i. e. op of tree from the git repository?
seems some bug..
This is probably a toolchain issue on your side, then. Or you modified the code. For me, 1.1.6 is building fine:
with U-Boot 1.1.6 = commit c5920044:
-> ./MAKEALL omap1510inn Configuring for omap1510inn board... text data bss dec hex filename 93503 3340 19512 116355 1c683 ./u-boot
with current = commit ff13ac8c:
-> ./MAKEALL omap1510inn Configuring for omap1510inn board... text data bss dec hex filename 95223 3352 19536 118111 1cd5f ./u-boot
------=_NextPart_000_098C_01C7EF2D.A3CAEB60 Content-Type: text/html; charset="iso-8859-1" Content-Transfer-Encoding: quoted-printable
Please never post HTML on thi slist!
Bhagwat
