[PATCH v1] rockchip: rk3288: use includes from dts/upstream
The clock and power DT includes for rk3288 are now available in the dts/upstream directory, so remove the ones that are now redundant. Remove the use of non existent SCLK_MAC_PLL id in the clock driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com ---
Changed: This patch does not include the removal of a clock binding as was proposed in an earlier serie elsewhere. For better fit with my other patch serie for binding removal.
http://patchwork.ozlabs.org/project/uboot/patch/71b804a0-ae2a-472c-84c9-ad7c... https://patchwork.ozlabs.org/project/uboot/patch/20241109210427.884888-4-jon... --- drivers/clk/rockchip/clk_rk3288.c | 8 +- include/dt-bindings/clock/rk3288-cru.h | 381 ----------------------- include/dt-bindings/power/rk3288-power.h | 32 -- 3 files changed, 4 insertions(+), 417 deletions(-) delete mode 100644 include/dt-bindings/clock/rk3288-cru.h delete mode 100644 include/dt-bindings/power/rk3288-power.h
diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 43c44fadbe7a..a4ff1c41abb8 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -903,11 +903,11 @@ static int __maybe_unused rk3288_gmac_set_parent(struct clk *clk, struct clk *pa int ret;
/* - * If the requested parent is in the same clock-controller and - * the id is SCLK_MAC_PLL ("mac_pll_src"), switch to the internal - * clock. + * If the requested parent is in the same clock-controller the + * likely parent is the unexported SCLK_MAC_PLL ("mac_pll_src"), + * switch to the internal clock. */ - if ((parent->dev == clk->dev) && (parent->id == SCLK_MAC_PLL)) { + if (parent->dev == clk->dev) { debug("%s: switching GAMC to SCLK_MAC_PLL\n", __func__); rk_clrsetreg(&cru->cru_clksel_con[21], RMII_EXTCLK_MASK, 0); return 0; diff --git a/include/dt-bindings/clock/rk3288-cru.h b/include/dt-bindings/clock/rk3288-cru.h deleted file mode 100644 index 453f66718c6b..000000000000 --- a/include/dt-bindings/clock/rk3288-cru.h +++ /dev/null @@ -1,381 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2014 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3288_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_NPLL 5 -#define ARMCLK 6 - -/* sclk gates (special clocks) */ -#define SCLK_GPU 64 -#define SCLK_SPI0 65 -#define SCLK_SPI1 66 -#define SCLK_SPI2 67 -#define SCLK_SDMMC 68 -#define SCLK_SDIO0 69 -#define SCLK_SDIO1 70 -#define SCLK_EMMC 71 -#define SCLK_TSADC 72 -#define SCLK_SARADC 73 -#define SCLK_PS2C 74 -#define SCLK_NANDC0 75 -#define SCLK_NANDC1 76 -#define SCLK_UART0 77 -#define SCLK_UART1 78 -#define SCLK_UART2 79 -#define SCLK_UART3 80 -#define SCLK_UART4 81 -#define SCLK_I2S0 82 -#define SCLK_SPDIF 83 -#define SCLK_SPDIF8CH 84 -#define SCLK_TIMER0 85 -#define SCLK_TIMER1 86 -#define SCLK_TIMER2 87 -#define SCLK_TIMER3 88 -#define SCLK_TIMER4 89 -#define SCLK_TIMER5 90 -#define SCLK_TIMER6 91 -#define SCLK_HSADC 92 -#define SCLK_OTGPHY0 93 -#define SCLK_OTGPHY1 94 -#define SCLK_OTGPHY2 95 -#define SCLK_OTG_ADP 96 -#define SCLK_HSICPHY480M 97 -#define SCLK_HSICPHY12M 98 -#define SCLK_MACREF 99 -#define SCLK_LCDC_PWM0 100 -#define SCLK_LCDC_PWM1 101 -#define SCLK_MAC_RX 102 -#define SCLK_MAC_TX 103 -#define SCLK_EDP_24M 104 -#define SCLK_EDP 105 -#define SCLK_RGA 106 -#define SCLK_ISP 107 -#define SCLK_ISP_JPE 108 -#define SCLK_HDMI_HDCP 109 -#define SCLK_HDMI_CEC 110 -#define SCLK_HEVC_CABAC 111 -#define SCLK_HEVC_CORE 112 -#define SCLK_I2S0_OUT 113 -#define SCLK_SDMMC_DRV 114 -#define SCLK_SDIO0_DRV 115 -#define SCLK_SDIO1_DRV 116 -#define SCLK_EMMC_DRV 117 -#define SCLK_SDMMC_SAMPLE 118 -#define SCLK_SDIO0_SAMPLE 119 -#define SCLK_SDIO1_SAMPLE 120 -#define SCLK_EMMC_SAMPLE 121 -#define SCLK_USBPHY480M_SRC 122 -#define SCLK_PVTM_CORE 123 -#define SCLK_PVTM_GPU 124 -#define SCLK_CRYPTO 125 -#define SCLK_MIPIDSI_24M 126 -#define SCLK_VIP_OUT 127 - -#define SCLK_MAC_PLL 150 -#define SCLK_MAC 151 -#define SCLK_MACREF_OUT 152 - -#define DCLK_VOP0 190 -#define DCLK_VOP1 191 - -/* aclk gates */ -#define ACLK_GPU 192 -#define ACLK_DMAC1 193 -#define ACLK_DMAC2 194 -#define ACLK_MMU 195 -#define ACLK_GMAC 196 -#define ACLK_VOP0 197 -#define ACLK_VOP1 198 -#define ACLK_CRYPTO 199 -#define ACLK_RGA 200 -#define ACLK_RGA_NIU 201 -#define ACLK_IEP 202 -#define ACLK_VIO0_NIU 203 -#define ACLK_VIP 204 -#define ACLK_ISP 205 -#define ACLK_VIO1_NIU 206 -#define ACLK_HEVC 207 -#define ACLK_VCODEC 208 -#define ACLK_CPU 209 -#define ACLK_PERI 210 - -/* pclk gates */ -#define PCLK_GPIO0 320 -#define PCLK_GPIO1 321 -#define PCLK_GPIO2 322 -#define PCLK_GPIO3 323 -#define PCLK_GPIO4 324 -#define PCLK_GPIO5 325 -#define PCLK_GPIO6 326 -#define PCLK_GPIO7 327 -#define PCLK_GPIO8 328 -#define PCLK_GRF 329 -#define PCLK_SGRF 330 -#define PCLK_PMU 331 -#define PCLK_I2C0 332 -#define PCLK_I2C1 333 -#define PCLK_I2C2 334 -#define PCLK_I2C3 335 -#define PCLK_I2C4 336 -#define PCLK_I2C5 337 -#define PCLK_SPI0 338 -#define PCLK_SPI1 339 -#define PCLK_SPI2 340 -#define PCLK_UART0 341 -#define PCLK_UART1 342 -#define PCLK_UART2 343 -#define PCLK_UART3 344 -#define PCLK_UART4 345 -#define PCLK_TSADC 346 -#define PCLK_SARADC 347 -#define PCLK_SIM 348 -#define PCLK_GMAC 349 -#define PCLK_PWM 350 -#define PCLK_RKPWM 351 -#define PCLK_PS2C 352 -#define PCLK_TIMER 353 -#define PCLK_TZPC 354 -#define PCLK_EDP_CTRL 355 -#define PCLK_MIPI_DSI0 356 -#define PCLK_MIPI_DSI1 357 -#define PCLK_MIPI_CSI 358 -#define PCLK_LVDS_PHY 359 -#define PCLK_HDMI_CTRL 360 -#define PCLK_VIO2_H2P 361 -#define PCLK_CPU 362 -#define PCLK_PERI 363 -#define PCLK_DDRUPCTL0 364 -#define PCLK_PUBL0 365 -#define PCLK_DDRUPCTL1 366 -#define PCLK_PUBL1 367 -#define PCLK_WDT 368 -#define PCLK_EFUSE256 369 -#define PCLK_EFUSE1024 370 -#define PCLK_ISP_IN 371 - -/* hclk gates */ -#define HCLK_GPS 448 -#define HCLK_OTG0 449 -#define HCLK_USBHOST0 450 -#define HCLK_USBHOST1 451 -#define HCLK_HSIC 452 -#define HCLK_NANDC0 453 -#define HCLK_NANDC1 454 -#define HCLK_TSP 455 -#define HCLK_SDMMC 456 -#define HCLK_SDIO0 457 -#define HCLK_SDIO1 458 -#define HCLK_EMMC 459 -#define HCLK_HSADC 460 -#define HCLK_CRYPTO 461 -#define HCLK_I2S0 462 -#define HCLK_SPDIF 463 -#define HCLK_SPDIF8CH 464 -#define HCLK_VOP0 465 -#define HCLK_VOP1 466 -#define HCLK_ROM 467 -#define HCLK_IEP 468 -#define HCLK_ISP 469 -#define HCLK_RGA 470 -#define HCLK_VIO_AHB_ARBI 471 -#define HCLK_VIO_NIU 472 -#define HCLK_VIP 473 -#define HCLK_VIO2_H2P 474 -#define HCLK_HEVC 475 -#define HCLK_VCODEC 476 -#define HCLK_CPU 477 -#define HCLK_PERI 478 - -#define CLK_NR_CLKS (HCLK_PERI + 1) - -/* soft-reset indices */ -#define SRST_CORE0 0 -#define SRST_CORE1 1 -#define SRST_CORE2 2 -#define SRST_CORE3 3 -#define SRST_CORE0_PO 4 -#define SRST_CORE1_PO 5 -#define SRST_CORE2_PO 6 -#define SRST_CORE3_PO 7 -#define SRST_PDCORE_STRSYS 8 -#define SRST_PDBUS_STRSYS 9 -#define SRST_L2C 10 -#define SRST_TOPDBG 11 -#define SRST_CORE0_DBG 12 -#define SRST_CORE1_DBG 13 -#define SRST_CORE2_DBG 14 -#define SRST_CORE3_DBG 15 - -#define SRST_PDBUG_AHB_ARBITOR 16 -#define SRST_EFUSE256 17 -#define SRST_DMAC1 18 -#define SRST_INTMEM 19 -#define SRST_ROM 20 -#define SRST_SPDIF8CH 21 -#define SRST_TIMER 22 -#define SRST_I2S0 23 -#define SRST_SPDIF 24 -#define SRST_TIMER0 25 -#define SRST_TIMER1 26 -#define SRST_TIMER2 27 -#define SRST_TIMER3 28 -#define SRST_TIMER4 29 -#define SRST_TIMER5 30 -#define SRST_EFUSE 31 - -#define SRST_GPIO0 32 -#define SRST_GPIO1 33 -#define SRST_GPIO2 34 -#define SRST_GPIO3 35 -#define SRST_GPIO4 36 -#define SRST_GPIO5 37 -#define SRST_GPIO6 38 -#define SRST_GPIO7 39 -#define SRST_GPIO8 40 -#define SRST_I2C0 42 -#define SRST_I2C1 43 -#define SRST_I2C2 44 -#define SRST_I2C3 45 -#define SRST_I2C4 46 -#define SRST_I2C5 47 - -#define SRST_DWPWM 48 -#define SRST_MMC_PERI 49 -#define SRST_PERIPH_MMU 50 -#define SRST_DAP 51 -#define SRST_DAP_SYS 52 -#define SRST_TPIU 53 -#define SRST_PMU_APB 54 -#define SRST_GRF 55 -#define SRST_PMU 56 -#define SRST_PERIPH_AXI 57 -#define SRST_PERIPH_AHB 58 -#define SRST_PERIPH_APB 59 -#define SRST_PERIPH_NIU 60 -#define SRST_PDPERI_AHB_ARBI 61 -#define SRST_EMEM 62 -#define SRST_USB_PERI 63 - -#define SRST_DMAC2 64 -#define SRST_MAC 66 -#define SRST_GPS 67 -#define SRST_RKPWM 69 -#define SRST_CCP 71 -#define SRST_USBHOST0 72 -#define SRST_HSIC 73 -#define SRST_HSIC_AUX 74 -#define SRST_HSIC_PHY 75 -#define SRST_HSADC 76 -#define SRST_NANDC0 77 -#define SRST_NANDC1 78 - -#define SRST_TZPC 80 -#define SRST_SPI0 83 -#define SRST_SPI1 84 -#define SRST_SPI2 85 -#define SRST_SARADC 87 -#define SRST_PDALIVE_NIU 88 -#define SRST_PDPMU_INTMEM 89 -#define SRST_PDPMU_NIU 90 -#define SRST_SGRF 91 - -#define SRST_VIO_ARBI 96 -#define SRST_RGA_NIU 97 -#define SRST_VIO0_NIU_AXI 98 -#define SRST_VIO_NIU_AHB 99 -#define SRST_LCDC0_AXI 100 -#define SRST_LCDC0_AHB 101 -#define SRST_LCDC0_DCLK 102 -#define SRST_VIO1_NIU_AXI 103 -#define SRST_VIP 104 -#define SRST_RGA_CORE 105 -#define SRST_IEP_AXI 106 -#define SRST_IEP_AHB 107 -#define SRST_RGA_AXI 108 -#define SRST_RGA_AHB 109 -#define SRST_ISP 110 -#define SRST_EDP 111 - -#define SRST_VCODEC_AXI 112 -#define SRST_VCODEC_AHB 113 -#define SRST_VIO_H2P 114 -#define SRST_MIPIDSI0 115 -#define SRST_MIPIDSI1 116 -#define SRST_MIPICSI 117 -#define SRST_LVDS_PHY 118 -#define SRST_LVDS_CON 119 -#define SRST_GPU 120 -#define SRST_HDMI 121 -#define SRST_CORE_PVTM 124 -#define SRST_GPU_PVTM 125 - -#define SRST_MMC0 128 -#define SRST_SDIO0 129 -#define SRST_SDIO1 130 -#define SRST_EMMC 131 -#define SRST_USBOTG_AHB 132 -#define SRST_USBOTG_PHY 133 -#define SRST_USBOTG_CON 134 -#define SRST_USBHOST0_AHB 135 -#define SRST_USBHOST0_PHY 136 -#define SRST_USBHOST0_CON 137 -#define SRST_USBHOST1_AHB 138 -#define SRST_USBHOST1_PHY 139 -#define SRST_USBHOST1_CON 140 -#define SRST_USB_ADP 141 -#define SRST_ACC_EFUSE 142 - -#define SRST_CORESIGHT 144 -#define SRST_PD_CORE_AHB_NOC 145 -#define SRST_PD_CORE_APB_NOC 146 -#define SRST_PD_CORE_MP_AXI 147 -#define SRST_GIC 148 -#define SRST_LCDC_PWM0 149 -#define SRST_LCDC_PWM1 150 -#define SRST_VIO0_H2P_BRG 151 -#define SRST_VIO1_H2P_BRG 152 -#define SRST_RGA_H2P_BRG 153 -#define SRST_HEVC 154 -#define SRST_TSADC 159 - -#define SRST_DDRPHY0 160 -#define SRST_DDRPHY0_APB 161 -#define SRST_DDRCTRL0 162 -#define SRST_DDRCTRL0_APB 163 -#define SRST_DDRPHY0_CTRL 164 -#define SRST_DDRPHY1 165 -#define SRST_DDRPHY1_APB 166 -#define SRST_DDRCTRL1 167 -#define SRST_DDRCTRL1_APB 168 -#define SRST_DDRPHY1_CTRL 169 -#define SRST_DDRMSCH0 170 -#define SRST_DDRMSCH1 171 -#define SRST_CRYPTO 174 -#define SRST_C2C_HOST 175 - -#define SRST_LCDC1_AXI 176 -#define SRST_LCDC1_AHB 177 -#define SRST_LCDC1_DCLK 178 -#define SRST_UART0 179 -#define SRST_UART1 180 -#define SRST_UART2 181 -#define SRST_UART3 182 -#define SRST_UART4 183 -#define SRST_SIMC 186 -#define SRST_PS2C 187 -#define SRST_TSP 188 -#define SRST_TSP_CLKIN0 189 -#define SRST_TSP_CLKIN1 190 -#define SRST_TSP_27M 191 - -#endif diff --git a/include/dt-bindings/power/rk3288-power.h b/include/dt-bindings/power/rk3288-power.h deleted file mode 100644 index f710b56ccd81..000000000000 --- a/include/dt-bindings/power/rk3288-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3288_POWER_H__ -#define __DT_BINDINGS_POWER_RK3288_POWER_H__ - -/** - * RK3288 Power Domain and Voltage Domain Summary. - */ - -/* VD_CORE */ -#define RK3288_PD_A17_0 0 -#define RK3288_PD_A17_1 1 -#define RK3288_PD_A17_2 2 -#define RK3288_PD_A17_3 3 -#define RK3288_PD_SCU 4 -#define RK3288_PD_DEBUG 5 -#define RK3288_PD_MEM 6 - -/* VD_LOGIC */ -#define RK3288_PD_BUS 7 -#define RK3288_PD_PERI 8 -#define RK3288_PD_VIO 9 -#define RK3288_PD_ALIVE 10 -#define RK3288_PD_HEVC 11 -#define RK3288_PD_VIDEO 12 - -/* VD_GPU */ -#define RK3288_PD_GPU 13 - -/* VD_PMU */ -#define RK3288_PD_PMU 14 - -#endif -- 2.39.5
Hi Johan,
[snip]
This cleanup is already handled in the following series:
rockchip: rk3288: Include files from dts/upstream https://patchwork.ozlabs.org/project/uboot/cover/20241109210427.884888-1-jon...
Regards, Jonas
Johan Jonker
Jonas Karlman
