[PATCH] soc: zynqmp: Add the IDcode for dr_SE and eg_SE variants
ID code is added for zu67dr_SE, zu11eg_SE, zu19eg_SE and zu47dr_SE variants. SE is the select edition of restricted devices with the capabilities.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- drivers/soc/soc_xilinx_zynqmp.c | 28 +++++++++++++++++++++++++++- 1 file changed, 27 insertions(+), 1 deletion(-)
diff --git a/drivers/soc/soc_xilinx_zynqmp.c b/drivers/soc/soc_xilinx_zynqmp.c index d9a5944965..786825d920 100644 --- a/drivers/soc/soc_xilinx_zynqmp.c +++ b/drivers/soc/soc_xilinx_zynqmp.c @@ -35,13 +35,15 @@ static const char zynqmp_family[] = "ZynqMP"; #define IDCODE2_PL_INIT_SHIFT 9 #define IDCODE2_PL_INIT_MASK BIT(IDCODE2_PL_INIT_SHIFT)
-#define ZYNQMP_VERSION_SIZE 7 +#define ZYNQMP_VERSION_SIZE 10
enum { ZYNQMP_VARIANT_EG = BIT(0), ZYNQMP_VARIANT_EV = BIT(1), ZYNQMP_VARIANT_CG = BIT(2), ZYNQMP_VARIANT_DR = BIT(3), + ZYNQMP_VARIANT_DR_SE = BIT(4), + ZYNQMP_VARIANT_EG_SE = BIT(5), };
struct zynqmp_device { @@ -105,6 +107,11 @@ static const struct zynqmp_device zynqmp_devices[] = { .device = 11, .variants = ZYNQMP_VARIANT_EG, }, + { + .id = 0x04741093, + .device = 11, + .variants = ZYNQMP_VARIANT_EG_SE, + }, { .id = 0x04750093, .device = 15, @@ -120,6 +127,11 @@ static const struct zynqmp_device zynqmp_devices[] = { .device = 19, .variants = ZYNQMP_VARIANT_EG, }, + { + .id = 0x0475C093, + .device = 19, + .variants = ZYNQMP_VARIANT_EG_SE, + }, { .id = 0x047E1093, .device = 21, @@ -170,6 +182,11 @@ static const struct zynqmp_device zynqmp_devices[] = { .device = 47, .variants = ZYNQMP_VARIANT_DR, }, + { + .id = 0x047FA093, + .device = 47, + .variants = ZYNQMP_VARIANT_DR_SE, + }, { .id = 0x047FB093, .device = 48, @@ -185,6 +202,11 @@ static const struct zynqmp_device zynqmp_devices[] = { .device = 67, .variants = ZYNQMP_VARIANT_DR, }, + { + .id = 0x046d7093, + .device = 67, + .variants = ZYNQMP_VARIANT_DR_SE, + }, { .id = 0x04712093, .device = 24, @@ -271,8 +293,12 @@ static int soc_xilinx_zynqmp_detect_machine(struct udevice *dev, u32 idcode, "cg" : "eg", sizeof(priv->machine)); } else if (device->variants & ZYNQMP_VARIANT_EG) { strlcat(priv->machine, "eg", sizeof(priv->machine)); + } else if (device->variants & ZYNQMP_VARIANT_EG_SE) { + strlcat(priv->machine, "eg_SE", sizeof(priv->machine)); } else if (device->variants & ZYNQMP_VARIANT_DR) { strlcat(priv->machine, "dr", sizeof(priv->machine)); + } else if (device->variants & ZYNQMP_VARIANT_DR_SE) { + strlcat(priv->machine, "dr_SE", sizeof(priv->machine)); }
.id = 0x04741093,
.device = 11,
- }, { .id = 0x04750093, .device = 15,
.id = 0x0475C093,
.device = 19,
- }, { .id = 0x047E1093, .device = 21,
.id = 0x047FA093,
.device = 47,
- }, { .id = 0x047FB093, .device = 48,
.id = 0x046d7093,
.device = 67,
- }, { .id = 0x04712093, .device = 24,
Applied. M
Michal Simek
