[U-Boot] Pull request: u-boot-rockchip/tags/rockchip-for-v2019.07-rc5-3
Hi Tom,
Please pull the update: - fix rockchip ATF generator script for 'loadables' property
Travis: https://travis-ci.org/keveryang/u-boot/builds/554575031
Thanks, - Kever
The following changes since commit ca4491f2d2af93d8b77c48c5d272d88094fc06eb:
Merge tag 'rockchip-for-v2019.07-rc5-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip (2019-07-02 08:18:19 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip.git tags/rockchip-for-v2019.07-rc5-3
for you to fetch changes up to 619f002db864ef8caa30863bde62df5c651a7312:
rockchip: make_fit_atf.py: fix loadables property set error (2019-07-05 15:57:52 +0800)
---------------------------------------------------------------- Andy Yan (1): rockchip: make_fit_atf.py: fix loadables property set error
arch/arm/mach-rockchip/make_fit_atf.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
On Sat, Jul 06, 2019 at 11:59:20PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
