[PATCH] lib: rsa: Set conventional salt length RSA-PSS parameter
RFC 3447 says that Typical salt length are either 0 or the length of the output of the digest algorithm, RFC 4055 also recommends hash value length as the salt length. Moreover, By convention, most of the signing infrastructures/libraries use the length of the digest algorithm (such as google cloud kms: https://cloud.google.com/kms/docs/algorithms).
If the salt-length parameter is not set, openssl default to the maximum allowed value, which is a openssl 'specificity', so this works well for local signing, but restricts compatibility with other engines (e.g pkcs11/libkmsp11):
``` returning 0x71 from C_SignInit due to status INVALID_ARGUMENT: at rsassa_pss.cc:53: expected salt length for key XX is 32, but 478 was supplied in the parameters Could not obtain signature: error:41000070:PKCS#11 module::Mechanism invalid ```
To improve compatibility, we set the default RSA-PSS salt-length value to the conventional one. A further improvement could consist in making it configurable as signature FIT node attribute.
rfc3447: https://datatracker.ietf.org/doc/html/rfc3447 rfc4055: https://datatracker.ietf.org/doc/html/rfc4055
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- lib/rsa/rsa-sign.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 2304030e32..fa9e143b4c 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -428,6 +428,15 @@ static int rsa_sign_with_key(EVP_PKEY *pkey, struct padding_algo *padding_algo, ret = rsa_err("Signer padding setup failed"); goto err_sign; } + + /* Per RFC 3447 (and convention) the Typical salt length is the + * length of the output of the digest algorithm. + */ + if (EVP_PKEY_CTX_set_rsa_pss_saltlen(ckey, + checksum_algo->checksum_len) <= 0) { + ret = rsa_err("Signer salt length setup failed"); + goto err_sign; + } }
for (i = 0; i < region_count; i++) {
Loic Poulain
