[U-Boot-Users] [PATCH 0/4] PPC4xx: Use common code for PPC440EPx SDRAM support
board/amcc/sequoia/sdram.c | 344 +----------------------------- board/amcc/sequoia/sdram.h | 505 -------------------------------------------- board/lwmon5/sdram.c | 357 ++----------------------------- board/lwmon5/sdram.h | 505 -------------------------------------------- 4 files changed, 26 insertions(+), 1685 deletions(-)
These four patches replace board-specific code for Denali-core SDRAM support with common definitions and functions. Please note:
(1) The changes to "board/amcc/sequoia/sdram.c" break the build for "sequoia_nand".
(2) The changes to "board/lwmon5/sdram.c" seem reasonable, but I have no board on which to test them. If you decide to use them, please test them first. I have modified the functionality so that the data-eye search is now done with with the cache disabled, as in the Denali SPD code.
Best regards, Larry
Larry Johnson
