[U-Boot] [PATCH] mxs_gpio: fix the handling in gpio_direction_output()
Setting the direction and an output value should be done by 1) set the desired output value, 2) switch to output.
If this is done in the inverse order, there can be a glitch on the GPIO line.
This patch fixes this by using the order as described above.
Signed-off-by: Michael Heimpold mhei@heimpold.de --- drivers/gpio/mxs_gpio.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/mxs_gpio.c b/drivers/gpio/mxs_gpio.c index d9a7a3a..da0199b 100644 --- a/drivers/gpio/mxs_gpio.c +++ b/drivers/gpio/mxs_gpio.c @@ -95,10 +95,10 @@ int gpio_direction_output(unsigned gpio, int value) struct mxs_register_32 *reg = (struct mxs_register_32 *)(MXS_PINCTRL_BASE + offset);
- writel(1 << PAD_PIN(gpio), ®->reg_set); - gpio_set_value(gpio, value);
+ writel(1 << PAD_PIN(gpio), ®->reg_set); + return 0; }
Hi Michael,
- set the desired output value,
- switch to output.
Yes, we had the same fix for mxc (commit 04c79cbd5f8f773aa7823feec6e77862e7e6426f)
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
- switch to output.
Applied to u-boot-imx, thanks.
Michael Heimpold
Stefano Babic
