[PATCH] octeontx: do not require cavium BDK node to be present
The cavium,bdk node is a non-standard dt node used by the BDK and therefore it is removed from the dt before booting Linux. Do not require this node to exist as it won't for standard dt's.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/Marvell/octeontx/board-fdt.c | 20 ++++++++------------ 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/board/Marvell/octeontx/board-fdt.c b/board/Marvell/octeontx/board-fdt.c index 0b05ef11e9..1db2a4a267 100644 --- a/board/Marvell/octeontx/board-fdt.c +++ b/board/Marvell/octeontx/board-fdt.c @@ -281,20 +281,16 @@ int ft_board_setup(void *blob, struct bd_info *bd) }
if (blob) { + /* delete cavium,bdk node if it exists */ offset = fdt_path_offset(blob, "/cavium,bdk"); - if (offset < 0) { - printf("ERROR: FDT BDK node not found\n"); - return offset; - } - - /* delete node */ - ret = fdt_del_node(blob, offset); - if (ret < 0) { - printf("WARNING : could not remove bdk node\n"); - return ret; + if (offset >= 0) { + ret = fdt_del_node(blob, offset); + if (ret < 0) { + printf("WARNING : could not remove bdk node\n"); + return ret; + } + debug("%s deleted bdk node\n", __func__); } - - debug("%s deleted bdk node\n", __func__); }
Thanks, Stefan
if (blob) {
offset = fdt_path_offset(blob, "/cavium,bdk");/* delete cavium,bdk node if it exists */
if (offset < 0) {
return offset;
/* delete node */
if (ret < 0) {
return ret;
if (offset >= 0) {
if (ret < 0) {
return ret;
}debug("%s deleted bdk node\n", __func__);
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
if (blob) {
if (offset < 0) {
return offset;
/* delete node */
if (ret < 0) {
return ret;
if (offset >= 0) {
if (ret < 0) {
return ret;
Viele Grüße, Stefan
Stefan Roese
Tim Harvey
