[U-Boot] [PATCH v3 0/2] efi_loader: add GetNextVariableName
In this patch series GetNextVariableName runtime service is implemented.
v3 rebase on efi-next v2 update variable_name_size in GetNextVariableName add more comments change some internal variable names
AKASHI Takahiro (2): efi_loader: implement GetNextVariableName() efi_selftest: fix variables test for GetNextVariableName()
lib/efi_loader/efi_variable.c | 154 +++++++++++++++++++++- lib/efi_selftest/efi_selftest_variables.c | 13 +- 2 files changed, 160 insertions(+), 7 deletions(-)
The current GetNextVariableName() is a placeholder. With this patch, it works well as expected.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org rebased on efi-next Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3: rebase on efi-next v2: update variable_name_size in GetNextVariableName add more comments change some internal variable names --- lib/efi_loader/efi_variable.c | 154 +++++++++++++++++++++++++++++++++- 1 file changed, 152 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index eea7f68b85..993bf3ce90 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -9,6 +9,9 @@ #include <charset.h> #include <efi_loader.h> #include <hexdump.h> +#include <environment.h> +#include <search.h> +#include <uuid.h>
#define READ_ONLY BIT(31)
@@ -203,14 +206,161 @@ efi_status_t EFIAPI efi_get_variable(u16 *variable_name, return EFI_EXIT(EFI_SUCCESS); }
-/* http://wiki.phoenix.com/wiki/index.php/EFI_RUNTIME_SERVICES#GetNextVariableN... */ +static char *efi_variables_list; +static char *efi_cur_variable; + +/** + * parse_uboot_variable() - parse a u-boot variable and get uefi-related + * information + * @variable: whole data of u-boot variable (ie. name=value) + * @variable_name_size: size of variable_name buffer in byte + * @variable_name: name of uefi variable in u16, null-terminated + * @vendor: vendor's guid + * @attributes: attributes + * + * A uefi variable is encoded into a u-boot variable as described above. + * This function parses such a u-boot variable and retrieve uefi-related + * information into respective parameters. In return, variable_name_size + * is the size of variable name including NULL. + * + * Return: EFI_SUCCESS if parsing is OK, EFI_NOT_FOUND when + the entire variable list has been returned, + otherwise non-zero status code + */ +static efi_status_t parse_uboot_variable(char *variable, + efi_uintn_t *variable_name_size, + u16 *variable_name, + const efi_guid_t *vendor, + u32 *attributes) +{ + char *guid, *name, *end, c; + unsigned long name_len; + u16 *p; + + guid = strchr(variable, '_'); + if (!guid) + return EFI_INVALID_PARAMETER; + guid++; + name = strchr(guid, '_'); + if (!name) + return EFI_INVALID_PARAMETER; + name++; + end = strchr(name, '='); + if (!end) + return EFI_INVALID_PARAMETER; + + name_len = end - name; + if (*variable_name_size < (name_len + 1)) { + *variable_name_size = name_len + 1; + return EFI_BUFFER_TOO_SMALL; + } + end++; /* point to value */ + + /* variable name */ + p = variable_name; + utf8_utf16_strncpy(&p, name, name_len); + variable_name[name_len] = 0; + *variable_name_size = name_len + 1; + + /* guid */ + c = *(name - 1); + *(name - 1) = '\0'; /* guid need be null-terminated here */ + uuid_str_to_bin(guid, (unsigned char *)vendor, UUID_STR_FORMAT_GUID); + *(name - 1) = c; + + /* attributes */ + parse_attr(end, attributes); + + return EFI_SUCCESS; +} + +/** + * efi_get_next_variable_name() - enumerate the current variable names + * @variable_name_size: size of variable_name buffer in byte + * @variable_name: name of uefi variable's name in u16 + * @vendor: vendor's guid + * + * This function implements the GetNextVariableName service. + * + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details: http://wiki.phoenix.com/wiki/index.php/ + * EFI_RUNTIME_SERVICES#GetNextVariableName.28.29 + * + * Return: status code + */ efi_status_t EFIAPI efi_get_next_variable_name(efi_uintn_t *variable_name_size, u16 *variable_name, const efi_guid_t *vendor) { + char *native_name, *variable; + ssize_t name_len, list_len; + char regex[256]; + char * const regexlist[] = {regex}; + u32 attributes; + int i; + efi_status_t ret; + EFI_ENTRY("%p "%ls" %pUl", variable_name_size, variable_name, vendor);
- return EFI_EXIT(EFI_DEVICE_ERROR); + if (!variable_name_size || !variable_name || !vendor) + EFI_EXIT(EFI_INVALID_PARAMETER); + + if (variable_name[0]) { + /* check null-terminated string */ + for (i = 0; i < *variable_name_size; i++) + if (!variable_name[i]) + break; + if (i >= *variable_name_size) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* search for the last-returned variable */ + ret = efi_to_native(&native_name, variable_name, vendor); + if (ret) + return EFI_EXIT(ret); + + name_len = strlen(native_name); + for (variable = efi_variables_list; variable && *variable;) { + if (!strncmp(variable, native_name, name_len) && + variable[name_len] == '=') + break; + + variable = strchr(variable, '\n'); + if (variable) + variable++; + } + + free(native_name); + if (!(variable && *variable)) + return EFI_EXIT(EFI_INVALID_PARAMETER); + + /* next variable */ + variable = strchr(variable, '\n'); + if (variable) + variable++; + if (!(variable && *variable)) + return EFI_EXIT(EFI_NOT_FOUND); + } else { + /* + *new search: free a list used in the previous search + */ + free(efi_variables_list); + efi_variables_list = NULL; + efi_cur_variable = NULL; + + snprintf(regex, 256, "efi_.*-.*-.*-.*-.*_.*"); + list_len = hexport_r(&env_htab, '\n', + H_MATCH_REGEX | H_MATCH_KEY, + &efi_variables_list, 0, 1, regexlist); + if (list_len <= 0) + return EFI_EXIT(EFI_NOT_FOUND); + + variable = efi_variables_list; + } + + ret = parse_uboot_variable(variable, variable_name_size, variable_name, + vendor, &attributes); + + return EFI_EXIT(ret); }
/* http://wiki.phoenix.com/wiki/index.php/EFI_RUNTIME_SERVICES#SetVariable.28.2... */
There is a bug in efi variables test. Fix it with some cosmetic improvements.
Please note that efi variables test still fails at QueryVariableInfo() and GetVariable(), but this is not due to a change in this patch. ==8<== Testing EFI API implementation
Selected test: 'variables'
Setting up 'variables' Setting up 'variables' succeeded
Executing 'variables' .../u-boot/lib/efi_selftest/efi_selftest_variables.c(60): TODO: QueryVariableInfo failed .../u-boot/lib/efi_selftest/efi_selftest_variables.c(131): TODO: GetVariable returned wrong length 7 .../u-boot/lib/efi_selftest/efi_selftest_variables.c(133): TODO: GetVariable returned wrong value Executing 'variables' succeeded
Boot services terminated
Summary: 0 failures ==>8==
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v3 no change v2 no change --- lib/efi_selftest/efi_selftest_variables.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_variables.c b/lib/efi_selftest/efi_selftest_variables.c index ffc8cad329..47a8e7fb95 100644 --- a/lib/efi_selftest/efi_selftest_variables.c +++ b/lib/efi_selftest/efi_selftest_variables.c @@ -141,19 +141,22 @@ static int execute(void) if (ret == EFI_NOT_FOUND) break; if (ret != EFI_SUCCESS) { - efi_st_todo("GetNextVariableName failed\n"); - break; + efi_st_error("GetNextVariableName failed (%u)\n", + (unsigned int)ret); + return EFI_ST_FAILURE; } if (!efi_st_memcmp(&guid, &guid_vendor0, sizeof(efi_guid_t)) && !efi_st_strcmp_16_8(varname, "efi_st_var0")) - flag |= 2; + flag |= 1; if (!efi_st_memcmp(&guid, &guid_vendor1, sizeof(efi_guid_t)) && !efi_st_strcmp_16_8(varname, "efi_st_var1")) flag |= 2; } - if (flag != 3) - efi_st_todo( + if (flag != 3) { + efi_st_error( "GetNextVariableName did not return all variables\n"); + return EFI_ST_FAILURE; + } /* Delete variable 1 */ ret = runtime->set_variable(L"efi_st_var1", &guid_vendor1, 0, 0, NULL);
This fails in Travis for me on the qemu-x86_64 target:
/home/travis/build/agraf/u-boot/lib/efi_selftest/efi_selftest_variables.c(145): ERROR: GetNextVariableName failed (2) /home/travis/build/agraf/u-boot/lib/efi_selftest/efi_selftest.c(110): ERROR: Executing 'variables' failed
Alex
Alex
Hello Alex,
[PATCH 1/1] efi_loader: fix GetNextVariableName https://lists.denx.de/pipermail/u-boot/2019-January/355811.html
offers a partial fix. Now we get the correct error code. There is still something wrong in hexport_r(). It does not find a match for:
lib/hashtable.c(617) hexport_r: ep->key efi_67029eb5-0af2-f6b1-da53-fcb566dd1ce6_efi_st_var0, flag 272, argc 1, argv efi_.*-.*-.*-.*-.*_.*
Best regards
Heinrich
Alexander Graf
