[U-Boot] [RFC] Double-stage u-boot to reduce footprint
29 Nov
2010
29 Nov
'10
11:21 a.m.
Hi ML,
I'm working to have a small but also full-featured u-boot bootloader. The idea, that I already see on lantiq sources, is to have a small bootstrap code that decompresses the final u-boot.
The code is divided into two stages:
1) bootstrap: initializes the ram in order to decompress the u-boot binary. After that, bootstrap jumps to final u-boot 2) 2) u-boot: the state of the art of the boot loaders.
Can be interesting for you to have these pieces of code?
I ask before to send any patch, because the boards to support the bootstrap code should define some symbols (CONFIG_BOOTSTRAP_*) and provides a linker script, and the lowlevel init code for the ram.
Thanks for any comments,
luigi
Luigi 'Comio' Mantellini
R&D - Software
Industrie Dial Face S.p.A.
Via Canzo, 4
20068 Peschiera Borromeo (MI) Italy
Tel.: +39 02 5167 2813
Fax: +39 02 5167 2459
E-mail: luigi.mantellini@idf-hit.com
Website: http://www.idf-hit.com
Questo messaggio e i suoi allegati sono indirizzati esclusivamente alle
persone indicate. La diffusione, copia o qualsiasi altra azione derivante dalla
conoscenza di queste informazioni sono rigorosamente vietate. Qualora abbiate
ricevuto questo documento per errore siete cortesemente pregati di darne
immediata comunicazione al mittente e di provvedere alla sua distruzione,
Grazie.
Rispetta l'ambiente. Non stampare questa mail se non è realmente necessario.
This e-mail and any attachments is confidential and may contain privileged
information intended for the addressee(s) only. Dissemination, copying,
printing or use by anybody else is unauthorized. If you are not the intended
recipient, please delete this message and any attachments and advise the
sender by return e-mail, Thanks.
Help the environment. Please do not print this email unless it is absolutely
necessary.
5277
