[PATCH 0/4] USB fixes: Mass Storage bugs & 64bit support
This series fixes some bugs in the USBMS driver and adds 64-bit LBA support. This is required to make USB HDDs >=4TB work.
Note that the increased timeout won't actually work right now, due to broken handling in the underlying USB infrastructure. That will be fixed in a follow-up series, which depends on [1] being applied first. The USBMS part is logically stand-alone and can be applied in parallel before that.
[1] https://lore.kernel.org/u-boot/20231029-usb-fixes-1-v2-0-623533f6316e@marcan...
Signed-off-by: Hector Martin marcan@marcan.st --- Hector Martin (4): scsi: Fix a bunch of SCSI definitions. usb: storage: Increase read/write timeout usb: storage: Use the correct CBW lengths usb: storage: Implement 64-bit LBA support
common/usb_storage.c | 164 ++++++++++++++++++++++++++++++++++++++++++--------- drivers/ata/ahci.c | 9 ++- drivers/scsi/scsi.c | 4 +- include/scsi.h | 8 ++- 4 files changed, 150 insertions(+), 35 deletions(-) --- base-commit: 8ad1c9c26f7740806a162818b790d4a72f515b7e change-id: 20231029-usb-fixes-3-c72f829ba61b
0x9e isn't Read Capacity, it's a service action and the read capacity command is a subcommand.
READ16 is not 0x48, it's 0x88. 0x48 is SANITIZE and that sounds like we might have been destroying data instead of reading data. No bueno.
Signed-off-by: Hector Martin marcan@marcan.st --- drivers/ata/ahci.c | 9 ++++++--- drivers/scsi/scsi.c | 4 ++-- include/scsi.h | 8 ++++++-- 3 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index 2062197afcd3..b252e9e525db 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -906,15 +906,18 @@ static int ahci_scsi_exec(struct udevice *dev, struct scsi_cmd *pccb) case SCSI_RD_CAPAC10: ret = ata_scsiop_read_capacity10(uc_priv, pccb); break; - case SCSI_RD_CAPAC16: - ret = ata_scsiop_read_capacity16(uc_priv, pccb); - break; case SCSI_TST_U_RDY: ret = ata_scsiop_test_unit_ready(uc_priv, pccb); break; case SCSI_INQUIRY: ret = ata_scsiop_inquiry(uc_priv, pccb); break; + case SCSI_SRV_ACTION_IN: + if ((pccb->cmd[1] & 0x1f) == SCSI_SAI_RD_CAPAC16) { + ret = ata_scsiop_read_capacity16(uc_priv, pccb); + break; + } + /* Fallthrough */ default: printf("Unsupport SCSI command 0x%02x\n", pccb->cmd[0]); return -ENOTSUPP; diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index d7b33010e469..f2c828eb305e 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -380,8 +380,8 @@ static int scsi_read_capacity(struct udevice *dev, struct scsi_cmd *pccb,
/* Read capacity (10) was insufficient. Use read capacity (16). */ memset(pccb->cmd, '\0', sizeof(pccb->cmd)); - pccb->cmd[0] = SCSI_RD_CAPAC16; - pccb->cmd[1] = 0x10; + pccb->cmd[0] = SCSI_SRV_ACTION_IN; + pccb->cmd[1] = SCSI_SAI_RD_CAPAC16; pccb->cmdlen = 16; pccb->msgout[0] = SCSI_IDENTIFY; /* NOT USED */
diff --git a/include/scsi.h b/include/scsi.h index b47c7463c1d6..89e268586477 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -141,10 +141,9 @@ struct scsi_cmd { #define SCSI_MED_REMOVL 0x1E /* Prevent/Allow medium Removal (O) */ #define SCSI_READ6 0x08 /* Read 6-byte (MANDATORY) */ #define SCSI_READ10 0x28 /* Read 10-byte (MANDATORY) */ -#define SCSI_READ16 0x48 +#define SCSI_READ16 0x88 /* Read 16-byte */ #define SCSI_RD_CAPAC 0x25 /* Read Capacity (MANDATORY) */ #define SCSI_RD_CAPAC10 SCSI_RD_CAPAC /* Read Capacity (10) */ -#define SCSI_RD_CAPAC16 0x9e /* Read Capacity (16) */ #define SCSI_RD_DEFECT 0x37 /* Read Defect Data (O) */ #define SCSI_READ_LONG 0x3E /* Read Long (O) */ #define SCSI_REASS_BLK 0x07 /* Reassign Blocks (O) */ @@ -158,15 +157,20 @@ struct scsi_cmd { #define SCSI_SEEK10 0x2B /* Seek 10-Byte (O) */ #define SCSI_SEND_DIAG 0x1D /* Send Diagnostics (MANDATORY) */ #define SCSI_SET_LIMIT 0x33 /* Set Limits (O) */ +#define SCSI_SRV_ACTION_IN 0x9E /* Service Action In */ +#define SCSI_SRV_ACTION_OUT 0x9F /* Service Action Out */ #define SCSI_START_STP 0x1B /* Start/Stop Unit (O) */ #define SCSI_SYNC_CACHE 0x35 /* Synchronize Cache (O) */ #define SCSI_VERIFY 0x2F /* Verify (O) */ #define SCSI_WRITE6 0x0A /* Write 6-Byte (MANDATORY) */ #define SCSI_WRITE10 0x2A /* Write 10-Byte (MANDATORY) */ +#define SCSI_WRITE16 0x8A /* Write 16-byte */ #define SCSI_WRT_VERIFY 0x2E /* Write and Verify (O) */ #define SCSI_WRITE_LONG 0x3F /* Write Long (O) */ #define SCSI_WRITE_SAME 0x41 /* Write Same (O) */
+#define SCSI_SAI_RD_CAPAC16 0x10 /* Service Action: Read Capacity (16) */ + /** * struct scsi_plat - stores information about SCSI controller *
case SCSI_TST_U_RDY: ret = ata_scsiop_test_unit_ready(uc_priv, pccb); break; case SCSI_INQUIRY: ret = ata_scsiop_inquiry(uc_priv, pccb); break;break;
- case SCSI_SRV_ACTION_IN:
break;
Would it make sense to add an else branch here and report unknown subcommand there ?
With that: Reviewed-by: Marek Vasut marex@denx.de
Some USB devices (like hard disks) can take a long time to initially respond to read/write requests. Explicitly specify a much longer timeout than normal.
Signed-off-by: Hector Martin marcan@marcan.st --- common/usb_storage.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index c9e2d7343ce2..729ddbc75a48 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -53,6 +53,12 @@ #undef BBB_COMDAT_TRACE #undef BBB_XPORT_TRACE
+/* + * Timeout for read/write transfers. This needs to be able to handle very slow + * devices, such as hard disks that are spinning up. + */ +#define US_XFER_TIMEOUT 15000 + #include <scsi.h> /* direction table -- this indicates the direction of the data * transfer for each command code -- a 1 indicates input @@ -394,7 +400,7 @@ static int us_one_transfer(struct us_data *us, int pipe, char *buf, int length) 11 - maxtry); result = usb_bulk_msg(us->pusb_dev, pipe, buf, this_xfer, &partial, - USB_CNTL_TIMEOUT * 5); + US_XFER_TIMEOUT); debug("bulk_msg returned %d xferred %d/%d\n", result, partial, this_xfer); if (us->pusb_dev->status != 0) { @@ -743,7 +749,7 @@ static int usb_stor_BBB_transport(struct scsi_cmd *srb, struct us_data *us) pipe = pipeout;
result = usb_bulk_msg(us->pusb_dev, pipe, srb->pdata, srb->datalen, - &data_actlen, USB_CNTL_TIMEOUT * 5); + &data_actlen, US_XFER_TIMEOUT); /* special handling of STALL in DATA phase */ if ((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) { debug("DATA:stall\n");
Can we make this configurable with e.g. env variable, similar to usb_pgood_delay , to avoid affecting existing users ?
USB UFI uses fixed 12-byte commands (as does RBC, which is not supported), but SCSI does not have this limitation. Use the correct command block lengths depending on the subclass.
Signed-off-by: Hector Martin marcan@marcan.st --- common/usb_storage.c | 22 ++++++++++++++-------- 1 file changed, 14 insertions(+), 8 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 729ddbc75a48..95507ffbce48 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -107,6 +107,7 @@ struct us_data { trans_reset transport_reset; /* reset routine */ trans_cmnd transport; /* transport routine */ unsigned short max_xfer_blk; /* maximum transfer blocks */ + bool cmd12; /* use 12-byte commands (RBC/UFI) */ };
#if !CONFIG_IS_ENABLED(BLK) @@ -349,7 +350,7 @@ static void usb_show_srb(struct scsi_cmd *pccb) { int i; printf("SRB: len %d datalen 0x%lX\n ", pccb->cmdlen, pccb->datalen); - for (i = 0; i < 12; i++) + for (i = 0; i < pccb->cmdlen; i++) printf("%02X ", pccb->cmd[i]); printf("\n"); } @@ -888,7 +889,7 @@ do_retry: psrb->cmd[4] = 18; psrb->datalen = 18; psrb->pdata = &srb->sense_buf[0]; - psrb->cmdlen = 12; + psrb->cmdlen = us->cmd12 ? 12 : 6; /* issue the command */ result = usb_stor_CB_comdat(psrb, us); debug("auto request returned %d\n", result); @@ -989,7 +990,7 @@ static int usb_inquiry(struct scsi_cmd *srb, struct us_data *ss) srb->cmd[1] = srb->lun << 5; srb->cmd[4] = 36; srb->datalen = 36; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 6; i = ss->transport(srb, ss); debug("inquiry returns %d\n", i); if (i == 0) @@ -1014,7 +1015,7 @@ static int usb_request_sense(struct scsi_cmd *srb, struct us_data *ss) srb->cmd[4] = 18; srb->datalen = 18; srb->pdata = &srb->sense_buf[0]; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 6; ss->transport(srb, ss); debug("Request Sense returned %02X %02X %02X\n", srb->sense_buf[2], srb->sense_buf[12], @@ -1032,7 +1033,7 @@ static int usb_test_unit_ready(struct scsi_cmd *srb, struct us_data *ss) srb->cmd[0] = SCSI_TST_U_RDY; srb->cmd[1] = srb->lun << 5; srb->datalen = 0; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 6; if (ss->transport(srb, ss) == USB_STOR_TRANSPORT_GOOD) { ss->flags |= USB_READY; return 0; @@ -1064,7 +1065,7 @@ static int usb_read_capacity(struct scsi_cmd *srb, struct us_data *ss) srb->cmd[0] = SCSI_RD_CAPAC; srb->cmd[1] = srb->lun << 5; srb->datalen = 8; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 10; if (ss->transport(srb, ss) == USB_STOR_TRANSPORT_GOOD) return 0; } while (retry--); @@ -1084,7 +1085,7 @@ static int usb_read_10(struct scsi_cmd *srb, struct us_data *ss, srb->cmd[5] = ((unsigned char) (start)) & 0xff; srb->cmd[7] = ((unsigned char) (blocks >> 8)) & 0xff; srb->cmd[8] = (unsigned char) blocks & 0xff; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 10; debug("read10: start %lx blocks %x\n", start, blocks); return ss->transport(srb, ss); } @@ -1101,7 +1102,7 @@ static int usb_write_10(struct scsi_cmd *srb, struct us_data *ss, srb->cmd[5] = ((unsigned char) (start)) & 0xff; srb->cmd[7] = ((unsigned char) (blocks >> 8)) & 0xff; srb->cmd[8] = (unsigned char) blocks & 0xff; - srb->cmdlen = 12; + srb->cmdlen = ss->cmd12 ? 12 : 10; debug("write10: start %lx blocks %x\n", start, blocks); return ss->transport(srb, ss); } @@ -1407,6 +1408,11 @@ int usb_storage_probe(struct usb_device *dev, unsigned int ifnum, printf("Sorry, protocol %d not yet supported.\n", ss->subclass); return 0; } + + /* UFI uses 12-byte commands (like RBC, unlike SCSI) */ + if (ss->subclass == US_SC_UFI) + ss->cmd12 = true; + if (ss->ep_int) { /* we had found an interrupt endpoint, prepare irq pipe * set up the IRQ pipe and handler
This makes things work properly on devices with >= 2 TiB capacity. If u-boot is built without CONFIG_SYS_64BIT_LBA, the capacity will be clamped at 2^32 - 1 sectors.
Signed-off-by: Hector Martin marcan@marcan.st --- common/usb_storage.c | 132 ++++++++++++++++++++++++++++++++++++++++++++------- 1 file changed, 114 insertions(+), 18 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 95507ffbce48..3035f2ee9868 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -66,7 +66,7 @@ static const unsigned char us_direction[256/8] = { 0x28, 0x81, 0x14, 0x14, 0x20, 0x01, 0x90, 0x77, 0x0C, 0x20, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, + 0x00, 0x01, 0x00, 0x40, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; #define US_DIRECTION(x) ((us_direction[x>>3] >> (x & 7)) & 1) @@ -1073,6 +1073,27 @@ static int usb_read_capacity(struct scsi_cmd *srb, struct us_data *ss) return -1; }
+#ifdef CONFIG_SYS_64BIT_LBA +static int usb_read_capacity64(struct scsi_cmd *srb, struct us_data *ss) +{ + int retry; + /* XXX retries */ + retry = 3; + do { + memset(&srb->cmd[0], 0, 16); + srb->cmd[0] = SCSI_SRV_ACTION_IN; + srb->cmd[1] = (srb->lun << 5) | SCSI_SAI_RD_CAPAC16; + srb->cmd[13] = 32; /* Allocation length */ + srb->datalen = 32; + srb->cmdlen = 16; + if (ss->transport(srb, ss) == USB_STOR_TRANSPORT_GOOD) + return 0; + } while (retry--); + + return -1; +} +#endif + static int usb_read_10(struct scsi_cmd *srb, struct us_data *ss, unsigned long start, unsigned short blocks) { @@ -1107,6 +1128,49 @@ static int usb_write_10(struct scsi_cmd *srb, struct us_data *ss, return ss->transport(srb, ss); }
+#ifdef CONFIG_SYS_64BIT_LBA +static int usb_read_16(struct scsi_cmd *srb, struct us_data *ss, + uint64_t start, unsigned short blocks) +{ + memset(&srb->cmd[0], 0, 16); + srb->cmd[0] = SCSI_READ16; + srb->cmd[1] = srb->lun << 5; + srb->cmd[2] = ((unsigned char) (start >> 56)) & 0xff; + srb->cmd[3] = ((unsigned char) (start >> 48)) & 0xff; + srb->cmd[4] = ((unsigned char) (start >> 40)) & 0xff; + srb->cmd[5] = ((unsigned char) (start >> 32)) & 0xff; + srb->cmd[6] = ((unsigned char) (start >> 24)) & 0xff; + srb->cmd[7] = ((unsigned char) (start >> 16)) & 0xff; + srb->cmd[8] = ((unsigned char) (start >> 8)) & 0xff; + srb->cmd[9] = ((unsigned char) (start)) & 0xff; + srb->cmd[12] = ((unsigned char) (blocks >> 8)) & 0xff; + srb->cmd[13] = (unsigned char) blocks & 0xff; + srb->cmdlen = 16; + debug("read16: start %llx blocks %x\n", (long long)start, blocks); + return ss->transport(srb, ss); +} + +static int usb_write_16(struct scsi_cmd *srb, struct us_data *ss, + uint64_t start, unsigned short blocks) +{ + memset(&srb->cmd[0], 0, 16); + srb->cmd[0] = SCSI_WRITE16; + srb->cmd[1] = srb->lun << 5; + srb->cmd[2] = ((unsigned char) (start >> 56)) & 0xff; + srb->cmd[3] = ((unsigned char) (start >> 48)) & 0xff; + srb->cmd[4] = ((unsigned char) (start >> 40)) & 0xff; + srb->cmd[5] = ((unsigned char) (start >> 32)) & 0xff; + srb->cmd[6] = ((unsigned char) (start >> 24)) & 0xff; + srb->cmd[7] = ((unsigned char) (start >> 16)) & 0xff; + srb->cmd[8] = ((unsigned char) (start >> 8)) & 0xff; + srb->cmd[9] = ((unsigned char) (start)) & 0xff; + srb->cmd[12] = ((unsigned char) (blocks >> 8)) & 0xff; + srb->cmd[13] = (unsigned char) blocks & 0xff; + srb->cmdlen = 16; + debug("write16: start %llx blocks %x\n", (long long)start, blocks); + return ss->transport(srb, ss); +} +#endif
#ifdef CONFIG_USB_BIN_FIXUP /* @@ -1145,6 +1209,7 @@ static unsigned long usb_stor_read(struct blk_desc *block_dev, lbaint_t blknr, struct usb_device *udev; struct us_data *ss; int retry; + int ret; struct scsi_cmd *srb = &usb_ccb; #if CONFIG_IS_ENABLED(BLK) struct blk_desc *block_dev; @@ -1190,7 +1255,13 @@ retry_it: usb_show_progress(); srb->datalen = block_dev->blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; - if (usb_read_10(srb, ss, start, smallblks)) { +#ifdef CONFIG_SYS_64BIT_LBA + if (block_dev->lba > ((lbaint_t)0x100000000)) + ret = usb_read_16(srb, ss, start, smallblks); + else +#endif + ret = usb_read_10(srb, ss, start, smallblks); + if (ret) { debug("Read ERROR\n"); ss->flags &= ~USB_READY; usb_request_sense(srb, ss); @@ -1228,6 +1299,7 @@ static unsigned long usb_stor_write(struct blk_desc *block_dev, lbaint_t blknr, struct usb_device *udev; struct us_data *ss; int retry; + int ret; struct scsi_cmd *srb = &usb_ccb; #if CONFIG_IS_ENABLED(BLK) struct blk_desc *block_dev; @@ -1277,7 +1349,13 @@ retry_it: usb_show_progress(); srb->datalen = block_dev->blksz * smallblks; srb->pdata = (unsigned char *)buf_addr; - if (usb_write_10(srb, ss, start, smallblks)) { +#ifdef CONFIG_SYS_64BIT_LBA + if (block_dev->lba > ((lbaint_t)0x100000000)) + ret = usb_write_16(srb, ss, start, smallblks); + else +#endif + ret = usb_write_10(srb, ss, start, smallblks); + if (ret) { debug("Write ERROR\n"); ss->flags &= ~USB_READY; usb_request_sense(srb, ss); @@ -1434,9 +1512,10 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, struct blk_desc *dev_desc) { unsigned char perq, modi; - ALLOC_CACHE_ALIGN_BUFFER(u32, cap, 2); + ALLOC_CACHE_ALIGN_BUFFER(u32, cap, 8); ALLOC_CACHE_ALIGN_BUFFER(u8, usb_stor_buf, 36); - u32 capacity, blksz; + lbaint_t capacity; + u32 blksz; struct scsi_cmd *pccb = &usb_ccb;
pccb->pdata = usb_stor_buf; @@ -1487,26 +1566,43 @@ int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, return 0; } pccb->pdata = (unsigned char *)cap; - memset(pccb->pdata, 0, 8); + memset(pccb->pdata, 0, 32); if (usb_read_capacity(pccb, ss) != 0) { printf("READ_CAP ERROR\n"); ss->flags &= ~USB_READY; - cap[0] = 2880; - cap[1] = 0x200; + capacity = 2880; + blksz = 512; + } else { + debug("Read Capacity returns: 0x%08x, 0x%08x\n", + cap[0], cap[1]); + capacity = ((lbaint_t)be32_to_cpu(cap[0])) + 1; + blksz = be32_to_cpu(cap[1]); } - debug("Read Capacity returns: 0x%08x, 0x%08x\n", cap[0], cap[1]); -#if 0 - if (cap[0] > (0x200000 * 10)) /* greater than 10 GByte */ - cap[0] >>= 16;
- cap[0] = cpu_to_be32(cap[0]); - cap[1] = cpu_to_be32(cap[1]); +#ifdef CONFIG_SYS_64BIT_LBA + if (capacity == 0x100000000) { + if (usb_read_capacity64(pccb, ss) != 0) { + puts("READ_CAP64 ERROR\n"); + } else { + debug("Read Capacity 64 returns: 0x%08x, 0x%08x, 0x%08x\n", + cap[0], cap[1], cap[2]); + capacity = be64_to_cpu(*(uint64_t *)cap) + 1; + blksz = be32_to_cpu(cap[2]); + } + } +#else + /* + * READ CAPACITY will return 0xffffffff when limited, + * which wraps to 0 with the +1 above + */ + if (!capacity) { + puts("LBA exceeds 32 bits but 64-bit LBA is disabled.\n"); + capacity = ~0; + } #endif
- capacity = be32_to_cpu(cap[0]) + 1; - blksz = be32_to_cpu(cap[1]); - - debug("Capacity = 0x%08x, blocksz = 0x%08x\n", capacity, blksz); + debug("Capacity = 0x%llx, blocksz = 0x%08x\n", + (long long)capacity, blksz); dev_desc->lba = capacity; dev_desc->blksz = blksz; dev_desc->log2blksz = LOG2(dev_desc->blksz);
- 0x00, 0x01, 0x00, 0x40, 0x00, 0x01, 0x00, 0x01,
What changed here ?
Could you try and use CONFIG_IS_ENABLED() ?
- if (capacity == 0x100000000) {
} else {
+#else
- if (!capacity) {
capacity = ~0;
- } #endif
What changed here ?
This is an incomplete bitmap specifying the data transfer direction for every possible SCSI command ID. I'm adding the new commands I'm now using.
Sure.
} else {
+#else
- if (!capacity) {
capacity = ~0;
- } #endif
- Hector
What changed here ?
Can you please add a code comment here, so others wouldn't ponder about this too ?
Series LGTM.
Reviewed-by: Neal Gompa neal@gompa.dev
Hector Martin
Neal Gompa
