[U-Boot] [PATCH] Convert CONFIG_NAND_DAVINCI to Kconfig
This converts the following to Kconfig: CONFIG_NAND_DAVINCI
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 497e5515d7..43292a126d 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 15c4944b3b..d1a6e542cb 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -34,4 +34,6 @@ CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_SYS_NS16550=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 3307839829..c5bb84a8d6 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -36,6 +36,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index ef6abc868d..a86eeb8b14 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -29,6 +29,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index ede8f6a701..911618c17a 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -36,6 +36,8 @@ CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 04f4b02a09..174af79960 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -29,6 +29,8 @@ CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index fa800f5ef7..942e44e7a9 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -36,6 +36,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 2cf5c4fd7c..12be37f0b7 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -29,6 +29,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 1034d36455..5381e9f7cc 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -36,6 +36,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index d369d320d6..0381a7240c 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -28,6 +28,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index cabea06256..4a97269dd4 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -35,6 +35,7 @@ CONFIG_DM=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y CONFIG_NAND=y +CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 2915d59f4c..c3a1453ee1 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -15,6 +15,12 @@ config NAND_ATMEL Enable this driver for NAND flash platforms using an Atmel NAND controller.
+config NAND_DAVINCI + bool "Support TI Davinci NAND controller" + help + Enable this driver for NAND flash controllers available in Davinici + and Keystone2 platforms + config NAND_DENALI bool select SYS_NAND_SELF_INIT diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index ebfdd1c7a3..006cd03c00 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -149,7 +149,6 @@ * Flash & Environment */ #ifdef CONFIG_USE_NAND -#define CONFIG_NAND_DAVINCI #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_SYS_NAND_USE_FLASH_BBT diff --git a/include/configs/ea20.h b/include/configs/ea20.h index c84cd962d7..5398120fbe 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -119,7 +119,6 @@ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS
-#define CONFIG_NAND_DAVINCI #define CONFIG_SYS_NAND_PAGE_2K #define CONFIG_SYS_NAND_NO_SUBPAGE #define CONFIG_SYS_NAND_CS 2 diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index faf21ddb08..18c7fd657f 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -117,7 +117,6 @@ /* * Flash & Environment */ -#define CONFIG_NAND_DAVINCI #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_SYS_NAND_USE_FLASH_BBT diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 58624ec581..a0aebfed25 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -143,7 +143,6 @@ * Flash & Environment */ #ifdef CONFIG_USE_NAND -#define CONFIG_NAND_DAVINCI #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 9) #define CONFIG_SYS_NAND_USE_FLASH_BBT diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index ccd466583a..18a03b3955 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -159,7 +159,6 @@ #define CONFIG_ENV_EEPROM_IS_ON_I2C
/* NAND Configuration */ -#define CONFIG_NAND_DAVINCI #define CONFIG_KEYSTONE_RBL_NAND #define CONFIG_KEYSTONE_NAND_MAX_RBL_SIZE CONFIG_ENV_OFFSET #define CONFIG_SYS_NAND_MASK_CLE 0x4000 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index baecbbbfa3..1fb8968ef5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1371,7 +1371,6 @@ CONFIG_NAND_6BYTES_OOB_FREE_10BYTES_ECC CONFIG_NAND_ACTL CONFIG_NAND_CS_INIT CONFIG_NAND_DATA_REG -CONFIG_NAND_DAVINCI CONFIG_NAND_ECC_BCH CONFIG_NAND_ENV_DST CONFIG_NAND_FSL_ELBC
Adam Ford
