[U-Boot-Users] help starting
Hi, I'm totally new to the world of porting U-Boot (or other boot loaders) to new hardware.
I have an older version of U-Boot (0.4.5) that was ported to 2 custom made boards we have, based on the MPC5200 CPU, and the IceCube evaluation board. Both has the same U-Boot up and running.
We now have a new board, base on the same design, but with some modification.
I have BDI2000 up and running, and I can access the board's memory, flash, cpu registers etc.
When I try to run the same U-boot, it, as can be expected, fails to run, and stop very soon after startup (no message comes out on the serial console).
I've tried to connect with GDB to debug, and I manage to do it, then step few commands, and I get SIGSTOP. To make sure that this is not a problem of the new board, I've tried the same with a working board, and the U-Boot fails at the same place (right after the starting point). On the other hand, if I don't try to do a step by step debugging, but give a "cont" command, the U-boot (on the older board) does work.
So I guess I have a basic problem in understanding how to debug the U-Boot with GDB.
Any help (either specific, or pointers to guides), will be great.
Thanks, Ilan
Did you read the "Debugging" section in the manual?
See http://www.denx.de/twiki/bin/view/DULG/DebuggingUBoot
Hi, Yes I've read it, but when I try this (on the older board, where the u-boot is working), the gdb doesn't stop at that function, just continue (and over the serial terminal, I see the normal u-boot messages, and later auto booting into linux).
Here is the screen dump of what I've done:
U-Boot $ powerpc-linux-gdb u-boot GNU gdb 5.3 Copyright 2002 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "--host=i686-pc-linux-gnu --target=powerpc-linux"... (gdb) target remote jtag2:2001 Remote debugging using jtag2:2001 _start () at /homes/ifinci/secure/work/SeeQNet/U-Boot/cpu/mpc5xxx/start.S:91 91 li r21, BOOTFLAG_COLD /* Normal Power-On */ (gdb) b cpu_init_f Breakpoint 1 at 0xfff03a34: file cpu_init.c, line 53. (gdb) c Continuing.
and I don't get the GDB prompt back unless I press CTRL+C.
Any idea?
Thanks, Ilan
on 12/01/04 09:22 Wolfgang Denk said the following:
Is your BDI is configured to use hardware breakpoints?
Apparently not :(
Setting it to use hardware BP, did the trick.
Thanks, Ilan
on 12/01/04 13:13 Wolfgang Denk said the following:
Ilan Finci
