[U-Boot] [PATCH 2/5] powerpc/b4860qds: dtb fixup for xfi
Since xfi has no phy, we delete the property "phy-handle" and use a "fixed-link" property for a xfi port.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- board/freescale/b4860qds/eth_b4860qds.c | 38 +++++++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+)
diff --git a/board/freescale/b4860qds/eth_b4860qds.c b/board/freescale/b4860qds/eth_b4860qds.c index aa48b5e..595bb4c 100644 --- a/board/freescale/b4860qds/eth_b4860qds.c +++ b/board/freescale/b4860qds/eth_b4860qds.c @@ -365,6 +365,11 @@ void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, { int phy; char alias[32]; + struct fixed_link f_link; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 prtcl2 = in_be32(&gur->rcwsr[4]) & FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + + prtcl2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT;
if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { phy = fm_info_get_phy_address(port); @@ -372,6 +377,39 @@ void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, sprintf(alias, "phy_sgmii_%x", phy); fdt_set_phy_handle(fdt, compat, addr, alias); fdt_status_okay_by_alias(fdt, alias); + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_XGMII) { + /* check if it's XFI interface for 10g */ + switch (prtcl2) { + case 0x80: + case 0x81: + case 0x82: + case 0x83: + case 0x84: + case 0x85: + case 0x86: + case 0x87: + case 0x88: + case 0x89: + case 0x8a: + case 0x8b: + case 0x8c: + case 0x8d: + case 0x8e: + case 0xb1: + case 0xb2: + f_link.phy_id = port; + f_link.duplex = 1; + f_link.link_speed = 10000; + f_link.pause = 0; + f_link.asym_pause = 0; + + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, + sizeof(f_link)); + break; + default: + break; + } } }
Applied to u-boot-mpc85xx, awaiting upstream.
York
shh.xie@gmail.com
York Sun
