[U-Boot] [RFC PATCH] common: board_f: Make reserve_mmu a weak function
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Make reserve_mmu a weak so that it provides an option to customize this routine as per platform need
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
common/board_f.c | 2 +- include/common.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 2cdd12a503ae..09f0fbfb6c96 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -340,7 +340,7 @@ static int reserve_round_4k(void) }
#ifdef CONFIG_ARM -static int reserve_mmu(void) +__weak int reserve_mmu(void) { #if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) /* reserve TLB table */ diff --git a/include/common.h b/include/common.h index 1a98512ab618..ce4c92015928 100644 --- a/include/common.h +++ b/include/common.h @@ -286,6 +286,7 @@ void board_show_dram(phys_size_t size); */ int arch_fixup_fdt(void *blob);
+int reserve_mmu(void); /* common/flash.c */ void flash_perror (int);
Hi Michal,
Why do you need this? Can we instead have the generic code do the right thing? Or can we use reserve_arch() to handle this?
-- 1.9.1
Hi Simon,
On 18.7.2017 16:01, Simon Glass wrote:
Hi Michal,
reserve_mmu is called just for ARM. What we need to do is support configuration where we have small memory OCM and we need to put mmu table to different location (TCM) because it is simply big and it can't be placed where it is placed now.
Based on looking at code the key question is if we can call reserve_mmu at that time when reserve_arch is called now. On zynqmp I can't see any issue to allocate tlb on the stack and call it from it. The question is if this is valid for all arms.
This is just a small hack I have created to move it to stack.
diff --git a/common/board_f.c b/common/board_f.c index 88e20e0168b2..32386c957962 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -433,13 +433,13 @@ __weak int reserve_mmu(void) { /* reserve TLB table */ gd->arch.tlb_size = PGTABLE_SIZE; - gd->relocaddr -= gd->arch.tlb_size; + gd->start_addr_sp -= gd->arch.tlb_size;
/* round down to next 64 kB limit */ - gd->relocaddr &= ~(0x10000 - 1); + gd->start_addr_sp &= ~(0x10000 - 1);
- gd->arch.tlb_addr = gd->relocaddr; - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, + gd->arch.tlb_addr = gd->start_addr_sp; + printf("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, gd->arch.tlb_addr + gd->arch.tlb_size);
#ifdef CONFIG_SYS_MEM_RESERVE_SECURE @@ -837,7 +837,7 @@ static int initf_dm(void) /* Architecture-specific memory reservation */ __weak int reserve_arch(void) { - return 0; + return reserve_mmu(); }
__weak int arch_cpu_init_dm(void) @@ -998,10 +998,6 @@ static init_fnc_t init_sequence_f[] = { reserve_pram, #endif reserve_round_4k, -#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) && \ - defined(CONFIG_ARM) - reserve_mmu, -#endif #ifdef CONFIG_DM_VIDEO reserve_video, #else
For us we can't just rewrite tlb addresses as we want to do because we can't allow reserve_mmu to allocate 64kB alied PGTABLE_SIZE in relocation structure. What do you think?
Thanks, Michal
Hi Michal,
On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote:
Hi Simon,
Hi Michal,
What arch are you using?
What is TCM? Is this the internal SRAM?
I don't understand 'simply big'. Are you saying it is too big to go into main memory?
gd->start_addr_sp -= gd->arch.tlb_size; /* round down to next 64 kB limit */
defined(CONFIG_ARM)
reserve_mmu,
Why not?
What do you think?
Thanks, Michal
Hi Simon,
On 18.7.2017 16:50, Simon Glass wrote:
Hi Michal,
Hi Simon,
Hi Michal,
arm64 - a53s
It is internal sram which is used mostly by R5s in the system but a53 has also access to it.
These configuration can't use DDR. One of that configuration which we are using is DDR memory test. It means you run from internal sram (256kB OCM + 256k TCM). Another configuration is for loading stuff to EMMC on different boards. It means you don't need to setup DDR for generic emmc programming.
All these configurations are using console over DCC - arm jtag uart.
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Because we need to fit to 256kB of memory also with relocation and also space for data. And IIRC MMU table size is 64kB. Another option could be to disable relocation.
Thanks, Michal
On 07/18/2017 10:59 PM, Michal Simek wrote:
Hi Simon,
Hi Michal,
Hi Simon,
Hi Michal,
arm64 - a53s
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Michal,
For your reference, we use two stage MMU setup for FSL ARMv8 SoCs. We setup an early MMU in arch_cpu_init() so we can enable d-cache very early to speed up execution. Our DDR init and testing is done on top of that. After DDR init, we use the reserved MMU table in DDR to setup a final MMU for normal use.
York
Hi Simon,
Hi Michal,
Hi Simon,
Hi Michal,
arm64 - a53s
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Michal,
How big is this speed up?
ok. This is a little bit different purpose but yes - we just need what you do in early to be consistent. Maybe there is an option simply check if tlb_size is filled and do not allocate space for it but this will break your SoC because you don't want to keep early mmu mapping in OCRAM.
Thanks, Michal
On 07/18/2017 10:59 PM, Michal Simek wrote: Hi Simon,
On 18.7.2017 16:50, Simon Glass wrote: Hi Michal,
On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote: Hi Simon,
On 18.7.2017 16:01, Simon Glass wrote: Hi Michal,
> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: > From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com > > Make reserve_mmu a weak so that it provides an option > to customize this routine as per platform need
arm64 - a53s
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Michal,
Huge improvement (feeling like 10x faster at least), especially on emulators.
York
> On 18.7.2017 16:01, Simon Glass wrote: > Hi Michal, > >> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: >> From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com >> >> Make reserve_mmu a weak so that it provides an option >> to customize this routine as per platform need > > Why do you need this? Can we instead have the generic code do the > right thing? Or can we use reserve_arch() to handle this?
arm64 - a53s
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Michal,
ok. It means on real silicon I see that improvement could be till a second right?
Thanks, Michal
On 19.7.2017 04:18, York Sun wrote: On 07/18/2017 10:59 PM, Michal Simek wrote: Hi Simon,
> On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote: > Hi Simon, > >> On 18.7.2017 16:01, Simon Glass wrote: >> Hi Michal, >> >>> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: >>> From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com >>> >>> Make reserve_mmu a weak so that it provides an option >>> to customize this routine as per platform need >> >> Why do you need this? Can we instead have the generic code do the >> right thing? Or can we use reserve_arch() to handle this? > > reserve_mmu is called just for ARM.
arm64 - a53s
> What we need to do is support configuration where we have small memory > OCM and we need to put mmu table to different location (TCM) because it > is simply big and it can't be placed where it is placed now.
> > Based on looking at code the key question is if we can call reserve_mmu > at that time when reserve_arch is called now. > On zynqmp I can't see any issue to allocate tlb on the stack and call it > from it. The question is if this is valid for all arms. > > This is just a small hack I have created to move it to stack. > > diff --git a/common/board_f.c b/common/board_f.c > index 88e20e0168b2..32386c957962 100644 > --- a/common/board_f.c > +++ b/common/board_f.c > @@ -433,13 +433,13 @@ __weak int reserve_mmu(void) > { > /* reserve TLB table */ > gd->arch.tlb_size = PGTABLE_SIZE; > - gd->relocaddr -= gd->arch.tlb_size; > + gd->start_addr_sp -= gd->arch.tlb_size; > > /* round down to next 64 kB limit */ > - gd->relocaddr &= ~(0x10000 - 1); > + gd->start_addr_sp &= ~(0x10000 - 1); > > - gd->arch.tlb_addr = gd->relocaddr; > - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, > + gd->arch.tlb_addr = gd->start_addr_sp; > + printf("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, > gd->arch.tlb_addr + gd->arch.tlb_size); > > #ifdef CONFIG_SYS_MEM_RESERVE_SECURE > @@ -837,7 +837,7 @@ static int initf_dm(void) > /* Architecture-specific memory reservation */ > __weak int reserve_arch(void) > { > - return 0; > + return reserve_mmu(); > } > > __weak int arch_cpu_init_dm(void) > @@ -998,10 +998,6 @@ static init_fnc_t init_sequence_f[] = { > reserve_pram, > #endif > reserve_round_4k, > -#if !(defined(CONFIG_SYS_ICACHE_OFF) && > defined(CONFIG_SYS_DCACHE_OFF)) && \ > - defined(CONFIG_ARM) > - reserve_mmu, > -#endif > #ifdef CONFIG_DM_VIDEO > reserve_video, > #else > > For us we can't just rewrite tlb addresses as we want to do because we > can't allow reserve_mmu to allocate 64kB alied PGTABLE_SIZE in > relocation structure.
Why not?
Michal,
It may be several hundreds milliseconds difference on real silicon, depends on core speed and booting device speed and booting method. For example, the NOR flash boot is very slow due to the interface.
York
> On 18.7.2017 16:50, Simon Glass wrote: > Hi Michal, > >> On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote: >> Hi Simon, >> >>> On 18.7.2017 16:01, Simon Glass wrote: >>> Hi Michal, >>> >>>> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: >>>> From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com >>>> >>>> Make reserve_mmu a weak so that it provides an option >>>> to customize this routine as per platform need >>> >>> Why do you need this? Can we instead have the generic code do the >>> right thing? Or can we use reserve_arch() to handle this? >> >> reserve_mmu is called just for ARM. > > What arch are you using?
arm64 - a53s
> >> What we need to do is support configuration where we have small memory >> OCM and we need to put mmu table to different location (TCM) because it >> is simply big and it can't be placed where it is placed now. > > What is TCM? Is this the internal SRAM?
> > I don't understand 'simply big'. Are you saying it is too big to go > into main memory?
> >> >> Based on looking at code the key question is if we can call reserve_mmu >> at that time when reserve_arch is called now. >> On zynqmp I can't see any issue to allocate tlb on the stack and call it >> from it. The question is if this is valid for all arms. >> >> This is just a small hack I have created to move it to stack. >> >> diff --git a/common/board_f.c b/common/board_f.c >> index 88e20e0168b2..32386c957962 100644 >> --- a/common/board_f.c >> +++ b/common/board_f.c >> @@ -433,13 +433,13 @@ __weak int reserve_mmu(void) >> { >> /* reserve TLB table */ >> gd->arch.tlb_size = PGTABLE_SIZE; >> - gd->relocaddr -= gd->arch.tlb_size; >> + gd->start_addr_sp -= gd->arch.tlb_size; >> >> /* round down to next 64 kB limit */ >> - gd->relocaddr &= ~(0x10000 - 1); >> + gd->start_addr_sp &= ~(0x10000 - 1); >> >> - gd->arch.tlb_addr = gd->relocaddr; >> - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >> + gd->arch.tlb_addr = gd->start_addr_sp; >> + printf("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >> gd->arch.tlb_addr + gd->arch.tlb_size); >> >> #ifdef CONFIG_SYS_MEM_RESERVE_SECURE >> @@ -837,7 +837,7 @@ static int initf_dm(void) >> /* Architecture-specific memory reservation */ >> __weak int reserve_arch(void) >> { >> - return 0; >> + return reserve_mmu(); >> } >> >> __weak int arch_cpu_init_dm(void) >> @@ -998,10 +998,6 @@ static init_fnc_t init_sequence_f[] = { >> reserve_pram, >> #endif >> reserve_round_4k, >> -#if !(defined(CONFIG_SYS_ICACHE_OFF) && >> defined(CONFIG_SYS_DCACHE_OFF)) && \ >> - defined(CONFIG_ARM) >> - reserve_mmu, >> -#endif >> #ifdef CONFIG_DM_VIDEO >> reserve_video, >> #else >> >> For us we can't just rewrite tlb addresses as we want to do because we >> can't allow reserve_mmu to allocate 64kB alied PGTABLE_SIZE in >> relocation structure. > > Why not?
Michal,
Ok. I see. Time to do some measurements and see if makes sense to invest our time to do this. Till now I am not aware about any request to speed up u-boot boot time. Definitely thanks for pointer.
Thanks, Michal
> On 19.7.2017 04:18, York Sun wrote: > On 07/18/2017 10:59 PM, Michal Simek wrote: > Hi Simon, > >> On 18.7.2017 16:50, Simon Glass wrote: >> Hi Michal, >> >>> On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote: >>> Hi Simon, >>> >>>> On 18.7.2017 16:01, Simon Glass wrote: >>>> Hi Michal, >>>> >>>>> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: >>>>> From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com >>>>> >>>>> Make reserve_mmu a weak so that it provides an option >>>>> to customize this routine as per platform need >>>> >>>> Why do you need this? Can we instead have the generic code do the >>>> right thing? Or can we use reserve_arch() to handle this? >>> >>> reserve_mmu is called just for ARM. >> >> What arch are you using? > > arm64 - a53s > >> >>> What we need to do is support configuration where we have small memory >>> OCM and we need to put mmu table to different location (TCM) because it >>> is simply big and it can't be placed where it is placed now. >> >> What is TCM? Is this the internal SRAM? > > It is internal sram which is used mostly by R5s in the system but a53 > has also access to it. > >> >> I don't understand 'simply big'. Are you saying it is too big to go >> into main memory? > > These configuration can't use DDR. One of that configuration which we > are using is DDR memory test. It means you run from internal sram (256kB > OCM + 256k TCM). > Another configuration is for loading stuff to EMMC on different boards. > It means you don't need to setup DDR for generic emmc programming. > > All these configurations are using console over DCC - arm jtag uart. > >> >>> >>> Based on looking at code the key question is if we can call reserve_mmu >>> at that time when reserve_arch is called now. >>> On zynqmp I can't see any issue to allocate tlb on the stack and call it >>> from it. The question is if this is valid for all arms. >>> >>> This is just a small hack I have created to move it to stack. >>> >>> diff --git a/common/board_f.c b/common/board_f.c >>> index 88e20e0168b2..32386c957962 100644 >>> --- a/common/board_f.c >>> +++ b/common/board_f.c >>> @@ -433,13 +433,13 @@ __weak int reserve_mmu(void) >>> { >>> /* reserve TLB table */ >>> gd->arch.tlb_size = PGTABLE_SIZE; >>> - gd->relocaddr -= gd->arch.tlb_size; >>> + gd->start_addr_sp -= gd->arch.tlb_size; >>> >>> /* round down to next 64 kB limit */ >>> - gd->relocaddr &= ~(0x10000 - 1); >>> + gd->start_addr_sp &= ~(0x10000 - 1); >>> >>> - gd->arch.tlb_addr = gd->relocaddr; >>> - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >>> + gd->arch.tlb_addr = gd->start_addr_sp; >>> + printf("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >>> gd->arch.tlb_addr + gd->arch.tlb_size); >>> >>> #ifdef CONFIG_SYS_MEM_RESERVE_SECURE >>> @@ -837,7 +837,7 @@ static int initf_dm(void) >>> /* Architecture-specific memory reservation */ >>> __weak int reserve_arch(void) >>> { >>> - return 0; >>> + return reserve_mmu(); >>> } >>> >>> __weak int arch_cpu_init_dm(void) >>> @@ -998,10 +998,6 @@ static init_fnc_t init_sequence_f[] = { >>> reserve_pram, >>> #endif >>> reserve_round_4k, >>> -#if !(defined(CONFIG_SYS_ICACHE_OFF) && >>> defined(CONFIG_SYS_DCACHE_OFF)) && \ >>> - defined(CONFIG_ARM) >>> - reserve_mmu, >>> -#endif >>> #ifdef CONFIG_DM_VIDEO >>> reserve_video, >>> #else >>> >>> For us we can't just rewrite tlb addresses as we want to do because we >>> can't allow reserve_mmu to allocate 64kB alied PGTABLE_SIZE in >>> relocation structure. >> >> Why not? > > Because we need to fit to 256kB of memory also with relocation and also > space for data. And IIRC MMU table size is 64kB. > Another option could be to disable relocation. > Michal,
It makes sense on emulators because they runs thousands times slower.
York
> On Jul 19, 2017, at 16:25, Michal Simek michal.simek@xilinx.com wrote: > >> On 19.7.2017 04:18, York Sun wrote: >> On 07/18/2017 10:59 PM, Michal Simek wrote: >> Hi Simon, >> >>> On 18.7.2017 16:50, Simon Glass wrote: >>> Hi Michal, >>> >>>> On 18 July 2017 at 07:23, Michal Simek michal.simek@xilinx.com wrote: >>>> Hi Simon, >>>> >>>>> On 18.7.2017 16:01, Simon Glass wrote: >>>>> Hi Michal, >>>>> >>>>>> On 13 July 2017 at 06:50, Michal Simek michal.simek@xilinx.com wrote: >>>>>> From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com >>>>>> >>>>>> Make reserve_mmu a weak so that it provides an option >>>>>> to customize this routine as per platform need >>>>> >>>>> Why do you need this? Can we instead have the generic code do the >>>>> right thing? Or can we use reserve_arch() to handle this? >>>> >>>> reserve_mmu is called just for ARM. >>> >>> What arch are you using? >> >> arm64 - a53s >> >>> >>>> What we need to do is support configuration where we have small memory >>>> OCM and we need to put mmu table to different location (TCM) because it >>>> is simply big and it can't be placed where it is placed now. >>> >>> What is TCM? Is this the internal SRAM? >> >> It is internal sram which is used mostly by R5s in the system but a53 >> has also access to it. >> >>> >>> I don't understand 'simply big'. Are you saying it is too big to go >>> into main memory? >> >> These configuration can't use DDR. One of that configuration which we >> are using is DDR memory test. It means you run from internal sram (256kB >> OCM + 256k TCM). >> Another configuration is for loading stuff to EMMC on different boards. >> It means you don't need to setup DDR for generic emmc programming. >> >> All these configurations are using console over DCC - arm jtag uart. >> >>> >>>> >>>> Based on looking at code the key question is if we can call reserve_mmu >>>> at that time when reserve_arch is called now. >>>> On zynqmp I can't see any issue to allocate tlb on the stack and call it >>>> from it. The question is if this is valid for all arms. >>>> >>>> This is just a small hack I have created to move it to stack. >>>> >>>> diff --git a/common/board_f.c b/common/board_f.c >>>> index 88e20e0168b2..32386c957962 100644 >>>> --- a/common/board_f.c >>>> +++ b/common/board_f.c >>>> @@ -433,13 +433,13 @@ __weak int reserve_mmu(void) >>>> { >>>> /* reserve TLB table */ >>>> gd->arch.tlb_size = PGTABLE_SIZE; >>>> - gd->relocaddr -= gd->arch.tlb_size; >>>> + gd->start_addr_sp -= gd->arch.tlb_size; >>>> >>>> /* round down to next 64 kB limit */ >>>> - gd->relocaddr &= ~(0x10000 - 1); >>>> + gd->start_addr_sp &= ~(0x10000 - 1); >>>> >>>> - gd->arch.tlb_addr = gd->relocaddr; >>>> - debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >>>> + gd->arch.tlb_addr = gd->start_addr_sp; >>>> + printf("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, >>>> gd->arch.tlb_addr + gd->arch.tlb_size); >>>> >>>> #ifdef CONFIG_SYS_MEM_RESERVE_SECURE >>>> @@ -837,7 +837,7 @@ static int initf_dm(void) >>>> /* Architecture-specific memory reservation */ >>>> __weak int reserve_arch(void) >>>> { >>>> - return 0; >>>> + return reserve_mmu(); >>>> } >>>> >>>> __weak int arch_cpu_init_dm(void) >>>> @@ -998,10 +998,6 @@ static init_fnc_t init_sequence_f[] = { >>>> reserve_pram, >>>> #endif >>>> reserve_round_4k, >>>> -#if !(defined(CONFIG_SYS_ICACHE_OFF) && >>>> defined(CONFIG_SYS_DCACHE_OFF)) && \ >>>> - defined(CONFIG_ARM) >>>> - reserve_mmu, >>>> -#endif >>>> #ifdef CONFIG_DM_VIDEO >>>> reserve_video, >>>> #else >>>> >>>> For us we can't just rewrite tlb addresses as we want to do because we >>>> can't allow reserve_mmu to allocate 64kB alied PGTABLE_SIZE in >>>> relocation structure. >>> >>> Why not? >> >> Because we need to fit to 256kB of memory also with relocation and also >> space for data. And IIRC MMU table size is 64kB. >> Another option could be to disable relocation. >> > Michal, > > For your reference, we use two stage MMU setup for FSL ARMv8 SoCs. We > setup an early MMU in arch_cpu_init() so we can enable d-cache very > early to speed up execution.
Agree but depends on emulators :-).
M
Hi Michal,
On 18 July 2017 at 07:59, Michal Simek michal.simek@xilinx.com wrote:
Hi Simon,
Hi Michal,
Hi Simon,
Hi Michal,
arm64 - a53s
OK I see.
defined(CONFIG_ARM)
reserve_mmu,
Why not?
I don't have a better option for this case unfortunately. I did send a board uclass series a while back which could have handled this, but for now I think what you have is reasonable.
Hi Simon and Tom,
On 19.7.2017 11:05, Simon Glass wrote:
Hi Michal,
Hi Simon,
Hi Michal,
Hi Simon,
Hi Michal,
arm64 - a53s
OK I see.
defined(CONFIG_ARM)
reserve_mmu,
Why not?
Simon: thanks.
Tom: Any comment or do you know better way how to support this?
Thanks, Michal
Michal Simek
York Sun
