[U-Boot] [PATCH 00/14] Enable Stratix10 SoC support
This patch series are enabling support for Stratix 10 SoC
Chin Liang See (14): arm: socfpga: stratix10: Add base address map for Statix10 SoC arm: dts: Add dts for Stratix10 SoC arm: socfpga: stratix10: Add Clock Manager driver for Stratix10 SoC arm: socfpga: stratix10: Add Reset Manager driver for Stratix10 SoC arm: socfpga: stratix10: Add pinmux support for Stratix10 SoC arm: socfpga: stratix10: Add misc support for Stratix10 SoC arm: socfpga: stratix10: Add mailbox support for Stratix10 SoC arm: socfpga: stratix10: Add MMU support for Stratix10 SoC arm: socfpga: Restructure the SPL file arm: socfpga: stratix10: Add SPL driver for Stratix10 SoC arm: socfpga: stratix10: Add timer support for Stratix10 SoC ddr: altera: stratix10: Add DDR support for Stratix10 SoC board: altera: stratix10: Add socdk board support for Stratix10 SoC arm: socfpga: stratix10: Enable Stratix10 SoC build
arch/arm/Kconfig | 8 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/socfpga_stratix10_socdk.dts | 141 ++++++++ arch/arm/mach-socfpga/Kconfig | 13 + arch/arm/mach-socfpga/Makefile | 19 +- arch/arm/mach-socfpga/clock_manager.c | 4 +- arch/arm/mach-socfpga/clock_manager_s10.c | 359 +++++++++++++++++++ arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 62 ++++ arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 + .../mach-socfpga/include/mach/clock_manager_s10.h | 202 +++++++++++ arch/arm/mach-socfpga/include/mach/firewall_s10.h | 84 +++++ arch/arm/mach-socfpga/include/mach/handoff_s10.h | 29 ++ arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 108 ++++++ arch/arm/mach-socfpga/include/mach/reset_manager.h | 2 + .../mach-socfpga/include/mach/reset_manager_s10.h | 116 +++++++ arch/arm/mach-socfpga/include/mach/sdram_s10.h | 333 ++++++++++++++++++ .../arm/mach-socfpga/include/mach/system_manager.h | 5 +- .../mach-socfpga/include/mach/system_manager_s10.h | 169 +++++++++ arch/arm/mach-socfpga/mailbox_s10.c | 239 +++++++++++++ arch/arm/mach-socfpga/misc.c | 4 + arch/arm/mach-socfpga/misc_s10.c | 165 +++++++++ arch/arm/mach-socfpga/mmu-arm64_s10.c | 71 ++++ arch/arm/mach-socfpga/reset_manager.c | 5 + arch/arm/mach-socfpga/reset_manager_s10.c | 140 ++++++++ arch/arm/mach-socfpga/spl_a10.c | 105 ++++++ arch/arm/mach-socfpga/{spl.c => spl_gen5.c} | 46 --- arch/arm/mach-socfpga/spl_s10.c | 138 ++++++++ arch/arm/mach-socfpga/system_manager_s10.c | 91 +++++ arch/arm/mach-socfpga/timer.c | 17 +- arch/arm/mach-socfpga/wrap_pinmux_config_s10.c | 55 +++ arch/arm/mach-socfpga/wrap_pll_config_s10.c | 46 +++ board/altera/stratix10-socdk/MAINTAINERS | 7 + board/altera/stratix10-socdk/Makefile | 7 + board/altera/stratix10-socdk/socfpga.c | 7 + configs/socfpga_stratix10_defconfig | 39 +++ drivers/ddr/altera/Makefile | 1 + drivers/ddr/altera/sdram_s10.c | 382 +++++++++++++++++++++ include/configs/socfpga_stratix10_socdk.h | 216 ++++++++++++ include/dt-bindings/reset/altr,rst-mgr-s10.h | 97 ++++++ 39 files changed, 3482 insertions(+), 55 deletions(-) create mode 100644 arch/arm/dts/socfpga_stratix10_socdk.dts create mode 100644 arch/arm/mach-socfpga/clock_manager_s10.c create mode 100644 arch/arm/mach-socfpga/include/mach/base_addr_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/firewall_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/handoff_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/mailbox_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/system_manager_s10.h create mode 100644 arch/arm/mach-socfpga/mailbox_s10.c create mode 100644 arch/arm/mach-socfpga/misc_s10.c create mode 100644 arch/arm/mach-socfpga/mmu-arm64_s10.c create mode 100644 arch/arm/mach-socfpga/reset_manager_s10.c create mode 100644 arch/arm/mach-socfpga/spl_a10.c rename arch/arm/mach-socfpga/{spl.c => spl_gen5.c} (83%) create mode 100644 arch/arm/mach-socfpga/spl_s10.c create mode 100644 arch/arm/mach-socfpga/system_manager_s10.c create mode 100644 arch/arm/mach-socfpga/wrap_pinmux_config_s10.c create mode 100644 arch/arm/mach-socfpga/wrap_pll_config_s10.c create mode 100644 board/altera/stratix10-socdk/MAINTAINERS create mode 100644 board/altera/stratix10-socdk/Makefile create mode 100644 board/altera/stratix10-socdk/socfpga.c create mode 100644 configs/socfpga_stratix10_defconfig create mode 100644 drivers/ddr/altera/sdram_s10.c create mode 100644 include/configs/socfpga_stratix10_socdk.h create mode 100644 include/dt-bindings/reset/altr,rst-mgr-s10.h
-- 2.2.2
Add the base address map for Statix10 SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 58 ++++++++++++++++++++++ 1 file changed, 58 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/base_addr_s10.h
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h new file mode 100644 index 0000000..feb1881 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_S10_BASE_HARDWARE_H_ +#define _SOCFPGA_S10_BASE_HARDWARE_H_ + +#define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 +#define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 +#define SOCFPGA_SDR_ADDRESS 0xf8011000 +#define SOCFPGA_SMMU_ADDRESS 0xfa000000 +#define SOCFPGA_EMAC0_ADDRESS 0xff800000 +#define SOCFPGA_EMAC1_ADDRESS 0xff802000 +#define SOCFPGA_EMAC2_ADDRESS 0xff804000 +#define SOCFPGA_SDMMC_ADDRESS 0xff808000 +#define SOCFPGA_QSPIREGS_ADDRESS 0xff8d2000 +#define SOCFPGA_QSPIDATA_ADDRESS 0xff900000 +#define SOCFPGA_MAILBOX_ADDRESS 0xffA30000 +#define SOCFPGA_USB0_ADDRESS 0xffb00000 +#define SOCFPGA_USB1_ADDRESS 0xffb40000 +#define SOCFPGA_NANDREGS_ADDRESS 0xffb80000 +#define SOCFPGA_NANDDATA_ADDRESS 0xffb90000 +#define SOCFPGA_UART0_ADDRESS 0xffc02000 +#define SOCFPGA_UART1_ADDRESS 0xffc02100 +#define SOCFPGA_I2C0_ADDRESS 0xffc02800 +#define SOCFPGA_I2C1_ADDRESS 0xffc02900 +#define SOCFPGA_I2C2_ADDRESS 0xffc02a00 +#define SOCFPGA_I2C3_ADDRESS 0xffc02b00 +#define SOCFPGA_I2C4_ADDRESS 0xffc02c00 +#define SOCFPGA_SPTIMER0_ADDRESS 0xffc03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0xffc03100 +#define SOCFPGA_GPIO0_ADDRESS 0xffc03200 +#define SOCFPGA_GPIO1_ADDRESS 0xffc03300 +#define SOCFPGA_SYSTIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_SYSTIMER1_ADDRESS 0xffd00100 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00200 +#define SOCFPGA_L4WD1_ADDRESS 0xffd00300 +#define SOCFPGA_L4WD2_ADDRESS 0xffd00400 +#define SOCFPGA_L4WD3_ADDRESS 0xffd00500 +#define SOCFPGA_GTIMER_SEC_ADDRESS 0xffd01000 +#define SOCFPGA_GTIMER_NSEC_ADDRESS 0xffd02000 +#define SOCFPGA_CLKMGR_ADDRESS 0xffd10000 +#define SOCFPGA_RSTMGR_ADDRESS 0xffd11000 +#define SOCFPGA_SYSMGR_ADDRESS 0xffd12000 +#define SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS 0xffd13000 +#define SOCFPGA_DMANONSECURE_ADDRESS 0xffda0000 +#define SOCFPGA_DMASECURE_ADDRESS 0xffda1000 +#define SOCFPGA_SPIS0_ADDRESS 0xffda2000 +#define SOCFPGA_SPIS1_ADDRESS 0xffda3000 +#define SOCFPGA_SPIM0_ADDRESS 0xffda4000 +#define SOCFPGA_SPIM1_ADDRESS 0xffda5000 +#define SOCFPGA_OCRAM_ADDRESS 0xffe00000 +#define GICD_BASE 0xfffc1000 +#define GICC_BASE 0xfffc2000 + +#endif /* _SOCFPGA_S10_BASE_HARDWARE_H_ */
Add only the stuff which is not obtainable from DT please.
- Copyright (C) 2016-2017 Intel Corporation <www.intel.com>
- SPDX-License-Identifier: GPL-2.0
Sure, let me remove the SDMMC, EMAC and QSPI since they are extracted from DT today
Thanks Chin Liang
arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 58 ++++++++++++++++++++++ 1 file changed, 58 insertions(+) create mode 100644 arch/arm/mach- socfpga/include/mach/base_addr_s10.h
Device tree for Stratix10 SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/socfpga_stratix10_socdk.dts | 141 +++++++++++++++++++++++++++++++ 2 files changed, 143 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/socfpga_stratix10_socdk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fee4680..4cf5fd0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -171,7 +171,8 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_cyclone5_sockit.dtb \ socfpga_cyclone5_socrates.dtb \ socfpga_cyclone5_sr1500.dtb \ - socfpga_cyclone5_vining_fpga.dtb + socfpga_cyclone5_vining_fpga.dtb \ + socfpga_stratix10_socdk.dtb
dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dra72-evm-revc.dtb dra71-evm.dtb dra76-evm.dtb diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts new file mode 100644 index 0000000..484c630 --- /dev/null +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -0,0 +1,141 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +/dts-v1/; +#include "skeleton.dtsi" +#include <dt-bindings/reset/altr,rst-mgr-s10.h> + +/ { + model = "Intel SOCFPGA Stratix 10 SoC Development Kit"; + compatible = "altr,socfpga-stratix10", "altr,socfpga"; + + #address-cells = <1>; + #size-cells = <1>; + + chosen { + bootargs = "console=ttyS0,115200"; + }; + + aliases { + ethernet0 = &gmac0; + spi0 = &qspi; + }; + + memory { + name = "memory"; + device_type = "memory"; + reg = <0x0 0x80000000>; /* 2GB */ + }; + + regulator_3_3v: 3-3-v-regulator { + compatible = "regulator-fixed"; + regulator-name = "3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + ranges; + u-boot,dm-pre-reloc; + + rst: rstmgr@ffd11000 { + #reset-cells = <1>; + compatible = "altr,rst-mgr"; + reg = <0xffd11000 0x100>; + altr,modrst-offset = <0x20>; + }; + + gmac0: ethernet@ff800000 { + compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + reg = <0xff800000 0x2000>; + interrupts = <0 90 4>; + interrupt-names = "macirq"; + mac-address = [00 00 00 00 00 00]; + resets = <&rst EMAC0_RESET>; + reset-names = "stmmaceth"; + phy-mode = "rgmii"; + phy-addr = <0xffffffff>; /* probe for phy addr */ + max-speed = <1000>; + txd0-skew-ps = <0>; /* -420ps */ + txd1-skew-ps = <0>; /* -420ps */ + txd2-skew-ps = <0>; /* -420ps */ + txd3-skew-ps = <0>; /* -420ps */ + rxd0-skew-ps = <420>; /* 0ps */ + rxd1-skew-ps = <420>; /* 0ps */ + rxd2-skew-ps = <420>; /* 0ps */ + rxd3-skew-ps = <420>; /* 0ps */ + txen-skew-ps = <0>; /* -420ps */ + txc-skew-ps = <1860>; /* 960ps */ + rxdv-skew-ps = <420>; /* 0ps */ + rxc-skew-ps = <1680>; /* 780ps */ + status = "okay"; + }; + + mmc0: dwmmc0@0xff808000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 96 4>; + num-slots = <1>; + broken-cd; + bus-width = <4>; + fifo-depth = <0x400>; + cap-mmc-highspeed; + cap-sd-highspeed; + drvsel = <3>; + smplsel = <0>; + status = "okay"; + u-boot,dm-pre-reloc; + vmmc-supply = <®ulator_3_3v>; + vqmmc-supply = <®ulator_3_3v>; + }; + + uart0: serial0@ffc02000 { + compatible = "snps,dw-apb-uart"; + reg = <0xffc02000 0x1000>; + interrupts = <0 108 4>; + reg-shift = <2>; + reg-io-width = <4>; + status = "okay"; + }; + + qspi: spi@ff8d2000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cadence,qspi"; + reg = <0xff8d2000 0x100>, + <0xff900000 0x100000>; + interrupts = <0 98 4>; + sram-size = <1024>; + bus-num = <0>; + spi-max-frequency = <50000000>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + status = "okay"; + u-boot,dm-pre-reloc; + + flash0: n25q1024a@0 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "stmicro,n25q1024a"; + reg = <0>; /* chip select */ + spi-max-frequency = <50000000>; + page-size = <256>; + block-size = <16>; /* 2^16, 64KB */ + tshsl-ns = <50>; + tsd2d-ns = <50>; + tchsh-ns = <4>; + tslch-ns = <4>; + }; + }; + }; +};
You don't add the patch for this include file until patch 4/14, which means the build will fail until patch 4 is applied. You need to move this patch after 4/14.
#size-cells = <1>;
chosen {
aliases {
ethernet0 = &gmac0;
spi0 = &qspi;
memory {
name = "memory";
soc {
#size-cells = <1>;
ranges;
#reset-cells = <1>;
phy-mode = "rgmii";
max-speed = <1000>;
These are PHY properties, which should be in a separate PHY node.
Dinh
Yes, good catch. Let shuffle this
Let me check on the PHY driver
Chin Liang
Dinh
#size-cells = <1>;
chosen {
aliases {
ethernet0 = &gmac0;
spi0 = &qspi;
memory {
name = "memory";
soc {
#size-cells = <1>;
ranges;
#reset-cells = <1>;
Where are the cpu nodes?
Dinh
yes, need to be added
CHin Liang
Dinh
Add Clock Manager driver support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 4 + arch/arm/mach-socfpga/clock_manager.c | 4 +- arch/arm/mach-socfpga/clock_manager_s10.c | 359 +++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 + .../mach-socfpga/include/mach/clock_manager_s10.h | 202 ++++++++++++ arch/arm/mach-socfpga/include/mach/handoff_s10.h | 29 ++ arch/arm/mach-socfpga/wrap_pll_config_s10.c | 46 +++ 7 files changed, 644 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_s10.c create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_s10.h create mode 100644 arch/arm/mach-socfpga/include/mach/handoff_s10.h create mode 100644 arch/arm/mach-socfpga/wrap_pll_config_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 286bfef..e5f9dd7 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -30,6 +30,10 @@ obj-y += pinmux_arria10.o obj-y += reset_manager_arria10.o endif
+ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 +obj-y += clock_manager_s10.o +obj-y += wrap_pll_config_s10.o +endif ifdef CONFIG_SPL_BUILD obj-y += spl.o ifdef CONFIG_TARGET_SOCFPGA_GEN5 diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index cb6ae03..f9450a4 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -21,7 +21,7 @@ void cm_wait_for_lock(u32 mask) do { #if defined(CONFIG_TARGET_SOCFPGA_GEN5) inter_val = readl(&clock_manager_base->inter) & mask; -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#else inter_val = readl(&clock_manager_base->stat) & mask; #endif /* Wait for stable lock */ @@ -52,7 +52,7 @@ int set_cpu_clk_info(void)
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) gd->bd->bi_ddr_freq = cm_get_sdram_clk_hz() / 1000000; -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#else gd->bd->bi_ddr_freq = 0; #endif
diff --git a/arch/arm/mach-socfpga/clock_manager_s10.c b/arch/arm/mach-socfpga/clock_manager_s10.c new file mode 100644 index 0000000..a9f9b07 --- /dev/null +++ b/arch/arm/mach-socfpga/clock_manager_s10.c @@ -0,0 +1,359 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/handoff_s10.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_clock_manager *clock_manager_base = + (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS; + +/* + * function to write the bypass register which requires a poll of the + * busy bit + */ +static void cm_write_bypass_mainpll(uint32_t val) +{ + writel(val, &clock_manager_base->main_pll.bypass); + cm_wait_for_fsm(); +} +static void cm_write_bypass_perpll(uint32_t val) +{ + writel(val, &clock_manager_base->per_pll.bypass); + cm_wait_for_fsm(); +} + +/* function to write the ctrl register which requires a poll of the busy bit */ +static void cm_write_ctrl(uint32_t val) +{ + writel(val, &clock_manager_base->ctrl); + cm_wait_for_fsm(); +} + +/* + * Setup clocks while making no assumptions about previous state of the clocks. + * + */ +void cm_basic_init(const struct cm_config * const cfg) +{ + uint32_t mdiv, refclkdiv, mscnt, hscnt, vcocalib; + + if (cfg == 0) + return; + + /* Put all plls in bypass */ + cm_write_bypass_mainpll(CLKMGR_BYPASS_MAINPLL_ALL); + cm_write_bypass_perpll(CLKMGR_BYPASS_PERPLL_ALL); + + /* setup main PLL dividers */ + /* calculate the vcocalib value */ + mdiv = (cfg->main_pll_fdbck >> CLKMGR_FDBCK_MDIV_OFFSET) & + CLKMGR_FDBCK_MDIV_MASK; + refclkdiv = (cfg->main_pll_pllglob >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & + CLKMGR_PLLGLOB_REFCLKDIV_MASK; + mscnt = 200 / (6 + mdiv) / refclkdiv; + hscnt = (mdiv + 6) * mscnt / refclkdiv - 9; + vcocalib = (hscnt & CLKMGR_VCOCALIB_HSCNT_MASK) | + ((mscnt & CLKMGR_VCOCALIB_MSCNT_MASK) << + CLKMGR_VCOCALIB_MSCNT_OFFSET); + + writel((cfg->main_pll_pllglob & ~CLKMGR_PLLGLOB_PD_MASK & + ~CLKMGR_PLLGLOB_RST_MASK), + &clock_manager_base->main_pll.pllglob); + writel(cfg->main_pll_fdbck, &clock_manager_base->main_pll.fdbck); + writel(vcocalib, &clock_manager_base->main_pll.vcocalib); + writel(cfg->main_pll_pllc0, &clock_manager_base->main_pll.pllc0); + writel(cfg->main_pll_pllc1, &clock_manager_base->main_pll.pllc1); + writel(cfg->main_pll_nocdiv, &clock_manager_base->main_pll.nocdiv); + + /* setup peripheral PLL dividers */ + /* calculate the vcocalib value */ + mdiv = (cfg->per_pll_fdbck >> CLKMGR_FDBCK_MDIV_OFFSET) & + CLKMGR_FDBCK_MDIV_MASK; + refclkdiv = (cfg->per_pll_pllglob >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & + CLKMGR_PLLGLOB_REFCLKDIV_MASK; + mscnt = 200 / (6 + mdiv) / refclkdiv; + hscnt = (mdiv + 6) * mscnt / refclkdiv - 9; + vcocalib = (hscnt & CLKMGR_VCOCALIB_HSCNT_MASK) | + ((mscnt & CLKMGR_VCOCALIB_MSCNT_MASK) << + CLKMGR_VCOCALIB_MSCNT_OFFSET); + + writel((cfg->per_pll_pllglob & ~CLKMGR_PLLGLOB_PD_MASK & + ~CLKMGR_PLLGLOB_RST_MASK), + &clock_manager_base->per_pll.pllglob); + writel(cfg->per_pll_fdbck, &clock_manager_base->per_pll.fdbck); + writel(vcocalib, &clock_manager_base->per_pll.vcocalib); + writel(cfg->per_pll_pllc0, &clock_manager_base->per_pll.pllc0); + writel(cfg->per_pll_pllc1, &clock_manager_base->per_pll.pllc1); + writel(cfg->per_pll_emacctl, &clock_manager_base->per_pll.emacctl); + writel(cfg->per_pll_gpiodiv, &clock_manager_base->per_pll.gpiodiv); + + /* Take both PLL out of reset and power up */ + setbits_le32(&clock_manager_base->main_pll.pllglob, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + setbits_le32(&clock_manager_base->per_pll.pllglob, + CLKMGR_PLLGLOB_PD_MASK | CLKMGR_PLLGLOB_RST_MASK); + +#define LOCKED_MASK \ + (CLKMGR_STAT_MAINPLL_LOCKED | \ + CLKMGR_STAT_PERPLL_LOCKED) + + cm_wait_for_lock(LOCKED_MASK); + + /* + * Dividers for C2 to C9 only init after PLLs are lock. We will a large + * dividers value then final value as requested by hardware behaviour + */ + writel(0xff, &clock_manager_base->main_pll.mpuclk); + writel(0xff, &clock_manager_base->main_pll.nocclk); + writel(0xff, &clock_manager_base->main_pll.cntr2clk); + writel(0xff, &clock_manager_base->main_pll.cntr3clk); + writel(0xff, &clock_manager_base->main_pll.cntr4clk); + writel(0xff, &clock_manager_base->main_pll.cntr5clk); + writel(0xff, &clock_manager_base->main_pll.cntr6clk); + writel(0xff, &clock_manager_base->main_pll.cntr7clk); + writel(0xff, &clock_manager_base->main_pll.cntr8clk); + writel(0xff, &clock_manager_base->main_pll.cntr9clk); + writel(0xff, &clock_manager_base->per_pll.cntr2clk); + writel(0xff, &clock_manager_base->per_pll.cntr3clk); + writel(0xff, &clock_manager_base->per_pll.cntr4clk); + writel(0xff, &clock_manager_base->per_pll.cntr5clk); + writel(0xff, &clock_manager_base->per_pll.cntr6clk); + writel(0xff, &clock_manager_base->per_pll.cntr7clk); + writel(0xff, &clock_manager_base->per_pll.cntr8clk); + writel(0xff, &clock_manager_base->per_pll.cntr9clk); + + writel(cfg->main_pll_mpuclk, &clock_manager_base->main_pll.mpuclk); + writel(cfg->main_pll_nocclk, &clock_manager_base->main_pll.nocclk); + writel(cfg->main_pll_cntr2clk, &clock_manager_base->main_pll.cntr2clk); + writel(cfg->main_pll_cntr3clk, &clock_manager_base->main_pll.cntr3clk); + writel(cfg->main_pll_cntr4clk, &clock_manager_base->main_pll.cntr4clk); + writel(cfg->main_pll_cntr5clk, &clock_manager_base->main_pll.cntr5clk); + writel(cfg->main_pll_cntr6clk, &clock_manager_base->main_pll.cntr6clk); + writel(cfg->main_pll_cntr7clk, &clock_manager_base->main_pll.cntr7clk); + writel(cfg->main_pll_cntr8clk, &clock_manager_base->main_pll.cntr8clk); + writel(cfg->main_pll_cntr9clk, &clock_manager_base->main_pll.cntr9clk); + writel(cfg->per_pll_cntr2clk, &clock_manager_base->per_pll.cntr2clk); + writel(cfg->per_pll_cntr3clk, &clock_manager_base->per_pll.cntr3clk); + writel(cfg->per_pll_cntr4clk, &clock_manager_base->per_pll.cntr4clk); + writel(cfg->per_pll_cntr5clk, &clock_manager_base->per_pll.cntr5clk); + writel(cfg->per_pll_cntr6clk, &clock_manager_base->per_pll.cntr6clk); + writel(cfg->per_pll_cntr7clk, &clock_manager_base->per_pll.cntr7clk); + writel(cfg->per_pll_cntr8clk, &clock_manager_base->per_pll.cntr8clk); + writel(cfg->per_pll_cntr9clk, &clock_manager_base->per_pll.cntr9clk); + + /* Take all PLLs out of bypass */ + cm_write_bypass_mainpll(0); + cm_write_bypass_perpll(0); + + /* clear safe mode / out of boot mode */ + cm_write_ctrl(readl(&clock_manager_base->ctrl) + & ~(CLKMGR_CTRL_SAFEMODE)); + + /* Now ungate non-hw-managed clocks */ + writel(~0, &clock_manager_base->main_pll.en); + writel(~0, &clock_manager_base->per_pll.en); + + /* Clear the loss of lock bits (write 1 to clear) */ + writel(CLKMGR_INTER_PERPLLLOST_MASK | CLKMGR_INTER_MAINPLLLOST_MASK, + &clock_manager_base->intrclr); +} + +static unsigned long cm_get_main_vco_clk_hz(void) +{ + unsigned long fref, refdiv, mdiv, reg, vco; + + reg = readl(&clock_manager_base->main_pll.pllglob); + + /* get the fref */ + fref = (reg >> CLKMGR_PLLGLOB_VCO_PSRC_OFFSET) & + CLKMGR_PLLGLOB_VCO_PSRC_MASK; + switch (fref) { + case CLKMGR_VCO_PSRC_EOSC1: + fref = cm_get_osc_clk_hz(0); + break; + case CLKMGR_VCO_PSRC_INTOSC: + fref = cm_get_intosc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_F2S: + fref = cm_get_fpga_clk_hz(); + break; + } + + /* get the refdiv */ + refdiv = (reg >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & + CLKMGR_PLLGLOB_REFCLKDIV_MASK; + + /* get the mdiv */ + reg = readl(&clock_manager_base->main_pll.fdbck); + mdiv = (reg >> CLKMGR_FDBCK_MDIV_OFFSET) & CLKMGR_FDBCK_MDIV_MASK; + + vco = fref / refdiv; + vco = vco * (6 + mdiv); + return vco; +} + +static unsigned long cm_get_per_vco_clk_hz(void) +{ + unsigned long fref, refdiv, mdiv, reg, vco; + + reg = readl(&clock_manager_base->per_pll.pllglob); + + /* get the fref */ + fref = (reg >> CLKMGR_PLLGLOB_VCO_PSRC_OFFSET) & + CLKMGR_PLLGLOB_VCO_PSRC_MASK; + switch (fref) { + case CLKMGR_VCO_PSRC_EOSC1: + fref = cm_get_osc_clk_hz(0); + break; + case CLKMGR_VCO_PSRC_INTOSC: + fref = cm_get_intosc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_F2S: + fref = cm_get_fpga_clk_hz(); + break; + } + + /* get the refdiv */ + refdiv = (reg >> CLKMGR_PLLGLOB_REFCLKDIV_OFFSET) & + CLKMGR_PLLGLOB_REFCLKDIV_MASK; + + /* get the mdiv */ + reg = readl(&clock_manager_base->per_pll.fdbck); + mdiv = (reg >> CLKMGR_FDBCK_MDIV_OFFSET) & CLKMGR_FDBCK_MDIV_MASK; + + vco = fref / refdiv; + vco = vco * (6 + mdiv); + return vco; +} + +unsigned long cm_get_mpu_clk_hz(void) +{ + unsigned long clock = readl(&clock_manager_base->main_pll.mpuclk); + clock = (clock >> CLKMGR_CLKSRC_OFFSET) & CLKMGR_CLKSRC_MASK; + + switch (clock) { + case CLKMGR_CLKSRC_MAIN: + clock = cm_get_main_vco_clk_hz(); + clock /= (readl(&clock_manager_base->main_pll.pllc0) & + CLKMGR_PLLC0_DIV_MASK); + break; + + case CLKMGR_CLKSRC_PER: + clock = cm_get_per_vco_clk_hz(); + clock /= (readl(&clock_manager_base->per_pll.pllc0) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(0); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + } + + clock /= 1 + (readl(&clock_manager_base->main_pll.mpuclk) & + CLKMGR_CLKCNT_MSK); + return clock; +} + +unsigned int cm_get_l3_main_clk_hz(void) +{ + uint32_t clock = readl(&clock_manager_base->main_pll.nocclk); + clock = (clock >> CLKMGR_CLKSRC_OFFSET) & CLKMGR_CLKSRC_MASK; + + switch (clock) { + case CLKMGR_CLKSRC_MAIN: + clock = cm_get_main_vco_clk_hz(); + clock /= (readl(&clock_manager_base->main_pll.pllc1) & + CLKMGR_PLLC0_DIV_MASK); + break; + + case CLKMGR_CLKSRC_PER: + clock = cm_get_per_vco_clk_hz(); + clock /= (readl(&clock_manager_base->per_pll.pllc1) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(0); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + } + + clock /= 1 + (readl(&clock_manager_base->main_pll.nocclk) & + CLKMGR_CLKCNT_MSK); + return clock; +} + +unsigned int cm_get_mmc_controller_clk_hz(void) +{ + uint32_t clock = readl(&clock_manager_base->per_pll.cntr6clk); + clock = (clock >> CLKMGR_CLKSRC_OFFSET) & CLKMGR_CLKSRC_MASK; + + switch (clock) { + case CLKMGR_CLKSRC_MAIN: + clock = cm_get_l3_main_clk_hz(); + clock /= 1 + (readl(&clock_manager_base->main_pll.cntr6clk) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_PER: + clock = cm_get_l3_main_clk_hz(); + clock /= 1 + (readl(&clock_manager_base->per_pll.cntr6clk) & + CLKMGR_CLKCNT_MSK); + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(0); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + } + return clock/4; +} + +unsigned int cm_get_l4_sp_clk_hz(void) +{ + uint32_t clock = cm_get_l3_main_clk_hz(); + + clock /= (1 << ((readl(&clock_manager_base->main_pll.nocdiv) >> + CLKMGR_NOCDIV_L4SPCLK_OFFSET) & CLKMGR_CLKCNT_MSK)); + return clock; +} + +void cm_print_clock_quick_summary(void) +{ + printf("MPU %d kHz\n", (u32)(cm_get_mpu_clk_hz() / 1000)); + printf("L3 main %d kHz\n", cm_get_l3_main_clk_hz() / 1000); + printf("Main VCO %d kHz\n", (u32)(cm_get_main_vco_clk_hz() / 1000)); + printf("Per VCO %d kHz\n", (u32)(cm_get_per_vco_clk_hz() / 1000)); + printf("EOSC1 %d kHz\n", cm_get_osc_clk_hz(0) / 1000); + printf("HPS MMC %d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); + printf("UART %d kHz\n", cm_get_l4_sp_clk_hz() / 1000); +} diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 4c6b1f8..ddf814f 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -17,6 +17,8 @@ void cm_print_clock_quick_summary(void); #include <asm/arch/clock_manager_gen5.h> #elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) #include <asm/arch/clock_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) +#include <asm/arch/clock_manager_s10.h> #endif
#endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h new file mode 100644 index 0000000..c99ad97 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h @@ -0,0 +1,202 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _CLOCK_MANAGER_S10_ +#define _CLOCK_MANAGER_S10_ + +/* Clock speed accessors */ +unsigned long cm_get_mpu_clk_hz(void); +unsigned long cm_get_sdram_clk_hz(void); +unsigned int cm_get_l4_sp_clk_hz(void); +unsigned int cm_get_mmc_controller_clk_hz(void); +unsigned int cm_get_qspi_controller_clk_hz(void); +unsigned int cm_get_spi_controller_clk_hz(void); +const unsigned int cm_get_osc_clk_hz(const int osc); +const unsigned int cm_get_f2s_per_ref_clk_hz(void); +const unsigned int cm_get_f2s_sdr_ref_clk_hz(void); +const unsigned int cm_get_intosc_clk_hz(void); +const unsigned int cm_get_fpga_clk_hz(void); + +/* Clock configuration accessors */ +const struct cm_config * const cm_get_default_config(void); + +struct cm_config { + /* main group */ + uint32_t main_pll_mpuclk; + uint32_t main_pll_nocclk; + uint32_t main_pll_cntr2clk; + uint32_t main_pll_cntr3clk; + uint32_t main_pll_cntr4clk; + uint32_t main_pll_cntr5clk; + uint32_t main_pll_cntr6clk; + uint32_t main_pll_cntr7clk; + uint32_t main_pll_cntr8clk; + uint32_t main_pll_cntr9clk; + uint32_t main_pll_nocdiv; + uint32_t main_pll_pllglob; + uint32_t main_pll_fdbck; + uint32_t main_pll_pllc0; + uint32_t main_pll_pllc1; + uint32_t spare; + + /* peripheral group */ + uint32_t per_pll_cntr2clk; + uint32_t per_pll_cntr3clk; + uint32_t per_pll_cntr4clk; + uint32_t per_pll_cntr5clk; + uint32_t per_pll_cntr6clk; + uint32_t per_pll_cntr7clk; + uint32_t per_pll_cntr8clk; + uint32_t per_pll_cntr9clk; + uint32_t per_pll_emacctl; + uint32_t per_pll_gpiodiv; + uint32_t per_pll_pllglob; + uint32_t per_pll_fdbck; + uint32_t per_pll_pllc0; + uint32_t per_pll_pllc1; + + /* incoming clock */ + uint32_t hps_osc_clk_hz; + uint32_t fpga_clk_hz; +}; + +void cm_basic_init(const struct cm_config * const cfg); + +struct socfpga_clock_manager_main_pll { + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 mpuclk; + u32 nocclk; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 nocdiv; + u32 pllglob; + u32 fdbck; + u32 mem; + u32 memstat; + u32 pllc0; + u32 pllc1; + u32 vcocalib; + u32 _pad_0x90_0xA0[5]; +}; + +struct socfpga_clock_manager_per_pll { + u32 en; + u32 ens; + u32 enr; + u32 bypass; + u32 bypasss; + u32 bypassr; + u32 cntr2clk; + u32 cntr3clk; + u32 cntr4clk; + u32 cntr5clk; + u32 cntr6clk; + u32 cntr7clk; + u32 cntr8clk; + u32 cntr9clk; + u32 emacctl; + u32 gpiodiv; + u32 pllglob; + u32 fdbck; + u32 mem; + u32 memstat; + u32 pllc0; + u32 pllc1; + u32 vcocalib; + u32 _pad_0x100_0x124[10]; +}; + +struct socfpga_clock_manager { + u32 ctrl; + u32 stat; + u32 testioctrl; + u32 intrgen; + u32 intrmsk; + u32 intrclr; + u32 intrsts; + u32 intrstk; + u32 intrraw; + u32 _pad_0x24_0x2c[3]; + struct socfpga_clock_manager_main_pll main_pll; + struct socfpga_clock_manager_per_pll per_pll; +}; + +#define CLKMGR_CTRL_SAFEMODE (1 << 0) +#define CLKMGR_BYPASS_MAINPLL_ALL 0x00000007 +#define CLKMGR_BYPASS_PERPLL_ALL 0x0000007f + +#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000001 +#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000002 +#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000004 +#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000008 +#define CLKMGR_STAT_BUSY (1 << 0) +#define CLKMGR_STAT_MAINPLL_LOCKED (1 << 8) +#define CLKMGR_STAT_PERPLL_LOCKED (1 << 9) + +#define CLKMGR_PLLGLOB_PD_MASK 0x00000001 +#define CLKMGR_PLLGLOB_RST_MASK 0x00000002 +#define CLKMGR_PLLGLOB_VCO_PSRC_MASK 0X3 +#define CLKMGR_PLLGLOB_VCO_PSRC_OFFSET 16 +#define CLKMGR_VCO_PSRC_EOSC1 0 +#define CLKMGR_VCO_PSRC_INTOSC 1 +#define CLKMGR_VCO_PSRC_F2S 2 +#define CLKMGR_PLLGLOB_REFCLKDIV_MASK 0X3f +#define CLKMGR_PLLGLOB_REFCLKDIV_OFFSET 8 + +#define CLKMGR_CLKSRC_MASK 0x7 +#define CLKMGR_CLKSRC_OFFSET 16 +#define CLKMGR_CLKSRC_MAIN 0 +#define CLKMGR_CLKSRC_PER 1 +#define CLKMGR_CLKSRC_OSC1 2 +#define CLKMGR_CLKSRC_INTOSC 3 +#define CLKMGR_CLKSRC_FPGA 4 +#define CLKMGR_CLKCNT_MSK 0x7ff + +#define CLKMGR_FDBCK_MDIV_MASK 0xff +#define CLKMGR_FDBCK_MDIV_OFFSET 24 + +#define CLKMGR_PLLC0_DIV_MASK 0xff +#define CLKMGR_PLLC1_DIV_MASK 0xff +#define CLKMGR_PLLC0_EN_OFFSET 27 +#define CLKMGR_PLLC1_EN_OFFSET 24 + +#define CLKMGR_NOCDIV_L4MAIN_OFFSET 0 +#define CLKMGR_NOCDIV_L4MPCLK_OFFSET 8 +#define CLKMGR_NOCDIV_L4SPCLK_OFFSET 16 +#define CLKMGR_NOCDIV_CSATCLK_OFFSET 24 +#define CLKMGR_NOCDIV_CSTRACECLK_OFFSET 26 +#define CLKMGR_NOCDIV_CSPDBGCLK_OFFSET 28 + +#define CLKMGR_NOCDIV_L4SPCLK_MASK 0X3 +#define CLKMGR_NOCDIV_DIV1 0 +#define CLKMGR_NOCDIV_DIV2 1 +#define CLKMGR_NOCDIV_DIV4 2 +#define CLKMGR_NOCDIV_DIV8 3 +#define CLKMGR_CSPDBGCLK_DIV1 0 +#define CLKMGR_CSPDBGCLK_DIV4 1 + +#define CLKMGR_VCOCALIB_MSCNT_MASK 0xff +#define CLKMGR_VCOCALIB_MSCNT_OFFSET 9 +#define CLKMGR_VCOCALIB_HSCNT_MASK 0xff + +#define CLKMGR_EMACCTL_EMAC0SEL_OFFSET 26 +#define CLKMGR_EMACCTL_EMAC1SEL_OFFSET 27 +#define CLKMGR_EMACCTL_EMAC2SEL_OFFSET 28 + +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK 0x00000020 + +#endif /* _CLOCK_MANAGER_S10_ */ diff --git a/arch/arm/mach-socfpga/include/mach/handoff_s10.h b/arch/arm/mach-socfpga/include/mach/handoff_s10.h new file mode 100644 index 0000000..d4b89ac --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/handoff_s10.h @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _HANDOFF_S10_H_ +#define _HANDOFF_S10_H_ + +/* + * Offset for HW handoff from Quartus tools + */ +#define CONFIG_HANDOFF_BASE 0xFFE3F000 +#define CONFIG_HANDOFF_MUX (CONFIG_HANDOFF_BASE + 0x10) +#define CONFIG_HANDOFF_IOCTL (CONFIG_HANDOFF_BASE + 0x1A0) +#define CONFIG_HANDOFF_FPGA (CONFIG_HANDOFF_BASE + 0x330) +#define CONFIG_HANODFF_DELAY (CONFIG_HANDOFF_BASE + 0x3F0) +#define CONFIG_HANDOFF_CLOCK (CONFIG_HANDOFF_BASE + 0x580) +#define CONFIG_HANDOFF_MISC (CONFIG_HANDOFF_BASE + 0x610) +#define CONFIG_HANDOFF_MAGIC_MUX 0x504D5558 +#define CONFIG_HANDOFF_MAGIC_IOCTL 0x494F4354 +#define CONFIG_HANDOFF_MAGIC_FPGA 0x46504741 +#define CONFIG_HANDOFF_MAGIC_DELAY 0x444C4159 +#define CONFIG_HANDOFF_MAGIC_CLOCK 0x434C4B53 +#define CONFIG_HANDOFF_MAGIC_MISC 0x4D495343 +#define CONFIG_HANDOFF_OFFSET_LENGTH 0x4 +#define CONFIG_HANDOFF_OFFSET_DATA 0x10 + +#endif /* _HANDOFF_S10_H_ */ diff --git a/arch/arm/mach-socfpga/wrap_pll_config_s10.c b/arch/arm/mach-socfpga/wrap_pll_config_s10.c new file mode 100644 index 0000000..2a624d5 --- /dev/null +++ b/arch/arm/mach-socfpga/wrap_pll_config_s10.c @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/arch/clock_manager.h> +#include <asm/io.h> +#include <asm/arch/handoff_s10.h> + +const struct cm_config * const cm_get_default_config(void) +{ + struct cm_config *cm_handoff_cfg = (struct cm_config *) + (CONFIG_HANDOFF_CLOCK + CONFIG_HANDOFF_OFFSET_DATA); + u32 *conversion = (u32 *)cm_handoff_cfg; + u32 i; + + if (swab32(readl(CONFIG_HANDOFF_CLOCK)) == CONFIG_HANDOFF_MAGIC_CLOCK) { + writel(swab32(readl(CONFIG_HANDOFF_CLOCK)), + CONFIG_HANDOFF_CLOCK); + for (i = 0; i < (sizeof(*cm_handoff_cfg) / sizeof(u32)); i++) + conversion[i] = swab32(conversion[i]); + return cm_handoff_cfg; + } else if (readl(CONFIG_HANDOFF_CLOCK) == CONFIG_HANDOFF_MAGIC_CLOCK) { + return cm_handoff_cfg; + } else + return 0; +} + +const unsigned int cm_get_osc_clk_hz(const int osc) +{ + return 25000000; +} + +const unsigned int cm_get_intosc_clk_hz(void) +{ + /* theory maximum internal osc clock */ + return 460000000; +} + +const unsigned int cm_get_fpga_clk_hz(void) +{ + /* assuming 50MHz */ + return 50000000; +}
- function to write the bypass register which requires a poll of the
- busy bit
cm_wait_for_fsm();
Add a new line..
cm_wait_for_fsm();
cm_wait_for_fsm();
- Setup clocks while making no assumptions about previous state of the clocks.
Remove extra line
if (cfg == 0)
return;
Move the above comment to where vcocalib is getting calculated, or remove.
Where are these values, 200 and 6 coming from? Should they be a #define?
Same for 6 and 9 here...
Same comments as above...
Can you update this comment? I don't understand what "We will a large" means.
/* get the fref */
Useless comment...
switch (fref) {
break;
break;
break;
same..
/* get the mdiv */
same...
Why 6? Define?
return vco;
/* get the fref */
switch (fref) {
break;
break;
break;
/* get the mdiv */
return vco;
switch (clock) {
break;
CLKMGR_CLKCNT_MSK);
break;
break;
break;
break;
CLKMGR_CLKCNT_MSK);
return clock;
switch (clock) {
break;
CLKMGR_CLKCNT_MSK);
break;
break;
break;
break;
CLKMGR_CLKCNT_MSK);
return clock;
switch (clock) {
CLKMGR_CLKCNT_MSK);
break;
CLKMGR_CLKCNT_MSK);
break;
break;
break;
break;
return clock/4;
Need space between '/'.
return clock;
+struct cm_config {
/* main group */
uint32_t spare;
u32 en;
u32 ens;
u32 enr;
u32 bypass;
u32 bypasss;
u32 bypassr;
u32 mpuclk;
u32 nocclk;
u32 cntr2clk;
u32 cntr3clk;
u32 cntr4clk;
u32 cntr5clk;
u32 cntr6clk;
u32 cntr7clk;
u32 cntr8clk;
u32 cntr9clk;
u32 nocdiv;
u32 pllglob;
u32 fdbck;
u32 mem;
u32 memstat;
u32 pllc0;
u32 pllc1;
u32 vcocalib;
u32 en;
u32 ens;
u32 enr;
u32 bypass;
u32 bypasss;
u32 bypassr;
u32 cntr2clk;
u32 cntr3clk;
u32 cntr4clk;
u32 cntr5clk;
u32 cntr6clk;
u32 cntr7clk;
u32 cntr8clk;
u32 cntr9clk;
u32 emacctl;
u32 gpiodiv;
u32 pllglob;
u32 fdbck;
u32 mem;
u32 memstat;
u32 pllc0;
u32 pllc1;
u32 vcocalib;
u32 ctrl;
u32 stat;
u32 testioctrl;
u32 intrgen;
u32 intrmsk;
u32 intrclr;
u32 intrsts;
u32 intrstk;
u32 intrraw;
- Copyright (C) 2017 Intel Corporation <www.intel.com>
- Offset for HW handoff from Quartus tools
u32 i;
} else
return 25000000;
Needs to be a #define
return 460000000;
Same...
return 50000000;
Same..
Dinh
arch/arm/mach-socfpga/Makefile | 4 + arch/arm/mach-socfpga/clock_manager.c | 4 +- arch/arm/mach-socfpga/clock_manager_s10.c | 359 +++++++++++++++++++++ arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 + .../mach-socfpga/include/mach/clock_manager_s10.h | 202 ++++++++++++ arch/arm/mach-socfpga/include/mach/handoff_s10.h | 29 ++ arch/arm/mach-socfpga/wrap_pll_config_s10.c | 46 +++ 7 files changed, 644 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-socfpga/clock_manager_s10.c create mode 100644 arch/arm/mach- socfpga/include/mach/clock_manager_s10.h create mode 100644 arch/arm/mach- socfpga/include/mach/handoff_s10.h create mode 100644 arch/arm/mach-socfpga/wrap_pll_config_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 286bfef..e5f9dd7 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -30,6 +30,10 @@ obj-y += pinmux_arria10.o obj-y += reset_manager_arria10.o endif
+ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 +obj-y += clock_manager_s10.o +obj-y += wrap_pll_config_s10.o +endif ifdef CONFIG_SPL_BUILD obj-y += spl.o ifdef CONFIG_TARGET_SOCFPGA_GEN5 diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach- socfpga/clock_manager.c index cb6ae03..f9450a4 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -21,7 +21,7 @@ void cm_wait_for_lock(u32 mask) do { #if defined(CONFIG_TARGET_SOCFPGA_GEN5) inter_val = readl(&clock_manager_base->inter) & mask; -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#else inter_val = readl(&clock_manager_base->stat) & mask; #endif /* Wait for stable lock */ @@ -52,7 +52,7 @@ int set_cpu_clk_info(void)
the
- busy bit
Add a new line..
of the clocks.
Remove extra line
Yes, I can improve the readaibility here.
main_pll.fdbck);
main_pll.pllc0);
main_pll.pllc1);
main_pll.nocdiv);
per_pll.fdbck);
per_pll.pllc0);
per_pll.pllc1);
per_pll.emacctl);
per_pll.gpiodiv);
Let me rephrase to why instead how.
Chin Liang
main_pll.mpuclk);
main_pll.nocclk);
main_pll.cntr2clk);
main_pll.cntr3clk);
main_pll.cntr4clk);
main_pll.cntr5clk);
main_pll.cntr6clk);
main_pll.cntr7clk);
main_pll.cntr8clk);
main_pll.cntr9clk);
per_pll.cntr2clk);
per_pll.cntr3clk);
per_pll.cntr4clk);
per_pll.cntr5clk);
per_pll.cntr6clk);
per_pll.cntr7clk);
per_pll.cntr8clk);
per_pll.cntr9clk);
Useless comment...
same..
same...
Why 6? Define?
+ return vco; +}
main_pll.mpuclk);
main_pll.pllc0) &
main_pll.nocclk);
main_pll.pllc1) &
per_pll.cntr6clk);
per_pll.cntr6clk) &
main_pll.nocdiv) >>
- * Copyright (C) 2017 Intel Corporation <www.intel.com>
Same...
Same..
Dinh
Add Reset Manager driver support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/reset_manager.h | 2 + .../mach-socfpga/include/mach/reset_manager_s10.h | 116 +++++++++++++++++ arch/arm/mach-socfpga/reset_manager.c | 5 + arch/arm/mach-socfpga/reset_manager_s10.c | 140 +++++++++++++++++++++ include/dt-bindings/reset/altr,rst-mgr-s10.h | 97 ++++++++++++++ 6 files changed, 361 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/reset_manager_s10.h create mode 100644 arch/arm/mach-socfpga/reset_manager_s10.c create mode 100644 include/dt-bindings/reset/altr,rst-mgr-s10.h
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index e5f9dd7..f10b05c 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -32,6 +32,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o +obj-y += reset_manager_s10.o obj-y += wrap_pll_config_s10.o endif ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 6591745..577fcce 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -45,6 +45,8 @@ void socfpga_per_reset_all(void); #include <asm/arch/reset_manager_gen5.h> #elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) #include <asm/arch/reset_manager_arria10.h> +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) +#include <asm/arch/reset_manager_s10.h> #endif
#endif /* _RESET_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h new file mode 100644 index 0000000..07ada59 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_s10.h @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _RESET_MANAGER_S10_ +#define _RESET_MANAGER_S10_ + +void reset_cpu(ulong addr); +void reset_deassert_peripherals_handoff(void); + +void socfpga_bridges_reset(int enable); + +void socfpga_per_reset(u32 reset, int set); +void socfpga_per_reset_all(void); + +struct socfpga_reset_manager { + u32 status; + u32 mpu_rst_stat; + u32 misc_stat; + u32 padding1; + u32 hdsk_en; + u32 hdsk_req; + u32 hdsk_ack; + u32 hdsk_stall; + u32 mpu_mod_reset; + u32 per_mod_reset; /* stated as per0_mod_reset in S10 datasheet */ + u32 per2_mod_reset; /* stated as per1_mod_reset in S10 datasheet */ + u32 brg_mod_reset; + u32 padding2; + u32 cold_mod_reset; + u32 padding3; + u32 dbg_mod_reset; + u32 tap_mod_reset; + u32 padding4; + u32 padding5; + u32 brg_warm_mask; + u32 padding6[3]; + u32 tst_stat; + u32 padding7; + u32 hdsk_timeout; + u32 mpul2flushtimeout; + u32 dbghdsktimeout; +}; + +#define RSTMGR_MPUMODRST_CORE0 0 +#define RSTMGR_PER0MODRST_OCP_MASK 0x0020bf00 +#define RSTMGR_BRGMODRST_DDRSCH_MASK 0X00000040 + +/* + * Define a reset identifier, from which a permodrst bank ID + * and reset ID can be extracted using the subsequent macros + * RSTMGR_RESET() and RSTMGR_BANK(). + */ +#define RSTMGR_BANK_OFFSET 8 +#define RSTMGR_BANK_MASK 0x7 +#define RSTMGR_RESET_OFFSET 0 +#define RSTMGR_RESET_MASK 0x1f +#define RSTMGR_DEFINE(_bank, _offset) \ + ((_bank) << RSTMGR_BANK_OFFSET) | ((_offset) << RSTMGR_RESET_OFFSET) + +/* Extract reset ID from the reset identifier. */ +#define RSTMGR_RESET(_reset) \ + (((_reset) >> RSTMGR_RESET_OFFSET) & RSTMGR_RESET_MASK) + +/* Extract bank ID from the reset identifier. */ +#define RSTMGR_BANK(_reset) \ + (((_reset) >> RSTMGR_BANK_OFFSET) & RSTMGR_BANK_MASK) + +/* + * SocFPGA Stratix10 reset IDs, bank mapping is as follows: + * 0 ... mpumodrst + * 1 ... per0modrst + * 2 ... per1modrst + * 3 ... brgmodrst + */ +#define RSTMGR_EMAC0 RSTMGR_DEFINE(1, 0) +#define RSTMGR_EMAC1 RSTMGR_DEFINE(1, 1) +#define RSTMGR_EMAC2 RSTMGR_DEFINE(1, 2) +#define RSTMGR_USB0 RSTMGR_DEFINE(1, 3) +#define RSTMGR_USB1 RSTMGR_DEFINE(1, 4) +#define RSTMGR_NAND RSTMGR_DEFINE(1, 5) +#define RSTMGR_SDMMC RSTMGR_DEFINE(1, 7) +#define RSTMGR_EMAC0_OCP RSTMGR_DEFINE(1, 8) +#define RSTMGR_EMAC1_OCP RSTMGR_DEFINE(1, 9) +#define RSTMGR_EMAC2_OCP RSTMGR_DEFINE(1, 10) +#define RSTMGR_USB0_OCP RSTMGR_DEFINE(1, 11) +#define RSTMGR_USB1_OCP RSTMGR_DEFINE(1, 12) +#define RSTMGR_NAND_OCP RSTMGR_DEFINE(1, 13) +#define RSTMGR_SDMMC_OCP RSTMGR_DEFINE(1, 15) +#define RSTMGR_DMA RSTMGR_DEFINE(1, 16) +#define RSTMGR_SPIM0 RSTMGR_DEFINE(1, 17) +#define RSTMGR_SPIM1 RSTMGR_DEFINE(1, 18) +#define RSTMGR_L4WD0 RSTMGR_DEFINE(2, 0) +#define RSTMGR_L4WD1 RSTMGR_DEFINE(2, 1) +#define RSTMGR_L4WD2 RSTMGR_DEFINE(2, 2) +#define RSTMGR_L4WD3 RSTMGR_DEFINE(2, 3) +#define RSTMGR_OSC1TIMER0 RSTMGR_DEFINE(2, 4) +#define RSTMGR_I2C0 RSTMGR_DEFINE(2, 8) +#define RSTMGR_I2C1 RSTMGR_DEFINE(2, 9) +#define RSTMGR_I2C2 RSTMGR_DEFINE(2, 10) +#define RSTMGR_I2C3 RSTMGR_DEFINE(2, 11) +#define RSTMGR_I2C4 RSTMGR_DEFINE(2, 12) +#define RSTMGR_UART0 RSTMGR_DEFINE(2, 16) +#define RSTMGR_UART1 RSTMGR_DEFINE(2, 17) +#define RSTMGR_GPIO0 RSTMGR_DEFINE(2, 24) +#define RSTMGR_GPIO1 RSTMGR_DEFINE(2, 25) +#define RSTMGR_SDR RSTMGR_DEFINE(3, 6) + +void socfpga_emac_manage_reset(const unsigned int of_reset_id, u32 state); + +/* Create a human-readable reference to SoCFPGA reset. */ +#define SOCFPGA_RESET(_name) RSTMGR_##_name + +#endif /* _RESET_MANAGER_S10_ */ diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index 29438ed..9acbf42 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -20,8 +20,13 @@ static const struct socfpga_reset_manager *reset_manager_base = void reset_cpu(ulong addr) { /* request a warm reset */ +#if defined(CONFIG_TARGET_SOCFPGA_STRATIX10) + writel((1 << RSTMGR_MPUMODRST_CORE0), + &reset_manager_base->mpu_mod_reset); +#else writel(1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB, &reset_manager_base->ctrl); +#endif /* * infinite loop here as watchdog will trigger and reset * the processor diff --git a/arch/arm/mach-socfpga/reset_manager_s10.c b/arch/arm/mach-socfpga/reset_manager_s10.c new file mode 100644 index 0000000..81bad11 --- /dev/null +++ b/arch/arm/mach-socfpga/reset_manager_s10.c @@ -0,0 +1,140 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <dt-bindings/reset/altr,rst-mgr-s10.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_reset_manager *reset_manager_base = + (void *)SOCFPGA_RSTMGR_ADDRESS; +static const struct socfpga_system_manager *system_manager_base = + (void *)SOCFPGA_SYSMGR_ADDRESS; + +/* Assert or de-assert SoCFPGA reset manager reset. */ +void socfpga_per_reset(u32 reset, int set) +{ + const void *reg; + + if (RSTMGR_BANK(reset) == 0) + reg = &reset_manager_base->mpu_mod_reset; + else if (RSTMGR_BANK(reset) == 1) + reg = &reset_manager_base->per_mod_reset; + else if (RSTMGR_BANK(reset) == 2) + reg = &reset_manager_base->per2_mod_reset; + else if (RSTMGR_BANK(reset) == 3) + reg = &reset_manager_base->brg_mod_reset; + else /* Invalid reset register, do nothing */ + return; + + if (set) + setbits_le32(reg, 1 << RSTMGR_RESET(reset)); + else + clrbits_le32(reg, 1 << RSTMGR_RESET(reset)); +} + +/* + * Assert reset on every peripheral but L4WD0. + * Watchdog must be kept intact to prevent glitches + * and/or hangs. + */ +void socfpga_per_reset_all(void) +{ + const u32 l4wd0 = 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)); + + /* disable all except OCP and l4wd0. OCP disable later */ + writel(~(l4wd0 | RSTMGR_PER0MODRST_OCP_MASK), + &reset_manager_base->per_mod_reset); + writel(~l4wd0, &reset_manager_base->per_mod_reset); + writel(0xffffffff, &reset_manager_base->per2_mod_reset); +} + +void socfpga_bridges_reset(int enable) +{ + if (enable) { + /* clear idle request to all bridges */ + setbits_le32(&system_manager_base->noc_idlereq_clr, ~0); + + /* Release bridges from reset state per handoff value */ + clrbits_le32(&reset_manager_base->brg_mod_reset, ~0); + + /* Poll until all idleack to 0 */ + while (readl(&system_manager_base->noc_idleack)) + ; + } else { + /* set idle request to all bridges */ + writel(~0, &system_manager_base->noc_idlereq_set); + + /* Enable the NOC timeout */ + writel(1, &system_manager_base->noc_timeout); + + /* Poll until all idleack to 1 */ + while ((readl(&system_manager_base->noc_idleack) ^ + (SYSMGR_NOC_H2F_MSK | SYSMGR_NOC_LWH2F_MSK))) + ; + + /* Poll until all idlestatus to 1 */ + while ((readl(&system_manager_base->noc_idlestatus) ^ + (SYSMGR_NOC_H2F_MSK | SYSMGR_NOC_LWH2F_MSK))) + ; + + /* Put all bridges (except NOR DDR scheduler) into reset */ + setbits_le32(&reset_manager_base->brg_mod_reset, + ~RSTMGR_BRGMODRST_DDRSCH_MASK); + + /* Disable NOC timeout */ + writel(0, &system_manager_base->noc_timeout); + } +} + +/* of_reset_id: emac reset id + * state: 0 - disable reset, !0 - enable reset + */ +void socfpga_emac_manage_reset(const unsigned int of_reset_id, u32 state) +{ + u32 reset_emac; + u32 reset_emacocp; + + /* hardcode this now */ + switch (of_reset_id) { + case EMAC0_RESET: + reset_emac = SOCFPGA_RESET(EMAC0); + reset_emacocp = SOCFPGA_RESET(EMAC0_OCP); + break; + case EMAC1_RESET: + reset_emac = SOCFPGA_RESET(EMAC1); + reset_emacocp = SOCFPGA_RESET(EMAC1_OCP); + break; + case EMAC2_RESET: + reset_emac = SOCFPGA_RESET(EMAC2); + reset_emacocp = SOCFPGA_RESET(EMAC2_OCP); + break; + default: + printf("GMAC: Invalid reset ID (%i)!\n", of_reset_id); + hang(); + break; + } + + /* Reset ECC OCP first */ + socfpga_per_reset(reset_emacocp, state); + + /* Release the EMAC controller from reset */ + socfpga_per_reset(reset_emac, state); +} + +/* + * Release peripherals from reset based on handoff + */ +void reset_deassert_peripherals_handoff(void) +{ + writel(0, &reset_manager_base->per2_mod_reset); + /* Enable OCP first */ + writel(~RSTMGR_PER0MODRST_OCP_MASK, &reset_manager_base->per_mod_reset); + writel(0, &reset_manager_base->per_mod_reset); +} diff --git a/include/dt-bindings/reset/altr,rst-mgr-s10.h b/include/dt-bindings/reset/altr,rst-mgr-s10.h new file mode 100644 index 0000000..29eb829 --- /dev/null +++ b/include/dt-bindings/reset/altr,rst-mgr-s10.h @@ -0,0 +1,97 @@ +/* + * Copyright (c) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + * + */ + +#ifndef _DT_BINDINGS_RESET_ALTR_RST_MGR_S10_H +#define _DT_BINDINGS_RESET_ALTR_RST_MGR_S10_H + +/* MPUMODRST */ +#define CPU0_RESET 0 +#define CPU1_RESET 1 +#define CPU2_RESET 2 +#define CPU3_RESET 3 + +/* PER0MODRST */ +#define EMAC0_RESET 32 +#define EMAC1_RESET 33 +#define EMAC2_RESET 34 +#define USB0_RESET 35 +#define USB1_RESET 36 +#define NAND_RESET 37 +/* 38 is empty*/ +#define SDMMC_RESET 39 +#define EMAC0OCP_RESET 40 +#define EMAC1OCP_RESET 41 +#define EMAC2OCP_RESET 42 +#define USB0OCP_RESET 43 +#define USB1OCP_RESET 44 +#define NANDOCP_RESET 45 +/* 46 is empty*/ +#define SDMMCOCP_RESET 47 +#define DMA_RESET 48 +#define SPIM0_RESET 49 +#define SPIM1_RESET 50 +#define SPIS0_RESET 51 +#define SPIS1_RESET 52 +#define DMAOCP_RESET 53 +#define EMACPTP_RESET 54 +/* 55 is empty*/ +#define DMAIF0_RESET 56 +#define DMAIF1_RESET 57 +#define DMAIF2_RESET 58 +#define DMAIF3_RESET 59 +#define DMAIF4_RESET 60 +#define DMAIF5_RESET 61 +#define DMAIF6_RESET 62 +#define DMAIF7_RESET 63 + +/* PER1MODRST */ +#define L4WD0_RESET 64 +#define L4WD1_RESET 65 +#define L4WD2_RESET 66 +#define L4WD3_RESET 67 +#define L4SYSTIMER0_RESET 68 +#define L4SYSTIMER1_RESET 69 +#define SPTIMER0_RESET 70 +#define SPTIMER1_RESET 71 +#define I2C0_RESET 72 +#define I2C1_RESET 73 +#define I2C2_RESET 74 +#define I2C3_RESET 75 +#define I2C4_RESET 76 +/* 77-79 is reserved */ +#define UART0_RESET 80 +#define UART1_RESET 81 +/* 82-87 is reserved */ +#define GPIO0_RESET 88 +#define GPIO1_RESET 89 + +/* BRGMODRST */ +#define HPS2FPGA_RESET 96 +#define LWHPS2FPGA_RESET 97 +#define FPGA2HPS_RESET 98 +#define F2SSDRAM0_RESET 99 +#define F2SSDRAM1_RESET 100 +#define F2SSDRAM2_RESET 101 +#define DDRSCH_RESET 102 + +/* 128-159 is reserved */ + +/* COLDMODRST */ +#define CPUPOR0_RESET 160 +#define CPUPOR1_RESET 161 +#define CPUPOR2_RESET 162 +#define CPUPOR3_RESET 163 +/* 164-167 is reserved */ +#define L2_RESET 168 + +/* 192-223 is reserved */ + +/* DBGMODRST */ +#define DBG_RESET 224 +#define CSDAP_RESET 225 + +#endif
I don't see why you need to add a new file for S10? The functionality between Gen 5 and Stratix10 is identical for the reset manager.
Dinh
Not really, they have same functions name but sequences are difference due to diff interconnect technology. Hence, try to avoid too much #if #else
Chin Liang
Dinh
On Fri, Sep 29, 2017 at 7:53 AM, See, Chin Liang chin.liang.see@intel.com wrote:
How so? I'm able to re-use the same driver for Linux on the Stratix10.
Dinh
Add pinmux driver support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 2 + .../arm/mach-socfpga/include/mach/system_manager.h | 5 +- .../mach-socfpga/include/mach/system_manager_s10.h | 169 +++++++++++++++++++++ arch/arm/mach-socfpga/system_manager_s10.c | 91 +++++++++++ arch/arm/mach-socfpga/wrap_pinmux_config_s10.c | 55 +++++++ 5 files changed, 321 insertions(+), 1 deletion(-) create mode 100644 arch/arm/mach-socfpga/include/mach/system_manager_s10.h create mode 100644 arch/arm/mach-socfpga/system_manager_s10.c create mode 100644 arch/arm/mach-socfpga/wrap_pinmux_config_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index f10b05c..910eb6f 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -33,6 +33,8 @@ endif ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o obj-y += reset_manager_s10.o +obj-y += system_manager_s10.o +obj-y += wrap_pinmux_config_s10.o obj-y += wrap_pll_config_s10.o endif ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index e6d4280..80c7d0b 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -7,6 +7,9 @@ #ifndef _SYSTEM_MANAGER_H_ #define _SYSTEM_MANAGER_H_
+#if defined(CONFIG_TARGET_SOCFPGA_STRATIX10) +#include <asm/arch/system_manager_s10.h> +#else #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX BIT(0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO BIT(1) #define SYSMGR_ECC_OCRAM_EN BIT(0) @@ -89,5 +92,5 @@
#define SYSMGR_GET_BOOTINFO_BSEL(bsel) \ (((bsel) >> SYSMGR_BOOTINFO_BSEL_SHIFT) & 7) - +#endif #endif /* _SYSTEM_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_s10.h b/arch/arm/mach-socfpga/include/mach/system_manager_s10.h new file mode 100644 index 0000000..d992072 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/system_manager_s10.h @@ -0,0 +1,169 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SYSTEM_MANAGER_S10_ +#define _SYSTEM_MANAGER_S10_ + +void sysmgr_pinmux_init(void); +void populate_sysmgr_fpgaintf_module(void); +void populate_sysmgr_pinmux(void); +void sysmgr_pinmux_table_sel(const u32 **table, unsigned int *table_len); +void sysmgr_pinmux_table_ctrl(const u32 **table, unsigned int *table_len); +void sysmgr_pinmux_table_fpga(const u32 **table, unsigned int *table_len); +void sysmgr_pinmux_table_delay(const u32 **table, unsigned int *table_len); + +struct socfpga_system_manager { + /* System Manager Module */ + u32 siliconid1; /* 0x00 */ + u32 siliconid2; + u32 wddbg; + u32 _pad_0xc; + u32 mpu_status; /* 0x10 */ + u32 mpu_ace; + u32 _pad_0x18_0x1c[2]; + u32 dma; /* 0x20 */ + u32 dma_periph; + /* SDMMC Controller Group */ + u32 sdmmcgrp_ctrl; + u32 sdmmcgrp_l3master; + /* NAND Flash Controller Register Group */ + u32 nandgrp_bootstrap; /* 0x30 */ + u32 nandgrp_l3master; + /* USB Controller Group */ + u32 usb0_l3master; + u32 usb1_l3master; + /* EMAC Group */ + u32 emac_gbl; /* 0x40 */ + u32 emac0; + u32 emac1; + u32 emac2; + u32 emac0_ace; /* 0x50 */ + u32 emac1_ace; + u32 emac2_ace; + u32 nand_axuser; + u32 _pad_0x60_0x64[2]; /* 0x60 */ + /* FPGA interface Group */ + u32 fpgaintf_en_1; + u32 fpgaintf_en_2; + u32 fpgaintf_en_3; /* 0x70 */ + u32 dma_l3master; + u32 etr_l3master; + u32 _pad_0x7c; + u32 sec_ctrl_slt; /* 0x80 */ + u32 osc_trim; + u32 _pad_0x88_0x8c[2]; + /* ECC Group */ + u32 ecc_intmask_value; /* 0x90 */ + u32 ecc_intmask_set; + u32 ecc_intmask_clr; + u32 ecc_intstatus_serr; + u32 ecc_intstatus_derr; /* 0xa0 */ + u32 _pad_0xa4_0xac[3]; + u32 noc_addr_remap; /* 0xb0 */ + u32 hmc_clk; + u32 io_pa_ctrl; + u32 _pad_0xbc; + /* NOC Group */ + u32 noc_timeout; /* 0xc0 */ + u32 noc_idlereq_set; + u32 noc_idlereq_clr; + u32 noc_idlereq_value; + u32 noc_idleack; /* 0xd0 */ + u32 noc_idlestatus; + u32 fpga2soc_ctrl; + u32 fpga_config; + u32 iocsrclk_gate; /* 0xe0 */ + u32 gpo; + u32 gpi; + u32 _pad_0xec; + u32 mpu; /* 0xf0 */ + u32 sdm_hps_spare; + u32 hps_sdm_spare; + u32 _pad_0xfc_0x1fc[65]; + /* Boot scratch register group */ + u32 boot_scratch_cold0; /* 0x200 */ + u32 boot_scratch_cold1; + u32 boot_scratch_cold2; + u32 boot_scratch_cold3; + u32 boot_scratch_cold4; /* 0x210 */ + u32 boot_scratch_cold5; + u32 boot_scratch_cold6; + u32 boot_scratch_cold7; + u32 boot_scratch_cold8; /* 0x220 */ + u32 boot_scratch_cold9; + u32 _pad_0x228_0xffc[886]; + /* Pin select and pin control group */ + u32 pinsel0[40]; /* 0x1000 */ + u32 _pad_0x10a0_0x10fc[24]; + u32 pinsel40[8]; + u32 _pad_0x1120_0x112c[4]; + u32 ioctrl0[28]; + u32 _pad_0x11a0_0x11fc[24]; + u32 ioctrl28[20]; + u32 _pad_0x1250_0x12fc[44]; + /* Use FPGA mux */ + u32 rgmii0usefpga; /* 0x1300 */ + u32 rgmii1usefpga; + u32 rgmii2usefpga; + u32 i2c0usefpga; + u32 i2c1usefpga; + u32 i2c_emac0_usefpga; + u32 i2c_emac1_usefpga; + u32 i2c_emac2_usefpga; + u32 nandusefpga; + u32 _pad_0x1324; + u32 spim0usefpga; + u32 spim1usefpga; + u32 spis0usefpga; + u32 spis1usefpga; + u32 uart0usefpga; + u32 uart1usefpga; + u32 mdio0usefpga; + u32 mdio1usefpga; + u32 mdio2usefpga; + u32 _pad_0x134c; + u32 jtagusefpga; + u32 sdmmcusefpga; + u32 hps_osc_clk; + u32 _pad_0x135c_0x13fc[41]; + u32 iodelay0[40]; + u32 _pad_0x14a0_0x14fc[24]; + u32 iodelay40[8]; + +}; + +#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) +#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) +#define SYSMGR_ECC_OCRAM_EN (1 << 0) +#define SYSMGR_ECC_OCRAM_SERR (1 << 3) +#define SYSMGR_ECC_OCRAM_DERR (1 << 4) +#define SYSMGR_FPGAINTF_USEFPGA 0x1 + +#define SYSMGR_FPGAINTF_NAND (1 << 4) +#define SYSMGR_FPGAINTF_SDMMC (1 << 8) +#define SYSMGR_FPGAINTF_SPIM0 (1 << 16) +#define SYSMGR_FPGAINTF_SPIM1 (1 << 24) +#define SYSMGR_FPGAINTF_EMAC0 (0x11 << 0) +#define SYSMGR_FPGAINTF_EMAC1 (0x11 << 8) +#define SYSMGR_FPGAINTF_EMAC2 (0x11 << 16) + +#define SYSMGR_SDMMC_SMPLSEL_SHIFT 4 +#define SYSMGR_SDMMC_DRVSEL_SHIFT 0 + +/* EMAC Group Bit definitions */ +#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII 0x0 +#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII 0x1 +#define SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII 0x2 + +#define SYSMGR_EMACGRP_CTRL_PHYSEL0_LSB 0 +#define SYSMGR_EMACGRP_CTRL_PHYSEL1_LSB 2 +#define SYSMGR_EMACGRP_CTRL_PHYSEL_MASK 0x3 + +#define SYSMGR_NOC_H2F_MSK 0x00000001 +#define SYSMGR_NOC_LWH2F_MSK 0x00000010 +#define SYSMGR_HMC_CLK_STATUS_MSK 0x00000001 + +#endif /* _SYSTEM_MANAGER_S10_ */ diff --git a/arch/arm/mach-socfpga/system_manager_s10.c b/arch/arm/mach-socfpga/system_manager_s10.c new file mode 100644 index 0000000..8c7a715 --- /dev/null +++ b/arch/arm/mach-socfpga/system_manager_s10.c @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/system_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* + * Configure all the pin muxes + */ +void sysmgr_pinmux_init(void) +{ + populate_sysmgr_pinmux(); + populate_sysmgr_fpgaintf_module(); +} + +/* + * Populate the value for SYSMGR.FPGAINTF.MODULE based on pinmux setting. + * The value is not wrote to SYSMGR.FPGAINTF.MODULE but + * CONFIG_SYSMGR_ISWGRP_HANDOFF. + */ +void populate_sysmgr_fpgaintf_module(void) +{ + uint32_t handoff_val = 0; + + /* Enable the signal for those HPS peripherals that use FPGA. */ + if (readl(&sysmgr_regs->nandusefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_NAND; + if (readl(&sysmgr_regs->sdmmcusefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SDMMC; + if (readl(&sysmgr_regs->spim0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SPIM0; + if (readl(&sysmgr_regs->spim1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_SPIM1; + writel(handoff_val, &sysmgr_regs->fpgaintf_en_2); + + handoff_val = 0; + if (readl(&sysmgr_regs->rgmii0usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_EMAC0; + if (readl(&sysmgr_regs->rgmii1usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_EMAC1; + if (readl(&sysmgr_regs->rgmii2usefpga) == SYSMGR_FPGAINTF_USEFPGA) + handoff_val |= SYSMGR_FPGAINTF_EMAC2; + writel(handoff_val, &sysmgr_regs->fpgaintf_en_3); +} + +/* + * Configure all the pin muxes + */ +void populate_sysmgr_pinmux(void) +{ + const u32 *sys_mgr_table_u32; + unsigned int len, i; + + /* setup the pin sel */ + sysmgr_pinmux_table_sel(&sys_mgr_table_u32, &len); + for (i = 0; i < len; i = i+2) { + writel(sys_mgr_table_u32[i+1], + sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->pinsel0[0]); + } + + /* setup the pin ctrl */ + sysmgr_pinmux_table_ctrl(&sys_mgr_table_u32, &len); + for (i = 0; i < len; i = i+2) { + writel(sys_mgr_table_u32[i+1], + sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->ioctrl0[0]); + } + + /* setup the fpga use */ + sysmgr_pinmux_table_fpga(&sys_mgr_table_u32, &len); + for (i = 0; i < len; i = i+2) { + writel(sys_mgr_table_u32[i+1], + sys_mgr_table_u32[i] + + (u8 *)&sysmgr_regs->rgmii0usefpga); + } + + /* setup the IO delay */ + sysmgr_pinmux_table_delay(&sys_mgr_table_u32, &len); + for (i = 0; i < len; i = i+2) { + writel(sys_mgr_table_u32[i+1], + sys_mgr_table_u32[i] + (u8 *)&sysmgr_regs->iodelay0[0]); + } +} diff --git a/arch/arm/mach-socfpga/wrap_pinmux_config_s10.c b/arch/arm/mach-socfpga/wrap_pinmux_config_s10.c new file mode 100644 index 0000000..b6a9f68 --- /dev/null +++ b/arch/arm/mach-socfpga/wrap_pinmux_config_s10.c @@ -0,0 +1,55 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/handoff_s10.h> + +static void sysmgr_pinmux_handoff_read(void *handoff_address, + const u32 **table, unsigned int *table_len) +{ + unsigned int handoff_entry = (swab32(readl(handoff_address + + CONFIG_HANDOFF_OFFSET_LENGTH)) - + CONFIG_HANDOFF_OFFSET_DATA) / + sizeof(unsigned int); + unsigned int handoff_chunk[handoff_entry], temp, i; + + if (swab32(readl(CONFIG_HANDOFF_MUX)) == CONFIG_HANDOFF_MAGIC_MUX) { + /* using handoff from Quartus tools if exists */ + for (i = 0; i < handoff_entry; i++) { + temp = readl(handoff_address + + CONFIG_HANDOFF_OFFSET_DATA + (i * 4)); + handoff_chunk[i] = swab32(temp); + } + *table = handoff_chunk; + *table_len = ARRAY_SIZE(handoff_chunk); + } +} + +void sysmgr_pinmux_table_sel(const u32 **table, unsigned int *table_len) +{ + sysmgr_pinmux_handoff_read((void *)CONFIG_HANDOFF_MUX, table, + table_len); +} + +void sysmgr_pinmux_table_ctrl(const u32 **table, unsigned int *table_len) +{ + sysmgr_pinmux_handoff_read((void *)CONFIG_HANDOFF_IOCTL, table, + table_len); +} + +void sysmgr_pinmux_table_fpga(const u32 **table, unsigned int *table_len) +{ + sysmgr_pinmux_handoff_read((void *)CONFIG_HANDOFF_FPGA, table, + table_len); +} + +void sysmgr_pinmux_table_delay(const u32 **table, unsigned int *table_len) +{ + sysmgr_pinmux_handoff_read((void *)CONFIG_HANODFF_DELAY, table, + table_len); +}
Add misc support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/misc.c | 4 + arch/arm/mach-socfpga/misc_s10.c | 165 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 170 insertions(+) create mode 100644 arch/arm/mach-socfpga/misc_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 910eb6f..b253914 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -32,6 +32,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o +obj-y += misc_s10.o obj-y += reset_manager_s10.o obj-y += system_manager_s10.o obj-y += wrap_pinmux_config_s10.o diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 00eff90..2ea94bc 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -23,8 +23,10 @@
+#ifdef CONFIG_SYS_L2_PL310 static const struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; +#endif
struct bsel bsel_str[] = { { "rsvd", "Reserved", }, @@ -53,6 +55,7 @@ void enable_caches(void) #endif }
+#ifdef CONFIG_SYS_L2_PL310 void v7_outer_cache_enable(void) { /* Disable the L2 cache */ @@ -73,6 +76,7 @@ void v7_outer_cache_disable(void) /* Disable the L2 cache */ clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); } +#endif
#if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c new file mode 100644 index 0000000..b84f055 --- /dev/null +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -0,0 +1,165 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <altera.h> +#include <miiphy.h> +#include <netdev.h> +#include <watchdog.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/pl310.h> + +#include <dt-bindings/reset/altr,rst-mgr-s10.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +/* + * DesignWare Ethernet initialization + */ +#ifdef CONFIG_ETH_DESIGNWARE +void dwmac_deassert_reset(const unsigned int of_reset_id, + const u32 phymode) +{ + /* Put the emac we're using into reset. + * This is required before configuring the PHY interface + */ + socfpga_emac_manage_reset(of_reset_id, 1); + + clrsetbits_le32(&sysmgr_regs->emac0 + (of_reset_id - EMAC0_RESET), + SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, + phymode); + + socfpga_emac_manage_reset(of_reset_id, 0); +} + +static u32 dwmac_phymode_to_modereg(const char *phymode, u32 *modereg) +{ + if (!phymode) + return -EINVAL; + + if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; + return 0; + } + + if (!strcmp(phymode, "rgmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; + return 0; + } + + if (!strcmp(phymode, "rmii")) { + *modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; + return 0; + } + + return -EINVAL; +} + +static int socfpga_eth_reset(void) +{ + const void *fdt = gd->fdt_blob; + struct fdtdec_phandle_args args; + const char *phy_mode; + u32 phy_modereg; + int nodes[2]; /* Max. 3 GMACs */ + int ret, count; + int i, node; + + count = fdtdec_find_aliases_for_id(fdt, "ethernet", + COMPAT_ALTERA_SOCFPGA_DWMAC, + nodes, ARRAY_SIZE(nodes)); + for (i = 0; i < count; i++) { + node = nodes[i]; + if (node <= 0) + continue; + + ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", + "#reset-cells", 1, 0, + &args); + if (ret || (args.args_count != 1)) { + debug("GMAC%i: Failed to parse DT 'resets'!\n", i); + continue; + } + + phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); + ret = dwmac_phymode_to_modereg(phy_mode, &phy_modereg); + if (ret) { + debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); + continue; + } + + dwmac_deassert_reset(args.args[0], phy_modereg); + } + + return 0; +} +#else +static int socfpga_eth_reset(void) +{ + return 0; +}; +#endif + +/* + * Print CPU information + */ +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + puts("CPU: Intel FPGA SoCFPGA Platform\n"); + puts("FPGA: Intel FPGA Stratix 10\n"); + return 0; +} +#endif + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + return socfpga_eth_reset(); +} +#endif + +int arch_early_init_r(void) +{ + return 0; +} + +int do_bridge(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc != 2) + return CMD_RET_USAGE; + + argv++; + + switch (*argv[0]) { + case 'e': /* Enable */ + socfpga_bridges_reset(1); + break; + case 'd': /* Disable */ + socfpga_bridges_reset(0); + break; + default: + return CMD_RET_USAGE; + } + + return 0; +} + +U_BOOT_CMD( + bridge, 2, 1, do_bridge, + "SoCFPGA HPS FPGA bridge control", + "enable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" + "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" + "" +);
Just because the file is call misc.c doesn't mean you can just keep the commit message that simple. Can you add what functions are you adding?
This misc_s10.c look very similar to the Gen5 stuff, can you re-use it?
Dinh
Definitely can add more details here
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 910eb6f..b253914 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -32,6 +32,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o +obj-y += misc_s10.o obj-y += reset_manager_s10.o obj-y += system_manager_s10.o obj-y += wrap_pinmux_config_s10.o diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach- socfpga/misc.c index 00eff90..2ea94bc 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -23,8 +23,10 @@
#if defined(CONFIG_SYS_CONSOLE_IS_IN_ENV) && \ defined(CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE) diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach- socfpga/misc_s10.c new file mode 100644 index 0000000..b84f055 --- /dev/null +++ b/arch/arm/mach-socfpga/misc_s10.c
Yes, its true. Let me move eth stuff to common.
Chin Liang
Dinh
Add mailbox support for Stratix SoC
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 108 ++++++++++ arch/arm/mach-socfpga/mailbox_s10.c | 239 +++++++++++++++++++++++ 3 files changed, 348 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/mailbox_s10.h create mode 100644 arch/arm/mach-socfpga/mailbox_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index b253914..43e18d2 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -32,6 +32,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o +obj-y += mailbox_s10.o obj-y += misc_s10.o obj-y += reset_manager_s10.o obj-y += system_manager_s10.o diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h new file mode 100644 index 0000000..b9bddf6 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -0,0 +1,108 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ +#ifndef _MAILBOX_S10_H_ +#define _MAILBOX_S10_H_ + +/* user define Uboot ID */ +#define MBOX_CLIENT_ID_UBOOT 0xB +#define MBOX_ID_UBOOT 0x1 + +#define MBOX_MAX_CMD_INDEX 2047 +#define MBOX_CMD_BUFFER_SIZE 32 +#define MBOX_RESP_BUFFER_SIZE 16 + +#define MBOX_HDR_CMD_LSB 0 +#define MBOX_HDR_CMD_MSK (BIT(11) - 1) +#define MBOX_HDR_I_LSB 11 +#define MBOX_HDR_I_MSK BIT(11) +#define MBOX_HDR_LEN_LSB 12 +#define MBOX_HDR_LEN_MSK 0x007FF000 +#define MBOX_HDR_ID_LSB 24 +#define MBOX_HDR_ID_MSK 0x0F000000 +#define MBOX_HDR_CLIENT_LSB 28 +#define MBOX_HDR_CLIENT_MSK 0xF0000000 + +/* Interrupt flags */ +#define MBOX_FLAGS_INT_COE BIT(0) /* COUT update interrupt enable */ +#define MBOX_FLAGS_INT_RIE BIT(1) /* RIN update interrupt enable */ +#define MBOX_FLAGS_INT_UAE BIT(8) /* Urgent ACK interrupt enable */ +#define MBOX_ALL_INTRS (MBOX_FLAGS_INT_COE | \ + MBOX_FLAGS_INT_RIE | \ + MBOX_FLAGS_INT_UAE) + +/* Status */ +#define MBOX_STATUS_UA_MSK BIT(8) + +#define MBOX_CMD_HEADER(client, id, len, cmd) \ + (((cmd) << MBOX_HDR_CMD_LSB) & MBOX_HDR_CMD_MSK) | \ + (((len) << MBOX_HDR_LEN_LSB) & MBOX_HDR_LEN_MSK) | \ + (((id) << MBOX_HDR_ID_LSB) & MBOX_HDR_ID_MSK) | \ + (((client) << MBOX_HDR_CLIENT_LSB) & MBOX_HDR_CLIENT_MSK) + +#define MBOX_RESP_ERR_GET(resp) \ + (((resp) & MBOX_HDR_CMD_MSK) >> MBOX_HDR_CMD_LSB) +#define MBOX_RESP_LEN_GET(resp) \ + (((resp) & MBOX_HDR_LEN_MSK) >> MBOX_HDR_LEN_LSB) +#define MBOX_RESP_ID_GET(resp) \ + (((resp) & MBOX_HDR_ID_MSK) >> MBOX_HDR_ID_LSB) +#define MBOX_RESP_CLIENT_GET(resp) \ + (((resp) & MBOX_HDR_CLIENT_MSK) >> MBOX_HDR_CLIENT_LSB) + +/* Response error list */ +typedef enum { + /* CMD completed succesfully, but check resp ARGS for any errors */ + MBOX_RESP_STATOK = 0, + /* CMD is incorrectly formatted in some way */ + MBOX_RESP_INVALID_COMMAND = 1, + /* BootROM Command code not undesrtood */ + MBOX_RESP_UNKNOWN_BR = 2, + /* CMD code not recognized by firmware */ + MBOX_RESP_UNKNOWN = 3, + /* Indicates that the device is not configured */ + MBOX_RESP_NOT_CONFIGURED = 256, + /* Indicates that the device is busy */ + MBOX_RESP_DEVICE_BUSY = 0x1FF, + /* Indicates that there is no valid response available */ + MBOX_RESP_NO_VALID_RESP_AVAILABLE = 0x2FF, + /* General Error */ + MBOX_RESP_ERROR = 0x3FF, +} ALT_SDM_MBOX_RESP_CODE; + +/* Mailbox command list */ +#define MBOX_RESTART 2 +#define MBOX_QSPI_OPEN 50 +#define MBOX_QSPI_CLOSE 51 +#define MBOX_QSPI_DIRECT 59 + +struct socfpga_mailbox { + u32 cin; /* command valid offset */ + u32 rout; /* response output offset */ + u32 urg; /* urgent command */ + u32 flags; /* interrupt enables */ + u32 pad_0x10_0x1f[4]; /* 0x10 - 0x1F reserved */ + u32 cout; /* command free offset */ + u32 rin; /* respond valid offset */ + u32 pad_0x28; /* 0x28 reserved */ + u32 status; /* mailbox status */ + u32 pad_0x30_0x3f[4]; /* 0x30 - 0x3F reserved */ + u32 cmd_buf[MBOX_CMD_BUFFER_SIZE]; /* 0x40 - 0xBC circular command + buffer to SDM */ + u32 resp_buf[MBOX_RESP_BUFFER_SIZE]; /* 0xC0 - 0xFF circular + response buffer */ +}; + +/* Use define other than put into struct socfpga_mailbox to save spaces */ +#define MBOX_DOORBELL_TO_SDM_REG (SOCFPGA_MAILBOX_ADDRESS + 0x400) +#define MBOX_DOORBELL_FROM_SDM_REG (SOCFPGA_MAILBOX_ADDRESS + 0x480) + +int mbox_init(void); + +#ifdef CONFIG_CADENCE_QSPI +int mbox_qspi_close(void); +int mbox_qspi_open(void); +#endif + +#endif /* _MAILBOX_S10_H_ */ diff --git a/arch/arm/mach-socfpga/mailbox_s10.c b/arch/arm/mach-socfpga/mailbox_s10.c new file mode 100644 index 0000000..074940d --- /dev/null +++ b/arch/arm/mach-socfpga/mailbox_s10.c @@ -0,0 +1,239 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <wait_bit.h> +#include <asm/io.h> +#include <asm/arch/mailbox_s10.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_mailbox *mbox_base = + (void *)SOCFPGA_MAILBOX_ADDRESS; + +#define MBOX_POLL_RESP_TIMEOUT 50 /* ms */ + +static int mbox_polling_resp(u32 rout) +{ + u32 rin; + unsigned long start = get_timer(0); + + while (1) { + rin = readl(&mbox_base->rin); + if (rout != rin) + return 0; + + if (get_timer(start) > MBOX_POLL_RESP_TIMEOUT) + break; + + udelay(1); + } + + debug("mailbox: polling response timeout\n"); + return -ETIMEDOUT; +} + +/* Check for available slot and write to circular buffer. + * It also update command valid offset (cin) register. + */ +static int mbox_fill_cmd_circular_buff(u32 header, u32 len, u32 *arg) +{ + u32 cmd_free_offset; + u32 i; + + /* checking available command free slot */ + cmd_free_offset = readl(&mbox_base->cout); + if (cmd_free_offset >= MBOX_CMD_BUFFER_SIZE) { + error("ERROR: Not enough space, cout %d\n", cmd_free_offset); + return -ENOMEM; + } + + /* write header to circular buffer */ + writel(header, &mbox_base->cmd_buf[cmd_free_offset++]); + /* wrapping around when it reach the buffer size */ + cmd_free_offset %= MBOX_CMD_BUFFER_SIZE; + + /* write arguments */ + for (i = 0; i < len; i++) { + writel(arg[i], &mbox_base->cmd_buf[cmd_free_offset++]); + /* wrapping around when it reach the buffer size */ + cmd_free_offset %= MBOX_CMD_BUFFER_SIZE; + } + + /* write command valid offset */ + writel(cmd_free_offset, &mbox_base->cin); + return 0; +} + +/* Support one command and up to 31 words argument length only */ +int mbox_send_cmd(u8 id, u32 cmd, u32 len, u32 *arg, u8 urgent, + u32 *resp_buf_len, u32 *resp_buf) +{ + u32 header; + u32 rin; + u32 resp; + u32 rout; + u32 status; + u32 resp_len; + u32 buf_len; + int ret; + + /* Total lenght is command + argument length */ + if ((len + 1) > MBOX_CMD_BUFFER_SIZE) { + error("ERROR: command %d arguments too long, max %d\n", cmd, + MBOX_CMD_BUFFER_SIZE - 1); + return -EINVAL; + } + + if (cmd > MBOX_MAX_CMD_INDEX) { + error("ERROR: Unsupported command index %d\n", cmd); + return -EINVAL; + } + + header = MBOX_CMD_HEADER(MBOX_CLIENT_ID_UBOOT, id , len, cmd); + + ret = mbox_fill_cmd_circular_buff(header, len, arg); + if (ret) + return ret; + + if (urgent) { + /* Send command as urgent command */ + writel(1, &mbox_base->urg); + } + + /* write doorbell */ + writel(1, MBOX_DOORBELL_TO_SDM_REG); + + while (1) { + /* Wait for doorbell from SDM */ + ret = wait_for_bit(__func__, + (const u32 *)MBOX_DOORBELL_FROM_SDM_REG, + 1, true, 500000, false); + if (ret) { + error("mailbox: timeout from SDM\n"); + return ret; + } + + /* clear interrupt */ + writel(0, MBOX_DOORBELL_FROM_SDM_REG); + + if (urgent) { + /* urgent command doesn't has response */ + writel(0, &mbox_base->urg); + status = readl(&mbox_base->status); + if (status & MBOX_STATUS_UA_MSK) + return 0; + + error("mailbox: cmd %d no urgent ACK\n", cmd); + return -1; + } + + /* read current response offset */ + rout = readl(&mbox_base->rout); + + /* read response valid offset */ + rin = readl(&mbox_base->rin); + + if (rout != rin) { + /* Response received */ + resp = readl(&mbox_base->resp_buf[rout]); + rout++; + /* wrapping around when it reach the buffer size */ + rout %= MBOX_RESP_BUFFER_SIZE; + /* update next ROUT */ + writel(rout, &mbox_base->rout); + + /* check client ID and ID */ + if ((MBOX_RESP_CLIENT_GET(resp) == + MBOX_CLIENT_ID_UBOOT) && + (MBOX_RESP_ID_GET(resp) == id)) { + ret = MBOX_RESP_ERR_GET(resp); + if (ret) { + error("mailbox send command %d error %d\n", + cmd, ret); + return ret; + } + + if (resp_buf_len) { + buf_len = *resp_buf_len; + *resp_buf_len = 0; + } else { + buf_len = 0; + } + + resp_len = MBOX_RESP_LEN_GET(resp); + while (resp_len) { + ret = mbox_polling_resp(rout); + if (ret) + return ret; + /* we need to process response buffer + even caller doesn't need it */ + resp = readl(&mbox_base->resp_buf[rout]); + rout++; + resp_len--; + rout %= MBOX_RESP_BUFFER_SIZE; + writel(rout, &mbox_base->rout); + if (buf_len) { + /* copy response to buffer */ + resp_buf[*resp_buf_len] = resp; + (*resp_buf_len)++; + buf_len--; + } + } + return ret; + } + } + }; + + return -EIO; +} + +int mbox_init(void) +{ + int ret; + + /* enable mailbox interrupts */ + writel(MBOX_ALL_INTRS, &mbox_base->flags); + + ret = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_RESTART, 0, NULL, 1, 0, NULL); + if (ret) + return ret; + + /* Renable mailbox interrupts after MBOX_RESTART */ + writel(MBOX_ALL_INTRS, &mbox_base->flags); + + return 0; +} + +#ifdef CONFIG_CADENCE_QSPI +int mbox_qspi_close(void) +{ + return mbox_send_cmd(MBOX_ID_UBOOT, MBOX_QSPI_CLOSE, 0, NULL, 0, 0, + NULL); +} + +int mbox_qspi_open(void) +{ + int ret; + + ret = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_QSPI_OPEN, 0, NULL, 0, 0, NULL); + if (ret) + return ret; + + ret = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_QSPI_DIRECT, 0, NULL, 0, 0, + NULL); + if (ret) + goto error; + + return ret; + +error: + mbox_qspi_close(); + + return ret; +} +#endif /* CONFIG_CADENCE_QSPI */ +
Add MMU support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/mmu-arm64_s10.c | 71 +++++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+) create mode 100644 arch/arm/mach-socfpga/mmu-arm64_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 43e18d2..098e5e9 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -34,6 +34,7 @@ ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o obj-y += mailbox_s10.o obj-y += misc_s10.o +obj-y += mmu-arm64_s10.o obj-y += reset_manager_s10.o obj-y += system_manager_s10.o obj-y += wrap_pinmux_config_s10.o diff --git a/arch/arm/mach-socfpga/mmu-arm64_s10.c b/arch/arm/mach-socfpga/mmu-arm64_s10.c new file mode 100644 index 0000000..91c7f2e --- /dev/null +++ b/arch/arm/mach-socfpga/mmu-arm64_s10.c @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct mm_region socfpga_stratix10_mem_map[] = { + { + /* MEM 2GB*/ + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* FPGA 1.5GB */ + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x60000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* DEVICE 142MB */ + .virt = 0xF7000000UL, + .phys = 0xF7000000UL, + .size = 0x08E00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* OCRAM 1MB but available 256KB */ + .virt = 0xFFE00000UL, + .phys = 0xFFE00000UL, + .size = 0x00100000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* DEVICE 32KB */ + .virt = 0xFFFC0000UL, + .phys = 0xFFFC0000UL, + .size = 0x00008000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* MEM 124GB */ + .virt = 0x0100000000UL, + .phys = 0x0100000000UL, + .size = 0x1F00000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* DEVICE 4GB */ + .virt = 0x2000000000UL, + .phys = 0x2000000000UL, + .size = 0x0100000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* List terminator */ + }, +}; + +struct mm_region *mem_map = socfpga_stratix10_mem_map;
Restructure the SPL so each devices such as CV, A10 and S10 will have their own dedicated SPL file. SPL file determine the HW initialization flow which is device specific
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 5 +- arch/arm/mach-socfpga/spl_a10.c | 105 ++++++++++++++++++++++++++++ arch/arm/mach-socfpga/{spl.c => spl_gen5.c} | 46 ------------ 3 files changed, 109 insertions(+), 47 deletions(-) create mode 100644 arch/arm/mach-socfpga/spl_a10.c rename arch/arm/mach-socfpga/{spl.c => spl_gen5.c} (83%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 098e5e9..b669d43 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -41,13 +41,16 @@ obj-y += wrap_pinmux_config_s10.o obj-y += wrap_pll_config_s10.o endif ifdef CONFIG_SPL_BUILD -obj-y += spl.o ifdef CONFIG_TARGET_SOCFPGA_GEN5 +obj-y += spl_gen5.o obj-y += freeze_controller.o obj-y += wrap_iocsr_config.o obj-y += wrap_pinmux_config.o obj-y += wrap_sdram_config.o endif +ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 +obj-y += spl_a10.o +endif endif
ifdef CONFIG_TARGET_SOCFPGA_GEN5 diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c new file mode 100644 index 0000000..e6fc766 --- /dev/null +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -0,0 +1,105 @@ +/* + * Copyright (C) 2012 Altera Corporation <www.altera.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/pl310.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <image.h> +#include <asm/arch/reset_manager.h> +#include <spl.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/freeze_controller.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/scan_manager.h> +#include <asm/arch/sdram.h> +#include <asm/arch/scu.h> +#include <asm/arch/nic301.h> +#include <asm/sections.h> +#include <fdtdec.h> +#include <watchdog.h> +#include <asm/arch/pinmux.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_system_manager *sysmgr_regs = + (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; + +u32 spl_boot_device(void) +{ + const u32 bsel = readl(&sysmgr_regs->bootinfo); + + switch (SYSMGR_GET_BOOTINFO_BSEL(bsel)) { + case 0x1: /* FPGA (HPS2FPGA Bridge) */ + return BOOT_DEVICE_RAM; + case 0x2: /* NAND Flash (1.8V) */ + case 0x3: /* NAND Flash (3.0V) */ + socfpga_per_reset(SOCFPGA_RESET(NAND), 0); + return BOOT_DEVICE_NAND; + case 0x4: /* SD/MMC External Transceiver (1.8V) */ + case 0x5: /* SD/MMC Internal Transceiver (3.0V) */ + socfpga_per_reset(SOCFPGA_RESET(SDMMC), 0); + socfpga_per_reset(SOCFPGA_RESET(DMA), 0); + return BOOT_DEVICE_MMC1; + case 0x6: /* QSPI Flash (1.8V) */ + case 0x7: /* QSPI Flash (3.0V) */ + socfpga_per_reset(SOCFPGA_RESET(QSPI), 0); + return BOOT_DEVICE_SPI; + default: + printf("Invalid boot device (bsel=%08x)!\n", bsel); + hang(); + } +} + +#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_boot_mode(const u32 boot_device) +{ +#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif +} +#endif + +void spl_board_init(void) +{ + /* configuring the clock based on handoff */ + cm_basic_init(gd->fdt_blob); + WATCHDOG_RESET(); + + config_dedicated_pins(gd->fdt_blob); + WATCHDOG_RESET(); + + /* Release UART from reset */ + socfpga_reset_uart(0); + + /* enable console uart printing */ + preloader_console_init(); +} + +void board_init_f(ulong dummy) +{ + /* + * Configure Clock Manager to use intosc clock instead external osc to + * ensure success watchdog operation. We do it as early as possible. + */ + cm_use_intosc(); + + socfpga_watchdog_disable(); + + arch_early_init_r(); + +#ifdef CONFIG_HW_WATCHDOG + /* release osc1 watchdog timer 0 from reset */ + socfpga_reset_deassert_osc1wd0(); + + /* reconfigure and enable the watchdog */ + hw_watchdog_init(); + WATCHDOG_RESET(); +#endif /* CONFIG_HW_WATCHDOG */ +} diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl_gen5.c similarity index 83% rename from arch/arm/mach-socfpga/spl.c rename to arch/arm/mach-socfpga/spl_gen5.c index 71bae82..9864082 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -22,21 +22,15 @@ #include <asm/sections.h> #include <fdtdec.h> #include <watchdog.h> -#if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -#include <asm/arch/pinmux.h> -#endif
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; -#endif - static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
@@ -77,7 +71,6 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
-#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { writel(0x1, &nic301_regs->lwhps2fpgaregs); @@ -193,42 +186,3 @@ void board_init_f(ulong dummy) /* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); } -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -void spl_board_init(void) -{ - /* configuring the clock based on handoff */ - cm_basic_init(gd->fdt_blob); - WATCHDOG_RESET(); - - config_dedicated_pins(gd->fdt_blob); - WATCHDOG_RESET(); - - /* Release UART from reset */ - socfpga_reset_uart(0); - - /* enable console uart printing */ - preloader_console_init(); -} - -void board_init_f(ulong dummy) -{ - /* - * Configure Clock Manager to use intosc clock instead external osc to - * ensure success watchdog operation. We do it as early as possible. - */ - cm_use_intosc(); - - socfpga_watchdog_disable(); - - arch_early_init_r(); - -#ifdef CONFIG_HW_WATCHDOG - /* release osc1 watchdog timer 0 from reset */ - socfpga_reset_deassert_osc1wd0(); - - /* reconfigure and enable the watchdog */ - hw_watchdog_init(); - WATCHDOG_RESET(); -#endif /* CONFIG_HW_WATCHDOG */ -} -#endif
Add SPL driver support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/Makefile | 4 + arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 4 + arch/arm/mach-socfpga/include/mach/firewall_s10.h | 84 +++++++++++++ arch/arm/mach-socfpga/spl_s10.c | 138 +++++++++++++++++++++ 4 files changed, 230 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/firewall_s10.h create mode 100644 arch/arm/mach-socfpga/spl_s10.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index b669d43..35b124a 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -40,6 +40,7 @@ obj-y += system_manager_s10.o obj-y += wrap_pinmux_config_s10.o obj-y += wrap_pll_config_s10.o endif + ifdef CONFIG_SPL_BUILD ifdef CONFIG_TARGET_SOCFPGA_GEN5 obj-y += spl_gen5.o @@ -51,6 +52,9 @@ endif ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 obj-y += spl_a10.o endif +ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 +obj-y += spl_s10.o +endif endif
ifdef CONFIG_TARGET_SOCFPGA_GEN5 diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h index feb1881..d79b9cd 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h @@ -45,6 +45,10 @@ #define SOCFPGA_RSTMGR_ADDRESS 0xffd11000 #define SOCFPGA_SYSMGR_ADDRESS 0xffd12000 #define SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS 0xffd13000 +#define SOCFPGA_FIREWALL_L4_PER 0xffd21000 +#define SOCFPGA_FIREWALL_L4_SYS 0xffd21100 +#define SOCFPGA_FIREWALL_SOC2FPGA 0xffd21200 +#define SOCFPGA_FIREWALL_LWSOC2FPGA 0xffd21300 #define SOCFPGA_DMANONSECURE_ADDRESS 0xffda0000 #define SOCFPGA_DMASECURE_ADDRESS 0xffda1000 #define SOCFPGA_SPIS0_ADDRESS 0xffda2000 diff --git a/arch/arm/mach-socfpga/include/mach/firewall_s10.h b/arch/arm/mach-socfpga/include/mach/firewall_s10.h new file mode 100644 index 0000000..6894bb9 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/firewall_s10.h @@ -0,0 +1,84 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _FIREWALL_S10_ +#define _FIREWALL_S10_ + +struct socfpga_firwall_l4_per { + u32 nand; /* 0x00 */ + u32 nand_data; + u32 _pad_0x8; + u32 usb0; + u32 usb1; /* 0x10 */ + u32 _pad_0x14; + u32 _pad_0x18; + u32 spim0; + u32 spim1; /* 0x20 */ + u32 spis0; + u32 spis1; + u32 emac0; + u32 emac1; /* 0x30 */ + u32 emac2; + u32 _pad_0x38; + u32 _pad_0x3c; + u32 sdmmc; /* 0x40 */ + u32 gpio0; + u32 gpio1; + u32 _pad_0x4c; + u32 i2c0; /* 0x50 */ + u32 i2c1; + u32 i2c2; + u32 i2c3; + u32 i2c4; /* 0x60 */ + u32 timer0; + u32 timer1; + u32 uart0; + u32 uart1; /* 0x70 */ +}; + +struct socfpga_firwall_l4_sys { + u32 _pad_0x00; /* 0x00 */ + u32 _pad_0x04; + u32 dma_ecc; + u32 emac0rx_ecc; + u32 emac0tx_ecc; /* 0x10 */ + u32 emac1rx_ecc; + u32 emac1tx_ecc; + u32 emac2rx_ecc; + u32 emac2tx_ecc; /* 0x20 */ + u32 _pad_0x24; + u32 _pad_0x28; + u32 nand_ecc; + u32 nand_read_ecc; /* 0x30 */ + u32 nand_write_ecc; + u32 ocram_ecc; + u32 _pad_0x3c; + u32 sdmmc_ecc; /* 0x40 */ + u32 usb0_ecc; + u32 usb1_ecc; + u32 clock_manager; + u32 _pad_0x50; /* 0x50 */ + u32 io_manager; + u32 reset_manager; + u32 system_manager; + u32 osc0_timer; /* 0x60 */ + u32 osc1_timer; + u32 watchdog0; + u32 watchdog1; + u32 watchdog2; /* 0x70 */ + u32 watchdog3; +}; + +#define FIREWALL_L4_DISABLE_ALL (BIT(0) | BIT(24) | BIT(16)) +#define FIREWALL_BRIDGE_DISABLE_ALL (~0) + +#define CCU_CPU0_MPRT_ADMASK_MEM_RAM0_ADDR 0xf7004688 +#define CCU_IOM_MPRT_ADMASK_MEM_RAM0_ADDR 0xf7018628 + +#define CCU_ADMASK_P_MASK (BIT(0)) +#define CCU_ADMASK_NS_MASK (BIT(1)) + +#endif /* _FIREWALL_S10_ */ diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c new file mode 100644 index 0000000..12cafe6 --- /dev/null +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -0,0 +1,138 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <image.h> +#include <asm/arch/reset_manager.h> +#include <spl.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/clock_manager.h> +#include <asm/arch/sdram_s10.h> +#include <asm/arch/mailbox_s10.h> +#include <asm/arch/firewall_s10.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_firwall_l4_per *firwall_l4_per_base = + (struct socfpga_firwall_l4_per *)SOCFPGA_FIREWALL_L4_PER; +static const struct socfpga_firwall_l4_sys *firwall_l4_sys_base = + (struct socfpga_firwall_l4_sys *)SOCFPGA_FIREWALL_L4_SYS; + +u32 spl_boot_device(void) +{ + /* TODO: Get from SDM or handoff */ +/* #ifdef CONFIG_CADENCE_QSPI*/ +#if 0 + return BOOT_DEVICE_SPI; +#else + return BOOT_DEVICE_MMC1; +#endif +} + +#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_boot_mode(const u32 boot_device) +{ +#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif +} +#endif + +void board_init_f(ulong dummy) +{ + const struct cm_config *cm_default_cfg = cm_get_default_config(); + + socfpga_per_reset(SOCFPGA_RESET(OSC1TIMER0), 0); + timer_init(); + + populate_sysmgr_pinmux(); + + /* configuring the HPS clocks */ + cm_basic_init(cm_default_cfg); + + /* enable console uart printing */ +#if (CONFIG_SYS_NS16550_COM1 == SOCFPGA_UART0_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(UART0), 0); + /* enables nonsecure access to UART0 */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->uart0); +#elif (CONFIG_SYS_NS16550_COM1 == SOCFPGA_UART1_ADDRESS) + socfpga_per_reset(SOCFPGA_RESET(UART1), 0); + /* enables nonsecure access to UART1 */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->uart1); +#endif + + preloader_console_init(); + cm_print_clock_quick_summary(); + + /* enable all EMACs */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->emac0); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->emac1); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->emac2); + /* enables nonsecure access to all the emacs */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac0rx_ecc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac0tx_ecc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac1rx_ecc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac1tx_ecc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac2rx_ecc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->emac2tx_ecc); + + /* enables SDMMC */ + socfpga_per_reset(SOCFPGA_RESET(SDMMC_OCP), 0); + socfpga_per_reset(SOCFPGA_RESET(SDMMC), 0); + /* Enables nonsecure access to SDMMC */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->sdmmc); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->sdmmc_ecc); + + /* enable i2c0 and i2c1 */ + socfpga_per_reset(SOCFPGA_RESET(I2C0), 0); + socfpga_per_reset(SOCFPGA_RESET(I2C1), 0); + /* enables nonsecure access to i2c0 and i2c1 */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->i2c0); + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_per_base->i2c1); + + /* disable lwsocf2fpga and soc2fpga bridge security */ + writel(FIREWALL_BRIDGE_DISABLE_ALL, SOCFPGA_FIREWALL_SOC2FPGA); + writel(FIREWALL_BRIDGE_DISABLE_ALL, SOCFPGA_FIREWALL_LWSOC2FPGA); + + /* enables nonsecure access to clock mgr */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->clock_manager); + + /* enables nonsecure access to OCRAM */ + writel(FIREWALL_L4_DISABLE_ALL, &firwall_l4_sys_base->ocram_ecc); + + /* disable ocram security at CCU for non secure access */ + clrbits_le32(CCU_CPU0_MPRT_ADMASK_MEM_RAM0_ADDR, + CCU_ADMASK_P_MASK | CCU_ADMASK_NS_MASK); + clrbits_le32(CCU_IOM_MPRT_ADMASK_MEM_RAM0_ADDR, + CCU_ADMASK_P_MASK | CCU_ADMASK_NS_MASK); + + puts("DDR: Initializing Hard Memory Controller\n"); + if (sdram_mmr_init_full(0)) { + puts("DDR: Initialization failed.\n"); + hang(); + } + + gd->ram_size = sdram_calculate_size(); + printf("DDR: %d MiB\n", (int)(gd->ram_size >> 20)); + + /* Sanity check ensure correct SDRAM size specified */ + puts("DDR: Running SDRAM size sanity check\n"); + if (get_ram_size(0, gd->ram_size) != gd->ram_size) { + puts("DDR: SDRAM size check failed!\n"); + hang(); + } + puts("DDR: SDRAM size check passed!\n"); + +#ifdef CONFIG_CADENCE_QSPI + mbox_init(); + mbox_qspi_open(); +#endif +}
Add timer support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/timer.c | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/timer.c b/arch/arm/mach-socfpga/timer.c index 253cde3..23450b0 100644 --- a/arch/arm/mach-socfpga/timer.c +++ b/arch/arm/mach-socfpga/timer.c @@ -1,5 +1,6 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * Copyright (C) 2012-2016 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,15 +11,29 @@
#define TIMER_LOAD_VAL 0xFFFFFFFF
+#if !defined(CONFIG_TARGET_SOCFPGA_STRATIX10) static const struct socfpga_timer *timer_base = (void *)CONFIG_SYS_TIMERBASE; +#endif
/* * Timer initialization */ int timer_init(void) { +#if defined(CONFIG_TARGET_SOCFPGA_STRATIX10) + int enable = 0x3; /* timer enable + output signal masked */ + int loadval = ~0; + + /* enable system counter */ + writel(enable, SOCFPGA_GTIMER_SEC_ADDRESS); + /* enable processor pysical counter */ + asm volatile("msr cntp_ctl_el0, %0" : : "r" (enable)); + asm volatile("msr cntp_tval_el0, %0" : : "r" (loadval)); + +#else writel(TIMER_LOAD_VAL, &timer_base->load_val); writel(TIMER_LOAD_VAL, &timer_base->curr_val); writel(readl(&timer_base->ctrl) | 0x3, &timer_base->ctrl); +#endif return 0; }
Add DDR support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/mach-socfpga/include/mach/sdram_s10.h | 333 +++++++++++++++++++++ drivers/ddr/altera/Makefile | 1 + drivers/ddr/altera/sdram_s10.c | 382 +++++++++++++++++++++++++ 3 files changed, 716 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/sdram_s10.h create mode 100644 drivers/ddr/altera/sdram_s10.c
diff --git a/arch/arm/mach-socfpga/include/mach/sdram_s10.h b/arch/arm/mach-socfpga/include/mach/sdram_s10.h new file mode 100644 index 0000000..d0fd958 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/sdram_s10.h @@ -0,0 +1,333 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SDRAM_S10_H_ +#define _SDRAM_S10_H_ + +unsigned long sdram_calculate_size(void); +int sdram_mmr_init_full(unsigned int sdr_phy_reg); +int sdram_calibration_full(void); + +#define DDR_TWR 15 +#define DDR_READ_LATENCY_DELAY 40 +#define DDR_ACTIVATE_FAWBANK 0x1 + + +struct socfpga_ecc_hmc { + uint32_t ip_rev_id; + uint32_t _pad_0x4_0x7; + uint32_t ddrioctrl; + uint32_t ddrcalstat; + uint32_t mpr_0beat1; + uint32_t mpr_1beat1; + uint32_t mpr_2beat1; + uint32_t mpr_3beat1; + uint32_t mpr_4beat1; + uint32_t mpr_5beat1; + uint32_t mpr_6beat1; + uint32_t mpr_7beat1; + uint32_t mpr_8beat1; + uint32_t mpr_0beat2; + uint32_t mpr_1beat2; + uint32_t mpr_2beat2; + uint32_t mpr_3beat2; + uint32_t mpr_4beat2; + uint32_t mpr_5beat2; + uint32_t mpr_6beat2; + uint32_t mpr_7beat2; + uint32_t mpr_8beat2; + uint32_t _pad_0x58_0x5f[2]; + uint32_t auto_precharge; + uint32_t _pad_0x64_0xdf[31]; + uint32_t dramaddrwidth; + uint32_t _pad_0xe4_0xff[7]; + uint32_t eccctrl; + uint32_t eccctrl2; + uint32_t _pad_0x108_0x10f[2]; + uint32_t errinten; + uint32_t errintens; + uint32_t errintenr; + uint32_t intmode; + uint32_t intstat; + uint32_t diaginttest; + uint32_t modstat; + uint32_t derraddra; + uint32_t serraddra; + uint32_t _pad_0x134_0x137; + uint32_t autowb_corraddr; + uint32_t serrcntreg; + uint32_t autowb_drop_cntreg; + uint32_t ecc_reg2wreccdatabus; + uint32_t ecc_rdeccdata2regbus; + uint32_t ecc_reg2rdeccdatabus; + uint32_t ecc_diagon; + uint32_t ecc_decstat; + uint32_t _pad_0x158_0x15f[2]; + uint32_t ecc_errgenaddr_0; + uint32_t ecc_errgenaddr_1; + uint32_t ecc_errgenaddr_2; + uint32_t ecc_errgenaddr_3; + uint32_t ecc_ref2rddatabus_beat0; + uint32_t ecc_ref2rddatabus_beat1; + uint32_t ecc_ref2rddatabus_beat2; + uint32_t ecc_ref2rddatabus_beat3; + uint32_t ecc_errgenhaddr_0; + uint32_t ecc_errgenhaddr_1; + uint32_t ecc_errgenhaddr_2; + uint32_t ecc_errgenhaddr_3; + uint32_t ecc_rdeccdata2regbus_beat0; + uint32_t ecc_rdeccdata2regbus_beat1; + uint32_t ecc_rdeccdata2regbus_beat2; + uint32_t ecc_rdeccdata2regbus_beat3; + uint32_t _pad_0x1a0_0x1af[4]; + uint32_t derrhaddr; + uint32_t serrhaddr; + uint32_t _pad_0x1b8_0x1bb; + uint32_t autowb_corrhaddr; + uint32_t _pad_0x1c0_0x20f[20]; + uint32_t hpsintfcsel; + uint32_t rsthandshakectrl; + uint32_t rsthandshakestat; +}; + +struct socfpga_noc_ddr_scheduler { + uint32_t main_scheduler_id_coreid; + uint32_t main_scheduler_id_revisionid; + uint32_t main_scheduler_ddrconf; + uint32_t main_scheduler_ddrtiming; + uint32_t main_scheduler_ddrmode; + uint32_t main_scheduler_readlatency; + uint32_t _pad_0x18_0x37[8]; + uint32_t main_scheduler_activate; + uint32_t main_scheduler_devtodev; + uint32_t main_scheduler_ddr4timing; +}; + +struct socfpga_io48_mmr { + uint32_t dbgcfg0; + uint32_t dbgcfg1; + uint32_t dbgcfg2; + uint32_t dbgcfg3; + uint32_t dbgcfg4; + uint32_t dbgcfg5; + uint32_t dbgcfg6; + uint32_t reserve0; + uint32_t reserve1; + uint32_t reserve2; + uint32_t ctrlcfg0; + uint32_t ctrlcfg1; + uint32_t ctrlcfg2; + uint32_t ctrlcfg3; + uint32_t ctrlcfg4; + uint32_t ctrlcfg5; + uint32_t ctrlcfg6; + uint32_t ctrlcfg7; + uint32_t ctrlcfg8; + uint32_t ctrlcfg9; + uint32_t dramtiming0; + uint32_t dramodt0; + uint32_t dramodt1; + uint32_t sbcfg0; + uint32_t sbcfg1; + uint32_t sbcfg2; + uint32_t sbcfg3; + uint32_t sbcfg4; + uint32_t sbcfg5; + uint32_t sbcfg6; + uint32_t sbcfg7; + uint32_t caltiming0; + uint32_t caltiming1; + uint32_t caltiming2; + uint32_t caltiming3; + uint32_t caltiming4; + uint32_t caltiming5; + uint32_t caltiming6; + uint32_t caltiming7; + uint32_t caltiming8; + uint32_t caltiming9; + uint32_t caltiming10; + uint32_t dramaddrw; + uint32_t sideband0; + uint32_t sideband1; + uint32_t sideband2; + uint32_t sideband3; + uint32_t sideband4; + uint32_t sideband5; + uint32_t sideband6; + uint32_t sideband7; + uint32_t sideband8; + uint32_t sideband9; + uint32_t sideband10; + uint32_t sideband11; + uint32_t sideband12; + uint32_t sideband13; + uint32_t sideband14; + uint32_t sideband15; + uint32_t dramsts; + uint32_t dbgdone; + uint32_t dbgsignals; + uint32_t dbgreset; + uint32_t dbgmatch; + uint32_t counter0mask; + uint32_t counter1mask; + uint32_t counter0match; + uint32_t counter1match; + uint32_t niosreserve0; + uint32_t niosreserve1; + uint32_t niosreserve2; +}; + +union dramaddrw_reg { + struct { + u32 cfg_col_addr_width:5; + u32 cfg_row_addr_width:5; + u32 cfg_bank_addr_width:4; + u32 cfg_bank_group_addr_width:2; + u32 cfg_cs_addr_width:3; + u32 reserved:13; + }; + u32 word; +}; + +union ctrlcfg0_reg { + struct { + u32 cfg_mem_type:4; + u32 cfg_dimm_type:3; + u32 cfg_ac_pos:2; + u32 cfg_ctrl_burst_len:5; + u32 reserved:18; /* Other fields unused */ + }; + u32 word; +}; + +union ctrlcfg1_reg { + struct { + u32 cfg_dbc3_burst_len:5; + u32 cfg_addr_order:2; + u32 cfg_ctrl_enable_ecc:1; + u32 reserved:24; /* Other fields unused */ + }; + u32 word; +}; + +union dramtiming0_reg { + struct { + u32 cfg_tcl:6; + u32 reserved:8; /* Other fields unused */ + }; + u32 word; +}; + +union caltiming0_reg { + struct { + u32 cfg_act_to_rdwr:6; + u32 cfg_act_to_pch:6; + u32 cfg_act_to_act:6; + u32 cfg_act_to_act_db:6; + u32 reserved:8; /* Other fields unused */ + }; + u32 word; +}; + +union caltiming1_reg { + struct { + u32 cfg_rd_to_rd:6; + u32 cfg_rd_to_rd_dc:6; + u32 cfg_rd_to_rd_db:6; + u32 cfg_rd_to_wr:6; + u32 cfg_rd_to_wr_dc:6; + u32 reserved:2; + }; + u32 word; +}; + +union caltiming2_reg { + struct { + u32 cfg_rd_to_wr_db:6; + u32 cfg_rd_to_pch:6; + u32 cfg_rd_ap_to_valid:6; + u32 cfg_wr_to_wr:6; + u32 cfg_wr_to_wr_dc:6; + u32 reserved:2; + }; + u32 word; +}; + +union caltiming3_reg { + struct { + u32 cfg_wr_to_wr_db:6; + u32 cfg_wr_to_rd:6; + u32 cfg_wr_to_rd_dc:6; + u32 cfg_wr_to_rd_db:6; + u32 cfg_wr_to_pch:6; + u32 reserved:2; + }; + u32 word; +}; + +union caltiming4_reg { + struct { + u32 cfg_wr_ap_to_valid:6; + u32 cfg_pch_to_valid:6; + u32 cfg_pch_all_to_valid:6; + u32 cfg_arf_to_valid:8; + u32 cfg_pdn_to_valid:6; + }; + u32 word; +}; + +union caltiming9_reg { + struct { + u32 cfg_4_act_to_act:8; + u32 reserved:24; + }; + u32 word; +}; + +#define DDR_SCHED_DDRTIMING_ACTTOACT_OFFSET 0 +#define DDR_SCHED_DDRTIMING_RDTOMISS_OFFSET 6 +#define DDR_SCHED_DDRTIMING_WRTOMISS_OFFSET 12 +#define DDR_SCHED_DDRTIMING_BURSTLEN_OFFSET 18 +#define DDR_SCHED_DDRTIMING_RDTOWR_OFFSET 21 +#define DDR_SCHED_DDRTIMING_WRTORD_OFFSET 26 +#define DDR_SCHED_DDRTIMING_BWRATIO_OFFSET 31 +#define DDR_SCHED_DDRMOD_BWRATIOEXTENDED_OFFSET 1 +#define DDR_SCHED_ACTIVATE_RRD_OFFSET 0 +#define DDR_SCHED_ACTIVATE_FAW_OFFSET 4 +#define DDR_SCHED_ACTIVATE_FAWBANK_OFFSET 10 +#define DDR_SCHED_DEVTODEV_BUSRDTORD_OFFSET 0 +#define DDR_SCHED_DEVTODEV_BUSRDTOWR_OFFSET 2 +#define DDR_SCHED_DEVTODEV_BUSWRTORD_OFFSET 4 +#define DDR_HMC_DDRIOCTRL_IOSIZE_MSK 0x00000003 +#define DDR_HMC_DDRCALSTAT_CAL_MSK 0x00000001 +#define DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK 0x00010000 +#define DDR_HMC_ECCCTL_CNT_RST_SET_MSK 0x00000100 +#define DDR_HMC_ECCCTL_ECC_EN_SET_MSK 0x00000001 +#define DDR_HMC_ECCCTL2_RMW_EN_SET_MSK 0x00000100 +#define DDR_HMC_ECCCTL2_AWB_EN_SET_MSK 0x00000001 +#define DDR_HMC_RSTHANDSHAKE_MASK 0x000000ff +#define DDR_HMC_CORE2SEQ_INT_REQ 0xF +#define DDR_HMC_SEQ2CORE_INT_RESP_MASK 0x8 +#define DDR_HMC_HPSINTFCSEL_ENABLE_MASK 0x001f1f1f + +#define CCU_CPU0_MPRT_ADBASE_DDRREG_ADDR 0xf7004400 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE0_ADDR 0xf70045c0 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE1A_ADDR 0xf70045e0 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE1B_ADDR 0xf7004600 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE1C_ADDR 0xf7004620 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE1D_ADDR 0xf7004640 +#define CCU_CPU0_MPRT_ADBASE_MEMSPACE1E_ADDR 0xf7004660 + +#define CCU_IOM_MPRT_ADBASE_MEMSPACE0_ADDR 0xf7018560 +#define CCU_IOM_MPRT_ADBASE_MEMSPACE1A_ADDR 0xf7018580 +#define CCU_IOM_MPRT_ADBASE_MEMSPACE1B_ADDR 0xf70185a0 +#define CCU_IOM_MPRT_ADBASE_MEMSPACE1C_ADDR 0xf70185c0 +#define CCU_IOM_MPRT_ADBASE_MEMSPACE1D_ADDR 0xf70185e0 +#define CCU_IOM_MPRT_ADBASE_MEMSPACE1E_ADDR 0xf7018600 + +#define CCU_ADBASE_DI_MASK 0x00000010 + +#endif /* _SDRAM_S10_H_ */ diff --git a/drivers/ddr/altera/Makefile b/drivers/ddr/altera/Makefile index bdd2872..943b6cd 100644 --- a/drivers/ddr/altera/Makefile +++ b/drivers/ddr/altera/Makefile @@ -10,4 +10,5 @@
ifdef CONFIG_ALTERA_SDRAM obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += sdram.o sequencer.o +obj-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += sdram_s10.o endif diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c new file mode 100644 index 0000000..c488caf --- /dev/null +++ b/drivers/ddr/altera/sdram_s10.c @@ -0,0 +1,382 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <errno.h> +#include <div64.h> +#include <asm/io.h> +#include <watchdog.h> +#include <asm/arch/sdram_s10.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/reset_manager.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_ecc_hmc *socfpga_ecc_hmc_base = + (void *)SOCFPGA_SDR_ADDRESS; +static const struct socfpga_noc_ddr_scheduler *socfpga_noc_ddr_scheduler_base = + (void *)SOCFPGA_SDR_SCHEDULER_ADDRESS; +static const struct socfpga_io48_mmr *socfpga_io48_mmr_base = + (void *)SOCFPGA_HMC_MMR_IO48_ADDRESS; +static const struct socfpga_system_manager *sysmgr_regs = + (void *)SOCFPGA_SYSMGR_ADDRESS; + +#define DDR_CONFIG(A, B, C, R) ((A<<24)|(B<<16)|(C<<8)|R) + +/* The followring are the supported configurations */ +u32 ddr_config[] = { + /* DDR_CONFIG(Address order,Bank,Column,Row) */ + /* List for DDR3 or LPDDR3 (pinout order > chip, row, bank, column) */ + DDR_CONFIG(0, 3, 10, 12), + DDR_CONFIG(0, 3, 9, 13), + DDR_CONFIG(0, 3, 10, 13), + DDR_CONFIG(0, 3, 9, 14), + DDR_CONFIG(0, 3, 10, 14), + DDR_CONFIG(0, 3, 10, 15), + DDR_CONFIG(0, 3, 11, 14), + DDR_CONFIG(0, 3, 11, 15), + DDR_CONFIG(0, 3, 10, 16), + DDR_CONFIG(0, 3, 11, 16), + DDR_CONFIG(0, 3, 12, 15), /* 0xa */ + /* List for DDR4 only (pinout order > chip, bank, row, column) */ + DDR_CONFIG(1, 3, 10, 14), + DDR_CONFIG(1, 4, 10, 14), + DDR_CONFIG(1, 3, 10, 15), + DDR_CONFIG(1, 4, 10, 15), + DDR_CONFIG(1, 3, 10, 16), + DDR_CONFIG(1, 4, 10, 16), + DDR_CONFIG(1, 3, 10, 17), + DDR_CONFIG(1, 4, 10, 17), +}; + +#define DDR_CONFIG_ELEMENTS (sizeof(ddr_config)/sizeof(u32)) + +int match_ddr_conf(u32 ddr_conf) +{ + int i; + for (i = 0; i < DDR_CONFIG_ELEMENTS; i++) { + if (ddr_conf == ddr_config[i]) + return i; + } + return 0; +} + +static int emif_clear(void) +{ + u32 s2c, i; + + writel(0, &socfpga_ecc_hmc_base->rsthandshakectrl); + s2c = readl(&socfpga_ecc_hmc_base->rsthandshakestat) & + DDR_HMC_RSTHANDSHAKE_MASK; + + for (i = 1000; (i > 0) && s2c; i--) { + WATCHDOG_RESET(); + mdelay(1); + s2c = readl(&socfpga_ecc_hmc_base->rsthandshakestat) & + DDR_HMC_RSTHANDSHAKE_MASK; + } + return !s2c; +} + +static int emif_reset(void) +{ + u32 c2s, s2c, i; + + c2s = readl(&socfpga_ecc_hmc_base->rsthandshakectrl) & + DDR_HMC_RSTHANDSHAKE_MASK; + s2c = readl(&socfpga_ecc_hmc_base->rsthandshakestat) & + DDR_HMC_RSTHANDSHAKE_MASK; + + debug("DDR: c2s=%08x s2c=%08x nr0=%08x nr1=%08x nr2=%08x dst=%08x\n", + c2s, s2c, readl(&socfpga_io48_mmr_base->niosreserve0), + readl(&socfpga_io48_mmr_base->niosreserve1), + readl(&socfpga_io48_mmr_base->niosreserve2), + readl(&socfpga_io48_mmr_base->dramsts)); + + if (s2c && emif_clear()) { + printf("DDR: emif_clear() failed\n"); + return -1; + } + + puts("DDR: Triggerring emif_reset\n"); + writel(DDR_HMC_CORE2SEQ_INT_REQ, + &socfpga_ecc_hmc_base->rsthandshakectrl); + + for (i = 1000; i > 0; i--) { + /* if seq2core[3] = 0, we are good */ + if (!(readl(&socfpga_ecc_hmc_base->rsthandshakestat) & + DDR_HMC_SEQ2CORE_INT_RESP_MASK)) + break; + WATCHDOG_RESET(); + mdelay(1); + } + + if (!i) { + printf("DDR: failed to get ack from EMIF\n"); + return -2; + } + + if (emif_clear()) { + printf("DDR: emif_clear() failed\n"); + return -3; + } + + printf("DDR: emif_reset triggered successly\n"); + return 0; +} + +static int poll_hmc_clock_status(void) +{ + u32 status, i; + + for (i = 1000; i > 0; i--) { + status = readl(&sysmgr_regs->hmc_clk) & + SYSMGR_HMC_CLK_STATUS_MSK; + udelay(1); + if (status) + break; + WATCHDOG_RESET(); + } + return status; +} + +/** + * sdram_mmr_init_full() - Function to initialize SDRAM MMR + * + * Initialize the SDRAM MMR. + */ +int sdram_mmr_init_full(unsigned int unused) +{ + u32 update_value, io48_value, ddrioctl; + u32 i, j, cal_success; + + /* Enable access to DDR from CPU master */ + clrbits_le32(CCU_CPU0_MPRT_ADBASE_DDRREG_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE0_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE1A_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE1B_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE1C_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE1D_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_CPU0_MPRT_ADBASE_MEMSPACE1E_ADDR, CCU_ADBASE_DI_MASK); + + /* Enable access to DDR from IO master */ + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE0_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE1A_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE1B_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE1C_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE1D_ADDR, CCU_ADBASE_DI_MASK); + clrbits_le32(CCU_IOM_MPRT_ADBASE_MEMSPACE1E_ADDR, CCU_ADBASE_DI_MASK); + + /* this enables nonsecure access to DDR */ + /* mpuregion0addr_limit */ + writel(0xFFFF0000, 0xF8020118); + writel(0x1F, 0xF802011c); + + /* nonmpuregion0addr_limit */ + writel(0xFFFF0000, 0xF8020198); + writel(0x1F, 0xF802019C); + + /* Enable mpuregion0enable and nonmpuregion0enable */ + writel(BIT(0) | BIT(8), 0xF8020100); + + /* Ensure HMC clock is running */ + if (!poll_hmc_clock_status()) { + puts("DDR: Error as HMC clock not running\n"); + return -1; + } + + /* release DDR scheduler from reset */ + socfpga_per_reset(SOCFPGA_RESET(SDR), 0); + + /* Try 3 times to do a calibration */ + for (i = 0; i < 3; i++) { + cal_success = readl(&socfpga_ecc_hmc_base->ddrcalstat) & + DDR_HMC_DDRCALSTAT_CAL_MSK; + /* A delay to wait for calibration bit to set */ + for (j = 0; (j < 1000) && !cal_success; j++) { + WATCHDOG_RESET(); + mdelay(1); + cal_success = readl(&socfpga_ecc_hmc_base->ddrcalstat) + & DDR_HMC_DDRCALSTAT_CAL_MSK; + } + + if (cal_success) + break; + else + emif_reset(); + } + + if (!cal_success) { + puts("DDR: Error as SDRAM calibration failed\n"); + return -1; + } + puts("DDR: Calibration success\n"); + + union ctrlcfg0_reg ctrlcfg0 = (union ctrlcfg0_reg) + readl(&socfpga_io48_mmr_base->ctrlcfg0); + union ctrlcfg1_reg ctrlcfg1 = (union ctrlcfg1_reg) + readl(&socfpga_io48_mmr_base->ctrlcfg1); + union dramaddrw_reg dramaddrw = (union dramaddrw_reg) + readl(&socfpga_io48_mmr_base->dramaddrw); + union dramtiming0_reg dramtim0 = (union dramtiming0_reg) + readl(&socfpga_io48_mmr_base->dramtiming0); + union caltiming0_reg caltim0 = (union caltiming0_reg) + readl(&socfpga_io48_mmr_base->caltiming0); + union caltiming1_reg caltim1 = (union caltiming1_reg) + readl(&socfpga_io48_mmr_base->caltiming1); + union caltiming2_reg caltim2 = (union caltiming2_reg) + readl(&socfpga_io48_mmr_base->caltiming2); + union caltiming3_reg caltim3 = (union caltiming3_reg) + readl(&socfpga_io48_mmr_base->caltiming3); + union caltiming4_reg caltim4 = (union caltiming4_reg) + readl(&socfpga_io48_mmr_base->caltiming4); + union caltiming9_reg caltim9 = (union caltiming9_reg) + readl(&socfpga_io48_mmr_base->caltiming9); + + /* + * Configure the DDR IO size [0xFFCFB008] + * niosreserve0: Used to indicate DDR width & + * bit[7:0] = Number of data bits (bit[6:5] 0x01=32bit, 0x10=64bit) + * bit[8] = 1 if user-mode OCT is present + * bit[9] = 1 if warm reset compiled into EMIF Cal Code + * bit[10] = 1 if warm reset is on during generation in EMIF Cal + * niosreserve1: IP ADCDS version encoded as 16 bit value + * bit[2:0] = Variant (0=not special,1=FAE beta, 2=Customer beta, + * 3=EAP, 4-6 are reserved) + * bit[5:3] = Service Pack # (e.g. 1) + * bit[9:6] = Minor Release # + * bit[14:10] = Major Release # + */ + update_value = readl(&socfpga_io48_mmr_base->niosreserve0); + writel(((update_value & 0xFF) >> 5), &socfpga_ecc_hmc_base->ddrioctrl); + ddrioctl = readl(&socfpga_ecc_hmc_base->ddrioctrl); + + /* enable HPS interface to HMC */ + writel(DDR_HMC_HPSINTFCSEL_ENABLE_MASK, + &socfpga_ecc_hmc_base->hpsintfcsel); + + /* Set the DDR Configuration */ + io48_value = DDR_CONFIG(ctrlcfg1.cfg_addr_order, + (dramaddrw.cfg_bank_addr_width + + dramaddrw.cfg_bank_group_addr_width), + dramaddrw.cfg_col_addr_width, + dramaddrw.cfg_row_addr_width); + + update_value = match_ddr_conf(io48_value); + if (update_value) + writel(update_value, + &socfpga_noc_ddr_scheduler_base->main_scheduler_ddrconf); + + /* Configure HMC dramaddrw */ + writel(readl(&socfpga_io48_mmr_base->dramaddrw), + &socfpga_ecc_hmc_base->dramaddrwidth); + + /* + * Configure DDR timing + * RDTOMISS = tRTP + tRP + tRCD - BL/2 + * WRTOMISS = WL + tWR + tRP + tRCD and + * WL = RL + BL/2 + 2 - rd-to-wr ; tWR = 15ns so... + * First part of equation is in memory clock units so divide by 2 + * for HMC clock units. 1066MHz is close to 1ns so use 15 directly. + * WRTOMISS = ((RL + BL/2 + 2 + tWR) >> 1)- rd-to-wr + tRP + tRCD + */ + update_value = caltim2.cfg_rd_to_pch + caltim4.cfg_pch_to_valid + + caltim0.cfg_act_to_rdwr - + (ctrlcfg0.cfg_ctrl_burst_len >> 2); + io48_value = (((dramtim0.cfg_tcl + 2 + DDR_TWR + + (ctrlcfg0.cfg_ctrl_burst_len >> 1)) >> 1) - + /* Up to here was in memory cycles so divide by 2 */ + caltim1.cfg_rd_to_wr + caltim0.cfg_act_to_rdwr + + caltim4.cfg_pch_to_valid); + + writel(((caltim0.cfg_act_to_act << DDR_SCHED_DDRTIMING_ACTTOACT_OFFSET) | + (update_value << DDR_SCHED_DDRTIMING_RDTOMISS_OFFSET) | + (io48_value << DDR_SCHED_DDRTIMING_WRTOMISS_OFFSET) | + ((ctrlcfg0.cfg_ctrl_burst_len >> 2) << + DDR_SCHED_DDRTIMING_BURSTLEN_OFFSET) | + (caltim1.cfg_rd_to_wr << DDR_SCHED_DDRTIMING_RDTOWR_OFFSET) | + (caltim3.cfg_wr_to_rd << DDR_SCHED_DDRTIMING_WRTORD_OFFSET) | + (((ddrioctl == 1) ? 1 : 0) << + DDR_SCHED_DDRTIMING_BWRATIO_OFFSET)), + &socfpga_noc_ddr_scheduler_base->main_scheduler_ddrtiming); + + /* Configure DDR mode [precharge = 0] */ + writel(((ddrioctl ? 0 : 1) << DDR_SCHED_DDRMOD_BWRATIOEXTENDED_OFFSET), + &socfpga_noc_ddr_scheduler_base->main_scheduler_ddrmode); + + /* Configure the read latency */ + writel((dramtim0.cfg_tcl >> 1) + DDR_READ_LATENCY_DELAY, + &socfpga_noc_ddr_scheduler_base->main_scheduler_readlatency); + + /* + * Configuring timing values concerning activate commands + * [FAWBANK alway 1 because always 4 bank DDR] + */ + writel(((caltim0.cfg_act_to_act_db << DDR_SCHED_ACTIVATE_RRD_OFFSET) | + (caltim9.cfg_4_act_to_act << DDR_SCHED_ACTIVATE_FAW_OFFSET) | + (DDR_ACTIVATE_FAWBANK << DDR_SCHED_ACTIVATE_FAWBANK_OFFSET)), + &socfpga_noc_ddr_scheduler_base->main_scheduler_activate); + + /* + * Configuring timing values concerning device to device data bus + * ownership change + */ + writel(((caltim1.cfg_rd_to_rd_dc << + DDR_SCHED_DEVTODEV_BUSRDTORD_OFFSET) | + (caltim1.cfg_rd_to_wr_dc << + DDR_SCHED_DEVTODEV_BUSRDTOWR_OFFSET) | + (caltim3.cfg_wr_to_rd_dc << + DDR_SCHED_DEVTODEV_BUSWRTORD_OFFSET)), + &socfpga_noc_ddr_scheduler_base->main_scheduler_devtodev); + + /* Enable or disable the SDRAM ECC */ + if (ctrlcfg1.cfg_ctrl_enable_ecc) { + setbits_le32(&socfpga_ecc_hmc_base->eccctrl, + (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | + DDR_HMC_ECCCTL_CNT_RST_SET_MSK | + DDR_HMC_ECCCTL_ECC_EN_SET_MSK)); + clrbits_le32(&socfpga_ecc_hmc_base->eccctrl, + (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | + DDR_HMC_ECCCTL_CNT_RST_SET_MSK)); + setbits_le32(&socfpga_ecc_hmc_base->eccctrl2, + (DDR_HMC_ECCCTL2_RMW_EN_SET_MSK | + DDR_HMC_ECCCTL2_AWB_EN_SET_MSK)); + } else { + clrbits_le32(&socfpga_ecc_hmc_base->eccctrl, + (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | + DDR_HMC_ECCCTL_CNT_RST_SET_MSK | + DDR_HMC_ECCCTL_ECC_EN_SET_MSK)); + clrbits_le32(&socfpga_ecc_hmc_base->eccctrl2, + (DDR_HMC_ECCCTL2_RMW_EN_SET_MSK | + DDR_HMC_ECCCTL2_AWB_EN_SET_MSK)); + } + + puts("DDR: HMC init success\n"); + return 0; +} + +/** + * sdram_calculate_size() - Calculate SDRAM size + * + * Calculate SDRAM device size based on SDRAM controller parameters. + * Size is specified in bytes. + */ +unsigned long sdram_calculate_size(void) +{ + union dramaddrw_reg dramaddrw = + (union dramaddrw_reg)readl(&socfpga_io48_mmr_base->dramaddrw); + + u32 size = (1 << (dramaddrw.cfg_cs_addr_width + + dramaddrw.cfg_bank_group_addr_width + + dramaddrw.cfg_bank_addr_width + + dramaddrw.cfg_row_addr_width + + dramaddrw.cfg_col_addr_width)); + + size *= (2 << (readl(&socfpga_ecc_hmc_base->ddrioctrl) & + DDR_HMC_DDRIOCTRL_IOSIZE_MSK)); + + return size; +}
Add socdk board support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- board/altera/stratix10-socdk/MAINTAINERS | 7 +++++++ board/altera/stratix10-socdk/Makefile | 7 +++++++ board/altera/stratix10-socdk/socfpga.c | 7 +++++++ 3 files changed, 21 insertions(+) create mode 100644 board/altera/stratix10-socdk/MAINTAINERS create mode 100644 board/altera/stratix10-socdk/Makefile create mode 100644 board/altera/stratix10-socdk/socfpga.c
diff --git a/board/altera/stratix10-socdk/MAINTAINERS b/board/altera/stratix10-socdk/MAINTAINERS new file mode 100644 index 0000000..6192bc9 --- /dev/null +++ b/board/altera/stratix10-socdk/MAINTAINERS @@ -0,0 +1,7 @@ +SOCFPGA BOARD +M: Chin-Liang See chin.liang.see@intel.com +M: Dinh Nguyen dinh.nguyen@intel.com +S: Maintained +F: board/altera/stratix10-socdk/ +F: include/configs/socfpga_stratix10_socdk.h +F: configs/socfpga_stratix10_defconfig diff --git a/board/altera/stratix10-socdk/Makefile b/board/altera/stratix10-socdk/Makefile new file mode 100644 index 0000000..02a9cad --- /dev/null +++ b/board/altera/stratix10-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2016-2017 Intel Corporation <www.intel.com> +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/altera/stratix10-socdk/socfpga.c b/board/altera/stratix10-socdk/socfpga.c new file mode 100644 index 0000000..3deb989 --- /dev/null +++ b/board/altera/stratix10-socdk/socfpga.c @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h>
Add build support for Stratix SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- arch/arm/Kconfig | 8 +- arch/arm/mach-socfpga/Kconfig | 13 ++ configs/socfpga_stratix10_defconfig | 39 ++++++ include/configs/socfpga_stratix10_socdk.h | 216 ++++++++++++++++++++++++++++++ 4 files changed, 273 insertions(+), 3 deletions(-) create mode 100644 configs/socfpga_stratix10_defconfig create mode 100644 include/configs/socfpga_stratix10_socdk.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index bb64b9c..13dd144 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -655,21 +655,23 @@ config ARCH_SNAPDRAGON
config ARCH_SOCFPGA bool "Altera SOCFPGA family" - select CPU_V7 + select CPU_V7 if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 + select ARM64 if TARGET_SOCFPGA_STRATIX10 select SUPPORT_SPL select OF_CONTROL select SPL_OF_CONTROL select DM select DM_SPI_FLASH select DM_SPI - select ENABLE_ARM_SOC_BOOT0_HOOK + select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select ARCH_EARLY_INIT_R select ARCH_MISC_INIT select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - select SYS_THUMB_BUILD + select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 imply CMD_MTDPARTS imply CRC32_VERIFY imply FAT_WRITE + select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10
config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs" diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 45e5379..03ab956 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -49,6 +49,12 @@ config TARGET_SOCFPGA_GEN5 bool select ALTERA_SDRAM
+config TARGET_SOCFPGA_STRATIX10 + bool + select ARMV8_MULTIENTRY + select ARMV8_SPIN_TABLE + select ARMV8_SET_SMPEN + choice prompt "Altera SOCFPGA board select" optional @@ -86,6 +92,10 @@ config TARGET_SOCFPGA_SR1500 bool "SR1500 (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
+config TARGET_SOCFPGA_STRATIX10_SOCDK + bool "Intel SOCFPGA SoCDK (Stratix 10)" + select TARGET_SOCFPGA_STRATIX10 + config TARGET_SOCFPGA_TERASIC_DE0_NANO bool "Terasic DE0-Nano-Atlas (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5 @@ -116,12 +126,14 @@ config SYS_BOARD default "sockit" if TARGET_SOCFPGA_TERASIC_SOCKIT default "socrates" if TARGET_SOCFPGA_EBV_SOCRATES default "sr1500" if TARGET_SOCFPGA_SR1500 + default "stratix10-socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK default "vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK + default "altera" if TARGET_SOCFPGA_STRATIX10_SOCDK default "aries" if TARGET_SOCFPGA_ARIES_MCVEVK default "ebv" if TARGET_SOCFPGA_EBV_SOCRATES default "samtec" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA @@ -145,6 +157,7 @@ config SYS_CONFIG_NAME default "socfpga_sockit" if TARGET_SOCFPGA_TERASIC_SOCKIT default "socfpga_socrates" if TARGET_SOCFPGA_EBV_SOCRATES default "socfpga_sr1500" if TARGET_SOCFPGA_SR1500 + default "socfpga_stratix10_socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK default "socfpga_vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA
endif diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig new file mode 100644 index 0000000..e5a7a69 --- /dev/null +++ b/configs/socfpga_stratix10_defconfig @@ -0,0 +1,39 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_FAT_SUPPORT=y +CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y +CONFIG_IDENT_STRING="socfpga_stratix10" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_stratix10_socdk" +CONFIG_BOOTDELAY=5 +CONFIG_SYS_PROMPT="SOCFPGA_STRATIX10 # " +CONFIG_CMD_CACHE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FS_GENERIC=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MII=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PING=y +CONFIG_CMD_SF=y +CONFIG_SPL=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_MMC=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DFU_MMC=y +CONFIG_MMC_DW=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CADENCE_QSPI=y +CONFIG_DM_ETH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_SYS_NS16550=y +CONFIG_USE_TINY_PRINTF=y diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h new file mode 100644 index 0000000..0d955f8 --- /dev/null +++ b/include/configs/socfpga_stratix10_socdk.h @@ -0,0 +1,216 @@ +/* + * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_STRATIX10_H__ +#define __CONFIG_SOCFGPA_STRATIX10_H__ + +#include <asm/arch/base_addr_s10.h> + +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_TEXT_BASE 0x1000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_LOADADDR 0x80000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_REMAKE_ELF +#define CPU_RELEASE_ADDR 0x80 +#define CONFIG_SYS_CACHELINE_SIZE 64 + +/* + * U-Boot console configurations + */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_LONGHELP +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ + +/* Extend size of kernel image for uncompression */ +#define CONFIG_SYS_BOOTM_LEN (32 * 1024 * 1024) + +/* + * U-Boot run time memory configurations + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x40000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR \ + + CONFIG_SYS_INIT_RAM_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_SP_ADDR) +#define CONFIG_SYS_MALLOC_LEN (5 * 1024 * 1024) + +/* + * U-Boot display configurations + */ +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* + * U-Boot environment configurations + */ +#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ + +/* + * QSPI support + */ + #ifdef CONFIG_CADENCE_QSPI +/* Enable it if you want to use dual-stacked mode */ +#undef CONFIG_SF_DUAL_FLASH +/*#define CONFIG_QSPI_RBF_ADDR 0x720000*/ + +/* Flash device info */ +#define CONFIG_SF_DEFAULT_SPEED (50000000) +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_3 | SPI_RX_QUAD) +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 + +/*#define CONFIG_ENV_IS_IN_SPI_FLASH*/ +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#undef CONFIG_ENV_OFFSET +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET 0x710000 +#define CONFIG_ENV_SIZE (4 * 1024) +#define CONFIG_ENV_SECT_SIZE (4 * 1024) +#endif /* CONFIG_ENV_IS_IN_SPI_FLASH */ + +/*#define CONFIG_BOOT_FLASH_TYPE "qspi"*/ +#define CONFIG_CQSPI_DECODER 0 + +#ifndef CONFIG_SPL_BUILD +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define MTDIDS_DEFAULT "nor0=ff705000.spi.0" +#endif /* CONFIG_SPL_BUILD */ + +/* 533MHz, TODO: Get from SDM */ +#define CONFIG_CQSPI_REF_CLK 400000000 + +#endif /* CONFIG_CADENCE_QSPI */ + +/* + * Boot arguments passed to the boot command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "earlycon" +#define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=Image\0" \ + "fdt_addr=8000000\0" \ + "fdtimage=socfpga_stratix10_socdk.dtb\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "booti ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootfile};" \ + "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" + +/* + * Generic Interrupt Controller Definitions + */ +#define CONFIG_GICV2 + +/* + * External memory configurations + */ +#define PHYS_SDRAM_1 0x0 +#define PHYS_SDRAM_1_SIZE (1 * 1024 * 1024 * 1024) +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_MEMTEST_START 0 +#define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1_SIZE - 0x200000 + +/* + * SDRAM controller + */ +#define CONFIG_ALTERA_SDRAM + +/* + * Serial / UART configurations + */ +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS +#define CONFIG_SYS_NS16550_CLK 100000000 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +/* always write in 32 bit manner */ +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_REG_SIZE -4 + +/* + * Timer & watchdog configurations + */ +#define COUNTER_FREQUENCY 400000000 + + +/* + * SDMMC configurations + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 +#endif +/* + * Flash configurations + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +/* Ethernet on SoC (EMAC) */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 +#define CONFIG_DW_ALTDESCRIPTOR +#define CONFIG_MII +#define CONFIG_AUTONEG_TIMEOUT (15 * CONFIG_SYS_HZ) +#define CONFIG_PHY_GIGE +#endif /* CONFIG_CMD_NET */ + + +/* + * SPL memory layout + * + * On chip RAM + * 0xFFE0_0000 ...... Start of OCRAM + * SPL code, rwdata + * 0xFFEx_xxxx ...... Top of stack (grows down) + * 0xFFEy_yyyy ...... Global Data + * 0xFFEz_zzzz ...... Malloc prior relocation (size CONFIG_SYS_MALLOC_F_LEN) + * 0xFFE3_FFFF ...... End of OCRAM + * + * SDRAM + * 0x0000_0000 ...... Start of SDRAM_1 + * unused / empty space for image loading + * Size 64MB ...... MALLOC (size CONFIG_SYS_SPL_MALLOC_SIZE) + * Size 1MB ...... BSS (size CONFIG_SPL_BSS_MAX_SIZE) + * 0x8000_0000 ...... End of SDRAM_1 (assume 2GB) + * + */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ +#define CONFIG_SPL_BSS_START_ADDR (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE \ + - CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE (CONFIG_SYS_MALLOC_LEN) +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR \ + - CONFIG_SYS_SPL_MALLOC_SIZE) +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x400000 + +/* SPL SDMMC boot support */ +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot-dtb.img" + +#endif /* __CONFIG_H */
Dinh Nguyen
See, Chin Liang
