[U-Boot] [PATCH] USB-CDC: Fix coding style issues
Fixed most of checkpatch warnings and errors in USB gadget stack.
Signed-off-by: Vitaly Kuzmichev vkuzmichev@mvista.com --- drivers/usb/gadget/config.c | 2 +- drivers/usb/gadget/epautoconf.c | 73 ++++---- drivers/usb/gadget/ether.c | 385 ++++++++++++++++++------------------- drivers/usb/gadget/gadget_chips.h | 51 +++--- drivers/usb/gadget/usbstring.c | 42 ++-- include/linux/usb/ch9.h | 4 +- include/linux/usb/gadget.h | 91 +++++----- 7 files changed, 325 insertions(+), 323 deletions(-)
diff --git a/drivers/usb/gadget/config.c b/drivers/usb/gadget/config.c index 84c90f0..cf22629 100644 --- a/drivers/usb/gadget/config.c +++ b/drivers/usb/gadget/config.c @@ -101,7 +101,7 @@ int usb_gadget_config_buf( *cp = *config;
/* then interface/endpoint/class/vendor/... */ - len = usb_descriptor_fillbuf(USB_DT_CONFIG_SIZE + (u8*)buf, + len = usb_descriptor_fillbuf(USB_DT_CONFIG_SIZE + (u8 *)buf, length - USB_DT_CONFIG_SIZE, desc); if (len < 0) return len; diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c index e11cc20..7cf3c67 100644 --- a/drivers/usb/gadget/epautoconf.c +++ b/drivers/usb/gadget/epautoconf.c @@ -32,7 +32,7 @@ /* we must assign addresses for configurable endpoints (like net2280) */ static unsigned epnum;
-// #define MANY_ENDPOINTS +/* #define MANY_ENDPOINTS */ #ifdef MANY_ENDPOINTS /* more than 15 configurable endpoints */ static unsigned in_epnum; @@ -55,8 +55,7 @@ static unsigned in_epnum; * NOTE: each endpoint is unidirectional, as specified by its USB * descriptor; and isn't specific to a configuration or altsetting. */ -static int -ep_matches ( +static int ep_matches( struct usb_gadget *gadget, struct usb_ep *ep, struct usb_endpoint_descriptor *desc @@ -83,37 +82,37 @@ ep_matches ( * direction-restriction: "in", "out". */ if ('-' != ep->name[2]) { - tmp = strrchr (ep->name, '-'); + tmp = strrchr(ep->name, '-'); if (tmp) { switch (type) { case USB_ENDPOINT_XFER_INT: /* bulk endpoints handle interrupt transfers, * except the toggle-quirky iso-synch kind */ - if ('s' == tmp[2]) // == "-iso" + if ('s' == tmp[2]) /* == "-iso" */ return 0; /* for now, avoid PXA "interrupt-in"; * it's documented as never using DATA1. */ - if (gadget_is_pxa (gadget) - && 'i' == tmp [1]) + if (gadget_is_pxa(gadget) + && 'i' == tmp[1]) return 0; break; case USB_ENDPOINT_XFER_BULK: - if ('b' != tmp[1]) // != "-bulk" + if ('b' != tmp[1]) /* != "-bulk" */ return 0; break; case USB_ENDPOINT_XFER_ISOC: - if ('s' != tmp[2]) // != "-iso" + if ('s' != tmp[2]) /* != "-iso" */ return 0; } } else { - tmp = ep->name + strlen (ep->name); + tmp = ep->name + strlen(ep->name); }
/* direction-restriction: "..in-..", "out-.." */ tmp--; - if (!isdigit (*tmp)) { + if (!isdigit(*tmp)) { if (desc->bEndpointAddress & USB_DIR_IN) { if ('n' != *tmp) return 0; @@ -155,8 +154,8 @@ ep_matches ( /* MATCH!! */
/* report address */ - if (isdigit (ep->name [2])) { - u8 num = simple_strtoul (&ep->name [2], NULL, 10); + if (isdigit(ep->name[2])) { + u8 num = simple_strtoul(&ep->name[2], NULL, 10); desc->bEndpointAddress |= num; #ifdef MANY_ENDPOINTS } else if (desc->bEndpointAddress & USB_DIR_IN) { @@ -183,12 +182,12 @@ ep_matches ( }
static struct usb_ep * -find_ep (struct usb_gadget *gadget, const char *name) +find_ep(struct usb_gadget *gadget, const char *name) { struct usb_ep *ep;
- list_for_each_entry (ep, &gadget->ep_list, ep_list) { - if (0 == strcmp (ep->name, name)) + list_for_each_entry(ep, &gadget->ep_list, ep_list) { + if (0 == strcmp(ep->name, name)) return ep; } return NULL; @@ -224,7 +223,7 @@ find_ep (struct usb_gadget *gadget, const char *name) * * On failure, this returns a null endpoint descriptor. */ -struct usb_ep * usb_ep_autoconfig ( +struct usb_ep *usb_ep_autoconfig( struct usb_gadget *gadget, struct usb_endpoint_descriptor *desc ) @@ -237,44 +236,44 @@ struct usb_ep * usb_ep_autoconfig ( /* First, apply chip-specific "best usage" knowledge. * This might make a good usb_gadget_ops hook ... */ - if (gadget_is_net2280 (gadget) && type == USB_ENDPOINT_XFER_INT) { + if (gadget_is_net2280(gadget) && type == USB_ENDPOINT_XFER_INT) { /* ep-e, ep-f are PIO with only 64 byte fifos */ - ep = find_ep (gadget, "ep-e"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep-e"); + if (ep && ep_matches(gadget, ep, desc)) return ep; - ep = find_ep (gadget, "ep-f"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep-f"); + if (ep && ep_matches(gadget, ep, desc)) return ep;
- } else if (gadget_is_goku (gadget)) { + } else if (gadget_is_goku(gadget)) { if (USB_ENDPOINT_XFER_INT == type) { /* single buffering is enough */ - ep = find_ep (gadget, "ep3-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep3-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; } else if (USB_ENDPOINT_XFER_BULK == type && (USB_DIR_IN & desc->bEndpointAddress)) { /* DMA may be available */ - ep = find_ep (gadget, "ep2-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep2-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; }
- } else if (gadget_is_sh (gadget) && USB_ENDPOINT_XFER_INT == type) { + } else if (gadget_is_sh(gadget) && USB_ENDPOINT_XFER_INT == type) { /* single buffering is enough; maybe 8 byte fifo is too */ - ep = find_ep (gadget, "ep3in-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep3in-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep;
- } else if (gadget_is_mq11xx (gadget) && USB_ENDPOINT_XFER_INT == type) { - ep = find_ep (gadget, "ep1-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + } else if (gadget_is_mq11xx(gadget) && USB_ENDPOINT_XFER_INT == type) { + ep = find_ep(gadget, "ep1-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; }
/* Second, look at endpoints until an unclaimed one looks usable */ - list_for_each_entry (ep, &gadget->ep_list, ep_list) { - if (ep_matches (gadget, ep, desc)) + list_for_each_entry(ep, &gadget->ep_list, ep_list) { + if (ep_matches(gadget, ep, desc)) return ep; }
@@ -291,11 +290,11 @@ struct usb_ep * usb_ep_autoconfig ( * state such as ep->driver_data and the record of assigned endpoints * used by usb_ep_autoconfig(). */ -void usb_ep_autoconfig_reset (struct usb_gadget *gadget) +void usb_ep_autoconfig_reset(struct usb_gadget *gadget) { struct usb_ep *ep;
- list_for_each_entry (ep, &gadget->ep_list, ep_list) { + list_for_each_entry(ep, &gadget->ep_list, ep_list) { ep->driver_data = NULL; } #ifdef MANY_ENDPOINTS diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2965299..051ab3c 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -89,8 +89,8 @@ unsigned packet_received, packet_sent; /* Based on linux 2.6.27 version */ #define DRIVER_VERSION "May Day 2005"
-static const char shortname [] = "ether"; -static const char driver_desc [] = DRIVER_DESC; +static const char shortname[] = "ether"; +static const char driver_desc[] = DRIVER_DESC;
#define RX_EXTRA 20 /* guard against rx overflows */
@@ -114,7 +114,7 @@ static inline int is_cdc(struct eth_dev *dev) { #if !defined(DEV_CONFIG_SUBSET) return 1; /* only cdc possible */ -#elif !defined (DEV_CONFIG_CDC) +#elif !defined(DEV_CONFIG_CDC) return 0; /* only subset possible */ #else return dev->cdc; /* depends on what hardware we found */ @@ -122,7 +122,7 @@ static inline int is_cdc(struct eth_dev *dev) }
#define subset_active(dev) (!is_cdc(dev)) -#define cdc_active(dev) ( is_cdc(dev)) +#define cdc_active(dev) (is_cdc(dev))
#define DEFAULT_QLEN 2 /* double buffering by default */
@@ -180,12 +180,12 @@ struct eth_dev { unsigned zlp:1; unsigned cdc:1; unsigned suspended:1; - unsigned network_started:1; + unsigned network_started:1; u16 cdc_filter; unsigned long todo; - int mtu; + int mtu; #define WORK_RX_MEMORY 0 - u8 host_mac [ETH_ALEN]; + u8 host_mac[ETH_ALEN]; };
/* This version autoconfigures as much as possible at run-time. @@ -276,14 +276,14 @@ device_desc = { .bLength = sizeof device_desc, .bDescriptorType = USB_DT_DEVICE,
- .bcdUSB = __constant_cpu_to_le16 (0x0200), + .bcdUSB = __constant_cpu_to_le16(0x0200),
.bDeviceClass = USB_CLASS_COMM, .bDeviceSubClass = 0, .bDeviceProtocol = 0,
- .idVendor = __constant_cpu_to_le16 (CDC_VENDOR_NUM), - .idProduct = __constant_cpu_to_le16 (CDC_PRODUCT_NUM), + .idVendor = __constant_cpu_to_le16(CDC_VENDOR_NUM), + .idProduct = __constant_cpu_to_le16(CDC_PRODUCT_NUM), .iManufacturer = STRING_MANUFACTURER, .iProduct = STRING_PRODUCT, .bNumConfigurations = 1, @@ -338,7 +338,7 @@ static const struct usb_cdc_header_desc header_desc = { .bDescriptorType = USB_DT_CS_INTERFACE, .bDescriptorSubType = USB_CDC_HEADER_TYPE,
- .bcdCDC = __constant_cpu_to_le16 (0x0110), + .bcdCDC = __constant_cpu_to_le16(0x0110), };
#if defined(DEV_CONFIG_CDC) @@ -391,15 +391,15 @@ static const u8 mdlm_detail_desc[] = {
static const struct usb_cdc_ether_desc ether_desc = { - .bLength = sizeof (ether_desc), + .bLength = sizeof(ether_desc), .bDescriptorType = USB_DT_CS_INTERFACE, .bDescriptorSubType = USB_CDC_ETHERNET_TYPE,
/* this descriptor actually adds value, surprise! */ .iMACAddress = STRING_ETHADDR, - .bmEthernetStatistics = __constant_cpu_to_le32 (0), /* no statistics */ - .wMaxSegmentSize = __constant_cpu_to_le16 (ETH_FRAME_LEN), - .wNumberMCFilters = __constant_cpu_to_le16 (0), + .bmEthernetStatistics = __constant_cpu_to_le32(0), /* no statistics */ + .wMaxSegmentSize = __constant_cpu_to_le16(ETH_FRAME_LEN), + .wNumberMCFilters = __constant_cpu_to_le16(0), .bNumberPowerFilters = 0, };
@@ -427,7 +427,7 @@ fs_status_desc = {
.bEndpointAddress = USB_DIR_IN, .bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .wMaxPacketSize = __constant_cpu_to_le16(STATUS_BYTECOUNT), .bInterval = 1 << LOG2_STATUS_INTERVAL_MSEC, }; #endif @@ -512,7 +512,7 @@ fs_sink_desc = { .bmAttributes = USB_ENDPOINT_XFER_BULK, };
-static const struct usb_descriptor_header *fs_eth_function [11] = { +static const struct usb_descriptor_header *fs_eth_function[11] = { (struct usb_descriptor_header *) &otg_descriptor, #ifdef DEV_CONFIG_CDC /* "cdc" mode descriptors */ @@ -560,7 +560,7 @@ hs_status_desc = { .bDescriptorType = USB_DT_ENDPOINT,
.bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .wMaxPacketSize = __constant_cpu_to_le16(STATUS_BYTECOUNT), .bInterval = LOG2_STATUS_INTERVAL_MSEC + 4, }; #endif /* DEV_CONFIG_CDC */ @@ -571,7 +571,7 @@ hs_source_desc = { .bDescriptorType = USB_DT_ENDPOINT,
.bmAttributes = USB_ENDPOINT_XFER_BULK, - .wMaxPacketSize = __constant_cpu_to_le16 (512), + .wMaxPacketSize = __constant_cpu_to_le16(512), };
static struct usb_endpoint_descriptor @@ -580,7 +580,7 @@ hs_sink_desc = { .bDescriptorType = USB_DT_ENDPOINT,
static struct usb_qualifier_descriptor @@ -588,13 +588,13 @@ dev_qualifier = { .bLength = sizeof dev_qualifier, .bDescriptorType = USB_DT_DEVICE_QUALIFIER,
- .bcdUSB = __constant_cpu_to_le16 (0x0200), + .bcdUSB = __constant_cpu_to_le16(0x0200), .bDeviceClass = USB_CLASS_COMM,
.bNumConfigurations = 1, };
-static const struct usb_descriptor_header *hs_eth_function [11] = { +static const struct usb_descriptor_header *hs_eth_function[11] = { (struct usb_descriptor_header *) &otg_descriptor, #ifdef DEV_CONFIG_CDC /* "cdc" mode descriptors */ @@ -645,15 +645,15 @@ ep_desc(struct usb_gadget *g, struct usb_endpoint_descriptor *hs,
/* descriptors that are built on-demand */
-static char manufacturer [50]; -static char product_desc [40] = DRIVER_DESC; -static char serial_number [20]; +static char manufacturer[50]; +static char product_desc[40] = DRIVER_DESC; +static char serial_number[20];
/* address that the host will use ... usually assigned at random */ -static char ethaddr [2 * ETH_ALEN + 1]; +static char ethaddr[2 * ETH_ALEN + 1];
/* static strings, in UTF-8 */ -static struct usb_string strings [] = { +static struct usb_string strings[] = { { STRING_MANUFACTURER, manufacturer, }, { STRING_PRODUCT, product_desc, }, { STRING_SERIALNUMBER, serial_number, }, @@ -730,13 +730,13 @@ config_buf(struct usb_gadget *g, u8 *buf, u8 type, unsigned index, int is_otg) return -EINVAL;
config = ð_config; - function = which_fn (eth); + function = which_fn(eth);
/* for now, don't advertise srp-only devices */ if (!is_otg) function++;
- len = usb_gadget_config_buf (config, buf, USB_BUFSIZ, function); + len = usb_gadget_config_buf(config, buf, USB_BUFSIZ, function); if (len < 0) return len; ((struct usb_config_descriptor *) buf)->bDescriptorType = type; @@ -745,10 +745,10 @@ config_buf(struct usb_gadget *g, u8 *buf, u8 type, unsigned index, int is_otg)
-static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags); +static int alloc_requests(struct eth_dev *dev, unsigned n, gfp_t gfp_flags);
static int -set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) +set_ether_config(struct eth_dev *dev, gfp_t gfp_flags) { int result = 0; struct usb_gadget *gadget = dev->gadget; @@ -756,11 +756,11 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) #if defined(DEV_CONFIG_CDC) /* status endpoint used for (optionally) CDC */ if (!subset_active(dev) && dev->status_ep) { - dev->status = ep_desc (gadget, &hs_status_desc, + dev->status = ep_desc(gadget, &hs_status_desc, &fs_status_desc); dev->status_ep->driver_data = dev;
- result = usb_ep_enable (dev->status_ep, dev->status); + result = usb_ep_enable(dev->status_ep, dev->status); if (result != 0) { debug("enable %s --> %d\n", dev->status_ep->name, result); @@ -780,14 +780,14 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) * so we don't activate them yet. Reset from SET_INTERFACE. */ if (!cdc_active(dev)) { - result = usb_ep_enable (dev->in_ep, dev->in); + result = usb_ep_enable(dev->in_ep, dev->in); if (result != 0) { debug("enable %s --> %d\n", dev->in_ep->name, result); goto done; }
- result = usb_ep_enable (dev->out_ep, dev->out); + result = usb_ep_enable(dev->out_ep, dev->out); if (result != 0) { debug("enable %s --> %d\n", dev->out_ep->name, result); @@ -797,15 +797,15 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags)
done: if (result == 0) - result = alloc_requests (dev, qlen (gadget), gfp_flags); + result = alloc_requests(dev, qlen(gadget), gfp_flags);
/* on error, disable any endpoints */ if (result < 0) { if (!subset_active(dev) && dev->status_ep) - (void) usb_ep_disable (dev->status_ep); + (void) usb_ep_disable(dev->status_ep); dev->status = NULL; - (void) usb_ep_disable (dev->in_ep); - (void) usb_ep_disable (dev->out_ep); + (void) usb_ep_disable(dev->in_ep); + (void) usb_ep_disable(dev->out_ep); dev->in = NULL; dev->out = NULL; } @@ -815,7 +815,7 @@ done: }
-static void eth_reset_config (struct eth_dev *dev) +static void eth_reset_config(struct eth_dev *dev) { if (dev->config == 0) return; @@ -827,21 +827,21 @@ static void eth_reset_config (struct eth_dev *dev) */
if (dev->in) { - usb_ep_disable (dev->in_ep); + usb_ep_disable(dev->in_ep); if (dev->tx_req) { - usb_ep_free_request (dev->in_ep, dev->tx_req); - dev->tx_req=NULL; + usb_ep_free_request(dev->in_ep, dev->tx_req); + dev->tx_req = NULL; } } if (dev->out) { - usb_ep_disable (dev->out_ep); + usb_ep_disable(dev->out_ep); if (dev->rx_req) { - usb_ep_free_request (dev->out_ep, dev->rx_req); - dev->rx_req=NULL; + usb_ep_free_request(dev->out_ep, dev->rx_req); + dev->rx_req = NULL; } } if (dev->status) { - usb_ep_disable (dev->status_ep); + usb_ep_disable(dev->status_ep); } dev->cdc_filter = 0; dev->config = 0; @@ -850,23 +850,24 @@ static void eth_reset_config (struct eth_dev *dev) /* change our operational config. must agree with the code * that returns config descriptors, and altsetting code. */ -static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags) +static int eth_set_config(struct eth_dev *dev, unsigned number, + gfp_t gfp_flags) { int result = 0; struct usb_gadget *gadget = dev->gadget;
- if (gadget_is_sa1100 (gadget) + if (gadget_is_sa1100(gadget) && dev->config && dev->tx_qlen != 0) { /* tx fifo is full, but we can't clear it...*/ error("can't change configurations"); return -ESPIPE; } - eth_reset_config (dev); + eth_reset_config(dev);
switch (number) { case DEV_CONFIG_VALUE: - result = set_ether_config (dev, gfp_flags); + result = set_ether_config(dev, gfp_flags); break; default: result = -EINVAL; @@ -877,7 +878,7 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags
if (result) { if (number) - eth_reset_config (dev); + eth_reset_config(dev); usb_gadget_vbus_draw(dev->gadget, gadget_is_otg(dev->gadget) ? 8 : 100); } else { @@ -888,17 +889,20 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags usb_gadget_vbus_draw(dev->gadget, power);
switch (gadget->speed) { - case USB_SPEED_FULL: speed = "full"; break; + case USB_SPEED_FULL: + speed = "full"; break; #ifdef CONFIG_USB_GADGET_DUALSPEED - case USB_SPEED_HIGH: speed = "high"; break; + case USB_SPEED_HIGH: + speed = "high"; break; #endif - default: speed = "?"; break; + default: + speed = "?"; break; }
dev->config = number; printf("%s speed config #%d: %d mA, %s, using %s\n", speed, number, power, driver_desc, - (cdc_active(dev)? "CDC Ethernet" + (cdc_active(dev) ? "CDC Ethernet" : "CDC Ethernet Subset")); } return result; @@ -914,7 +918,7 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags * we want this CDC Ethernet code to be vendor-neutral, we don't use that * command mechanism; and only one status request is ever queued. */ -static void eth_status_complete (struct usb_ep *ep, struct usb_request *req) +static void eth_status_complete(struct usb_ep *ep, struct usb_request *req) { struct usb_cdc_notification *event = req->buf; int value = req->status; @@ -927,32 +931,31 @@ static void eth_status_complete (struct usb_ep *ep, struct usb_request *req)
event->bmRequestType = 0xA1; event->bNotificationType = USB_CDC_NOTIFY_SPEED_CHANGE; - event->wValue = __constant_cpu_to_le16 (0); - event->wIndex = __constant_cpu_to_le16 (1); - event->wLength = __constant_cpu_to_le16 (8); + event->wValue = __constant_cpu_to_le16(0); + event->wIndex = __constant_cpu_to_le16(1); + event->wLength = __constant_cpu_to_le16(8);
/* SPEED_CHANGE data is up/down speeds in bits/sec */ - data [0] = data [1] = cpu_to_le32 (BITRATE (dev->gadget)); + data[0] = data[1] = cpu_to_le32(BITRATE(dev->gadget));
req->length = STATUS_BYTECOUNT; - value = usb_ep_queue (ep, req, GFP_ATOMIC); + value = usb_ep_queue(ep, req, GFP_ATOMIC); debug("send SPEED_CHANGE --> %d\n", value); if (value == 0) return; } else if (value != -ECONNRESET) { debug("event %02x --> %d\n", event->bNotificationType, value); - if (event->bNotificationType== - USB_CDC_NOTIFY_SPEED_CHANGE) - { - l_ethdev.network_started=1; + if (event->bNotificationType == + USB_CDC_NOTIFY_SPEED_CHANGE) { + l_ethdev.network_started = 1; printf("USB network up!\n"); } } req->context = NULL; }
-static void issue_start_status (struct eth_dev *dev) +static void issue_start_status(struct eth_dev *dev) { struct usb_request *req = dev->stat_req; struct usb_cdc_notification *event; @@ -967,8 +970,8 @@ static void issue_start_status (struct eth_dev *dev) * * FIXME iff req->context != null just dequeue it */ - usb_ep_disable (dev->status_ep); - usb_ep_enable (dev->status_ep, dev->status); + usb_ep_disable(dev->status_ep); + usb_ep_enable(dev->status_ep, dev->status);
/* 3.8.1 says to issue first NETWORK_CONNECTION, then * a SPEED_CHANGE. could be useful in some configs. @@ -976,15 +979,15 @@ static void issue_start_status (struct eth_dev *dev) event = req->buf; event->bmRequestType = 0xA1; event->bNotificationType = USB_CDC_NOTIFY_NETWORK_CONNECTION; - event->wValue = __constant_cpu_to_le16 (1); /* connected */ - event->wIndex = __constant_cpu_to_le16 (1); + event->wValue = __constant_cpu_to_le16(1); /* connected */ + event->wIndex = __constant_cpu_to_le16(1); event->wLength = 0;
req->length = sizeof *event; req->complete = eth_status_complete; req->context = dev;
- value = usb_ep_queue (dev->status_ep, req, GFP_ATOMIC); + value = usb_ep_queue(dev->status_ep, req, GFP_ATOMIC); if (value < 0) debug("status buf queue --> %d\n", value); } @@ -993,7 +996,7 @@ static void issue_start_status (struct eth_dev *dev)
-static void eth_setup_complete (struct usb_ep *ep, struct usb_request *req) +static void eth_setup_complete(struct usb_ep *ep, struct usb_request *req) { if (req->status || req->actual != req->length) debug("setup complete --> %d, %d/%d\n", @@ -1010,9 +1013,9 @@ static void eth_setup_complete (struct usb_ep *ep, struct usb_request *req) * - class-specific control requests */ static int -eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +eth_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) { - struct eth_dev *dev = get_gadget_data (gadget); + struct eth_dev *dev = get_gadget_data(gadget); struct usb_request *req = dev->req; int value = -EOPNOTSUPP; u16 wIndex = le16_to_cpu(ctrl->wIndex); @@ -1034,14 +1037,14 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) switch (wValue >> 8) {
case USB_DT_DEVICE: - value = min (wLength, (u16) sizeof device_desc); - memcpy (req->buf, &device_desc, value); + value = min(wLength, (u16) sizeof device_desc); + memcpy(req->buf, &device_desc, value); break; case USB_DT_DEVICE_QUALIFIER: if (!gadget_is_dualspeed(gadget)) break; - value = min (wLength, (u16) sizeof dev_qualifier); - memcpy (req->buf, &dev_qualifier, value); + value = min(wLength, (u16) sizeof dev_qualifier); + memcpy(req->buf, &dev_qualifier, value); break;
case USB_DT_OTHER_SPEED_CONFIG: @@ -1054,15 +1057,15 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) wValue & 0xff, gadget_is_otg(gadget)); if (value >= 0) - value = min (wLength, (u16) value); + value = min(wLength, (u16) value); break;
case USB_DT_STRING: - value = usb_gadget_get_string (&stringtab, + value = usb_gadget_get_string(&stringtab, wValue & 0xff, req->buf);
break; } @@ -1075,13 +1078,13 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) debug("HNP available\n"); else if (gadget->a_alt_hnp_support) debug("HNP needs a different root port\n"); - value = eth_set_config (dev, wValue, GFP_ATOMIC); + value = eth_set_config(dev, wValue, GFP_ATOMIC); break; case USB_REQ_GET_CONFIGURATION: if (ctrl->bRequestType != USB_DIR_IN) break; *(u8 *)req->buf = dev->config; - value = min (wLength, (u16) 1); + value = min(wLength, (u16) 1); break;
case USB_REQ_SET_INTERFACE: @@ -1095,8 +1098,8 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) /* PXA hardware partially handles SET_INTERFACE; * we need to kluge around that interference. */ - if (gadget_is_pxa (gadget)) { - value = eth_set_config (dev, DEV_CONFIG_VALUE, + if (gadget_is_pxa(gadget)) { + value = eth_set_config(dev, DEV_CONFIG_VALUE, GFP_ATOMIC); goto done_set_intf; } @@ -1107,29 +1110,29 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (wValue != 0) break; if (dev->status) { - usb_ep_disable (dev->status_ep); - usb_ep_enable (dev->status_ep, dev->status); + usb_ep_disable(dev->status_ep); + usb_ep_enable(dev->status_ep, dev->status); } value = 0; break; case 1: /* data intf */ if (wValue > 1) break; - usb_ep_disable (dev->in_ep); - usb_ep_disable (dev->out_ep); + usb_ep_disable(dev->in_ep); + usb_ep_disable(dev->out_ep);
/* CDC requires the data transfers not be done from * the default interface setting ... also, setting * the non-default interface resets filters etc. */ if (wValue == 1) { - if (!cdc_active (dev)) + if (!cdc_active(dev)) break; - usb_ep_enable (dev->in_ep, dev->in); - usb_ep_enable (dev->out_ep, dev->out); + usb_ep_enable(dev->in_ep, dev->in); + usb_ep_enable(dev->out_ep, dev->out); dev->cdc_filter = DEFAULT_FILTER; if (dev->status) - issue_start_status (dev); + issue_start_status(dev); }
value = 0; @@ -1160,7 +1163,7 @@ done_set_intf: /* carrier always ok ...*/ *(u8 *)req->buf = 1 ; } - value = min (wLength, (u16) 1); + value = min(wLength, (u16) 1); break;
#ifdef DEV_CONFIG_CDC @@ -1199,11 +1202,11 @@ done_set_intf: req->length = value; req->zero = value < wLength && (value % gadget->ep0->maxpacket) == 0; - value = usb_ep_queue (gadget->ep0, req, GFP_ATOMIC); + value = usb_ep_queue(gadget->ep0, req, GFP_ATOMIC); if (value < 0) { debug("ep_queue --> %d\n", value); req->status = 0; - eth_setup_complete (gadget->ep0, req); + eth_setup_complete(gadget->ep0, req); } }
@@ -1214,9 +1217,9 @@ done_set_intf:
-static void rx_complete (struct usb_ep *ep, struct usb_request *req); +static void rx_complete(struct usb_ep *ep, struct usb_request *req);
-static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ +static int rx_submit(struct eth_dev *dev, struct usb_request *req, gfp_t gfp_flags) { int retval = -ENOMEM; @@ -1245,7 +1248,7 @@ static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ req->length = size; req->complete = rx_complete;
- retval = usb_ep_queue (dev->out_ep, req, gfp_flags); + retval = usb_ep_queue(dev->out_ep, req, gfp_flags);
if (retval) { error("rx submit --> %d", retval); @@ -1254,28 +1257,28 @@ static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ }
-static void rx_complete (struct usb_ep *ep, struct usb_request *req) +static void rx_complete(struct usb_ep *ep, struct usb_request *req) { struct eth_dev *dev = ep->driver_data;
debug("%s: status %d\n", __func__, req->status);
- packet_received=1; + packet_received = 1;
if (req) - dev->rx_req=req; + dev->rx_req = req; }
-static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags) +static int alloc_requests(struct eth_dev *dev, unsigned n, gfp_t gfp_flags) {
- dev->tx_req = usb_ep_alloc_request (dev->in_ep, 0); + dev->tx_req = usb_ep_alloc_request(dev->in_ep, 0);
if (!dev->tx_req) goto fail;
- dev->rx_req = usb_ep_alloc_request (dev->out_ep, 0); + dev->rx_req = usb_ep_alloc_request(dev->out_ep, 0);
if (!dev->rx_req) goto fail; @@ -1288,16 +1291,16 @@ fail: }
-static void tx_complete (struct usb_ep *ep, struct usb_request *req) +static void tx_complete(struct usb_ep *ep, struct usb_request *req) { - debug("%s: status %s\n", __func__, (req->status)?"failed":"ok"); - packet_sent=1; + debug("%s: status %s\n", __func__, (req->status) ? "failed" : "ok"); + packet_sent = 1; }
-static inline int eth_is_promisc (struct eth_dev *dev) +static inline int eth_is_promisc(struct eth_dev *dev) { /* no filters for the CDC subset; always promisc */ - if (subset_active (dev)) + if (subset_active(dev)) return 1; return dev->cdc_filter & USB_CDC_PACKET_TYPE_PROMISCUOUS; } @@ -1415,49 +1418,49 @@ drop: /*-------------------------------------------------------------------------*/ #endif
-static void eth_unbind (struct usb_gadget *gadget) +static void eth_unbind(struct usb_gadget *gadget) { - struct eth_dev *dev = get_gadget_data (gadget); + struct eth_dev *dev = get_gadget_data(gadget);
debug("%s...\n", __func__);
/* we've already been disconnected ... no i/o is active */ if (dev->req) { - usb_ep_free_request (gadget->ep0, dev->req); + usb_ep_free_request(gadget->ep0, dev->req); dev->req = NULL; } if (dev->stat_req) { - usb_ep_free_request (dev->status_ep, dev->stat_req); + usb_ep_free_request(dev->status_ep, dev->stat_req); dev->stat_req = NULL; }
/* unregister_netdev (dev->net);*/ /* free_netdev(dev->net);*/
- set_gadget_data (gadget, NULL); + set_gadget_data(gadget, NULL); }
-static void eth_disconnect (struct usb_gadget *gadget) +static void eth_disconnect(struct usb_gadget *gadget) { - eth_reset_config (get_gadget_data (gadget)); + eth_reset_config(get_gadget_data(gadget)); }
-static void eth_suspend (struct usb_gadget *gadget) +static void eth_suspend(struct usb_gadget *gadget) { /* Not used */ }
-static void eth_resume (struct usb_gadget *gadget) +static void eth_resume(struct usb_gadget *gadget) { /* Not used */ } @@ -1492,12 +1495,12 @@ static int is_eth_addr_valid(char *str) return 0; }
-static u8 nibble (unsigned char c) +static u8 nibble(unsigned char c) { - if (likely (isdigit (c))) + if (likely(isdigit(c))) return c - '0'; - c = toupper (c); - if (likely (isxdigit (c))) + c = toupper(c); + if (likely(isxdigit(c))) return 10 + c - 'A'; return 0; } @@ -1510,13 +1513,13 @@ static int get_ether_addr(const char *str, u8 *dev_addr) for (i = 0; i < 6; i++) { unsigned char num;
- if((*str == '.') || (*str == ':')) + if ((*str == '.') || (*str == ':')) str++; num = nibble(*str++) << 4; num |= (nibble(*str++)); - dev_addr [i] = num; + dev_addr[i] = num; } - if (is_valid_ether_addr (dev_addr)) + if (is_valid_ether_addr(dev_addr)) return 0; } return 1; @@ -1528,7 +1531,7 @@ static int eth_bind(struct usb_gadget *gadget) u8 cdc = 1, zlp = 1; struct usb_ep *in_ep, *out_ep, *status_ep = NULL; int gcnum; - u8 tmp[7]; + u8 tmp[7];
/* these flags are only ever cleared; compiler take note */ #ifndef DEV_CONFIG_CDC @@ -1538,7 +1541,7 @@ static int eth_bind(struct usb_gadget *gadget) * standard protocol is _strongly_ preferred for interop purposes. * (By everyone except Microsoft.) */ - if (gadget_is_pxa (gadget)) { + if (gadget_is_pxa(gadget)) { /* pxa doesn't support altsettings */ cdc = 0; } else if (gadget_is_musbhdrc(gadget)) { @@ -1547,7 +1550,7 @@ static int eth_bind(struct usb_gadget *gadget) } else if (gadget_is_sh(gadget)) { /* sh doesn't support multiple interfaces or configs */ cdc = 0; - } else if (gadget_is_sa1100 (gadget)) { + } else if (gadget_is_sa1100(gadget)) { /* hardware can't write zlps */ zlp = 0; /* sa1100 CAN do CDC, without status endpoint ... we use @@ -1556,9 +1559,9 @@ static int eth_bind(struct usb_gadget *gadget) cdc = 0; }
- gcnum = usb_gadget_controller_number (gadget); + gcnum = usb_gadget_controller_number(gadget); if (gcnum >= 0) - device_desc.bcdDevice = cpu_to_le16 (0x0300 + gcnum); + device_desc.bcdDevice = cpu_to_le16(0x0300 + gcnum); else { /* can't assume CDC works. don't want to default to * anything less functional on CDC-capable hardware, @@ -1588,17 +1591,17 @@ static int eth_bind(struct usb_gadget *gadget) if (bcdDevice) device_desc.bcdDevice = cpu_to_le16(bcdDevice); if (iManufacturer) - strlcpy (manufacturer, iManufacturer, sizeof manufacturer); + strlcpy(manufacturer, iManufacturer, sizeof manufacturer); if (iProduct) - strlcpy (product_desc, iProduct, sizeof product_desc); + strlcpy(product_desc, iProduct, sizeof product_desc); if (iSerialNumber) { device_desc.iSerialNumber = STRING_SERIALNUMBER, strlcpy(serial_number, iSerialNumber, sizeof serial_number); }
/* all we really need is bulk IN/OUT */ - usb_ep_autoconfig_reset (gadget); - in_ep = usb_ep_autoconfig (gadget, &fs_source_desc); + usb_ep_autoconfig_reset(gadget); + in_ep = usb_ep_autoconfig(gadget, &fs_source_desc); if (!in_ep) { autoconf_fail: error("can't autoconfigure on %s\n", @@ -1607,7 +1610,7 @@ autoconf_fail: } in_ep->driver_data = in_ep; /* claim */
- out_ep = usb_ep_autoconfig (gadget, &fs_sink_desc); + out_ep = usb_ep_autoconfig(gadget, &fs_sink_desc); if (!out_ep) goto autoconf_fail; out_ep->driver_data = out_ep; /* claim */ @@ -1617,7 +1620,7 @@ autoconf_fail: * Since some hosts expect one, try to allocate one anyway. */ if (cdc) { - status_ep = usb_ep_autoconfig (gadget, &fs_status_desc); + status_ep = usb_ep_autoconfig(gadget, &fs_status_desc); if (status_ep) { status_ep->driver_data = status_ep; /* claim */ } else if (cdc) { @@ -1640,7 +1643,7 @@ autoconf_fail: }
device_desc.bMaxPacketSize0 = gadget->ep0->maxpacket; - usb_gadget_set_selfpowered (gadget); + usb_gadget_set_selfpowered(gadget);
if (gadget_is_dualspeed(gadget)) { if (!cdc) @@ -1668,7 +1671,7 @@ autoconf_fail: }
dev->net = &l_netdev; - strcpy (dev->net->name, USB_NET_NAME); + strcpy(dev->net->name, USB_NET_NAME);
dev->cdc = cdc; dev->zlp = zlp; @@ -1690,10 +1693,10 @@ autoconf_fail:
get_ether_addr(host_addr, dev->host_mac);
- sprintf (ethaddr, "%02X%02X%02X%02X%02X%02X", - dev->host_mac [0], dev->host_mac [1], - dev->host_mac [2], dev->host_mac [3], - dev->host_mac [4], dev->host_mac [5]); + sprintf(ethaddr, "%02X%02X%02X%02X%02X%02X", + dev->host_mac[0], dev->host_mac[1], + dev->host_mac[2], dev->host_mac[3], + dev->host_mac[4], dev->host_mac[5]);
printf("using %s, OUT %s IN %s%s%s\n", gadget->name, out_ep->name, in_ep->name, @@ -1701,15 +1704,15 @@ autoconf_fail: status_ep ? status_ep->name : "" ); printf("MAC %02x:%02x:%02x:%02x:%02x:%02x\n", - dev->net->enetaddr [0], dev->net->enetaddr [1], - dev->net->enetaddr [2], dev->net->enetaddr [3], - dev->net->enetaddr [4], dev->net->enetaddr [5]); + dev->net->enetaddr[0], dev->net->enetaddr[1], + dev->net->enetaddr[2], dev->net->enetaddr[3], + dev->net->enetaddr[4], dev->net->enetaddr[5]);
if (cdc) { printf("HOST MAC %02x:%02x:%02x:%02x:%02x:%02x\n", - dev->host_mac [0], dev->host_mac [1], - dev->host_mac [2], dev->host_mac [3], - dev->host_mac [4], dev->host_mac [5]); + dev->host_mac[0], dev->host_mac[1], + dev->host_mac[2], dev->host_mac[3], + dev->host_mac[4], dev->host_mac[5]); }
/* use PKTSIZE (or aligned... from u-boot) and set @@ -1717,7 +1720,7 @@ autoconf_fail: dev->mtu = PKTSIZE_ALIGN; /* RNDIS does not like this, only 1514, TODO*/
/* preallocate control message data and buffer */ - dev->req = usb_ep_alloc_request (gadget->ep0, GFP_KERNEL); + dev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); if (!dev->req) goto fail; dev->req->buf = control_req; @@ -1728,7 +1731,7 @@ autoconf_fail: if (dev->status_ep) { dev->stat_req = usb_ep_alloc_request(dev->status_ep, GFP_KERNEL); if (!dev->stat_req) { - usb_ep_free_request (dev->status_ep, dev->req); + usb_ep_free_request(dev->status_ep, dev->req);
goto fail; } @@ -1739,7 +1742,7 @@ autoconf_fail:
/* finish hookup to lower layer ... */ dev->gadget = gadget; - set_gadget_data (gadget, dev); + set_gadget_data(gadget, dev); gadget->ep0->driver_data = dev;
/* two kinds of host-initiated state changes: @@ -1750,13 +1753,13 @@ autoconf_fail:
fail: error("%s failed", __func__); - eth_unbind (gadget); + eth_unbind(gadget); return -ENOMEM; }
-static int usb_eth_init(struct eth_device* netdev, bd_t* bd) +static int usb_eth_init(struct eth_device *netdev, bd_t *bd) { - struct eth_dev *dev=&l_ethdev; + struct eth_dev *dev = &l_ethdev; struct usb_gadget *gadget; unsigned long ts; unsigned long timeout = USB_CONNECT_TIMEOUT; @@ -1780,8 +1783,7 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) timeout = simple_strtoul(getenv("cdc_connect_timeout"), NULL, 10) * CONFIG_SYS_HZ; ts = get_timer(0); - while (!l_ethdev.network_started) - { + while (!l_ethdev.network_started) { /* Handle control-c and timeouts */ if (ctrlc() || (get_timer(ts) > timeout)) { error("The remote end did not respond in time."); @@ -1790,19 +1792,20 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) usb_gadget_handle_interrupts(); }
- rx_submit (dev, dev->rx_req, 0); + rx_submit(dev, dev->rx_req, 0); return 0; fail: return -1; }
-static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int length) +static int usb_eth_send(struct eth_device *netdev, + volatile void *packet, int length) { int retval; struct usb_request *req = NULL; struct eth_dev *dev = &l_ethdev; - unsigned long ts; - unsigned long timeout = USB_CONNECT_TIMEOUT; + unsigned long ts; + unsigned long timeout = USB_CONNECT_TIMEOUT;
debug("%s:...\n", __func__);
@@ -1827,54 +1830,50 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le req->no_interrupt = (dev->gadget->speed == USB_SPEED_HIGH) ? ((dev->tx_qlen % qmult) != 0) : 0; #endif - dev->tx_qlen=1; - ts = get_timer(0); - packet_sent = 0; + dev->tx_qlen = 1; + ts = get_timer(0); + packet_sent = 0;
- retval = usb_ep_queue (dev->in_ep, req, GFP_ATOMIC); + retval = usb_ep_queue(dev->in_ep, req, GFP_ATOMIC);
if (!retval) debug("%s: packet queued\n", __func__); - while(!packet_sent) - { - if (get_timer(ts) > timeout) { - printf("timeout sending packets to usb ethernet\n"); - return -1; - } - usb_gadget_handle_interrupts(); + while (!packet_sent) { + if (get_timer(ts) > timeout) { + printf("timeout sending packets to usb ethernet\n"); + return -1; + } + usb_gadget_handle_interrupts(); }
return 0; }
-static int usb_eth_recv(struct eth_device* netdev) +static int usb_eth_recv(struct eth_device *netdev) { struct eth_dev *dev = &l_ethdev;
- if (packet_received) - { - debug("%s: packet received \n", __func__); - if (dev->rx_req) - { - NetReceive(NetRxPackets[0],dev->rx_req->length); - packet_received=0; + if (packet_received) { + debug("%s: packet received\n", __func__); + if (dev->rx_req) { + NetReceive(NetRxPackets[0], dev->rx_req->length); + packet_received = 0;
if (dev->rx_req) rx_submit (dev, dev->rx_req, 0); - } - else error("dev->rx_req invalid"); + } else + error("dev->rx_req invalid"); } return 0; }
-void usb_eth_halt(struct eth_device* netdev) +void usb_eth_halt(struct eth_device *netdev) { - struct eth_dev *dev =&l_ethdev; + struct eth_dev *dev = &l_ethdev;
- if (!netdev) - { + if (!netdev) { error("received NULL ptr"); return; } @@ -1898,9 +1897,9 @@ static struct usb_gadget_driver eth_driver = { int usb_eth_initialize(bd_t *bi) { int status = 0; - struct eth_device *netdev=&l_netdev; + struct eth_device *netdev = &l_netdev;
- sprintf(netdev->name,"usb_ether"); + sprintf(netdev->name, "usb_ether");
netdev->init = usb_eth_init; netdev->send = usb_eth_send; diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index 480bc87..9bb7e2e 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -15,109 +15,109 @@ * Remy Bohmer linux@bohmer.net */ #ifdef CONFIG_USB_GADGET_NET2280 -#define gadget_is_net2280(g) !strcmp("net2280", (g)->name) +#define gadget_is_net2280(g) (!strcmp("net2280", (g)->name)) #else #define gadget_is_net2280(g) 0 #endif
#ifdef CONFIG_USB_GADGET_AMD5536UDC -#define gadget_is_amd5536udc(g) !strcmp("amd5536udc", (g)->name) +#define gadget_is_amd5536udc(g) (!strcmp("amd5536udc", (g)->name)) #else #define gadget_is_amd5536udc(g) 0 #endif
#ifdef CONFIG_USB_GADGET_DUMMY_HCD -#define gadget_is_dummy(g) !strcmp("dummy_udc", (g)->name) +#define gadget_is_dummy(g) (!strcmp("dummy_udc", (g)->name)) #else #define gadget_is_dummy(g) 0 #endif
#ifdef CONFIG_USB_GADGET_PXA2XX -#define gadget_is_pxa(g) !strcmp("pxa2xx_udc", (g)->name) +#define gadget_is_pxa(g) (!strcmp("pxa2xx_udc", (g)->name)) #else #define gadget_is_pxa(g) 0 #endif
#ifdef CONFIG_USB_GADGET_GOKU -#define gadget_is_goku(g) !strcmp("goku_udc", (g)->name) +#define gadget_is_goku(g) (!strcmp("goku_udc", (g)->name)) #else #define gadget_is_goku(g) 0 #endif
/* SH3 UDC -- not yet ported 2.4 --> 2.6 */ #ifdef CONFIG_USB_GADGET_SUPERH -#define gadget_is_sh(g) !strcmp("sh_udc", (g)->name) +#define gadget_is_sh(g) (!strcmp("sh_udc", (g)->name)) #else #define gadget_is_sh(g) 0 #endif
/* not yet stable on 2.6 (would help "original Zaurus") */ #ifdef CONFIG_USB_GADGET_SA1100 -#define gadget_is_sa1100(g) !strcmp("sa1100_udc", (g)->name) +#define gadget_is_sa1100(g) (!strcmp("sa1100_udc", (g)->name)) #else #define gadget_is_sa1100(g) 0 #endif
#ifdef CONFIG_USB_GADGET_LH7A40X -#define gadget_is_lh7a40x(g) !strcmp("lh7a40x_udc", (g)->name) +#define gadget_is_lh7a40x(g) (!strcmp("lh7a40x_udc", (g)->name)) #else #define gadget_is_lh7a40x(g) 0 #endif
/* handhelds.org tree (?) */ #ifdef CONFIG_USB_GADGET_MQ11XX -#define gadget_is_mq11xx(g) !strcmp("mq11xx_udc", (g)->name) +#define gadget_is_mq11xx(g) (!strcmp("mq11xx_udc", (g)->name)) #else #define gadget_is_mq11xx(g) 0 #endif
#ifdef CONFIG_USB_GADGET_OMAP -#define gadget_is_omap(g) !strcmp("omap_udc", (g)->name) +#define gadget_is_omap(g) (!strcmp("omap_udc", (g)->name)) #else #define gadget_is_omap(g) 0 #endif
/* not yet ported 2.4 --> 2.6 */ #ifdef CONFIG_USB_GADGET_N9604 -#define gadget_is_n9604(g) !strcmp("n9604_udc", (g)->name) +#define gadget_is_n9604(g) (!strcmp("n9604_udc", (g)->name)) #else #define gadget_is_n9604(g) 0 #endif
/* various unstable versions available */ #ifdef CONFIG_USB_GADGET_PXA27X -#define gadget_is_pxa27x(g) !strcmp("pxa27x_udc", (g)->name) +#define gadget_is_pxa27x(g) (!strcmp("pxa27x_udc", (g)->name)) #else #define gadget_is_pxa27x(g) 0 #endif
#ifdef CONFIG_USB_GADGET_ATMEL_USBA -#define gadget_is_atmel_usba(g) !strcmp("atmel_usba_udc", (g)->name) +#define gadget_is_atmel_usba(g) (!strcmp("atmel_usba_udc", (g)->name)) #else #define gadget_is_atmel_usba(g) 0 #endif
#ifdef CONFIG_USB_GADGET_S3C2410 -#define gadget_is_s3c2410(g) !strcmp("s3c2410_udc", (g)->name) +#define gadget_is_s3c2410(g) (!strcmp("s3c2410_udc", (g)->name)) #else #define gadget_is_s3c2410(g) 0 #endif
#ifdef CONFIG_USB_GADGET_AT91 -#define gadget_is_at91(g) !strcmp("at91_udc", (g)->name) +#define gadget_is_at91(g) (!strcmp("at91_udc", (g)->name)) #else #define gadget_is_at91(g) 0 #endif
/* status unclear */ #ifdef CONFIG_USB_GADGET_IMX -#define gadget_is_imx(g) !strcmp("imx_udc", (g)->name) +#define gadget_is_imx(g) (!strcmp("imx_udc", (g)->name)) #else #define gadget_is_imx(g) 0 #endif
#ifdef CONFIG_USB_GADGET_FSL_USB2 -#define gadget_is_fsl_usb2(g) !strcmp("fsl-usb2-udc", (g)->name) +#define gadget_is_fsl_usb2(g) (!strcmp("fsl-usb2-udc", (g)->name)) #else #define gadget_is_fsl_usb2(g) 0 #endif @@ -125,36 +125,37 @@ /* Mentor high speed function controller */ /* from Montavista kernel (?) */ #ifdef CONFIG_USB_GADGET_MUSBHSFC -#define gadget_is_musbhsfc(g) !strcmp("musbhsfc_udc", (g)->name) +#define gadget_is_musbhsfc(g) (!strcmp("musbhsfc_udc", (g)->name)) #else #define gadget_is_musbhsfc(g) 0 #endif
/* Mentor high speed "dual role" controller, in peripheral role */ #ifdef CONFIG_USB_GADGET_MUSB_HDRC -#define gadget_is_musbhdrc(g) !strcmp("musb_hdrc", (g)->name) +#define gadget_is_musbhdrc(g) (!strcmp("musb_hdrc", (g)->name)) #else #define gadget_is_musbhdrc(g) 0 #endif
/* from Montavista kernel (?) */ #ifdef CONFIG_USB_GADGET_MPC8272 -#define gadget_is_mpc8272(g) !strcmp("mpc8272_udc", (g)->name) +#define gadget_is_mpc8272(g) (!strcmp("mpc8272_udc", (g)->name)) #else #define gadget_is_mpc8272(g) 0 #endif
#ifdef CONFIG_USB_GADGET_M66592 -#define gadget_is_m66592(g) !strcmp("m66592_udc", (g)->name) +#define gadget_is_m66592(g) (!strcmp("m66592_udc", (g)->name)) #else #define gadget_is_m66592(g) 0 #endif
-// CONFIG_USB_GADGET_SX2 -// CONFIG_USB_GADGET_AU1X00 -// ... - +/* + * CONFIG_USB_GADGET_SX2 + * CONFIG_USB_GADGET_AU1X00 + * ... + */
/** * usb_gadget_controller_number - support bcdDevice id convention diff --git a/drivers/usb/gadget/usbstring.c b/drivers/usb/gadget/usbstring.c index 168f75f..45dfb1a 100644 --- a/drivers/usb/gadget/usbstring.c +++ b/drivers/usb/gadget/usbstring.c @@ -30,8 +30,9 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) */ while (len != 0 && (c = (u8) *s++) != 0) { if ((c & 0x80)) { - // 2-byte sequence: - // 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + /* 2-byte sequence: + * 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + */ if ((c & 0xe0) == 0xc0) { uchar = (c & 0x1f) << 6;
@@ -41,8 +42,9 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) c &= 0x3f; uchar |= c;
- // 3-byte sequence (most CJKV characters): - // zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + /* 3-byte sequence (most CJKV characters): + * zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + */ } else if ((c & 0xf0) == 0xe0) { uchar = (c & 0x0f) << 12;
@@ -62,12 +64,12 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) if (0xd800 <= uchar && uchar <= 0xdfff) goto fail;
- // 4-byte sequence (surrogate pairs, currently rare): - // 11101110wwwwzzzzyy + 110111yyyyxxxxxx - // = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx - // (uuuuu = wwww + 1) - // FIXME accept the surrogate code points (only) - + /* 4-byte sequence (surrogate pairs, currently rare): + * 11101110wwwwzzzzyy + 110111yyyyxxxxxx + * = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx + * (uuuuu = wwww + 1) + * FIXME accept the surrogate code points (only) + */ } else goto fail; } else @@ -100,17 +102,17 @@ fail: * characters (which are also widely used in C strings). */ int -usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) +usb_gadget_get_string(struct usb_gadget_strings *table, int id, u8 *buf) { struct usb_string *s; int len;
/* descriptor 0 has the language id */ if (id == 0) { - buf [0] = 4; - buf [1] = USB_DT_STRING; - buf [2] = (u8) table->language; - buf [3] = (u8) (table->language >> 8); + buf[0] = 4; + buf[1] = USB_DT_STRING; + buf[2] = (u8) table->language; + buf[3] = (u8) (table->language >> 8); return 4; } for (s = table->strings; s && s->s; s++) @@ -122,13 +124,13 @@ usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) return -EINVAL;
/* string descriptors have length, tag, then UTF16-LE text */ - len = min ((size_t) 126, strlen (s->s)); - memset (buf + 2, 0, 2 * len); /* zero all the bytes */ + len = min((size_t) 126, strlen(s->s)); + memset(buf + 2, 0, 2 * len); /* zero all the bytes */ len = utf8_to_utf16le(s->s, (__le16 *)&buf[2], len); if (len < 0) return -EINVAL; - buf [0] = (len + 1) * 2; - buf [1] = USB_DT_STRING; - return buf [0]; + buf[0] = (len + 1) * 2; + buf[1] = USB_DT_STRING; + return buf[0]; }
diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h index 1091692..49b7483 100644 --- a/include/linux/usb/ch9.h +++ b/include/linux/usb/ch9.h @@ -69,8 +69,8 @@ #define USB_RECIP_ENDPOINT 0x02 #define USB_RECIP_OTHER 0x03 /* From Wireless USB 1.0 */ -#define USB_RECIP_PORT 0x04 -#define USB_RECIP_RPIPE 0x05 +#define USB_RECIP_PORT 0x04 +#define USB_RECIP_RPIPE 0x05
/* * Standard requests, for the bRequest field of a SETUP packet. diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 344fc78..cad2eeb 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -74,8 +74,9 @@ struct usb_ep; * Bulk endpoints can use any size buffers, and can also be used for interrupt * transfers. interrupt-only endpoints can be much less functional. */ - // NOTE this is analagous to 'struct urb' on the host side, - // except that it's thinner and promotes more pre-allocation. + /* NOTE this is analagous to 'struct urb' on the host side, + * except that it's thinner and promotes more pre-allocation. + */
struct usb_request { void *buf; @@ -171,9 +172,9 @@ struct usb_ep { * returns zero, or a negative error code. */ static inline int -usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) +usb_ep_enable(struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) { - return ep->ops->enable (ep, desc); + return ep->ops->enable(ep, desc); }
/** @@ -189,9 +190,9 @@ usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) * returns zero, or a negative error code. */ static inline int -usb_ep_disable (struct usb_ep *ep) +usb_ep_disable(struct usb_ep *ep) { - return ep->ops->disable (ep); + return ep->ops->disable(ep); }
/** @@ -209,9 +210,9 @@ usb_ep_disable (struct usb_ep *ep) * Returns the request, or null if one could not be allocated. */ static inline struct usb_request * -usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) +usb_ep_alloc_request(struct usb_ep *ep, gfp_t gfp_flags) { - return ep->ops->alloc_request (ep, gfp_flags); + return ep->ops->alloc_request(ep, gfp_flags); }
/** @@ -224,9 +225,9 @@ usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) * no longer be requeued (or otherwise used). */ static inline void -usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) +usb_ep_free_request(struct usb_ep *ep, struct usb_request *req) { - ep->ops->free_request (ep, req); + ep->ops->free_request(ep, req); }
/** @@ -284,9 +285,9 @@ usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) * reported when the usb peripheral is disconnected. */ static inline int -usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) +usb_ep_queue(struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) { - return ep->ops->queue (ep, req, gfp_flags); + return ep->ops->queue(ep, req, gfp_flags); }
/** @@ -303,9 +304,9 @@ usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) * restrictions prevent drivers from supporting configuration changes, * even to configuration zero (a "chapter 9" requirement). */ -static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) +static inline int usb_ep_dequeue(struct usb_ep *ep, struct usb_request *req) { - return ep->ops->dequeue (ep, req); + return ep->ops->dequeue(ep, req); }
/** @@ -330,9 +331,9 @@ static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) * (usually a FIFO) still holds bytes that the host hasn't collected. */ static inline int -usb_ep_set_halt (struct usb_ep *ep) +usb_ep_set_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 1); + return ep->ops->set_halt(ep, 1); }
/** @@ -349,9 +350,9 @@ usb_ep_set_halt (struct usb_ep *ep) * and accordingly can't correctly implement interface altsettings. */ static inline int -usb_ep_clear_halt (struct usb_ep *ep) +usb_ep_clear_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 0); + return ep->ops->set_halt(ep, 0); }
/** @@ -370,10 +371,10 @@ usb_ep_clear_halt (struct usb_ep *ep) * precise handling. */ static inline int -usb_ep_fifo_status (struct usb_ep *ep) +usb_ep_fifo_status(struct usb_ep *ep) { if (ep->ops->fifo_status) - return ep->ops->fifo_status (ep); + return ep->ops->fifo_status(ep); else return -EOPNOTSUPP; } @@ -388,10 +389,10 @@ usb_ep_fifo_status (struct usb_ep *ep) * protocol translation. */ static inline void -usb_ep_fifo_flush (struct usb_ep *ep) +usb_ep_fifo_flush(struct usb_ep *ep) { if (ep->ops->fifo_flush) - ep->ops->fifo_flush (ep); + ep->ops->fifo_flush(ep); }
@@ -475,18 +476,18 @@ struct usb_gadget { struct device dev; };
-static inline void set_gadget_data (struct usb_gadget *gadget, void *data) +static inline void set_gadget_data(struct usb_gadget *gadget, void *data) { gadget->dev.driver_data = data; }
-static inline void *get_gadget_data (struct usb_gadget *gadget) +static inline void *get_gadget_data(struct usb_gadget *gadget) { return gadget->dev.driver_data; }
/* iterates the non-control endpoints; 'tmp' is a struct usb_ep pointer */ -#define gadget_for_each_ep(tmp,gadget) \ +#define gadget_for_each_ep(tmp, gadget) \ list_for_each_entry(tmp, &(gadget)->ep_list, ep_list)
@@ -530,9 +531,9 @@ static inline int gadget_is_otg(struct usb_gadget *g) * Returns the usb frame number, normally eleven bits from a SOF packet, * or negative errno if this device doesn't support this capability. */ -static inline int usb_gadget_frame_number (struct usb_gadget *gadget) +static inline int usb_gadget_frame_number(struct usb_gadget *gadget) { - return gadget->ops->get_frame (gadget); + return gadget->ops->get_frame(gadget); }
/** @@ -548,11 +549,11 @@ static inline int usb_gadget_frame_number (struct usb_gadget *gadget) * even if OTG isn't otherwise in use. OTG devices may also start * remote wakeup even when hosts don't explicitly enable it. */ -static inline int usb_gadget_wakeup (struct usb_gadget *gadget) +static inline int usb_gadget_wakeup(struct usb_gadget *gadget) { if (!gadget->ops->wakeup) return -EOPNOTSUPP; - return gadget->ops->wakeup (gadget); + return gadget->ops->wakeup(gadget); }
/** @@ -565,11 +566,11 @@ static inline int usb_gadget_wakeup (struct usb_gadget *gadget) * returns zero on success, else negative errno. */ static inline int -usb_gadget_set_selfpowered (struct usb_gadget *gadget) +usb_gadget_set_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 1); + return gadget->ops->set_selfpowered(gadget, 1); }
/** @@ -583,11 +584,11 @@ usb_gadget_set_selfpowered (struct usb_gadget *gadget) * returns zero on success, else negative errno. */ static inline int -usb_gadget_clear_selfpowered (struct usb_gadget *gadget) +usb_gadget_clear_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 0); + return gadget->ops->set_selfpowered(gadget, 0); }
/** @@ -607,7 +608,7 @@ usb_gadget_vbus_connect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 1); + return gadget->ops->vbus_session(gadget, 1); }
/** @@ -627,7 +628,7 @@ usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) { if (!gadget->ops->vbus_draw) return -EOPNOTSUPP; - return gadget->ops->vbus_draw (gadget, mA); + return gadget->ops->vbus_draw(gadget, mA); }
/** @@ -645,7 +646,7 @@ usb_gadget_vbus_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 0); + return gadget->ops->vbus_session(gadget, 0); }
/** @@ -660,11 +661,11 @@ usb_gadget_vbus_disconnect(struct usb_gadget *gadget) * Returns zero on success, else negative errno. */ static inline int -usb_gadget_connect (struct usb_gadget *gadget) +usb_gadget_connect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 1); + return gadget->ops->pullup(gadget, 1); }
/** @@ -683,11 +684,11 @@ usb_gadget_connect (struct usb_gadget *gadget) * Returns zero on success, else negative errno. */ static inline int -usb_gadget_disconnect (struct usb_gadget *gadget) +usb_gadget_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 0); + return gadget->ops->pullup(gadget, 0); }
@@ -795,7 +796,7 @@ struct usb_gadget_driver { * the bind() functions will be in init sections. * This function must be called in a context that can sleep. */ -int usb_gadget_register_driver (struct usb_gadget_driver *driver); +int usb_gadget_register_driver(struct usb_gadget_driver *driver);
/** * usb_gadget_unregister_driver - unregister a gadget driver @@ -810,7 +811,7 @@ int usb_gadget_register_driver (struct usb_gadget_driver *driver); * will in in exit sections, so may not be linked in some kernels. * This function must be called in a context that can sleep. */ -int usb_gadget_unregister_driver (struct usb_gadget_driver *driver); +int usb_gadget_unregister_driver(struct usb_gadget_driver *driver);
@@ -843,7 +844,7 @@ struct usb_gadget_strings { };
/* put descriptor for string with that id into buf (buflen >= 256) */ -int usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf); +int usb_gadget_get_string(struct usb_gadget_strings *table, int id, u8 *buf);
@@ -861,10 +862,10 @@ int usb_gadget_config_buf(const struct usb_config_descriptor *config,
/* utility wrapping a simple endpoint selection policy */
-extern struct usb_ep *usb_ep_autoconfig (struct usb_gadget *, +extern struct usb_ep *usb_ep_autoconfig(struct usb_gadget *, struct usb_endpoint_descriptor *);
-extern void usb_ep_autoconfig_reset (struct usb_gadget *); +extern void usb_ep_autoconfig_reset(struct usb_gadget *);
extern int usb_gadget_handle_interrupts(void);
2010/9/10 vkuzmichev@mvista.com:
- /* NOTE this is analagous to 'struct urb' on the host side,
- * except that it's thinner and promotes more pre-allocation.
Multi-line comments should be like: /* * comment line 1 * comment line 2 */
NOT: /* comment line 1 * comment line 2 */
Apart from that this patch looks good. Please fix globally.
Kind regards,
Remy
Dear Remy Bohmer,
In message AANLkTi=ptZmysNEmX7ZsRzowra7ZhpaewBj92-2aEGgN@mail.gmail.com you wrote:
Hm... should we not rather try to keep (or bring) this file in sync with the corresponding current Linux header file?
Hello,
Wolfgang Denk wrote:
Dear Remy Bohmer,
Yes, we should. In linux this comment was moved into previous: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdif... I'm going to fix this and add more details in the header.
____ With best regards, Vitaly Kuzmichev.
Hi Wolfgang,
2010/9/11 Wolfgang Denk wd@denx.de:
Dear Remy Bohmer,
Yes indeed. Where possible we should keep the files in sync. However in the USB gadget layer there are a few files for which it is difficult to keep them in sync with Linux. This header is not one of them...
Kind regards,
Remy
Fixes most of checkpatch warnings and errors in USB gadget stack.
The most frequently encountered problems are: 1) "(foo*)", "foo * bar", "foo* bar" 2) C99 // comments 3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '(' 4) Spaces before '[' 5) Spaces between function names and '(' 6) Block braces in wrong places 7) Spaces before tabs 8) Macros with complex values not enclosed in parenthesis
Signed-off-by: Vitaly Kuzmichev vkuzmichev@mvista.com --- drivers/usb/gadget/config.c | 2 +- drivers/usb/gadget/epautoconf.c | 73 ++++---- drivers/usb/gadget/ether.c | 398 ++++++++++++++++++------------------ drivers/usb/gadget/gadget_chips.h | 51 +++--- drivers/usb/gadget/usbstring.c | 48 +++-- include/linux/usb/cdc.h | 16 +- include/linux/usb/ch9.h | 4 +- include/linux/usb/gadget.h | 120 +++++------ 8 files changed, 352 insertions(+), 360 deletions(-)
- list_for_each_entry (ep, &gadget->ep_list, ep_list) { + list_for_each_entry(ep, &gadget->ep_list, ep_list) { ep->driver_data = NULL; } #ifdef MANY_ENDPOINTS diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2965299..12cb082 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -89,8 +89,8 @@ unsigned packet_received, packet_sent; /* Based on linux 2.6.27 version */ #define DRIVER_VERSION "May Day 2005"
-static void eth_reset_config (struct eth_dev *dev) +static void eth_reset_config(struct eth_dev *dev) { if (dev->config == 0) return; @@ -827,22 +827,22 @@ static void eth_reset_config (struct eth_dev *dev) */
if (dev->in) { - usb_ep_disable (dev->in_ep); + usb_ep_disable(dev->in_ep); if (dev->tx_req) { - usb_ep_free_request (dev->in_ep, dev->tx_req); - dev->tx_req=NULL; + usb_ep_free_request(dev->in_ep, dev->tx_req); + dev->tx_req = NULL; } } if (dev->out) { - usb_ep_disable (dev->out_ep); + usb_ep_disable(dev->out_ep); if (dev->rx_req) { - usb_ep_free_request (dev->out_ep, dev->rx_req); - dev->rx_req=NULL; + usb_ep_free_request(dev->out_ep, dev->rx_req); + dev->rx_req = NULL; } } - if (dev->status) { - usb_ep_disable (dev->status_ep); - } + if (dev->status) + usb_ep_disable(dev->status_ep); + dev->cdc_filter = 0; dev->config = 0; } @@ -850,23 +850,24 @@ static void eth_reset_config (struct eth_dev *dev) /* change our operational config. must agree with the code * that returns config descriptors, and altsetting code. */ -static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags) +static int eth_set_config(struct eth_dev *dev, unsigned number, + gfp_t gfp_flags) { int result = 0; struct usb_gadget *gadget = dev->gadget;
-static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ +static int rx_submit(struct eth_dev *dev, struct usb_request *req, gfp_t gfp_flags) { int retval = -ENOMEM; @@ -1245,37 +1248,37 @@ static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ req->length = size; req->complete = rx_complete;
- if (retval) { + if (retval) error("rx submit --> %d", retval); - } + return retval; }
/* preallocate control message data and buffer */ - dev->req = usb_ep_alloc_request (gadget->ep0, GFP_KERNEL); + dev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); if (!dev->req) goto fail; dev->req->buf = control_req; @@ -1726,9 +1729,10 @@ autoconf_fail: /* ... and maybe likewise for status transfer */ #if defined(DEV_CONFIG_CDC) if (dev->status_ep) { - dev->stat_req = usb_ep_alloc_request(dev->status_ep, GFP_KERNEL); + dev->stat_req = usb_ep_alloc_request(dev->status_ep, + GFP_KERNEL); if (!dev->stat_req) { - usb_ep_free_request (dev->status_ep, dev->req); + usb_ep_free_request(dev->status_ep, dev->req);
goto fail; } @@ -1739,7 +1743,7 @@ autoconf_fail:
/* two kinds of host-initiated state changes: @@ -1750,13 +1754,13 @@ autoconf_fail:
-static int usb_eth_init(struct eth_device* netdev, bd_t* bd) +static int usb_eth_init(struct eth_device *netdev, bd_t *bd) { - struct eth_dev *dev=&l_ethdev; + struct eth_dev *dev = &l_ethdev; struct usb_gadget *gadget; unsigned long ts; unsigned long timeout = USB_CONNECT_TIMEOUT; @@ -1780,8 +1784,7 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) timeout = simple_strtoul(getenv("cdc_connect_timeout"), NULL, 10) * CONFIG_SYS_HZ; ts = get_timer(0); - while (!l_ethdev.network_started) - { + while (!l_ethdev.network_started) { /* Handle control-c and timeouts */ if (ctrlc() || (get_timer(ts) > timeout)) { error("The remote end did not respond in time."); @@ -1790,19 +1793,20 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) usb_gadget_handle_interrupts(); }
@@ -1827,54 +1831,50 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le req->no_interrupt = (dev->gadget->speed == USB_SPEED_HIGH) ? ((dev->tx_qlen % qmult) != 0) : 0; #endif - dev->tx_qlen=1; - ts = get_timer(0); - packet_sent = 0; + dev->tx_qlen = 1; + ts = get_timer(0); + packet_sent = 0;
return 0; }
if (dev->rx_req) - rx_submit (dev, dev->rx_req, 0); - } - else error("dev->rx_req invalid"); + rx_submit(dev, dev->rx_req, 0); + } else + error("dev->rx_req invalid"); } return 0; }
- if (!netdev) - { + if (!netdev) { error("received NULL ptr"); return; } @@ -1898,9 +1898,9 @@ static struct usb_gadget_driver eth_driver = { int usb_eth_initialize(bd_t *bi) { int status = 0; - struct eth_device *netdev=&l_netdev; + struct eth_device *netdev = &l_netdev;
/** * usb_gadget_controller_number - support bcdDevice id convention diff --git a/drivers/usb/gadget/usbstring.c b/drivers/usb/gadget/usbstring.c index 168f75f..6e9d1bf 100644 --- a/drivers/usb/gadget/usbstring.c +++ b/drivers/usb/gadget/usbstring.c @@ -24,14 +24,17 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) u8 c; u16 uchar;
- /* this insists on correct encodings, though not minimal ones. + /* + * this insists on correct encodings, though not minimal ones. * BUT it currently rejects legit 4-byte UTF-8 code points, * which need surrogate pairs. (Unicode 3.1 can use them.) */ while (len != 0 && (c = (u8) *s++) != 0) { if ((c & 0x80)) { - // 2-byte sequence: - // 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + /* + * 2-byte sequence: + * 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + */ if ((c & 0xe0) == 0xc0) { uchar = (c & 0x1f) << 6;
@@ -41,8 +44,10 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) c &= 0x3f; uchar |= c;
- // 3-byte sequence (most CJKV characters): - // zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + /* + * 3-byte sequence (most CJKV characters): + * zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + */ } else if ((c & 0xf0) == 0xe0) { uchar = (c & 0x0f) << 12;
@@ -62,12 +67,13 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) if (0xd800 <= uchar && uchar <= 0xdfff) goto fail;
- // 4-byte sequence (surrogate pairs, currently rare): - // 11101110wwwwzzzzyy + 110111yyyyxxxxxx - // = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx - // (uuuuu = wwww + 1) - // FIXME accept the surrogate code points (only) - + /* + * 4-byte sequence (surrogate pairs, currently rare): + * 11101110wwwwzzzzyy + 110111yyyyxxxxxx + * = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx + * (uuuuu = wwww + 1) + * FIXME accept the surrogate code points (only) + */ } else goto fail; } else @@ -100,17 +106,17 @@ fail: * characters (which are also widely used in C strings). */ int -usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) +usb_gadget_get_string(struct usb_gadget_strings *table, int id, u8 *buf) { struct usb_string *s; int len;
/* descriptor 0 has the language id */ if (id == 0) { - buf [0] = 4; - buf [1] = USB_DT_STRING; - buf [2] = (u8) table->language; - buf [3] = (u8) (table->language >> 8); + buf[0] = 4; + buf[1] = USB_DT_STRING; + buf[2] = (u8) table->language; + buf[3] = (u8) (table->language >> 8); return 4; } for (s = table->strings; s && s->s; s++) @@ -122,13 +128,13 @@ usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) return -EINVAL;
diff --git a/include/linux/usb/cdc.h b/include/linux/usb/cdc.h index 9b129c9..03541cb 100644 --- a/include/linux/usb/cdc.h +++ b/include/linux/usb/cdc.h @@ -34,16 +34,16 @@ * Class-Specific descriptors ... there are a couple dozen of them */
-#define USB_CDC_HEADER_TYPE 0x00 /* header_desc */ -#define USB_CDC_CALL_MANAGEMENT_TYPE 0x01 /* call_mgmt_descriptor */ -#define USB_CDC_ACM_TYPE 0x02 /* acm_descriptor */ -#define USB_CDC_UNION_TYPE 0x06 /* union_desc */ +#define USB_CDC_HEADER_TYPE 0x00 /* header_desc */ +#define USB_CDC_CALL_MANAGEMENT_TYPE 0x01 /* call_mgmt_descriptor */ +#define USB_CDC_ACM_TYPE 0x02 /* acm_descriptor */ +#define USB_CDC_UNION_TYPE 0x06 /* union_desc */ #define USB_CDC_COUNTRY_TYPE 0x07 -#define USB_CDC_NETWORK_TERMINAL_TYPE 0x0a /* network_terminal_desc */ -#define USB_CDC_ETHERNET_TYPE 0x0f /* ether_desc */ +#define USB_CDC_NETWORK_TERMINAL_TYPE 0x0a /* network_terminal_desc */ +#define USB_CDC_ETHERNET_TYPE 0x0f /* ether_desc */ #define USB_CDC_WHCM_TYPE 0x11 -#define USB_CDC_MDLM_TYPE 0x12 /* mdlm_desc */ -#define USB_CDC_MDLM_DETAIL_TYPE 0x13 /* mdlm_detail_desc */ +#define USB_CDC_MDLM_TYPE 0x12 /* mdlm_desc */ +#define USB_CDC_MDLM_DETAIL_TYPE 0x13 /* mdlm_detail_desc */ #define USB_CDC_DMM_TYPE 0x14 #define USB_CDC_OBEX_TYPE 0x15
/* * Standard requests, for the bRequest field of a SETUP packet. diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 344fc78..275cb5f 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -73,9 +73,10 @@ struct usb_ep; * * Bulk endpoints can use any size buffers, and can also be used for interrupt * transfers. interrupt-only endpoints can be much less functional. + * + * NOTE: this is analagous to 'struct urb' on the host side, except that + * it's thinner and promotes more pre-allocation. */ - // NOTE this is analagous to 'struct urb' on the host side, - // except that it's thinner and promotes more pre-allocation.
struct usb_request { void *buf; @@ -170,10 +171,10 @@ struct usb_ep { * * returns zero, or a negative error code. */ -static inline int -usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) +static inline int usb_ep_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) { - return ep->ops->enable (ep, desc); + return ep->ops->enable(ep, desc); }
/** @@ -188,10 +189,9 @@ usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) * * returns zero, or a negative error code. */ -static inline int -usb_ep_disable (struct usb_ep *ep) +static inline int usb_ep_disable(struct usb_ep *ep) { - return ep->ops->disable (ep); + return ep->ops->disable(ep); }
/** @@ -208,10 +208,10 @@ usb_ep_disable (struct usb_ep *ep) * * Returns the request, or null if one could not be allocated. */ -static inline struct usb_request * -usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) +static inline struct usb_request *usb_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags) { - return ep->ops->alloc_request (ep, gfp_flags); + return ep->ops->alloc_request(ep, gfp_flags); }
/** @@ -223,10 +223,10 @@ usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) * Caller guarantees the request is not queued, and that it will * no longer be requeued (or otherwise used). */ -static inline void -usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) +static inline void usb_ep_free_request(struct usb_ep *ep, + struct usb_request *req) { - ep->ops->free_request (ep, req); + ep->ops->free_request(ep, req); }
/** @@ -283,10 +283,10 @@ usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) * report errors; errors will also be * reported when the usb peripheral is disconnected. */ -static inline int -usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) +static inline int usb_ep_queue(struct usb_ep *ep, + struct usb_request *req, gfp_t gfp_flags) { - return ep->ops->queue (ep, req, gfp_flags); + return ep->ops->queue(ep, req, gfp_flags); }
/** @@ -303,9 +303,9 @@ usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) * restrictions prevent drivers from supporting configuration changes, * even to configuration zero (a "chapter 9" requirement). */ -static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) +static inline int usb_ep_dequeue(struct usb_ep *ep, struct usb_request *req) { - return ep->ops->dequeue (ep, req); + return ep->ops->dequeue(ep, req); }
/** @@ -329,10 +329,9 @@ static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) * transfer requests are still queued, or if the controller hardware * (usually a FIFO) still holds bytes that the host hasn't collected. */ -static inline int -usb_ep_set_halt (struct usb_ep *ep) +static inline int usb_ep_set_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 1); + return ep->ops->set_halt(ep, 1); }
/** @@ -348,10 +347,9 @@ usb_ep_set_halt (struct usb_ep *ep) * Note that some hardware can't support this request (like pxa2xx_udc), * and accordingly can't correctly implement interface altsettings. */ -static inline int -usb_ep_clear_halt (struct usb_ep *ep) +static inline int usb_ep_clear_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 0); + return ep->ops->set_halt(ep, 0); }
/** @@ -369,11 +367,10 @@ usb_ep_clear_halt (struct usb_ep *ep) * errno if the endpoint doesn't use a FIFO or doesn't support such * precise handling. */ -static inline int -usb_ep_fifo_status (struct usb_ep *ep) +static inline int usb_ep_fifo_status(struct usb_ep *ep) { if (ep->ops->fifo_status) - return ep->ops->fifo_status (ep); + return ep->ops->fifo_status(ep); else return -EOPNOTSUPP; } @@ -387,11 +384,10 @@ usb_ep_fifo_status (struct usb_ep *ep) * must never be used except when endpoint is not being used for any * protocol translation. */ -static inline void -usb_ep_fifo_flush (struct usb_ep *ep) +static inline void usb_ep_fifo_flush(struct usb_ep *ep) { if (ep->ops->fifo_flush) - ep->ops->fifo_flush (ep); + ep->ops->fifo_flush(ep); }
@@ -475,18 +471,18 @@ struct usb_gadget { struct device dev; };
@@ -522,7 +518,6 @@ static inline int gadget_is_otg(struct usb_gadget *g) #endif }
- /** * usb_gadget_frame_number - returns the current frame number * @gadget: controller that reports the frame number @@ -530,9 +525,9 @@ static inline int gadget_is_otg(struct usb_gadget *g) * Returns the usb frame number, normally eleven bits from a SOF packet, * or negative errno if this device doesn't support this capability. */ -static inline int usb_gadget_frame_number (struct usb_gadget *gadget) +static inline int usb_gadget_frame_number(struct usb_gadget *gadget) { - return gadget->ops->get_frame (gadget); + return gadget->ops->get_frame(gadget); }
/** @@ -548,11 +543,11 @@ static inline int usb_gadget_frame_number (struct usb_gadget *gadget) * even if OTG isn't otherwise in use. OTG devices may also start * remote wakeup even when hosts don't explicitly enable it. */ -static inline int usb_gadget_wakeup (struct usb_gadget *gadget) +static inline int usb_gadget_wakeup(struct usb_gadget *gadget) { if (!gadget->ops->wakeup) return -EOPNOTSUPP; - return gadget->ops->wakeup (gadget); + return gadget->ops->wakeup(gadget); }
/** @@ -564,12 +559,11 @@ static inline int usb_gadget_wakeup (struct usb_gadget *gadget) * * returns zero on success, else negative errno. */ -static inline int -usb_gadget_set_selfpowered (struct usb_gadget *gadget) +static inline int usb_gadget_set_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 1); + return gadget->ops->set_selfpowered(gadget, 1); }
/** @@ -582,12 +576,11 @@ usb_gadget_set_selfpowered (struct usb_gadget *gadget) * * returns zero on success, else negative errno. */ -static inline int -usb_gadget_clear_selfpowered (struct usb_gadget *gadget) +static inline int usb_gadget_clear_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 0); + return gadget->ops->set_selfpowered(gadget, 0); }
/** @@ -602,12 +595,11 @@ usb_gadget_clear_selfpowered (struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_connect(struct usb_gadget *gadget) +static inline int usb_gadget_vbus_connect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 1); + return gadget->ops->vbus_session(gadget, 1); }
/** @@ -622,12 +614,11 @@ usb_gadget_vbus_connect(struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) +static inline int usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) { if (!gadget->ops->vbus_draw) return -EOPNOTSUPP; - return gadget->ops->vbus_draw (gadget, mA); + return gadget->ops->vbus_draw(gadget, mA); }
/** @@ -640,12 +631,11 @@ usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_disconnect(struct usb_gadget *gadget) +static inline int usb_gadget_vbus_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 0); + return gadget->ops->vbus_session(gadget, 0); }
/** @@ -659,12 +649,11 @@ usb_gadget_vbus_disconnect(struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_connect (struct usb_gadget *gadget) +static inline int usb_gadget_connect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 1); + return gadget->ops->pullup(gadget, 1); }
/** @@ -682,16 +671,14 @@ usb_gadget_connect (struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_disconnect (struct usb_gadget *gadget) +static inline int usb_gadget_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 0); + return gadget->ops->pullup(gadget, 0); }
/** @@ -774,7 +761,6 @@ struct usb_gadget_driver { };
/* driver modules register and unregister, as usual. @@ -795,7 +781,7 @@ struct usb_gadget_driver { * the bind() functions will be in init sections. * This function must be called in a context that can sleep. */ -int usb_gadget_register_driver (struct usb_gadget_driver *driver); +int usb_gadget_register_driver(struct usb_gadget_driver *driver);
/** * usb_gadget_unregister_driver - unregister a gadget driver @@ -810,7 +796,7 @@ int usb_gadget_register_driver (struct usb_gadget_driver *driver); * will in in exit sections, so may not be linked in some kernels. * This function must be called in a context that can sleep. */ -int usb_gadget_unregister_driver (struct usb_gadget_driver *driver); +int usb_gadget_unregister_driver(struct usb_gadget_driver *driver);
@@ -843,7 +829,7 @@ struct usb_gadget_strings { };
@@ -861,10 +847,10 @@ int usb_gadget_config_buf(const struct usb_config_descriptor *config,
The most frequently encountered problems are: 1) "(foo*)", "foo * bar", "foo* bar" 2) C99 // comments 3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '(' 4) Spaces before '[' 5) Spaces between function names and '(' 6) Block braces in wrong places 7) Spaces before tabs 8) Macros with complex values not enclosed in parenthesis 9) Multiline comments start just after /*
Signed-off-by: Vitaly Kuzmichev vkuzmichev@mvista.com --- drivers/usb/gadget/config.c | 2 +- drivers/usb/gadget/epautoconf.c | 73 +++--- drivers/usb/gadget/ether.c | 510 +++++++++++++++++++------------------ drivers/usb/gadget/gadget_chips.h | 51 ++-- drivers/usb/gadget/usbstring.c | 48 ++-- include/linux/usb/cdc.h | 16 +- include/linux/usb/ch9.h | 4 +- include/linux/usb/gadget.h | 120 ++++----- 8 files changed, 418 insertions(+), 406 deletions(-)
diff --git a/drivers/usb/gadget/config.c b/drivers/usb/gadget/config.c index 84c90f0..cf22629 100644 --- a/drivers/usb/gadget/config.c +++ b/drivers/usb/gadget/config.c @@ -101,7 +101,7 @@ int usb_gadget_config_buf( *cp = *config;
/* then interface/endpoint/class/vendor/... */ - len = usb_descriptor_fillbuf(USB_DT_CONFIG_SIZE + (u8*)buf, + len = usb_descriptor_fillbuf(USB_DT_CONFIG_SIZE + (u8 *)buf, length - USB_DT_CONFIG_SIZE, desc); if (len < 0) return len; diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c index e11cc20..7cf3c67 100644 --- a/drivers/usb/gadget/epautoconf.c +++ b/drivers/usb/gadget/epautoconf.c @@ -32,7 +32,7 @@ /* we must assign addresses for configurable endpoints (like net2280) */ static unsigned epnum;
-// #define MANY_ENDPOINTS +/* #define MANY_ENDPOINTS */ #ifdef MANY_ENDPOINTS /* more than 15 configurable endpoints */ static unsigned in_epnum; @@ -55,8 +55,7 @@ static unsigned in_epnum; * NOTE: each endpoint is unidirectional, as specified by its USB * descriptor; and isn't specific to a configuration or altsetting. */ -static int -ep_matches ( +static int ep_matches( struct usb_gadget *gadget, struct usb_ep *ep, struct usb_endpoint_descriptor *desc @@ -83,37 +82,37 @@ ep_matches ( * direction-restriction: "in", "out". */ if ('-' != ep->name[2]) { - tmp = strrchr (ep->name, '-'); + tmp = strrchr(ep->name, '-'); if (tmp) { switch (type) { case USB_ENDPOINT_XFER_INT: /* bulk endpoints handle interrupt transfers, * except the toggle-quirky iso-synch kind */ - if ('s' == tmp[2]) // == "-iso" + if ('s' == tmp[2]) /* == "-iso" */ return 0; /* for now, avoid PXA "interrupt-in"; * it's documented as never using DATA1. */ - if (gadget_is_pxa (gadget) - && 'i' == tmp [1]) + if (gadget_is_pxa(gadget) + && 'i' == tmp[1]) return 0; break; case USB_ENDPOINT_XFER_BULK: - if ('b' != tmp[1]) // != "-bulk" + if ('b' != tmp[1]) /* != "-bulk" */ return 0; break; case USB_ENDPOINT_XFER_ISOC: - if ('s' != tmp[2]) // != "-iso" + if ('s' != tmp[2]) /* != "-iso" */ return 0; } } else { - tmp = ep->name + strlen (ep->name); + tmp = ep->name + strlen(ep->name); }
/* direction-restriction: "..in-..", "out-.." */ tmp--; - if (!isdigit (*tmp)) { + if (!isdigit(*tmp)) { if (desc->bEndpointAddress & USB_DIR_IN) { if ('n' != *tmp) return 0; @@ -155,8 +154,8 @@ ep_matches ( /* MATCH!! */
/* report address */ - if (isdigit (ep->name [2])) { - u8 num = simple_strtoul (&ep->name [2], NULL, 10); + if (isdigit(ep->name[2])) { + u8 num = simple_strtoul(&ep->name[2], NULL, 10); desc->bEndpointAddress |= num; #ifdef MANY_ENDPOINTS } else if (desc->bEndpointAddress & USB_DIR_IN) { @@ -183,12 +182,12 @@ ep_matches ( }
static struct usb_ep * -find_ep (struct usb_gadget *gadget, const char *name) +find_ep(struct usb_gadget *gadget, const char *name) { struct usb_ep *ep;
- list_for_each_entry (ep, &gadget->ep_list, ep_list) { - if (0 == strcmp (ep->name, name)) + list_for_each_entry(ep, &gadget->ep_list, ep_list) { + if (0 == strcmp(ep->name, name)) return ep; } return NULL; @@ -224,7 +223,7 @@ find_ep (struct usb_gadget *gadget, const char *name) * * On failure, this returns a null endpoint descriptor. */ -struct usb_ep * usb_ep_autoconfig ( +struct usb_ep *usb_ep_autoconfig( struct usb_gadget *gadget, struct usb_endpoint_descriptor *desc ) @@ -237,44 +236,44 @@ struct usb_ep * usb_ep_autoconfig ( /* First, apply chip-specific "best usage" knowledge. * This might make a good usb_gadget_ops hook ... */ - if (gadget_is_net2280 (gadget) && type == USB_ENDPOINT_XFER_INT) { + if (gadget_is_net2280(gadget) && type == USB_ENDPOINT_XFER_INT) { /* ep-e, ep-f are PIO with only 64 byte fifos */ - ep = find_ep (gadget, "ep-e"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep-e"); + if (ep && ep_matches(gadget, ep, desc)) return ep; - ep = find_ep (gadget, "ep-f"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep-f"); + if (ep && ep_matches(gadget, ep, desc)) return ep;
- } else if (gadget_is_goku (gadget)) { + } else if (gadget_is_goku(gadget)) { if (USB_ENDPOINT_XFER_INT == type) { /* single buffering is enough */ - ep = find_ep (gadget, "ep3-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep3-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; } else if (USB_ENDPOINT_XFER_BULK == type && (USB_DIR_IN & desc->bEndpointAddress)) { /* DMA may be available */ - ep = find_ep (gadget, "ep2-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep2-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; }
- } else if (gadget_is_sh (gadget) && USB_ENDPOINT_XFER_INT == type) { + } else if (gadget_is_sh(gadget) && USB_ENDPOINT_XFER_INT == type) { /* single buffering is enough; maybe 8 byte fifo is too */ - ep = find_ep (gadget, "ep3in-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + ep = find_ep(gadget, "ep3in-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep;
- } else if (gadget_is_mq11xx (gadget) && USB_ENDPOINT_XFER_INT == type) { - ep = find_ep (gadget, "ep1-bulk"); - if (ep && ep_matches (gadget, ep, desc)) + } else if (gadget_is_mq11xx(gadget) && USB_ENDPOINT_XFER_INT == type) { + ep = find_ep(gadget, "ep1-bulk"); + if (ep && ep_matches(gadget, ep, desc)) return ep; }
/* Second, look at endpoints until an unclaimed one looks usable */ - list_for_each_entry (ep, &gadget->ep_list, ep_list) { - if (ep_matches (gadget, ep, desc)) + list_for_each_entry(ep, &gadget->ep_list, ep_list) { + if (ep_matches(gadget, ep, desc)) return ep; }
@@ -291,11 +290,11 @@ struct usb_ep * usb_ep_autoconfig ( * state such as ep->driver_data and the record of assigned endpoints * used by usb_ep_autoconfig(). */ -void usb_ep_autoconfig_reset (struct usb_gadget *gadget) +void usb_ep_autoconfig_reset(struct usb_gadget *gadget) { struct usb_ep *ep;
- list_for_each_entry (ep, &gadget->ep_list, ep_list) { + list_for_each_entry(ep, &gadget->ep_list, ep_list) { ep->driver_data = NULL; } #ifdef MANY_ENDPOINTS diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 2965299..0948824 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -89,8 +89,8 @@ unsigned packet_received, packet_sent; /* Based on linux 2.6.27 version */ #define DRIVER_VERSION "May Day 2005"
-static const char shortname [] = "ether"; -static const char driver_desc [] = DRIVER_DESC; +static const char shortname[] = "ether"; +static const char driver_desc[] = DRIVER_DESC;
#define RX_EXTRA 20 /* guard against rx overflows */
@@ -114,7 +114,7 @@ static inline int is_cdc(struct eth_dev *dev) { #if !defined(DEV_CONFIG_SUBSET) return 1; /* only cdc possible */ -#elif !defined (DEV_CONFIG_CDC) +#elif !defined(DEV_CONFIG_CDC) return 0; /* only subset possible */ #else return dev->cdc; /* depends on what hardware we found */ @@ -122,7 +122,7 @@ static inline int is_cdc(struct eth_dev *dev) }
#define subset_active(dev) (!is_cdc(dev)) -#define cdc_active(dev) ( is_cdc(dev)) +#define cdc_active(dev) (is_cdc(dev))
#define DEFAULT_QLEN 2 /* double buffering by default */
@@ -180,15 +180,16 @@ struct eth_dev { unsigned zlp:1; unsigned cdc:1; unsigned suspended:1; - unsigned network_started:1; + unsigned network_started:1; u16 cdc_filter; unsigned long todo; - int mtu; + int mtu; #define WORK_RX_MEMORY 0 - u8 host_mac [ETH_ALEN]; + u8 host_mac[ETH_ALEN]; };
-/* This version autoconfigures as much as possible at run-time. +/* + * This version autoconfigures as much as possible at run-time. * * It also ASSUMES a self-powered device, without remote wakeup, * although remote wakeup support would make sense. @@ -196,17 +197,20 @@ struct eth_dev {
-/* DO NOT REUSE THESE IDs with a protocol-incompatible driver!! Ever!! +/* + * DO NOT REUSE THESE IDs with a protocol-incompatible driver!! Ever!! * Instead: allocate your own, using normal USB-IF procedures. */
-/* Thanks to NetChip Technologies for donating this product ID. +/* + * Thanks to NetChip Technologies for donating this product ID. * It's for devices with only CDC Ethernet configurations. */ #define CDC_VENDOR_NUM 0x0525 /* NetChip */ #define CDC_PRODUCT_NUM 0xa4a1 /* Linux-USB Ethernet Gadget */
-/* For hardware that can't talk CDC, we use the same vendor ID that +/* + * For hardware that can't talk CDC, we use the same vendor ID that * ARM Linux has used for ethernet-over-usb, both with sa1100 and * with pxa250. We're protocol-compatible, if the host-side drivers * use the endpoint descriptors. bcdDevice (version) is nonzero, so @@ -220,7 +224,8 @@ struct eth_dev { #define SIMPLE_VENDOR_NUM 0x049f #define SIMPLE_PRODUCT_NUM 0x505a
-/* Some systems will want different product identifers published in the +/* + * Some systems will want different product identifers published in the * device descriptor, either numbers or strings or both. These string * parameters are in UTF-8 (superset of ASCII's 7 bit characters). */ @@ -238,7 +243,8 @@ static char host_addr[18];
-/* USB DRIVER HOOKUP (to the hardware driver, below us), mostly +/* + * USB DRIVER HOOKUP (to the hardware driver, below us), mostly * ep0 implementation: descriptors, config management, setup(). * also optional class-specific notification interrupt transfer. */ @@ -276,14 +282,14 @@ device_desc = { .bLength = sizeof device_desc, .bDescriptorType = USB_DT_DEVICE,
- .bcdUSB = __constant_cpu_to_le16 (0x0200), + .bcdUSB = __constant_cpu_to_le16(0x0200),
.bDeviceClass = USB_CLASS_COMM, .bDeviceSubClass = 0, .bDeviceProtocol = 0,
- .idVendor = __constant_cpu_to_le16 (CDC_VENDOR_NUM), - .idProduct = __constant_cpu_to_le16 (CDC_PRODUCT_NUM), + .idVendor = __constant_cpu_to_le16(CDC_VENDOR_NUM), + .idProduct = __constant_cpu_to_le16(CDC_PRODUCT_NUM), .iManufacturer = STRING_MANUFACTURER, .iProduct = STRING_PRODUCT, .bNumConfigurations = 1, @@ -338,7 +344,7 @@ static const struct usb_cdc_header_desc header_desc = { .bDescriptorType = USB_DT_CS_INTERFACE, .bDescriptorSubType = USB_CDC_HEADER_TYPE,
- .bcdCDC = __constant_cpu_to_le16 (0x0110), + .bcdCDC = __constant_cpu_to_le16(0x0110), };
#if defined(DEV_CONFIG_CDC) @@ -356,7 +362,8 @@ static const struct usb_cdc_union_desc union_desc = {
-/* "SAFE" loosely follows CDC WMC MDLM, violating the spec in various +/* + * "SAFE" loosely follows CDC WMC MDLM, violating the spec in various * ways: data endpoints live in the control interface, there's no data * interface, and it's not used to talk to a cell phone radio. */ @@ -373,7 +380,8 @@ static const struct usb_cdc_mdlm_desc mdlm_desc = { }, };
-/* since "usb_cdc_mdlm_detail_desc" is a variable length structure, we +/* + * since "usb_cdc_mdlm_detail_desc" is a variable length structure, we * can't really use its struct. All we do here is say that we're using * the submode of "SAFE" which directly matches the CDC Subset. */ @@ -389,24 +397,23 @@ static const u8 mdlm_detail_desc[] = {
#endif
- static const struct usb_cdc_ether_desc ether_desc = { - .bLength = sizeof (ether_desc), + .bLength = sizeof(ether_desc), .bDescriptorType = USB_DT_CS_INTERFACE, .bDescriptorSubType = USB_CDC_ETHERNET_TYPE,
/* this descriptor actually adds value, surprise! */ .iMACAddress = STRING_ETHADDR, - .bmEthernetStatistics = __constant_cpu_to_le32 (0), /* no statistics */ - .wMaxSegmentSize = __constant_cpu_to_le16 (ETH_FRAME_LEN), - .wNumberMCFilters = __constant_cpu_to_le16 (0), + .bmEthernetStatistics = __constant_cpu_to_le32(0), /* no statistics */ + .wMaxSegmentSize = __constant_cpu_to_le16(ETH_FRAME_LEN), + .wNumberMCFilters = __constant_cpu_to_le16(0), .bNumberPowerFilters = 0, };
- #if defined(DEV_CONFIG_CDC)
-/* include the status endpoint if we can, even where it's optional. +/* + * include the status endpoint if we can, even where it's optional. * use wMaxPacketSize big enough to fit CDC_NOTIFY_SPEED_CHANGE in one * packet, to simplify cancellation; and a big transfer interval, to * waste less bandwidth. @@ -427,7 +434,7 @@ fs_status_desc = {
.bEndpointAddress = USB_DIR_IN, .bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .wMaxPacketSize = __constant_cpu_to_le16(STATUS_BYTECOUNT), .bInterval = 1 << LOG2_STATUS_INTERVAL_MSEC, }; #endif @@ -493,7 +500,6 @@ subset_data_intf = {
#endif /* SUBSET */
- static struct usb_endpoint_descriptor fs_source_desc = { .bLength = USB_DT_ENDPOINT_SIZE, @@ -512,7 +518,7 @@ fs_sink_desc = { .bmAttributes = USB_ENDPOINT_XFER_BULK, };
-static const struct usb_descriptor_header *fs_eth_function [11] = { +static const struct usb_descriptor_header *fs_eth_function[11] = { (struct usb_descriptor_header *) &otg_descriptor, #ifdef DEV_CONFIG_CDC /* "cdc" mode descriptors */ @@ -560,7 +566,7 @@ hs_status_desc = { .bDescriptorType = USB_DT_ENDPOINT,
.bmAttributes = USB_ENDPOINT_XFER_INT, - .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .wMaxPacketSize = __constant_cpu_to_le16(STATUS_BYTECOUNT), .bInterval = LOG2_STATUS_INTERVAL_MSEC + 4, }; #endif /* DEV_CONFIG_CDC */ @@ -571,7 +577,7 @@ hs_source_desc = { .bDescriptorType = USB_DT_ENDPOINT,
.bmAttributes = USB_ENDPOINT_XFER_BULK, - .wMaxPacketSize = __constant_cpu_to_le16 (512), + .wMaxPacketSize = __constant_cpu_to_le16(512), };
static struct usb_endpoint_descriptor @@ -580,7 +586,7 @@ hs_sink_desc = { .bDescriptorType = USB_DT_ENDPOINT,
static struct usb_qualifier_descriptor @@ -588,13 +594,13 @@ dev_qualifier = { .bLength = sizeof dev_qualifier, .bDescriptorType = USB_DT_DEVICE_QUALIFIER,
- .bcdUSB = __constant_cpu_to_le16 (0x0200), + .bcdUSB = __constant_cpu_to_le16(0x0200), .bDeviceClass = USB_CLASS_COMM,
.bNumConfigurations = 1, };
-static const struct usb_descriptor_header *hs_eth_function [11] = { +static const struct usb_descriptor_header *hs_eth_function[11] = { (struct usb_descriptor_header *) &otg_descriptor, #ifdef DEV_CONFIG_CDC /* "cdc" mode descriptors */ @@ -640,20 +646,19 @@ ep_desc(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, return fs; }
/* descriptors that are built on-demand */
-static char manufacturer [50]; -static char product_desc [40] = DRIVER_DESC; -static char serial_number [20]; +static char manufacturer[50]; +static char product_desc[40] = DRIVER_DESC; +static char serial_number[20];
/* address that the host will use ... usually assigned at random */ -static char ethaddr [2 * ETH_ALEN + 1]; +static char ethaddr[2 * ETH_ALEN + 1];
/* static strings, in UTF-8 */ -static struct usb_string strings [] = { +static struct usb_string strings[] = { { STRING_MANUFACTURER, manufacturer, }, { STRING_PRODUCT, product_desc, }, { STRING_SERIALNUMBER, serial_number, }, @@ -674,13 +679,11 @@ static struct usb_gadget_strings stringtab = { .strings = strings, };
- /*============================================================================*/ static u8 control_req[USB_BUFSIZ]; static u8 status_req[STATUS_BYTECOUNT] __attribute__ ((aligned(4)));
- /** * strlcpy - Copy a %NUL terminated string into a sized buffer * @dest: Where to copy the string to @@ -704,7 +707,6 @@ size_t strlcpy(char *dest, const char *src, size_t size) return ret; }
/* @@ -730,13 +732,13 @@ config_buf(struct usb_gadget *g, u8 *buf, u8 type, unsigned index, int is_otg) return -EINVAL;
config = ð_config; - function = which_fn (eth); + function = which_fn(eth);
/* for now, don't advertise srp-only devices */ if (!is_otg) function++;
- len = usb_gadget_config_buf (config, buf, USB_BUFSIZ, function); + len = usb_gadget_config_buf(config, buf, USB_BUFSIZ, function); if (len < 0) return len; ((struct usb_config_descriptor *) buf)->bDescriptorType = type; @@ -745,10 +747,10 @@ config_buf(struct usb_gadget *g, u8 *buf, u8 type, unsigned index, int is_otg)
-static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags); +static int alloc_requests(struct eth_dev *dev, unsigned n, gfp_t gfp_flags);
static int -set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) +set_ether_config(struct eth_dev *dev, gfp_t gfp_flags) { int result = 0; struct usb_gadget *gadget = dev->gadget; @@ -756,11 +758,11 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) #if defined(DEV_CONFIG_CDC) /* status endpoint used for (optionally) CDC */ if (!subset_active(dev) && dev->status_ep) { - dev->status = ep_desc (gadget, &hs_status_desc, + dev->status = ep_desc(gadget, &hs_status_desc, &fs_status_desc); dev->status_ep->driver_data = dev;
- result = usb_ep_enable (dev->status_ep, dev->status); + result = usb_ep_enable(dev->status_ep, dev->status); if (result != 0) { debug("enable %s --> %d\n", dev->status_ep->name, result); @@ -775,19 +777,20 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) dev->out = ep_desc(gadget, &hs_sink_desc, &fs_sink_desc); dev->out_ep->driver_data = dev;
- /* With CDC, the host isn't allowed to use these two data + /* + * With CDC, the host isn't allowed to use these two data * endpoints in the default altsetting for the interface. * so we don't activate them yet. Reset from SET_INTERFACE. */ if (!cdc_active(dev)) { - result = usb_ep_enable (dev->in_ep, dev->in); + result = usb_ep_enable(dev->in_ep, dev->in); if (result != 0) { debug("enable %s --> %d\n", dev->in_ep->name, result); goto done; }
- result = usb_ep_enable (dev->out_ep, dev->out); + result = usb_ep_enable(dev->out_ep, dev->out); if (result != 0) { debug("enable %s --> %d\n", dev->out_ep->name, result); @@ -797,15 +800,15 @@ set_ether_config (struct eth_dev *dev, gfp_t gfp_flags)
done: if (result == 0) - result = alloc_requests (dev, qlen (gadget), gfp_flags); + result = alloc_requests(dev, qlen(gadget), gfp_flags);
/* on error, disable any endpoints */ if (result < 0) { if (!subset_active(dev) && dev->status_ep) - (void) usb_ep_disable (dev->status_ep); + (void) usb_ep_disable(dev->status_ep); dev->status = NULL; - (void) usb_ep_disable (dev->in_ep); - (void) usb_ep_disable (dev->out_ep); + (void) usb_ep_disable(dev->in_ep); + (void) usb_ep_disable(dev->out_ep); dev->in = NULL; dev->out = NULL; } @@ -814,59 +817,61 @@ done: return result; }
- -static void eth_reset_config (struct eth_dev *dev) +static void eth_reset_config(struct eth_dev *dev) { if (dev->config == 0) return;
debug("%s\n", __func__);
- /* disable endpoints, forcing (synchronous) completion of + /* + * disable endpoints, forcing (synchronous) completion of * pending i/o. then free the requests. */
-/* change our operational config. must agree with the code +/* + * change our operational config. must agree with the code * that returns config descriptors, and altsetting code. */ -static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags) +static int eth_set_config(struct eth_dev *dev, unsigned number, + gfp_t gfp_flags) { int result = 0; struct usb_gadget *gadget = dev->gadget;
- if (gadget_is_sa1100 (gadget) + if (gadget_is_sa1100(gadget) && dev->config && dev->tx_qlen != 0) { /* tx fifo is full, but we can't clear it...*/ error("can't change configurations"); return -ESPIPE; } - eth_reset_config (dev); + eth_reset_config(dev);
switch (number) { case DEV_CONFIG_VALUE: - result = set_ether_config (dev, gfp_flags); + result = set_ether_config(dev, gfp_flags); break; default: result = -EINVAL; @@ -877,7 +882,7 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags
if (result) { if (number) - eth_reset_config (dev); + eth_reset_config(dev); usb_gadget_vbus_draw(dev->gadget, gadget_is_otg(dev->gadget) ? 8 : 100); } else { @@ -888,17 +893,20 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags usb_gadget_vbus_draw(dev->gadget, power);
switch (gadget->speed) { - case USB_SPEED_FULL: speed = "full"; break; + case USB_SPEED_FULL: + speed = "full"; break; #ifdef CONFIG_USB_GADGET_DUALSPEED - case USB_SPEED_HIGH: speed = "high"; break; + case USB_SPEED_HIGH: + speed = "high"; break; #endif - default: speed = "?"; break; + default: + speed = "?"; break; }
dev->config = number; printf("%s speed config #%d: %d mA, %s, using %s\n", speed, number, power, driver_desc, - (cdc_active(dev)? "CDC Ethernet" + (cdc_active(dev) ? "CDC Ethernet" : "CDC Ethernet Subset")); } return result; @@ -908,13 +916,14 @@ static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags
-/* The interrupt endpoint is used in CDC networking models (Ethernet, ATM) +/* + * The interrupt endpoint is used in CDC networking models (Ethernet, ATM) * only to notify the host about link status changes (which we support) or * report completion of some encapsulated command. Since * we want this CDC Ethernet code to be vendor-neutral, we don't use that * command mechanism; and only one status request is ever queued. */ -static void eth_status_complete (struct usb_ep *ep, struct usb_request *req) +static void eth_status_complete(struct usb_ep *ep, struct usb_request *req) { struct usb_cdc_notification *event = req->buf; int value = req->status; @@ -927,38 +936,38 @@ static void eth_status_complete (struct usb_ep *ep, struct usb_request *req)
event->bmRequestType = 0xA1; event->bNotificationType = USB_CDC_NOTIFY_SPEED_CHANGE; - event->wValue = __constant_cpu_to_le16 (0); - event->wIndex = __constant_cpu_to_le16 (1); - event->wLength = __constant_cpu_to_le16 (8); + event->wValue = __constant_cpu_to_le16(0); + event->wIndex = __constant_cpu_to_le16(1); + event->wLength = __constant_cpu_to_le16(8);
/* SPEED_CHANGE data is up/down speeds in bits/sec */ - data [0] = data [1] = cpu_to_le32 (BITRATE (dev->gadget)); + data[0] = data[1] = cpu_to_le32(BITRATE(dev->gadget));
req->length = STATUS_BYTECOUNT; - value = usb_ep_queue (ep, req, GFP_ATOMIC); + value = usb_ep_queue(ep, req, GFP_ATOMIC); debug("send SPEED_CHANGE --> %d\n", value); if (value == 0) return; } else if (value != -ECONNRESET) { debug("event %02x --> %d\n", event->bNotificationType, value); - if (event->bNotificationType== - USB_CDC_NOTIFY_SPEED_CHANGE) - { - l_ethdev.network_started=1; + if (event->bNotificationType == + USB_CDC_NOTIFY_SPEED_CHANGE) { + l_ethdev.network_started = 1; printf("USB network up!\n"); } } req->context = NULL; }
-static void issue_start_status (struct eth_dev *dev) +static void issue_start_status(struct eth_dev *dev) { struct usb_request *req = dev->stat_req; struct usb_cdc_notification *event; int value;
- /* flush old status + /* + * flush old status * * FIXME ugly idiom, maybe we'd be better with just * a "cancel the whole queue" primitive since any @@ -967,24 +976,25 @@ static void issue_start_status (struct eth_dev *dev) * * FIXME iff req->context != null just dequeue it */ - usb_ep_disable (dev->status_ep); - usb_ep_enable (dev->status_ep, dev->status); + usb_ep_disable(dev->status_ep); + usb_ep_enable(dev->status_ep, dev->status);
- /* 3.8.1 says to issue first NETWORK_CONNECTION, then + /* + * 3.8.1 says to issue first NETWORK_CONNECTION, then * a SPEED_CHANGE. could be useful in some configs. */ event = req->buf; event->bmRequestType = 0xA1; event->bNotificationType = USB_CDC_NOTIFY_NETWORK_CONNECTION; - event->wValue = __constant_cpu_to_le16 (1); /* connected */ - event->wIndex = __constant_cpu_to_le16 (1); + event->wValue = __constant_cpu_to_le16(1); /* connected */ + event->wIndex = __constant_cpu_to_le16(1); event->wLength = 0;
req->length = sizeof *event; req->complete = eth_status_complete; req->context = dev;
- value = usb_ep_queue (dev->status_ep, req, GFP_ATOMIC); + value = usb_ep_queue(dev->status_ep, req, GFP_ATOMIC); if (value < 0) debug("status buf queue --> %d\n", value); } @@ -993,7 +1003,7 @@ static void issue_start_status (struct eth_dev *dev)
-static void eth_setup_complete (struct usb_ep *ep, struct usb_request *req) +static void eth_setup_complete(struct usb_ep *ep, struct usb_request *req) { if (req->status || req->actual != req->length) debug("setup complete --> %d, %d/%d\n", @@ -1010,16 +1020,17 @@ static void eth_setup_complete (struct usb_ep *ep, struct usb_request *req) * - class-specific control requests */ static int -eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +eth_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) { - struct eth_dev *dev = get_gadget_data (gadget); + struct eth_dev *dev = get_gadget_data(gadget); struct usb_request *req = dev->req; int value = -EOPNOTSUPP; u16 wIndex = le16_to_cpu(ctrl->wIndex); u16 wValue = le16_to_cpu(ctrl->wValue); u16 wLength = le16_to_cpu(ctrl->wLength);
- /* descriptors just go into the pre-allocated ep0 buffer, + /* + * descriptors just go into the pre-allocated ep0 buffer, * while config change events may enable network traffic. */
@@ -1034,14 +1045,14 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) switch (wValue >> 8) {
case USB_DT_DEVICE: - value = min (wLength, (u16) sizeof device_desc); - memcpy (req->buf, &device_desc, value); + value = min(wLength, (u16) sizeof device_desc); + memcpy(req->buf, &device_desc, value); break; case USB_DT_DEVICE_QUALIFIER: if (!gadget_is_dualspeed(gadget)) break; - value = min (wLength, (u16) sizeof dev_qualifier); - memcpy (req->buf, &dev_qualifier, value); + value = min(wLength, (u16) sizeof dev_qualifier); + memcpy(req->buf, &dev_qualifier, value); break;
case USB_DT_OTHER_SPEED_CONFIG: @@ -1054,15 +1065,15 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) wValue & 0xff, gadget_is_otg(gadget)); if (value >= 0) - value = min (wLength, (u16) value); + value = min(wLength, (u16) value); break;
case USB_DT_STRING: - value = usb_gadget_get_string (&stringtab, + value = usb_gadget_get_string(&stringtab, wValue & 0xff, req->buf);
break; } @@ -1075,13 +1086,13 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) debug("HNP available\n"); else if (gadget->a_alt_hnp_support) debug("HNP needs a different root port\n"); - value = eth_set_config (dev, wValue, GFP_ATOMIC); + value = eth_set_config(dev, wValue, GFP_ATOMIC); break; case USB_REQ_GET_CONFIGURATION: if (ctrl->bRequestType != USB_DIR_IN) break; *(u8 *)req->buf = dev->config; - value = min (wLength, (u16) 1); + value = min(wLength, (u16) 1); break;
case USB_REQ_SET_INTERFACE: @@ -1092,11 +1103,12 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (!cdc_active(dev) && wIndex != 0) break;
- /* PXA hardware partially handles SET_INTERFACE; + /* + * PXA hardware partially handles SET_INTERFACE; * we need to kluge around that interference. */ - if (gadget_is_pxa (gadget)) { - value = eth_set_config (dev, DEV_CONFIG_VALUE, + if (gadget_is_pxa(gadget)) { + value = eth_set_config(dev, DEV_CONFIG_VALUE, GFP_ATOMIC); goto done_set_intf; } @@ -1107,36 +1119,38 @@ eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) if (wValue != 0) break; if (dev->status) { - usb_ep_disable (dev->status_ep); - usb_ep_enable (dev->status_ep, dev->status); + usb_ep_disable(dev->status_ep); + usb_ep_enable(dev->status_ep, dev->status); } value = 0; break; case 1: /* data intf */ if (wValue > 1) break; - usb_ep_disable (dev->in_ep); - usb_ep_disable (dev->out_ep); + usb_ep_disable(dev->in_ep); + usb_ep_disable(dev->out_ep);
- /* CDC requires the data transfers not be done from + /* + * CDC requires the data transfers not be done from * the default interface setting ... also, setting * the non-default interface resets filters etc. */ if (wValue == 1) { - if (!cdc_active (dev)) + if (!cdc_active(dev)) break; - usb_ep_enable (dev->in_ep, dev->in); - usb_ep_enable (dev->out_ep, dev->out); + usb_ep_enable(dev->in_ep, dev->in); + usb_ep_enable(dev->out_ep, dev->out); dev->cdc_filter = DEFAULT_FILTER; if (dev->status) - issue_start_status (dev); + issue_start_status(dev); }
value = 0; break; } #else - /* FIXME this is wrong, as is the assumption that + /* + * FIXME this is wrong, as is the assumption that * all non-PXA hardware talks real CDC ... */ debug("set_interface ignored!\n"); @@ -1160,12 +1174,13 @@ done_set_intf: /* carrier always ok ...*/ *(u8 *)req->buf = 1 ; } - value = min (wLength, (u16) 1); + value = min(wLength, (u16) 1); break;
#ifdef DEV_CONFIG_CDC case USB_CDC_SET_ETHERNET_PACKET_FILTER: - /* see 6.2.30: no data, wIndex = interface, + /* + * see 6.2.30: no data, wIndex = interface, * wValue = packet filter bitmap */ if (ctrl->bRequestType != (USB_TYPE_CLASS|USB_RECIP_INTERFACE) @@ -1178,7 +1193,8 @@ done_set_intf: value = 0; break;
- /* and potentially: + /* + * and potentially: * case USB_CDC_SET_ETHERNET_MULTICAST_FILTERS: * case USB_CDC_SET_ETHERNET_PM_PATTERN_FILTER: * case USB_CDC_GET_ETHERNET_PM_PATTERN_FILTER: @@ -1199,11 +1215,11 @@ done_set_intf: req->length = value; req->zero = value < wLength && (value % gadget->ep0->maxpacket) == 0; - value = usb_ep_queue (gadget->ep0, req, GFP_ATOMIC); + value = usb_ep_queue(gadget->ep0, req, GFP_ATOMIC); if (value < 0) { debug("ep_queue --> %d\n", value); req->status = 0; - eth_setup_complete (gadget->ep0, req); + eth_setup_complete(gadget->ep0, req); } }
@@ -1211,18 +1227,18 @@ done_set_intf: return value; }
-static void rx_complete (struct usb_ep *ep, struct usb_request *req); +static void rx_complete(struct usb_ep *ep, struct usb_request *req);
-static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ +static int rx_submit(struct eth_dev *dev, struct usb_request *req, gfp_t gfp_flags) { int retval = -ENOMEM; size_t size;
- /* Padding up to RX_EXTRA handles minor disagreements with host. + /* + * Padding up to RX_EXTRA handles minor disagreements with host. * Normally we use the USB "terminate on short read" convention; * so allow up to (N*maxpacket), since that memory is normally * already allocated. Some hardware doesn't deal well with short @@ -1236,8 +1252,8 @@ static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ size += dev->out_ep->maxpacket - 1; size -= size % dev->out_ep->maxpacket;
- - /* Some platforms perform better when IP packets are aligned, + /* + * Some platforms perform better when IP packets are aligned, * but on at least one, checksumming fails otherwise. */
@@ -1245,37 +1261,35 @@ static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ req->length = size; req->complete = rx_complete;
- retval = usb_ep_queue (dev->out_ep, req, gfp_flags); + retval = usb_ep_queue(dev->out_ep, req, gfp_flags);
- -static void rx_complete (struct usb_ep *ep, struct usb_request *req) +static void rx_complete(struct usb_ep *ep, struct usb_request *req) { struct eth_dev *dev = ep->driver_data;
debug("%s: status %d\n", __func__, req->status);
- packet_received=1; + packet_received = 1;
if (req) - dev->rx_req=req; + dev->rx_req = req; }
- -static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags) +static int alloc_requests(struct eth_dev *dev, unsigned n, gfp_t gfp_flags) {
- dev->tx_req = usb_ep_alloc_request (dev->in_ep, 0); + dev->tx_req = usb_ep_alloc_request(dev->in_ep, 0);
if (!dev->tx_req) goto fail;
- dev->rx_req = usb_ep_alloc_request (dev->out_ep, 0); + dev->rx_req = usb_ep_alloc_request(dev->out_ep, 0);
if (!dev->rx_req) goto fail; @@ -1287,17 +1301,16 @@ fail: return -1; }
- -static void tx_complete (struct usb_ep *ep, struct usb_request *req) +static void tx_complete(struct usb_ep *ep, struct usb_request *req) { - debug("%s: status %s\n", __func__, (req->status)?"failed":"ok"); - packet_sent=1; + debug("%s: status %s\n", __func__, (req->status) ? "failed" : "ok"); + packet_sent = 1; }
-static inline int eth_is_promisc (struct eth_dev *dev) +static inline int eth_is_promisc(struct eth_dev *dev) { /* no filters for the CDC subset; always promisc */ - if (subset_active (dev)) + if (subset_active(dev)) return 1; return dev->cdc_filter & USB_CDC_PACKET_TYPE_PROMISCUOUS; } @@ -1415,49 +1428,49 @@ drop: /*-------------------------------------------------------------------------*/ #endif
-static void eth_unbind (struct usb_gadget *gadget) +static void eth_unbind(struct usb_gadget *gadget) { - struct eth_dev *dev = get_gadget_data (gadget); + struct eth_dev *dev = get_gadget_data(gadget);
debug("%s...\n", __func__);
/* we've already been disconnected ... no i/o is active */ if (dev->req) { - usb_ep_free_request (gadget->ep0, dev->req); + usb_ep_free_request(gadget->ep0, dev->req); dev->req = NULL; } if (dev->stat_req) { - usb_ep_free_request (dev->status_ep, dev->stat_req); + usb_ep_free_request(dev->status_ep, dev->stat_req); dev->stat_req = NULL; }
/* unregister_netdev (dev->net);*/ /* free_netdev(dev->net);*/
- set_gadget_data (gadget, NULL); + set_gadget_data(gadget, NULL); }
-static void eth_disconnect (struct usb_gadget *gadget) +static void eth_disconnect(struct usb_gadget *gadget) { - eth_reset_config (get_gadget_data (gadget)); + eth_reset_config(get_gadget_data(gadget)); }
-static void eth_suspend (struct usb_gadget *gadget) +static void eth_suspend(struct usb_gadget *gadget) { /* Not used */ }
-static void eth_resume (struct usb_gadget *gadget) +static void eth_resume(struct usb_gadget *gadget) { /* Not used */ } @@ -1492,12 +1505,12 @@ static int is_eth_addr_valid(char *str) return 0; }
-static u8 nibble (unsigned char c) +static u8 nibble(unsigned char c) { - if (likely (isdigit (c))) + if (likely(isdigit(c))) return c - '0'; - c = toupper (c); - if (likely (isxdigit (c))) + c = toupper(c); + if (likely(isxdigit(c))) return 10 + c - 'A'; return 0; } @@ -1510,13 +1523,13 @@ static int get_ether_addr(const char *str, u8 *dev_addr) for (i = 0; i < 6; i++) { unsigned char num;
- if((*str == '.') || (*str == ':')) + if ((*str == '.') || (*str == ':')) str++; num = nibble(*str++) << 4; num |= (nibble(*str++)); - dev_addr [i] = num; + dev_addr[i] = num; } - if (is_valid_ether_addr (dev_addr)) + if (is_valid_ether_addr(dev_addr)) return 0; } return 1; @@ -1528,17 +1541,18 @@ static int eth_bind(struct usb_gadget *gadget) u8 cdc = 1, zlp = 1; struct usb_ep *in_ep, *out_ep, *status_ep = NULL; int gcnum; - u8 tmp[7]; + u8 tmp[7];
/* these flags are only ever cleared; compiler take note */ #ifndef DEV_CONFIG_CDC cdc = 0; #endif - /* Because most host side USB stacks handle CDC Ethernet, that + /* + * Because most host side USB stacks handle CDC Ethernet, that * standard protocol is _strongly_ preferred for interop purposes. * (By everyone except Microsoft.) */ - if (gadget_is_pxa (gadget)) { + if (gadget_is_pxa(gadget)) { /* pxa doesn't support altsettings */ cdc = 0; } else if (gadget_is_musbhdrc(gadget)) { @@ -1547,20 +1561,22 @@ static int eth_bind(struct usb_gadget *gadget) } else if (gadget_is_sh(gadget)) { /* sh doesn't support multiple interfaces or configs */ cdc = 0; - } else if (gadget_is_sa1100 (gadget)) { + } else if (gadget_is_sa1100(gadget)) { /* hardware can't write zlps */ zlp = 0; - /* sa1100 CAN do CDC, without status endpoint ... we use + /* + * sa1100 CAN do CDC, without status endpoint ... we use * non-CDC to be compatible with ARM Linux-2.4 "usb-eth". */ cdc = 0; }
- gcnum = usb_gadget_controller_number (gadget); + gcnum = usb_gadget_controller_number(gadget); if (gcnum >= 0) - device_desc.bcdDevice = cpu_to_le16 (0x0300 + gcnum); + device_desc.bcdDevice = cpu_to_le16(0x0300 + gcnum); else { - /* can't assume CDC works. don't want to default to + /* + * can't assume CDC works. don't want to default to * anything less functional on CDC-capable hardware, * so we fail in this case. */ @@ -1569,7 +1585,8 @@ static int eth_bind(struct usb_gadget *gadget) return -ENODEV; }
- /* CDC subset ... recognized by Linux since 2.4.10, but Windows + /* + * CDC subset ... recognized by Linux since 2.4.10, but Windows * drivers aren't widely available. (That may be improved by * supporting one submode of the "SAFE" variant of MDLM.) */ @@ -1588,17 +1605,17 @@ static int eth_bind(struct usb_gadget *gadget) if (bcdDevice) device_desc.bcdDevice = cpu_to_le16(bcdDevice); if (iManufacturer) - strlcpy (manufacturer, iManufacturer, sizeof manufacturer); + strlcpy(manufacturer, iManufacturer, sizeof manufacturer); if (iProduct) - strlcpy (product_desc, iProduct, sizeof product_desc); + strlcpy(product_desc, iProduct, sizeof product_desc); if (iSerialNumber) { device_desc.iSerialNumber = STRING_SERIALNUMBER, strlcpy(serial_number, iSerialNumber, sizeof serial_number); }
/* all we really need is bulk IN/OUT */ - usb_ep_autoconfig_reset (gadget); - in_ep = usb_ep_autoconfig (gadget, &fs_source_desc); + usb_ep_autoconfig_reset(gadget); + in_ep = usb_ep_autoconfig(gadget, &fs_source_desc); if (!in_ep) { autoconf_fail: error("can't autoconfigure on %s\n", @@ -1607,17 +1624,18 @@ autoconf_fail: } in_ep->driver_data = in_ep; /* claim */
- out_ep = usb_ep_autoconfig (gadget, &fs_sink_desc); + out_ep = usb_ep_autoconfig(gadget, &fs_sink_desc); if (!out_ep) goto autoconf_fail; out_ep->driver_data = out_ep; /* claim */
#if defined(DEV_CONFIG_CDC) - /* CDC Ethernet control interface doesn't require a status endpoint. + /* + * CDC Ethernet control interface doesn't require a status endpoint. * Since some hosts expect one, try to allocate one anyway. */ if (cdc) { - status_ep = usb_ep_autoconfig (gadget, &fs_status_desc); + status_ep = usb_ep_autoconfig(gadget, &fs_status_desc); if (status_ep) { status_ep->driver_data = status_ep; /* claim */ } else if (cdc) { @@ -1632,7 +1650,8 @@ autoconf_fail: eth_config.bNumInterfaces = 1; eth_config.iConfiguration = STRING_SUBSET;
- /* use functions to set these up, in case we're built to work + /* + * use functions to set these up, in case we're built to work * with multiple controllers and must override CDC Ethernet. */ fs_subset_descriptors(); @@ -1640,7 +1659,7 @@ autoconf_fail: }
device_desc.bMaxPacketSize0 = gadget->ep0->maxpacket; - usb_gadget_set_selfpowered (gadget); + usb_gadget_set_selfpowered(gadget);
if (gadget_is_dualspeed(gadget)) { if (!cdc) @@ -1668,7 +1687,7 @@ autoconf_fail: }
dev->net = &l_netdev; - strcpy (dev->net->name, USB_NET_NAME); + strcpy(dev->net->name, USB_NET_NAME);
dev->cdc = cdc; dev->zlp = zlp; @@ -1677,7 +1696,8 @@ autoconf_fail: dev->out_ep = out_ep; dev->status_ep = status_ep;
- /* Module params for these addresses should come from ID proms. + /* + * Module params for these addresses should come from ID proms. * The host side address is used with CDC, and commonly * ends up in a persistent config database. It's not clear if * host side code for the SAFE thing cares -- its original BLAN @@ -1690,10 +1710,10 @@ autoconf_fail:
get_ether_addr(host_addr, dev->host_mac);
- sprintf (ethaddr, "%02X%02X%02X%02X%02X%02X", - dev->host_mac [0], dev->host_mac [1], - dev->host_mac [2], dev->host_mac [3], - dev->host_mac [4], dev->host_mac [5]); + sprintf(ethaddr, "%02X%02X%02X%02X%02X%02X", + dev->host_mac[0], dev->host_mac[1], + dev->host_mac[2], dev->host_mac[3], + dev->host_mac[4], dev->host_mac[5]);
printf("using %s, OUT %s IN %s%s%s\n", gadget->name, out_ep->name, in_ep->name, @@ -1701,23 +1721,24 @@ autoconf_fail: status_ep ? status_ep->name : "" ); printf("MAC %02x:%02x:%02x:%02x:%02x:%02x\n", - dev->net->enetaddr [0], dev->net->enetaddr [1], - dev->net->enetaddr [2], dev->net->enetaddr [3], - dev->net->enetaddr [4], dev->net->enetaddr [5]); + dev->net->enetaddr[0], dev->net->enetaddr[1], + dev->net->enetaddr[2], dev->net->enetaddr[3], + dev->net->enetaddr[4], dev->net->enetaddr[5]);
if (cdc) { printf("HOST MAC %02x:%02x:%02x:%02x:%02x:%02x\n", - dev->host_mac [0], dev->host_mac [1], - dev->host_mac [2], dev->host_mac [3], - dev->host_mac [4], dev->host_mac [5]); + dev->host_mac[0], dev->host_mac[1], + dev->host_mac[2], dev->host_mac[3], + dev->host_mac[4], dev->host_mac[5]); }
- /* use PKTSIZE (or aligned... from u-boot) and set + /* + * use PKTSIZE (or aligned... from u-boot) and set * wMaxSegmentSize accordingly*/ dev->mtu = PKTSIZE_ALIGN; /* RNDIS does not like this, only 1514, TODO*/
/* preallocate control message data and buffer */ - dev->req = usb_ep_alloc_request (gadget->ep0, GFP_KERNEL); + dev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); if (!dev->req) goto fail; dev->req->buf = control_req; @@ -1726,9 +1747,10 @@ autoconf_fail: /* ... and maybe likewise for status transfer */ #if defined(DEV_CONFIG_CDC) if (dev->status_ep) { - dev->stat_req = usb_ep_alloc_request(dev->status_ep, GFP_KERNEL); + dev->stat_req = usb_ep_alloc_request(dev->status_ep, + GFP_KERNEL); if (!dev->stat_req) { - usb_ep_free_request (dev->status_ep, dev->req); + usb_ep_free_request(dev->status_ep, dev->req);
goto fail; } @@ -1739,10 +1761,11 @@ autoconf_fail:
/* finish hookup to lower layer ... */ dev->gadget = gadget; - set_gadget_data (gadget, dev); + set_gadget_data(gadget, dev); gadget->ep0->driver_data = dev;
- /* two kinds of host-initiated state changes: + /* + * two kinds of host-initiated state changes: * - iff DATA transfer is active, carrier is "on" * - tx queueing enabled if open *and* carrier is "on" */ @@ -1750,13 +1773,13 @@ autoconf_fail:
fail: error("%s failed", __func__); - eth_unbind (gadget); + eth_unbind(gadget); return -ENOMEM; }
-static int usb_eth_init(struct eth_device* netdev, bd_t* bd) +static int usb_eth_init(struct eth_device *netdev, bd_t *bd) { - struct eth_dev *dev=&l_ethdev; + struct eth_dev *dev = &l_ethdev; struct usb_gadget *gadget; unsigned long ts; unsigned long timeout = USB_CONNECT_TIMEOUT; @@ -1780,8 +1803,7 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) timeout = simple_strtoul(getenv("cdc_connect_timeout"), NULL, 10) * CONFIG_SYS_HZ; ts = get_timer(0); - while (!l_ethdev.network_started) - { + while (!l_ethdev.network_started) { /* Handle control-c and timeouts */ if (ctrlc() || (get_timer(ts) > timeout)) { error("The remote end did not respond in time."); @@ -1790,19 +1812,20 @@ static int usb_eth_init(struct eth_device* netdev, bd_t* bd) usb_gadget_handle_interrupts(); }
- rx_submit (dev, dev->rx_req, 0); + rx_submit(dev, dev->rx_req, 0); return 0; fail: return -1; }
-static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int length) +static int usb_eth_send(struct eth_device *netdev, + volatile void *packet, int length) { int retval; struct usb_request *req = NULL; struct eth_dev *dev = &l_ethdev; - unsigned long ts; - unsigned long timeout = USB_CONNECT_TIMEOUT; + unsigned long ts; + unsigned long timeout = USB_CONNECT_TIMEOUT;
debug("%s:...\n", __func__);
@@ -1812,7 +1835,8 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le req->context = NULL; req->complete = tx_complete;
- /* use zlp framing on tx for strict CDC-Ether conformance, + /* + * use zlp framing on tx for strict CDC-Ether conformance, * though any robust network rx path ignores extra padding. * and some hardware doesn't like to write zlps. */ @@ -1827,54 +1851,50 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le req->no_interrupt = (dev->gadget->speed == USB_SPEED_HIGH) ? ((dev->tx_qlen % qmult) != 0) : 0; #endif - dev->tx_qlen=1; - ts = get_timer(0); - packet_sent = 0; + dev->tx_qlen = 1; + ts = get_timer(0); + packet_sent = 0;
- retval = usb_ep_queue (dev->in_ep, req, GFP_ATOMIC); + retval = usb_ep_queue(dev->in_ep, req, GFP_ATOMIC);
if (!retval) debug("%s: packet queued\n", __func__); - while(!packet_sent) - { - if (get_timer(ts) > timeout) { - printf("timeout sending packets to usb ethernet\n"); - return -1; - } - usb_gadget_handle_interrupts(); + while (!packet_sent) { + if (get_timer(ts) > timeout) { + printf("timeout sending packets to usb ethernet\n"); + return -1; + } + usb_gadget_handle_interrupts(); }
return 0; }
-static int usb_eth_recv(struct eth_device* netdev) +static int usb_eth_recv(struct eth_device *netdev) { struct eth_dev *dev = &l_ethdev;
- if (packet_received) - { - debug("%s: packet received \n", __func__); - if (dev->rx_req) - { - NetReceive(NetRxPackets[0],dev->rx_req->length); - packet_received=0; + if (packet_received) { + debug("%s: packet received\n", __func__); + if (dev->rx_req) { + NetReceive(NetRxPackets[0], dev->rx_req->length); + packet_received = 0;
-void usb_eth_halt(struct eth_device* netdev) +void usb_eth_halt(struct eth_device *netdev) { - struct eth_dev *dev =&l_ethdev; + struct eth_dev *dev = &l_ethdev;
- if (!netdev) - { + if (!netdev) { error("received NULL ptr"); return; } @@ -1898,9 +1918,9 @@ static struct usb_gadget_driver eth_driver = { int usb_eth_initialize(bd_t *bi) { int status = 0; - struct eth_device *netdev=&l_netdev; + struct eth_device *netdev = &l_netdev;
- sprintf(netdev->name,"usb_ether"); + sprintf(netdev->name, "usb_ether");
netdev->init = usb_eth_init; netdev->send = usb_eth_send; diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index 480bc87..9bb7e2e 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -15,109 +15,109 @@ * Remy Bohmer linux@bohmer.net */ #ifdef CONFIG_USB_GADGET_NET2280 -#define gadget_is_net2280(g) !strcmp("net2280", (g)->name) +#define gadget_is_net2280(g) (!strcmp("net2280", (g)->name)) #else #define gadget_is_net2280(g) 0 #endif
#ifdef CONFIG_USB_GADGET_AMD5536UDC -#define gadget_is_amd5536udc(g) !strcmp("amd5536udc", (g)->name) +#define gadget_is_amd5536udc(g) (!strcmp("amd5536udc", (g)->name)) #else #define gadget_is_amd5536udc(g) 0 #endif
#ifdef CONFIG_USB_GADGET_DUMMY_HCD -#define gadget_is_dummy(g) !strcmp("dummy_udc", (g)->name) +#define gadget_is_dummy(g) (!strcmp("dummy_udc", (g)->name)) #else #define gadget_is_dummy(g) 0 #endif
#ifdef CONFIG_USB_GADGET_PXA2XX -#define gadget_is_pxa(g) !strcmp("pxa2xx_udc", (g)->name) +#define gadget_is_pxa(g) (!strcmp("pxa2xx_udc", (g)->name)) #else #define gadget_is_pxa(g) 0 #endif
#ifdef CONFIG_USB_GADGET_GOKU -#define gadget_is_goku(g) !strcmp("goku_udc", (g)->name) +#define gadget_is_goku(g) (!strcmp("goku_udc", (g)->name)) #else #define gadget_is_goku(g) 0 #endif
/* SH3 UDC -- not yet ported 2.4 --> 2.6 */ #ifdef CONFIG_USB_GADGET_SUPERH -#define gadget_is_sh(g) !strcmp("sh_udc", (g)->name) +#define gadget_is_sh(g) (!strcmp("sh_udc", (g)->name)) #else #define gadget_is_sh(g) 0 #endif
/* not yet stable on 2.6 (would help "original Zaurus") */ #ifdef CONFIG_USB_GADGET_SA1100 -#define gadget_is_sa1100(g) !strcmp("sa1100_udc", (g)->name) +#define gadget_is_sa1100(g) (!strcmp("sa1100_udc", (g)->name)) #else #define gadget_is_sa1100(g) 0 #endif
#ifdef CONFIG_USB_GADGET_LH7A40X -#define gadget_is_lh7a40x(g) !strcmp("lh7a40x_udc", (g)->name) +#define gadget_is_lh7a40x(g) (!strcmp("lh7a40x_udc", (g)->name)) #else #define gadget_is_lh7a40x(g) 0 #endif
/* handhelds.org tree (?) */ #ifdef CONFIG_USB_GADGET_MQ11XX -#define gadget_is_mq11xx(g) !strcmp("mq11xx_udc", (g)->name) +#define gadget_is_mq11xx(g) (!strcmp("mq11xx_udc", (g)->name)) #else #define gadget_is_mq11xx(g) 0 #endif
#ifdef CONFIG_USB_GADGET_OMAP -#define gadget_is_omap(g) !strcmp("omap_udc", (g)->name) +#define gadget_is_omap(g) (!strcmp("omap_udc", (g)->name)) #else #define gadget_is_omap(g) 0 #endif
/* not yet ported 2.4 --> 2.6 */ #ifdef CONFIG_USB_GADGET_N9604 -#define gadget_is_n9604(g) !strcmp("n9604_udc", (g)->name) +#define gadget_is_n9604(g) (!strcmp("n9604_udc", (g)->name)) #else #define gadget_is_n9604(g) 0 #endif
/* various unstable versions available */ #ifdef CONFIG_USB_GADGET_PXA27X -#define gadget_is_pxa27x(g) !strcmp("pxa27x_udc", (g)->name) +#define gadget_is_pxa27x(g) (!strcmp("pxa27x_udc", (g)->name)) #else #define gadget_is_pxa27x(g) 0 #endif
#ifdef CONFIG_USB_GADGET_ATMEL_USBA -#define gadget_is_atmel_usba(g) !strcmp("atmel_usba_udc", (g)->name) +#define gadget_is_atmel_usba(g) (!strcmp("atmel_usba_udc", (g)->name)) #else #define gadget_is_atmel_usba(g) 0 #endif
#ifdef CONFIG_USB_GADGET_S3C2410 -#define gadget_is_s3c2410(g) !strcmp("s3c2410_udc", (g)->name) +#define gadget_is_s3c2410(g) (!strcmp("s3c2410_udc", (g)->name)) #else #define gadget_is_s3c2410(g) 0 #endif
#ifdef CONFIG_USB_GADGET_AT91 -#define gadget_is_at91(g) !strcmp("at91_udc", (g)->name) +#define gadget_is_at91(g) (!strcmp("at91_udc", (g)->name)) #else #define gadget_is_at91(g) 0 #endif
/* status unclear */ #ifdef CONFIG_USB_GADGET_IMX -#define gadget_is_imx(g) !strcmp("imx_udc", (g)->name) +#define gadget_is_imx(g) (!strcmp("imx_udc", (g)->name)) #else #define gadget_is_imx(g) 0 #endif
#ifdef CONFIG_USB_GADGET_FSL_USB2 -#define gadget_is_fsl_usb2(g) !strcmp("fsl-usb2-udc", (g)->name) +#define gadget_is_fsl_usb2(g) (!strcmp("fsl-usb2-udc", (g)->name)) #else #define gadget_is_fsl_usb2(g) 0 #endif @@ -125,36 +125,37 @@ /* Mentor high speed function controller */ /* from Montavista kernel (?) */ #ifdef CONFIG_USB_GADGET_MUSBHSFC -#define gadget_is_musbhsfc(g) !strcmp("musbhsfc_udc", (g)->name) +#define gadget_is_musbhsfc(g) (!strcmp("musbhsfc_udc", (g)->name)) #else #define gadget_is_musbhsfc(g) 0 #endif
/* Mentor high speed "dual role" controller, in peripheral role */ #ifdef CONFIG_USB_GADGET_MUSB_HDRC -#define gadget_is_musbhdrc(g) !strcmp("musb_hdrc", (g)->name) +#define gadget_is_musbhdrc(g) (!strcmp("musb_hdrc", (g)->name)) #else #define gadget_is_musbhdrc(g) 0 #endif
/* from Montavista kernel (?) */ #ifdef CONFIG_USB_GADGET_MPC8272 -#define gadget_is_mpc8272(g) !strcmp("mpc8272_udc", (g)->name) +#define gadget_is_mpc8272(g) (!strcmp("mpc8272_udc", (g)->name)) #else #define gadget_is_mpc8272(g) 0 #endif
#ifdef CONFIG_USB_GADGET_M66592 -#define gadget_is_m66592(g) !strcmp("m66592_udc", (g)->name) +#define gadget_is_m66592(g) (!strcmp("m66592_udc", (g)->name)) #else #define gadget_is_m66592(g) 0 #endif
-// CONFIG_USB_GADGET_SX2 -// CONFIG_USB_GADGET_AU1X00 -// ... - +/* + * CONFIG_USB_GADGET_SX2 + * CONFIG_USB_GADGET_AU1X00 + * ... + */
/** * usb_gadget_controller_number - support bcdDevice id convention diff --git a/drivers/usb/gadget/usbstring.c b/drivers/usb/gadget/usbstring.c index 168f75f..6e9d1bf 100644 --- a/drivers/usb/gadget/usbstring.c +++ b/drivers/usb/gadget/usbstring.c @@ -24,14 +24,17 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) u8 c; u16 uchar;
- /* this insists on correct encodings, though not minimal ones. + /* + * this insists on correct encodings, though not minimal ones. * BUT it currently rejects legit 4-byte UTF-8 code points, * which need surrogate pairs. (Unicode 3.1 can use them.) */ while (len != 0 && (c = (u8) *s++) != 0) { if ((c & 0x80)) { - // 2-byte sequence: - // 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + /* + * 2-byte sequence: + * 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + */ if ((c & 0xe0) == 0xc0) { uchar = (c & 0x1f) << 6;
@@ -41,8 +44,10 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) c &= 0x3f; uchar |= c;
- // 3-byte sequence (most CJKV characters): - // zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + /* + * 3-byte sequence (most CJKV characters): + * zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + */ } else if ((c & 0xf0) == 0xe0) { uchar = (c & 0x0f) << 12;
@@ -62,12 +67,13 @@ static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) if (0xd800 <= uchar && uchar <= 0xdfff) goto fail;
- // 4-byte sequence (surrogate pairs, currently rare): - // 11101110wwwwzzzzyy + 110111yyyyxxxxxx - // = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx - // (uuuuu = wwww + 1) - // FIXME accept the surrogate code points (only) - + /* + * 4-byte sequence (surrogate pairs, currently rare): + * 11101110wwwwzzzzyy + 110111yyyyxxxxxx + * = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx + * (uuuuu = wwww + 1) + * FIXME accept the surrogate code points (only) + */ } else goto fail; } else @@ -100,17 +106,17 @@ fail: * characters (which are also widely used in C strings). */ int -usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) +usb_gadget_get_string(struct usb_gadget_strings *table, int id, u8 *buf) { struct usb_string *s; int len;
/* descriptor 0 has the language id */ if (id == 0) { - buf [0] = 4; - buf [1] = USB_DT_STRING; - buf [2] = (u8) table->language; - buf [3] = (u8) (table->language >> 8); + buf[0] = 4; + buf[1] = USB_DT_STRING; + buf[2] = (u8) table->language; + buf[3] = (u8) (table->language >> 8); return 4; } for (s = table->strings; s && s->s; s++) @@ -122,13 +128,13 @@ usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) return -EINVAL;
/* string descriptors have length, tag, then UTF16-LE text */ - len = min ((size_t) 126, strlen (s->s)); - memset (buf + 2, 0, 2 * len); /* zero all the bytes */ + len = min((size_t) 126, strlen(s->s)); + memset(buf + 2, 0, 2 * len); /* zero all the bytes */ len = utf8_to_utf16le(s->s, (__le16 *)&buf[2], len); if (len < 0) return -EINVAL; - buf [0] = (len + 1) * 2; - buf [1] = USB_DT_STRING; - return buf [0]; + buf[0] = (len + 1) * 2; + buf[1] = USB_DT_STRING; + return buf[0]; }
diff --git a/include/linux/usb/cdc.h b/include/linux/usb/cdc.h index 9b129c9..03541cb 100644 --- a/include/linux/usb/cdc.h +++ b/include/linux/usb/cdc.h @@ -34,16 +34,16 @@ * Class-Specific descriptors ... there are a couple dozen of them */
-#define USB_CDC_HEADER_TYPE 0x00 /* header_desc */ -#define USB_CDC_CALL_MANAGEMENT_TYPE 0x01 /* call_mgmt_descriptor */ -#define USB_CDC_ACM_TYPE 0x02 /* acm_descriptor */ -#define USB_CDC_UNION_TYPE 0x06 /* union_desc */ +#define USB_CDC_HEADER_TYPE 0x00 /* header_desc */ +#define USB_CDC_CALL_MANAGEMENT_TYPE 0x01 /* call_mgmt_descriptor */ +#define USB_CDC_ACM_TYPE 0x02 /* acm_descriptor */ +#define USB_CDC_UNION_TYPE 0x06 /* union_desc */ #define USB_CDC_COUNTRY_TYPE 0x07 -#define USB_CDC_NETWORK_TERMINAL_TYPE 0x0a /* network_terminal_desc */ -#define USB_CDC_ETHERNET_TYPE 0x0f /* ether_desc */ +#define USB_CDC_NETWORK_TERMINAL_TYPE 0x0a /* network_terminal_desc */ +#define USB_CDC_ETHERNET_TYPE 0x0f /* ether_desc */ #define USB_CDC_WHCM_TYPE 0x11 -#define USB_CDC_MDLM_TYPE 0x12 /* mdlm_desc */ -#define USB_CDC_MDLM_DETAIL_TYPE 0x13 /* mdlm_detail_desc */ +#define USB_CDC_MDLM_TYPE 0x12 /* mdlm_desc */ +#define USB_CDC_MDLM_DETAIL_TYPE 0x13 /* mdlm_detail_desc */ #define USB_CDC_DMM_TYPE 0x14 #define USB_CDC_OBEX_TYPE 0x15
diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h index 1091692..49b7483 100644 --- a/include/linux/usb/ch9.h +++ b/include/linux/usb/ch9.h @@ -69,8 +69,8 @@ #define USB_RECIP_ENDPOINT 0x02 #define USB_RECIP_OTHER 0x03 /* From Wireless USB 1.0 */ -#define USB_RECIP_PORT 0x04 -#define USB_RECIP_RPIPE 0x05 +#define USB_RECIP_PORT 0x04 +#define USB_RECIP_RPIPE 0x05
/* * Standard requests, for the bRequest field of a SETUP packet. diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 344fc78..275cb5f 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -73,9 +73,10 @@ struct usb_ep; * * Bulk endpoints can use any size buffers, and can also be used for interrupt * transfers. interrupt-only endpoints can be much less functional. + * + * NOTE: this is analagous to 'struct urb' on the host side, except that + * it's thinner and promotes more pre-allocation. */ - // NOTE this is analagous to 'struct urb' on the host side, - // except that it's thinner and promotes more pre-allocation.
struct usb_request { void *buf; @@ -170,10 +171,10 @@ struct usb_ep { * * returns zero, or a negative error code. */ -static inline int -usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) +static inline int usb_ep_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) { - return ep->ops->enable (ep, desc); + return ep->ops->enable(ep, desc); }
/** @@ -188,10 +189,9 @@ usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) * * returns zero, or a negative error code. */ -static inline int -usb_ep_disable (struct usb_ep *ep) +static inline int usb_ep_disable(struct usb_ep *ep) { - return ep->ops->disable (ep); + return ep->ops->disable(ep); }
/** @@ -208,10 +208,10 @@ usb_ep_disable (struct usb_ep *ep) * * Returns the request, or null if one could not be allocated. */ -static inline struct usb_request * -usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) +static inline struct usb_request *usb_ep_alloc_request(struct usb_ep *ep, + gfp_t gfp_flags) { - return ep->ops->alloc_request (ep, gfp_flags); + return ep->ops->alloc_request(ep, gfp_flags); }
/** @@ -223,10 +223,10 @@ usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) * Caller guarantees the request is not queued, and that it will * no longer be requeued (or otherwise used). */ -static inline void -usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) +static inline void usb_ep_free_request(struct usb_ep *ep, + struct usb_request *req) { - ep->ops->free_request (ep, req); + ep->ops->free_request(ep, req); }
/** @@ -283,10 +283,10 @@ usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) * report errors; errors will also be * reported when the usb peripheral is disconnected. */ -static inline int -usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) +static inline int usb_ep_queue(struct usb_ep *ep, + struct usb_request *req, gfp_t gfp_flags) { - return ep->ops->queue (ep, req, gfp_flags); + return ep->ops->queue(ep, req, gfp_flags); }
/** @@ -303,9 +303,9 @@ usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) * restrictions prevent drivers from supporting configuration changes, * even to configuration zero (a "chapter 9" requirement). */ -static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) +static inline int usb_ep_dequeue(struct usb_ep *ep, struct usb_request *req) { - return ep->ops->dequeue (ep, req); + return ep->ops->dequeue(ep, req); }
/** @@ -329,10 +329,9 @@ static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) * transfer requests are still queued, or if the controller hardware * (usually a FIFO) still holds bytes that the host hasn't collected. */ -static inline int -usb_ep_set_halt (struct usb_ep *ep) +static inline int usb_ep_set_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 1); + return ep->ops->set_halt(ep, 1); }
/** @@ -348,10 +347,9 @@ usb_ep_set_halt (struct usb_ep *ep) * Note that some hardware can't support this request (like pxa2xx_udc), * and accordingly can't correctly implement interface altsettings. */ -static inline int -usb_ep_clear_halt (struct usb_ep *ep) +static inline int usb_ep_clear_halt(struct usb_ep *ep) { - return ep->ops->set_halt (ep, 0); + return ep->ops->set_halt(ep, 0); }
/** @@ -369,11 +367,10 @@ usb_ep_clear_halt (struct usb_ep *ep) * errno if the endpoint doesn't use a FIFO or doesn't support such * precise handling. */ -static inline int -usb_ep_fifo_status (struct usb_ep *ep) +static inline int usb_ep_fifo_status(struct usb_ep *ep) { if (ep->ops->fifo_status) - return ep->ops->fifo_status (ep); + return ep->ops->fifo_status(ep); else return -EOPNOTSUPP; } @@ -387,11 +384,10 @@ usb_ep_fifo_status (struct usb_ep *ep) * must never be used except when endpoint is not being used for any * protocol translation. */ -static inline void -usb_ep_fifo_flush (struct usb_ep *ep) +static inline void usb_ep_fifo_flush(struct usb_ep *ep) { if (ep->ops->fifo_flush) - ep->ops->fifo_flush (ep); + ep->ops->fifo_flush(ep); }
@@ -475,18 +471,18 @@ struct usb_gadget { struct device dev; };
-static inline void set_gadget_data (struct usb_gadget *gadget, void *data) +static inline void set_gadget_data(struct usb_gadget *gadget, void *data) { gadget->dev.driver_data = data; }
-static inline void *get_gadget_data (struct usb_gadget *gadget) +static inline void *get_gadget_data(struct usb_gadget *gadget) { return gadget->dev.driver_data; }
/* iterates the non-control endpoints; 'tmp' is a struct usb_ep pointer */ -#define gadget_for_each_ep(tmp,gadget) \ +#define gadget_for_each_ep(tmp, gadget) \ list_for_each_entry(tmp, &(gadget)->ep_list, ep_list)
@@ -522,7 +518,6 @@ static inline int gadget_is_otg(struct usb_gadget *g) #endif }
- /** * usb_gadget_frame_number - returns the current frame number * @gadget: controller that reports the frame number @@ -530,9 +525,9 @@ static inline int gadget_is_otg(struct usb_gadget *g) * Returns the usb frame number, normally eleven bits from a SOF packet, * or negative errno if this device doesn't support this capability. */ -static inline int usb_gadget_frame_number (struct usb_gadget *gadget) +static inline int usb_gadget_frame_number(struct usb_gadget *gadget) { - return gadget->ops->get_frame (gadget); + return gadget->ops->get_frame(gadget); }
/** @@ -548,11 +543,11 @@ static inline int usb_gadget_frame_number (struct usb_gadget *gadget) * even if OTG isn't otherwise in use. OTG devices may also start * remote wakeup even when hosts don't explicitly enable it. */ -static inline int usb_gadget_wakeup (struct usb_gadget *gadget) +static inline int usb_gadget_wakeup(struct usb_gadget *gadget) { if (!gadget->ops->wakeup) return -EOPNOTSUPP; - return gadget->ops->wakeup (gadget); + return gadget->ops->wakeup(gadget); }
/** @@ -564,12 +559,11 @@ static inline int usb_gadget_wakeup (struct usb_gadget *gadget) * * returns zero on success, else negative errno. */ -static inline int -usb_gadget_set_selfpowered (struct usb_gadget *gadget) +static inline int usb_gadget_set_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 1); + return gadget->ops->set_selfpowered(gadget, 1); }
/** @@ -582,12 +576,11 @@ usb_gadget_set_selfpowered (struct usb_gadget *gadget) * * returns zero on success, else negative errno. */ -static inline int -usb_gadget_clear_selfpowered (struct usb_gadget *gadget) +static inline int usb_gadget_clear_selfpowered(struct usb_gadget *gadget) { if (!gadget->ops->set_selfpowered) return -EOPNOTSUPP; - return gadget->ops->set_selfpowered (gadget, 0); + return gadget->ops->set_selfpowered(gadget, 0); }
/** @@ -602,12 +595,11 @@ usb_gadget_clear_selfpowered (struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_connect(struct usb_gadget *gadget) +static inline int usb_gadget_vbus_connect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 1); + return gadget->ops->vbus_session(gadget, 1); }
/** @@ -622,12 +614,11 @@ usb_gadget_vbus_connect(struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) +static inline int usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) { if (!gadget->ops->vbus_draw) return -EOPNOTSUPP; - return gadget->ops->vbus_draw (gadget, mA); + return gadget->ops->vbus_draw(gadget, mA); }
/** @@ -640,12 +631,11 @@ usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_vbus_disconnect(struct usb_gadget *gadget) +static inline int usb_gadget_vbus_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->vbus_session) return -EOPNOTSUPP; - return gadget->ops->vbus_session (gadget, 0); + return gadget->ops->vbus_session(gadget, 0); }
/** @@ -659,12 +649,11 @@ usb_gadget_vbus_disconnect(struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_connect (struct usb_gadget *gadget) +static inline int usb_gadget_connect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 1); + return gadget->ops->pullup(gadget, 1); }
/** @@ -682,16 +671,14 @@ usb_gadget_connect (struct usb_gadget *gadget) * * Returns zero on success, else negative errno. */ -static inline int -usb_gadget_disconnect (struct usb_gadget *gadget) +static inline int usb_gadget_disconnect(struct usb_gadget *gadget) { if (!gadget->ops->pullup) return -EOPNOTSUPP; - return gadget->ops->pullup (gadget, 0); + return gadget->ops->pullup(gadget, 0); }
/** @@ -774,7 +761,6 @@ struct usb_gadget_driver { };
/* driver modules register and unregister, as usual. @@ -795,7 +781,7 @@ struct usb_gadget_driver { * the bind() functions will be in init sections. * This function must be called in a context that can sleep. */ -int usb_gadget_register_driver (struct usb_gadget_driver *driver); +int usb_gadget_register_driver(struct usb_gadget_driver *driver);
/** * usb_gadget_unregister_driver - unregister a gadget driver @@ -810,7 +796,7 @@ int usb_gadget_register_driver (struct usb_gadget_driver *driver); * will in in exit sections, so may not be linked in some kernels. * This function must be called in a context that can sleep. */ -int usb_gadget_unregister_driver (struct usb_gadget_driver *driver); +int usb_gadget_unregister_driver(struct usb_gadget_driver *driver);
@@ -843,7 +829,7 @@ struct usb_gadget_strings { };
/* put descriptor for string with that id into buf (buflen >= 256) */ -int usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf); +int usb_gadget_get_string(struct usb_gadget_strings *table, int id, u8 *buf);
@@ -861,10 +847,10 @@ int usb_gadget_config_buf(const struct usb_config_descriptor *config,
/* utility wrapping a simple endpoint selection policy */
-extern struct usb_ep *usb_ep_autoconfig (struct usb_gadget *, +extern struct usb_ep *usb_ep_autoconfig(struct usb_gadget *, struct usb_endpoint_descriptor *);
-extern void usb_ep_autoconfig_reset (struct usb_gadget *); +extern void usb_ep_autoconfig_reset(struct usb_gadget *);
extern int usb_gadget_handle_interrupts(void);
Hello Remy,
vkuzmichev@mvista.com wrote: [...]
- wMaxSegmentSize accordingly*/
Could you please fix the last line before commit? I missed this and would not like to spam more patches to the list.
____ With best regards, Vitaly.
2010/9/13 Vitaly Kuzmichev vkuzmichev@mvista.com:
Hello Remy,
- * use PKTSIZE (or aligned... from u-boot) and set
Fixed and applied to u-boot-usb (cdc)
Thanks.
Remy
Remy Bohmer
Vitaly Kuzmichev
