[U-Boot] [PATCH 1/1] efi_loader: correctly split device path of loaded image
When the LoadImage() service is called for an image that is already loaded to memory the file path may be NULL or it will contain both a device path as well as a media path. We should not assume that there is no media path.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- This patch resolves a problem occurring after
[PATCH v3 8/9] efi_loader: rework bootmgr/bootefi using load_image API https://lists.denx.de/pipermail/u-boot/2019-April/365439.html
leading to a failure to chain a script in iPXE. --- lib/efi_loader/efi_boottime.c | 12 ++---------- 1 file changed, 2 insertions(+), 10 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 19a58144cf4..601b0a2cb88 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1700,19 +1700,11 @@ efi_status_t EFIAPI efi_load_image(bool boot_policy, &source_size); if (ret != EFI_SUCCESS) goto error; - /* - * split file_path which contains both the device and - * file parts: - */ - efi_dp_split_file_path(file_path, &dp, &fp); } else { - /* In this case, file_path is the "device" path, i.e. - * something like a HARDWARE_DEVICE:MEMORY_MAPPED - */ dest_buffer = source_buffer; - dp = file_path; - fp = NULL; } + /* split file_path which contains both the device and file parts */ + efi_dp_split_file_path(file_path, &dp, &fp); ret = efi_setup_loaded_image(dp, fp, image_obj, &info); if (ret == EFI_SUCCESS) ret = efi_load_pe(*image_obj, dest_buffer, info); -- 2.21.0
