[U-Boot] [PATCH] lcd: Fix build error with CONFIG_LCD_BMP_RLE8
Add a block to avoid a build error with the variable declaration. Enable the option on sandbox to prevent an error being introduced in future.
common/lcd.c | 4 ++-- include/configs/sandbox.h | 1 + 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 217ec9d..689d30e 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -1023,7 +1023,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y)
switch (bmp_bpix) { case 1: /* pass through */ - case 8: + case 8: { #ifdef CONFIG_LCD_BMP_RLE8 u32 compression = get_unaligned_le32(&bmp->header.compression); if (compression == BMP_BI_RLE8) { @@ -1056,7 +1056,7 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) fb -= byte_width + lcd_line_length; } break; - + } #if defined(CONFIG_BMP_16BPP) case 16: for (i = 0; i < height; ++i) { diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 6972643..022629f 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -172,6 +172,7 @@ #define CONFIG_CONSOLE_MUX #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define LCD_BPP LCD_COLOR16 +#define CONFIG_LCD_BMP_RLE8
#define CONFIG_CROS_EC_KEYB #define CONFIG_KEYBOARD
Hi Simon,
Applied to u-boot-video/master.
Thanks,
Anatolij
Anatolij Gustschin
