[PATCH] dm: pinctrl: Use right device pointer for configuring pinctrl
commit 719cab6d2e2bf ("dm: pinctrl: convert pinctrl-single to livetree") converted pinctrl driver to livetree. In this conversion, the call to read pinctrl-single,pins/bits property is provided with pinctrl device pointer instead of pinctrl config pointer. Because of this none of the pins gets configured. Fix it by passing the right udevice pointer.
Fixes: 719cab6d2e2bf ("dm: pinctrl: convert pinctrl-single to livetree") Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/pinctrl/pinctrl-single.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-single.c b/drivers/pinctrl/pinctrl-single.c index a5d1ff0e97..738f5bd636 100644 --- a/drivers/pinctrl/pinctrl-single.c +++ b/drivers/pinctrl/pinctrl-single.c @@ -120,7 +120,7 @@ static int single_set_state(struct udevice *dev, const struct single_fdt_bits_cfg *prop_bits; int len;
- prop = dev_read_prop(dev, "pinctrl-single,pins", &len); + prop = dev_read_prop(config, "pinctrl-single,pins", &len);
if (prop) { dev_dbg(dev, "configuring pins for %s\n", config->name); @@ -133,7 +133,7 @@ static int single_set_state(struct udevice *dev, }
/* pinctrl-single,pins not found so check for pinctrl-single,bits */ - prop_bits = dev_read_prop(dev, "pinctrl-single,bits", &len); + prop_bits = dev_read_prop(config, "pinctrl-single,bits", &len); if (prop_bits) { dev_dbg(dev, "configuring pins for %s\n", config->name); if (len % sizeof(struct single_fdt_bits_cfg)) {
Thanks for the quick turn-around!
Tested-by: Tom Rini trini@konsulko.com [am65x_evm_a53 / am65x_evm_r5]
I'll pick this up soon to give others a chance to comment.
From: Lokesh Vutla lokeshvutla@ti.com Sent: mercredi 22 avril 2020 19:26
Sorry for regression...
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
And thanks for the fixe
Patrick
Lokesh Vutla
Patrick DELAUNAY
