[PATCH 0/2] clk: imx8mp: clock names and clock source fixes
This series addresses few fixes for clock sub-system for i.MX8MP SOC.
One is dealing with incorrect names used, while the second one addresses root clock selection which has been apparently omitted during merge and caused the warning to be reported during boot.
Andrey Zhizhikin (2): clk: imx8mp: fix root clock names for ecspi clk: imx8mp: use usb_core_ref for usb_root_clk
drivers/clk/imx/clk-imx8mp.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
base-commit: 3053b781465711fd05b88ab141b1f2b55a875516
Root clock name contained underscore, which does not match to the actual clock name.
Correct the name to match what is present in the FDT.
Fixes: 87f958810fcb ("clk: imx8mp: Add ECSPI clocks") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com --- drivers/clk/imx/clk-imx8mp.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index ac727b7e40..cbed86a684 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -122,15 +122,15 @@ static const char *imx8mp_gic_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_p "sys_pll2_100m", "sys_pll1_800m", "sys_pll2_500m", "clk_ext4", "audio_pll2_out" };
-static const char *imx8mp_ecspi1_sels[] = {"clock-osc_24m", "sys_pll2_200m", "sys_pll1_40m", +static const char *imx8mp_ecspi1_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll1_40m", "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", "sys_pll2_250m", "audio_pll2_out", };
-static const char *imx8mp_ecspi2_sels[] = {"clock-osc_24m", "sys_pll2_200m", "sys_pll1_40m", +static const char *imx8mp_ecspi2_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll1_40m", "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", "sys_pll2_250m", "audio_pll2_out", };
-static const char *imx8mp_ecspi3_sels[] = {"clock-osc_24m", "sys_pll2_200m", "sys_pll1_40m", +static const char *imx8mp_ecspi3_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll1_40m", "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", "sys_pll2_250m", "audio_pll2_out", };
Reviewed-by: Fabio Estevam festevam@denx.de
Root clock name contained underscore, which does not match to the actual clock name. Correct the name to match what is present in the FDT. Fixes: 87f958810fcb ("clk: imx8mp: Add ECSPI clocks") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Upstream commit 7a2c3be95a50 ("clk: imx8mp: Fill in DWC3 USB, USB PHY, HSIOMIX clock") added usb_core_ref for USB Controller but never set it to be used as a clock source, using rather "osc_32k" instead.
This produces following boot log message: "clk_register: failed to get osc_32k device (parent of usb_root_clk)"
Fix the USB controller clock source by using usb_core_ref instead of osc_32k.
Fixes: 7a2c3be95a50 ("clk: imx8mp: Fill in DWC3 USB, USB PHY, HSIOMIX clock") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- drivers/clk/imx/clk-imx8mp.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index cbed86a684..ffbc1d1ba9 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -300,7 +300,7 @@ static int imx8mp_clk_probe(struct udevice *dev) clk_dm(IMX8MP_CLK_UART2_ROOT, imx_clk_gate4("uart2_root_clk", "uart2", base + 0x44a0, 0)); clk_dm(IMX8MP_CLK_UART3_ROOT, imx_clk_gate4("uart3_root_clk", "uart3", base + 0x44b0, 0)); clk_dm(IMX8MP_CLK_UART4_ROOT, imx_clk_gate4("uart4_root_clk", "uart4", base + 0x44c0, 0)); - clk_dm(IMX8MP_CLK_USB_ROOT, imx_clk_gate4("usb_root_clk", "osc_32k", base + 0x44d0, 0)); + clk_dm(IMX8MP_CLK_USB_ROOT, imx_clk_gate4("usb_root_clk", "usb_core_ref", base + 0x44d0, 0)); clk_dm(IMX8MP_CLK_USB_PHY_ROOT, imx_clk_gate4("usb_phy_root_clk", "usb_phy_ref", base + 0x44f0, 0)); clk_dm(IMX8MP_CLK_USDHC1_ROOT, imx_clk_gate4("usdhc1_root_clk", "usdhc1", base + 0x4510, 0)); clk_dm(IMX8MP_CLK_USDHC2_ROOT, imx_clk_gate4("usdhc2_root_clk", "usdhc2", base + 0x4520, 0));
On Fri, Jun 3, 2022, 17:16 Andrey Zhizhikin < andrey.zhizhikin@leica-geosystems.com> wrote:
"usb_core_ref", base + 0x44d0, 0)); clk_dm(IMX8MP_CLK_USB_PHY_ROOT, imx_clk_gate4("usb_phy_root_clk", "usb_phy_ref", base + 0x44f0, 0)); clk_dm(IMX8MP_CLK_USDHC1_ROOT, imx_clk_gate4("usdhc1_root_clk", "usdhc1", base + 0x4510, 0)); clk_dm(IMX8MP_CLK_USDHC2_ROOT, imx_clk_gate4("usdhc2_root_clk", "usdhc2", base + 0x4520, 0)); -- 2.25.1
Reviewed-by: Tommaso Merciai tommaso.merciai@amarulasolutions.com
Upstream commit 7a2c3be95a50 ("clk: imx8mp: Fill in DWC3 USB, USB PHY, HSIOMIX clock") added usb_core_ref for USB Controller but never set it to be used as a clock source, using rather "osc_32k" instead. This produces following boot log message: "clk_register: failed to get osc_32k device (parent of usb_root_clk)" Fix the USB controller clock source by using usb_core_ref instead of osc_32k. Fixes: 7a2c3be95a50 ("clk: imx8mp: Fill in DWC3 USB, USB PHY, HSIOMIX clock") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Fabio Estevam festevam@denx.de
Andrey Zhizhikin
Fabio Estevam
sbabic@denx.de
Tommaso Merciai
