[PATCH 0/4] xen: improve console outputs
This patch series improves the behavior and functionality of console output on Xen:
Patch#1: allow for U-Boot banner Patch#2-4: enable DEBUG_UART (or early printf)
AKASHI Takahiro (4): serial: serial_xen: print U-Boot banner and others arch: arm/xen: add putc() for debugging xen: add definitions for console_io serial: serial_xen: add DEBUG_UART support
arch/arm/include/asm/xen/hypercall.h | 6 ++++++ drivers/serial/Kconfig | 14 +++++++++++--- drivers/serial/serial_xen.c | 22 ++++++++++++++++++++-- include/xen/interface/xen.h | 6 ++++++ 4 files changed, 43 insertions(+), 5 deletions(-)
At present, DM_FLAG_PRE_RELOC is set only if !OF_CONTROL. It doesn't make sense for this para-virtualized driver.
With this patch applied, you will be able to see early boot messages:
U-Boot 2020.10-00001-ge442e71a6c52-dirty (Oct 15 2020 - 11:02:25 +0900) xenguest
Xen virtual CPU Model: XENVM-4.15 DRAM: 128 MiB PVBLOCK: (XEN) gnttab_mark_dirty not implemented yet pvblock: 0 In: hypervisor Out: hypervisor Err: hypervisor xenguest#
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/serial/serial_xen.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/serial/serial_xen.c b/drivers/serial/serial_xen.c index ba6504b94796..ed191829f059 100644 --- a/drivers/serial/serial_xen.c +++ b/drivers/serial/serial_xen.c @@ -175,8 +175,6 @@ U_BOOT_DRIVER(serial_xen) = { .priv_auto_alloc_size = sizeof(struct xen_uart_priv), .probe = xen_serial_probe, .ops = &xen_serial_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) .flags = DM_FLAG_PRE_RELOC, -#endif };
Subject: [PATCH 1/4] serial: serial_xen: print U-Boot banner and others
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.28.0
I applied this patch and unfortunately on ARM there were no logs. I think this series should be improved a little.
Regards, Anastasiia
I will check. Please tell me - the board that you're using - the version of Xen (and .config)
Thanks, -Takahiro Akashi
Regards, Anastasiia
Hello,
Board is based on imx8qm Xen version 4.13.0 .config: # # Automatically generated file; DO NOT EDIT. # U-Boot 2020.10 Configuration #
# # Compiler: aarch64-linux-gnu-gcc (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 7.5.0 # CONFIG_CREATE_ARCH_SYMLINK=y # CONFIG_ARC is not set CONFIG_ARM=y # CONFIG_M68K is not set # CONFIG_MICROBLAZE is not set # CONFIG_MIPS is not set # CONFIG_NDS32 is not set # CONFIG_NIOS2 is not set # CONFIG_PPC is not set # CONFIG_RISCV is not set # CONFIG_SANDBOX is not set # CONFIG_SH is not set # CONFIG_X86 is not set # CONFIG_XTENSA is not set CONFIG_SYS_ARCH="arm" CONFIG_SYS_CPU="armv8" CONFIG_SYS_VENDOR="xen" CONFIG_SYS_BOARD="xenguest_arm64" CONFIG_SYS_CONFIG_NAME="xenguest_arm64" # CONFIG_SYS_ICACHE_OFF is not set # CONFIG_SYS_DCACHE_OFF is not set
# # ARM architecture # CONFIG_ARM64=y CONFIG_POSITION_INDEPENDENT=y CONFIG_INIT_SP_RELATIVE=y CONFIG_SYS_INIT_SP_BSS_OFFSET=524288 CONFIG_LINUX_KERNEL_IMAGE_HEADER=y # CONFIG_GIC_V3_ITS is not set CONFIG_STATIC_RELA=y CONFIG_DMA_ADDR_T_64BIT=y CONFIG_ARM_ASM_UNIFIED=y # CONFIG_SYS_ARM_CACHE_CP15 is not set # CONFIG_SYS_ARM_MMU is not set # CONFIG_SYS_ARM_MPU is not set CONFIG_SYS_ARM_ARCH=8 CONFIG_SYS_CACHE_SHIFT_6=y CONFIG_SYS_CACHELINE_SIZE=64 CONFIG_SYS_ARM_CACHE_WRITEBACK=y # CONFIG_SYS_ARM_CACHE_WRITETHROUGH is not set # CONFIG_SYS_ARM_CACHE_WRITEALLOC is not set # CONFIG_ARCH_CPU_INIT is not set CONFIG_SYS_ARCH_TIMER=y CONFIG_ARM_SMCCC=y # CONFIG_SEMIHOSTING is not set # CONFIG_SYS_L2CACHE_OFF is not set # CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set CONFIG_ARM64_SUPPORT_AARCH32=y # CONFIG_ARCH_AT91 is not set # CONFIG_TARGET_EDB93XX is not set # CONFIG_TARGET_ASPENITE is not set # CONFIG_TARGET_GPLUGD is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_TARGET_APF27 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_TARGET_SPEAR300 is not set # CONFIG_TARGET_SPEAR310 is not set # CONFIG_TARGET_SPEAR320 is not set # CONFIG_TARGET_SPEAR600 is not set # CONFIG_TARGET_STV0991 is not set # CONFIG_TARGET_X600 is not set # CONFIG_TARGET_FLEA3 is not set # CONFIG_TARGET_MX35PDK is not set # CONFIG_ARCH_BCM283X is not set # CONFIG_ARCH_BCM63158 is not set # CONFIG_ARCH_BCM68360 is not set # CONFIG_ARCH_BCM6858 is not set # CONFIG_TARGET_VEXPRESS_CA15_TC2 is not set # CONFIG_ARCH_BCMSTB is not set # CONFIG_TARGET_VEXPRESS_CA5X2 is not set # CONFIG_TARGET_VEXPRESS_CA9X4 is not set # CONFIG_TARGET_BCM23550_W1D is not set # CONFIG_TARGET_BCM28155_AP is not set # CONFIG_TARGET_BCMCYGNUS is not set # CONFIG_TARGET_BCMNSP is not set # CONFIG_TARGET_BCMNS2 is not set # CONFIG_TARGET_BCMNS3 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_S5PC1XX is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_IPQ40XX is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_K3 is not set # CONFIG_ARCH_OMAP2PLUS is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MEDIATEK is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_IMX8 is not set # CONFIG_ARCH_IMX8M is not set # CONFIG_ARCH_IMXRT is not set # CONFIG_ARCH_MX23 is not set # CONFIG_ARCH_MX25 is not set # CONFIG_ARCH_MX28 is not set # CONFIG_ARCH_MX31 is not set # CONFIG_ARCH_MX7ULP is not set # CONFIG_ARCH_MX7 is not set # CONFIG_ARCH_MX6 is not set CONFIG_SPL_LDSCRIPT="arch/arm/cpu/armv8/u-boot-spl.lds" # CONFIG_ARCH_MX5 is not set # CONFIG_ARCH_NEXELL is not set # CONFIG_ARCH_OWL is not set # CONFIG_ARCH_QEMU is not set # CONFIG_ARCH_RMOBILE is not set # CONFIG_TARGET_S32V234EVB is not set # CONFIG_ARCH_SNAPDRAGON is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VERSAL is not set # CONFIG_ARCH_VF610 is not set # CONFIG_ARCH_ZYNQ is not set # CONFIG_ARCH_ZYNQMP_R5 is not set # CONFIG_ARCH_ZYNQMP is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_TARGET_VEXPRESS64_AEMV8A is not set # CONFIG_TARGET_VEXPRESS64_BASE_FVP is not set # CONFIG_TARGET_VEXPRESS64_JUNO is not set # CONFIG_TARGET_TOTAL_COMPUTE is not set # CONFIG_TARGET_LS2080A_EMU is not set # CONFIG_TARGET_LS2080A_SIMU is not set # CONFIG_TARGET_LS1088AQDS is not set # CONFIG_TARGET_LS2080AQDS is not set # CONFIG_TARGET_LS2080ARDB is not set # CONFIG_TARGET_LS2081ARDB is not set # CONFIG_TARGET_LX2160ARDB is not set # CONFIG_TARGET_LX2160AQDS is not set # CONFIG_TARGET_HIKEY is not set # CONFIG_TARGET_HIKEY960 is not set # CONFIG_TARGET_POPLAR is not set # CONFIG_TARGET_LS1012AQDS is not set # CONFIG_TARGET_LS1012ARDB is not set # CONFIG_TARGET_LS1012A2G5RDB is not set # CONFIG_TARGET_LS1012AFRWY is not set # CONFIG_TARGET_LS1012AFRDM is not set # CONFIG_TARGET_LS1028AQDS is not set # CONFIG_TARGET_LS1028ARDB is not set # CONFIG_TARGET_LS1088ARDB is not set # CONFIG_TARGET_LS1021AQDS is not set # CONFIG_TARGET_LS1021ATWR is not set # CONFIG_TARGET_LS1021ATSN is not set # CONFIG_TARGET_LS1021AIOT is not set # CONFIG_TARGET_LS1043AQDS is not set # CONFIG_TARGET_LS1043ARDB is not set # CONFIG_TARGET_LS1046AQDS is not set # CONFIG_TARGET_LS1046ARDB is not set # CONFIG_TARGET_LS1046AFRWY is not set # CONFIG_TARGET_COLIBRI_PXA270 is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_STM32 is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_STM32MP is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_OCTEONTX is not set # CONFIG_ARCH_OCTEONTX2 is not set # CONFIG_TARGET_THUNDERX_88XX is not set # CONFIG_ARCH_ASPEED is not set # CONFIG_TARGET_DURIAN is not set # CONFIG_TARGET_PRESIDIO_ASIC is not set CONFIG_TARGET_XENGUEST_ARM64=y CONFIG_SYS_TEXT_BASE=0x40080000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=4 CONFIG_ENV_SIZE=0x1f000 # CONFIG_DM_GPIO is not set CONFIG_ERR_PTR_OFFSET=0x0 CONFIG_BOOTSTAGE_STASH_ADDR=0 # CONFIG_DEBUG_UART_BOARD_INIT is not set CONFIG_IDENT_STRING=" xenguest" # CONFIG_ARMV8_MULTIENTRY is not set # CONFIG_ARMV8_SET_SMPEN is not set
# # ARMv8 secure monitor firmware # # CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT is not set # CONFIG_SPL_ARMV8_SEC_FIRMWARE_SUPPORT is not set # CONFIG_SPL_RECOVER_DATA_SECTION is not set CONFIG_PSCI_RESET=y # CONFIG_ARMV8_PSCI is not set # CONFIG_ARMV8_EA_EL3_FIRST is not set # CONFIG_CMD_DEKBLOB is not set # CONFIG_CMD_HDMIDETECT is not set CONFIG_IMX_DCD_ADDR=0x00910000
# # ARM debug # CONFIG_BUILD_TARGET="" CONFIG_DEFAULT_DEVICE_TREE="" CONFIG_DEBUG_UART=y # CONFIG_AHCI is not set # CONFIG_OF_BOARD_FIXUP is not set
# # General setup # CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y # CONFIG_OPTIMIZE_INLINING is not set CONFIG_CC_HAS_ASM_INLINE=y CONFIG_XEN=y # CONFIG_DISTRO_DEFAULTS is not set # CONFIG_ENV_VARS_UBOOT_CONFIG is not set # CONFIG_SYS_BOOT_GET_CMDLINE is not set # CONFIG_SYS_BOOT_GET_KBD is not set CONFIG_SYS_MALLOC_F=y CONFIG_EXPERT=y CONFIG_SYS_MALLOC_CLEAR_ON_INIT=y # CONFIG_SYS_MALLOC_DEFAULT_TO_INIT is not set # CONFIG_TOOLS_DEBUG is not set CONFIG_PHYS_64BIT=y # CONFIG_SYS_CUSTOM_LDSCRIPT is not set CONFIG_PLATFORM_ELFENTRY="_start" CONFIG_STACK_SIZE=0x1000000 CONFIG_SYS_SRAM_BASE=0x0 CONFIG_SYS_SRAM_SIZE=0x0 # CONFIG_EXAMPLES is not set
# # API # # CONFIG_API is not set
# # Boot options #
# # Boot images # # CONFIG_ANDROID_BOOT_IMAGE is not set # CONFIG_FIT is not set CONFIG_LEGACY_IMAGE_FORMAT=y # CONFIG_SUPPORT_RAW_INITRD is not set # CONFIG_OF_BOARD_SETUP is not set # CONFIG_OF_SYSTEM_SETUP is not set # CONFIG_OF_STDOUT_VIA_ALIAS is not set CONFIG_SYS_EXTRA_OPTIONS="" CONFIG_HAVE_SYS_TEXT_BASE=y CONFIG_ARCH_FIXUP_FDT_MEMORY=y
# # Boot timing # # CONFIG_BOOTSTAGE is not set CONFIG_BOOTSTAGE_RECORD_COUNT=30 CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=5 CONFIG_TPL_BOOTSTAGE_RECORD_COUNT=5 CONFIG_BOOTSTAGE_STASH_SIZE=0x1000 # CONFIG_SHOW_BOOT_PROGRESS is not set
# # Boot media # # CONFIG_NAND_BOOT is not set # CONFIG_ONENAND_BOOT is not set # CONFIG_QSPI_BOOT is not set # CONFIG_SATA_BOOT is not set # CONFIG_SD_BOOT is not set # CONFIG_SPI_BOOT is not set
# # Autoboot options # CONFIG_AUTOBOOT=y CONFIG_BOOTDELAY=10 # CONFIG_AUTOBOOT_KEYED is not set # CONFIG_AUTOBOOT_USE_MENUKEY is not set # CONFIG_USE_BOOTARGS is not set # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_USE_PREBOOT is not set CONFIG_DEFAULT_FDT_FILE=""
# # Console # # CONFIG_CONSOLE_RECORD is not set # CONFIG_DISABLE_CONSOLE is not set CONFIG_LOGLEVEL=4 CONFIG_SPL_LOGLEVEL=4 CONFIG_TPL_LOGLEVEL=4 # CONFIG_SILENT_CONSOLE is not set # CONFIG_PRE_CONSOLE_BUFFER is not set # CONFIG_CONSOLE_MUX is not set # CONFIG_SYS_CONSOLE_IS_IN_ENV is not set # CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE is not set # CONFIG_SYS_CONSOLE_ENV_OVERWRITE is not set # CONFIG_SYS_CONSOLE_INFO_QUIET is not set # CONFIG_SYS_STDIO_DEREGISTER is not set # CONFIG_SPL_SYS_STDIO_DEREGISTER is not set # CONFIG_SYS_DEVICE_NULLDEV is not set
# # Logging # # CONFIG_LOG is not set
# # Init options # # CONFIG_BOARD_TYPES is not set CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y # CONFIG_DISPLAY_BOARDINFO_LATE is not set
# # Start-up hooks # # CONFIG_ARCH_EARLY_INIT_R is not set # CONFIG_ARCH_MISC_INIT is not set # CONFIG_BOARD_EARLY_INIT_F is not set # CONFIG_BOARD_EARLY_INIT_R is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_LAST_STAGE_INIT is not set # CONFIG_MISC_INIT_R is not set
# # Security support #
# # Update support # # CONFIG_ANDROID_AB is not set
# # Blob list # # CONFIG_BLOBLIST is not set
# # SPL / TPL # CONFIG_SPL_SYS_STACK_F_CHECK_BYTE=0xaa # CONFIG_SPL_SYS_REPORT_STACK_F_USAGE is not set
# # PowerPC and LayerScape SPL Boot options #
# # Command line interface # CONFIG_CMDLINE=y # CONFIG_HUSH_PARSER is not set CONFIG_CMDLINE_EDITING=y CONFIG_AUTO_COMPLETE=y CONFIG_SYS_LONGHELP=y CONFIG_SYS_PROMPT="xenguest# " CONFIG_SYS_XTRACE="y"
# # Commands #
# # Info commands # # CONFIG_CMD_ACPI is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONFIG is not set CONFIG_CMD_CONSOLE=y # CONFIG_CMD_CPU is not set # CONFIG_CMD_LICENSE is not set # CONFIG_CMD_PMC is not set
# # Boot commands # # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTM=y # CONFIG_CMD_BOOTZ is not set CONFIG_CMD_BOOTI=y CONFIG_BOOTM_LINUX=y CONFIG_BOOTM_NETBSD=y # CONFIG_BOOTM_OPENRTOS is not set # CONFIG_BOOTM_OSE is not set CONFIG_BOOTM_PLAN9=y CONFIG_BOOTM_RTEMS=y CONFIG_BOOTM_VXWORKS=y # CONFIG_CMD_BOOTMENU is not set # CONFIG_CMD_ADTIMG is not set # CONFIG_CMD_ELF is not set CONFIG_CMD_FDT=y # CONFIG_CMD_GO is not set CONFIG_CMD_RUN=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_THOR_DOWNLOAD is not set # CONFIG_CMD_ZBOOT is not set
# # Environment commands # # CONFIG_CMD_ASKENV is not set # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_GREPENV is not set # CONFIG_CMD_SAVEENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_ENV_CALLBACK is not set # CONFIG_CMD_ENV_FLAGS is not set # CONFIG_CMD_NVEDIT_INFO is not set # CONFIG_CMD_NVEDIT_LOAD is not set # CONFIG_CMD_NVEDIT_SELECT is not set
# # Memory commands # # CONFIG_CMD_BINOP is not set # CONFIG_CMD_BLOBLIST is not set # CONFIG_CMD_CRC32 is not set # CONFIG_CMD_EEPROM is not set # CONFIG_LOOPW is not set # CONFIG_CMD_MD5SUM is not set # CONFIG_CMD_MEMINFO is not set CONFIG_CMD_MEMORY=y # CONFIG_CMD_MEM_SEARCH is not set # CONFIG_CMD_MX_CYCLIC is not set # CONFIG_CMD_MEMTEST is not set # CONFIG_CMD_SHA1SUM is not set # CONFIG_CMD_STRINGS is not set
# # Compression commands # # CONFIG_CMD_LZMADEC is not set CONFIG_CMD_UNLZ4=y # CONFIG_CMD_UNZIP is not set # CONFIG_CMD_ZIP is not set
# # Device access commands # # CONFIG_CMD_ARMFLASH is not set # CONFIG_CMD_BIND is not set # CONFIG_CMD_CLK is not set # CONFIG_CMD_DEMO is not set # CONFIG_CMD_DFU is not set # CONFIG_CMD_DM is not set # CONFIG_CMD_FPGAD is not set # CONFIG_CMD_FUSE is not set # CONFIG_CMD_GPIO is not set # CONFIG_CMD_GPT is not set # CONFIG_RANDOM_UUID is not set # CONFIG_CMD_IDE is not set # CONFIG_CMD_IO is not set # CONFIG_CMD_IOTRACE is not set # CONFIG_CMD_I2C is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_LSBLK is not set # CONFIG_CMD_MMC is not set # CONFIG_CMD_CLONE is not set # CONFIG_CMD_OSD is not set # CONFIG_CMD_PART is not set # CONFIG_CMD_PCI is not set # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_POWEROFF is not set # CONFIG_CMD_READ is not set # CONFIG_CMD_SATA is not set # CONFIG_CMD_SAVES is not set # CONFIG_CMD_SCSI is not set # CONFIG_CMD_SDRAM is not set # CONFIG_CMD_TSI148 is not set # CONFIG_CMD_UNIVERSE is not set # CONFIG_CMD_USB is not set # CONFIG_CMD_USB_SDP is not set # CONFIG_CMD_USB_MASS_STORAGE is not set CONFIG_CMD_PVBLOCK=y
# # Shell scripting commands # # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set
# # Android support commands # # CONFIG_CMD_NET is not set # CONFIG_CMD_ETHSW is not set # CONFIG_CMD_PXE is not set # CONFIG_CMD_WOL is not set
# # Misc commands # # CONFIG_CMD_BSP is not set CONFIG_CMD_BLOCK_CACHE=y # CONFIG_CMD_CACHE is not set # CONFIG_CMD_CONITRACE is not set # CONFIG_CMD_EXCEPTION is not set # CONFIG_CMD_DATE is not set # CONFIG_CMD_TIME is not set # CONFIG_CMD_GETTIME is not set # CONFIG_CMD_MISC is not set # CONFIG_MP is not set # CONFIG_CMD_TIMER is not set # CONFIG_CMD_SYSBOOT is not set # CONFIG_CMD_QFW is not set # CONFIG_CMD_PSTORE is not set # CONFIG_CMD_TERMINAL is not set # CONFIG_CMD_UUID is not set
# # TI specific command line interface # # CONFIG_CMD_DDR3 is not set
# # Power commands #
# # Security commands # # CONFIG_CMD_AES is not set # CONFIG_CMD_BLOB is not set # CONFIG_CMD_HASH is not set # CONFIG_CMD_HVC is not set # CONFIG_CMD_SMC is not set
# # Firmware commands #
# # Filesystem commands # # CONFIG_CMD_BTRFS is not set # CONFIG_CMD_EXT2 is not set CONFIG_CMD_EXT4=y # CONFIG_CMD_EXT4_WRITE is not set CONFIG_CMD_FAT=y # CONFIG_CMD_SQUASHFS is not set # CONFIG_CMD_FS_GENERIC is not set # CONFIG_CMD_FS_UUID is not set # CONFIG_CMD_JFFS2 is not set # CONFIG_CMD_REISER is not set # CONFIG_CMD_ZFS is not set
# # Debug commands # # CONFIG_CMD_BEDBUG is not set # CONFIG_CMD_DIAG is not set # CONFIG_CMD_LOG is not set # CONFIG_CMD_TRACE is not set # CONFIG_CMD_UBI is not set
# # Partition Types # CONFIG_PARTITIONS=y # CONFIG_MAC_PARTITION is not set CONFIG_DOS_PARTITION=y # CONFIG_ISO_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_EFI_PARTITION is not set # CONFIG_PARTITION_UUIDS is not set CONFIG_SUPPORT_OF_CONTROL=y CONFIG_DTC=y
# # Device Tree Control # CONFIG_OF_CONTROL=y # CONFIG_OF_LIVE is not set # CONFIG_OF_SEPARATE is not set # CONFIG_OF_EMBED is not set CONFIG_OF_BOARD=y # CONFIG_OF_PRIOR_STAGE is not set # CONFIG_MULTI_DTB_FIT is not set # CONFIG_OF_DTB_PROPS_REMOVE is not set
# # Environment # CONFIG_ENV_SUPPORT=y # CONFIG_ENV_OVERWRITE is not set CONFIG_ENV_IS_NOWHERE=y # CONFIG_ENV_IS_IN_EEPROM is not set # CONFIG_ENV_IS_IN_FAT is not set # CONFIG_ENV_IS_IN_EXT4 is not set # CONFIG_ENV_IS_IN_FLASH is not set # CONFIG_ENV_IS_IN_NAND is not set # CONFIG_ENV_IS_IN_NVRAM is not set # CONFIG_ENV_IS_IN_ONENAND is not set # CONFIG_ENV_IS_IN_REMOTE is not set # CONFIG_SYS_RELOC_GD_ENV_ADDR is not set # CONFIG_USE_DEFAULT_ENV_FILE is not set # CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG is not set # CONFIG_ENV_APPEND is not set # CONFIG_ENV_WRITEABLE_LIST is not set # CONFIG_ENV_ACCESS_IGNORE_FORCE is not set # CONFIG_VERSION_VARIABLE is not set CONFIG_NET=y # CONFIG_PROT_UDP is not set # CONFIG_BOOTP_SEND_HOSTNAME is not set # CONFIG_NET_RANDOM_ETHADDR is not set # CONFIG_NETCONSOLE is not set # CONFIG_IP_DEFRAG is not set CONFIG_TFTP_BLOCKSIZE=1468 CONFIG_TFTP_WINDOWSIZE=1
# # Device Drivers #
# # Generic Driver Options # CONFIG_DM=y CONFIG_DM_WARN=y # CONFIG_DM_DEBUG is not set CONFIG_DM_DEVICE_REMOVE=y CONFIG_DM_STDIO=y CONFIG_DM_SEQ_ALIAS=y # CONFIG_REGMAP is not set # CONFIG_DEVRES is not set CONFIG_SIMPLE_BUS=y CONFIG_OF_TRANSLATE=y # CONFIG_TRANSLATION_OFFSET is not set CONFIG_DM_DEV_READ_INLINE=y # CONFIG_ACPIGEN is not set # CONFIG_BOUNCE_BUFFER is not set # CONFIG_ADC is not set # CONFIG_ADC_EXYNOS is not set # CONFIG_ADC_SANDBOX is not set # CONFIG_SARADC_MESON is not set # CONFIG_SARADC_ROCKCHIP is not set # CONFIG_SATA is not set # CONFIG_SCSI_AHCI is not set
# # SATA/SCSI device support # # CONFIG_DWC_AHSATA is not set # CONFIG_FSL_SATA is not set # CONFIG_MVSATA_IDE is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIL3114 is not set # CONFIG_AXI is not set
# # Bus devices # CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BLOCK_CACHE=y # CONFIG_IDE is not set # CONFIG_BOOTCOUNT_LIMIT is not set
# # Button Support # # CONFIG_BUTTON is not set
# # Cache Controller drivers # # CONFIG_CACHE is not set # CONFIG_L2X0_CACHE is not set # CONFIG_NCORE_CACHE is not set
# # Clock # # CONFIG_CLK is not set # CONFIG_CLK_CCF is not set # CONFIG_CPU is not set
# # Hardware crypto devices # # CONFIG_FSL_CAAM is not set # CONFIG_SYS_FSL_SEC_BE is not set # CONFIG_SYS_FSL_SEC_LE is not set
# # Demo for driver model # # CONFIG_DM_DEMO is not set # CONFIG_BOARD is not set
# # DFU support #
# # DMA Support # # CONFIG_DMA is not set # CONFIG_TI_EDMA3 is not set
# # Fastboot support # # CONFIG_UDP_FUNCTION_FASTBOOT is not set CONFIG_FIRMWARE=y # CONFIG_SPL_FIRMWARE is not set CONFIG_ARM_PSCI_FW=y # CONFIG_ZYNQMP_FIRMWARE is not set # CONFIG_SCMI_FIRMWARE is not set
# # FPGA support # # CONFIG_FPGA_ALTERA is not set # CONFIG_FPGA_SOCFPGA is not set # CONFIG_FPGA_XILINX is not set
# # GPIO Support # # CONFIG_AT91_GPIO is not set # CONFIG_DA8XX_GPIO is not set # CONFIG_INTEL_BROADWELL_GPIO is not set # CONFIG_IMX_RGPIO2P is not set # CONFIG_IPROC_GPIO is not set # CONFIG_LPC32XX_GPIO is not set # CONFIG_MXC_GPIO is not set # CONFIG_MXS_GPIO is not set # CONFIG_CMD_PCA953X is not set # CONFIG_CMD_TCA642X is not set # CONFIG_VYBRID_GPIO is not set
# # Hardware Spinlock Support # # CONFIG_DM_HWSPINLOCK is not set
# # I2C support # # CONFIG_DM_I2C is not set # CONFIG_SYS_I2C_DW is not set # CONFIG_SYS_I2C_IMX_LPI2C is not set # CONFIG_SYS_I2C_MXC is not set CONFIG_INPUT=y # CONFIG_DM_KEYBOARD is not set # CONFIG_CROS_EC_KEYB is not set # CONFIG_TEGRA_KEYBOARD is not set # CONFIG_TWL4030_INPUT is not set
# # LED Support # # CONFIG_LED is not set # CONFIG_LED_STATUS is not set
# # Mailbox Controller Support # # CONFIG_DM_MAILBOX is not set
# # Memory Controller drivers #
# # Multifunction device drivers # # CONFIG_MISC is not set # CONFIG_CROS_EC is not set # CONFIG_DS4510 is not set # CONFIG_FSL_SEC_MON is not set # CONFIG_NUVOTON_NCT6102D is not set # CONFIG_PWRSEQ is not set # CONFIG_PCA9551_LED is not set # CONFIG_TWL4030_LED is not set # CONFIG_WINBOND_W83627 is not set # CONFIG_FS_LOADER is not set
# # MMC Host controller Support # # CONFIG_MMC is not set # CONFIG_MMC_BROKEN_CD is not set # CONFIG_DM_MMC is not set # CONFIG_FSL_ESDHC is not set # CONFIG_FSL_ESDHC_IMX is not set
# # MTD Support # # CONFIG_MTD is not set # CONFIG_DM_MTD is not set # CONFIG_MTD_NOR_FLASH is not set # CONFIG_FLASH_CFI_DRIVER is not set # CONFIG_MTD_RAW_NAND is not set
# # SPI Flash Support # # CONFIG_SPI_FLASH is not set
# # UBI support # # CONFIG_UBI_SILENCE_MSG is not set # CONFIG_MTD_UBI is not set # CONFIG_BITBANGMII is not set # CONFIG_MV88E6352_SWITCH is not set # CONFIG_PHYLIB is not set # CONFIG_FSL_PFE is not set # CONFIG_DM_ETH is not set # CONFIG_DM_ETH_PHY is not set # CONFIG_NETDEVICES is not set # CONFIG_PCI is not set
# # PCI Endpoint # # CONFIG_PCI_ENDPOINT is not set # CONFIG_X86_PCH7 is not set # CONFIG_X86_PCH9 is not set
# # PHY Subsystem # # CONFIG_PHY is not set
# # Rockchip PHY driver # # CONFIG_MVEBU_COMPHY_SUPPORT is not set
# # Pin controllers # # CONFIG_PINCTRL is not set
# # Power # # CONFIG_ACPI_PMC is not set # CONFIG_SPL_ACPI_PMC is not set # CONFIG_TPL_ACPI_PMC is not set
# # Power Domain Support # # CONFIG_POWER_DOMAIN is not set # CONFIG_DM_PMIC is not set # CONFIG_PMIC_AS3722 is not set # CONFIG_POWER_MC34VR500 is not set # CONFIG_DM_REGULATOR is not set # CONFIG_POWER_MT6323 is not set # CONFIG_DM_PWM is not set # CONFIG_PWM_IMX is not set # CONFIG_PWM_SANDBOX is not set # CONFIG_U_QE is not set # CONFIG_RAM is not set
# # Remote Processor drivers #
# # Reset Controller Support # # CONFIG_DM_RESET is not set # CONFIG_RESET_SCMI is not set # CONFIG_DM_RNG is not set
# # Real Time Clock # # CONFIG_DM_RTC is not set # CONFIG_RTC_ENABLE_32KHZ_OUTPUT is not set # CONFIG_RTC_RX8025 is not set # CONFIG_RTC_PL031 is not set # CONFIG_RTC_S35392A is not set # CONFIG_RTC_MC146818 is not set # CONFIG_RTC_M41T62 is not set # CONFIG_SCSI is not set # CONFIG_DM_SCSI is not set
# # Serial drivers # CONFIG_BAUDRATE=115200 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set # CONFIG_SPECIFY_CONSOLE_INDEX is not set CONFIG_SERIAL_PRESENT=y CONFIG_DM_SERIAL=y # CONFIG_SERIAL_RX_BUFFER is not set # CONFIG_SERIAL_SEARCH_ALL is not set CONFIG_DEBUG_UART_XEN=y # CONFIG_DEBUG_UART_ANNOUNCE is not set # CONFIG_DEBUG_UART_SKIP_INIT is not set # CONFIG_ALTERA_JTAG_UART is not set # CONFIG_ALTERA_UART is not set # CONFIG_ARC_SERIAL is not set # CONFIG_ARM_DCC is not set # CONFIG_ATMEL_USART is not set # CONFIG_BCM6345_SERIAL is not set # CONFIG_COREBOOT_SERIAL is not set # CONFIG_CORTINA_UART is not set # CONFIG_FSL_LINFLEXUART is not set # CONFIG_FSL_LPUART is not set # CONFIG_MVEBU_A3700_UART is not set # CONFIG_MCFUART is not set # CONFIG_NULLDEV_SERIAL is not set # CONFIG_SYS_NS16550 is not set # CONFIG_NS16550_DYNAMIC is not set # CONFIG_PL01X_SERIAL is not set # CONFIG_XILINX_UARTLITE is not set # CONFIG_MSM_SERIAL is not set # CONFIG_OMAP_SERIAL is not set # CONFIG_PXA_SERIAL is not set # CONFIG_SIFIVE_SERIAL is not set # CONFIG_ZYNQ_SERIAL is not set # CONFIG_MTK_SERIAL is not set CONFIG_XEN_SERIAL=y # CONFIG_SMEM is not set
# # Sound support # # CONFIG_SOUND is not set
# # SOC (System On Chip) specific Drivers # # CONFIG_SOC_DEVICE is not set # CONFIG_SOC_TI is not set # CONFIG_SPI is not set
# # SPMI support # # CONFIG_SPMI is not set
# # System reset device drivers # # CONFIG_SYSRESET is not set # CONFIG_SYSRESET_SYSCON is not set # CONFIG_SYSRESET_WATCHDOG is not set # CONFIG_SYSRESET_RESETCTL is not set # CONFIG_SYSRESET_MPC83XX is not set # CONFIG_TEE is not set # CONFIG_OPTEE is not set # CONFIG_DM_THERMAL is not set
# # Timer Support # # CONFIG_TIMER is not set
# # TPM support # # CONFIG_USB is not set
# # UFS Host Controller Support # # CONFIG_TI_J721E_UFS is not set
# # Graphics support # # CONFIG_DM_VIDEO is not set # CONFIG_SYS_WHITE_ON_BLACK is not set # CONFIG_NO_FB_CLEAR is not set
# # TrueType Fonts # # CONFIG_VIDEO_VESA is not set # CONFIG_VIDEO_LCD_ANX9804 is not set # CONFIG_VIDEO_LCD_SSD2828 is not set # CONFIG_VIDEO_MVEBU is not set # CONFIG_I2C_EDID is not set # CONFIG_DISPLAY is not set # CONFIG_ATMEL_HLCD is not set # CONFIG_AM335X_LCD is not set # CONFIG_VIDEO_TEGRA20 is not set # CONFIG_VIDEO_BRIDGE is not set # CONFIG_VIDEO is not set # CONFIG_LCD is not set # CONFIG_VIDEO_SIMPLE is not set # CONFIG_VIDEO_DT_SIMPLEFB is not set # CONFIG_OSD is not set # CONFIG_SPLASH_SCREEN is not set
# # VirtIO Drivers # # CONFIG_VIRTIO_MMIO is not set
# # 1-Wire support # # CONFIG_W1 is not set
# # 1-wire EEPROM support # # CONFIG_W1_EEPROM is not set
# # Watchdog Timer Support # # CONFIG_WATCHDOG is not set CONFIG_WATCHDOG_TIMEOUT_MSECS=60000 # CONFIG_WATCHDOG_RESET_DISABLE is not set # CONFIG_IMX_WATCHDOG is not set # CONFIG_ULP_WATCHDOG is not set # CONFIG_DESIGNWARE_WATCHDOG is not set # CONFIG_WDT is not set CONFIG_PVBLOCK=y # CONFIG_PHYS_TO_BUS is not set
# # File systems # # CONFIG_FS_BTRFS is not set # CONFIG_FS_CBFS is not set # CONFIG_SPL_FS_CBFS is not set CONFIG_FS_EXT4=y # CONFIG_EXT4_WRITE is not set CONFIG_FS_FAT=y # CONFIG_FAT_WRITE is not set CONFIG_FS_FAT_MAX_CLUSTSIZE=65536 # CONFIG_FS_JFFS2 is not set # CONFIG_UBIFS_SILENCE_MSG is not set # CONFIG_FS_CRAMFS is not set # CONFIG_YAFFS2 is not set # CONFIG_FS_SQUASHFS is not set
# # Library routines # # CONFIG_ADDR_MAP is not set # CONFIG_BCH is not set # CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED is not set # CONFIG_DYNAMIC_CRC_TABLE is not set CONFIG_PRINTF=y CONFIG_SPRINTF=y CONFIG_SSCANF=y CONFIG_STRTO=y CONFIG_SYS_HZ=1000 # CONFIG_PANIC_HANG is not set CONFIG_REGEX=y # CONFIG_SPL_TINY_MEMSET is not set # CONFIG_TPL_TINY_MEMSET is not set # CONFIG_BITREVERSE is not set # CONFIG_TRACE is not set # CONFIG_CMD_DHRYSTONE is not set
# # Security support # # CONFIG_AES is not set # CONFIG_RSA is not set # CONFIG_ASYMMETRIC_KEY_TYPE is not set # CONFIG_TPM is not set
# # Android Verified Boot #
# # Hashing Support # # CONFIG_SHA1 is not set # CONFIG_SHA256 is not set # CONFIG_SHA512_ALGO is not set # CONFIG_SHA_HW_ACCEL is not set # CONFIG_MD5 is not set # CONFIG_SPL_MD5 is not set
# # Compression Support # CONFIG_LZ4=y # CONFIG_LZMA is not set # CONFIG_LZO is not set CONFIG_GZIP=y # CONFIG_ZLIB_UNCOMPRESS is not set # CONFIG_BZIP2 is not set CONFIG_ZLIB=y # CONFIG_ZSTD is not set # CONFIG_SPL_LZ4 is not set # CONFIG_SPL_LZMA is not set # CONFIG_SPL_LZO is not set # CONFIG_SPL_GZIP is not set # CONFIG_SPL_ZSTD is not set # CONFIG_ERRNO_STR is not set # CONFIG_HEXDUMP is not set CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_ASSUME_MASK=0 # CONFIG_OF_LIBFDT_OVERLAY is not set # CONFIG_SPL_OF_LIBFDT is not set # CONFIG_TPL_OF_LIBFDT is not set
# # System tables # # CONFIG_EFI_LOADER is not set # CONFIG_TEST_FDTDEC is not set # CONFIG_UNIT_TEST is not set
# # Tools options # CONFIG_MKIMAGE_DTC_PATH="dtc"
Regards, Anastasiia
Regards, Anastasiia
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Peng Fan peng.fan@nxp.com
This new function, xen_debug_putc(), is intended to be used to enable CONFIG_DEBUG_UART on xen guest.
Please note that the underlying functionality in Xen is available only when Xen is configured with !NDEBUG but is much simpler than a generic HYPERVISOR_console_io().
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- arch/arm/include/asm/xen/hypercall.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/xen/hypercall.h b/arch/arm/include/asm/xen/hypercall.h index a4fd077079a9..121ccfcc608f 100644 --- a/arch/arm/include/asm/xen/hypercall.h +++ b/arch/arm/include/asm/xen/hypercall.h @@ -19,4 +19,10 @@ int HYPERVISOR_sched_op(int cmd, void *arg); int HYPERVISOR_event_channel_op(int cmd, void *arg); unsigned long HYPERVISOR_hvm_op(int op, void *arg); int HYPERVISOR_memory_op(unsigned int cmd, void *arg); + +static inline void xen_debug_putc(int c) +{ + register int v __asm__ ("x0") = c; + __asm__ __volatile__("hvc 0xfffe" : "=r" (v) : "0" (v)); +} #endif /* _ASM_ARM_XEN_HYPERCALL_H */
Subject: [PATCH 2/4] arch: arm/xen: add putc() for debugging
+static inline void xen_debug_putc(int c) {
- register int v __asm__ ("x0") = c;
- __asm__ __volatile__("hvc 0xfffe" : "=r" (v) : "0" (v)); }
-- 2.28.0
Those definitions added are used with HYPERVISOR_console_io().
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/xen/interface/xen.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/xen/interface/xen.h b/include/xen/interface/xen.h index eec8ab75b9ce..a7c8ed781b34 100644 --- a/include/xen/interface/xen.h +++ b/include/xen/interface/xen.h @@ -76,6 +76,12 @@ #define __HYPERVISOR_arch_6 54 #define __HYPERVISOR_arch_7 55
+/* + * Commands to HYPERVISOR_console_io(). + */ +#define CONSOLEIO_write 0 +#define CONSOLEIO_read 1 + #ifndef __ASSEMBLY__
typedef u16 domid_t;
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of AKASHI Takahiro Sent: 2020年10月15日 12:25 To: anastasiia_lukianenko@epam.com; oleksandr_andrushchenko@epam.com Cc: u-boot@lists.denx.de; AKASHI Takahiro takahiro.akashi@linaro.org Subject: [PATCH 3/4] xen: add definitions for console_io
- Commands to HYPERVISOR_console_io().
-- 2.28.0
By using a hypervisor call, we can implement DEBUG_UART on xen. This will allow us to see messages even earlier than serial_init().
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- drivers/serial/Kconfig | 14 +++++++++++--- drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ 2 files changed, 31 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index e344677f91f6..536cf0641773 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -401,11 +401,19 @@ config DEBUG_UART_MTK driver will be available until the real driver model serial is running.
+config DEBUG_UART_XEN + bool "XEN Hypervisor Console" + depends on XEN_SERIAL + help + Select this to enable a debug UART using the serial_xen driver. You + will not have to provide any parameters to make this work. The driver + will be available until the real driver-model serial is running. + endchoice
config DEBUG_UART_BASE hex "Base address of UART" - depends on DEBUG_UART + depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART_SANDBOX help This is the base address of your UART for memory-mapped UARTs. @@ -415,7 +423,7 @@ config DEBUG_UART_BASE
config DEBUG_UART_CLOCK int "UART input clock" - depends on DEBUG_UART + depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART_SANDBOX help The UART input clock determines the speed of the internal UART @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK
config DEBUG_UART_SHIFT int "UART register shift" - depends on DEBUG_UART + depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART help Some UARTs (notably ns16550) support different register layouts diff --git a/drivers/serial/serial_xen.c b/drivers/serial/serial_xen.c index ed191829f059..34c90ece40fc 100644 --- a/drivers/serial/serial_xen.c +++ b/drivers/serial/serial_xen.c @@ -5,6 +5,7 @@ */ #include <common.h> #include <cpu_func.h> +#include <debug_uart.h> #include <dm.h> #include <serial.h> #include <watchdog.h> @@ -15,11 +16,14 @@ #include <xen/events.h>
#include <xen/interface/sched.h> +#include <xen/interface/xen.h> #include <xen/interface/hvm/hvm_op.h> #include <xen/interface/hvm/params.h> #include <xen/interface/io/console.h> #include <xen/interface/io/ring.h>
+#include <asm/xen/hypercall.h> + DECLARE_GLOBAL_DATA_PTR;
u32 console_evtchn; @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { .flags = DM_FLAG_PRE_RELOC, };
+#if defined(CONFIG_DEBUG_UART_XEN) +static inline void _debug_uart_init(void) {} + +static inline void _debug_uart_putc(int c) +{ +#if CONFIG_IS_ENABLED(ARM) + xen_debug_putc(c); +#else + /* the type cast should work on LE only */ + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); +#endif +} + +DEBUG_UART_FUNCS + +#endif
Subject: [PATCH 4/4] serial: serial_xen: add DEBUG_UART support
- bool "XEN Hypervisor Console"
- depends on XEN_SERIAL
- help
Please add one more line that it needs XEN debug enabled. without xen debug, you will not able to see any outputs.
Regards, Peng.
endchoice
- depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART_SANDBOX help This is the base address of your UART for memory-mapped UARTs.
- depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART_SANDBOX help The UART input clock determines the speed of the internal UART @@
- depends on DEBUG_UART && !DEBUG_UART_XEN default 0 if DEBUG_UART help Some UARTs (notably ns16550) support different register layouts diff
+static inline void _debug_uart_putc(int c) { #if CONFIG_IS_ENABLED(ARM)
- xen_debug_putc(c);
+#else
- /* the type cast should work on LE only */
- HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); #endif }
+DEBUG_UART_FUNCS
2.28.0
- help
driver. You
The driver
running.
endchoice
+#else
An error occurs during compilation: drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in this function); did you mean ‘c’? HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch);
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
- help
driver. You
The driver
running.
endchoice
+#else
Ah, yes. You're now using x86, right?
So what happens if you have made the fix above? Does it work in your environment? (I have confirmed that HYPERVISOR_console_io version works on arm(64).)
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
Hello,
- help
driver. You
The driver
is running.
endchoice
+#else
No, I just tried different options and accidentally discovered this error.
Unfortunately, nothing happened (there are no logs mentioned earlier).
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
On Fri, Oct 23, 2020 at 08:50:56AM +0000, Anastasiia Lukianenko wrote:
Hello,
- help
driver. You
The driver
is running.
endchoice
+#else
No? My code is protected with "if CONFIG_IS_ENABLED(ARM)", and so you have no chance of building "else" clause unless you use x86.
Anyway,
1. Have you ever executed HYPERVISOR_console_io on your platform before? 2. If possible, please try to my code on qemu, as my patch intended, so that we can determine if your issue is generic or specific on your environment?
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
Hello,
- help
driver. You
The driver
is running.
endchoice
u32 console_evtchn;
+#else
The question here is that if x86 is selected it won't compile. Another
question if we tested that with x86: no, we didn't. The reason we tried x86
part was that HYPERVISOR_console_io is a generic definition for all the platforms,
so it was natural to try that as a way to debug things.
Anyway,
- Have you ever executed HYPERVISOR_console_io on your platform before?
Yes, we did that. You may have noticed that in [1] which I referred earlier
and the problems we faced with that.
- If possible, please try to my code on qemu, as my patch intended, so that we can determine if your issue is generic or specific on your environment?
The code runs on two different platforms with the same result (non-QEMU though).
Thank you,
Oleksandr
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
[1] https://lists.xenproject.org/archives/html/xen-devel/2020-06/msg00737.html
Hello,
- help
driver. You
The driver
is running.
endchoice
u32 console_evtchn;
+#else
Anastasiia said, "No, I just tried different options." Instead of different options, you tried modified code.
Anyway,
Yes, we did that. You may have noticed that in [1] which I referred earlier and the problems we faced with that.
Okay. Since I started to play with Xen just a few weeks ago, I actually don't know the past discussions at all.
So the issue you have mentioned has been fixed, hasn't it? Even if so, you must have submitted your patch in June or later this year.
Anastasiia said that she had used xen 4.13(+?) to test my code. So obviously, there will be no chance that you patch be merged in her test environment.
Please check on qemu with the latest Xen so that, as I said, we can determine if the issue is platform or environment (including a difference of version used) specific or not. I believe that it is quite easy for you to run U-Boot on qemu.
-Takahiro Akashi
Thank you,
Oleksandr
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
Hello,
On Thu, 2020-10-15 at 13:25 +0900, AKASHI Takahiro wrote: > By using a hypervisor call, we can implement DEBUG_UART on xen. > This will allow us to see messages even earlier than > serial_init(). > > Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org > --- > drivers/serial/Kconfig | 14 +++++++++++--- > drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ > 2 files changed, 31 insertions(+), 3 deletions(-) > > diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig > index e344677f91f6..536cf0641773 100644 > --- a/drivers/serial/Kconfig > +++ b/drivers/serial/Kconfig > @@ -401,11 +401,19 @@ config DEBUG_UART_MTK > driver will be available until the real driver model serial > is > running. > > +config DEBUG_UART_XEN > + bool "XEN Hypervisor Console" > + depends on XEN_SERIAL > + help > + Select this to enable a debug UART using the serial_xen > driver. You > + will not have to provide any parameters to make this work. > The driver > + will be available until the real driver-model serial > is > running. > + > endchoice > > config DEBUG_UART_BASE > hex "Base address of UART" > - depends on DEBUG_UART > + depends on DEBUG_UART && !DEBUG_UART_XEN > default 0 if DEBUG_UART_SANDBOX > help > This is the base address of your UART for memory-mapped > UARTs. > @@ -415,7 +423,7 @@ config DEBUG_UART_BASE > > config DEBUG_UART_CLOCK > int "UART input clock" > - depends on DEBUG_UART > + depends on DEBUG_UART && !DEBUG_UART_XEN > default 0 if DEBUG_UART_SANDBOX > help > The UART input clock determines the speed of the internal > UART > @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK > > config DEBUG_UART_SHIFT > int "UART register shift" > - depends on DEBUG_UART > + depends on DEBUG_UART && !DEBUG_UART_XEN > default 0 if DEBUG_UART > help > Some UARTs (notably ns16550) support different register > layouts > diff --git a/drivers/serial/serial_xen.c > b/drivers/serial/serial_xen.c > index ed191829f059..34c90ece40fc 100644 > --- a/drivers/serial/serial_xen.c > +++ b/drivers/serial/serial_xen.c > @@ -5,6 +5,7 @@ > */ > #include <common.h> > #include <cpu_func.h> > +#include <debug_uart.h> > #include <dm.h> > #include <serial.h> > #include <watchdog.h> > @@ -15,11 +16,14 @@ > #include <xen/events.h> > > #include <xen/interface/sched.h> > +#include <xen/interface/xen.h> > #include <xen/interface/hvm/hvm_op.h> > #include <xen/interface/hvm/params.h> > #include <xen/interface/io/console.h> > #include <xen/interface/io/ring.h> > > +#include <asm/xen/hypercall.h> > + > DECLARE_GLOBAL_DATA_PTR; > > u32 console_evtchn; > @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { > .flags = DM_FLAG_PRE_RELOC, > }; > > +#if defined(CONFIG_DEBUG_UART_XEN) > +static inline void _debug_uart_init(void) {} > + > +static inline void _debug_uart_putc(int c) > +{ > +#if CONFIG_IS_ENABLED(ARM) > + xen_debug_putc(c); > +#else > + /* the type cast should work on LE only */ > + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); An error occurs during compilation: drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in this function); did you mean ‘c’? HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch);
That was to debug why the original code didn't work, I see nothing wrong
in that she tried helping you to figure out why...
Anyway,
-Takahiro Akashi
Thank you,
Oleksandr
Regards, Anastasiia
> +#endif > +} > + > +DEBUG_UART_FUNCS > + > +#endif Regards, Anastasiia
[1] https://urldefense.com/v3/__https://lists.xenproject.org/archives/html/xen-d... [lists[.]xenproject[.]org]
Hello,
On Thu, Oct 22, 2020 at 09:19:41AM +0000, Anastasiia Lukianenko wrote: > Hi, > > On Thu, 2020-10-15 at 13:25 +0900, AKASHI Takahiro wrote: >> By using a hypervisor call, we can implement DEBUG_UART on xen. >> This will allow us to see messages even earlier than >> serial_init(). >> >> Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org >> --- >> drivers/serial/Kconfig | 14 +++++++++++--- >> drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ >> 2 files changed, 31 insertions(+), 3 deletions(-) >> >> diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig >> index e344677f91f6..536cf0641773 100644 >> --- a/drivers/serial/Kconfig >> +++ b/drivers/serial/Kconfig >> @@ -401,11 +401,19 @@ config DEBUG_UART_MTK >> driver will be available until the real driver model serial >> is >> running. >> >> +config DEBUG_UART_XEN >> + bool "XEN Hypervisor Console" >> + depends on XEN_SERIAL >> + help >> + Select this to enable a debug UART using the serial_xen >> driver. You >> + will not have to provide any parameters to make this work. >> The driver >> + will be available until the real driver-model serial >> is >> running. >> + >> endchoice >> >> config DEBUG_UART_BASE >> hex "Base address of UART" >> - depends on DEBUG_UART >> + depends on DEBUG_UART && !DEBUG_UART_XEN >> default 0 if DEBUG_UART_SANDBOX >> help >> This is the base address of your UART for memory-mapped >> UARTs. >> @@ -415,7 +423,7 @@ config DEBUG_UART_BASE >> >> config DEBUG_UART_CLOCK >> int "UART input clock" >> - depends on DEBUG_UART >> + depends on DEBUG_UART && !DEBUG_UART_XEN >> default 0 if DEBUG_UART_SANDBOX >> help >> The UART input clock determines the speed of the internal >> UART >> @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK >> >> config DEBUG_UART_SHIFT >> int "UART register shift" >> - depends on DEBUG_UART >> + depends on DEBUG_UART && !DEBUG_UART_XEN >> default 0 if DEBUG_UART >> help >> Some UARTs (notably ns16550) support different register >> layouts >> diff --git a/drivers/serial/serial_xen.c >> b/drivers/serial/serial_xen.c >> index ed191829f059..34c90ece40fc 100644 >> --- a/drivers/serial/serial_xen.c >> +++ b/drivers/serial/serial_xen.c >> @@ -5,6 +5,7 @@ >> */ >> #include <common.h> >> #include <cpu_func.h> >> +#include <debug_uart.h> >> #include <dm.h> >> #include <serial.h> >> #include <watchdog.h> >> @@ -15,11 +16,14 @@ >> #include <xen/events.h> >> >> #include <xen/interface/sched.h> >> +#include <xen/interface/xen.h> >> #include <xen/interface/hvm/hvm_op.h> >> #include <xen/interface/hvm/params.h> >> #include <xen/interface/io/console.h> >> #include <xen/interface/io/ring.h> >> >> +#include <asm/xen/hypercall.h> >> + >> DECLARE_GLOBAL_DATA_PTR; >> >> u32 console_evtchn; >> @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { >> .flags = DM_FLAG_PRE_RELOC, >> }; >> >> +#if defined(CONFIG_DEBUG_UART_XEN) >> +static inline void _debug_uart_init(void) {} >> + >> +static inline void _debug_uart_putc(int c) >> +{ >> +#if CONFIG_IS_ENABLED(ARM) >> + xen_debug_putc(c); >> +#else >> + /* the type cast should work on LE only */ >> + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); > An error occurs during compilation: > drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in > this > function); did you mean ‘c’? > HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); Ah, yes. You're now using x86, right?
I really appreciate your assistance here.
But without knowing the detailed environment on your side, it may sometimes be difficult to find out the root cause.
Anyway,
Please confirm this.
Please try this first. I believe that it is the first step to take.
Since I don't have any real hardwrare at this moment, it will be difficult for me to dig into the issue unless it can be reproduced on qemu.
-Takahiro Akashi
Thank you,
Oleksandr
Regards, Anastasiia
>> +#endif >> +} >> + >> +DEBUG_UART_FUNCS >> + >> +#endif > Regards, > Anastasiia
Hello,
On Thu, 2020-10-22 at 18:53 +0900, takahiro.akashi@linaro.org wrote: > On Thu, Oct 22, 2020 at 09:19:41AM +0000, Anastasiia Lukianenko > wrote: >> Hi, >> >> On Thu, 2020-10-15 at 13:25 +0900, AKASHI Takahiro wrote: >>> By using a hypervisor call, we can implement DEBUG_UART on xen. >>> This will allow us to see messages even earlier than >>> serial_init(). >>> >>> Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org >>> --- >>> drivers/serial/Kconfig | 14 +++++++++++--- >>> drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ >>> 2 files changed, 31 insertions(+), 3 deletions(-) >>> >>> diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig >>> index e344677f91f6..536cf0641773 100644 >>> --- a/drivers/serial/Kconfig >>> +++ b/drivers/serial/Kconfig >>> @@ -401,11 +401,19 @@ config DEBUG_UART_MTK >>> driver will be available until the real driver model serial >>> is >>> running. >>> >>> +config DEBUG_UART_XEN >>> + bool "XEN Hypervisor Console" >>> + depends on XEN_SERIAL >>> + help >>> + Select this to enable a debug UART using the serial_xen >>> driver. You >>> + will not have to provide any parameters to make this work. >>> The driver >>> + will be available until the real driver-model serial >>> is >>> running. >>> + >>> endchoice >>> >>> config DEBUG_UART_BASE >>> hex "Base address of UART" >>> - depends on DEBUG_UART >>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>> default 0 if DEBUG_UART_SANDBOX >>> help >>> This is the base address of your UART for memory-mapped >>> UARTs. >>> @@ -415,7 +423,7 @@ config DEBUG_UART_BASE >>> >>> config DEBUG_UART_CLOCK >>> int "UART input clock" >>> - depends on DEBUG_UART >>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>> default 0 if DEBUG_UART_SANDBOX >>> help >>> The UART input clock determines the speed of the internal >>> UART >>> @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK >>> >>> config DEBUG_UART_SHIFT >>> int "UART register shift" >>> - depends on DEBUG_UART >>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>> default 0 if DEBUG_UART >>> help >>> Some UARTs (notably ns16550) support different register >>> layouts >>> diff --git a/drivers/serial/serial_xen.c >>> b/drivers/serial/serial_xen.c >>> index ed191829f059..34c90ece40fc 100644 >>> --- a/drivers/serial/serial_xen.c >>> +++ b/drivers/serial/serial_xen.c >>> @@ -5,6 +5,7 @@ >>> */ >>> #include <common.h> >>> #include <cpu_func.h> >>> +#include <debug_uart.h> >>> #include <dm.h> >>> #include <serial.h> >>> #include <watchdog.h> >>> @@ -15,11 +16,14 @@ >>> #include <xen/events.h> >>> >>> #include <xen/interface/sched.h> >>> +#include <xen/interface/xen.h> >>> #include <xen/interface/hvm/hvm_op.h> >>> #include <xen/interface/hvm/params.h> >>> #include <xen/interface/io/console.h> >>> #include <xen/interface/io/ring.h> >>> >>> +#include <asm/xen/hypercall.h> >>> + >>> DECLARE_GLOBAL_DATA_PTR; >>> >>> u32 console_evtchn; >>> @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { >>> .flags = DM_FLAG_PRE_RELOC, >>> }; >>> >>> +#if defined(CONFIG_DEBUG_UART_XEN) >>> +static inline void _debug_uart_init(void) {} >>> + >>> +static inline void _debug_uart_putc(int c) >>> +{ >>> +#if CONFIG_IS_ENABLED(ARM) >>> + xen_debug_putc(c); >>> +#else >>> + /* the type cast should work on LE only */ >>> + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); >> An error occurs during compilation: >> drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in >> this >> function); did you mean ‘c’? >> HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); > Ah, yes. You're now using x86, right? No, I just tried different options and accidentally discovered this error.
We are really interested in what you do as we didn't have enough cycles to do the same
at the time of the initial submission. And we can help testing that on 2 different
HW platforms: Renesas and iMX8. Also, Xen devel community and us will be glad to
help you with this
I believe this part must be platform agnostic, e.g. it should work the same way
on any platform
Anyway,
> So what happens if you have made the fix above? > Does it work in your environment? > (I have confirmed that HYPERVISOR_console_io version works on > arm(64).) Unfortunately, nothing happened (there are no logs mentioned earlier).
Xen ARM ABI is stable for a long time now, so it is confirmed as not related
to possible code changes, but ABI violation on u-boot side before the MMU is on
(this is basically where we need debug console most of the time).
Please provide the exact environment you use, so we can have the same on our side
Understand you and as I said above we can help testing this on real HW
Thank you,
Oleksandr
-Takahiro Akashi
Thank you,
Oleksandr
Regards, Anastasiia > Thanks, > -Takahiro Akashi > > >>> +#endif >>> +} >>> + >>> +DEBUG_UART_FUNCS >>> + >>> +#endif >> Regards, >> Anastasiia
Oleksandr,
It seems that we now stand on the same page.
On Fri, Oct 23, 2020 at 08:50:56AM +0000, Anastasiia Lukianenko wrote: > Hello, > > On Thu, 2020-10-22 at 18:53 +0900, takahiro.akashi@linaro.org wrote: >> On Thu, Oct 22, 2020 at 09:19:41AM +0000, Anastasiia Lukianenko >> wrote: >>> Hi, >>> >>> On Thu, 2020-10-15 at 13:25 +0900, AKASHI Takahiro wrote: >>>> By using a hypervisor call, we can implement DEBUG_UART on xen. >>>> This will allow us to see messages even earlier than >>>> serial_init(). >>>> >>>> Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org >>>> --- >>>> drivers/serial/Kconfig | 14 +++++++++++--- >>>> drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ >>>> 2 files changed, 31 insertions(+), 3 deletions(-) >>>> >>>> diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig >>>> index e344677f91f6..536cf0641773 100644 >>>> --- a/drivers/serial/Kconfig >>>> +++ b/drivers/serial/Kconfig >>>> @@ -401,11 +401,19 @@ config DEBUG_UART_MTK >>>> driver will be available until the real driver model serial >>>> is >>>> running. >>>> >>>> +config DEBUG_UART_XEN >>>> + bool "XEN Hypervisor Console" >>>> + depends on XEN_SERIAL >>>> + help >>>> + Select this to enable a debug UART using the serial_xen >>>> driver. You >>>> + will not have to provide any parameters to make this work. >>>> The driver >>>> + will be available until the real driver-model serial >>>> is >>>> running. >>>> + >>>> endchoice >>>> >>>> config DEBUG_UART_BASE >>>> hex "Base address of UART" >>>> - depends on DEBUG_UART >>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>> default 0 if DEBUG_UART_SANDBOX >>>> help >>>> This is the base address of your UART for memory-mapped >>>> UARTs. >>>> @@ -415,7 +423,7 @@ config DEBUG_UART_BASE >>>> >>>> config DEBUG_UART_CLOCK >>>> int "UART input clock" >>>> - depends on DEBUG_UART >>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>> default 0 if DEBUG_UART_SANDBOX >>>> help >>>> The UART input clock determines the speed of the internal >>>> UART >>>> @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK >>>> >>>> config DEBUG_UART_SHIFT >>>> int "UART register shift" >>>> - depends on DEBUG_UART >>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>> default 0 if DEBUG_UART >>>> help >>>> Some UARTs (notably ns16550) support different register >>>> layouts >>>> diff --git a/drivers/serial/serial_xen.c >>>> b/drivers/serial/serial_xen.c >>>> index ed191829f059..34c90ece40fc 100644 >>>> --- a/drivers/serial/serial_xen.c >>>> +++ b/drivers/serial/serial_xen.c >>>> @@ -5,6 +5,7 @@ >>>> */ >>>> #include <common.h> >>>> #include <cpu_func.h> >>>> +#include <debug_uart.h> >>>> #include <dm.h> >>>> #include <serial.h> >>>> #include <watchdog.h> >>>> @@ -15,11 +16,14 @@ >>>> #include <xen/events.h> >>>> >>>> #include <xen/interface/sched.h> >>>> +#include <xen/interface/xen.h> >>>> #include <xen/interface/hvm/hvm_op.h> >>>> #include <xen/interface/hvm/params.h> >>>> #include <xen/interface/io/console.h> >>>> #include <xen/interface/io/ring.h> >>>> >>>> +#include <asm/xen/hypercall.h> >>>> + >>>> DECLARE_GLOBAL_DATA_PTR; >>>> >>>> u32 console_evtchn; >>>> @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { >>>> .flags = DM_FLAG_PRE_RELOC, >>>> }; >>>> >>>> +#if defined(CONFIG_DEBUG_UART_XEN) >>>> +static inline void _debug_uart_init(void) {} >>>> + >>>> +static inline void _debug_uart_putc(int c) >>>> +{ >>>> +#if CONFIG_IS_ENABLED(ARM) >>>> + xen_debug_putc(c); >>>> +#else >>>> + /* the type cast should work on LE only */ >>>> + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); >>> An error occurs during compilation: >>> drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in >>> this >>> function); did you mean ‘c’? >>> HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); >> Ah, yes. You're now using x86, right? > No, I just tried different options and accidentally discovered this > error. No? My code is protected with "if CONFIG_IS_ENABLED(ARM)", and so you have no chance of building "else" clause unless you use x86.
We are really interested in what you do as we didn't have enough cycles to do the same at the time of the initial submission. And we can help testing that on 2 different HW platforms: Renesas and iMX8. Also, Xen devel community and us will be glad to help you with this
Thank you again.
on any platform
Of course, agree.
Anyway,
>> So what happens if you have made the fix above? >> Does it work in your environment? >> (I have confirmed that HYPERVISOR_console_io version works on >> arm(64).) > Unfortunately, nothing happened (there are no logs mentioned earlier).
Xen ARM ABI is stable for a long time now, so it is confirmed as not related to possible code changes, but ABI violation on u-boot side before the MMU is on (this is basically where we need debug console most of the time).
Still I'm a bit confused.
After all, HYPERBVISOR_console_io doesn't work yet on arm/arm64, at least, in an early boot stage of U-Boot.
Is this the right understanding about current HYPERVISOR_console_io support?
host: debian 20.04 qemu: debian's qemu (4.2.1) or my own build (of 5.1.0)
qemu cmd params: -serial mon:stdio -nographic -boot menu=on -machine virt,gic-version=3,virtualization=on,secure=on -cpu cortex-a57 -smp 2 -m 4G -d unimp ... (misc virtio disks) -rtc base=utc -bios /path/to/rom.bin (I use tf-a + u-boot to boot xen+debian.)
xen: upstream 4.15+ (25849c8b16f2 "xen/rpi4: implement watchdog-based reset") with default configuration (maybe adding "#undef NDEBUG") xen boot params: sync_console dom0_mem=2G loglvl=all guest_loglvl=all
dom0: debian testing (as of Oct 5th?) + my own built xen/xentools (see above)
u-boot: upstream v2020.10 (or pre-v2021.01-rc1) + my patch with xenguest_arm64_defconfig + CONFIG_DEBUG_UART (+ misc configurations) domU config: kernel = "/boot/u-boot.bin" memory = 128 vcpus = 1
Please let me know if you need more information.
Thank you,
Oleksandr
-Takahiro Akashi
Thank you,
Oleksandr
> Regards, > Anastasiia >> Thanks, >> -Takahiro Akashi >> >> >>>> +#endif >>>> +} >>>> + >>>> +DEBUG_UART_FUNCS >>>> + >>>> +#endif >>> Regards, >>> Anastasiia
On 10/26/20 10:03 AM, takahiro.akashi@linaro.org wrote:
Oleksandr,
Great, hope all together we can make it happen
On 10/26/20 7:58 AM, takahiro.akashi@linaro.org wrote: > On Fri, Oct 23, 2020 at 08:50:56AM +0000, Anastasiia Lukianenko wrote: >> Hello, >> >> On Thu, 2020-10-22 at 18:53 +0900, takahiro.akashi@linaro.org wrote: >>> On Thu, Oct 22, 2020 at 09:19:41AM +0000, Anastasiia Lukianenko >>> wrote: >>>> Hi, >>>> >>>> On Thu, 2020-10-15 at 13:25 +0900, AKASHI Takahiro wrote: >>>>> By using a hypervisor call, we can implement DEBUG_UART on xen. >>>>> This will allow us to see messages even earlier than >>>>> serial_init(). >>>>> >>>>> Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org >>>>> --- >>>>> drivers/serial/Kconfig | 14 +++++++++++--- >>>>> drivers/serial/serial_xen.c | 20 ++++++++++++++++++++ >>>>> 2 files changed, 31 insertions(+), 3 deletions(-) >>>>> >>>>> diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig >>>>> index e344677f91f6..536cf0641773 100644 >>>>> --- a/drivers/serial/Kconfig >>>>> +++ b/drivers/serial/Kconfig >>>>> @@ -401,11 +401,19 @@ config DEBUG_UART_MTK >>>>> driver will be available until the real driver model serial >>>>> is >>>>> running. >>>>> >>>>> +config DEBUG_UART_XEN >>>>> + bool "XEN Hypervisor Console" >>>>> + depends on XEN_SERIAL >>>>> + help >>>>> + Select this to enable a debug UART using the serial_xen >>>>> driver. You >>>>> + will not have to provide any parameters to make this work. >>>>> The driver >>>>> + will be available until the real driver-model serial >>>>> is >>>>> running. >>>>> + >>>>> endchoice >>>>> >>>>> config DEBUG_UART_BASE >>>>> hex "Base address of UART" >>>>> - depends on DEBUG_UART >>>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>>> default 0 if DEBUG_UART_SANDBOX >>>>> help >>>>> This is the base address of your UART for memory-mapped >>>>> UARTs. >>>>> @@ -415,7 +423,7 @@ config DEBUG_UART_BASE >>>>> >>>>> config DEBUG_UART_CLOCK >>>>> int "UART input clock" >>>>> - depends on DEBUG_UART >>>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>>> default 0 if DEBUG_UART_SANDBOX >>>>> help >>>>> The UART input clock determines the speed of the internal >>>>> UART >>>>> @@ -427,7 +435,7 @@ config DEBUG_UART_CLOCK >>>>> >>>>> config DEBUG_UART_SHIFT >>>>> int "UART register shift" >>>>> - depends on DEBUG_UART >>>>> + depends on DEBUG_UART && !DEBUG_UART_XEN >>>>> default 0 if DEBUG_UART >>>>> help >>>>> Some UARTs (notably ns16550) support different register >>>>> layouts >>>>> diff --git a/drivers/serial/serial_xen.c >>>>> b/drivers/serial/serial_xen.c >>>>> index ed191829f059..34c90ece40fc 100644 >>>>> --- a/drivers/serial/serial_xen.c >>>>> +++ b/drivers/serial/serial_xen.c >>>>> @@ -5,6 +5,7 @@ >>>>> */ >>>>> #include <common.h> >>>>> #include <cpu_func.h> >>>>> +#include <debug_uart.h> >>>>> #include <dm.h> >>>>> #include <serial.h> >>>>> #include <watchdog.h> >>>>> @@ -15,11 +16,14 @@ >>>>> #include <xen/events.h> >>>>> >>>>> #include <xen/interface/sched.h> >>>>> +#include <xen/interface/xen.h> >>>>> #include <xen/interface/hvm/hvm_op.h> >>>>> #include <xen/interface/hvm/params.h> >>>>> #include <xen/interface/io/console.h> >>>>> #include <xen/interface/io/ring.h> >>>>> >>>>> +#include <asm/xen/hypercall.h> >>>>> + >>>>> DECLARE_GLOBAL_DATA_PTR; >>>>> >>>>> u32 console_evtchn; >>>>> @@ -178,3 +182,19 @@ U_BOOT_DRIVER(serial_xen) = { >>>>> .flags = DM_FLAG_PRE_RELOC, >>>>> }; >>>>> >>>>> +#if defined(CONFIG_DEBUG_UART_XEN) >>>>> +static inline void _debug_uart_init(void) {} >>>>> + >>>>> +static inline void _debug_uart_putc(int c) >>>>> +{ >>>>> +#if CONFIG_IS_ENABLED(ARM) >>>>> + xen_debug_putc(c); >>>>> +#else >>>>> + /* the type cast should work on LE only */ >>>>> + HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); >>>> An error occurs during compilation: >>>> drivers/serial/serial_xen.c: error: ‘ch’ undeclared (first use in >>>> this >>>> function); did you mean ‘c’? >>>> HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); >>> Ah, yes. You're now using x86, right? >> No, I just tried different options and accidentally discovered this >> error. > No? > My code is protected with "if CONFIG_IS_ENABLED(ARM)", and so > you have no chance of building "else" clause unless you use x86. The question here is that if x86 is selected it won't compile. Another
Thank you again.
on any platform
Of course, agree.
> Anyway, > >>> So what happens if you have made the fix above? >>> Does it work in your environment? >>> (I have confirmed that HYPERVISOR_console_io version works on >>> arm(64).) >> Unfortunately, nothing happened (there are no logs mentioned earlier). > 1. Have you ever executed HYPERVISOR_console_io on your platform before? Yes, we did that. You may have noticed that in [1] which I referred earlier and the problems we faced with that.
I do suggest you read [1] for better understanding of the issue we faced with
early debug console. In our setup we, without having debug UART implementation,
use the two following for debugging:
staticvoidxen_serial_putc(constcharc) { invalidate_dcache_range((unsignedlong)&c, (unsignedlong)&c + 1); (void)HYPERVISOR_console_io(CONSOLEIO_write, 1, (char*)&c); } staticvoidxen_serial_puts(constchar*str) { intlen = strlen(str); invalidate_dcache_range((unsignedlong)str, (unsignedlong)str + len); (void)HYPERVISOR_console_io(CONSOLEIO_write, len, (char*)str); } Please not those invalidate_dcache_range calls. With the above we can see debug prints way before the DM based serial driver is initialized and MMU is set up (this is required because of D-cache on ARM).
> 2. If possible, please try to my code on qemu, as my patch intended, so that > we can determine if your issue is generic or specific on your environment? The code runs on two different platforms with the same result (non-QEMU though).
Thank you
Thanks, -Takahiro Akashi
Thank you,
Oleksandr
Thank you,
Oleksandr
-Takahiro Akashi
Thank you,
Oleksandr
> Thanks, > -Takahiro Akashi > > >> Regards, >> Anastasiia >>> Thanks, >>> -Takahiro Akashi >>> >>> >>>>> +#endif >>>>> +} >>>>> + >>>>> +DEBUG_UART_FUNCS >>>>> + >>>>> +#endif >>>> Regards, >>>> Anastasiia [1] https://urldefense.com/v3/__https://lists.xenproject.org/archives/html/xen-d... [lists[.]xenproject[.]org]
Hello,
Anyway,
So, this is why I provided you with a link to previous discussion we had on
Xen development list: that was with respect to console_io and D-cache maintenance.
That was actually the reason we didn't put debug console as a part of the initial
submission.
No, why? It is all defined in Xen ARM's ABI and u-boot must take care of it on its end
as it violates the ABI before the MMU is on.
Hm...
Ok, once again. This is about the ABI which is stable. Do you think more recent Xen
broke something?
Well, I have probably missed something, but you neither mentioned you are running
under QEMU (my apologies if this is not true) nor you have provided the exact configuration
of your setup, e.g. QEMU's command line, what is used as a root fs etc. so one interested
in the topic can actually reproduce your setup.
Thank you,
Oleksandr
-Takahiro Akashi
Thank you,
Oleksandr
Regards, Anastasiia
- help
driver. You
The driver
is running.
endchoice
+#else
Sorry, I forgot to write in the last letter the question: Why can't we simply use HYPERVISOR_console_io(CONSOLEIO_write, 1, (char *)&ch); for both ARM and Xen?
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
- help
driver. You
The driver
is running.
endchoice
+#else
Simply because the executed code on Xen side is quite simple. I assume that simpler it is, more chance of output.
-Takahiro Akashi
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
- help
driver. You
The driver
is running.
endchoice
u32 console_evtchn;
+#else
This is true that the simpler the better. And we already have a proper platform
agnostic definition for that:
arch/arm/cpu/armv8/xen/hypercall.S:73:HYPERCALL3(console_io); arch/arm/include/asm/xen/hypercall.h:16:int HYPERVISOR_console_io(int cmd, int count, char *str); include/xen/interface/xen.h:44:#define __HYPERVISOR_console_io 18
So, we are not only adding an ARM specific implementation in the patch, but also add
#ifdef's in the code while we can simply avoid that. So, to me, it would make
much more sense if we use what we already have the way Xen has it rather than adding
the code which may require maintenance and make the code harder to read
Thank you,
Oleksandr
-Takahiro Akashi
Regards, Anastasiia
+#endif +}
+DEBUG_UART_FUNCS
Regards, Anastasiia
Hello,
Sorry, I thought there was still discussion on the series. May I ask why it was merged?
Regards, Anastasiia
On Fri, Oct 23, 2020 at 09:22:20AM +0000, Anastasiia Lukianenko wrote:
Hello,
I just missed it, sorry. Do you want me too revert the series for now or should i just expect a small follow-up soon?
Hello,
I have no strong opinion here: on one hand there are patches which won't compile for at least x86 which is obviously not good. On the other hand we are discussing the rest of the patches as I was not able to run them on my ARM board, so it either can be that I miss something and the pacthes are ok or it can also be that the pacthes need to be re-worked. So, best was not to have them in the tree yet...
Regards, Anastasiia
Hello,
OK, I've reverted the series. Sorry for the confusion!
participants (6)
AKASHI Takahiro
Peng Fan
