[U-Boot] Return value of run command
Hi all,
Should the command 'run something"' return the value that returns "something" or just return "true" if can execute something and "false" if it can't ?
I'll explain. Imagine you have a variable that loads a file from the mmc but this files doesn't exist.
loadfile=load mmc ${mmcdev} ${loadaddr} my-file
In the case you do the following script
if run loadfile; then echo "true"; else echo "false"; fi
the result is always "true", either the file doesn't exist
OTOH, if you do :
if ${loadfile}; then echo "true"; else echo "false"; fi
Then the result is "true" if file exist and "false" if file doesn't exist.
For me looks like the "run something" command should return the result of the command but this is not the behaviour. With current behaviour something like CONFIG_EXTRA_ENV_SETTINGS from include/configs/am335x_evm.h file,
129 "echo SD/MMC found on device ${mmcdev};" \ 130 "if run loadbootenv; then " \ 131 "echo Loaded environment from ${bootenv};" \ 132 "run importbootenv;" \ 133 "fi;" \
Either uEnv.txt file exist or not, the "run loadbootenv" always returns true, so always tries to run "run importbootenv". I supose this is not the expected behaviour.
The question is. It's a problem with run command or with the definition of CONFIG_EXTRA_ENV_SETTING, that should be something like that:
- 130 "if run loadbootenv; then " \ + 130 "if ${loadbootenv}; then " \
Best regards, Enric
On Fri, May 30, 2014 at 05:03:36PM +0200, Enric Balletbo Serra wrote:
Hi all,
OTOH, if you do :
- 130 "if ${loadbootenv}; then " \
Sorry for sitting on this for so long. There's been a change in behaviour that I'm going to go track down now and see what we can do about.
Hi all,
OTOH, if you do :
Derp-de-derp, yes, we've fixed this regression since then, time to track down if I've got an outstanding pull request to Albert somewhere..
