[U-Boot] [PATCH v2] global_data.h: Standardize tabs and alignment for comments
Line up comments for readibility.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
missed the last few lines with patch v1, and if i'm going to do it, i might as well do it properly.
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index a6d1d2a..dc4cbdb 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -28,18 +28,18 @@ typedef struct global_data { bd_t *bd; unsigned long flags; unsigned int baudrate; - unsigned long cpu_clk; /* CPU clock in Hz! */ + unsigned long cpu_clk; /* CPU clock in Hz! */ unsigned long bus_clk; /* We cannot bracket this with CONFIG_PCI due to mpc5xxx */ unsigned long pci_clk; unsigned long mem_clk; #if defined(CONFIG_LCD) || defined(CONFIG_VIDEO) - unsigned long fb_base; /* Base address of framebuffer mem */ + unsigned long fb_base; /* Base address of framebuffer mem */ #endif #if defined(CONFIG_POST) || defined(CONFIG_LOGBUFFER) - unsigned long post_log_word; /* Record POST activities */ - unsigned long post_log_res; /* success of POST test */ - unsigned long post_init_f_time; /* When post_init_f started */ + unsigned long post_log_word; /* Record POST activities */ + unsigned long post_log_res; /* success of POST test */ + unsigned long post_init_f_time; /* When post_init_f started */ #endif #ifdef CONFIG_BOARD_TYPES unsigned long board_type; @@ -48,14 +48,13 @@ typedef struct global_data { #ifdef CONFIG_PRE_CONSOLE_BUFFER unsigned long precon_buf_idx; /* Pre-Console buffer index */ #endif - unsigned long env_addr; /* Address of Environment struct */ + unsigned long env_addr; /* Address of Environment struct */ unsigned long env_valid; /* Checksum of Environment valid? */
- unsigned long ram_top; /* Top address of RAM used by U-Boot */ - + unsigned long ram_top; /* Top address of RAM used by U-Boot */ unsigned long relocaddr; /* Start address of U-Boot in RAM */ - phys_size_t ram_size; /* RAM size */ - unsigned long mon_len; /* monitor len */ + phys_size_t ram_size; /* RAM size */ + unsigned long mon_len; /* monitor len */ unsigned long irq_sp; /* irq stack pointer */ unsigned long start_addr_sp; /* start_addr_stackpointer */ unsigned long reloc_off; @@ -67,14 +66,14 @@ typedef struct global_data { struct list_head uclass_root; /* Head of core tree */ #endif #ifdef CONFIG_TIMER - struct udevice *timer; /* Timer instance for Driver Model */ + struct udevice *timer; /* Timer instance for Driver Model */ #endif
- const void *fdt_blob; /* Our device tree, NULL if none */ - void *new_fdt; /* Relocated FDT */ - unsigned long fdt_size; /* Space reserved for relocated FDT */ + const void *fdt_blob; /* Our device tree, NULL if none */ + void *new_fdt; /* Relocated FDT */ + unsigned long fdt_size; /* Space reserved for relocated FDT */ struct jt_funcs *jt; /* jump table */ - char env_buf[32]; /* buffer for getenv() before reloc. */ + char env_buf[32]; /* buffer for getenv() before reloc. */ #ifdef CONFIG_TRACE void *trace_buff; /* The trace buffer */ #endif @@ -125,8 +124,8 @@ typedef struct global_data { #define GD_FLG_SERIAL_READY 0x00100 /* Pre-reloc serial console ready */ #define GD_FLG_FULL_MALLOC_INIT 0x00200 /* Full malloc() is ready */ #define GD_FLG_SPL_INIT 0x00400 /* spl_init() has been called */ -#define GD_FLG_SKIP_RELOC 0x00800 /* Don't relocate */ -#define GD_FLG_RECORD 0x01000 /* Record console */ -#define GD_FLG_ENV_DEFAULT 0x02000 /* Default variable flag */ +#define GD_FLG_SKIP_RELOC 0x00800 /* Don't relocate */ +#define GD_FLG_RECORD 0x01000 /* Record console */ +#define GD_FLG_ENV_DEFAULT 0x02000 /* Default variable flag */
#endif /* __ASM_GENERIC_GBL_DATA_H */
Robert P. J. Day
