[PATCH] pinctrl: fix typo
fix typo in pinctrl Kconfig file to avoid git commit failure on some commit hooks check.
Signed-off-by: Yuan Fang fangyuanseu@gmail.com --- drivers/pinctrl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 77fb851114..30eaa376c8 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -69,7 +69,7 @@ config PINCONF_RECURSIVE direct children of the pin controller device (may be grandchildren for example). It is define is each individual pin controller device. Say Y here if you want to keep this behavior with the pinconfig - u-class: all sub are recursivelly bounded. + u-class: all sub are recursively bounded. If the option is disabled, this behavior is deactivated and only the direct children of pin controller will be assumed as pin configuration; you can save memory footprint when this feature is
Yuan Fang
