[U-Boot-Users] [GIT PULL] AVR32 fixes
Hi Wolfgang,
The following changes since commit 527c80f012030fa0b51f8594847ec56c9317e9b1: Stefan Roese (1): Merge with git://www.denx.de/git/u-boot.git
git://www.denx.de/git/u-boot-avr32.git master
Eirik Aanonsen (2): Add some comments to clocks in atstk1002.h Update atstk1002 bootargs.
Haavard Skinnemoen (3): Merge commit 'origin/master' Fix memtest breakage AVR32: Initialize bi_flash* in board_init_r
Hans-Christian Egtvedt (2): Remove double quotation marks around MAC address for STK1002 Reduce BOOTDELAY variable to 1 second by default for STK1002
Semih Hazar (1): AVR32: Change prototype of memset
board/atmel/atstk1000/flash.c | 4 ---- include/asm-avr32/string.h | 2 +- include/configs/atstk1002.h | 38 ++++++++++++++++++++++++++------------ lib_avr32/board.c | 12 +++++++++++- 4 files changed, 38 insertions(+), 18 deletions(-)
diff --git a/board/atmel/atstk1000/flash.c b/board/atmel/atstk1000/flash.c index 958f4dc..93d790f 100644 --- a/board/atmel/atstk1000/flash.c +++ b/board/atmel/atstk1000/flash.c @@ -55,10 +55,6 @@ unsigned long flash_init(void) unsigned long addr; unsigned int i;
- gd->bd->bi_flashstart = CFG_FLASH_BASE; - gd->bd->bi_flashsize = CFG_FLASH_SIZE; - gd->bd->bi_flashoffset = _edata - _text; - flash_info[0].size = CFG_FLASH_SIZE; flash_info[0].sector_count = 135;
diff --git a/include/asm-avr32/string.h b/include/asm-avr32/string.h index 8b05d1a..58582a3 100644 --- a/include/asm-avr32/string.h +++ b/include/asm-avr32/string.h @@ -23,6 +23,6 @@ #define __ASM_AVR32_STRING_H
#define __HAVE_ARCH_MEMSET -extern void *memset(void *s, int c, size_t n); +extern void *memset(void *s, int c, __kernel_size_t n);
#endif /* __ASM_AVR32_STRING_H */ diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 75b153e..1809fc5 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -39,8 +39,10 @@ #define CFG_HZ 1000
/* - * Set up the PLL to run at 199.5 MHz, the CPU to run at 1/2 the PLL - * frequency and the peripherals to run at 1/4 the PLL frequency. + * Set up the PLL to run at 140 MHz, the CPU to run at the PLL + * frequency, the HSB and PBB at 1/2, and the PBA to run at 1/4 the + * PLL frequency. + * (CFG_OSC0_HZ * CFG_PLL0_MUL) / CFG_PLL0_DIV = PLL MHz */ #define CONFIG_PLL 1 #define CFG_POWER_MANAGER 1 @@ -48,9 +50,25 @@ #define CFG_PLL0_DIV 1 #define CFG_PLL0_MUL 7 #define CFG_PLL0_SUPPRESS_CYCLES 16 +/* + * Set the CPU running at: + * PLL / (2^CFG_CLKDIV_CPU) = CPU MHz + */ #define CFG_CLKDIV_CPU 0 +/* + * Set the HSB running at: + * PLL / (2^CFG_CLKDIV_HSB) = HSB MHz + */ #define CFG_CLKDIV_HSB 1 +/* + * Set the PBA running at: + * PLL / (2^CFG_CLKDIV_PBA) = PBA MHz + */ #define CFG_CLKDIV_PBA 2 +/* + * Set the PBB running at: + * PLL / (2^CFG_CLKDIV_PBB) = PBB MHz + */ #define CFG_CLKDIV_PBB 1
/* @@ -78,7 +96,7 @@
#define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS \ - "console=ttyS0 root=/dev/mtdblock1 rootfstype=jffs2 fbmem=600k" + "console=ttyS0 root=/dev/mmcblk0p1 fbmem=600k rootwait=1"
#define CONFIG_BOOTCOMMAND \ "fsload; bootm $(fileaddr)" @@ -87,7 +105,7 @@ * Only interrupt autoboot if <space> is pressed. Otherwise, garbage * data on the serial line may interrupt the boot sequence. */ -#define CONFIG_BOOTDELAY 2 +#define CONFIG_BOOTDELAY 1 #define CONFIG_AUTOBOOT 1 #define CONFIG_AUTOBOOT_KEYED 1 #define CONFIG_AUTOBOOT_PROMPT \ @@ -103,8 +121,8 @@ * generated and assigned to the environment variables "ethaddr" and * "eth1addr". */ -#define CONFIG_ETHADDR "6a:87:71:14:cd:cb" -#define CONFIG_ETH1ADDR "ca:f8:15:e6:3e:e6" +#define CONFIG_ETHADDR 6a:87:71:14:cd:cb +#define CONFIG_ETH1ADDR ca:f8:15:e6:3e:e6 #define CONFIG_OVERWRITE_ETHADDR_ONCE 1 #define CONFIG_NET_MULTI 1
@@ -182,12 +200,8 @@ #define CFG_PBSIZE (CFG_CBSIZE + sizeof(CFG_PROMPT) + 16) #define CFG_LONGHELP 1
-#define CFG_MEMTEST_START \ - ({ gd->bd->bi_dram[0].start; }) -#define CFG_MEMTEST_END \ - ({ \ - gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size; \ - }) +#define CFG_MEMTEST_START CFG_SDRAM_BASE +#define CFG_MEMTEST_END (CFG_MEMTEST_START + 0x700000) #define CFG_BAUDRATE_TABLE { 115200, 38400, 19200, 9600, 2400 }
#endif /* __CONFIG_H */ diff --git a/lib_avr32/board.c b/lib_avr32/board.c index 8b9ca38..11d864f 100644 --- a/lib_avr32/board.c +++ b/lib_avr32/board.c @@ -310,10 +310,20 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) malloc_bin_reloc(); dma_alloc_init(); board_init_info(); - flash_init(); + + bd->bi_flashstart = 0; + bd->bi_flashsize = 0; + bd->bi_flashoffset = 0; + +#ifndef CFG_NO_FLASH + bd->bi_flashstart = CFG_FLASH_BASE; + bd->bi_flashsize = flash_init(); + bd->bi_flashoffset = (unsigned long)_edata - (unsigned long)_text;
if (bd->bi_flashsize) display_flash_config(); +#endif + if (bd->bi_dram[0].size) display_dram_config();
In message 20071007140612.5b1734ab@siona you wrote:
Hi Wolfgang,
Umm... have these patches really gone over the mailing list? I can't find such subjects in the archive?
Merged...
No, most of them probably haven't. Some of them came through the u-boot@avr32linux.org mailing list, while others are just trivial fixes that I didn't bother posting anywhere. They're all rather trivial, actually; otherwise I would have held them until the next merge window.
I can start forwarding such patches to the main u-boot list if you want.
Merged...
Thanks.
Håvard
Please do. Ideally, *all* patches should be reviewed here on the list *before* a custodian picks them up for his repo.
Ok, since it's obviously best if the patches are sent to this list in the first place, I've added a note to
http://avr32linux.org/twiki/bin/view/Main/MailingLists
I'll try to catch the ones that aren't and pass them on before merging.
Håvard
Can you drop the AVR32 u-boot mailing list entirely and direct posters here? It's not like the u-boot list is high volume and it would be better to discuss even arch specific changes in the common forum.
Cheers, g.
On Sun, 14 Oct 2007 16:22:40 -0600 "Grant Likely" grant.likely@secretlab.ca wrote:
Yeah, that's a good point. When we created the kernel list at avr32linux.org we sort of figured it might be a good idea to create one for u-boot as well. Perhaps that was a bad move.
However, I'm a bit afraid of losing some of the potential testers that are subscribed to that list. Contributors should probably subscribe to u-boot-users to get a better feeling of the whole picture, but I suspect that some people aren't all that interested in everything that happens on the main mailing list, while they might very well be interested in testing specific bugfixes or improvements targeted towards avr32 boards.
I think the avr32linux.org list is also a good place to announce releases and pre-releases of our "vendor" loaders. Those are probably only interesting to people using avr32.
So I think I want to keep the list for now, as a very-low-volume avr32-specific thing. The volume on u-boot-users seems to be picking up; that's a good thing, but it may also drive some users away.
Håvard
----- Original Message ----- From: "Haavard Skinnemoen" hskinnemoen@atmel.com To: "Grant Likely" grant.likely@secretlab.ca Cc: "U-Boot Users" u-boot-users@lists.sourceforge.net; u-boot@avr32linux.org; "Wolfgang Denk" wd@denx.de Sent: Monday, October 15, 2007 11:18 AM Subject: Re: [U-Boot-Users] [GIT PULL] AVR32 fixes
You can forward everything on the AVR32 list to the normal u-boot list easily, adding [AVR32] to the header. You could also filter the u-boot list, and anything on this list with [AVR32] in the header gets forwarded to the AVR32 list (without bouncing back of course)
Håvard
Best Regards Ulf Samuelsson ulf@atmel.com Atmel Nordic AB Mail: Box 2033, 174 02 Sundbyberg, Sweden Visit: Kavallerivägen 24, 174 58 Sundbyberg, Sweden Phone +46 (8) 441 54 22 Fax +46 (8) 441 54 29 GSM +46 (706) 22 44 57
Technical support when I am not available: AT89 C51 Applications Group: mailto:micro.hotline@nto.atmel.com AT90 AVR Applications Group: mailto:avr@atmel.com AT91 ARM Applications Group: mailto:at91support@atmel.com FPSLIC Application Group: mailto:fpslic@atmel.com Best AVR link: www.avrfreaks.net
Hmm...I'm not sure if I want to do any automatic forwarding between the two lists. By "forwarding patches", I really mean something along the lines of
* Apply the patch to my working tree and add my signoff * Test that it compiles * Extract it with git-format-patch and send it to u-boot-users for further review.
which takes about two minutes to do, assuming the patch applies cleanly. This should work the other way around as well.
Håvard
Grant Likely
Haavard Skinnemoen
Ulf Samuelsson
