[U-Boot] [PATCH] ARM: mvebu: dts: add Clearfog GT-8K
The SolidRun Clearfog GT-8K is based on Armada 8040.
https://wiki.solid-run.com/doku.php?id=products:a8040:clearfoggt8k
Signed-off-by: Rabeeh Khoury rabeeh@solid-run.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-8040-clearfog-gt-8k.dts | 315 ++++++++++++++++++++ 2 files changed, 316 insertions(+) create mode 100644 arch/arm/dts/armada-8040-clearfog-gt-8k.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 44ebc50bfab1..c9a23ea68450 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -99,6 +99,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-7040-db-nand.dtb \ armada-8040-db.dtb \ armada-8040-mcbin.dtb \ + armada-8040-clearfog-gt-8k.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ diff --git a/arch/arm/dts/armada-8040-clearfog-gt-8k.dts b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts new file mode 100644 index 000000000000..015ef35b0d81 --- /dev/null +++ b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts @@ -0,0 +1,315 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 SolidRun ltd + */ + +#include "armada-8040.dtsi" + +/ { + model = "ClearFog-GT-8K"; + compatible = "solidrun,armada8040-cf-gt-8k", + "marvell,armada8040"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cpm_i2c0; + i2c1 = &cpm_i2c1; + spi0 = &cps_spi1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + simple-bus { + compatible = "simple-bus"; + + reg_usb3h0_vbus: usb3-vbus0 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&cpm_xhci_vbus_pins>; + regulator-name = "reg-usb3h0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <300000>; + shutdown-delay-us = <500000>; + regulator-force-boot-off; + gpio = <&cpm_gpio1 15 GPIO_ACTIVE_LOW>; /* GPIO[47] */ + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&ap_pinctl { + /* + * MPP Bus: + * eMMC [0-10] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 3 0 0 0 0 0 0 0 3 >; +}; + +/* on-board eMMC */ +&ap_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&ap_emmc_pins>; + bus-width = <8>; + status = "okay"; +}; + +&cpm_pinctl { + /* + * MPP Bus: + * [0-31] = 0xff: Keep default CP0_shared_pins: + * [11] CLKOUT_MPP_11 (out) + * [23] LINK_RD_IN_CP2CP (in) + * [25] CLKOUT_MPP_25 (out) + * [29] AVS_FB_IN_CP2CP (in) + * [32, 33, 34] pci0/1/2 reset + * [35-38] CP0 I2C1 and I2C0 + * [39] GPIO reset button + * [40,41] LED0 and LED1 + * [43] 1512 phy reset + * [47] USB VBUS EN (active low) + * [48] FAN PWM + * [49] SFP+ present signal + * [50] TPM interrupt + * [51] WLAN0 disable + * [52] WLAN1 disable + * [53] LTE disable + * [54] NFC reset + * [55] Micro SD card detect + * [56-61] Micro SD + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0 0 0 0 2 2 2 2 0 + 0 0 0 0 0 0 0 0 0 0 + 0 0 0 0 0 0 0xe 0xe 0xe 0xe + 0xe 0xe 0 >; + + cpm_xhci_vbus_pins: cpm-xhci-vbus-pins { + marvell,pins = < 47 >; + marvell,function = <0>; + }; + + cps_1g_phy_reset: cps-1g-phy-reset { + marvell,pins = < 43 >; + marvell,function = <0>; + }; +}; + +/* uSD slot */ +&cpm_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +&cpm_pcie0 { + num-lanes = <1>; + status = "okay"; +}; + +&cpm_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c1_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_sata0 { + status = "okay"; +}; + +&cpm_comphy { + /* + * CP0 Serdes Configuration: + * Lane 0: PCIe0 (x1) + * Lane 1: Not connected + * Lane 2: SFI (10G) + * Lane 3: Not connected + * Lane 4: USB 3.0 host port1 (can be PCIe) + * Lane 5: Not connected + */ + phy0 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy1 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy2 { + phy-type = <PHY_TYPE_SFI>; + }; + phy3 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy4 { + phy-type = <PHY_TYPE_USB3_HOST1>; + }; + phy5 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; +}; + +&cpm_ethernet { + pinctrl-names = "default"; + status = "okay"; +}; + +/* 10G SFI SFP */ +&cpm_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +&cps_sata0 { + status = "okay"; +}; + +&cps_usb3_0 { + vbus-supply = <®_usb3h0_vbus>; + status = "okay"; +}; + +&cps_utmi0 { + status = "okay"; +}; + +&cps_pinctl { + /* + * MPP Bus: + * [0-5] TDM + * [6] VHV Enable + * [7] CP1 SPI0 CSn1 (FXS) + * [8] CP1 SPI0 CSn0 (TPM) + * [9.11]CP1 SPI0 MOSI/MISO/CLK + * [13] CP1 SPI1 MISO (TDM and SPI ROM shared) + * [14] CP1 SPI1 CS0n (64Mb SPI ROM) + * [15] CP1 SPI1 MOSI (TDM and SPI ROM shared) + * [16] CP1 SPI1 CLK (TDM and SPI ROM shared) + * [24] Topaz switch reset + * [26] Buzzer + * [27] CP1 SMI MDIO + * [28] CP1 SMI MDC + * [29] CP0 10G SFP TX Disable + * [30] WPS button + * [31] Front panel button + * [32-62] = 0xff: Keep default CP1_shared_pins: + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x4 0x4 0x4 0x4 0x4 0x4 0x0 0x4 0x4 0x4 + 0x4 0x4 0x0 0x3 0x3 0x3 0x3 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0x0 0xff 0x0 0x8 0x8 0x0 + 0x0 0x0 0x0 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff>; +}; + +&cps_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cps_spi1_pins>; + status = "okay"; + + spi-flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <10000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "U-Boot"; + reg = <0 0x200000>; + }; + partition@200000 { + label = "Filesystem"; + reg = <0x200000 0xce0000>; + }; + }; + }; +}; + +&cps_comphy { + /* + * CP1 Serdes Configuration: + * Lane 0: SATA 1 (RX swapped). Can be PCIe0 + * Lane 1: Not used + * Lane 2: USB HOST 0 + * Lane 3: SGMII1 - Connected to 1512 port + * Lane 4: Not used + * Lane 5: SGMII2 - Connected to Topaz switch + */ + phy0 { + phy-type = <PHY_TYPE_SATA1>; + phy-invert = <PHY_POLARITY_RXD_INVERT>; + }; + phy1 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy2 { + phy-type = <PHY_TYPE_USB3_HOST0>; + }; + phy3 { + phy-type = <PHY_TYPE_SGMII1>; + phy-speed = <PHY_SPEED_1_25G>; + }; + phy4 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy5 { + phy-type = <PHY_TYPE_SGMII2>; + phy-speed = <PHY_SPEED_3_125G>; + }; +}; + +&cps_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +&cps_ethernet { + pinctrl-names = "default"; + pinctrl-0 = <&cps_1g_phy_reset>; + status = "okay"; +}; + +/* 1G SGMII */ +&cps_eth1 { + status = "okay"; + phy-mode = "sgmii"; + phy = <&phy0>; + phy-reset-gpios = <&cpm_gpio1 11 GPIO_ACTIVE_LOW>; +}; + +/* 2.5G to Topaz switch */ +&cps_eth2 { + status = "okay"; + phy-mode = "sgmii"; + phy-speed = <2500>; + phy-reset-gpios = <&cps_gpio0 24 GPIO_ACTIVE_LOW>; +};
Hi Baruch,
Is a dts file enough for a functional U-Boot port? Don't you need to reference it at least in some new defconfig file?
Thanks, Stefan
Hi Stefan,
Stefan Roese writes:
The defconfig is exactly the same as the Macchiatobin. So doing:
make mvebu_mcbin-88f8040_defconfig make DEVICE_TREE=armada-8040-clearfog-gt-8k
should do the trick. Do you think I should add another defconfig that only changes CONFIG_DEFAULT_DEVICE_TREE?
baruch
On 22.10.18 16:30, Baruch Siach wrote:
Hi Stefan,
From my experience, users look for existing U-Boot ports in the "configs" directory (in modern U-Boot). So yes, I think its clearer and more obvious that this board is supported (and how it can be built) by adding this new defconfig file.
Thanks, Stefan
- Copyright (C) 2018 SolidRun ltd
chosen {
aliases {
i2c0 = &cpm_i2c0;
i2c1 = &cpm_i2c1;
spi0 = &cps_spi1;
memory@00000000 {
simple-bus {
GPIO[47] */
+&uart0 {
status = "okay";
+&ap_pinctl {
* MPP Bus:
* eMMC [0-10]
* UART0 [11,19]
bus-width = <8>;
status = "okay";
+&cpm_pinctl {
* MPP Bus:
* [48] FAN PWM
* [53] LTE disable
* [54] NFC reset
* [56-61] Micro SD
0 0 0 0 0 0 0 0 0 0
0xe 0xe 0 >;
bus-width = <4>;
status = "okay";
+&cpm_pcie0 {
num-lanes = <1>;
status = "okay";
+&cpm_i2c0 {
status = "okay";
+&cpm_i2c1 {
status = "okay";
+&cpm_sata0 {
status = "okay";
+&cpm_comphy {
* Lane 2: SFI (10G)
phy0 {
phy1 {
phy2 {
phy3 {
phy4 {
phy5 {
+&cpm_ethernet {
status = "okay";
status = "okay";
phy-mode = "sfi";
+&cps_sata0 {
status = "okay";
+&cps_usb3_0 {
status = "okay";
+&cps_utmi0 {
status = "okay";
+&cps_pinctl {
* MPP Bus:
* [0-5] TDM
* [6] VHV Enable
* [26] Buzzer
* [27] CP1 SMI MDIO
* [28] CP1 SMI MDC
* [30] WPS button
0xff 0xff 0xff>;
+&cps_spi1 {
status = "okay";
spi-flash@0 {
Last time I looked u-boot needs this to include "spi-flash".
+ reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "U-Boot";
reg = <0 0x200000>;
partition@200000 {
+&cps_comphy {
* Lane 1: Not used
* Lane 4: Not used
phy0 {
phy1 {
phy2 {
phy3 {
phy4 {
phy5 {
+&cps_mdio {
reg = <0>;
+&cps_ethernet {
status = "okay";
status = "okay";
phy-mode = "sgmii";
phy = <&phy0>;
status = "okay";
phy-mode = "sgmii";
phy-speed = <2500>;
2.19.1
Hi Baruch,
On 22.10.18 21:59, Chris Packham wrote:
On Fri, 19 Oct 2018, 12:55 AM Baruch Siach, <baruch@tkos.co.il mailto:baruch@tkos.co.il> wrote:
From: Rabeeh Khoury <rabeeh@solid-run.com <mailto:rabeeh@solid-run.com>> The SolidRun Clearfog GT-8K is based on Armada 8040. https://wiki.solid-run.com/doku.php?id=products:a8040:clearfoggt8k Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com <mailto:rabeeh@solid-run.com>> Signed-off-by: Baruch Siach <baruch@tkos.co.il <mailto:baruch@tkos.co.il>> --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-8040-clearfog-gt-8k.dts | 315 ++++++++++++++++++++ 2 files changed, 316 insertions(+) create mode 100644 arch/arm/dts/armada-8040-clearfog-gt-8k.dts diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 44ebc50bfab1..c9a23ea68450 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -99,6 +99,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-7040-db-nand.dtb \ armada-8040-db.dtb \ armada-8040-mcbin.dtb \ + armada-8040-clearfog-gt-8k.dtb \ armada-xp-gp.dtb \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ diff --git a/arch/arm/dts/armada-8040-clearfog-gt-8k.dts b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts new file mode 100644 index 000000000000..015ef35b0d81 --- /dev/null +++ b/arch/arm/dts/armada-8040-clearfog-gt-8k.dts @@ -0,0 +1,315 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 SolidRun ltd + */ + +#include "armada-8040.dtsi" + +/ { + model = "ClearFog-GT-8K"; + compatible = "solidrun,armada8040-cf-gt-8k", + "marvell,armada8040"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + aliases { + i2c0 = &cpm_i2c0; + i2c1 = &cpm_i2c1; + spi0 = &cps_spi1; + }; + + memory@00000000 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + simple-bus { + compatible = "simple-bus"; + + reg_usb3h0_vbus: usb3-vbus0 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&cpm_xhci_vbus_pins>; + regulator-name = "reg-usb3h0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + startup-delay-us = <300000>; + shutdown-delay-us = <500000>; + regulator-force-boot-off; + gpio = <&cpm_gpio1 15 GPIO_ACTIVE_LOW>; /* GPIO[47] */ + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&ap_pinctl { + /* + * MPP Bus: + * eMMC [0-10] + * UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 1 1 1 1 1 1 1 1 1 1 + 1 3 0 0 0 0 0 0 0 3 >; +}; + +/* on-board eMMC */ +&ap_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&ap_emmc_pins>; + bus-width = <8>; + status = "okay"; +}; + +&cpm_pinctl { + /* + * MPP Bus: + * [0-31] = 0xff: Keep default CP0_shared_pins: + * [11] CLKOUT_MPP_11 (out) + * [23] LINK_RD_IN_CP2CP (in) + * [25] CLKOUT_MPP_25 (out) + * [29] AVS_FB_IN_CP2CP (in) + * [32, 33, 34] pci0/1/2 reset + * [35-38] CP0 I2C1 and I2C0 + * [39] GPIO reset button + * [40,41] LED0 and LED1 + * [43] 1512 phy reset + * [47] USB VBUS EN (active low) + * [48] FAN PWM + * [49] SFP+ present signal + * [50] TPM interrupt + * [51] WLAN0 disable + * [52] WLAN1 disable + * [53] LTE disable + * [54] NFC reset + * [55] Micro SD card detect + * [56-61] Micro SD + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0 0 0 0 2 2 2 2 0 + 0 0 0 0 0 0 0 0 0 0 + 0 0 0 0 0 0 0xe 0xe 0xe 0xe + 0xe 0xe 0 >; + + cpm_xhci_vbus_pins: cpm-xhci-vbus-pins { + marvell,pins = < 47 >; + marvell,function = <0>; + }; + + cps_1g_phy_reset: cps-1g-phy-reset { + marvell,pins = < 43 >; + marvell,function = <0>; + }; +}; + +/* uSD slot */ +&cpm_sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_sdhci_pins>; + bus-width = <4>; + status = "okay"; +}; + +&cpm_pcie0 { + num-lanes = <1>; + status = "okay"; +}; + +&cpm_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c0_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&cpm_i2c1_pins>; + status = "okay"; + clock-frequency = <100000>; +}; + +&cpm_sata0 { + status = "okay"; +}; + +&cpm_comphy { + /* + * CP0 Serdes Configuration: + * Lane 0: PCIe0 (x1) + * Lane 1: Not connected + * Lane 2: SFI (10G) + * Lane 3: Not connected + * Lane 4: USB 3.0 host port1 (can be PCIe) + * Lane 5: Not connected + */ + phy0 { + phy-type = <PHY_TYPE_PEX0>; + }; + phy1 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy2 { + phy-type = <PHY_TYPE_SFI>; + }; + phy3 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; + phy4 { + phy-type = <PHY_TYPE_USB3_HOST1>; + }; + phy5 { + phy-type = <PHY_TYPE_UNCONNECTED>; + }; +}; + +&cpm_ethernet { + pinctrl-names = "default"; + status = "okay"; +}; + +/* 10G SFI SFP */ +&cpm_eth0 { + status = "okay"; + phy-mode = "sfi"; +}; + +&cps_sata0 { + status = "okay"; +}; + +&cps_usb3_0 { + vbus-supply = <®_usb3h0_vbus>; + status = "okay"; +}; + +&cps_utmi0 { + status = "okay"; +}; + +&cps_pinctl { + /* + * MPP Bus: + * [0-5] TDM + * [6] VHV Enable + * [7] CP1 SPI0 CSn1 (FXS) + * [8] CP1 SPI0 CSn0 (TPM) + * [9.11]CP1 SPI0 MOSI/MISO/CLK + * [13] CP1 SPI1 MISO (TDM and SPI ROM shared) + * [14] CP1 SPI1 CS0n (64Mb SPI ROM) + * [15] CP1 SPI1 MOSI (TDM and SPI ROM shared) + * [16] CP1 SPI1 CLK (TDM and SPI ROM shared) + * [24] Topaz switch reset + * [26] Buzzer + * [27] CP1 SMI MDIO + * [28] CP1 SMI MDC + * [29] CP0 10G SFP TX Disable + * [30] WPS button + * [31] Front panel button + * [32-62] = 0xff: Keep default CP1_shared_pins: + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x4 0x4 0x4 0x4 0x4 0x4 0x0 0x4 0x4 0x4 + 0x4 0x4 0x0 0x3 0x3 0x3 0x3 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0x0 0xff 0x0 0x8 0x8 0x0 + 0x0 0x0 0x0 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff>; +}; + +&cps_spi1 { + pinctrl-names = "default"; + pinctrl-0 = <&cps_spi1_pins>; + status = "okay"; + + spi-flash@0 { + compatible = "jedec,spi-nor";
Yes, please add this in v2. And please merge / squash the defconfig file into this patch as well.
While at it, you might want to add "spi-flash" to other MVEBU / Armada boards where its still missing in some other patch. That would be helpful.
Thanks, Stefan
Baruch Siach
Chris Packham
Stefan Roese
