[U-Boot] [PATCH v5 0/3] pmic:pfuze support buck regulator mode switch
This patch set is to support buck regulator can working in different switching modes. To improve system efficiency the buck regulators can operate in different switching modes.
patch 1/3 is to add related bit definitions and registers. patch 2/3 is to implement the switching mode init function. patch 3/3 is to add related mode init function in board code.
mx6slevk board is not included in this patch set, since power and i2c interface are not implemented for it. These patches are at: https://patchwork.ozlabs.org/patch/426961/ https://patchwork.ozlabs.org/patch/426962/ https://patchwork.ozlabs.org/patch/426963/
Added "Acked-by: Przemyslaw Marczak p.marczak@samsung.com" in this patch set. Added "Reviewed-by: Stefano Babic sbabic@denx.de" for patch 1/3. There is no major changes for this patch version. Only defined a macro SWITCH_SIZE to replace the constant in patch 2/3.
Peng Fan (3): pmic:pfuz100 add switch mode and more registers pmic:pfuze implement pmic_mode_init imx:mx6 set normal APS and standby PFM mode
board/freescale/common/pfuze.c | 37 ++++++++++++++++++ board/freescale/common/pfuze.h | 1 + board/freescale/mx6qsabreauto/mx6qsabreauto.c | 6 +++ board/freescale/mx6sabresd/mx6sabresd.c | 6 ++- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 6 ++- include/power/pfuze100_pmic.h | 55 +++++++++++++++++++++++++++ 6 files changed, 109 insertions(+), 2 deletions(-)
Add more pfuze register offset. And switch mode definition. Add a macro SWITCH_SIZE
Signed-off-by: Peng Fan Peng.Fan@freescale.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com Reviewed-by: Stefano Babic sbabic@denx.de ---
Changes v5: add "Acked-by: Przemyslaw Marczak p.marczak@samsung.com" and "Reviewed-by: Stefano Babic sbabic@denx.de" define a SWITCH_SIZE macro to replace constant in patch 2/3
Changes v4: none
Changes v3: none
Changes v2: none
include/power/pfuze100_pmic.h | 55 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/include/power/pfuze100_pmic.h b/include/power/pfuze100_pmic.h index 1118489..41aa3c4 100644 --- a/include/power/pfuze100_pmic.h +++ b/include/power/pfuze100_pmic.h @@ -16,14 +16,34 @@ enum {
PFUZE100_SW1ABVOL = 0x20, PFUZE100_SW1ABSTBY = 0x21, + PFUZE100_SW1ABOFF = 0x22, + PFUZE100_SW1ABMODE = 0x23, PUZE_100_SW1ABCONF = 0x24, PFUZE100_SW1CVOL = 0x2e, PFUZE100_SW1CSTBY = 0x2f, + PFUZE100_SW1COFF = 0x30, + PFUZE100_SW1CMODE = 0x31, PFUZE100_SW1CCONF = 0x32, PFUZE100_SW2VOL = 0x35, + PFUZE100_SW2STBY = 0x36, + PFUZE100_SW2OFF = 0x37, + PFUZE100_SW2MODE = 0x38, + PFUZE100_SW2CONF = 0x39, PFUZE100_SW3AVOL = 0x3c, + PFUZE100_SW3ASTBY = 0x3D, + PFUZE100_SW3AOFF = 0x3E, + PFUZE100_SW3AMODE = 0x3F, + PFUZE100_SW3ACONF = 0x40, PFUZE100_SW3BVOL = 0x43, + PFUZE100_SW3BSTBY = 0x44, + PFUZE100_SW3BOFF = 0x45, + PFUZE100_SW3BMODE = 0x46, + PFUZE100_SW3BCONF = 0x47, PFUZE100_SW4VOL = 0x4a, + PFUZE100_SW4STBY = 0x4b, + PFUZE100_SW4OFF = 0x4c, + PFUZE100_SW4MODE = 0x4d, + PFUZE100_SW4CONF = 0x4e, PFUZE100_SWBSTCON1 = 0x66, PFUZE100_VREFDDRCON = 0x6a, PFUZE100_VSNVSVOL = 0x6b, @@ -177,5 +197,40 @@ enum { #define SWBST_MODE_AUTO (2 << 2) #define SWBST_MODE_APS (2 << 3)
+/* + * Regulator Mode Control + * + * OFF: The regulator is switched off and the output voltage is discharged. + * PFM: In this mode, the regulator is always in PFM mode, which is useful + * at light loads for optimized efficiency. + * PWM: In this mode, the regulator is always in PWM mode operation + * regardless of load conditions. + * APS: In this mode, the regulator moves automatically between pulse + * skipping mode and PWM mode depending on load conditions. + * + * SWxMODE[3:0] + * Normal Mode | Standby Mode | value + * OFF OFF 0x0 + * PWM OFF 0x1 + * PFM OFF 0x3 + * APS OFF 0x4 + * PWM PWM 0x5 + * PWM APS 0x6 + * APS APS 0x8 + * APS PFM 0xc + * PWM PFM 0xd + */ +#define OFF_OFF 0x0 +#define PWM_OFF 0x1 +#define PFM_OFF 0x3 +#define APS_OFF 0x4 +#define PWM_PWM 0x5 +#define PWM_APS 0x6 +#define APS_APS 0x8 +#define APS_PFM 0xc +#define PWM_PFM 0xd + +#define SWITCH_SIZE 0x7 + int power_pfuze100_init(unsigned char bus); #endif
Best regards, Stefano Babic
This patch is to implement pmic_mode_init function, and add prototype in header file.
This function is to set switching mode for pmic buck regulators to improve system efficiency.
Mode: OFF: The regulator is switched off and the output voltage is discharged. PFM: In this mode, the regulator is always in PFM mode, which is useful at light loads for optimized efficiency. PWM: In this mode, the regulator is always in PWM mode operation regardless of load conditions. APS: In this mode, the regulator moves automatically between pulse skipping mode and PWM mode depending on load conditions.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com ---
Changes v5: Add Acked-by: Przemyslaw Marczak p.marczak@samsung.com replace the constant 7 using macro SWITCH_SIZE which defined in header file. Include "errno.h" to avoid compile error.
Changes v4: Take Fabio's comments, fix return value using -EINVAL when error.
Changes v3: delete the new feature, it is fine to use the original v1 patch version
Changes v2: implement new feature to configure one regulator
board/freescale/common/pfuze.c | 38 ++++++++++++++++++++++++++++++++++++++ board/freescale/common/pfuze.h | 1 + 2 files changed, 39 insertions(+)
diff --git a/board/freescale/common/pfuze.c b/board/freescale/common/pfuze.c index 2cd1794..4980bf7 100644 --- a/board/freescale/common/pfuze.c +++ b/board/freescale/common/pfuze.c @@ -5,9 +5,47 @@ */
#include <common.h> +#include <errno.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h>
+int pfuze_mode_init(struct pmic *p, u32 mode) +{ + unsigned char offset, i, switch_num; + u32 id, ret; + + pmic_reg_read(p, PFUZE100_DEVICEID, &id); + id = id & 0xf; + + if (id == 0) { + switch_num = 6; + offset = PFUZE100_SW1CMODE; + } else if (id == 1) { + switch_num = 4; + offset = PFUZE100_SW2MODE; + } else { + printf("Not supported, id=%d\n", id); + return -EINVAL; + } + + ret = pmic_reg_write(p, PFUZE100_SW1ABMODE, mode); + if (ret < 0) { + printf("Set SW1AB mode error!\n"); + return ret; + } + + for (i = 0; i < switch_num - 1; i++) { + ret = pmic_reg_write(p, offset + i * SWITCH_SIZE, mode); + if (ret < 0) { + printf("Set switch 0x%x mode error!\n", + offset + i * SWITCH_SIZE); + return ret; + } + } + + return ret; +} + struct pmic *pfuze_common_init(unsigned char i2cbus) { struct pmic *p; diff --git a/board/freescale/common/pfuze.h b/board/freescale/common/pfuze.h index 7a4126c..53cfc99 100644 --- a/board/freescale/common/pfuze.h +++ b/board/freescale/common/pfuze.h @@ -8,5 +8,6 @@ #define __PFUZE_BOARD_HELPER__
struct pmic *pfuze_common_init(unsigned char i2cbus); +int pfuze_mode_init(struct pmic *p, u32 mode);
#endif
Hi, Stefano
I did not see this patch applied to u-boot-imx, I saw only patch 1/3 is applied. Do you miss this one?
Regards, Peng.
Hi Peng,
On 11/02/2015 02:59, Peng Fan wrote:
Hi, Stefano
I see. I have applied only patches that are assigned to me (in patchwork), in this case only Patch 1/3. Patch 2 and 3 were still assigned to Przemyslaw (but we have his ACK). I assign the patches to me and I will apply them.
However, something bad happened. No idea how it could happen, but applying patch1/3, the define for SWITCH_SIZE disappeared - see in file. I cannot find a valid reason for that. I fix it myself, and I start rebuilding to check breakage before pushing on the server.
To normal mode, use APS switching mode. To standy mode, use PFM switching mode.
Changes v4: none
Changes v3: Following Fabio's comments, correct return value
Changes v2: none
board/freescale/mx6qsabreauto/mx6qsabreauto.c | 6 ++++++ board/freescale/mx6sabresd/mx6sabresd.c | 6 +++++- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 6 +++++- 3 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index 59387ff..b12e74e 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -29,6 +29,7 @@ #include <asm/arch/crm_regs.h> #include <pca953x.h> #include <power/pmic.h> +#include <power/pfuze100_pmic.h> #include "../common/pfuze.h"
DECLARE_GLOBAL_DATA_PTR; @@ -515,11 +516,16 @@ int board_spi_cs_gpio(unsigned bus, unsigned cs) int power_init_board(void) { struct pmic *p; + unsigned int ret;
p = pfuze_common_init(I2C_PMIC); if (!p) return -ENODEV;
+ ret = pfuze_mode_init(p, APS_PFM); + if (ret < 0) + return ret; + return 0; }
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 2f7198d..bb2dd96 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -631,12 +631,16 @@ int board_init(void) int power_init_board(void) { struct pmic *p; - unsigned int reg; + unsigned int reg, ret;
+ ret = pfuze_mode_init(p, APS_PFM); + if (ret < 0) + return ret; + /* Increase VGEN3 from 2.5 to 2.8V */ pmic_reg_read(p, PFUZE100_VGEN3VOL, ®); reg &= ~LDO_VOL_MASK; diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index a2c9aae..2ff960e 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -199,12 +199,16 @@ static struct i2c_pads_info i2c_pad_info1 = { int power_init_board(void) { struct pmic *p; - unsigned int reg; + unsigned int reg, ret;
+ ret = pfuze_mode_init(p, APS_PFM); + if (ret < 0) + return ret; + /* Enable power of VGEN5 3V3, needed for SD3 */ pmic_reg_read(p, PFUZE100_VGEN5VOL, ®); reg &= ~LDO_VOL_MASK;
Hi, Stefano
Did you miss this patch? I also did not see this one applied.
Regards, Peng.
Peng Fan
Peng Fan
Stefano Babic
