Re: [U-Boot] AM335x Ethernet pin mux confusion
On Monday 24 November 2014 07:57 PM, Andy Pont wrote:
Hello,
I am working on porting U-Boot 2014.07 to a custom TI AM3354 based hardware platform and am confused trying to set the pin mux for the two Ethernet interfaces that are on the board.
RGMII1_ pins are connected to an ATHEROS AR8031 PHY (PHY ADDR 04) and the pins GPMC_A0 .. GPMC_A11 are connected to a Micrel KSZ8041NL (PHY ADDR 01). The output of the "mii info" command looks OK so the MDIO interface looks to be OK as it gives:
PHY 0x00: OUI = 0x0885, Model = 0x11, Rev = 0x03, 10baseT, HDX PHY 0x01: OUI = 0x0885, Model = 0x11, Rev = 0x03, 10baseT, HDX PHY 0x04: OUI = 0x1374, Model = 0x07, Rev = 0x04, 1000baseX, FDX
However, with debug enabled, it is reporting the PHYs incorrectly as it gives:
cpsw connected to Micrel KSZ804 cpsw connected to Micrel KSZ804 cpsw
The AR8031 provides a connection to the outside world and the KSZ8041 connects to an Ethernet switch which then connects on to other devices on the board to form a private network. The DHCP command just sits in a loop waiting for PHY auto negotiation to complete but timing out!
In the SPL code I am setting up the pin mux as follows:
static struct module_pin_mux rgmii1_pin_mux[] = { {OFFSET(mii1_txen), MODE(2)}, /* RGMII1_TCTL */ {OFFSET(mii1_rxdv), MODE(2) | RXACTIVE}, /* RGMII1_RCTL */ {OFFSET(mii1_txd3), MODE(2)}, /* RGMII1_TD3 */ {OFFSET(mii1_txd2), MODE(2)}, /* RGMII1_TD2 */ {OFFSET(mii1_txd1), MODE(2)}, /* RGMII1_TD1 */ {OFFSET(mii1_txd0), MODE(2)}, /* RGMII1_TD0 */ {OFFSET(mii1_txclk), MODE(2)}, /* RGMII1_TCLK */ {OFFSET(mii1_rxclk), MODE(2) | RXACTIVE}, /* RGMII1_RCLK */ {OFFSET(mii1_rxd3), MODE(2) | RXACTIVE}, /* RGMII1_RD3 */ {OFFSET(mii1_rxd2), MODE(2) | RXACTIVE}, /* RGMII1_RD2 */ {OFFSET(mii1_rxd1), MODE(2) | RXACTIVE}, /* RGMII1_RD1 */ {OFFSET(mii1_rxd0), MODE(2) | RXACTIVE}, /* RGMII1_RD0 */ {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ {-1}, };
static struct module_pin_mux rmii2_pin_mux[] = { {OFFSET(gpmc_a0), MODE(2)}, /* RMII2_TXEN */ {OFFSET(gpmc_a1), MODE(2) | RXACTIVE}, /* RMII2_RXDV */ {OFFSET(gpmc_a2), MODE(2)}, /* RMII2_TXD3 */ {OFFSET(gpmc_a3), MODE(2)}, /* RMII2_TXD2 */ {OFFSET(gpmc_a4), MODE(2)}, /* RMII2_TXD1 */ {OFFSET(gpmc_a5), MODE(2)}, /* RMII2_TXD0 */ {OFFSET(gpmc_a6), MODE(2)}, /* RMII2_TXCLK */ {OFFSET(gpmc_a7), MODE(2) | RXACTIVE}, /* RMII2_RXCLK */ {OFFSET(gpmc_a8), MODE(2) | RXACTIVE}, /* RMII2_RXD3 */ {OFFSET(gpmc_a9), MODE(2) | RXACTIVE}, /* RMII2_RXD2 */ {OFFSET(gpmc_a10), MODE(2) | RXACTIVE}, /* RMII2_RXD1 */ {OFFSET(gpmc_a11), MODE(2) | RXACTIVE}, /* RMII2_RXD0 */ {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ {-1}, };
Any help would be much appreciated?
There is no relation between pinmux and phy attached to the slave. Is your cpsw slave structures are populated with proper phy ids?
Regards Mugunthan V N
Hello Mugunthan,
Thanks for giving me the steer on this. I hadn't updated the slave structure. Having updated the slave structure it is now correctly detecting both PHYs and I can communicate with the network. :-)
Now to fix all the issues I am having with the Linux kernel...
Regards,
Andy.
Andy Pont
Mugunthan V N
