[U-Boot] [PATCH] mmc: support the correct card version for eMMC
eMMC vesrion is supported up to v4.5. But bootloader isn't saw the exact eMMC version. After applied this patch, if use the mmcinfo command, then can see the exactly mmc version.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- common/cmd_mmc.c | 2 +- drivers/mmc/mmc.c | 18 ++++++++++++++++++ include/mmc.h | 21 +++++++++++++-------- 3 files changed, 32 insertions(+), 9 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 7dacd51..9e8d293 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -106,7 +106,7 @@ static void print_mmcinfo(struct mmc *mmc) printf("Rd Block Len: %d\n", mmc->read_bl_len);
printf("%s version %d.%d\n", IS_SD(mmc) ? "SD" : "MMC", - (mmc->version >> 4) & 0xf, mmc->version & 0xf); + (mmc->version >> 8) & 0xf, mmc->version & 0xff);
printf("High Capacity: %s\n", mmc->high_capacity ? "Yes" : "No"); puts("Capacity: "); diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 72e8ce6..3b3317e 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1029,6 +1029,24 @@ static int mmc_startup(struct mmc *mmc) mmc->capacity = capacity; }
+ switch (ext_csd[EXT_CSD_REV]) { + case 1: + mmc->version = MMC_VERSION_4_1; + break; + case 2: + mmc->version = MMC_VERSION_4_2; + break; + case 3: + mmc->version = MMC_VERSION_4_3; + break; + case 5: + mmc->version = MMC_VERSION_4_41; + break; + case 6: + mmc->version = MMC_VERSION_4_5; + break; + } + /* * Check whether GROUP_DEF is set, if yes, read out * group size from ext_csd directly, or calculate diff --git a/include/mmc.h b/include/mmc.h index a13e2bd..d0ec744 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -30,16 +30,21 @@ #include <linux/compiler.h>
#define SD_VERSION_SD 0x20000 -#define SD_VERSION_2 (SD_VERSION_SD | 0x20) -#define SD_VERSION_1_0 (SD_VERSION_SD | 0x10) -#define SD_VERSION_1_10 (SD_VERSION_SD | 0x1a) +#define SD_VERSION_2 (SD_VERSION_SD | 0x200) +#define SD_VERSION_1_0 (SD_VERSION_SD | 0x100) +#define SD_VERSION_1_10 (SD_VERSION_SD | 0x10a) #define MMC_VERSION_MMC 0x10000 #define MMC_VERSION_UNKNOWN (MMC_VERSION_MMC) -#define MMC_VERSION_1_2 (MMC_VERSION_MMC | 0x12) -#define MMC_VERSION_1_4 (MMC_VERSION_MMC | 0x14) -#define MMC_VERSION_2_2 (MMC_VERSION_MMC | 0x22) -#define MMC_VERSION_3 (MMC_VERSION_MMC | 0x30) -#define MMC_VERSION_4 (MMC_VERSION_MMC | 0x40) +#define MMC_VERSION_1_2 (MMC_VERSION_MMC | 0x102) +#define MMC_VERSION_1_4 (MMC_VERSION_MMC | 0x104) +#define MMC_VERSION_2_2 (MMC_VERSION_MMC | 0x202) +#define MMC_VERSION_3 (MMC_VERSION_MMC | 0x300) +#define MMC_VERSION_4 (MMC_VERSION_MMC | 0x400) +#define MMC_VERSION_4_1 (MMC_VERSION_MMC | 0x401) +#define MMC_VERSION_4_2 (MMC_VERSION_MMC | 0x402) +#define MMC_VERSION_4_3 (MMC_VERSION_MMC | 0x403) +#define MMC_VERSION_4_41 (MMC_VERSION_MMC | 0x429) +#define MMC_VERSION_4_5 (MMC_VERSION_MMC | 0x405)
#define MMC_MODE_HS 0x001 #define MMC_MODE_HS_52MHz 0x010
Hi Rommel,
Could you review or test for this?
Best Regards, Jaehoon Chung
case 1:
break;
case 2:
break;
case 3:
break;
case 5:
break;
case 6:
break;
- Check whether GROUP_DEF is set, if yes, read out
- group size from ext_csd directly, or calculate
Dear Jaehoon,
On 2013.01/31, Jaehoon Chung wrote:
Hi Rommel,
Doesn't git am cleanly when "mmc: check the revision for sd3.0" is applied first. And "mmc: check the revision for sd3.0" doesn't git am cleanly if this patch is applied first. Maybe merging the two patches is better to avoid this chicken and egg problem.
Builds OK all by itself.
Acked-by: Rommel Custodio sessyargc@gmail.com
All the best, Rommel
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Acked-by: Rommel Custodio sessyargc@gmail.com
Applied to u-boot/master and tested on omap5_uevm (eMMC 4.45) and next gen beaglebone (am335x_evm, eMMC 4.41). Thanks!
Jaehoon Chung
Rommel Custodio
