[U-Boot] [PATCH] fdt: fix address cell count checking in fdt_translate_address()
Commit: dm: core: Enable optional use of fdt_translate_address()
Enables use of this function as default, but after this it's not possible to get dev address for the case in which: '#size-cells == 0'
This causes errors when getting address for some GPIOs, for which the '#size-cells' is set to 0.
Example error: '__of_translate_address: Bad cell count for gpx0'
Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', (called from )__of_translate_address(), fixes the issue.
Now, this macro doesn't check, that '#size-cells' is greater than 0.
This is possible from the specification point of view, but I'm not sure that it doesn't introduce a regression for other configs.
Please test and share the results.
Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Marek Vasut marex@denx.de --- common/fdt_support.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index f86365e..5f808cc 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const char *alias) /* Max address size we deal with */ #define OF_MAX_ADDR_CELLS 4 #define OF_BAD_ADDR ((u64)-1) -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= OF_MAX_ADDR_CELLS && \ - (ns) > 0) +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= OF_MAX_ADDR_CELLS)
/* Debug utility */ #ifdef DEBUG @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void *blob, int node_offset, const fdt32_t *in
/* Cound address cells & copy address locally */ bus->count_cells(blob, parent, &na, &ns); - if (!OF_CHECK_COUNTS(na, ns)) { + if (!OF_CHECK_COUNTS(na)) { printf("%s: Bad cell count for %s\n", __FUNCTION__, fdt_get_name(blob, node_offset, NULL)); goto bail; @@ -1142,7 +1141,7 @@ static u64 __of_translate_address(void *blob, int node_offset, const fdt32_t *in /* Get new parent bus and counts */ pbus = &of_busses[0]; pbus->count_cells(blob, parent, &pna, &pns); - if (!OF_CHECK_COUNTS(pna, pns)) { + if (!OF_CHECK_COUNTS(pna)) { printf("%s: Bad cell count for %s\n", __FUNCTION__, fdt_get_name(blob, node_offset, NULL)); break;
Hi, Przemyslaw.
I have also tested with exynos boards. As you mentioned, it seems that needs to test for other SoC.
Tested-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
(ns) > 0)
- if (!OF_CHECK_COUNTS(na)) { printf("%s: Bad cell count for %s\n", __FUNCTION__, fdt_get_name(blob, node_offset, NULL)); goto bail;
Hi Jaehoon,
Hi, Przemyslaw.
(ns) > 0)
+#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= OF_MAX_ADDR_CELLS) /* Debug utility */ #ifdef DEBUG @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void *blob, int node_offset, const fdt32_t *in /* Cound address cells & copy address locally */ bus->count_cells(blob, parent, &na, &ns);
Tested-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Exynos 4210 - Trats board.
Hi Stefan,
(ns) > 0)
This seems to conflict with the comment at the top of this function:
* Note: We consider that crossing any level with #size-cells == 0 to mean * that translation is impossible (that is we are not dealing with a value * that can be mapped to a cpu physical address). This is not really specified * that way, but this is traditionally the way IBM at least do things
What should we do here?
-- 1.9.1
Hello All,
On 10/29/2015 06:15 PM, Simon Glass wrote:
Hi Stefan,
(ns) > 0)
- Note: We consider that crossing any level with #size-cells == 0 to mean
- that translation is impossible (that is we are not dealing with a value
- that can be mapped to a cpu physical address). This is not really specified
- that way, but this is traditionally the way IBM at least do things
Is that commit acceptable? I would like send V2 with removing the above comment.
On 3 November 2015 at 02:57, Przemyslaw Marczak p.marczak@samsung.com wrote:
Hello All,
Hi Stefan,
(ns) > 0)
mean
value
specified
That's what I am worried about. Presumably the comment is accurate today and this check has some value. I was hoping Stefan might know.
Przemyslaw Marczak Samsung R&D Institute Poland Samsung Electronics p.marczak@samsung.com
__FUNCTION__, fdt_get_name(blob, node_offset, NULL)); break; -- 1.9.1
Hello All,
Hi Stefan,
(ns) > 0)
mean
value
specified
Unfortunately no. I just stumbled over this problem with the translation of the "complex" ranges on the MVEBU platform. And noticed that we already have this functionality to translate the addresses the "right way".
I'm wondering how this problem with those GPIOs is handled in the kernel? I assume that it is working correctly there, right? Przemyslaw, could you perhaps check this and see, why its working there? And change / fix it in U-Boot accordingly?
Thanks, Stefan
Hi Przemyslaw,
Hello All,
Hi Stefan,
(ns) > 0)
mean
value
specified
Let's pick up this patch for now as a bug-fix. We can deal with this problem after the release.
+Stephen
On 4 January 2016 at 17:59, Simon Glass sjg@chromium.org wrote:
Hi Przemyslaw,
Hello All,
Hi Stefan,
(ns) > 0)
mean
value
specified
Applied to u-boot-dm/master.
I'll post a revert after the release. It seems like you and Stephen are making good progress.
- Simon
Hello Simon,
On 01/07/2016 08:24 PM, Simon Glass wrote:
+Stephen
Hi Przemyslaw,
Hello All,
Hi Stefan,
On 28 October 2015 at 08:37, Przemyslaw Marczak p.marczak@samsung.com wrote: > > > Commit: dm: core: Enable optional use of fdt_translate_address() > > Enables use of this function as default, but after this it's not > possible to get dev address for the case in which: '#size-cells == 0' > > This causes errors when getting address for some GPIOs, for which > the '#size-cells' is set to 0. > > Example error: > '__of_translate_address: Bad cell count for gpx0' > > Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', > (called from )__of_translate_address(), fixes the issue. > > Now, this macro doesn't check, that '#size-cells' is greater than 0. > > This is possible from the specification point of view, but I'm not sure > that it doesn't introduce a regression for other configs. > > Please test and share the results. > > Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox. > > Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com > Cc: Masahiro Yamada yamada.masahiro@socionext.com > Cc: Lukasz Majewski l.majewski@samsung.com > Cc: Jaehoon Chung jh80.chung@samsung.com > Cc: Stefan Roese sr@denx.de > Cc: Simon Glass sjg@chromium.org > Cc: Bin Meng bmeng.cn@gmail.com > Cc: Marek Vasut marex@denx.de > --- > common/fdt_support.c | 7 +++---- > 1 file changed, 3 insertions(+), 4 deletions(-) > > diff --git a/common/fdt_support.c b/common/fdt_support.c > index f86365e..5f808cc 100644 > --- a/common/fdt_support.c > +++ b/common/fdt_support.c > @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const char > *alias) > /* Max address size we deal with */ > #define OF_MAX_ADDR_CELLS 4 > #define OF_BAD_ADDR ((u64)-1) > -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= > OF_MAX_ADDR_CELLS && \ > - (ns) > 0) > +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= OF_MAX_ADDR_CELLS) > > /* Debug utility */ > #ifdef DEBUG > @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void *blob, int > node_offset, const fdt32_t *in > > /* Cound address cells & copy address locally */ > bus->count_cells(blob, parent, &na, &ns); > - if (!OF_CHECK_COUNTS(na, ns)) { > + if (!OF_CHECK_COUNTS(na)) {
- Simon
Why so fast with this one?
I think, that more proper for a temporary fix is my latest patch with #size-cells count checking only if ranges found in the parent node.
I will continue the discussion with Stephen.
Hi Przemyslaw,
On 8 January 2016 at 05:01, Przemyslaw Marczak p.marczak@samsung.com wrote:
Hello Simon,
+Stephen
Hi Przemyslaw,
Hello All,
On 10/29/2015 06:15 PM, Simon Glass wrote: > > > > Hi Stefan, > > On 28 October 2015 at 08:37, Przemyslaw Marczak > p.marczak@samsung.com > wrote: >> >> >> >> Commit: dm: core: Enable optional use of fdt_translate_address() >> >> Enables use of this function as default, but after this it's not >> possible to get dev address for the case in which: '#size-cells == >> 0' >> >> This causes errors when getting address for some GPIOs, for which >> the '#size-cells' is set to 0. >> >> Example error: >> '__of_translate_address: Bad cell count for gpx0' >> >> Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', >> (called from )__of_translate_address(), fixes the issue. >> >> Now, this macro doesn't check, that '#size-cells' is greater than 0. >> >> This is possible from the specification point of view, but I'm not >> sure >> that it doesn't introduce a regression for other configs. >> >> Please test and share the results. >> >> Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox. >> >> Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com >> Cc: Masahiro Yamada yamada.masahiro@socionext.com >> Cc: Lukasz Majewski l.majewski@samsung.com >> Cc: Jaehoon Chung jh80.chung@samsung.com >> Cc: Stefan Roese sr@denx.de >> Cc: Simon Glass sjg@chromium.org >> Cc: Bin Meng bmeng.cn@gmail.com >> Cc: Marek Vasut marex@denx.de >> --- >> common/fdt_support.c | 7 +++---- >> 1 file changed, 3 insertions(+), 4 deletions(-) >> >> diff --git a/common/fdt_support.c b/common/fdt_support.c >> index f86365e..5f808cc 100644 >> --- a/common/fdt_support.c >> +++ b/common/fdt_support.c >> @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const >> char >> *alias) >> /* Max address size we deal with */ >> #define OF_MAX_ADDR_CELLS 4 >> #define OF_BAD_ADDR ((u64)-1) >> -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= >> OF_MAX_ADDR_CELLS && \ >> - (ns) > 0) >> +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= >> OF_MAX_ADDR_CELLS) >> >> /* Debug utility */ >> #ifdef DEBUG >> @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void *blob, >> int >> node_offset, const fdt32_t *in >> >> /* Cound address cells & copy address locally */ >> bus->count_cells(blob, parent, &na, &ns); >> - if (!OF_CHECK_COUNTS(na, ns)) { >> + if (!OF_CHECK_COUNTS(na)) { > > > > > This seems to conflict with the comment at the top of this function: > > * Note: We consider that crossing any level with #size-cells == 0 > to > mean > * that translation is impossible (that is we are not dealing with > a > value > * that can be mapped to a cpu physical address). This is not > really > specified > * that way, but this is traditionally the way IBM at least do > things > > What should we do here? >
- Simon
The release is scheduled for today, so we had to do something to fix the breakage.
Once you have a full solution figured out we can revert this patch and apply what you come up with.
Hello Simon,
On 01/11/2016 05:59 PM, Simon Glass wrote:
Hi Przemyslaw,
Hello Simon,
+Stephen
Hi Przemyslaw,
On 3 November 2015 at 02:57, Przemyslaw Marczak p.marczak@samsung.com wrote: > > > Hello All, > > > On 10/29/2015 06:15 PM, Simon Glass wrote: >> >> >> >> Hi Stefan, >> >> On 28 October 2015 at 08:37, Przemyslaw Marczak >> p.marczak@samsung.com >> wrote: >>> >>> >>> >>> Commit: dm: core: Enable optional use of fdt_translate_address() >>> >>> Enables use of this function as default, but after this it's not >>> possible to get dev address for the case in which: '#size-cells == >>> 0' >>> >>> This causes errors when getting address for some GPIOs, for which >>> the '#size-cells' is set to 0. >>> >>> Example error: >>> '__of_translate_address: Bad cell count for gpx0' >>> >>> Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', >>> (called from )__of_translate_address(), fixes the issue. >>> >>> Now, this macro doesn't check, that '#size-cells' is greater than 0. >>> >>> This is possible from the specification point of view, but I'm not >>> sure >>> that it doesn't introduce a regression for other configs. >>> >>> Please test and share the results. >>> >>> Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox. >>> >>> Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com >>> Cc: Masahiro Yamada yamada.masahiro@socionext.com >>> Cc: Lukasz Majewski l.majewski@samsung.com >>> Cc: Jaehoon Chung jh80.chung@samsung.com >>> Cc: Stefan Roese sr@denx.de >>> Cc: Simon Glass sjg@chromium.org >>> Cc: Bin Meng bmeng.cn@gmail.com >>> Cc: Marek Vasut marex@denx.de >>> --- >>> common/fdt_support.c | 7 +++---- >>> 1 file changed, 3 insertions(+), 4 deletions(-) >>> >>> diff --git a/common/fdt_support.c b/common/fdt_support.c >>> index f86365e..5f808cc 100644 >>> --- a/common/fdt_support.c >>> +++ b/common/fdt_support.c >>> @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const >>> char >>> *alias) >>> /* Max address size we deal with */ >>> #define OF_MAX_ADDR_CELLS 4 >>> #define OF_BAD_ADDR ((u64)-1) >>> -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= >>> OF_MAX_ADDR_CELLS && \ >>> - (ns) > 0) >>> +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= >>> OF_MAX_ADDR_CELLS) >>> >>> /* Debug utility */ >>> #ifdef DEBUG >>> @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void *blob, >>> int >>> node_offset, const fdt32_t *in >>> >>> /* Cound address cells & copy address locally */ >>> bus->count_cells(blob, parent, &na, &ns); >>> - if (!OF_CHECK_COUNTS(na, ns)) { >>> + if (!OF_CHECK_COUNTS(na)) { >> >> >> >> >> This seems to conflict with the comment at the top of this function: >> >> * Note: We consider that crossing any level with #size-cells == 0 >> to >> mean >> * that translation is impossible (that is we are not dealing with >> a >> value >> * that can be mapped to a cpu physical address). This is not >> really >> specified >> * that way, but this is traditionally the way IBM at least do >> things >> >> What should we do here? >> > > Is that commit acceptable? I would like send V2 with removing the > above > comment.
- Simon
Ok. It's hard to convince Stephen to accept such change, so I will send a patch with another solution - just bring back fdtdec_get_addr() for Exynos GPIO driver. And will revert this one within the patchset.
Hi Przemyslaw,
On 12 January 2016 at 03:49, Przemyslaw Marczak p.marczak@samsung.com wrote:
Hello Simon,
Hi Przemyslaw,
Hello Simon,
+Stephen
Hi Przemyslaw,
On 06.11.2015 04:16, Simon Glass wrote: > > > > Hi, > > On 3 November 2015 at 02:57, Przemyslaw Marczak > p.marczak@samsung.com > wrote: >> >> >> >> Hello All, >> >> >> On 10/29/2015 06:15 PM, Simon Glass wrote: >>> >>> >>> >>> >>> Hi Stefan, >>> >>> On 28 October 2015 at 08:37, Przemyslaw Marczak >>> p.marczak@samsung.com >>> wrote: >>>> >>>> >>>> >>>> >>>> Commit: dm: core: Enable optional use of fdt_translate_address() >>>> >>>> Enables use of this function as default, but after this it's not >>>> possible to get dev address for the case in which: '#size-cells == >>>> 0' >>>> >>>> This causes errors when getting address for some GPIOs, for which >>>> the '#size-cells' is set to 0. >>>> >>>> Example error: >>>> '__of_translate_address: Bad cell count for gpx0' >>>> >>>> Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', >>>> (called from )__of_translate_address(), fixes the issue. >>>> >>>> Now, this macro doesn't check, that '#size-cells' is greater than >>>> 0. >>>> >>>> This is possible from the specification point of view, but I'm not >>>> sure >>>> that it doesn't introduce a regression for other configs. >>>> >>>> Please test and share the results. >>>> >>>> Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox. >>>> >>>> Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com >>>> Cc: Masahiro Yamada yamada.masahiro@socionext.com >>>> Cc: Lukasz Majewski l.majewski@samsung.com >>>> Cc: Jaehoon Chung jh80.chung@samsung.com >>>> Cc: Stefan Roese sr@denx.de >>>> Cc: Simon Glass sjg@chromium.org >>>> Cc: Bin Meng bmeng.cn@gmail.com >>>> Cc: Marek Vasut marex@denx.de >>>> --- >>>> common/fdt_support.c | 7 +++---- >>>> 1 file changed, 3 insertions(+), 4 deletions(-) >>>> >>>> diff --git a/common/fdt_support.c b/common/fdt_support.c >>>> index f86365e..5f808cc 100644 >>>> --- a/common/fdt_support.c >>>> +++ b/common/fdt_support.c >>>> @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const >>>> char >>>> *alias) >>>> /* Max address size we deal with */ >>>> #define OF_MAX_ADDR_CELLS 4 >>>> #define OF_BAD_ADDR ((u64)-1) >>>> -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= >>>> OF_MAX_ADDR_CELLS && \ >>>> - (ns) > 0) >>>> +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= >>>> OF_MAX_ADDR_CELLS) >>>> >>>> /* Debug utility */ >>>> #ifdef DEBUG >>>> @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void >>>> *blob, >>>> int >>>> node_offset, const fdt32_t *in >>>> >>>> /* Cound address cells & copy address locally */ >>>> bus->count_cells(blob, parent, &na, &ns); >>>> - if (!OF_CHECK_COUNTS(na, ns)) { >>>> + if (!OF_CHECK_COUNTS(na)) { >>> >>> >>> >>> >>> >>> This seems to conflict with the comment at the top of this >>> function: >>> >>> * Note: We consider that crossing any level with #size-cells >>> == 0 >>> to >>> mean >>> * that translation is impossible (that is we are not dealing >>> with >>> a >>> value >>> * that can be mapped to a cpu physical address). This is not >>> really >>> specified >>> * that way, but this is traditionally the way IBM at least do >>> things >>> >>> What should we do here? >>> >> >> Is that commit acceptable? I would like send V2 with removing the >> above >> comment. > > > > > That's what I am worried about. Presumably the comment is accurate > today and this check has some value. I was hoping Stefan might know.
- Simon
Please hold off on that. I'll accept your other patch but let's see if Stephen wants to write something first. Using fdtdec_get_addr() doesn't make sense although I fully understand your frustration. Let's give it a week.
Hello Simon,
On 01/12/2016 02:59 PM, Simon Glass wrote:
Hi Przemyslaw,
Hello Simon,
Hi Przemyslaw,
Hello Simon,
+Stephen
Hi Przemyslaw,
On 5 November 2015 at 23:47, Stefan Roese sr@denx.de wrote: > > > On 06.11.2015 04:16, Simon Glass wrote: >> >> >> >> Hi, >> >> On 3 November 2015 at 02:57, Przemyslaw Marczak >> p.marczak@samsung.com >> wrote: >>> >>> >>> >>> Hello All, >>> >>> >>> On 10/29/2015 06:15 PM, Simon Glass wrote: >>>> >>>> >>>> >>>> >>>> Hi Stefan, >>>> >>>> On 28 October 2015 at 08:37, Przemyslaw Marczak >>>> p.marczak@samsung.com >>>> wrote: >>>>> >>>>> >>>>> >>>>> >>>>> Commit: dm: core: Enable optional use of fdt_translate_address() >>>>> >>>>> Enables use of this function as default, but after this it's not >>>>> possible to get dev address for the case in which: '#size-cells == >>>>> 0' >>>>> >>>>> This causes errors when getting address for some GPIOs, for which >>>>> the '#size-cells' is set to 0. >>>>> >>>>> Example error: >>>>> '__of_translate_address: Bad cell count for gpx0' >>>>> >>>>> Allowing for that case by modifying the macro 'OF_CHECK_COUNTS', >>>>> (called from )__of_translate_address(), fixes the issue. >>>>> >>>>> Now, this macro doesn't check, that '#size-cells' is greater than >>>>> 0. >>>>> >>>>> This is possible from the specification point of view, but I'm not >>>>> sure >>>>> that it doesn't introduce a regression for other configs. >>>>> >>>>> Please test and share the results. >>>>> >>>>> Tested-on: Odroid U3, Odroid X2, Odroid XU3, Sandbox. >>>>> >>>>> Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com >>>>> Cc: Masahiro Yamada yamada.masahiro@socionext.com >>>>> Cc: Lukasz Majewski l.majewski@samsung.com >>>>> Cc: Jaehoon Chung jh80.chung@samsung.com >>>>> Cc: Stefan Roese sr@denx.de >>>>> Cc: Simon Glass sjg@chromium.org >>>>> Cc: Bin Meng bmeng.cn@gmail.com >>>>> Cc: Marek Vasut marex@denx.de >>>>> --- >>>>> common/fdt_support.c | 7 +++---- >>>>> 1 file changed, 3 insertions(+), 4 deletions(-) >>>>> >>>>> diff --git a/common/fdt_support.c b/common/fdt_support.c >>>>> index f86365e..5f808cc 100644 >>>>> --- a/common/fdt_support.c >>>>> +++ b/common/fdt_support.c >>>>> @@ -946,8 +946,7 @@ void fdt_del_node_and_alias(void *blob, const >>>>> char >>>>> *alias) >>>>> /* Max address size we deal with */ >>>>> #define OF_MAX_ADDR_CELLS 4 >>>>> #define OF_BAD_ADDR ((u64)-1) >>>>> -#define OF_CHECK_COUNTS(na, ns) ((na) > 0 && (na) <= >>>>> OF_MAX_ADDR_CELLS && \ >>>>> - (ns) > 0) >>>>> +#define OF_CHECK_COUNTS(na) ((na) > 0 && (na) <= >>>>> OF_MAX_ADDR_CELLS) >>>>> >>>>> /* Debug utility */ >>>>> #ifdef DEBUG >>>>> @@ -1115,7 +1114,7 @@ static u64 __of_translate_address(void >>>>> *blob, >>>>> int >>>>> node_offset, const fdt32_t *in >>>>> >>>>> /* Cound address cells & copy address locally */ >>>>> bus->count_cells(blob, parent, &na, &ns); >>>>> - if (!OF_CHECK_COUNTS(na, ns)) { >>>>> + if (!OF_CHECK_COUNTS(na)) { >>>> >>>> >>>> >>>> >>>> >>>> This seems to conflict with the comment at the top of this >>>> function: >>>> >>>> * Note: We consider that crossing any level with #size-cells >>>> == 0 >>>> to >>>> mean >>>> * that translation is impossible (that is we are not dealing >>>> with >>>> a >>>> value >>>> * that can be mapped to a cpu physical address). This is not >>>> really >>>> specified >>>> * that way, but this is traditionally the way IBM at least do >>>> things >>>> >>>> What should we do here? >>>> >>> >>> Is that commit acceptable? I would like send V2 with removing the >>> above >>> comment. >> >> >> >> >> That's what I am worried about. Presumably the comment is accurate >> today and this check has some value. I was hoping Stefan might know. > > > > > Unfortunately no. I just stumbled over this problem with the > translation of the "complex" ranges on the MVEBU platform. And > noticed that we already have this functionality to translate > the addresses the "right way". > > I'm wondering how this problem with those GPIOs is handled in > the kernel? I assume that it is working correctly there, right? > Przemyslaw, could you perhaps check this and see, why its > working there? And change / fix it in U-Boot accordingly?
- Simon
Ah, too late:)
I have prepared patch, it's simple and doesn't touch the code - only device-tree. And this would be a proper approach, according to Stephen's comments.
participants (5)
Jaehoon Chung
Lukasz Majewski
Przemyslaw Marczak
Stefan Roese
