[PATCH] xilinx: Remove the legacy property "#stream-id-cells"
"#stream-id-cells" was being used with "mmu-masters" for Xen specific device trees. With Xen commit 2278d2cbb0b7c1b48b298c6c4c6a7de2271ac928 (Link below) Xen is able to support smmu bindings in both formats ie : 1. Using iommus (linux format) 2. Using mmu-masters (legacy format).
Thus, "#stream-id-cells" which was used for the legacy format, can be removed as Xen can use smmu bindings in linux format.
Link: https://www.mail-archive.com/xen-devel@lists.xenproject.org/msg101649.html Signed-off-by: Ayan Kumar Halder ayankuma@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/versal-mini-emmc0.dts | 1 - arch/arm/dts/versal-mini-emmc1.dts | 1 - arch/arm/dts/zynqmp.dtsi | 28 ---------------------------- 3 files changed, 30 deletions(-)
diff --git a/arch/arm/dts/versal-mini-emmc0.dts b/arch/arm/dts/versal-mini-emmc0.dts index 6a6e7467a233..7c81a82fb92d 100644 --- a/arch/arm/dts/versal-mini-emmc0.dts +++ b/arch/arm/dts/versal-mini-emmc0.dts @@ -47,7 +47,6 @@ xlnx,device_id = <0>; no-1-8-v; xlnx,mio-bank = <0>; - #stream-id-cells = <1>; }; };
diff --git a/arch/arm/dts/versal-mini-emmc1.dts b/arch/arm/dts/versal-mini-emmc1.dts index c342e6bdf7ad..bf7569d4cca4 100644 --- a/arch/arm/dts/versal-mini-emmc1.dts +++ b/arch/arm/dts/versal-mini-emmc1.dts @@ -47,7 +47,6 @@ xlnx,device_id = <1>; no-1-8-v; xlnx,mio-bank = <0>; - #stream-id-cells = <1>; }; };
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index dae8f0669df8..fbc6e752da93 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -281,7 +281,6 @@ interrupts = <0 124 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14e8>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -295,7 +294,6 @@ interrupts = <0 125 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14e9>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -309,7 +307,6 @@ interrupts = <0 126 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14ea>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -323,7 +320,6 @@ interrupts = <0 127 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14eb>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -337,7 +333,6 @@ interrupts = <0 128 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14ec>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -351,7 +346,6 @@ interrupts = <0 129 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14ed>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -365,7 +359,6 @@ interrupts = <0 130 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14ee>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -379,7 +372,6 @@ interrupts = <0 131 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <128>; - #stream-id-cells = <1>; iommus = <&smmu 0x14ef>; power-domains = <&zynqmp_firmware PD_GDMA>; #dma-cells = <1>; @@ -420,7 +412,6 @@ interrupts = <0 77 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x868>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -434,7 +425,6 @@ interrupts = <0 78 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x869>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -448,7 +438,6 @@ interrupts = <0 79 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86a>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -462,7 +451,6 @@ interrupts = <0 80 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86b>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -476,7 +464,6 @@ interrupts = <0 81 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86c>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -490,7 +477,6 @@ interrupts = <0 82 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86d>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -504,7 +490,6 @@ interrupts = <0 83 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86e>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -518,7 +503,6 @@ interrupts = <0 84 4>; clock-names = "clk_main", "clk_apb"; xlnx,bus-width = <64>; - #stream-id-cells = <1>; iommus = <&smmu 0x86f>; power-domains = <&zynqmp_firmware PD_ADMA>; #dma-cells = <1>; @@ -540,7 +524,6 @@ interrupts = <0 14 4>; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x872>; power-domains = <&zynqmp_firmware PD_NAND>; }; @@ -554,7 +537,6 @@ clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk"; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x874>; power-domains = <&zynqmp_firmware PD_ETH_0>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM0>; @@ -569,7 +551,6 @@ clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk"; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x875>; power-domains = <&zynqmp_firmware PD_ETH_1>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM1>; @@ -584,7 +565,6 @@ clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk"; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x876>; power-domains = <&zynqmp_firmware PD_ETH_2>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM2>; @@ -599,7 +579,6 @@ clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk"; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x877>; power-domains = <&zynqmp_firmware PD_ETH_3>; resets = <&zynqmp_reset ZYNQMP_RESET_GEM3>; @@ -676,7 +655,6 @@ <0x0 0x0 0x0 0x2 &pcie_intc 0x2>, <0x0 0x0 0x0 0x3 &pcie_intc 0x3>, <0x0 0x0 0x0 0x4 &pcie_intc 0x4>; - #stream-id-cells = <1>; iommus = <&smmu 0x4d0>; power-domains = <&zynqmp_firmware PD_PCIE>; pcie_intc: legacy-interrupt-controller { @@ -698,7 +676,6 @@ <0x0 0xc0000000 0x0 0x8000000>; #address-cells = <1>; #size-cells = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x873>; power-domains = <&zynqmp_firmware PD_QSPI>; }; @@ -730,7 +707,6 @@ interrupts = <0 133 4>; power-domains = <&zynqmp_firmware PD_SATA>; resets = <&zynqmp_reset ZYNQMP_RESET_SATA>; - #stream-id-cells = <4>; iommus = <&smmu 0x4c0>, <&smmu 0x4c1>, <&smmu 0x4c2>, <&smmu 0x4c3>; /* dma-coherent; */ @@ -745,7 +721,6 @@ reg = <0x0 0xff160000 0x0 0x1000>; clock-names = "clk_xin", "clk_ahb"; xlnx,device_id = <0>; - #stream-id-cells = <1>; iommus = <&smmu 0x870>; #clock-cells = <1>; clock-output-names = "clk_out_sd0", "clk_in_sd0"; @@ -762,7 +737,6 @@ reg = <0x0 0xff170000 0x0 0x1000>; clock-names = "clk_xin", "clk_ahb"; xlnx,device_id = <1>; - #stream-id-cells = <1>; iommus = <&smmu 0x871>; #clock-cells = <1>; clock-output-names = "clk_out_sd1", "clk_in_sd1"; @@ -892,7 +866,6 @@ interrupt-parent = <&gic>; interrupt-names = "dwc_usb3", "otg", "hiber"; interrupts = <0 65 4>, <0 69 4>, <0 75 4>; - #stream-id-cells = <1>; iommus = <&smmu 0x860>; snps,quirk-frame-length-adjustment = <0x20>; snps,refclk_fladj; @@ -924,7 +897,6 @@ interrupt-parent = <&gic>; interrupt-names = "dwc_usb3", "otg", "hiber"; interrupts = <0 70 4>, <0 74 4>, <0 76 4>; - #stream-id-cells = <1>; iommus = <&smmu 0x861>; snps,quirk-frame-length-adjustment = <0x20>; snps,refclk_fladj;
- Using iommus (linux format)
- Using mmu-masters (legacy format).
}; };#stream-id-cells = <1>;
};#stream-id-cells = <1>; iommus = <&smmu 0x872>; power-domains = <&zynqmp_firmware PD_NAND>;
};#stream-id-cells = <1>; iommus = <&smmu 0x873>; power-domains = <&zynqmp_firmware PD_QSPI>;
Applied. M
Michal Simek
