[U-Boot] [PATCH] arm, arm-kirkwood: disable l2c before linux boot
The decompressor expects the L2 cache to be disabled. This fixes booting some kernels, which have CONFIG_ARM_PATCH_PHYS_VIRT enabled.
Signed-off-by: Michael Walle michael@walle.cc Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com --- arch/arm/cpu/arm926ejs/cache.c | 15 +++++++++++ arch/arm/cpu/arm926ejs/cpu.c | 2 + arch/arm/cpu/arm926ejs/kirkwood/Makefile | 1 + arch/arm/cpu/arm926ejs/kirkwood/cache.c | 41 ++++++++++++++++++++++++++++++ 4 files changed, 59 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/kirkwood/cache.c
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 4415642..7a7d0a6 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -73,3 +73,18 @@ void flush_cache(unsigned long start, unsigned long size) { } #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */ + +/* + * Stub implementations for l2 cache operations + */ +void __l2_cache_enable(void) +{ +} +void l2_cache_enable(void) + __attribute__((weak, alias("__l2_cache_enable"))); + +void __l2_cache_disable(void) +{ +} +void l2_cache_disable(void) + __attribute__((weak, alias("__l2_cache_disable"))); diff --git a/arch/arm/cpu/arm926ejs/cpu.c b/arch/arm/cpu/arm926ejs/cpu.c index 5c902df..626384c 100644 --- a/arch/arm/cpu/arm926ejs/cpu.c +++ b/arch/arm/cpu/arm926ejs/cpu.c @@ -50,6 +50,8 @@ int cleanup_before_linux (void) /* turn off I/D-cache */ icache_disable(); dcache_disable(); + l2_cache_disable(); + /* flush I/D-cache */ cache_flush();
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/Makefile b/arch/arm/cpu/arm926ejs/kirkwood/Makefile index 0754297..777006c 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/Makefile +++ b/arch/arm/cpu/arm926ejs/kirkwood/Makefile @@ -30,6 +30,7 @@ COBJS-y = cpu.o COBJS-y += dram.o COBJS-y += mpp.o COBJS-y += timer.o +COBJS-y += cache.o
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cache.c b/arch/arm/cpu/arm926ejs/kirkwood/cache.c new file mode 100644 index 0000000..84207f7 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/kirkwood/cache.c @@ -0,0 +1,41 @@ +/* + * Copyright (c) 2011 Michael Walle + * Michael Walle michael@walle.cc + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +#include <common.h> +#include <asm/arch/cpu.h> + +void l2_cache_enable() +{ + u32 ctrl; + + ctrl = readfr_extra_feature_reg(); + ctrl |= 1 << 22; /* enable l2 cache */ + writefr_extra_feature_reg(ctrl); +} + +void l2_cache_disable() +{ + u32 ctrl; + + ctrl = readfr_extra_feature_reg(); + ctrl &= ~(1 << 22); /* disable l2 cache */ + writefr_extra_feature_reg(ctrl); +}
Am Sonntag 18 Dezember 2011, 23:09:51 schrieb Michael Walle:
You should consider applying this patch to the RC, too. CONFIG_ARM_PATCH_PHYS_VIRT is enabled by default since 3.2-rc1.
- Stub implementations for l2 cache operations
- l2_cache_disable();
- /* flush I/D-cache */ cache_flush();
- Copyright (c) 2011 Michael Walle
- Michael Walle michael@walle.cc
- project.
- Foundation, Inc.
- u32 ctrl;
- ctrl = readfr_extra_feature_reg();
- ctrl |= 1 << 22; /* enable l2 cache */
- writefr_extra_feature_reg(ctrl);
- u32 ctrl;
- ctrl &= ~(1 << 22); /* disable l2 cache */
Please use #define <name> to define the magic value above (1 << 22) and then use it.
M
Am Montag 19 Dezember 2011, 00:04:18 schrieb Marek Vasut: [..snip..]
M
The bit was taken from arch/arm/cpu/arm926ejs/kirkwood/cpu.c. Unfortunately there is no documentation publicly available, so i can only guess names.
FEROCEON_EXTRA_FEATURE_L2C_EN ?
Even the linux kernel has no proper macro names :(
Hi Michael,
Please use #define<name> to define the magic value above (1<< 22) and then use it.
M
Works for me.
Time we told them to have one, then. :)
I assume the patch was tested against a 3.2-rc1 kernel and also a pre-3.2-rc1 kernel to avoid regression?
Amicalement,
Am Dienstag 20 Dezember 2011, 08:04:23 schrieb Albert ARIBAUD:
Tested with 3.0, 3.1 and 3.2-rc both with CONFIG_ARM_PATCH_PHYS_VIRT enabled and disabled.
Signed-off-by: Michael Walle michael@walle.cc Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com --- arch/arm/cpu/arm926ejs/cache.c | 15 ++++++++++ arch/arm/cpu/arm926ejs/cpu.c | 2 + arch/arm/cpu/arm926ejs/kirkwood/Makefile | 1 + arch/arm/cpu/arm926ejs/kirkwood/cache.c | 43 ++++++++++++++++++++++++++++++ 4 files changed, 61 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/kirkwood/cache.c
SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cache.c b/arch/arm/cpu/arm926ejs/kirkwood/cache.c new file mode 100644 index 0000000..df90cb9 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/kirkwood/cache.c @@ -0,0 +1,43 @@ +/* + * Copyright (c) 2011 Michael Walle + * Michael Walle michael@walle.cc + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +#include <common.h> +#include <asm/arch/cpu.h> + +#define FEROCEON_EXTRA_FEATURE_L2C_EN (1<<22) + +void l2_cache_enable() +{ + u32 ctrl; + + ctrl = readfr_extra_feature_reg(); + ctrl |= FEROCEON_EXTRA_FEATURE_L2C_EN; + writefr_extra_feature_reg(ctrl); +} + +void l2_cache_disable() +{ + u32 ctrl; + + ctrl = readfr_extra_feature_reg(); + ctrl &= ~FEROCEON_EXTRA_FEATURE_L2C_EN; + writefr_extra_feature_reg(ctrl); +}
- project.
- Foundation, Inc.
- u32 ctrl;
- ctrl |= FEROCEON_EXTRA_FEATURE_L2C_EN;
- u32 ctrl;
- ctrl &= ~FEROCEON_EXTRA_FEATURE_L2C_EN;
Fine by me ...
Acked-by: Marek Vasut marek.vasut@gmail.com
Am Mittwoch 21 Dezember 2011, 00:35:46 schrieb Michael Walle:
Ping :)
Hi Michael,
Ping :)
Sorry, start of year was hectic.
That's V2 of the patch, correct? But it has no V2 tag, nor history.
Also, I'm missing something: you introduce two functions, for enabling and disabling the cache, yet the code uses only the one for disabling. So what enabled it in the first place?
Regards, Albert.
Signed-off-by: Michael Walle michael@walle.cc Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Prafulla Wadaskar prafulla@marvell.com --- This is a repost, because the former had no version tag nor a history.
v2: - replace magic number with macro
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index ee90ab7..ba13154 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -68,3 +68,18 @@ void flush_cache(unsigned long start, unsigned long size) { } #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */ + +/* + * Stub implementations for l2 cache operations + */ +void __l2_cache_enable(void) +{ +} +void l2_cache_enable(void) + __attribute__((weak, alias("__l2_cache_enable"))); + +void __l2_cache_disable(void) +{ +} +void l2_cache_disable(void) + __attribute__((weak, alias("__l2_cache_disable"))); diff --git a/arch/arm/cpu/arm926ejs/cpu.c b/arch/arm/cpu/arm926ejs/cpu.c index 5c902df..626384c 100644 --- a/arch/arm/cpu/arm926ejs/cpu.c +++ b/arch/arm/cpu/arm926ejs/cpu.c @@ -50,6 +50,8 @@ int cleanup_before_linux (void) /* turn off I/D-cache */ icache_disable(); dcache_disable(); + l2_cache_disable(); + /* flush I/D-cache */ cache_flush();
[Sorry can't answer to the original message, because it was blocked by spam filter]
The L2C is enabled in arch_misc_init() in arch/arm/cpu/arm926ejs/kirkwood/cpu.c
My enable function is just for completeness atm.
Am Freitag 13 Januar 2012, 23:59:08 schrieb Michael Walle:
Ping.
Is there something still uncertain?
Dear Michael Walle,
Ping.
Nothing is uncertain.
But we do not add dead code.
Albert ARIBAUD
Michael Walle
