[PATCH 0/2] publish HTML documentation on readthedocs.org
readthedocs.org offers a free service to publish generated HTML documentation.
For testing I have set this up for U-Boot using my https://github.com/xypron2/u-boot repository.
The generated output is available at https://u-boot.readthedocs.io/en/latest/
In a final version we should implement the necessary git hook on Gitlab and change the source repository to https://gitlab.denx.de/u-boot/u-boot.
Than whenever we update the master branch or create a new tag the documentation will be generated and published.
For a correct functioning of the readathedocs.org build process we need the two appended patches.
Heinrich Schuchardt (2): doc: specify that xelatex is used as Latex engine Add .readthedocs.yml
.readthedocs.yml | 19 +++++++++++++++++++ doc/conf.py | 2 ++ 2 files changed, 21 insertions(+) create mode 100644 .readthedocs.yml
-- 2.26.1
Building the pdf documentation on readthedocs.org fails with pdflatex.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/conf.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/doc/conf.py b/doc/conf.py index 0772fb6f0c..b033de9d3a 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -31,6 +31,8 @@ from load_config import loadConfig # If your documentation needs a minimal Sphinx version, state it here. needs_sphinx = '1.3'
+latex_engine = 'xelatex' + # Add any Sphinx extension module names here, as strings. They can be # extensions coming with Sphinx (named 'sphinx.ext.*') or your custom # ones. -- 2.26.1
readthedocs.org allows to automatically generate and publish the HTML documentation for the U-Boot project.
Add a file controlling building https://u-boot.readthedocs.io/.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- .readthedocs.yml | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+) create mode 100644 .readthedocs.yml
diff --git a/.readthedocs.yml b/.readthedocs.yml new file mode 100644 index 0000000000..f3fb5ed51b --- /dev/null +++ b/.readthedocs.yml @@ -0,0 +1,19 @@ +# .readthedocs.yml +# Read the Docs configuration file +# See https://docs.readthedocs.io/en/stable/config-file/v2.html for details + +# Required +version: 2 + +# Build documentation in the docs/ directory with Sphinx +sphinx: + configuration: docs/conf.py + +# Optionally build your docs in additional formats such as PDF and ePub +formats: [] + +# Optionally set the version of Python and requirements required to build your docs +# python: +# version: 3.7 +# install: +# - requirements: docs/requirements.txt -- 2.26.1
Very neat, thanks for doing this!
