[U-Boot] Unable to decompress files greater than 500 MB
We are using u-boot source code which has the support for most of the compressions like bz2, lzma, gz etc.
We tried uncompressing bz2, lzma and gz images and most of them either fail or data abort or hang indefinitely for large sized uncompressed data > 500 MB.
This is for the arm port.
Could you please provide us any pointers for the same?
signature
Hello Zakir Ahmed,
Am 26.10.2016 um 12:22 schrieb Zakir Ahmed:
On which board is this and how much RAM do you have? How looks your memory map? In which way does it fail?
I just speculate now ... you may overwrite U-Boot Code /stack malloc space ?
bye, Heiko
Hello Schocher,
Thanks for your response.
This is custom board which uses ARM Cortex- A15 processor. RAM is 2GB. I run loading uboot at 1536 MB (0x60000000) to avoid overwriting uboot code. Compressed Image at 0x47400000 -> 1140 MB (Compressed Image < 200 MB) Uncompressed Image at 0x0C000000 -> I have tested this at different addresses starting from 0xA000 till 0x0C000000. Same issue is seen
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Thursday, October 27, 2016 9:46 AM To: Zakir Ahmed Cc: u-boot@lists.denx.de; 'ANAND N'; cpgs@samsung.com Subject: Re: [U-Boot] Unable to decompress files greater than 500 MB
Hello Zakir Ahmed,
bye, Heiko
Heiko Schocher
Zakir Ahmed
