[U-Boot-Users] [GIT PULL] [ARM] Please pull from git://denx.de/git/u-boot-arm.git
Wolfgang
The changes address your comments:-
The following issues need to be addressed: include/led.h => seems specific to the at91rm9200dk board only, please move to board directory. Also, the calls to these functions should be handled without #ifdef's in common code. Either use existing functions hooks, or weak references.
Moved to asm-arm as coloured_led.h - I want to play with the coloured leds on other ARM boards sometime.
drivers/at45.c => has coding style issues - indentation of long, wrapped around lines is broken.
- ran Lindent on it
cpu/arm920t/start.S => I'm surprised to see a lot of intialization code has now been added to the "reset" entry point. Is this by accident, or am I missing something?
Ulf and I missed that CONFIG_BOOTBINFUNC has been deprecated and split into CONFIG_SKIP_RELOCATE_UBOOT CONFIG_SKIP_LOWLEVEL_INIT as described in the README.
Since the CONFIG_BOOTBINFUNC code has not been tested e.g. there was no lowlevelinit(), I have removed it for now.
I want to take this opportunity to remind ARM developers that any intialization - of the cpu should take place in cpu/<armcpu> /<file>::cpu_init_crit() - of the board should take place in board/<armboard>/<file>::lowlevel_init().
There are currently various misplaced initializations which I hope to sort out with the board maintainers.
Anyone submitting at91rm9200 code should be aware that currently - the define CONFIG_AT91RM9200 is used by at91rm9200dk cmc_pu2 mp2usb - the define CONFIG_AT91RM9200DK is used by at91rm9200dk mp2usb please make sure not to break the other boards.
include/config_cmd_all.h: "CONFIG_CMD_MUX" is a pretty generic name, while here it is used for a board or CPU specific feature only. I suggest you rename this into something which has a "AT91" in the name, like "CONFIG_CMD_AT91_SPIMUX" or so.
- done
Signed-off-by: Peter Pearse peter.pearse@arm.com Signed-off-by: Ulf Samuelsson ulf@atmel.com
--- The following changes since commit 38ad82da0c1180ecdeb212a8f4245e945bcc546e: Grzegorz Bernacki (1): [GP3SSA] Add define CONFIG_MPC85XX_PCI2 in config file to allow u-boot to
are found in the git repository at:
git://www.denx.de/git/u-boot-arm.git
Peter Pearse (10): Rename CONFIG_CMD_MUX to CONFIG_CMD_AT91_SPIMUX Ran Lindent on drivers/at45.c Move include/led.h to board/at91rm9200dk Add coloured led interface for ARM boards. Changed API name to coloured_led.h Merge with git://www.denx.de/git/u-boot.git Merge with git://www.denx.de/git/u-boot.git Merge with git://www.denx.de/git/u-boot.git Merge with git://www.denx.de/git/u-boot.git Final tidy
board/at91rm9200dk/led.c | 2 +- cpu/arm920t/start.S | 128 ++--------- drivers/at45.c | 334 ++++++++++++++--------------- include/{led.h => asm-arm/coloured_led.h} | 2 +- include/config_cmd_all.h | 2 +- lib_arm/board.c | 24 ++ 6 files changed, 210 insertions(+), 282 deletions(-) rename include/{led.h => asm-arm/coloured_led.h} (97%) ---
Dear Peter,
I still would rather have this integrated into the existing status_led driver.
Please feel free to do so.
- ran Lindent on it
Actually the new version is even worse. It has many lines which are not indented by multiple of 8 chars.
Please clean this up.
Peter Pearse
