[U-Boot] [PATCH v2] Add support for Microchip LAN75xx and LAN78xx
Add support for Microchip LAN7500, LAN7800 and LAN7850, USB to 10/100/1000 Ethernet Controllers
Signed-off-by: Yuiko Oshino yuiko.oshino@microchip.com Cc: Marek Vasut marex@denx.de Cc: Joe Hershberger joe.hershberger@gmail.com --- Changes for v2: - wait_for_bit functions copy the real one. - uses phylib - unnecessary variables were removed - all return values are checked - uses mii_resolve_flowctrl_fdx() from linux/mii.h ([PATCH] mii: Add mii_resolve_flowctrl_fdx() submitted on June 26, 2017) --- drivers/usb/Kconfig | 2 + drivers/usb/eth/Kconfig | 18 ++ drivers/usb/eth/Makefile | 2 + drivers/usb/eth/lan75xx.c | 320 +++++++++++++++++++++++++++++ drivers/usb/eth/lan78xx.c | 479 +++++++++++++++++++++++++++++++++++++++++++ drivers/usb/eth/lan7x.c | 506 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/eth/lan7x.h | 232 +++++++++++++++++++++ 7 files changed, 1559 insertions(+) create mode 100644 drivers/usb/eth/Kconfig create mode 100644 drivers/usb/eth/lan75xx.c create mode 100644 drivers/usb/eth/lan78xx.c create mode 100644 drivers/usb/eth/lan7x.c create mode 100644 drivers/usb/eth/lan7x.h
diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index da3ec2f..62126aa 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -94,4 +94,6 @@ endif
source "drivers/usb/gadget/Kconfig"
+source "drivers/usb/eth/Kconfig" + endif diff --git a/drivers/usb/eth/Kconfig b/drivers/usb/eth/Kconfig new file mode 100644 index 0000000..a07243f --- /dev/null +++ b/drivers/usb/eth/Kconfig @@ -0,0 +1,18 @@ +comment "USB to Ethernet Controller Drivers" + +config USB_ETHER_LAN75XX + bool "Microchip LAN75XX support" + ---help--- + Say Y here if you would like to support Microchip LAN75XX Hi-Speed + USB 2.0 to 10/100/1000 Gigabit Ethernet controller. + Supports 10Base-T/ 100Base-TX/1000Base-T. + This driver supports the internal PHY. + +config USB_ETHER_LAN78XX + bool "Microchip LAN78XX support" + ---help--- + Say Y here if you would like to support Microchip LAN78XX USB 3.1 + Gen 1 to 10/100/1000 Gigabit Ethernet controller. + Supports 10Base-T/ 100Base-TX/1000Base-T. + This driver supports the internal PHY. + diff --git a/drivers/usb/eth/Makefile b/drivers/usb/eth/Makefile index 4c44efc..4b935a3 100644 --- a/drivers/usb/eth/Makefile +++ b/drivers/usb/eth/Makefile @@ -9,4 +9,6 @@ obj-$(CONFIG_USB_ETHER_ASIX) += asix.o obj-$(CONFIG_USB_ETHER_ASIX88179) += asix88179.o obj-$(CONFIG_USB_ETHER_MCS7830) += mcs7830.o obj-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o +obj-$(CONFIG_USB_ETHER_LAN75XX) += lan7x.o lan75xx.o +obj-$(CONFIG_USB_ETHER_LAN78XX) += lan7x.o lan78xx.o obj-$(CONFIG_USB_ETHER_RTL8152) += r8152.o r8152_fw.o diff --git a/drivers/usb/eth/lan75xx.c b/drivers/usb/eth/lan75xx.c new file mode 100644 index 0000000..8ac7784 --- /dev/null +++ b/drivers/usb/eth/lan75xx.c @@ -0,0 +1,320 @@ +/* + * Copyright (c) 2017 Microchip Technology Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm.h> +#include <usb.h> +#include <linux/mii.h> +#include "usb_ether.h" +#include "lan7x.h" + +/* LAN75xx specific register/bit defines */ +#define LAN75XX_HW_CFG_BIR BIT(7) + +#define LAN75XX_BURST_CAP 0x034 + +#define LAN75XX_BULK_IN_DLY 0x03C + +#define LAN75XX_RFE_CTL 0x060 + +#define LAN75XX_FCT_RX_CTL 0x090 + +#define LAN75XX_FCT_TX_CTL 0x094 + +#define LAN75XX_FCT_RX_FIFO_END 0x098 + +#define LAN75XX_FCT_TX_FIFO_END 0x09C + +#define LAN75XX_FCT_FLOW 0x0A0 + +/* MAC ADDRESS PERFECT FILTER For LAN75xx */ +#define LAN75XX_ADDR_FILTX 0x300 +#define LAN75XX_ADDR_FILTX_FB_VALID BIT(31) + +/* + * Lan75xx infrastructure commands + */ +static int lan75xx_phy_gig_workaround(struct usb_device *udev, + struct ueth_data *dev) +{ + int ret = 0; + + /* Only internal phy */ + /* Set the phy in Gig loopback */ + lan7x_mdio_write(udev, dev->phy_id, MII_BMCR, + (BMCR_LOOPBACK | BMCR_SPEED1000)); + + /* Wait for the link up */ + ret = lan7x_mdio_wait_for_bit(udev, "BMSR_LSTATUS", + dev->phy_id, MII_BMSR, BMSR_LSTATUS, + true, PHY_CONNECT_TIMEOUT_MS, 1); + if (ret) + return ret; + + /* phy reset */ + return lan7x_pmt_phy_reset(udev, dev); +} + +static int lan75xx_update_flowcontrol(struct usb_device *udev, + struct ueth_data *dev) +{ + uint32_t flow = 0, fct_flow = 0; + int ret; + + ret = lan7x_update_flowcontrol(udev, dev, &flow, &fct_flow); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN75XX_FCT_FLOW, fct_flow); + if (ret) + return ret; + return lan7x_write_reg(udev, FLOW, flow); +} + +static int lan75xx_read_mac(unsigned char *enetaddr, + struct usb_device *udev) +{ + /* + * Refer to the doc/README.enetaddr and doc/README.usb for + * the U-Boot MAC address policy + */ + return lan7x_read_eeprom_mac(enetaddr, udev); +} + +static int lan75xx_set_receive_filter(struct usb_device *udev) +{ + /* No multicast in u-boot */ + return lan7x_write_reg(udev, LAN75XX_RFE_CTL, + RFE_CTL_BCAST_EN | RFE_CTL_DA_PERFECT); +} + +/* starts the TX path */ +static void lan75xx_start_tx_path(struct usb_device *udev) +{ + /* Enable Tx at MAC */ + lan7x_write_reg(udev, MAC_TX, MAC_TX_TXEN); + + /* Enable Tx at SCSRs */ + lan7x_write_reg(udev, LAN75XX_FCT_TX_CTL, FCT_TX_CTL_EN); +} + +/* Starts the Receive path */ +static void lan75xx_start_rx_path(struct usb_device *udev) +{ + /* Enable Rx at MAC */ + lan7x_write_reg(udev, MAC_RX, + LAN7X_MAC_RX_MAX_SIZE_DEFAULT | + MAC_RX_FCS_STRIP | MAC_RX_RXEN); + + /* Enable Rx at SCSRs */ + lan7x_write_reg(udev, LAN75XX_FCT_RX_CTL, FCT_RX_CTL_EN); +} + +static int lan75xx_basic_reset(struct usb_device *udev, + struct ueth_data *dev, + struct lan7x_private *priv) +{ + int ret; + u32 val; + + ret = lan7x_basic_reset(udev, dev); + if (ret) + return ret; + + /* Keep the chip ID */ + ret = lan7x_read_reg(udev, ID_REV, &val); + if (ret) + return ret; + debug("LAN75xx ID_REV = 0x%08x\n", val); + + priv->chipid = (val & ID_REV_CHIP_ID_MASK) >> 16; + + /* Respond to the IN token with a NAK */ + ret = lan7x_read_reg(udev, HW_CFG, &val); + if (ret) + return ret; + val |= LAN75XX_HW_CFG_BIR; + return lan7x_write_reg(udev, HW_CFG, val); +} + +#ifdef CONFIG_DM_ETH +int lan75xx_write_hwaddr(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + unsigned char *enetaddr = pdata->enetaddr; + u32 addr_lo = get_unaligned_le32(&enetaddr[0]); + u32 addr_hi = (u32)get_unaligned_le16(&enetaddr[4]); + int ret; + + /* set hardware address */ + ret = lan7x_write_reg(udev, RX_ADDRL, addr_lo); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, RX_ADDRH, addr_hi); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN75XX_ADDR_FILTX + 4, addr_lo); + if (ret) + return ret; + + addr_hi |= LAN75XX_ADDR_FILTX_FB_VALID; + ret = lan7x_write_reg(udev, LAN75XX_ADDR_FILTX, addr_hi); + if (ret) + return ret; + + debug("MAC addr %pM written\n", enetaddr); + + return 0; +} + +static int lan75xx_eth_start(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct lan7x_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + int ret; + u32 write_buf; + + /* Reset and read Mac addr were done in probe() */ + ret = lan75xx_write_hwaddr(dev); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, INT_STS, 0xFFFFFFFF); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN75XX_BURST_CAP, 0); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN75XX_BULK_IN_DLY, DEFAULT_BULK_IN_DELAY); + if (ret) + return ret; + + /* set FIFO sizes */ + write_buf = (MAX_RX_FIFO_SIZE - 512) / 512; + ret = lan7x_write_reg(udev, LAN75XX_FCT_RX_FIFO_END, write_buf); + if (ret) + return ret; + + write_buf = (MAX_TX_FIFO_SIZE - 512) / 512; + ret = lan7x_write_reg(udev, LAN75XX_FCT_TX_FIFO_END, write_buf); + if (ret) + return ret; + + /* Init Tx */ + ret = lan7x_write_reg(udev, FLOW, 0); + if (ret) + return ret; + + /* Init Rx. Set Vlan, keep defult for VLAN on 75xx */ + ret = lan75xx_set_receive_filter(udev); + if (ret) + return ret; + + /* phy workaround for gig link */ + ret = lan75xx_phy_gig_workaround(udev, ueth); + if (ret) + return ret; + + /* Init PHY, autonego, and link */ + ret = lan7x_eth_phylib_connect(dev, &priv->ueth); + if (ret) + return ret; + ret = lan7x_eth_phylib_config_start(dev); + if (ret) + return ret; + + /* + * MAC_CR has to be set after PHY init. + * MAC will auto detect the PHY speed. + */ + ret = lan7x_read_reg(udev, MAC_CR, &write_buf); + if (ret) + return ret; + write_buf |= MAC_CR_AUTO_DUPLEX | MAC_CR_AUTO_SPEED | MAC_CR_ADP; + ret = lan7x_write_reg(udev, MAC_CR, write_buf); + if (ret) + return ret; + + lan75xx_start_tx_path(udev); + lan75xx_start_rx_path(udev); + + return lan75xx_update_flowcontrol(udev, ueth); +} + +int lan75xx_read_rom_hwaddr(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + int ret; + + ret = lan75xx_read_mac(pdata->enetaddr, udev); + if (ret) + memset(pdata->enetaddr, 0, 6); + + return 0; +} + +static int lan75xx_eth_probe(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct lan7x_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + struct eth_pdata *pdata = dev_get_platdata(dev); + int ret; + + /* Do a reset in order to get the MAC address from HW */ + if (lan75xx_basic_reset(udev, ueth, priv)) + return 0; + + /* Get the MAC address */ + /* + * We must set the eth->enetaddr from HW because the upper layer + * will force to use the environmental var (usbethaddr) or random if + * there is no valid MAC address in eth->enetaddr. + */ + lan75xx_read_mac(pdata->enetaddr, udev); + /* Do not return 0 for not finding MAC addr in HW */ + + ret = usb_ether_register(dev, ueth, RX_URB_SIZE); + if (ret) + return ret; + + /* Register phylib */ + return lan7x_phylib_register(dev); +} + +static const struct eth_ops lan75xx_eth_ops = { + .start = lan75xx_eth_start, + .send = lan7x_eth_send, + .recv = lan7x_eth_recv, + .free_pkt = lan7x_free_pkt, + .stop = lan7x_eth_stop, + .write_hwaddr = lan75xx_write_hwaddr, + .read_rom_hwaddr = lan75xx_read_rom_hwaddr, +}; + +U_BOOT_DRIVER(lan75xx_eth) = { + .name = "lan75xx_eth", + .id = UCLASS_ETH, + .probe = lan75xx_eth_probe, + .remove = lan7x_eth_remove, + .ops = &lan75xx_eth_ops, + .priv_auto_alloc_size = sizeof(struct lan7x_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static const struct usb_device_id lan75xx_eth_id_table[] = { + { USB_DEVICE(0x0424, 0x7500) }, /* LAN7500 USB Ethernet */ + { } /* Terminating entry */ +}; + +U_BOOT_USB_DEVICE(lan75xx_eth, lan75xx_eth_id_table); +#endif diff --git a/drivers/usb/eth/lan78xx.c b/drivers/usb/eth/lan78xx.c new file mode 100644 index 0000000..5160db7 --- /dev/null +++ b/drivers/usb/eth/lan78xx.c @@ -0,0 +1,479 @@ +/* + * Copyright (c) 2017 Microchip Technology Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm.h> +#include <usb.h> +#include "usb_ether.h" +#include "lan7x.h" + +/* LAN78xx specific register/bit defines */ +#define LAN78XX_HW_CFG_LED1_EN BIT(21) /* Muxed with EEDO */ +#define LAN78XX_HW_CFG_LED0_EN BIT(20) /* Muxed with EECLK */ + +#define LAN78XX_USB_CFG0 0x080 +#define LAN78XX_USB_CFG0_BIR BIT(6) + +#define LAN78XX_BURST_CAP 0x090 + +#define LAN78XX_BULK_IN_DLY 0x094 + +#define LAN78XX_RFE_CTL 0x0B0 + +#define LAN78XX_FCT_RX_CTL 0x0C0 + +#define LAN78XX_FCT_TX_CTL 0x0C4 + +#define LAN78XX_FCT_RX_FIFO_END 0x0C8 + +#define LAN78XX_FCT_TX_FIFO_END 0x0CC + +#define LAN78XX_FCT_FLOW 0x0D0 + +#define LAN78XX_MAF_BASE 0x400 +#define LAN78XX_MAF_HIX 0x00 +#define LAN78XX_MAF_LOX 0x04 +#define LAN78XX_MAF_HI_BEGIN (LAN78XX_MAF_BASE + LAN78XX_MAF_HIX) +#define LAN78XX_MAF_LO_BEGIN (LAN78XX_MAF_BASE + LAN78XX_MAF_LOX) +#define LAN78XX_MAF_HI(index) (LAN78XX_MAF_BASE + (8 * (index)) + \ + LAN78XX_MAF_HIX) +#define LAN78XX_MAF_LO(index) (LAN78XX_MAF_BASE + (8 * (index)) + \ + LAN78XX_MAF_LOX) +#define LAN78XX_MAF_HI_VALID BIT(31) + +/* OTP registers */ +#define LAN78XX_OTP_BASE_ADDR 0x00001000 + +#define LAN78XX_OTP_PWR_DN (LAN78XX_OTP_BASE_ADDR + 4 * 0x00) +#define LAN78XX_OTP_PWR_DN_PWRDN_N BIT(0) + +#define LAN78XX_OTP_ADDR1 (LAN78XX_OTP_BASE_ADDR + 4 * 0x01) +#define LAN78XX_OTP_ADDR1_15_11 0x1F + +#define LAN78XX_OTP_ADDR2 (LAN78XX_OTP_BASE_ADDR + 4 * 0x02) +#define LAN78XX_OTP_ADDR2_10_3 0xFF + +#define LAN78XX_OTP_RD_DATA (LAN78XX_OTP_BASE_ADDR + 4 * 0x06) + +#define LAN78XX_OTP_FUNC_CMD (LAN78XX_OTP_BASE_ADDR + 4 * 0x08) +#define LAN78XX_OTP_FUNC_CMD_READ BIT(0) + +#define LAN78XX_OTP_CMD_GO (LAN78XX_OTP_BASE_ADDR + 4 * 0x0A) +#define LAN78XX_OTP_CMD_GO_GO BIT(0) + +#define LAN78XX_OTP_STATUS (LAN78XX_OTP_BASE_ADDR + 4 * 0x0C) +#define LAN78XX_OTP_STATUS_BUSY BIT(0) + +#define LAN78XX_OTP_INDICATOR_1 0xF3 +#define LAN78XX_OTP_INDICATOR_2 0xF7 + +/* + * Lan78xx infrastructure commands + */ +static int lan78xx_read_raw_otp(struct usb_device *udev, u32 offset, + u32 length, u8 *data) +{ + int i; + int ret; + u32 buf; + + ret = lan7x_read_reg(udev, LAN78XX_OTP_PWR_DN, &buf); + if (ret) + return ret; + + if (buf & LAN78XX_OTP_PWR_DN_PWRDN_N) { + /* clear it and wait to be cleared */ + ret = lan7x_write_reg(udev, LAN78XX_OTP_PWR_DN, 0); + if (ret) + return ret; + + ret = lan7x_wait_for_bit(udev, "LAN78XX_OTP_PWR_DN_PWRDN_N", + LAN78XX_OTP_PWR_DN, + LAN78XX_OTP_PWR_DN_PWRDN_N, + false, 1000, 0); + if (ret) + return ret; + } + + for (i = 0; i < length; i++) { + ret = lan7x_write_reg(udev, LAN78XX_OTP_ADDR1, + ((offset + i) >> 8) & + LAN78XX_OTP_ADDR1_15_11); + if (ret) + return ret; + ret = lan7x_write_reg(udev, LAN78XX_OTP_ADDR2, + ((offset + i) & LAN78XX_OTP_ADDR2_10_3)); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_OTP_FUNC_CMD, + LAN78XX_OTP_FUNC_CMD_READ); + if (ret) + return ret; + ret = lan7x_write_reg(udev, LAN78XX_OTP_CMD_GO, + LAN78XX_OTP_CMD_GO_GO); + + if (ret) + return ret; + + ret = lan7x_wait_for_bit(udev, "LAN78XX_OTP_STATUS_BUSY", + LAN78XX_OTP_STATUS, + LAN78XX_OTP_STATUS_BUSY, + false, 1000, 0); + if (ret) + return ret; + + ret = lan7x_read_reg(udev, LAN78XX_OTP_RD_DATA, &buf); + if (ret) + return ret; + + data[i] = (u8)(buf & 0xFF); + } + + return 0; +} + +static int lan78xx_read_otp(struct usb_device *udev, u32 offset, + u32 length, u8 *data) +{ + u8 sig; + int ret; + + ret = lan78xx_read_raw_otp(udev, 0, 1, &sig); + + if (!ret) { + if (sig == LAN78XX_OTP_INDICATOR_1) + offset = offset; + else if (sig == LAN78XX_OTP_INDICATOR_2) + offset += 0x100; + else + return -EINVAL; + ret = lan78xx_read_raw_otp(udev, offset, length, data); + if (ret) + return ret; + } + debug("LAN78x: MAC address from OTP = %pM\n", data); + + return ret; +} + +static int lan78xx_read_otp_mac(unsigned char *enetaddr, + struct usb_device *udev) +{ + int ret; + + memset(enetaddr, 0, 6); + + ret = lan78xx_read_otp(udev, + EEPROM_MAC_OFFSET, + ETH_ALEN, + enetaddr); + if (!ret && is_valid_ethaddr(enetaddr)) { + /* eeprom values are valid so use them */ + debug("MAC address read from OTP %pM\n", enetaddr); + return 0; + } + debug("MAC address read from OTP invalid %pM\n", enetaddr); + + memset(enetaddr, 0, 6); + return -EINVAL; +} + +static int lan78xx_update_flowcontrol(struct usb_device *udev, + struct ueth_data *dev) +{ + uint32_t flow = 0, fct_flow = 0; + int ret; + + ret = lan7x_update_flowcontrol(udev, dev, &flow, &fct_flow); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_FCT_FLOW, fct_flow); + if (ret) + return ret; + return lan7x_write_reg(udev, FLOW, flow); +} + +static int lan78xx_read_mac(unsigned char *enetaddr, + struct usb_device *udev, + struct lan7x_private *priv) +{ + u32 val; + int ret; + int saved = 0, done = 0; + + /* + * Depends on chip, some EEPROM pins are muxed with LED function. + * disable & restore LED function to access EEPROM. + */ + if ((priv->chipid == ID_REV_CHIP_ID_7800) || + (priv->chipid == ID_REV_CHIP_ID_7850)) { + ret = lan7x_read_reg(udev, HW_CFG, &val); + if (ret) + return ret; + saved = val; + val &= ~(LAN78XX_HW_CFG_LED1_EN | LAN78XX_HW_CFG_LED0_EN); + ret = lan7x_write_reg(udev, HW_CFG, val); + if (ret) + goto restore; + } + + /* + * Refer to the doc/README.enetaddr and doc/README.usb for + * the U-Boot MAC address policy + */ + /* try reading mac address from EEPROM, then from OTP */ + ret = lan7x_read_eeprom_mac(enetaddr, udev); + if (!ret) + done = 1; + +restore: + if ((priv->chipid == ID_REV_CHIP_ID_7800) || + (priv->chipid == ID_REV_CHIP_ID_7850)) { + ret = lan7x_write_reg(udev, HW_CFG, saved); + if (ret) + return ret; + } + /* if the EEPROM mac address is good, then exit */ + if (done) + return 0; + + /* try reading mac address from OTP if the device is LAN78xx */ + return lan78xx_read_otp_mac(enetaddr, udev); +} + +static int lan78xx_set_receive_filter(struct usb_device *udev) +{ + /* No multicast in u-boot for now */ + return lan7x_write_reg(udev, LAN78XX_RFE_CTL, + RFE_CTL_BCAST_EN | RFE_CTL_DA_PERFECT); +} + +/* starts the TX path */ +static void lan78xx_start_tx_path(struct usb_device *udev) +{ + /* Enable Tx at MAC */ + lan7x_write_reg(udev, MAC_TX, MAC_TX_TXEN); + + /* Enable Tx at SCSRs */ + lan7x_write_reg(udev, LAN78XX_FCT_TX_CTL, FCT_TX_CTL_EN); +} + +/* Starts the Receive path */ +static void lan78xx_start_rx_path(struct usb_device *udev) +{ + /* Enable Rx at MAC */ + lan7x_write_reg(udev, MAC_RX, + LAN7X_MAC_RX_MAX_SIZE_DEFAULT | + MAC_RX_FCS_STRIP | MAC_RX_RXEN); + + /* Enable Rx at SCSRs */ + lan7x_write_reg(udev, LAN78XX_FCT_RX_CTL, FCT_RX_CTL_EN); +} + +static int lan78xx_basic_reset(struct usb_device *udev, + struct ueth_data *dev, + struct lan7x_private *priv) +{ + int ret; + u32 val; + + ret = lan7x_basic_reset(udev, dev); + if (ret) + return ret; + + /* Keep the chip ID */ + ret = lan7x_read_reg(udev, ID_REV, &val); + if (ret) + return ret; + debug("LAN78xx ID_REV = 0x%08x\n", val); + + priv->chipid = (val & ID_REV_CHIP_ID_MASK) >> 16; + + /* Respond to the IN token with a NAK */ + ret = lan7x_read_reg(udev, LAN78XX_USB_CFG0, &val); + if (ret) + return ret; + val |= LAN78XX_USB_CFG0_BIR; + return lan7x_write_reg(udev, LAN78XX_USB_CFG0, val); +} + +#ifdef CONFIG_DM_ETH +int lan78xx_write_hwaddr(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + unsigned char *enetaddr = pdata->enetaddr; + u32 addr_lo = get_unaligned_le32(&enetaddr[0]); + u32 addr_hi = (u32)get_unaligned_le16(&enetaddr[4]); + int ret; + + /* set hardware address */ + ret = lan7x_write_reg(udev, RX_ADDRL, addr_lo); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, RX_ADDRH, addr_hi); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_MAF_LO(0), addr_lo); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_MAF_HI(0), + addr_hi | LAN78XX_MAF_HI_VALID); + if (ret) + return ret; + + debug("MAC addr %pM written\n", enetaddr); + + return 0; +} + +static int lan78xx_eth_start(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct lan7x_private *priv = dev_get_priv(dev); + + int ret; + u32 write_buf; + + /* Reset and read Mac addr were done in probe() */ + ret = lan78xx_write_hwaddr(dev); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_BURST_CAP, 0); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_BULK_IN_DLY, DEFAULT_BULK_IN_DELAY); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, INT_STS, 0xFFFFFFFF); + if (ret) + return ret; + + /* set FIFO sizes */ + ret = lan7x_write_reg(udev, LAN78XX_FCT_RX_FIFO_END, + (MAX_RX_FIFO_SIZE - 512) / 512); + if (ret) + return ret; + + ret = lan7x_write_reg(udev, LAN78XX_FCT_TX_FIFO_END, + (MAX_TX_FIFO_SIZE - 512) / 512); + if (ret) + return ret; + + /* Init Tx */ + ret = lan7x_write_reg(udev, FLOW, 0); + if (ret) + return ret; + + /* Init Rx. Set Vlan, keep defult for VLAN on 78xx */ + ret = lan78xx_set_receive_filter(udev); + if (ret) + return ret; + + /* Init PHY, autonego, and link */ + ret = lan7x_eth_phylib_connect(dev, &priv->ueth); + if (ret) + return ret; + ret = lan7x_eth_phylib_config_start(dev); + if (ret) + return ret; + + /* + * MAC_CR has to be set after PHY init. + * MAC will auto detect the PHY speed. + */ + ret = lan7x_read_reg(udev, MAC_CR, &write_buf); + if (ret) + return ret; + write_buf |= MAC_CR_AUTO_DUPLEX | MAC_CR_AUTO_SPEED | MAC_CR_ADP; + ret = lan7x_write_reg(udev, MAC_CR, write_buf); + if (ret) + return ret; + + lan78xx_start_tx_path(udev); + lan78xx_start_rx_path(udev); + + return lan78xx_update_flowcontrol(udev, &priv->ueth); +} + +int lan78xx_read_rom_hwaddr(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct lan7x_private *priv = dev_get_priv(dev); + int ret; + + ret = lan78xx_read_mac(pdata->enetaddr, udev, priv); + if (ret) + memset(pdata->enetaddr, 0, 6); + + return 0; +} + +static int lan78xx_eth_probe(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct lan7x_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + struct eth_pdata *pdata = dev_get_platdata(dev); + int ret; + + /* Do a reset in order to get the MAC address from HW */ + if (lan78xx_basic_reset(udev, ueth, priv)) + return 0; + + /* Get the MAC address */ + /* + * We must set the eth->enetaddr from HW because the upper layer + * will force to use the environmental var (usbethaddr) or random if + * there is no valid MAC address in eth->enetaddr. + */ + lan78xx_read_mac(pdata->enetaddr, udev, priv); + /* Do not return 0 for not finding MAC addr in HW */ + + ret = usb_ether_register(dev, ueth, RX_URB_SIZE); + if (ret) + return ret; + + /* Register phylib */ + return lan7x_phylib_register(dev); +} + +static const struct eth_ops lan78xx_eth_ops = { + .start = lan78xx_eth_start, + .send = lan7x_eth_send, + .recv = lan7x_eth_recv, + .free_pkt = lan7x_free_pkt, + .stop = lan7x_eth_stop, + .write_hwaddr = lan78xx_write_hwaddr, + .read_rom_hwaddr = lan78xx_read_rom_hwaddr, +}; + +U_BOOT_DRIVER(lan78xx_eth) = { + .name = "lan78xx_eth", + .id = UCLASS_ETH, + .probe = lan78xx_eth_probe, + .remove = lan7x_eth_remove, + .ops = &lan78xx_eth_ops, + .priv_auto_alloc_size = sizeof(struct lan7x_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static const struct usb_device_id lan78xx_eth_id_table[] = { + { USB_DEVICE(0x0424, 0x7800) }, /* LAN7800 USB Ethernet */ + { USB_DEVICE(0x0424, 0x7850) }, /* LAN7850 USB Ethernet */ + { } /* Terminating entry */ +}; + +U_BOOT_USB_DEVICE(lan78xx_eth, lan78xx_eth_id_table); +#endif diff --git a/drivers/usb/eth/lan7x.c b/drivers/usb/eth/lan7x.c new file mode 100644 index 0000000..a2ebbeb --- /dev/null +++ b/drivers/usb/eth/lan7x.c @@ -0,0 +1,506 @@ +/* + * Copyright (c) 2017 Microchip Technology Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm.h> +#include <malloc.h> +#include <miiphy.h> +#include <memalign.h> +#include <usb.h> +#include <linux/ethtool.h> +#include <linux/mii.h> +#include "usb_ether.h" +#include "lan7x.h" + +/* + * Lan7x infrastructure commands + */ +int lan7x_write_reg(struct usb_device *udev, u32 index, u32 data) +{ + int len; + ALLOC_CACHE_ALIGN_BUFFER(u32, tmpbuf, 1); + + cpu_to_le32s(&data); + tmpbuf[0] = data; + + len = usb_control_msg(udev, usb_sndctrlpipe(udev, 0), + USB_VENDOR_REQUEST_WRITE_REGISTER, + USB_DIR_OUT | USB_TYPE_VENDOR | USB_RECIP_DEVICE, + 0, index, tmpbuf, sizeof(data), + USB_CTRL_SET_TIMEOUT_MS); + if (len != sizeof(data)) { + debug("%s failed: index=%d, data=%d, len=%d", + __func__, index, data, len); + return -EIO; + } + return 0; +} + +int lan7x_read_reg(struct usb_device *udev, u32 index, u32 *data) +{ + int len; + ALLOC_CACHE_ALIGN_BUFFER(u32, tmpbuf, 1); + + len = usb_control_msg(udev, usb_rcvctrlpipe(udev, 0), + USB_VENDOR_REQUEST_READ_REGISTER, + USB_DIR_IN | USB_TYPE_VENDOR | USB_RECIP_DEVICE, + 0, index, tmpbuf, sizeof(*data), + USB_CTRL_GET_TIMEOUT_MS); + *data = tmpbuf[0]; + if (len != sizeof(*data)) { + debug("%s failed: index=%d, len=%d", __func__, index, len); + return -EIO; + } + + le32_to_cpus(data); + return 0; +} + +static int lan7x_phy_wait_not_busy(struct usb_device *udev) +{ + return lan7x_wait_for_bit(udev, __func__, + MII_ACC, MII_ACC_MII_BUSY, + false, 100, 0); +} + +int lan7x_mdio_read(struct usb_device *udev, int phy_id, int idx) +{ + u32 val, addr; + + /* confirm MII not busy */ + if (lan7x_phy_wait_not_busy(udev)) { + debug("MII is busy in %s\n", __func__); + return -ETIMEDOUT; + } + + /* set the address, index & direction (read from PHY) */ + addr = (phy_id << 11) | (idx << 6) | + MII_ACC_MII_READ | MII_ACC_MII_BUSY; + lan7x_write_reg(udev, MII_ACC, addr); + + if (lan7x_phy_wait_not_busy(udev)) { + debug("Timed out reading MII reg %02X\n", idx); + return -ETIMEDOUT; + } + + lan7x_read_reg(udev, MII_DATA, &val); + + return val & 0xFFFF; +} + +void lan7x_mdio_write(struct usb_device *udev, int phy_id, int idx, int regval) +{ + u32 addr; + + /* confirm MII not busy */ + if (lan7x_phy_wait_not_busy(udev)) { + debug("MII is busy in %s\n", __func__); + return; + } + + lan7x_write_reg(udev, MII_DATA, regval); + + /* set the address, index & direction (write to PHY) */ + addr = (phy_id << 11) | (idx << 6) | + MII_ACC_MII_WRITE | MII_ACC_MII_BUSY; + lan7x_write_reg(udev, MII_ACC, addr); + + if (lan7x_phy_wait_not_busy(udev)) + debug("Timed out writing MII reg %02X\n", idx); +} + +/* + * Lan7x phylib wrappers + */ +static int lan7x_phylib_mdio_read(struct mii_dev *bus, + int addr, int devad, int reg) +{ + struct usb_device *udev = dev_get_parent_priv(bus->priv); + + return lan7x_mdio_read(udev, addr, reg); +} + +static int lan7x_phylib_mdio_write(struct mii_dev *bus, + int addr, int devad, int reg, u16 val) +{ + struct usb_device *udev = dev_get_parent_priv(bus->priv); + + lan7x_mdio_write(udev, addr, reg, (int)val); + + return 0; +} + +/* + * Lan7x eeprom functions + */ +static int lan7x_eeprom_confirm_not_busy(struct usb_device *udev) +{ + return lan7x_wait_for_bit(udev, __func__, + E2P_CMD, E2P_CMD_EPC_BUSY, + false, 100, 0); +} + +static int lan7x_wait_eeprom(struct usb_device *udev) +{ + return lan7x_wait_for_bit(udev, __func__, + E2P_CMD, + (E2P_CMD_EPC_BUSY | E2P_CMD_EPC_TIMEOUT), + false, 100, 0); +} + +static int lan7x_read_eeprom(struct usb_device *udev, + u32 offset, u32 length, u8 *data) +{ + u32 val; + int i, ret; + + ret = lan7x_eeprom_confirm_not_busy(udev); + if (ret) + return ret; + + for (i = 0; i < length; i++) { + val = E2P_CMD_EPC_BUSY | E2P_CMD_EPC_CMD_READ | + (offset & E2P_CMD_EPC_ADDR_MASK); + lan7x_write_reg(udev, E2P_CMD, val); + + ret = lan7x_wait_eeprom(udev); + if (ret) + return ret; + + lan7x_read_reg(udev, E2P_DATA, &val); + data[i] = val & 0xFF; + offset++; + } + return ret; +} + +/* + * Lan7x phylib functions + */ +int lan7x_phylib_register(struct udevice *udev) +{ + struct lan7x_private *priv = dev_get_priv(udev); + int ret; + + priv->mdiobus = mdio_alloc(); + if (!priv->mdiobus) { + printf("mdio_alloc failed\n"); + return -ENOMEM; + } + priv->mdiobus->read = lan7x_phylib_mdio_read; + priv->mdiobus->write = lan7x_phylib_mdio_write; + strcpy(priv->mdiobus->name, "lan78x_mdiobus"); + priv->mdiobus->priv = (void *)udev; + + ret = mdio_register(priv->mdiobus); + if (ret) { + printf("mdio_register failed\n"); + free(priv->mdiobus); + return -ENOMEM; + } + + return 0; +} + +int lan7x_eth_phylib_connect(struct udevice *udev, struct ueth_data *dev) +{ + struct lan7x_private *priv = dev_get_priv(udev); + + priv->phydev = phy_connect(priv->mdiobus, dev->phy_id, + udev, PHY_INTERFACE_MODE_MII); + + if (!priv->phydev) { + printf("phy_connect failed\n"); + return -ENODEV; + } + return 0; +} + +int lan7x_eth_phylib_config_start(struct udevice *udev) +{ + struct lan7x_private *priv = dev_get_priv(udev); + int ret; + + /* configure supported modes */ + priv->phydev->supported = PHY_BASIC_FEATURES | + SUPPORTED_1000baseT_Full | + SUPPORTED_Pause | + SUPPORTED_Asym_Pause; + + priv->phydev->advertising = ADVERTISED_10baseT_Half | + ADVERTISED_10baseT_Full | + ADVERTISED_100baseT_Half | + ADVERTISED_100baseT_Full | + ADVERTISED_1000baseT_Full | + ADVERTISED_Pause | + ADVERTISED_Asym_Pause | + ADVERTISED_Autoneg; + + priv->phydev->autoneg = AUTONEG_ENABLE; + + ret = genphy_config_aneg(priv->phydev); + if (ret) { + printf("genphy_config_aneg failed\n"); + return ret; + } + ret = phy_startup(priv->phydev); + if (ret) { + printf("phy_startup failed\n"); + return ret; + } + + debug("** %s() speed %i duplex %i adv %X supp %X\n", __func__, + priv->phydev->speed, priv->phydev->duplex, + priv->phydev->advertising, priv->phydev->supported); + + return 0; +} + +int lan7x_update_flowcontrol(struct usb_device *udev, + struct ueth_data *dev, + uint32_t *flow, uint32_t *fct_flow) +{ + uint32_t lcladv, rmtadv; + u8 cap = 0; + struct lan7x_private *priv = dev_get_priv(udev->dev); + + debug("** %s()\n", __func__); + debug("** %s() priv->phydev->speed %i duplex %i\n", __func__, + priv->phydev->speed, priv->phydev->duplex); + + if (priv->phydev->duplex == DUPLEX_FULL) { + lcladv = lan7x_mdio_read(udev, dev->phy_id, MII_ADVERTISE); + rmtadv = lan7x_mdio_read(udev, dev->phy_id, MII_LPA); + cap = mii_resolve_flowctrl_fdx(lcladv, rmtadv); + + debug("TX Flow "); + if (cap & FLOW_CTRL_TX) { + *flow = (FLOW_CR_TX_FCEN | 0xFFFF); + /* set fct_flow thresholds to 20% and 80% */ + *fct_flow = ((MAX_RX_FIFO_SIZE * 2) / (10 * 512)) + & 0x7FUL; + *fct_flow <<= 8UL; + *fct_flow |= ((MAX_RX_FIFO_SIZE * 8) / (10 * 512)) + & 0x7FUL; + debug("EN "); + } else { + debug("DIS "); + } + debug("RX Flow "); + if (cap & FLOW_CTRL_RX) { + *flow |= FLOW_CR_RX_FCEN; + debug("EN"); + } else { + debug("DIS"); + } + } + debug("\n"); + return 0; +} + +int lan7x_read_eeprom_mac(unsigned char *enetaddr, struct usb_device *udev) +{ + int ret; + + memset(enetaddr, 0, 6); + + ret = lan7x_read_eeprom(udev, 0, 1, enetaddr); + + if ((ret == 0) && (enetaddr[0] == EEPROM_INDICATOR)) { + ret = lan7x_read_eeprom(udev, + EEPROM_MAC_OFFSET, ETH_ALEN, + enetaddr); + if ((ret == 0) && is_valid_ethaddr(enetaddr)) { + /* eeprom values are valid so use them */ + debug("MAC address read from EEPROM %pM\n", + enetaddr); + return 0; + } + } + debug("MAC address read from EEPROM invalid %pM\n", enetaddr); + + memset(enetaddr, 0, 6); + return -EINVAL; +} + +int lan7x_pmt_phy_reset(struct usb_device *udev, + struct ueth_data *dev) +{ + int ret; + u32 data; + + ret = lan7x_read_reg(udev, PMT_CTL, &data); + if (ret) + return ret; + ret = lan7x_write_reg(udev, PMT_CTL, data | PMT_CTL_PHY_RST); + if (ret) + return ret; + + /* for LAN7x, we need to check PMT_CTL_READY asserted */ + ret = lan7x_wait_for_bit(udev, "PMT_CTL_PHY_RST", + PMT_CTL, PMT_CTL_PHY_RST, + false, 1000, 0); /* could take over 125mS */ + if (ret) + return ret; + + return lan7x_wait_for_bit(udev, "PMT_CTL_READY", + PMT_CTL, PMT_CTL_READY, + true, 1000, 0); +} + +int lan7x_basic_reset(struct usb_device *udev, + struct ueth_data *dev) +{ + int ret; + + dev->phy_id = LAN7X_INTERNAL_PHY_ID; /* fixed phy id */ + + ret = lan7x_write_reg(udev, HW_CFG, HW_CFG_LRST); + if (ret) + return ret; + + ret = lan7x_wait_for_bit(udev, "HW_CFG_LRST", + HW_CFG, HW_CFG_LRST, + false, 1000, 0); + if (ret) + return ret; + + return lan7x_pmt_phy_reset(udev, dev); +} + +#ifdef CONFIG_DM_ETH +void lan7x_eth_stop(struct udevice *dev) +{ + debug("** %s()\n", __func__); +} + +int lan7x_eth_send(struct udevice *dev, void *packet, int length) +{ + struct lan7x_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + int err; + int actual_len; + u32 tx_cmd_a; + u32 tx_cmd_b; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, msg, + PKTSIZE + sizeof(tx_cmd_a) + sizeof(tx_cmd_b)); + + debug("** %s(), len %d, buf %#x\n", __func__, length, + (unsigned int)(ulong) msg); + if (length > PKTSIZE) + return -ENOSPC; + + /* LAN7x disable all TX offload features for u-boot */ + tx_cmd_a = (u32) (length & TX_CMD_A_LEN_MASK) | TX_CMD_A_FCS; + tx_cmd_b = 0; + cpu_to_le32s(&tx_cmd_a); + cpu_to_le32s(&tx_cmd_b); + + /* prepend cmd_a and cmd_b */ + memcpy(msg, &tx_cmd_a, sizeof(tx_cmd_a)); + memcpy(msg + sizeof(tx_cmd_a), &tx_cmd_b, sizeof(tx_cmd_b)); + memcpy(msg + sizeof(tx_cmd_a) + sizeof(tx_cmd_b), (void *)packet, + length); + err = usb_bulk_msg(ueth->pusb_dev, + usb_sndbulkpipe(ueth->pusb_dev, ueth->ep_out), + (void *)msg, + length + sizeof(tx_cmd_a) + + sizeof(tx_cmd_b), + &actual_len, USB_BULK_SEND_TIMEOUT_MS); + debug("Tx: len = %u, actual = %u, err = %d\n", + (unsigned int)(length + sizeof(tx_cmd_a) + sizeof(tx_cmd_b)), + (unsigned int)actual_len, err); + + return err; +} + +int lan7x_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct lan7x_private *priv = dev_get_priv(dev); + struct ueth_data *ueth = &priv->ueth; + DEFINE_CACHE_ALIGN_BUFFER(unsigned char, recv_buf, RX_URB_SIZE); + unsigned char *buf_ptr; + int err; + int actual_len = 0; + u32 packet_len = 0; + u32 rx_cmd_a = 0; + + err = usb_bulk_msg(ueth->pusb_dev, + usb_rcvbulkpipe(ueth->pusb_dev, ueth->ep_in), + (void *)recv_buf, RX_URB_SIZE, &actual_len, + USB_BULK_RECV_TIMEOUT_MS); + + debug("Rx: RX_URB_SIZE = %u, actual = %u, err = %d\n", RX_URB_SIZE, + actual_len, err); + if (err != 0) { + debug("Rx: failed to receive\n"); + return err; + } + if (actual_len > RX_URB_SIZE) { + debug("Rx: received too many bytes %d\n", actual_len); + return -ENOSPC; + } + + buf_ptr = recv_buf; + + /* + * No multiple Ethernet Frames per USB Packet (MEF) used + * for the U-boot for now. + */ + if (actual_len > 0) { + if (actual_len < sizeof(rx_cmd_a)) { + debug("Rx: incomplete packet length\n"); + return -EIO; + } + memcpy(&rx_cmd_a, buf_ptr, sizeof(rx_cmd_a)); + le32_to_cpus(&rx_cmd_a); + if (rx_cmd_a & RX_CMD_A_RXE) { + debug("Rx: Error header=%#x", rx_cmd_a); + return -EIO; + } + packet_len = (u16) (rx_cmd_a & RX_CMD_A_LEN_MASK); + + if (packet_len > actual_len - sizeof(packet_len)) { + debug("Rx: too large packet: %d\n", packet_len); + return -EIO; + } + + /* + * For LAN7x, the length in command A does not + * include command A, B, and C length. + * So use it as is. + */ + + debug("Rx: cmd_a 0x%08X packet_len %d\n", rx_cmd_a, packet_len); + + /* Notify net stack */ + net_process_received_packet(buf_ptr + 10, packet_len); + } + + return err; +} + +int lan7x_free_pkt(struct udevice *dev, uchar *packet, int packet_len) +{ + struct lan7x_private *priv = dev_get_priv(dev); + + packet_len = ALIGN(packet_len, 4); + usb_ether_advance_rxbuf(&priv->ueth, sizeof(u32) + packet_len); + + return 0; +} + +int lan7x_eth_remove(struct udevice *dev) +{ + struct lan7x_private *priv = dev_get_priv(dev); + + debug("** %s()\n", __func__); + free(priv->phydev); + mdio_unregister(priv->mdiobus); + mdio_free(priv->mdiobus); + + return 0; +} +#endif /* CONFIG_DM_ETH */ diff --git a/drivers/usb/eth/lan7x.h b/drivers/usb/eth/lan7x.h new file mode 100644 index 0000000..6f4647a --- /dev/null +++ b/drivers/usb/eth/lan7x.h @@ -0,0 +1,232 @@ +/* + * Copyright (c) 2017 Microchip Technology Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <console.h> +#include <watchdog.h> + +/* USB Vendor Requests */ +#define USB_VENDOR_REQUEST_WRITE_REGISTER 0xA0 +#define USB_VENDOR_REQUEST_READ_REGISTER 0xA1 +#define USB_VENDOR_REQUEST_GET_STATS 0xA2 + +/* Tx Command A */ +#define TX_CMD_A_FCS BIT(22) +#define TX_CMD_A_LEN_MASK 0x000FFFFF + +/* Rx Command A */ +#define RX_CMD_A_RXE BIT(18) +#define RX_CMD_A_LEN_MASK 0x00003FFF + +/* SCSRs */ +#define ID_REV 0x00 +#define ID_REV_CHIP_ID_MASK 0xFFFF0000 +#define ID_REV_CHIP_ID_7500 0x7500 +#define ID_REV_CHIP_ID_7800 0x7800 +#define ID_REV_CHIP_ID_7850 0x7850 + +#define INT_STS 0x0C + +#define HW_CFG 0x010 +#define HW_CFG_LRST BIT(1) + +#define PMT_CTL 0x014 +#define PMT_CTL_PHY_PWRUP BIT(10) +#define PMT_CTL_READY BIT(7) +#define PMT_CTL_PHY_RST BIT(4) + +#define E2P_CMD 0x040 +#define E2P_CMD_EPC_BUSY BIT(31) +#define E2P_CMD_EPC_CMD_READ 0x00000000 +#define E2P_CMD_EPC_TIMEOUT BIT(10) +#define E2P_CMD_EPC_ADDR_MASK 0x000001FF + +#define E2P_DATA 0x044 + +#define RFE_CTL_BCAST_EN BIT(10) +#define RFE_CTL_DA_PERFECT BIT(1) + +#define FCT_RX_CTL_EN BIT(31) + +#define FCT_TX_CTL_EN BIT(31) + +#define MAC_CR 0x100 +#define MAC_CR_ADP BIT(13) +#define MAC_CR_AUTO_DUPLEX BIT(12) +#define MAC_CR_AUTO_SPEED BIT(11) + +#define MAC_RX 0x104 +#define MAC_RX_FCS_STRIP BIT(4) +#define MAC_RX_RXEN BIT(0) + +#define MAC_TX 0x108 +#define MAC_TX_TXEN BIT(0) + +#define FLOW 0x10C +#define FLOW_CR_TX_FCEN BIT(30) +#define FLOW_CR_RX_FCEN BIT(29) + +#define RX_ADDRH 0x118 +#define RX_ADDRL 0x11C + +#define MII_ACC 0x120 +#define MII_ACC_MII_READ 0x00000000 +#define MII_ACC_MII_WRITE 0x00000002 +#define MII_ACC_MII_BUSY BIT(0) + +#define MII_DATA 0x124 + +#define SS_USB_PKT_SIZE 1024 +#define HS_USB_PKT_SIZE 512 +#define FS_USB_PKT_SIZE 64 + +#define MAX_RX_FIFO_SIZE (12 * 1024) +#define MAX_TX_FIFO_SIZE (12 * 1024) +#define DEFAULT_BULK_IN_DELAY 0x0800 + +#define EEPROM_INDICATOR 0xA5 +#define EEPROM_MAC_OFFSET 0x01 + +/* Some extra defines */ +#define LAN7X_INTERNAL_PHY_ID 1 + +#define LAN7X_MAC_RX_MAX_SIZE(mtu) \ + ((mtu) << 16) /* Max frame size */ +#define LAN7X_MAC_RX_MAX_SIZE_DEFAULT \ + LAN7X_MAC_RX_MAX_SIZE(ETH_FRAME_LEN + 4 /* VLAN */ + 4 /* CRC */) + +/* Timeouts */ +#define USB_CTRL_SET_TIMEOUT_MS 5000 +#define USB_CTRL_GET_TIMEOUT_MS 5000 +#define USB_BULK_SEND_TIMEOUT_MS 5000 +#define USB_BULK_RECV_TIMEOUT_MS 5000 +#define TIMEOUT_RESOLUTION_MS 50 +#define PHY_CONNECT_TIMEOUT_MS 5000 + +#define RX_URB_SIZE 2048 + +/* driver private */ +struct lan7x_private { + struct ueth_data ueth; + u32 chipid; /* Chip or device ID */ + struct mii_dev *mdiobus; + struct phy_device *phydev; +}; + +/* + * Lan7x infrastructure commands + */ + +int lan7x_write_reg(struct usb_device *udev, u32 index, u32 data); + +int lan7x_read_reg(struct usb_device *udev, u32 index, u32 *data); + +static inline int lan7x_wait_for_bit(struct usb_device *udev, + const char *prefix, const u32 reg, + const u32 mask, const bool set, + const unsigned int timeout_ms, + const bool breakable) +{ + u32 val; + unsigned long start = get_timer(0); + + while (1) { + lan7x_read_reg(udev, reg, &val); + + if (!set) + val = ~val; + + if ((val & mask) == mask) + return 0; + + if (get_timer(start) > timeout_ms) + break; + + if (breakable && ctrlc()) { + puts("Abort\n"); + return -EINTR; + } + + udelay(1); + WATCHDOG_RESET(); + } + + debug("%s: Timeout (reg=0x%x mask=%08x wait_set=%i)\n", prefix, reg, + mask, set); + + return -ETIMEDOUT; +} + +int lan7x_mdio_read(struct usb_device *udev, int phy_id, int idx); + +void lan7x_mdio_write(struct usb_device *udev, int phy_id, int idx, + int regval); + +static inline int lan7x_mdio_wait_for_bit(struct usb_device *udev, + const char *prefix, + int phy_id, const u32 reg, + const u32 mask, const bool set, + const unsigned int timeout_ms, + const bool breakable) +{ + u32 val; + unsigned long start = get_timer(0); + + while (1) { + val = lan7x_mdio_read(udev, phy_id, reg); + + if (!set) + val = ~val; + + if ((val & mask) == mask) + return 0; + + if (get_timer(start) > timeout_ms) + break; + + if (breakable && ctrlc()) { + puts("Abort\n"); + return -EINTR; + } + + udelay(1); + WATCHDOG_RESET(); + } + + debug("%s: Timeout (reg=0x%x mask=%08x wait_set=%i)\n", prefix, reg, + mask, set); + + return -ETIMEDOUT; +} + +int lan7x_phylib_register(struct udevice *udev); + +int lan7x_eth_phylib_connect(struct udevice *udev, struct ueth_data *dev); + +int lan7x_eth_phylib_config_start(struct udevice *udev); + +int lan7x_pmt_phy_reset(struct usb_device *udev, + struct ueth_data *dev); + +int lan7x_update_flowcontrol(struct usb_device *udev, + struct ueth_data *dev, + uint32_t *flow, uint32_t *fct_flow); + +int lan7x_read_eeprom_mac(unsigned char *enetaddr, struct usb_device *udev); + +int lan7x_basic_reset(struct usb_device *udev, + struct ueth_data *dev); + +#ifdef CONFIG_DM_ETH +void lan7x_eth_stop(struct udevice *dev); + +int lan7x_eth_send(struct udevice *dev, void *packet, int length); + +int lan7x_eth_recv(struct udevice *dev, int flags, uchar **packetp); + +int lan7x_free_pkt(struct udevice *dev, uchar *packet, int packet_len); + +int lan7x_eth_remove(struct udevice *dev); +#endif /* CONFIG_DM_ETH */
Hi Yuiko,
Changes for v2:
- uses phylib
---help---
---help---
- Copyright (c) 2017 Microchip Technology Inc. All rights reserved.
- Lan75xx infrastructure commands
int ret = 0;
if (ret)
return ret;
/* phy reset */
int ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
u32 val;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
u32 write_buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
/* Init Tx */
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
if (ret)
int ret;
if (ret)
return ret;
.id = UCLASS_ETH,
LAN78XX_MAF_HIX)
LAN78XX_MAF_LOX)
- Lan78xx infrastructure commands
int i;
int ret;
u32 buf;
if (ret)
return ret;
if (ret)
return ret;
LAN78XX_OTP_PWR_DN,
false, 1000, 0);
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
LAN78XX_OTP_STATUS,
false, 1000, 0);
if (ret)
return ret;
if (ret)
return ret;
u8 sig;
int ret;
if (!ret) {
offset = offset;
offset += 0x100;
else
return -EINVAL;
if (ret)
return ret;
return ret;
int ret;
EEPROM_MAC_OFFSET,
ETH_ALEN,
enetaddr);
return -EINVAL;
int ret;
if (ret)
return ret;
if (ret)
return ret;
u32 val;
int ret;
if (ret)
return ret;
saved = val;
if (ret)
goto restore;
if (!ret)
done = 1;
+restore:
if (ret)
return ret;
if (done)
int ret;
u32 val;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
u32 write_buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
/* Init Tx */
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
int ret;
if (ret)
int ret;
if (ret)
return ret;
.id = UCLASS_ETH,
- Lan7x infrastructure commands
int len;
tmpbuf[0] = data;
return -EIO;
int len;
*data = tmpbuf[0];
return -EIO;
le32_to_cpus(data);
false, 100, 0);
u32 val, addr;
return -ETIMEDOUT;
return -ETIMEDOUT;
u32 addr;
return;
- Lan7x phylib wrappers
- Lan7x eeprom functions
false, 100, 0);
E2P_CMD,
false, 100, 0);
u32 val;
int i, ret;
if (ret)
return ret;
if (ret)
return ret;
offset++;
return ret;
- Lan7x phylib functions
int ret;
return -ENOMEM;
if (ret) {
return -ENOMEM;
return -ENODEV;
int ret;
SUPPORTED_Pause |
ADVERTISED_Pause |
ADVERTISED_Autoneg;
if (ret) {
return ret;
if (ret) {
return ret;
u8 cap = 0;
debug("TX Flow ");
& 0x7FUL;
*fct_flow <<= 8UL;
& 0x7FUL;
debug("EN ");
} else {
debug("DIS ");
debug("RX Flow ");
debug("EN");
} else {
debug("DIS");
debug("\n");
int ret;
enetaddr);
enetaddr);
return -EINVAL;
int ret;
u32 data;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
true, 1000, 0);
int ret;
if (ret)
return ret;
false, 1000, 0);
if (ret)
return ret;
int err;
int actual_len;
u32 tx_cmd_a;
u32 tx_cmd_b;
return -ENOSPC;
tx_cmd_b = 0;
length);
(void *)msg,
sizeof(tx_cmd_b),
return err;
int err;
int actual_len = 0;
u32 packet_len = 0;
u32 rx_cmd_a = 0;
actual_len, err);
if (err != 0) {
return err;
return -ENOSPC;
buf_ptr = recv_buf;
return -EIO;
return -EIO;
return -EIO;
* So use it as is.
This is not correct. See eth_rx in net/net-uclass.c
You are expected to return the number of bytes written to the packetp buffer.
The framework will then handle the packed for you and call your free_pkt() function.
return err;
free(priv->phydev);
u32 val;
while (1) {
if (!set)
val = ~val;
break;
puts("Abort\n");
return -EINTR;
udelay(1);
WATCHDOG_RESET();
mask, set);
return -ETIMEDOUT;
int regval);
const char *prefix,
u32 val;
while (1) {
if (!set)
val = ~val;
break;
puts("Abort\n");
return -EINTR;
udelay(1);
WATCHDOG_RESET();
mask, set);
return -ETIMEDOUT;
This should always be the case on a new driver. Anything that is supporting non-DM should be dropped from the patch.
2.7.4
Joe Hershberger
