[U-Boot] [PATCH v7 00/26] pmic: Redesign PMIC framework to support multiple instances of devices
PMIC framework has been redesigned to support multiple instances of power related devices (e.g. fuel gauge, PMICs, chargers, micro USB IC, battery).
Due to that, code at other architectures and boards have been adjusted properly.
New power_init_board() method at ./lib/board.c file has been introduced. It is meant to be an architecture dependent function to support advanced power management. Since PMIC framework uses lists internally to link different devices, its initialization must be done just after malloc initialization.
Please consider commits from this patch set as the example of advanced power management for a particular HW (Trats board in this case).
In the new approach PMICs are selected with their names (e.g. 'pmic dump MAX8997_PMIC') Presented patch set is a first step to change 'pmic' command to more generic (i.e. power) to provide control for multiple devices.
Moreover device's battery is treated as an oridinary "power" device (like PMIC). Due to that, framework unification is possible. For even more versalite design, each power device instance can specify its parent.
For trats one can build a following scheme (it can de different for other boards): ----------------- --------| BAT |------------ | | | | | ----------------- | | | | |/ |/ |/ ----------- ----------------- --------- |FG | |MUIC | |CHRG | | | | | | | ----------- ----------------- ---------
Finally, this patch series also comprises of a "namespace" cleanup - an attempt to rename "pmic" to "power" to better reflect generality of this framework.
Test HW: - Exynos4210 Trats development board - Exynos3 (C110) Goni development board
Lukasz Majewski (26): pmic:i2c: Handle PMIC I2C transmission comprising of two bytes pmic:i2c: Add I2C sensor byte order (big/little) to PMIC framework pmic:max8997: Switch the MAX8997 PMIC to be used with multibus I2C pmic: Extend PMIC framework to support multiple instances of PMIC devices pmic: Introduce power_init_board() method at ./lib/board.c file pmic: Enable power_board_init() support at TRATS pmic:chrg: Common information about charger and battery (power_chrg.h) pmic: Move pmic related code to ./drivers/power directory pmic: Extend struct pmic to support battery and charger related operations pmic:battery: Support for Trats Battery at PMIC framework pmic:muic: Support for MUIC built into MAX8997 device pmic:fuel-gauge: Support for MAX17042 fuel-gauge pmic:max8997: Function for calculating LDO internal register value arm:trats:pmic: Default PMIC(MAX8997) initialization for Samsung's TRATS board arm:trats:pmic: Enable MUIC (MAX8997) at Samsung's TRATS board arm:trats:pmic: Enable fuel-gauge (MAX17042) at Samsung's TRATS board arm:trats:pmic: Enable battery support at Samsung's TRATS board pmic:max8997: Support for MAX8997 internal charger control arm:trats:pmic: Power consumption reduction state for Samsung's TRATS board arm:trats:pmic: Support for charging battery at Samsung's TRATS board pmic: Extend PMIC framework to support battery related commands power:pmic: Rename ./drivers/power/pmic_* to ./drivers/power/power_* files power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWER power:pmic: Rename CONFIG_DIALOG_PMIC defines to CONFIG_DIALOG_POWER arm:goni:pmic: Adjust GONI target platform board to new PMIC framework arm:universal_c210:pmic: Adjust C210 Universal target platform board to new PMIC framework
Makefile | 5 +- arch/arm/lib/board.c | 8 + board/davedenx/qong/qong.c | 12 +- board/freescale/mx31pdk/mx31pdk.c | 12 +- board/freescale/mx35pdk/mx35pdk.c | 14 +- board/freescale/mx51evk/mx51evk.c | 12 +- board/freescale/mx53evk/mx53evk.c | 12 +- board/freescale/mx53loco/mx53loco.c | 21 +- board/genesi/mx51_efikamx/efikamx.c | 12 +- board/hale/tt01/tt01.c | 14 +- board/samsung/goni/goni.c | 22 +- board/samsung/trats/trats.c | 292 +++++++++++++++++++- board/samsung/universal_c210/universal.c | 27 ++- board/ttcontrol/vision2/vision2.c | 12 +- drivers/misc/Makefile | 7 - drivers/misc/pmic_core.c | 147 ---------- drivers/misc/pmic_i2c.c | 98 ------- drivers/misc/pmic_max8997.c | 43 --- drivers/power/Makefile | 12 +- drivers/power/battery/Makefile | 47 ++++ drivers/power/battery/bat_trats.c | 100 +++++++ drivers/power/fuel_gauge/Makefile | 47 ++++ drivers/power/fuel_gauge/fg_max17042.c | 250 +++++++++++++++++ drivers/power/pmic/Makefile | 49 ++++ drivers/power/pmic/muic_max8997.c | 90 ++++++ drivers/power/pmic/pmic_max8997.c | 123 ++++++++ drivers/{misc => power/pmic}/pmic_max8998.c | 16 +- drivers/power/power_core.c | 232 ++++++++++++++++ .../{misc/pmic_dialog.c => power/power_dialog.c} | 14 +- drivers/{misc/pmic_fsl.c => power/power_fsl.c} | 22 +- drivers/power/power_i2c.c | 125 +++++++++ drivers/{misc/pmic_spi.c => power/power_spi.c} | 4 +- drivers/rtc/mc13xxx-rtc.c | 10 +- include/configs/imx31_litekit.h | 6 +- include/configs/mx31ads.h | 6 +- include/configs/mx31pdk.h | 6 +- include/configs/mx35pdk.h | 6 +- include/configs/mx51_efikamx.h | 6 +- include/configs/mx51evk.h | 6 +- include/configs/mx53evk.h | 6 +- include/configs/mx53loco.h | 8 +- include/configs/qong.h | 6 +- include/configs/s5p_goni.h | 6 +- include/configs/s5pc210_universal.h | 6 +- include/configs/trats.h | 14 +- include/configs/tt01.h | 6 +- include/configs/vision2.h | 6 +- include/pmic.h | 72 ----- include/power/battery.h | 38 +++ include/power/fg_battery_cell_params.h | 90 ++++++ include/power/max17042_fg.h | 74 +++++ include/power/max8997_muic.h | 61 ++++ include/{ => power}/max8997_pmic.h | 26 ++- include/{ => power}/max8998_pmic.h | 0 include/power/pmic.h | 109 ++++++++ include/power/power_chrg.h | 43 +++ 56 files changed, 2027 insertions(+), 491 deletions(-) delete mode 100644 drivers/misc/pmic_core.c delete mode 100644 drivers/misc/pmic_i2c.c delete mode 100644 drivers/misc/pmic_max8997.c create mode 100644 drivers/power/battery/Makefile create mode 100644 drivers/power/battery/bat_trats.c create mode 100644 drivers/power/fuel_gauge/Makefile create mode 100644 drivers/power/fuel_gauge/fg_max17042.c create mode 100644 drivers/power/pmic/Makefile create mode 100644 drivers/power/pmic/muic_max8997.c create mode 100644 drivers/power/pmic/pmic_max8997.c rename drivers/{misc => power/pmic}/pmic_max8998.c (82%) create mode 100644 drivers/power/power_core.c rename drivers/{misc/pmic_dialog.c => power/power_dialog.c} (81%) rename drivers/{misc/pmic_fsl.c => power/power_fsl.c} (81%) create mode 100644 drivers/power/power_i2c.c rename drivers/{misc/pmic_spi.c => power/power_spi.c} (97%) delete mode 100644 include/pmic.h create mode 100644 include/power/battery.h create mode 100644 include/power/fg_battery_cell_params.h create mode 100644 include/power/max17042_fg.h create mode 100644 include/power/max8997_muic.h rename include/{ => power}/max8997_pmic.h (88%) rename include/{ => power}/max8998_pmic.h (100%) create mode 100644 include/power/pmic.h create mode 100644 include/power/power_chrg.h
This patch adds support for proper handling of a PMIC I2C transmission comprising of two bytes.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/misc/pmic_i2c.c | 9 ++++++++- 1 files changed, 8 insertions(+), 1 deletions(-)
diff --git a/drivers/misc/pmic_i2c.c b/drivers/misc/pmic_i2c.c index 95a3365..e74c372 100644 --- a/drivers/misc/pmic_i2c.c +++ b/drivers/misc/pmic_i2c.c @@ -44,6 +44,10 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val) buf[1] = (val >> 8) & 0xff; buf[2] = val & 0xff; break; + case 2: + buf[0] = (val >> 8) & 0xff; + buf[1] = val & 0xff; + break; case 1: buf[0] = val & 0xff; break; @@ -73,6 +77,9 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) case 3: ret_val = buf[0] << 16 | buf[1] << 8 | buf[2]; break; + case 2: + ret_val = buf[0] << 8 | buf[1]; + break; case 1: ret_val = buf[0]; break; @@ -88,7 +95,7 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) int pmic_probe(struct pmic *p) { I2C_SET_BUS(p->bus); - debug("PMIC:%s probed!\n", p->name); + debug("Bus: %d PMIC:%s probed!\n", p->bus, p->name); if (i2c_probe(pmic_i2c_addr)) { printf("Can't find PMIC:%s\n", p->name); return -1;
Since the pmic_reg_read is the u32 value, the order in which bytes are placed to form u32 value is important.
Support for big and little sensor endianess is added.
Moreover calls to [leXX|beXX]_to_cpu have been added to support little and big endian SoCs.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes for v2: - Move byte_order variable to struct pmic Changes for v3: - New names for sensor endianess (more readable) - Support for SoCs with different endianess Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/misc/pmic_i2c.c | 38 +++++++++++++++++++++++++++++--------- include/pmic.h | 2 ++ 2 files changed, 31 insertions(+), 9 deletions(-)
diff --git a/drivers/misc/pmic_i2c.c b/drivers/misc/pmic_i2c.c index e74c372..1064bfe 100644 --- a/drivers/misc/pmic_i2c.c +++ b/drivers/misc/pmic_i2c.c @@ -30,6 +30,7 @@ #include <linux/types.h> #include <pmic.h> #include <i2c.h> +#include <compiler.h>
int pmic_reg_write(struct pmic *p, u32 reg, u32 val) { @@ -40,16 +41,27 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val)
switch (pmic_i2c_tx_num) { case 3: - buf[0] = (val >> 16) & 0xff; - buf[1] = (val >> 8) & 0xff; - buf[2] = val & 0xff; + if (p->sensor_byte_order == PMIC_SENSOR_BYTE_ORDER_BIG) { + buf[2] = (cpu_to_le32(val) >> 16) & 0xff; + buf[1] = (cpu_to_le32(val) >> 8) & 0xff; + buf[0] = cpu_to_le32(val) & 0xff; + } else { + buf[0] = (cpu_to_le32(val) >> 16) & 0xff; + buf[1] = (cpu_to_le32(val) >> 8) & 0xff; + buf[2] = cpu_to_le32(val) & 0xff; + } break; case 2: - buf[0] = (val >> 8) & 0xff; - buf[1] = val & 0xff; + if (p->sensor_byte_order == PMIC_SENSOR_BYTE_ORDER_BIG) { + buf[1] = (cpu_to_le32(val) >> 8) & 0xff; + buf[0] = cpu_to_le32(val) & 0xff; + } else { + buf[0] = (cpu_to_le32(val) >> 8) & 0xff; + buf[1] = cpu_to_le32(val) & 0xff; + } break; case 1: - buf[0] = val & 0xff; + buf[0] = cpu_to_le32(val) & 0xff; break; default: printf("%s: invalid tx_num: %d", __func__, pmic_i2c_tx_num); @@ -75,13 +87,21 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val)
switch (pmic_i2c_tx_num) { case 3: - ret_val = buf[0] << 16 | buf[1] << 8 | buf[2]; + if (p->sensor_byte_order == PMIC_SENSOR_BYTE_ORDER_BIG) + ret_val = le32_to_cpu(buf[2] << 16 + | buf[1] << 8 | buf[0]); + else + ret_val = le32_to_cpu(buf[0] << 16 | + buf[1] << 8 | buf[2]); break; case 2: - ret_val = buf[0] << 8 | buf[1]; + if (p->sensor_byte_order == PMIC_SENSOR_BYTE_ORDER_BIG) + ret_val = le32_to_cpu(buf[1] << 8 | buf[0]); + else + ret_val = le32_to_cpu(buf[0] << 8 | buf[1]); break; case 1: - ret_val = buf[0]; + ret_val = le32_to_cpu(buf[0]); break; default: printf("%s: invalid tx_num: %d", __func__, pmic_i2c_tx_num); diff --git a/include/pmic.h b/include/pmic.h index 6a05b40..1a2db05 100644 --- a/include/pmic.h +++ b/include/pmic.h @@ -27,6 +27,7 @@ enum { PMIC_I2C, PMIC_SPI, }; enum { I2C_PMIC, I2C_NUM, }; enum { PMIC_READ, PMIC_WRITE, }; +enum { PMIC_SENSOR_BYTE_ORDER_LITTLE, PMIC_SENSOR_BYTE_ORDER_BIG, };
struct p_i2c { unsigned char addr; @@ -47,6 +48,7 @@ struct pmic { const char *name; unsigned char bus; unsigned char interface; + unsigned char sensor_byte_order; unsigned char number_of_regs; union hw { struct p_i2c i2c;
PMIC MAX8997 is now ready to work with single and multibus soft I2C implementation.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/misc/pmic_max8997.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/misc/pmic_max8997.c b/drivers/misc/pmic_max8997.c index 62dbc05..4943f66 100644 --- a/drivers/misc/pmic_max8997.c +++ b/drivers/misc/pmic_max8997.c @@ -24,6 +24,7 @@ #include <common.h> #include <pmic.h> #include <max8997_pmic.h> +#include <i2c.h>
int pmic_init(void) { @@ -37,7 +38,7 @@ int pmic_init(void) p->number_of_regs = PMIC_NUM_OF_REGS; p->hw.i2c.addr = MAX8997_I2C_ADDR; p->hw.i2c.tx_num = 1; - p->bus = I2C_PMIC; + p->bus = I2C_0;
return 0; }
The PMIC framework has been extended to support multiple instances of the variety of devices responsible for power management. This change allows supporting of e.g. fuel gauge, charger, MUIC (Micro USB Interface Circuit). Power related includes have been moved to ./include/power directory. This is a first of a series of patches - in the future "pmic" will be replaced with "power".
Two important issues: 1. The PMIC needs to be initialized just after malloc is configured 2. It uses list to hold information about available PMIC devices
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - Convert mx51_efikamx board from genesi to new pmic/power framework Changes for v6: - None Changes for v7: - Check pmic_alloc() return value (to prevent NULL pointer dereference) - Check pmic_init() return value - Check pmic_get() return value --- board/davedenx/qong/qong.c | 12 +++- board/freescale/mx31pdk/mx31pdk.c | 12 +++- board/freescale/mx35pdk/mx35pdk.c | 14 +++- board/freescale/mx51evk/mx51evk.c | 12 +++- board/freescale/mx53evk/mx53evk.c | 12 +++- board/freescale/mx53loco/mx53loco.c | 21 ++++-- board/genesi/mx51_efikamx/efikamx.c | 12 +++- board/hale/tt01/tt01.c | 14 +++- board/samsung/goni/goni.c | 11 ++- board/samsung/trats/trats.c | 18 +++-- board/samsung/universal_c210/universal.c | 14 +++-- board/ttcontrol/vision2/vision2.c | 12 +++- drivers/misc/pmic_core.c | 116 ++++++++++++++++++++++------- drivers/misc/pmic_dialog.c | 14 +++- drivers/misc/pmic_fsl.c | 14 +++- drivers/misc/pmic_i2c.c | 6 +- drivers/misc/pmic_max8997.c | 16 +++-- drivers/misc/pmic_max8998.c | 16 +++-- drivers/misc/pmic_spi.c | 4 +- drivers/rtc/mc13xxx-rtc.c | 10 ++- include/{ => power}/max8997_pmic.h | 15 ++++- include/{ => power}/max8998_pmic.h | 0 include/{ => power}/pmic.h | 19 ++++-- 23 files changed, 288 insertions(+), 106 deletions(-) rename include/{ => power}/max8997_pmic.h (92%) rename include/{ => power}/max8998_pmic.h (100%) rename include/{ => power}/pmic.h (84%)
diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index c41f11d..a3079db 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -28,11 +28,12 @@ #include <asm/arch/sys_proto.h> #include <asm/io.h> #include <nand.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <asm/gpio.h> #include "qong_fpga.h" #include <watchdog.h> +#include <errno.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -172,10 +173,15 @@ int board_late_init(void) { u32 val; struct pmic *p; + int ret;
- pmic_init(); - p = get_pmic(); + ret = pmic_init(I2C_PMIC); + if (ret) + return ret;
+ p = pmic_get("FSL_PMIC"); + if (!p) + return -ENODEV; /* Enable RTC battery */ pmic_reg_read(p, REG_POWER_CTL0, &val); pmic_reg_write(p, REG_POWER_CTL0, val | COINCHEN); diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 9f8bc53..bc60632 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -30,8 +30,9 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> #include <watchdog.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> +#include <errno.h>
@@ -83,10 +84,15 @@ int board_late_init(void) { u32 val; struct pmic *p; + int ret;
+ p = pmic_get("FSL_PMIC"); + if (!p) + return -ENODEV; /* Enable RTC battery */ pmic_reg_read(p, REG_POWER_CTL0, &val); pmic_reg_write(p, REG_POWER_CTL0, val | COINCHEN); diff --git a/board/freescale/mx35pdk/mx35pdk.c b/board/freescale/mx35pdk/mx35pdk.c index a12531f..c835b0e 100644 --- a/board/freescale/mx35pdk/mx35pdk.c +++ b/board/freescale/mx35pdk/mx35pdk.c @@ -31,7 +31,7 @@ #include <asm/arch/mx35_pins.h> #include <asm/arch/iomux.h> #include <i2c.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <mmc.h> #include <fsl_esdhc.h> @@ -207,7 +207,9 @@ int board_init(void) static inline int pmic_detect(void) { unsigned int id; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("FSL_PMIC"); + if (!p) + return -ENODEV;
pmic_reg_read(p, REG_IDENTIFICATION, &id);
@@ -231,10 +233,14 @@ int board_late_init(void) u8 val; u32 pmic_val; struct pmic *p; + int ret; + + ret = pmic_init(I2C_PMIC); + if (ret) + return ret;
- pmic_init(); if (pmic_detect()) { - p = get_pmic(); + p = pmic_get("FSL_PMIC"); mxc_request_iomux(MX35_PIN_WATCHDOG_RST, MUX_CONFIG_SION | MUX_CONFIG_ALT1);
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 421d8c2..5504636 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -33,7 +33,7 @@ #include <i2c.h> #include <mmc.h> #include <fsl_esdhc.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <mc13892.h> #include <usb/ehci-fsl.h> @@ -252,9 +252,15 @@ static void power_init(void) unsigned int val; struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)MXC_CCM_BASE; struct pmic *p; + int ret; + + ret = pmic_init(I2C_PMIC); + if (ret) + return;
- pmic_init(); - p = get_pmic(); + p = pmic_get("FSL_PMIC"); + if (!p) + return;
/* Write needed to Power Gate 2 register */ pmic_reg_read(p, REG_POWER_MISC, &val); diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index bb4621d..1273501 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -34,7 +34,7 @@ #include <i2c.h> #include <mmc.h> #include <fsl_esdhc.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <asm/gpio.h> #include <mc13892.h> @@ -123,9 +123,15 @@ void power_init(void) { unsigned int val; struct pmic *p; + int ret; + + ret = pmic_init(I2C_PMIC); + if (ret) + return;
/* Set VDDA to 1.25V */ pmic_reg_read(p, REG_SW_2, &val); diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index a11e883..f4a9b08 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -36,7 +36,7 @@ #include <mmc.h> #include <fsl_esdhc.h> #include <asm/gpio.h> -#include <pmic.h> +#include <power/pmic.h> #include <dialog_pmic.h> #include <fsl_pmic.h> #include <linux/fb.h> @@ -344,10 +344,16 @@ static int power_init(void) unsigned int val; int ret = -1; struct pmic *p; + int retval;
if (!i2c_probe(CONFIG_SYS_DIALOG_PMIC_I2C_ADDR)) { - pmic_dialog_init(); - p = get_pmic(); + retval = pmic_dialog_init(I2C_PMIC); + if (retval) + return retval; + + p = pmic_get("DIALOG_PMIC"); + if (!p) + return -ENODEV;
/* Set VDDA to 1.25V */ val = DA9052_BUCKCORE_BCOREEN | DA_BUCKCORE_VBCORE_1_250V; @@ -363,8 +369,13 @@ static int power_init(void) }
if (!i2c_probe(CONFIG_SYS_FSL_PMIC_I2C_ADDR)) { - pmic_init(); - p = get_pmic(); + retval = pmic_init(I2C_PMIC); + if (retval) + return retval; + + p = pmic_get("DIALOG_PMIC"); + if (!p) + return -ENODEV;
/* Set VDDGP to 1.25V for 1GHz on SW1 */ pmic_reg_read(p, REG_SW_0, &val); diff --git a/board/genesi/mx51_efikamx/efikamx.c b/board/genesi/mx51_efikamx/efikamx.c index c2b2823..69d41db 100644 --- a/board/genesi/mx51_efikamx/efikamx.c +++ b/board/genesi/mx51_efikamx/efikamx.c @@ -33,7 +33,7 @@ #include <i2c.h> #include <mmc.h> #include <fsl_esdhc.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <mc13892.h>
@@ -173,9 +173,15 @@ static void power_init(void) unsigned int val; struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)MXC_CCM_BASE; struct pmic *p; + int ret; + + ret = pmic_init(I2C_PMIC); + if (ret) + return;
/* Write needed to Power Gate 2 register */ pmic_reg_read(p, REG_POWER_MISC, &val); diff --git a/board/hale/tt01/tt01.c b/board/hale/tt01/tt01.c index 143fcef..0c2cb79 100644 --- a/board/hale/tt01/tt01.c +++ b/board/hale/tt01/tt01.c @@ -25,12 +25,13 @@ #include <common.h> #include <netdev.h> #include <command.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> #include <mc13783.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/io.h> +#include <errno.h>
@@ -195,14 +196,21 @@ int board_mmc_init(bd_t *bis) { u32 val; struct pmic *p; + int ret;
/* * this is the first driver to use the pmic, so call * pmic_init() here. board_late_init() is too late for * the MMC driver. */ - pmic_init(); - p = get_pmic(); + + ret = pmic_init(I2C_PMIC); + if (ret) + return ret; + + p = pmic_get("FSL_PMIC"); + if (!p) + return -ENODEV;
/* configure pins for SDHC1 only */ mx31_gpio_mux(IOMUX_MODE(MUX_CTL_SD1_CLK, MUX_CTL_FUNC)); diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index e8fb1ea..71ed618 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -25,10 +25,10 @@ #include <common.h> #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> -#include <pmic.h> +#include <power/pmic.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> -#include <max8998_pmic.h> +#include <power/max8998_pmic.h> DECLARE_GLOBAL_DATA_PTR;
static struct s5pc110_gpio *s5pc110_gpio; @@ -42,8 +42,9 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
#if defined(CONFIG_PMIC) - pmic_init(); + pmic_init(I2C_5); #endif + return 0; }
@@ -108,7 +109,9 @@ static int s5pc1xx_phy_control(int on) { int ret; static int status; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8998_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return -1; diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index e11a892..e0a9890 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -34,9 +34,9 @@ #include <asm/arch/mipi_dsim.h> #include <asm/arch/watchdog.h> #include <asm/arch/power.h> -#include <pmic.h> +#include <power/pmic.h> #include <usb/s3c_udc.h> -#include <max8997_pmic.h> +#include <power/max8997_pmic.h> #include <libtizen.h>
#include "setup.h" @@ -69,7 +69,7 @@ int board_init(void) printf("HW Revision:\t0x%x\n", board_rev);
return 0; @@ -238,7 +238,9 @@ static int s5pc210_phy_control(int on) { int ret = 0; u32 val = 0; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8997_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return -1; @@ -413,7 +415,9 @@ static void lcd_reset(void) static int lcd_power(void) { int ret = 0; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8997_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return 0; @@ -473,7 +477,9 @@ static struct mipi_dsim_lcd_device mipi_lcd_device = { static int mipi_power(void) { int ret = 0; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8997_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return 0; diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 90fff5c..c4950dd 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -27,10 +27,10 @@ #include <asm/arch/adc.h> #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> -#include <pmic.h> +#include <power/pmic.h> #include <usb/s3c_udc.h> #include <asm/arch/cpu.h> -#include <max8998_pmic.h> +#include <power/max8998_pmic.h>
@@ -59,7 +59,7 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
check_hw_revision(); @@ -112,7 +112,9 @@ static unsigned short get_adc_value(int channel) static int adc_power_control(int on) { int ret; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8998_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return -1; @@ -280,7 +282,9 @@ int board_mmc_init(bd_t *bis) static int s5pc210_phy_control(int on) { int ret = 0; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("MAX8998_PMIC"); + if (!p) + return -ENODEV;
if (pmic_probe(p)) return -1; diff --git a/board/ttcontrol/vision2/vision2.c b/board/ttcontrol/vision2/vision2.c index abdd1aa..a471fec 100644 --- a/board/ttcontrol/vision2/vision2.c +++ b/board/ttcontrol/vision2/vision2.c @@ -34,7 +34,7 @@ #include <asm/arch/sys_proto.h> #include <i2c.h> #include <mmc.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_esdhc.h> #include <fsl_pmic.h> #include <mc13892.h> @@ -306,9 +306,15 @@ static void power_init_mx51(void) { unsigned int val; struct pmic *p; + int ret; + + ret = pmic_init(I2C_PMIC); + if (ret) + return;
/* Write needed to Power Gate 2 register */ pmic_reg_read(p, REG_POWER_MISC, &val); diff --git a/drivers/misc/pmic_core.c b/drivers/misc/pmic_core.c index 5d62a56..4066b15 100644 --- a/drivers/misc/pmic_core.c +++ b/drivers/misc/pmic_core.c @@ -27,18 +27,21 @@ */
#include <common.h> +#include <malloc.h> #include <linux/types.h> -#include <pmic.h> +#include <linux/list.h> +#include <power/pmic.h>
-static struct pmic pmic; +static LIST_HEAD(pmic_list);
-int check_reg(u32 reg) +int check_reg(struct pmic *p, u32 reg) { - if (reg >= pmic.number_of_regs) { + if (reg >= p->number_of_regs) { printf("<reg num> = %d is invalid. Should be less than %d\n", - reg, pmic.number_of_regs); + reg, p->number_of_regs); return -1; } + return 0; }
@@ -65,11 +68,16 @@ static void pmic_show_info(struct pmic *p) printf("PMIC: %s\n", p->name); }
-static void pmic_dump(struct pmic *p) +static int pmic_dump(struct pmic *p) { int i, ret; u32 val;
+ if (!p) { + puts("Wrong PMIC name!\n"); + return -1; + } + pmic_show_info(p); for (i = 0; i < p->number_of_regs; i++) { ret = pmic_reg_read(p, i, &val); @@ -82,35 +90,84 @@ static void pmic_dump(struct pmic *p) printf("%08x ", val); } puts("\n"); + return 0; }
-struct pmic *get_pmic(void) +struct pmic *pmic_alloc(void) { - return &pmic; + struct pmic *p; + + p = calloc(sizeof(*p), 1); + if (!p) { + printf("%s: No available memory for allocation!\n", __func__); + return NULL; + } + + list_add_tail(&p->list, &pmic_list); + + debug("%s: new pmic struct: 0x%p\n", __func__, p); + + return p; +} + +struct pmic *pmic_get(const char *s) +{ + struct pmic *p; + + list_for_each_entry(p, &pmic_list, list) { + if (strcmp(p->name, s) == 0) { + debug("%s: pmic %s -> 0x%p\n", __func__, p->name, p); + return p; + } + } + + return NULL; +} + +static void pmic_list_names(void) +{ + struct pmic *p; + + puts("PMIC devices:\n"); + list_for_each_entry(p, &pmic_list, list) { + printf("name: %s\n", p->name); + } }
int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { u32 ret, reg, val; + struct pmic *p; char *cmd;
- struct pmic *p = &pmic; - /* at least two arguments please */ if (argc < 2) - return cmd_usage(cmdtp); + return CMD_RET_USAGE;
cmd = argv[1]; + + if (strcmp(cmd, "list") == 0) { + pmic_list_names(); + return CMD_RET_SUCCESS; + } + if (strcmp(cmd, "dump") == 0) { - pmic_dump(p); - return 0; + p = pmic_get(argv[2]); + if (!p) + return CMD_RET_FAILURE; + if (pmic_dump(p)) + return CMD_RET_FAILURE; + return CMD_RET_SUCCESS; }
if (strcmp(cmd, "read") == 0) { - if (argc < 3) - return cmd_usage(cmdtp); + if (argc < 4) + return CMD_RET_USAGE;
- reg = simple_strtoul(argv[2], NULL, 16); + reg = simple_strtoul(argv[3], NULL, 16); + p = pmic_get(argv[2]); + if (!p) + return CMD_RET_FAILURE;
ret = pmic_reg_read(p, reg, &val);
@@ -119,29 +176,32 @@ int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
printf("\n0x%02x: 0x%08x\n", reg, val);
- return 0; + return CMD_RET_SUCCESS; }
if (strcmp(cmd, "write") == 0) { - if (argc < 4) - return cmd_usage(cmdtp); - - reg = simple_strtoul(argv[2], NULL, 16); - val = simple_strtoul(argv[3], NULL, 16); - + if (argc < 5) + return CMD_RET_USAGE; + + reg = simple_strtoul(argv[3], NULL, 16); + val = simple_strtoul(argv[4], NULL, 16); + p = pmic_get(argv[2]); + if (!p) + return CMD_RET_FAILURE; pmic_reg_write(p, reg, val);
/* No subcommand found */ - return 1; + return CMD_RET_SUCCESS; }
U_BOOT_CMD( pmic, CONFIG_SYS_MAXARGS, 1, do_pmic, "PMIC", - "dump - dump PMIC registers\n" - "pmic read <reg> - read register\n" - "pmic write <reg> <value> - write register" + "list - list available PMICs\n" + "pmic dump name - dump named PMIC registers\n" + "pmic name read <reg> - read register\n" + "pmic name write <reg> <value> - write register" ); diff --git a/drivers/misc/pmic_dialog.c b/drivers/misc/pmic_dialog.c index e97af1d..d7ebd15 100644 --- a/drivers/misc/pmic_dialog.c +++ b/drivers/misc/pmic_dialog.c @@ -17,13 +17,19 @@ */
#include <common.h> -#include <pmic.h> +#include <power/pmic.h> #include <dialog_pmic.h> +#include <errno.h>
-int pmic_dialog_init(void) +int pmic_dialog_init(unsigned char bus) { - struct pmic *p = get_pmic(); static const char name[] = "DIALOG_PMIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + }
p->name = name; p->number_of_regs = DIALOG_NUM_OF_REGS; @@ -31,7 +37,7 @@ int pmic_dialog_init(void) p->interface = PMIC_I2C; p->hw.i2c.addr = CONFIG_SYS_DIALOG_PMIC_I2C_ADDR; p->hw.i2c.tx_num = 1; - p->bus = I2C_PMIC; + p->bus = bus;
return 0; } diff --git a/drivers/misc/pmic_fsl.c b/drivers/misc/pmic_fsl.c index 0ff75ed..0275fd9 100644 --- a/drivers/misc/pmic_fsl.c +++ b/drivers/misc/pmic_fsl.c @@ -23,8 +23,9 @@
#include <common.h> #include <spi.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h> +#include <errno.h>
#if defined(CONFIG_PMIC_SPI) static u32 pmic_spi_prepare_tx(u32 reg, u32 *val, u32 write) @@ -33,10 +34,15 @@ static u32 pmic_spi_prepare_tx(u32 reg, u32 *val, u32 write) } #endif
-int pmic_init(void) +int pmic_init(unsigned char bus) { - struct pmic *p = get_pmic(); static const char name[] = "FSL_PMIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + }
p->name = name; p->number_of_regs = PMIC_NUM_OF_REGS; @@ -54,7 +60,7 @@ int pmic_init(void) p->interface = PMIC_I2C; p->hw.i2c.addr = CONFIG_SYS_FSL_PMIC_I2C_ADDR; p->hw.i2c.tx_num = 3; - p->bus = I2C_PMIC; + p->bus = bus; #else #error "You must select CONFIG_PMIC_SPI or CONFIG_PMIC_I2C" #endif diff --git a/drivers/misc/pmic_i2c.c b/drivers/misc/pmic_i2c.c index 1064bfe..3e5a784 100644 --- a/drivers/misc/pmic_i2c.c +++ b/drivers/misc/pmic_i2c.c @@ -28,7 +28,7 @@
#include <common.h> #include <linux/types.h> -#include <pmic.h> +#include <power/pmic.h> #include <i2c.h> #include <compiler.h>
@@ -36,7 +36,7 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val) { unsigned char buf[4] = { 0 };
- if (check_reg(reg)) + if (check_reg(p, reg)) return -1;
switch (pmic_i2c_tx_num) { @@ -79,7 +79,7 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) unsigned char buf[4] = { 0 }; u32 ret_val = 0;
if (i2c_read(pmic_i2c_addr, reg, 1, buf, pmic_i2c_tx_num)) diff --git a/drivers/misc/pmic_max8997.c b/drivers/misc/pmic_max8997.c index 4943f66..7fe1b53 100644 --- a/drivers/misc/pmic_max8997.c +++ b/drivers/misc/pmic_max8997.c @@ -22,14 +22,20 @@ */
#include <common.h> -#include <pmic.h> -#include <max8997_pmic.h> +#include <power/pmic.h> +#include <power/max8997_pmic.h> #include <i2c.h> +#include <errno.h>
-int pmic_init(void) +int pmic_init(unsigned char bus) { - struct pmic *p = get_pmic(); static const char name[] = "MAX8997_PMIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + }
puts("Board PMIC init\n");
@@ -38,7 +44,7 @@ int pmic_init(void) p->number_of_regs = PMIC_NUM_OF_REGS; p->hw.i2c.addr = MAX8997_I2C_ADDR; p->hw.i2c.tx_num = 1; - p->bus = I2C_0; + p->bus = bus;
return 0; } diff --git a/drivers/misc/pmic_max8998.c b/drivers/misc/pmic_max8998.c index cc69fd7..452e1c8 100644 --- a/drivers/misc/pmic_max8998.c +++ b/drivers/misc/pmic_max8998.c @@ -22,13 +22,19 @@ */
#include <common.h> -#include <pmic.h> -#include <max8998_pmic.h> +#include <power/pmic.h> +#include <power/max8998_pmic.h> +#include <errno.h>
-int pmic_init(void) +int pmic_init(unsigned char bus) { - struct pmic *p = get_pmic(); static const char name[] = "MAX8998_PMIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + }
@@ -37,7 +43,7 @@ int pmic_init(void) p->number_of_regs = PMIC_NUM_OF_REGS; p->hw.i2c.addr = MAX8998_I2C_ADDR; p->hw.i2c.tx_num = 1; - p->bus = I2C_PMIC; + p->bus = bus;
return 0; } diff --git a/drivers/misc/pmic_spi.c b/drivers/misc/pmic_spi.c index 5a0dd22..27488ea 100644 --- a/drivers/misc/pmic_spi.c +++ b/drivers/misc/pmic_spi.c @@ -28,7 +28,7 @@
#include <common.h> #include <linux/types.h> -#include <pmic.h> +#include <power/pmic.h> #include <spi.h>
static struct spi_slave *slave; @@ -59,7 +59,7 @@ static u32 pmic_reg(struct pmic *p, u32 reg, u32 *val, u32 write) return -1; }
if (spi_claim_bus(slave)) diff --git a/drivers/rtc/mc13xxx-rtc.c b/drivers/rtc/mc13xxx-rtc.c index 70ea8a1..e79f462 100644 --- a/drivers/rtc/mc13xxx-rtc.c +++ b/drivers/rtc/mc13xxx-rtc.c @@ -23,16 +23,18 @@ #include <common.h> #include <rtc.h> #include <spi.h> -#include <pmic.h> +#include <power/pmic.h> #include <fsl_pmic.h>
int rtc_get(struct rtc_time *rtc) { u32 day1, day2, time; int tim, i = 0; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("FSL_PMIC"); int ret;
+ if (!p) + return -1; do { ret = pmic_reg_read(p, REG_RTC_DAY, &day1); if (ret < 0) @@ -61,7 +63,9 @@ int rtc_get(struct rtc_time *rtc) int rtc_set(struct rtc_time *rtc) { u32 time, day; - struct pmic *p = get_pmic(); + struct pmic *p = pmic_get("FSL_PMIC"); + if (!p) + return -1;
time = mktime(rtc->tm_year, rtc->tm_mon, rtc->tm_mday, rtc->tm_hour, rtc->tm_min, rtc->tm_sec); diff --git a/include/max8997_pmic.h b/include/power/max8997_pmic.h similarity index 92% rename from include/max8997_pmic.h rename to include/power/max8997_pmic.h index 17ae24e..1db7deb 100644 --- a/include/max8997_pmic.h +++ b/include/power/max8997_pmic.h @@ -111,7 +111,7 @@ enum { MAX8997_REG_MBCCTRL6 = 0x55, MAX8997_REG_OTPCGHCVS = 0x56,
- MAX8997_REG_SAFEOUTCTRL = 0x5a, + MAX8997_REG_SAFEOUTCTRL = 0x5a,
MAX8997_REG_LBCNFG1 = 0x5e, MAX8997_REG_LBCNFG2 = 0x5f, @@ -171,9 +171,22 @@ enum { PMIC_NUM_OF_REGS = 0x9b, };
+#define ACTDISSAFEO1 (1 << 4) +#define ACTDISSAFEO2 (1 << 5) #define ENSAFEOUT1 (1 << 6) #define ENSAFEOUT2 (1 << 7)
+/* Charger */ +enum {CHARGER_ENABLE, CHARGER_DISABLE}; +#define DETBAT (1 << 2) +#define MBCICHFCSET (1 << 4) +#define MBCHOSTEN (1 << 6) +#define VCHGR_FC (1 << 7) + +#define CHARGER_MIN_CURRENT 200 +#define CHARGER_MAX_CURRENT 950 +#define CHARGER_CURRENT_RESOLUTION 50 + #define MAX8997_I2C_ADDR (0xCC >> 1) #define MAX8997_RTC_ADDR (0x0C >> 1) #define MAX8997_MUIC_ADDR (0x4A >> 1) diff --git a/include/max8998_pmic.h b/include/power/max8998_pmic.h similarity index 100% rename from include/max8998_pmic.h rename to include/power/max8998_pmic.h diff --git a/include/pmic.h b/include/power/pmic.h similarity index 84% rename from include/pmic.h rename to include/power/pmic.h index 1a2db05..e9affc8 100644 --- a/include/pmic.h +++ b/include/power/pmic.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011 Samsung Electronics + * Copyright (C) 2011-2012 Samsung Electronics * Lukasz Majewski l.majewski@samsung.com * * See file CREDITS for list of people who contributed to this @@ -24,6 +24,10 @@ #ifndef __CORE_PMIC_H_ #define __CORE_PMIC_H_
+#include <common.h> +#include <linux/list.h> +#include <i2c.h> + enum { PMIC_I2C, PMIC_SPI, }; enum { I2C_PMIC, I2C_NUM, }; enum { PMIC_READ, PMIC_WRITE, }; @@ -49,17 +53,20 @@ struct pmic { unsigned char bus; unsigned char interface; unsigned char sensor_byte_order; - unsigned char number_of_regs; + unsigned int number_of_regs; union hw { struct p_i2c i2c; struct p_spi spi; } hw; + + struct list_head list; };
-int pmic_init(void); -int pmic_dialog_init(void); -int check_reg(u32 reg); -struct pmic *get_pmic(void); +int pmic_init(unsigned char bus); +int pmic_dialog_init(unsigned char bus); +int check_reg(struct pmic *p, u32 reg); +struct pmic *pmic_alloc(void); +struct pmic *pmic_get(const char *s); int pmic_probe(struct pmic *p); int pmic_reg_read(struct pmic *p, u32 reg, u32 *val); int pmic_reg_write(struct pmic *p, u32 reg, u32 val);
It is necessary to introduce a new system wide function- power_init_board()
It turns out, that power initialization must be done as early as possible. In the case of PMIC framework redesign, which aims to support multiple instances of PMIC devices the initialization shall be performed just after malloc configuration.
The power_init_board function is a weak function with default implementation.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes for v2: - None Changes for v3: - rename power_board_init to power_init_board - power_init_board() defined as __weak function with default implementation - CONFIG_POWER_INIT flag removed since it is not needed Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- arch/arm/lib/board.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 92cad9a..22a4d9c 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -224,6 +224,13 @@ int __arch_cpu_init(void) int arch_cpu_init(void) __attribute__((weak, alias("__arch_cpu_init")));
+int __power_init_board(void) +{ + return 0; +} +int power_init_board(void) + __attribute__((weak, alias("__power_init_board"))); + init_fnc_t *init_sequence[] = { arch_cpu_init, /* basic arch cpu dependent setup */
@@ -525,6 +532,7 @@ void board_init_r(gd_t *id, ulong dest_addr) #ifdef CONFIG_ARCH_EARLY_INIT_R arch_early_init_r(); #endif + power_init_board();
#if !defined(CONFIG_SYS_NO_FLASH) puts("Flash: ");
Enable support for power_board_init() method at TRATS board.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - None Changes for v3: - Remove CONFIG_POWER_INIT flag Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check pmic_init() return value --- board/samsung/trats/trats.c | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index e0a9890..1fa10ef 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -68,10 +68,6 @@ int board_init(void) check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
-#if defined(CONFIG_PMIC) - pmic_init(I2C_5); -#endif - return 0; }
@@ -90,6 +86,17 @@ void i2c_init_board(void) s5p_gpio_direction_output(&gpio2->y4, 1, 1); }
+int power_init_board(void) +{ + int ret; + + ret = pmic_init(I2C_5); + if (ret) + return ret; + + return 0; +} + int dram_init(void) { gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) +
New power_chrg.h file has been added to "bind" together common information about charging battery available in the system.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - Move struct battery elements to a separate file Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- include/power/power_chrg.h | 43 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 43 insertions(+), 0 deletions(-) create mode 100644 include/power/power_chrg.h
diff --git a/include/power/power_chrg.h b/include/power/power_chrg.h new file mode 100644 index 0000000..24c4cde --- /dev/null +++ b/include/power/power_chrg.h @@ -0,0 +1,43 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __POWER_CHARGER_H_ +#define __POWER_CHARGER_H_ + +/* Type of available chargers */ +enum { + CHARGER_NO = 0, + CHARGER_TA, + CHARGER_USB, + CHARGER_TA_500, + CHARGER_UNKNOWN, +}; + +enum { + UNKNOWN, + EXT_SOURCE, + CHARGE, + NORMAL, +}; + +#endif /* __POWER_CHARGER_H_ */
The PMIC framework has been moved to its more natural place ./drivers/power from ./drivers/misc directory.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes for v2: - New patch for v2 Changes for v3: - None Changes for v4: - Move PMIC related code (max8997.c and max8998.c) to power/pmic - Define ./power/pmic/libpmic.o library Changes for v5: - None Changes for v6: - None Changes for v7: - None --- Makefile | 3 +- drivers/misc/Makefile | 7 ---- drivers/power/Makefile | 12 +++++-- drivers/power/pmic/Makefile | 48 +++++++++++++++++++++++++++ drivers/{misc => power/pmic}/pmic_max8997.c | 0 drivers/{misc => power/pmic}/pmic_max8998.c | 0 drivers/{misc => power}/pmic_core.c | 0 drivers/{misc => power}/pmic_dialog.c | 0 drivers/{misc => power}/pmic_fsl.c | 0 drivers/{misc => power}/pmic_i2c.c | 0 drivers/{misc => power}/pmic_spi.c | 0 11 files changed, 59 insertions(+), 11 deletions(-) create mode 100644 drivers/power/pmic/Makefile rename drivers/{misc => power/pmic}/pmic_max8997.c (100%) rename drivers/{misc => power/pmic}/pmic_max8998.c (100%) rename drivers/{misc => power}/pmic_core.c (100%) rename drivers/{misc => power}/pmic_dialog.c (100%) rename drivers/{misc => power}/pmic_fsl.c (100%) rename drivers/{misc => power}/pmic_i2c.c (100%) rename drivers/{misc => power}/pmic_spi.c (100%)
diff --git a/Makefile b/Makefile index 9dc89f9..aa8ace8 100644 --- a/Makefile +++ b/Makefile @@ -293,7 +293,8 @@ LIBS-y += drivers/net/libnet.o LIBS-y += drivers/net/phy/libphy.o LIBS-y += drivers/pci/libpci.o LIBS-y += drivers/pcmcia/libpcmcia.o -LIBS-y += drivers/power/libpower.o +LIBS-y += drivers/power/libpower.o \ + drivers/power/pmic/libpmic.o LIBS-y += drivers/spi/libspi.o LIBS-y += drivers/dfu/libdfu.o ifeq ($(CPU),mpc83xx) diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 271463c..cdec88b 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -34,13 +34,6 @@ COBJS-$(CONFIG_NS87308) += ns87308.o COBJS-$(CONFIG_PDSP188x) += pdsp188x.o COBJS-$(CONFIG_STATUS_LED) += status_led.o COBJS-$(CONFIG_TWL4030_LED) += twl4030_led.o -COBJS-$(CONFIG_PMIC) += pmic_core.o -COBJS-$(CONFIG_DIALOG_PMIC) += pmic_dialog.o -COBJS-$(CONFIG_PMIC_FSL) += pmic_fsl.o -COBJS-$(CONFIG_PMIC_I2C) += pmic_i2c.o -COBJS-$(CONFIG_PMIC_SPI) += pmic_spi.o -COBJS-$(CONFIG_PMIC_MAX8998) += pmic_max8998.o -COBJS-$(CONFIG_PMIC_MAX8997) += pmic_max8997.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 6bf388c..7fc5554 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -23,7 +23,7 @@
include $(TOPDIR)/config.mk
-LIB := $(obj)libpower.o +LIB := $(obj)libpower.o
COBJS-$(CONFIG_FTPMU010_POWER) += ftpmu010.o COBJS-$(CONFIG_TPS6586X_POWER) += tps6586x.o @@ -31,9 +31,15 @@ COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o COBJS-$(CONFIG_TWL6035_POWER) += twl6035.o
+COBJS-$(CONFIG_PMIC) += pmic_core.o +COBJS-$(CONFIG_DIALOG_PMIC) += pmic_dialog.o +COBJS-$(CONFIG_PMIC_FSL) += pmic_fsl.o +COBJS-$(CONFIG_PMIC_I2C) += pmic_i2c.o +COBJS-$(CONFIG_PMIC_SPI) += pmic_spi.o + COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
all: $(LIB)
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile new file mode 100644 index 0000000..8ccd6e9 --- /dev/null +++ b/drivers/power/pmic/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2012 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libpmic.o + +COBJS-$(CONFIG_PMIC_MAX8998) += pmic_max8998.o +COBJS-$(CONFIG_PMIC_MAX8997) += pmic_max8997.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################## diff --git a/drivers/misc/pmic_max8997.c b/drivers/power/pmic/pmic_max8997.c similarity index 100% rename from drivers/misc/pmic_max8997.c rename to drivers/power/pmic/pmic_max8997.c diff --git a/drivers/misc/pmic_max8998.c b/drivers/power/pmic/pmic_max8998.c similarity index 100% rename from drivers/misc/pmic_max8998.c rename to drivers/power/pmic/pmic_max8998.c diff --git a/drivers/misc/pmic_core.c b/drivers/power/pmic_core.c similarity index 100% rename from drivers/misc/pmic_core.c rename to drivers/power/pmic_core.c diff --git a/drivers/misc/pmic_dialog.c b/drivers/power/pmic_dialog.c similarity index 100% rename from drivers/misc/pmic_dialog.c rename to drivers/power/pmic_dialog.c diff --git a/drivers/misc/pmic_fsl.c b/drivers/power/pmic_fsl.c similarity index 100% rename from drivers/misc/pmic_fsl.c rename to drivers/power/pmic_fsl.c diff --git a/drivers/misc/pmic_i2c.c b/drivers/power/pmic_i2c.c similarity index 100% rename from drivers/misc/pmic_i2c.c rename to drivers/power/pmic_i2c.c diff --git a/drivers/misc/pmic_spi.c b/drivers/power/pmic_spi.c similarity index 100% rename from drivers/misc/pmic_spi.c rename to drivers/power/pmic_spi.c
Now it is possible to provide specific function per PMIC/power device instance.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- Changes for v2: - New at patch v2 Changes for v3: - separate power_{battery|chrg|fg} structures to provide battery ops - struct pmic *parent pointer added Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- include/power/battery.h | 38 ++++++++++++++++++++++++++++++++++++++ include/power/pmic.h | 30 +++++++++++++++++++++++++++++- 2 files changed, 67 insertions(+), 1 deletions(-) create mode 100644 include/power/battery.h
diff --git a/include/power/battery.h b/include/power/battery.h new file mode 100644 index 0000000..e2fec68 --- /dev/null +++ b/include/power/battery.h @@ -0,0 +1,38 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __POWER_BATTERY_H_ +#define __POWER_BATTERY_H_ + +struct battery { + unsigned int version; + unsigned int state_of_chrg; + unsigned int time_to_empty; + unsigned int capacity; + unsigned int voltage_uV; + + unsigned int state; +}; + +int power_bat_init(unsigned char bus); +#endif /* __POWER_BATTERY_H_ */ diff --git a/include/power/pmic.h b/include/power/pmic.h index e9affc8..1ecfc05 100644 --- a/include/power/pmic.h +++ b/include/power/pmic.h @@ -27,8 +27,9 @@ #include <common.h> #include <linux/list.h> #include <i2c.h> +#include <power/power_chrg.h>
-enum { PMIC_I2C, PMIC_SPI, }; +enum { PMIC_I2C, PMIC_SPI, PMIC_NONE}; enum { I2C_PMIC, I2C_NUM, }; enum { PMIC_READ, PMIC_WRITE, }; enum { PMIC_SENSOR_BYTE_ORDER_LITTLE, PMIC_SENSOR_BYTE_ORDER_BIG, }; @@ -48,6 +49,27 @@ struct p_spi { u32 (*prepare_tx)(u32 reg, u32 *val, u32 write); };
+struct pmic; +struct power_fg { + int (*fg_battery_check) (struct pmic *p, struct pmic *bat); + int (*fg_battery_update) (struct pmic *p, struct pmic *bat); +}; + +struct power_chrg { + int (*chrg_type) (struct pmic *p); + int (*chrg_bat_present) (struct pmic *p); + int (*chrg_state) (struct pmic *p, int state, int current); +}; + +struct power_battery { + struct battery *bat; + int (*battery_init) (struct pmic *bat, struct pmic *p1, + struct pmic *p2, struct pmic *p3); + int (*battery_charge) (struct pmic *bat); + /* Keep info about power devices involved with battery operation */ + struct pmic *chrg, *fg, *muic; +}; + struct pmic { const char *name; unsigned char bus; @@ -59,6 +81,12 @@ struct pmic { struct p_spi spi; } hw;
+ void (*low_power_mode) (void); + struct power_battery *pbat; + struct power_chrg *chrg; + struct power_fg *fg; + + struct pmic *parent; struct list_head list; };
Trats battery is now treated in the same way as other power related devices. This approach allows for more unified handling of all devices responsible for power management.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - New patch at v2. Changes for v3: - only battery dependent battery_init method added - change code according to struct pmic redesign Changes for v4: - Adding ./power/battery/Makefile - Introduce the libbattery.o at Makefile - Change the state of charge value from 5 to 100 Changes for v5: - None Changes for v6: - None Changes for v7: - Check pmic_alloc() return value (to prevent NULL pointer dereference) --- Makefile | 3 +- drivers/power/battery/Makefile | 47 +++++++++++++++++ drivers/power/battery/bat_trats.c | 100 +++++++++++++++++++++++++++++++++++++ 3 files changed, 149 insertions(+), 1 deletions(-) create mode 100644 drivers/power/battery/Makefile create mode 100644 drivers/power/battery/bat_trats.c
diff --git a/Makefile b/Makefile index aa8ace8..2a8a098 100644 --- a/Makefile +++ b/Makefile @@ -294,7 +294,8 @@ LIBS-y += drivers/net/phy/libphy.o LIBS-y += drivers/pci/libpci.o LIBS-y += drivers/pcmcia/libpcmcia.o LIBS-y += drivers/power/libpower.o \ - drivers/power/pmic/libpmic.o + drivers/power/pmic/libpmic.o \ + drivers/power/battery/libbattery.o LIBS-y += drivers/spi/libspi.o LIBS-y += drivers/dfu/libdfu.o ifeq ($(CPU),mpc83xx) diff --git a/drivers/power/battery/Makefile b/drivers/power/battery/Makefile new file mode 100644 index 0000000..b176701 --- /dev/null +++ b/drivers/power/battery/Makefile @@ -0,0 +1,47 @@ +# +# Copyright (C) 2012 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libbattery.o + +COBJS-$(CONFIG_POWER_BATTERY_TRATS) += bat_trats.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################## diff --git a/drivers/power/battery/bat_trats.c b/drivers/power/battery/bat_trats.c new file mode 100644 index 0000000..ca0d214 --- /dev/null +++ b/drivers/power/battery/bat_trats.c @@ -0,0 +1,100 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <power/pmic.h> +#include <power/battery.h> +#include <power/max8997_pmic.h> +#include <errno.h> + +static struct battery battery_trats; + +static int power_battery_charge(struct pmic *bat) +{ + struct power_battery *p_bat = bat->pbat; + struct battery *battery = p_bat->bat; + int k; + + if (bat->chrg->chrg_state(p_bat->chrg, CHARGER_ENABLE, 450)) + return -1; + + for (k = 0; bat->chrg->chrg_bat_present(p_bat->chrg) && + bat->chrg->chrg_type(p_bat->muic) && + battery->state_of_chrg < 100; k++) { + udelay(10000000); + puts("."); + bat->fg->fg_battery_update(p_bat->fg, bat); + + if (k == 100) { + debug(" %d [V]", battery->voltage_uV); + puts("\n"); + k = 0; + } + + } + + bat->chrg->chrg_state(p_bat->chrg, CHARGER_DISABLE, 0); + + return 0; +} + +static int power_battery_init_trats(struct pmic *bat_, + struct pmic *fg_, + struct pmic *chrg_, + struct pmic *muic_) +{ + bat_->pbat->fg = fg_; + bat_->pbat->chrg = chrg_; + bat_->pbat->muic = muic_; + + bat_->fg = fg_->fg; + bat_->chrg = chrg_->chrg; + bat_->chrg->chrg_type = muic_->chrg->chrg_type; + return 0; +} + +static struct power_battery power_bat_trats = { + .bat = &battery_trats, + .battery_init = power_battery_init_trats, + .battery_charge = power_battery_charge, +}; + +int power_bat_init(unsigned char bus) +{ + static const char name[] = "BAT_TRATS"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + debug("Board BAT init\n"); + + p->interface = PMIC_NONE; + p->name = name; + p->bus = bus; + + p->pbat = &power_bat_trats; + return 0; +}
Support for MUIC (Micro USB Integrated Circuit) built into the MAX8997 power management device.
The MUIC device will work with redesigned PMIC framework.
--- Changes for v2: - power_init_battery now available as a callback from MUIC struct pmic instance Changes for v3: - change code according to struct pmic redesign Changes for v4: - Move muic code to ./drivers/power/pmic directory Changes for v5: - None Changes for v6: - None Changes for v7: - Check pmic_alloc() return value (to prevent NULL pointer dereference) --- drivers/power/pmic/Makefile | 1 + drivers/power/pmic/muic_max8997.c | 90 +++++++++++++++++++++++++++++++++++++ include/power/max8997_muic.h | 61 +++++++++++++++++++++++++ 3 files changed, 152 insertions(+), 0 deletions(-) create mode 100644 drivers/power/pmic/muic_max8997.c create mode 100644 include/power/max8997_muic.h
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 8ccd6e9..9b71e55 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libpmic.o
COBJS-$(CONFIG_PMIC_MAX8998) += pmic_max8998.o COBJS-$(CONFIG_PMIC_MAX8997) += pmic_max8997.o +COBJS-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/power/pmic/muic_max8997.c b/drivers/power/pmic/muic_max8997.c new file mode 100644 index 0000000..d5095c8 --- /dev/null +++ b/drivers/power/pmic/muic_max8997.c @@ -0,0 +1,90 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <power/pmic.h> +#include <power/power_chrg.h> +#include <power/max8997_muic.h> +#include <i2c.h> +#include <errno.h> + +static int power_chrg_get_type(struct pmic *p) +{ + unsigned int val; + unsigned char charge_type, charger; + + if (pmic_probe(p)) + return CHARGER_NO; + + pmic_reg_read(p, MAX8997_MUIC_STATUS2, &val); + charge_type = val & MAX8997_MUIC_CHG_MASK; + + switch (charge_type) { + case MAX8997_MUIC_CHG_NO: + charger = CHARGER_NO; + break; + case MAX8997_MUIC_CHG_USB: + case MAX8997_MUIC_CHG_USB_D: + charger = CHARGER_USB; + break; + case MAX8997_MUIC_CHG_TA: + case MAX8997_MUIC_CHG_TA_1A: + charger = CHARGER_TA; + break; + case MAX8997_MUIC_CHG_TA_500: + charger = CHARGER_TA_500; + break; + default: + charger = CHARGER_UNKNOWN; + break; + } + + return charger; +} + +static struct power_chrg power_chrg_muic_ops = { + .chrg_type = power_chrg_get_type, +}; + +int power_muic_init(unsigned int bus) +{ + static const char name[] = "MAX8997_MUIC"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + debug("Board Micro USB Interface Controller init\n"); + + p->name = name; + p->interface = PMIC_I2C; + p->number_of_regs = MUIC_NUM_OF_REGS; + p->hw.i2c.addr = MAX8997_MUIC_I2C_ADDR; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + p->chrg = &power_chrg_muic_ops; + return 0; +} diff --git a/include/power/max8997_muic.h b/include/power/max8997_muic.h new file mode 100644 index 0000000..0149c12 --- /dev/null +++ b/include/power/max8997_muic.h @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MAX8997_MUIC_H_ +#define __MAX8997_MUIC_H_ + +#include <power/power_chrg.h> + +/* MAX8997_MUIC_STATUS2 */ +#define MAX8997_MUIC_CHG_NO 0x00 +#define MAX8997_MUIC_CHG_USB 0x01 +#define MAX8997_MUIC_CHG_USB_D 0x02 +#define MAX8997_MUIC_CHG_TA 0x03 +#define MAX8997_MUIC_CHG_TA_500 0x04 +#define MAX8997_MUIC_CHG_TA_1A 0x05 +#define MAX8997_MUIC_CHG_MASK 0x07 + +/* MAX 8997 MUIC registers */ +enum { + MAX8997_MUIC_ID = 0x00, + MAX8997_MUIC_INT1 = 0x01, + MAX8997_MUIC_INT2 = 0x02, + MAX8997_MUIC_INT3 = 0x03, + MAX8997_MUIC_STATUS1 = 0x04, + MAX8997_MUIC_STATUS2 = 0x05, + MAX8997_MUIC_STATUS3 = 0x06, + MAX8997_MUIC_INTMASK1 = 0x07, + MAX8997_MUIC_INTMASK2 = 0x08, + MAX8997_MUIC_INTMASK3 = 0x09, + MAX8997_MUIC_CDETCTRL = 0x0A, + MAX8997_MUIC_CONTROL1 = 0x0C, + MAX8997_MUIC_CONTROL2 = 0x0D, + MAX8997_MUIC_CONTROL3 = 0x0E, + + MUIC_NUM_OF_REGS = 0x0F, +}; + +#define MAX8997_MUIC_I2C_ADDR (0x4A >> 1) + +int power_muic_init(unsigned int bus); +#endif /* __MAX8997_MUIC_H_ */
Support for MAX17042 fuel-gauge (FG), which is built into the MAX8997 power management device. Special file - fg_battery_cell_params.h with cells characteristics added.
The FG device will work with redesigned PMIC framework.
--- Changes for v2: - File moved to separate directory at ./drivers/power - {check|update}_battery available as callbacks from struct power_battery Changes for v3: - change code according to struct pmic redesign Changes for v4: - Introduce libfuel_gauge.o at ./Makefile - Move fg_max17042.c file to ./drivers/power/fuel_gauge directory Changes for v5: - None Changes for v6: - None Changes for v7: - Check pmic_alloc() return value (to prevent NULL pointer dereference) --- Makefile | 1 + drivers/power/fuel_gauge/Makefile | 47 ++++++ drivers/power/fuel_gauge/fg_max17042.c | 250 ++++++++++++++++++++++++++++++++ include/power/fg_battery_cell_params.h | 90 ++++++++++++ include/power/max17042_fg.h | 74 ++++++++++ 5 files changed, 462 insertions(+), 0 deletions(-) create mode 100644 drivers/power/fuel_gauge/Makefile create mode 100644 drivers/power/fuel_gauge/fg_max17042.c create mode 100644 include/power/fg_battery_cell_params.h create mode 100644 include/power/max17042_fg.h
diff --git a/Makefile b/Makefile index 2a8a098..5336531 100644 --- a/Makefile +++ b/Makefile @@ -294,6 +294,7 @@ LIBS-y += drivers/net/phy/libphy.o LIBS-y += drivers/pci/libpci.o LIBS-y += drivers/pcmcia/libpcmcia.o LIBS-y += drivers/power/libpower.o \ + drivers/power/fuel_gauge/libfuel_gauge.o \ drivers/power/pmic/libpmic.o \ drivers/power/battery/libbattery.o LIBS-y += drivers/spi/libspi.o diff --git a/drivers/power/fuel_gauge/Makefile b/drivers/power/fuel_gauge/Makefile new file mode 100644 index 0000000..da15414 --- /dev/null +++ b/drivers/power/fuel_gauge/Makefile @@ -0,0 +1,47 @@ +# +# Copyright (C) 2012 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libfuel_gauge.o + +COBJS-$(CONFIG_POWER_FG_MAX17042) += fg_max17042.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################## diff --git a/drivers/power/fuel_gauge/fg_max17042.c b/drivers/power/fuel_gauge/fg_max17042.c new file mode 100644 index 0000000..9b7c184 --- /dev/null +++ b/drivers/power/fuel_gauge/fg_max17042.c @@ -0,0 +1,250 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <power/pmic.h> +#include <power/max17042_fg.h> +#include <i2c.h> +#include <power/max8997_pmic.h> +#include <power/power_chrg.h> +#include <power/battery.h> +#include <power/fg_battery_cell_params.h> +#include <errno.h> + +static int fg_write_regs(struct pmic *p, u8 addr, u16 *data, int num) +{ + int ret = 0; + int i; + + for (i = 0; i < num; i++, addr++) + ret |= pmic_reg_write(p, addr, *(data + i)); + + return ret; +} + +static int fg_read_regs(struct pmic *p, u8 addr, u16 *data, int num) +{ + int ret = 0; + int i; + + for (i = 0; i < num; i++, addr++) + ret |= pmic_reg_read(p, addr, (u32 *) (data + i)); + + return ret; +} + +static int fg_write_and_verify(struct pmic *p, u8 addr, u16 data) +{ + unsigned int val = data; + int ret = 0; + + ret |= pmic_reg_write(p, addr, val); + ret |= pmic_reg_read(p, addr, &val); + + if (ret) + return ret; + + if (((u16) val) == data) + return 0; + + return -1; +} + +static void por_fuelgauge_init(struct pmic *p) +{ + u16 r_data0[16], r_data1[16], r_data2[16]; + u32 rewrite_count = 5, i = 0; + unsigned int val; + int ret = 0; + + /* Delay 500 ms */ + mdelay(500); + /* Initilize Configuration */ + pmic_reg_write(p, MAX17042_CONFIG, 0x2310); + +rewrite_model: + /* Unlock Model Access */ + pmic_reg_write(p, MAX17042_MLOCKReg1, MODEL_UNLOCK1); + pmic_reg_write(p, MAX17042_MLOCKReg2, MODEL_UNLOCK2); + + /* Write/Read/Verify the Custom Model */ + ret |= fg_write_regs(p, MAX17042_MODEL1, cell_character0, + ARRAY_SIZE(cell_character0)); + ret |= fg_write_regs(p, MAX17042_MODEL2, cell_character1, + ARRAY_SIZE(cell_character1)); + ret |= fg_write_regs(p, MAX17042_MODEL3, cell_character2, + ARRAY_SIZE(cell_character2)); + + if (ret) { + printf("%s: Cell parameters write failed!\n", __func__); + return; + } + + ret |= fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); + ret |= fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); + ret |= fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); + + if (ret) + printf("%s: Cell parameters read failed!\n", __func__); + + for (i = 0; i < 16; i++) { + if ((cell_character0[i] != r_data0[i]) + || (cell_character1[i] != r_data1[i]) + || (cell_character2[i] != r_data2[i])) + goto rewrite_model; + } + + /* Lock model access */ + pmic_reg_write(p, MAX17042_MLOCKReg1, MODEL_LOCK1); + pmic_reg_write(p, MAX17042_MLOCKReg2, MODEL_LOCK2); + + /* Verify the model access is locked */ + ret |= fg_read_regs(p, MAX17042_MODEL1, r_data0, ARRAY_SIZE(r_data0)); + ret |= fg_read_regs(p, MAX17042_MODEL2, r_data1, ARRAY_SIZE(r_data1)); + ret |= fg_read_regs(p, MAX17042_MODEL3, r_data2, ARRAY_SIZE(r_data2)); + + if (ret) { + printf("%s: Cell parameters read failed!\n", __func__); + return; + } + + for (i = 0; i < ARRAY_SIZE(r_data0); i++) { + /* Check if model locked */ + if (r_data0[i] || r_data1[i] || r_data2[i]) { + /* Rewrite model data - prevent from endless loop */ + if (rewrite_count--) { + puts("FG - Lock model access failed!\n"); + goto rewrite_model; + } + } + } + + /* Write Custom Parameters */ + fg_write_and_verify(p, MAX17042_RCOMP0, RCOMP0); + fg_write_and_verify(p, MAX17042_TEMPCO, TempCo); + + /* Delay at least 350mS */ + mdelay(350); + + /* Initialization Complete */ + pmic_reg_read(p, MAX17042_STATUS, &val); + /* Write and Verify Status with POR bit Cleared */ + fg_write_and_verify(p, MAX17042_STATUS, val & ~MAX17042_POR); + + /* Delay at least 350 ms */ + mdelay(350); +} + +static int power_update_battery(struct pmic *p, struct pmic *bat) +{ + struct power_battery *pb = bat->pbat; + unsigned int val; + int ret = 0; + + if (pmic_probe(p)) { + puts("Can't find max17042 fuel gauge\n"); + return -1; + } + + ret |= pmic_reg_read(p, MAX17042_VFSOC, &val); + pb->bat->state_of_chrg = (val >> 8); + + pmic_reg_read(p, MAX17042_VCELL, &val); + debug("vfsoc: 0x%x\n", val); + pb->bat->voltage_uV = ((val & 0xFFUL) >> 3) + ((val & 0xFF00) >> 3); + pb->bat->voltage_uV = (pb->bat->voltage_uV * 625); + + pmic_reg_read(p, 0x05, &val); + pb->bat->capacity = val >> 2; + + return ret; +} + +static int power_check_battery(struct pmic *p, struct pmic *bat) +{ + struct power_battery *pb = bat->pbat; + unsigned int val; + int ret = 0; + + if (pmic_probe(p)) { + puts("Can't find max17042 fuel gauge\n"); + return -1; + } + + ret |= pmic_reg_read(p, MAX17042_STATUS, &val); + debug("fg status: 0x%x\n", val); + + if (val == MAX17042_POR) + por_fuelgauge_init(p); + + ret |= pmic_reg_read(p, MAX17042_VERSION, &val); + pb->bat->version = val; + + power_update_battery(p, bat); + debug("fg ver: 0x%x\n", pb->bat->version); + printf("BAT: state_of_charge(SOC):%d%%\n", + pb->bat->state_of_chrg); + + printf(" voltage: %d.%6.6d [V] (expected to be %d [mAh])\n", + pb->bat->voltage_uV / 1000000, + pb->bat->voltage_uV % 1000000, + pb->bat->capacity); + + if (pb->bat->voltage_uV > 3850000) + pb->bat->state = EXT_SOURCE; + else if (pb->bat->voltage_uV < 3600000 || pb->bat->state_of_chrg < 5) + pb->bat->state = CHARGE; + else + pb->bat->state = NORMAL; + + return ret; +} + +static struct power_fg power_fg_ops = { + .fg_battery_check = power_check_battery, + .fg_battery_update = power_update_battery, +}; + +int power_fg_init(unsigned char bus) +{ + static const char name[] = "MAX17042_FG"; + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + debug("Board Fuel Gauge init\n"); + + p->name = name; + p->interface = PMIC_I2C; + p->number_of_regs = FG_NUM_OF_REGS; + p->hw.i2c.addr = MAX17042_I2C_ADDR; + p->hw.i2c.tx_num = 2; + p->sensor_byte_order = PMIC_SENSOR_BYTE_ORDER_BIG; + p->bus = bus; + + p->fg = &power_fg_ops; + return 0; +} diff --git a/include/power/fg_battery_cell_params.h b/include/power/fg_battery_cell_params.h new file mode 100644 index 0000000..7ddf6f2 --- /dev/null +++ b/include/power/fg_battery_cell_params.h @@ -0,0 +1,90 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FG_BATTERY_CELL_PARAMS_H_ +#define __FG_BATTERY_CELL_PARAMS_H_ + +#if defined(CONFIG_POWER_FG_MAX17042) && defined(CONFIG_TRATS) + +/* Cell characteristics - Exynos4 TRATS development board */ +/* Shall be written to addr 0x80h */ +u16 cell_character0[16] = { + 0xA2A0, + 0xB6E0, + 0xB850, + 0xBAD0, + 0xBB20, + 0xBB70, + 0xBBC0, + 0xBC20, + 0xBC80, + 0xBCE0, + 0xBD80, + 0xBE20, + 0xC090, + 0xC420, + 0xC910, + 0xD070 +}; + +/* Shall be written to addr 0x90h */ +u16 cell_character1[16] = { + 0x0090, + 0x1A50, + 0x02F0, + 0x2060, + 0x2060, + 0x2E60, + 0x26A0, + 0x2DB0, + 0x2DB0, + 0x1870, + 0x2A20, + 0x16F0, + 0x08F0, + 0x0D40, + 0x08C0, + 0x08C0 +}; + +/* Shall be written to addr 0xA0h */ +u16 cell_character2[16] = { + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100, + 0x0100 +}; +#endif +#endif /* __FG_BATTERY_CELL_PARAMS_H_ */ diff --git a/include/power/max17042_fg.h b/include/power/max17042_fg.h new file mode 100644 index 0000000..1103a48 --- /dev/null +++ b/include/power/max17042_fg.h @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2012 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MAX17042_FG_H_ +#define __MAX17042_FG_H_ + +/* MAX 17042 registers */ +enum { + MAX17042_STATUS = 0x00, + MAX17042_SOCREP = 0x06, + MAX17042_VCELL = 0x09, + MAX17042_CURRENT = 0x0A, + MAX17042_AVG_CURRENT = 0x0B, + MAX17042_SOCMIX = 0x0D, + MAX17042_SOCAV = 0x0E, + MAX17042_DESIGN_CAP = 0x18, + MAX17042_AVG_VCELL = 0x19, + MAX17042_CONFIG = 0x1D, + MAX17042_VERSION = 0x21, + MAX17042_LEARNCFG = 0x28, + MAX17042_FILTERCFG = 0x29, + MAX17042_RELAXCFG = 0x2A, + MAX17042_MISCCFG = 0x2B, + MAX17042_CGAIN = 0x2E, + MAX17042_COFF = 0x2F, + MAX17042_RCOMP0 = 0x38, + MAX17042_TEMPCO = 0x39, + MAX17042_FSTAT = 0x3D, + MAX17042_MLOCKReg1 = 0x62, + MAX17042_MLOCKReg2 = 0x63, + MAX17042_MODEL1 = 0x80, + MAX17042_MODEL2 = 0x90, + MAX17042_MODEL3 = 0xA0, + MAX17042_VFOCV = 0xFB, + MAX17042_VFSOC = 0xFF, + + FG_NUM_OF_REGS = 0x100, +}; + +#define RCOMP0 0x0060 +#define TempCo 0x1015 + + +#define MAX17042_POR (1 << 1) + +#define MODEL_UNLOCK1 0x0059 +#define MODEL_UNLOCK2 0x00c4 +#define MODEL_LOCK1 0x0000 +#define MODEL_LOCK2 0x0000 + +#define MAX17042_I2C_ADDR (0x6C >> 1) + +int power_fg_init(unsigned char bus); +#endif /* __MAX17042_FG_H_ */
Function for calculating LDO internal register value from passed micro Volt.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - MAX8997_LDO_MAX_VAL defined Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/power/pmic/pmic_max8997.c | 16 ++++++++++++++++ include/power/max8997_pmic.h | 2 ++ 2 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/drivers/power/pmic/pmic_max8997.c b/drivers/power/pmic/pmic_max8997.c index 7fe1b53..2e46884 100644 --- a/drivers/power/pmic/pmic_max8997.c +++ b/drivers/power/pmic/pmic_max8997.c @@ -27,6 +27,22 @@ #include <i2c.h> #include <errno.h>
+unsigned char max8997_reg_ldo(int uV) +{ + unsigned char ret; + if (uV <= 800000) + return 0; + if (uV >= 3950000) + return MAX8997_LDO_MAX_VAL; + ret = (uV - 800000) / 50000; + if (ret > MAX8997_LDO_MAX_VAL) { + printf("MAX8997 LDO SETTING ERROR (%duV) -> %u\n", uV, ret); + ret = MAX8997_LDO_MAX_VAL; + } + + return ret; +} + int pmic_init(unsigned char bus) { static const char name[] = "MAX8997_PMIC"; diff --git a/include/power/max8997_pmic.h b/include/power/max8997_pmic.h index 1db7deb..03cac04 100644 --- a/include/power/max8997_pmic.h +++ b/include/power/max8997_pmic.h @@ -200,4 +200,6 @@ enum { EN_LDO = (0x3 << 6), };
+#define MAX8997_LDO_MAX_VAL 0x3F +unsigned char max8997_reg_ldo(int uV); #endif /* __MAX8997_PMIC_H_ */
Default PMIC (MAX8997) initialization for Samsung's TRATS development board.
--- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check return value from pmic_init_max8997() function --- board/samsung/trats/trats.c | 151 ++++++++++++++++++++++++++++++++++++++++++ include/power/max8997_pmic.h | 9 +++ 2 files changed, 160 insertions(+), 0 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 1fa10ef..ebbc7ab 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -86,11 +86,162 @@ void i2c_init_board(void) s5p_gpio_direction_output(&gpio2->y4, 1, 1); }
+static int pmic_init_max8997(void) +{ + struct pmic *p = pmic_get("MAX8997_PMIC"); + int i = 0, ret = 0; + u32 val; + + if (pmic_probe(p)) + return -1; + + /* BUCK1 VARM: 1.2V */ + val = (1200000 - 650000) / 25000; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK1DVS1, val); + val = ENBUCK | ACTIVE_DISCHARGE; /* DVS OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_BUCK1CTRL, val); + + /* BUCK2 VINT: 1.1V */ + val = (1100000 - 650000) / 25000; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK2DVS1, val); + val = ENBUCK | ACTIVE_DISCHARGE; /* DVS OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_BUCK2CTRL, val); + + + /* BUCK3 G3D: 1.1V - OFF */ + ret |= pmic_reg_read(p, MAX8997_REG_BUCK3CTRL, &val); + val &= ~ENBUCK; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK3CTRL, val); + + val = (1100000 - 750000) / 50000; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK3DVS, val); + + /* BUCK4 CAMISP: 1.2V - OFF */ + ret |= pmic_reg_read(p, MAX8997_REG_BUCK4CTRL, &val); + val &= ~ENBUCK; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK4CTRL, val); + + val = (1200000 - 650000) / 25000; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK4DVS, val); + + /* BUCK5 VMEM: 1.2V */ + val = (1200000 - 650000) / 25000; + for (i = 0; i < 8; i++) + ret |= pmic_reg_write(p, MAX8997_REG_BUCK5DVS1 + i, val); + + val = ENBUCK | ACTIVE_DISCHARGE; /* DVS OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_BUCK5CTRL, val); + + /* BUCK6 CAM AF: 2.8V */ + /* No Voltage Setting Register */ + /* GNSLCT 3.0X */ + val = GNSLCT; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK6CTRL, val); + + /* BUCK7 VCC_SUB: 2.0V */ + val = (2000000 - 750000) / 50000; + ret |= pmic_reg_write(p, MAX8997_REG_BUCK7DVS, val); + + /* LDO1 VADC: 3.3V */ + val = max8997_reg_ldo(3300000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO1CTRL, val); + + /* LDO1 Disable active discharging */ + ret |= pmic_reg_read(p, MAX8997_REG_LDO1CONFIG, &val); + val &= ~LDO_ADE; + ret |= pmic_reg_write(p, MAX8997_REG_LDO1CONFIG, val); + + /* LDO2 VALIVE: 1.1V */ + val = max8997_reg_ldo(1100000) | EN_LDO; + ret |= pmic_reg_write(p, MAX8997_REG_LDO2CTRL, val); + + /* LDO3 VUSB/MIPI: 1.1V */ + val = max8997_reg_ldo(1100000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO3CTRL, val); + + /* LDO4 VMIPI: 1.8V */ + val = max8997_reg_ldo(1800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO4CTRL, val); + + /* LDO5 VHSIC: 1.2V */ + val = max8997_reg_ldo(1200000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO5CTRL, val); + + /* LDO6 VCC_1.8V_PDA: 1.8V */ + val = max8997_reg_ldo(1800000) | EN_LDO; + ret |= pmic_reg_write(p, MAX8997_REG_LDO6CTRL, val); + + /* LDO7 CAM_ISP: 1.8V */ + val = max8997_reg_ldo(1800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO7CTRL, val); + + /* LDO8 VDAC/VUSB: 3.3V */ + val = max8997_reg_ldo(3300000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO8CTRL, val); + + /* LDO9 VCC_2.8V_PDA: 2.8V */ + val = max8997_reg_ldo(2800000) | EN_LDO; + ret |= pmic_reg_write(p, MAX8997_REG_LDO9CTRL, val); + + /* LDO10 VPLL: 1.1V */ + val = max8997_reg_ldo(1100000) | EN_LDO; + ret |= pmic_reg_write(p, MAX8997_REG_LDO10CTRL, val); + + /* LDO11 TOUCH: 2.8V */ + val = max8997_reg_ldo(2800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO11CTRL, val); + + /* LDO12 VTCAM: 1.8V */ + val = max8997_reg_ldo(1800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO12CTRL, val); + + /* LDO13 VCC_3.0_LCD: 3.0V */ + val = max8997_reg_ldo(3000000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO13CTRL, val); + + /* LDO14 MOTOR: 3.0V */ + val = max8997_reg_ldo(3000000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO14CTRL, val); + + /* LDO15 LED_A: 2.8V */ + val = max8997_reg_ldo(2800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO15CTRL, val); + + /* LDO16 CAM_SENSOR: 1.8V */ + val = max8997_reg_ldo(1800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO16CTRL, val); + + /* LDO17 VTF: 2.8V */ + val = max8997_reg_ldo(2800000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO17CTRL, val); + + /* LDO18 TOUCH_LED 3.3V */ + val = max8997_reg_ldo(3300000) | DIS_LDO; /* OFF */ + ret |= pmic_reg_write(p, MAX8997_REG_LDO18CTRL, val); + + /* LDO21 VDDQ: 1.2V */ + val = max8997_reg_ldo(1200000) | EN_LDO; + ret |= pmic_reg_write(p, MAX8997_REG_LDO21CTRL, val); + + /* SAFEOUT for both 1 and 2: 4.9V, Active discharge, Enable */ + val = (SAFEOUT_4_90V << 0) | (SAFEOUT_4_90V << 2) | + ACTDISSAFEO1 | ACTDISSAFEO2 | ENSAFEOUT1 | ENSAFEOUT2; + ret |= pmic_reg_write(p, MAX8997_REG_SAFEOUTCTRL, val); + + if (ret) { + puts("MAX8997 PMIC setting error!\n"); + return -1; + } + return 0; +} + int power_init_board(void) { int ret;
ret = pmic_init(I2C_5); + ret |= pmic_init_max8997(); + if (ret) return ret;
diff --git a/include/power/max8997_pmic.h b/include/power/max8997_pmic.h index 03cac04..5d2d94d 100644 --- a/include/power/max8997_pmic.h +++ b/include/power/max8997_pmic.h @@ -176,6 +176,15 @@ enum { #define ENSAFEOUT1 (1 << 6) #define ENSAFEOUT2 (1 << 7)
+#define ENBUCK (1 << 0) +#define ACTIVE_DISCHARGE (1 << 3) +#define GNSLCT (1 << 2) +#define LDO_ADE (1 << 1) +#define SAFEOUT_4_85V 0x00 +#define SAFEOUT_4_90V 0x01 +#define SAFEOUT_4_95V 0x02 +#define SAFEOUT_3_30V 0x03 + /* Charger */ enum {CHARGER_ENABLE, CHARGER_DISABLE}; #define DETBAT (1 << 2)
MUIC IC built into the MAX8997 device is enabled at TRATS.
--- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check return value of power_muic_init() function --- board/samsung/trats/trats.c | 3 ++- include/configs/trats.h | 2 ++ 2 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index ebbc7ab..2359a99 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -38,6 +38,7 @@ #include <usb/s3c_udc.h> #include <power/max8997_pmic.h> #include <libtizen.h> +#include <power/max8997_muic.h>
#include "setup.h"
@@ -241,7 +242,7 @@ int power_init_board(void)
ret = pmic_init(I2C_5); ret |= pmic_init_max8997(); - + ret |= power_muic_init(I2C_5); if (ret) return ret;
diff --git a/include/configs/trats.h b/include/configs/trats.h index d7808aa..74c4a23 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -238,6 +238,8 @@ #define CONFIG_PMIC_I2C #define CONFIG_PMIC_MAX8997
+#define CONFIG_POWER_MUIC +#define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED
FG IC built into the MAX8997 device (compliant to MAX17042) is enabled at TRATS.
--- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check return value from power_fg_init() --- board/samsung/trats/trats.c | 2 ++ include/configs/trats.h | 2 ++ 2 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 2359a99..6c2f199 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -39,6 +39,7 @@ #include <power/max8997_pmic.h> #include <libtizen.h> #include <power/max8997_muic.h> +#include <power/max17042_fg.h>
#include "setup.h"
@@ -242,6 +243,7 @@ int power_init_board(void)
ret = pmic_init(I2C_5); ret |= pmic_init_max8997(); + ret |= power_fg_init(I2C_9); ret |= power_muic_init(I2C_5); if (ret) return ret; diff --git a/include/configs/trats.h b/include/configs/trats.h index 74c4a23..0bc1f3a 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -238,6 +238,8 @@ #define CONFIG_PMIC_I2C #define CONFIG_PMIC_MAX8997
+#define CONFIG_POWER_FG +#define CONFIG_POWER_FG_MAX17042 #define CONFIG_POWER_MUIC #define CONFIG_POWER_MUIC_MAX8997 #define CONFIG_USB_GADGET
Support for TRATS battery has been added. It is treated as a "normal" power related device and thereof controlled by pmic/power subsystem.
--- Changes for v2: - New patch for v2. Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check return value of power_bat_init() function --- board/samsung/trats/trats.c | 2 ++ include/configs/trats.h | 2 ++ 2 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 6c2f199..94bf5c0 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -39,6 +39,7 @@ #include <power/max8997_pmic.h> #include <libtizen.h> #include <power/max8997_muic.h> +#include <power/battery.h> #include <power/max17042_fg.h>
#include "setup.h" @@ -245,6 +246,7 @@ int power_init_board(void) ret |= pmic_init_max8997(); ret |= power_fg_init(I2C_9); ret |= power_muic_init(I2C_5); + ret |= power_bat_init(0); if (ret) return ret;
diff --git a/include/configs/trats.h b/include/configs/trats.h index 0bc1f3a..2fdc597 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -242,6 +242,8 @@ #define CONFIG_POWER_FG_MAX17042 #define CONFIG_POWER_MUIC #define CONFIG_POWER_MUIC_MAX8997 +#define CONFIG_POWER_BATTERY +#define CONFIG_POWER_BATTERY_TRATS #define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_S3C_UDC_OTG #define CONFIG_USB_GADGET_DUALSPEED
Support for MAX8997 built-in charger.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - power_init_battery() method added to be called from MAX8997 struct pmic instance Changes for v3: - change code according to struct pmic redesign Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/power/pmic/pmic_max8997.c | 59 ++++++++++++++++++++++++++++++++++++- 1 files changed, 58 insertions(+), 1 deletions(-)
diff --git a/drivers/power/pmic/pmic_max8997.c b/drivers/power/pmic/pmic_max8997.c index 2e46884..4e5c6d6 100644 --- a/drivers/power/pmic/pmic_max8997.c +++ b/drivers/power/pmic/pmic_max8997.c @@ -43,6 +43,62 @@ unsigned char max8997_reg_ldo(int uV) return ret; }
+static int pmic_charger_state(struct pmic *p, int state, int current) +{ + unsigned char fc; + u32 val = 0; + + if (pmic_probe(p)) + return -1; + + if (state == CHARGER_DISABLE) { + puts("Disable the charger.\n"); + pmic_reg_read(p, MAX8997_REG_MBCCTRL2, &val); + val &= ~(MBCHOSTEN | VCHGR_FC); + pmic_reg_write(p, MAX8997_REG_MBCCTRL2, val); + + return -1; + } + + if (current < CHARGER_MIN_CURRENT || current > CHARGER_MAX_CURRENT) { + printf("%s: Wrong charge current: %d [mA]\n", + __func__, current); + return -1; + } + + fc = (current - CHARGER_MIN_CURRENT) / CHARGER_CURRENT_RESOLUTION; + fc = fc & 0xf; /* up to 950 mA */ + + printf("Enable the charger @ %d [mA]\n", fc * CHARGER_CURRENT_RESOLUTION + + CHARGER_MIN_CURRENT); + + val = fc | MBCICHFCSET; + pmic_reg_write(p, MAX8997_REG_MBCCTRL4, val); + + pmic_reg_read(p, MAX8997_REG_MBCCTRL2, &val); + val = MBCHOSTEN | VCHGR_FC; /* enable charger & fast charge */ + pmic_reg_write(p, MAX8997_REG_MBCCTRL2, val); + + return 0; +} + +static int pmic_charger_bat_present(struct pmic *p) +{ + u32 val; + + if (pmic_probe(p)) + return -1; + + pmic_reg_read(p, MAX8997_REG_STATUS4, &val); + + return !(val & DETBAT); +} + +static struct power_chrg power_chrg_pmic_ops = { + .chrg_bat_present = pmic_charger_bat_present, + .chrg_state = pmic_charger_state, +}; + int pmic_init(unsigned char bus) { static const char name[] = "MAX8997_PMIC"; @@ -53,7 +109,7 @@ int pmic_init(unsigned char bus) return -ENOMEM; }
- puts("Board PMIC init\n"); + debug("Board PMIC init\n");
p->name = name; p->interface = PMIC_I2C; @@ -62,5 +118,6 @@ int pmic_init(unsigned char bus) p->hw.i2c.tx_num = 1; p->bus = bus;
+ p->chrg = &power_chrg_pmic_ops; return 0; }
When charging battery is necessary, the development board needs to be turned into low power mode for better efficiency.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - None Changes for v3: - None Changes for v4: - None Changes for v5: - None Changes for v6: - Explanation of a magic numbers (APLL, CLOCK) Changes for v7: - None --- board/samsung/trats/trats.c | 58 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 58 insertions(+), 0 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 94bf5c0..226b529 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -89,6 +89,64 @@ void i2c_init_board(void) s5p_gpio_direction_output(&gpio2->y4, 1, 1); }
+static void trats_low_power_mode(void) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + struct exynos4_power *pwr = + (struct exynos4_power *)samsung_get_base_power(); + + /* Power down CORE1 */ + /* LOCAL_PWR_CFG [1:0] 0x3 EN, 0x0 DIS */ + writel(0x0, &pwr->arm_core1_configuration); + + /* Change the APLL frequency */ + /* ENABLE (1 enable) | LOCKED (1 locked) */ + /* [31] | [29] */ + /* FSEL | MDIV | PDIV | SDIV */ + /* [27] | [25:16] | [13:8] | [2:0] */ + writel(0xa0c80604, &clk->apll_con0); + + /* Change CPU0 clock divider */ + /* CORE2_RATIO | APLL_RATIO | PCLK_DBG_RATIO | ATB_RATIO */ + /* [30:28] | [26:24] | [22:20] | [18:16] */ + /* PERIPH_RATIO | COREM1_RATIO | COREM0_RATIO | CORE_RATIO */ + /* [14:12] | [10:8] | [6:4] | [2:0] */ + writel(0x00000100, &clk->div_cpu0); + + /* CLK_DIV_STAT_CPU0 - wait until clock gets stable (0 = stable) */ + while (readl(&clk->div_stat_cpu0) & 0x1111111) + continue; + + /* Change clock divider ratio for DMC */ + /* DMCP_RATIO | DMCD_RATIO */ + /* [22:20] | [18:16] */ + /* DMC_RATIO | DPHY_RATIO | ACP_PCLK_RATIO | ACP_RATIO */ + /* [14:12] | [10:8] | [6:4] | [2:0] */ + writel(0x13113117, &clk->div_dmc0); + + /* CLK_DIV_STAT_DMC0 - wait until clock gets stable (0 = stable) */ + while (readl(&clk->div_stat_dmc0) & 0x11111111) + continue; + + /* Turn off unnecessary power domains */ + writel(0x0, &pwr->xxti_configuration); /* XXTI */ + writel(0x0, &pwr->cam_configuration); /* CAM */ + writel(0x0, &pwr->tv_configuration); /* TV */ + writel(0x0, &pwr->mfc_configuration); /* MFC */ + writel(0x0, &pwr->g3d_configuration); /* G3D */ + writel(0x0, &pwr->gps_configuration); /* GPS */ + writel(0x0, &pwr->gps_alive_configuration); /* GPS_ALIVE */ + + /* Turn off unnecessary clocks */ + writel(0x0, &clk->gate_ip_cam); /* CAM */ + writel(0x0, &clk->gate_ip_tv); /* TV */ + writel(0x0, &clk->gate_ip_mfc); /* MFC */ + writel(0x0, &clk->gate_ip_g3d); /* G3D */ + writel(0x0, &clk->gate_ip_image); /* IMAGE */ + writel(0x0, &clk->gate_ip_gps); /* GPS */ +} + static int pmic_init_max8997(void) { struct pmic *p = pmic_get("MAX8997_PMIC");
The battery connected to Samsung's Trats development board is now charged when voltage drops below threshold.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v2: - Define separate *p_{} pointer instances for each power device available at Trats - Only basic checks performed - Core responsible for battery charging moved to separate file - ./drivers/power/bat_trats.c Changes for v3: - change code according to struct pmic redesign Changes for v4: - None Changes for v5: - None Changes for v6: - Code indentation improvement Changes for v7: - Check return value from pmic_get() --- board/samsung/trats/trats.c | 49 ++++++++++++++++++++++++++++++++++++++++++- 1 files changed, 48 insertions(+), 1 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 226b529..e540190 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -298,7 +298,9 @@ static int pmic_init_max8997(void)
int power_init_board(void) { - int ret; + int chrg, ret; + struct power_battery *pb; + struct pmic *p_fg, *p_chrg, *p_muic, *p_bat;
ret = pmic_init(I2C_5); ret |= pmic_init_max8997(); @@ -308,6 +310,51 @@ int power_init_board(void) if (ret) return ret;
+ p_fg = pmic_get("MAX17042_FG"); + if (!p_fg) { + puts("MAX17042_FG: Not found\n"); + return -ENODEV; + } + + p_chrg = pmic_get("MAX8997_PMIC"); + if (!p_chrg) { + puts("MAX8997_PMIC: Not found\n"); + return -ENODEV; + } + + p_muic = pmic_get("MAX8997_MUIC"); + if (!p_muic) { + puts("MAX8997_MUIC: Not found\n"); + return -ENODEV; + } + + p_bat = pmic_get("BAT_TRATS"); + if (!p_bat) { + puts("BAT_TRATS: Not found\n"); + return -ENODEV; + } + + p_fg->parent = p_bat; + p_chrg->parent = p_bat; + p_muic->parent = p_bat; + + p_bat->low_power_mode = trats_low_power_mode; + p_bat->pbat->battery_init(p_bat, p_fg, p_chrg, p_muic); + + pb = p_bat->pbat; + chrg = p_muic->chrg->chrg_type(p_muic); + debug("CHARGER TYPE: %d\n", chrg); + + if (!p_chrg->chrg->chrg_bat_present(p_chrg)) { + puts("No battery detected\n"); + return -1; + } + + p_fg->fg->fg_battery_check(p_fg, p_bat); + + if (pb->bat->state == CHARGE && chrg == CHARGER_USB) + puts("CHARGE Battery !\n"); + return 0; }
Two extra commands: "pmic name bat state" and "pmic name bat charge" has been added to pmic framework. Those provides state display and charge capabilities to named batteries.
The pmic_core.c file has been refactored to more consistent name scheme.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v2: - New patch to v2. Changes for v3: - change code according to struct pmic redesign Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - Check return value from pmic_get() --- drivers/power/pmic_core.c | 59 ++++++++++++++++++++++++++++++++------------- 1 files changed, 42 insertions(+), 17 deletions(-)
diff --git a/drivers/power/pmic_core.c b/drivers/power/pmic_core.c index 4066b15..90df2c5 100644 --- a/drivers/power/pmic_core.c +++ b/drivers/power/pmic_core.c @@ -124,37 +124,47 @@ struct pmic *pmic_get(const char *s) return NULL; }
+const char *power_get_interface(int interface) +{ + const char *power_interface[] = {"I2C", "SPI", "|+|-|"}; + return power_interface[interface]; +} + static void pmic_list_names(void) { struct pmic *p;
puts("PMIC devices:\n"); list_for_each_entry(p, &pmic_list, list) { - printf("name: %s\n", p->name); + printf("name: %s bus: %s_%d\n", p->name, + power_get_interface(p->interface), p->bus); } }
int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { u32 ret, reg, val; + char *cmd, *name; struct pmic *p; - char *cmd;
/* at least two arguments please */ if (argc < 2) return CMD_RET_USAGE;
- cmd = argv[1]; - - if (strcmp(cmd, "list") == 0) { + if (strcmp(argv[1], "list") == 0) { pmic_list_names(); return CMD_RET_SUCCESS; }
+ name = argv[1]; + cmd = argv[2]; + + debug("%s: name: %s cmd: %s\n", __func__, name, cmd); + p = pmic_get(name); + if (!p) + return CMD_RET_FAILURE; + if (strcmp(cmd, "dump") == 0) { - p = pmic_get(argv[2]); - if (!p) - return CMD_RET_FAILURE; if (pmic_dump(p)) return CMD_RET_FAILURE; return CMD_RET_SUCCESS; @@ -165,10 +175,6 @@ int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_USAGE;
reg = simple_strtoul(argv[3], NULL, 16); - p = pmic_get(argv[2]); - if (!p) - return CMD_RET_FAILURE; - ret = pmic_reg_read(p, reg, &val);
if (ret) @@ -185,14 +191,31 @@ int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
reg = simple_strtoul(argv[3], NULL, 16); val = simple_strtoul(argv[4], NULL, 16); - p = pmic_get(argv[2]); - if (!p) - return CMD_RET_FAILURE; pmic_reg_write(p, reg, val);
+ if (strcmp(cmd, "bat") == 0) { + if (argc < 4) + return CMD_RET_USAGE; + + if (strcmp(argv[3], "state") == 0) + p->fg->fg_battery_check(p->pbat->fg, p); + + if (strcmp(argv[3], "charge") == 0) { + if (p->pbat) { + printf("PRINT BAT charge %s\n", p->name); + if (p->low_power_mode) + p->low_power_mode(); + if (p->pbat->battery_charge) + p->pbat->battery_charge(p); + } + } + + return CMD_RET_SUCCESS; + } + /* No subcommand found */ return CMD_RET_SUCCESS; } @@ -201,7 +224,9 @@ U_BOOT_CMD( pmic, CONFIG_SYS_MAXARGS, 1, do_pmic, "PMIC", "list - list available PMICs\n" - "pmic dump name - dump named PMIC registers\n" + "pmic name dump - dump named PMIC registers\n" "pmic name read <reg> - read register\n" - "pmic name write <reg> <value> - write register" + "pmic name write <reg> <value> - write register\n" + "pmic name bat state - write register\n" + "pmic name bat charge - write register\n" );
Rename pmic/power related files at ./drivers/power directory
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v3: - New patch at v3. Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/power/Makefile | 10 +++++----- drivers/power/{pmic_core.c => power_core.c} | 0 drivers/power/{pmic_dialog.c => power_dialog.c} | 0 drivers/power/{pmic_fsl.c => power_fsl.c} | 0 drivers/power/{pmic_i2c.c => power_i2c.c} | 0 drivers/power/{pmic_spi.c => power_spi.c} | 0 6 files changed, 5 insertions(+), 5 deletions(-) rename drivers/power/{pmic_core.c => power_core.c} (100%) rename drivers/power/{pmic_dialog.c => power_dialog.c} (100%) rename drivers/power/{pmic_fsl.c => power_fsl.c} (100%) rename drivers/power/{pmic_i2c.c => power_i2c.c} (100%) rename drivers/power/{pmic_spi.c => power_spi.c} (100%)
diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 7fc5554..7733e01 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -31,11 +31,11 @@ COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o COBJS-$(CONFIG_TWL6035_POWER) += twl6035.o
-COBJS-$(CONFIG_PMIC) += pmic_core.o -COBJS-$(CONFIG_DIALOG_PMIC) += pmic_dialog.o -COBJS-$(CONFIG_PMIC_FSL) += pmic_fsl.o -COBJS-$(CONFIG_PMIC_I2C) += pmic_i2c.o -COBJS-$(CONFIG_PMIC_SPI) += pmic_spi.o +COBJS-$(CONFIG_PMIC) += power_core.o +COBJS-$(CONFIG_DIALOG_PMIC) += power_dialog.o +COBJS-$(CONFIG_PMIC_FSL) += power_fsl.o +COBJS-$(CONFIG_PMIC_I2C) += power_i2c.o +COBJS-$(CONFIG_PMIC_SPI) += power_spi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/power/pmic_core.c b/drivers/power/power_core.c similarity index 100% rename from drivers/power/pmic_core.c rename to drivers/power/power_core.c diff --git a/drivers/power/pmic_dialog.c b/drivers/power/power_dialog.c similarity index 100% rename from drivers/power/pmic_dialog.c rename to drivers/power/power_dialog.c diff --git a/drivers/power/pmic_fsl.c b/drivers/power/power_fsl.c similarity index 100% rename from drivers/power/pmic_fsl.c rename to drivers/power/power_fsl.c diff --git a/drivers/power/pmic_i2c.c b/drivers/power/power_i2c.c similarity index 100% rename from drivers/power/pmic_i2c.c rename to drivers/power/power_i2c.c diff --git a/drivers/power/pmic_spi.c b/drivers/power/power_spi.c similarity index 100% rename from drivers/power/pmic_spi.c rename to drivers/power/power_spi.c
Rename all CONFIG_PMIC* defines to CONFIG_POWER*
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v3: - New patch at v3. Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- board/samsung/goni/goni.c | 2 +- board/samsung/universal_c210/universal.c | 2 +- drivers/power/Makefile | 8 ++++---- drivers/power/pmic/Makefile | 4 ++-- drivers/power/power_fsl.c | 8 ++++---- include/configs/imx31_litekit.h | 6 +++--- include/configs/mx31ads.h | 6 +++--- include/configs/mx31pdk.h | 6 +++--- include/configs/mx35pdk.h | 6 +++--- include/configs/mx51_efikamx.h | 6 +++--- include/configs/mx51evk.h | 6 +++--- include/configs/mx53evk.h | 6 +++--- include/configs/mx53loco.h | 6 +++--- include/configs/qong.h | 6 +++--- include/configs/s5p_goni.h | 6 +++--- include/configs/s5pc210_universal.h | 6 +++--- include/configs/trats.h | 6 +++--- include/configs/tt01.h | 6 +++--- include/configs/vision2.h | 6 +++--- 19 files changed, 54 insertions(+), 54 deletions(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 71ed618..50e9210 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -41,7 +41,7 @@ int board_init(void) gd->bd->bi_arch_number = MACH_TYPE_GONI; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
-#if defined(CONFIG_PMIC) +#if defined(CONFIG_POWER) pmic_init(I2C_5); #endif
diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index c4950dd..9849c6d 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -58,7 +58,7 @@ int board_init(void) gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 7733e01..2723724 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -31,11 +31,11 @@ COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o COBJS-$(CONFIG_TWL6035_POWER) += twl6035.o
-COBJS-$(CONFIG_PMIC) += power_core.o +COBJS-$(CONFIG_POWER) += power_core.o COBJS-$(CONFIG_DIALOG_PMIC) += power_dialog.o -COBJS-$(CONFIG_PMIC_FSL) += power_fsl.o -COBJS-$(CONFIG_PMIC_I2C) += power_i2c.o -COBJS-$(CONFIG_PMIC_SPI) += power_spi.o +COBJS-$(CONFIG_POWER_FSL) += power_fsl.o +COBJS-$(CONFIG_POWER_I2C) += power_i2c.o +COBJS-$(CONFIG_POWER_SPI) += power_spi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 9b71e55..e19a9a8 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -25,8 +25,8 @@ include $(TOPDIR)/config.mk
-COBJS-$(CONFIG_PMIC_MAX8998) += pmic_max8998.o -COBJS-$(CONFIG_PMIC_MAX8997) += pmic_max8997.o +COBJS-$(CONFIG_POWER_MAX8998) += pmic_max8998.o +COBJS-$(CONFIG_POWER_MAX8997) += pmic_max8997.o COBJS-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o
COBJS := $(COBJS-y) diff --git a/drivers/power/power_fsl.c b/drivers/power/power_fsl.c index 0275fd9..651f88f 100644 --- a/drivers/power/power_fsl.c +++ b/drivers/power/power_fsl.c @@ -27,7 +27,7 @@ #include <fsl_pmic.h> #include <errno.h>
-#if defined(CONFIG_PMIC_SPI) +#if defined(CONFIG_POWER_SPI) static u32 pmic_spi_prepare_tx(u32 reg, u32 *val, u32 write) { return (write << 31) | (reg << 25) | (*val & 0x00FFFFFF); @@ -47,7 +47,7 @@ int pmic_init(unsigned char bus) p->name = name; p->number_of_regs = PMIC_NUM_OF_REGS;
-#if defined(CONFIG_PMIC_SPI) +#if defined(CONFIG_POWER_SPI) p->interface = PMIC_SPI; p->bus = CONFIG_FSL_PMIC_BUS; p->hw.spi.cs = CONFIG_FSL_PMIC_CS; @@ -56,13 +56,13 @@ int pmic_init(unsigned char bus) p->hw.spi.bitlen = CONFIG_FSL_PMIC_BITLEN; p->hw.spi.flags = SPI_XFER_BEGIN | SPI_XFER_END; p->hw.spi.prepare_tx = pmic_spi_prepare_tx; -#elif defined(CONFIG_PMIC_I2C) +#elif defined(CONFIG_POWER_I2C) p->interface = PMIC_I2C; p->hw.i2c.addr = CONFIG_SYS_FSL_PMIC_I2C_ADDR; p->hw.i2c.tx_num = 3; p->bus = bus; #else -#error "You must select CONFIG_PMIC_SPI or CONFIG_PMIC_I2C" +#error "You must select CONFIG_POWER_SPI or CONFIG_PMIC_I2C" #endif
return 0; diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 6ae764a..8fc3942 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -72,9 +72,9 @@ #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
/* PMIC Controller */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 1000000 diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 9d9f4a7..9e4006b4 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -68,9 +68,9 @@ #define CONFIG_MXC_GPIO
/* PMIC Controller */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 1000000 diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 223b5b0..3b86c9e 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -69,9 +69,9 @@ #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
/* PMIC Controller */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 2 #define CONFIG_FSL_PMIC_CLK 1000000 diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 826c912..342d53f 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -65,9 +65,9 @@ /* * PMIC Configs */ -#define CONFIG_PMIC -#define CONFIG_PMIC_I2C -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_FSL #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x08 #define CONFIG_RTC_MC13XXX
diff --git a/include/configs/mx51_efikamx.h b/include/configs/mx51_efikamx.h index ffe771f..3c1c056 100644 --- a/include/configs/mx51_efikamx.h +++ b/include/configs/mx51_efikamx.h @@ -127,9 +127,9 @@ #endif
/* SPI PMIC */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 0 #define CONFIG_FSL_PMIC_CS (0 | 120 << 8) #define CONFIG_FSL_PMIC_CLK 25000000 diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 225d359..f00cec2 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -69,9 +69,9 @@ #define CONFIG_MXC_SPI
/* PMIC Controller */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 0 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 2500000 diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index d1f684c..1916b85 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -55,9 +55,9 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* PMIC Configs */ -#define CONFIG_PMIC -#define CONFIG_PMIC_I2C -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_FSL #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 8 #define CONFIG_RTC_MC13XXX
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index a1b27ce..d16de33 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -89,10 +89,10 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* PMIC Controller */ -#define CONFIG_PMIC -#define CONFIG_PMIC_I2C +#define CONFIG_POWER +#define CONFIG_POWER_I2C #define CONFIG_DIALOG_PMIC -#define CONFIG_PMIC_FSL +#define CONFIG_POWER_FSL #define CONFIG_SYS_DIALOG_PMIC_I2C_ADDR 0x48 #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x8
diff --git a/include/configs/qong.h b/include/configs/qong.h index e43a021..d9bf201 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -58,9 +58,9 @@ #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_RTC_MC13XXX
-#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 100000 diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 7e0b302..56e8347 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -215,9 +215,9 @@
#define CONFIG_SYS_CACHELINE_SIZE 64
-#define CONFIG_PMIC -#define CONFIG_PMIC_I2C -#define CONFIG_PMIC_MAX8998 +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_MAX8998
#include <asm/arch/gpio.h> /* diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 5fc6136..894f38b 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -253,9 +253,9 @@ #define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_MAX_I2C_BUS 7
#define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_S3C_UDC_OTG diff --git a/include/configs/trats.h b/include/configs/trats.h index 2fdc597..355029e 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -234,9 +234,9 @@ #define CONFIG_SOFT_I2C_GPIO_SDA get_multi_sda_pin() #define I2C_INIT multi_i2c_init()
-#define CONFIG_PMIC -#define CONFIG_PMIC_I2C -#define CONFIG_PMIC_MAX8997 +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_MAX8997
#define CONFIG_POWER_FG #define CONFIG_POWER_FG_MAX17042 diff --git a/include/configs/tt01.h b/include/configs/tt01.h index f46efa5..9f8f240 100644 --- a/include/configs/tt01.h +++ b/include/configs/tt01.h @@ -149,9 +149,9 @@ #define CONFIG_MXC_GPIO
/* MC13783 connected to CSPI3 and SS0 */ -#define CONFIG_PMIC -#define CONFIG_PMIC_SPI -#define CONFIG_PMIC_FSL +#define CONFIG_POWER +#define CONFIG_POWER_SPI +#define CONFIG_POWER_FSL
#define CONFIG_FSL_PMIC_BUS 2 #define CONFIG_FSL_PMIC_CS 0 diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 848df88..a72010f 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -87,9 +87,9 @@ #define CONFIG_ENV_IS_IN_SPI_FLASH
Rename CONFIG_DIALOG_PMIC to CONFIG_DIALOG_POWER
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- Changes for v3: - New patch at v3. Changes for v4: - None Changes for v5: - None Changes for v6: - None Changes for v7: - None --- drivers/power/Makefile | 2 +- include/configs/mx53loco.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/Makefile b/drivers/power/Makefile index 2723724..8c71901 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -32,7 +32,7 @@ COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o COBJS-$(CONFIG_TWL6035_POWER) += twl6035.o
COBJS-$(CONFIG_POWER) += power_core.o -COBJS-$(CONFIG_DIALOG_PMIC) += power_dialog.o +COBJS-$(CONFIG_DIALOG_POWER) += power_dialog.o COBJS-$(CONFIG_POWER_FSL) += power_fsl.o COBJS-$(CONFIG_POWER_I2C) += power_i2c.o COBJS-$(CONFIG_POWER_SPI) += power_spi.o diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index d16de33..a110176 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -91,7 +91,7 @@ /* PMIC Controller */ #define CONFIG_POWER #define CONFIG_POWER_I2C -#define CONFIG_DIALOG_PMIC +#define CONFIG_DIALOG_POWER #define CONFIG_POWER_FSL #define CONFIG_SYS_DIALOG_PMIC_I2C_ADDR 0x48 #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x8
Move pmic_init() function call from board_init() to power_init_board() to work with new PMIC/POWER framework.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - New patch at v5. Changes for v6: - None Changes for v7: - Check pmic_init() return value --- board/samsung/goni/goni.c | 13 ++++++++++--- 1 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index 50e9210..ff76963 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -41,9 +41,16 @@ int board_init(void) gd->bd->bi_arch_number = MACH_TYPE_GONI; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
-#if defined(CONFIG_POWER) - pmic_init(I2C_5); -#endif + return 0; +} + +int power_init_board(void) +{ + int ret; + + ret = pmic_init(I2C_5); + if (ret) + return ret;
return 0; }
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v5: - New patch at v5. Changes for v6: - None Changes for v7: - Check pmic_init() return value --- board/samsung/universal_c210/universal.c | 15 +++++++++++---- 1 files changed, 11 insertions(+), 4 deletions(-)
diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 9849c6d..36a0472 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -58,16 +58,23 @@ int board_init(void) gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
-#if defined(CONFIG_POWER) - pmic_init(I2C_5); -#endif - check_hw_revision(); printf("HW Revision:\t0x%x\n", board_rev);
return 0; }
+int power_init_board(void) +{ + int ret; + + ret = pmic_init(I2C_5); + if (ret) + return ret; + + return 0; +} + int dram_init(void) { gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) +
On Tue, 13 Nov 2012 14:21:51 +0100 Lukasz Majewski l.majewski@samsung.com wrote: ...
Lukasz Majewski (26): pmic:i2c: Handle PMIC I2C transmission comprising of two bytes pmic:i2c: Add I2C sensor byte order (big/little) to PMIC framework pmic:max8997: Switch the MAX8997 PMIC to be used with multibus I2C pmic: Extend PMIC framework to support multiple instances of PMIC devices pmic: Introduce power_init_board() method at ./lib/board.c file pmic: Enable power_board_init() support at TRATS pmic:chrg: Common information about charger and battery (power_chrg.h) pmic: Move pmic related code to ./drivers/power directory pmic: Extend struct pmic to support battery and charger related operations pmic:battery: Support for Trats Battery at PMIC framework pmic:muic: Support for MUIC built into MAX8997 device pmic:fuel-gauge: Support for MAX17042 fuel-gauge pmic:max8997: Function for calculating LDO internal register value arm:trats:pmic: Default PMIC(MAX8997) initialization for Samsung's TRATS board arm:trats:pmic: Enable MUIC (MAX8997) at Samsung's TRATS board arm:trats:pmic: Enable fuel-gauge (MAX17042) at Samsung's TRATS board arm:trats:pmic: Enable battery support at Samsung's TRATS board pmic:max8997: Support for MAX8997 internal charger control arm:trats:pmic: Power consumption reduction state for Samsung's TRATS board arm:trats:pmic: Support for charging battery at Samsung's TRATS board pmic: Extend PMIC framework to support battery related commands power:pmic: Rename ./drivers/power/pmic_* to ./drivers/power/power_* files power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWER power:pmic: Rename CONFIG_DIALOG_PMIC defines to CONFIG_DIALOG_POWER arm:goni:pmic: Adjust GONI target platform board to new PMIC framework arm:universal_c210:pmic: Adjust C210 Universal target platform board to new PMIC framework
Makefile | 5 +- arch/arm/lib/board.c | 8 + board/davedenx/qong/qong.c | 12 +- board/freescale/mx31pdk/mx31pdk.c | 12 +- board/freescale/mx35pdk/mx35pdk.c | 14 +- board/freescale/mx51evk/mx51evk.c | 12 +- board/freescale/mx53evk/mx53evk.c | 12 +- board/freescale/mx53loco/mx53loco.c | 21 +- board/genesi/mx51_efikamx/efikamx.c | 12 +- board/hale/tt01/tt01.c | 14 +- board/samsung/goni/goni.c | 22 +- board/samsung/trats/trats.c | 292 +++++++++++++++++++- board/samsung/universal_c210/universal.c | 27 ++- board/ttcontrol/vision2/vision2.c | 12 +- drivers/misc/Makefile | 7 - drivers/misc/pmic_core.c | 147 ---------- drivers/misc/pmic_i2c.c | 98 ------- drivers/misc/pmic_max8997.c | 43 --- drivers/power/Makefile | 12 +- drivers/power/battery/Makefile | 47 ++++ drivers/power/battery/bat_trats.c | 100 +++++++ drivers/power/fuel_gauge/Makefile | 47 ++++ drivers/power/fuel_gauge/fg_max17042.c | 250 +++++++++++++++++ drivers/power/pmic/Makefile | 49 ++++ drivers/power/pmic/muic_max8997.c | 90 ++++++ drivers/power/pmic/pmic_max8997.c | 123 ++++++++ drivers/{misc => power/pmic}/pmic_max8998.c | 16 +- drivers/power/power_core.c | 232 ++++++++++++++++ .../{misc/pmic_dialog.c => power/power_dialog.c} | 14 +- drivers/{misc/pmic_fsl.c => power/power_fsl.c} | 22 +- drivers/power/power_i2c.c | 125 +++++++++ drivers/{misc/pmic_spi.c => power/power_spi.c} | 4 +- drivers/rtc/mc13xxx-rtc.c | 10 +- include/configs/imx31_litekit.h | 6 +- include/configs/mx31ads.h | 6 +- include/configs/mx31pdk.h | 6 +- include/configs/mx35pdk.h | 6 +- include/configs/mx51_efikamx.h | 6 +- include/configs/mx51evk.h | 6 +- include/configs/mx53evk.h | 6 +- include/configs/mx53loco.h | 8 +- include/configs/qong.h | 6 +- include/configs/s5p_goni.h | 6 +- include/configs/s5pc210_universal.h | 6 +- include/configs/trats.h | 14 +- include/configs/tt01.h | 6 +- include/configs/vision2.h | 6 +- include/pmic.h | 72 ----- include/power/battery.h | 38 +++ include/power/fg_battery_cell_params.h | 90 ++++++ include/power/max17042_fg.h | 74 +++++ include/power/max8997_muic.h | 61 ++++ include/{ => power}/max8997_pmic.h | 26 ++- include/{ => power}/max8998_pmic.h | 0 include/power/pmic.h | 109 ++++++++ include/power/power_chrg.h | 43 +++ 56 files changed, 2027 insertions(+), 491 deletions(-) delete mode 100644 drivers/misc/pmic_core.c delete mode 100644 drivers/misc/pmic_i2c.c delete mode 100644 drivers/misc/pmic_max8997.c create mode 100644 drivers/power/battery/Makefile create mode 100644 drivers/power/battery/bat_trats.c create mode 100644 drivers/power/fuel_gauge/Makefile create mode 100644 drivers/power/fuel_gauge/fg_max17042.c create mode 100644 drivers/power/pmic/Makefile create mode 100644 drivers/power/pmic/muic_max8997.c create mode 100644 drivers/power/pmic/pmic_max8997.c rename drivers/{misc => power/pmic}/pmic_max8998.c (82%) create mode 100644 drivers/power/power_core.c rename drivers/{misc/pmic_dialog.c => power/power_dialog.c} (81%) rename drivers/{misc/pmic_fsl.c => power/power_fsl.c} (81%) create mode 100644 drivers/power/power_i2c.c rename drivers/{misc/pmic_spi.c => power/power_spi.c} (97%) delete mode 100644 include/pmic.h create mode 100644 include/power/battery.h create mode 100644 include/power/fg_battery_cell_params.h create mode 100644 include/power/max17042_fg.h create mode 100644 include/power/max8997_muic.h rename include/{ => power}/max8997_pmic.h (88%) rename include/{ => power}/max8998_pmic.h (100%) create mode 100644 include/power/pmic.h create mode 100644 include/power/power_chrg.h
Appied this series to staging/agust@denx.de, thanks!
Anatolij
Well written documentation for PMIC framework was missing and hence it has been probably difficult and time consuming for other developers to understand rationale for key design decisions and overall design structure. This commit provides proper documentation entry.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com --- doc/README.power-framework | 166 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 166 insertions(+) create mode 100644 doc/README.power-framework
diff --git a/doc/README.power-framework b/doc/README.power-framework new file mode 100644 index 0000000..1f6fd43 --- /dev/null +++ b/doc/README.power-framework @@ -0,0 +1,166 @@ +# +# (C) Copyright 2014 Samsung Electronics +# Lukasz Majewski l.majewski@samsung.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +Introduction +------------ + +This document describes the second version of the u-boot's PMIC (Power +Management IC) framework. As a reference boards please consider Samsungs' Trats +and Trats2. + +Background +---------- + +Boards supported by u-boot are getting increasingly complex. Developers and +designers strive to cut down power consumption. Hence several different types of +devices are now available on the board - namely power managers (PMIC), fuel +gauges (FG), micro USB interface controllers (MUIC), batteries, multi-function +devices (MFD). + +Explanation of key design decisions +----------------------------------- + +One package can integrate PMIC and MUIC with different addresses on the I2C bus. +The same device - e.g. MAX8997 uses two different I2C busses and addresses. + +Power devices use not only I2C for communication, but SPI as well. Additionally +different ICs use different endianess. For this reason struct pmic holds +information about I2C/SPI transmission, which is used with generic +pmic_req_write() function. + +The "flat" hierarchy for power devices works well when each device performs only +one operation - e.g. PMIC enables LDO. + +The problem emerges when we have a device (battery) which conceptually shall be +the master and uses methods exported by other devices. We need to control MUIC +to start charging the battery, use PMIC to reduce board's overall power +consumption (by disabling not needed LDOs, BUCKs) and get current state of +energy on the battery from FG. +Up till now u-boot doesn't support device model, so a simple one had to be +added. + +The directory hierarchy has following structure: +./include/power/<device_name>_<device_function>.h +e.g. ./include/power/max8997_pmic.h + +./drivers/power/pmic/power_{core files}.c +e.g. ./drivers/power/pmic/power_core.c + +./drivers/power/pmic/<device_function>/<device_function>_<device_name>.c +e.g. ./drivers/power/pmic/pmic_max8997.c +e.g. ./drivers/power/battery/trats/bat_trats.c +e.g. ./drivers/power/fuel_gauge/fg_max17042.c + +The framework classifies devices by their function - separate directories should +be maintained for different classes of devices. + +Current design +-------------- + +Everything is a power device described by struct pmic. Even battery is +considered as a valid power device. This helps for better management of those +devices. + +- Block diagram of the hierarchy: + ----------------- + --------| BAT |------------ + | | | | + | ----------------- | + | | | + |/ |/ |/ + ----------- ----------------- --------- + |FG | |MUIC | |CHRG | + | | | | | | + ----------- ----------------- --------- + + +1. When hierarchy is not needed (no complex battery charge): + +Definition of the struct pmic is only required with proper name and parameters +for communication. This is enough to use the "pmic" command in the u-boot +prompt to change values of device's register (enable/disable LDO, BUCK). + +The PG, MUIC and CHRG above are regarded to be in the same level in the +hierarchy. + +2. Complex battery charging. + +To charge a battery, information from several "abstract" power devices is +needed (defined at ./include/power/pmic.h): +- FG device (struct power_fg): + -- *fg_battery_check - check if battery is not above its limits + -- *fg_battery_update - update the pmic framework with current + battery state(voltage and current capacity) + +- Charger device (struct power_chrq): + -- *chrg_type - type/capacity of the charger (including information + about USB cable disconnection) + -- *chrg_bat_present - detection if battery to be charged is + present + -- *chrg_state - status of the charger - if it is enabled or + disabled + +- Battery device (struct power_battery): + -- *battery_init - assign proper callbacks to be used by top + hierarchy battery device + -- *battery_charge - called from "pmic" command, responsible + for performing the charging + +Now two batteries are supported; trats and trats2 [*]. Those differ in the way +how they handle the exact charging. Trats uses polling (MAX8997) and trats2 +relies on the PMIC/MUIC HW completely (MAX77693). + +__Example for trats (this can be very different for other board):__ + -- *fg_battery_check -> FG device (fg_max17042.c) + -- *fg_battery_update -> FG device (fg_max17042.c) + -- *chrg_type -> MUIC device (muic_max8997.c) + -- *chrg_bat_present -> PMIC device (pmic_max8997.c) + -- *chrg_state -> PMIC device (pmic_max8997.c) + -- *battery_init -> BAT device (bat_trats.c) + -- *battery_charge -> BAT device (bat_trats.c) + +Also the struct pmic holds method (*low_power_mode) for reducing board's +power consumption when one calls "pmic BAT_TRATS bat charge" command. + +How to add a new power device +----------------------------- + +1. Simple device should be added with creation of file +<pmic_function>_<pmic_name>.c, <pmic_name>_<pmic_function>.h according to the +proposed and described above scheme. + +Then "pmic" command supports reading/writing/dump of device's internal +registers. + +2. Charging battery with hierarchy +Define devices as listed at 1. + +Define battery file (bat_<board>.c). Please also note that one might need a +corresponding battery model description for FG. + +For points 1 and 2 use a generic function power_init_board() to initialise the +power framework on your board. + +For reference, please look into the trats/trats2 boards. + +TO DO list (for PMICv3) - up till v2014.04 +------------------------------------------ + +1. Description of the devices related to power via device tree is not available. +This is the main problem when a developer tries to build a multi-boot u-boot +binary. The best would be to parse the DTS from Linux kernel. + +2. To support many instances of the same IC, like two MAX8997, one needs to +copy the corresponding pmic_max8997.c file with changed name to "MAX8997_PMICX", +where X is the device number. This problem will be addressed when extended +pmic_core.c will support storing available devices in a list. + +3. Definition of batteries [*] (for trats/trats2) should be excluded from the +code responsible for charging them and since it in fact describes the charging +profile it should be put to a separate file. + +4. Adjust the framework to work with the device model.
Hi Lukasz,
But it would be good to say "U-Boot"
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Simon Glass sjg@chromium.org
Anatolij Gustschin
Lukasz Majewski
