[U-Boot] [PATCH] ARMV7: S5PC210: Fixed register offset in mmc.h
MMC controller "control4" register offset set to 0x8C as per data sheet. Added missed out reserved field. Updated padding field size.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org Signed-off-by: Tushar Behera tushar.behera@linaro.org --- arch/arm/include/asm/arch-s5pc2xx/mmc.h | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-s5pc2xx/mmc.h b/arch/arm/include/asm/arch-s5pc2xx/mmc.h index 528150d..04827ca 100644 --- a/arch/arm/include/asm/arch-s5pc2xx/mmc.h +++ b/arch/arm/include/asm/arch-s5pc2xx/mmc.h @@ -53,10 +53,11 @@ struct s5p_mmc { unsigned char res3[0x34]; unsigned int control2; unsigned int control3; + unsigned char res4[4]; unsigned int control4; - unsigned char res4[0x6e]; + unsigned char res5[0x6e]; unsigned short hcver; - unsigned char res5[0xFF02]; + unsigned char res6[0xFF00]; };
struct mmc_host {
Dear Chander Kashyap,
- unsigned char res4[4];
- unsigned char res5[0x6e];
- unsigned char res6[0xFF00];
struct mmc_host {
Thanks for patch. But, you should fix s5pc1xx also. Please send next patch.
Thanks. Minkyu Kang.
Chander Kashyap
Minkyu Kang
